GPU Empty work server assignment in Ubuntu
Kebast
Post by Kebast »
Is this configuration valid? I get assigned core 18 WU if I remove the max-packet-size flag, but those take 7-10 days each on these cards. This works fine in Windows7, and I get plenty of core 15 WUs. Any tips?
*********************** Log Started 2015-10-14T16:04:53Z ***********************
16:04:53:************************* Folding@home Client *************************
16:04:53:    Website: http://folding.stanford.edu/
16:04:53:  Copyright: (c) 2009-2014 Stanford University
16:04:53:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:04:53:       Args: --child --lifeline 1276 /etc/fahclient/config.xml --run-as
16:04:53:             fahclient --pid-file=/var/run/fahclient.pid --daemon
16:04:53:     Config: /etc/fahclient/config.xml
16:04:53:******************************** Build ********************************
16:04:53:    Version: 7.4.4
16:04:53:       Date: Mar 4 2014
16:04:53:       Time: 12:02:38
16:04:53:    SVN Rev: 4130
16:04:53:     Branch: fah/trunk/client
16:04:53:   Compiler: GNU 4.4.7
16:04:53:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
16:04:53:             -fno-unsafe-math-optimizations -msse2
16:04:53:   Platform: linux2 3.2.0-1-amd64
16:04:53:       Bits: 64
16:04:53:       Mode: Release
16:04:53:******************************* System ********************************
16:04:53:        CPU: Intel(R) Xeon(R) CPU E5603 @ 1.60GHz
16:04:53:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
16:04:53:       CPUs: 8
16:04:53:     Memory: 3.85GiB
16:04:53:Free Memory: 3.41GiB
16:04:53:    Threads: POSIX_THREADS
16:04:53: OS Version: 3.13
16:04:53:Has Battery: false
16:04:53: On Battery: false
16:04:53: UTC Offset: -4
16:04:53:        PID: 1278
16:04:53:        CWD: /var/lib/fahclient
16:04:53:         OS: Linux 3.13.0-65-generic x86_64
16:04:53:    OS Arch: AMD64
16:04:53:       GPUs: 2
16:04:53:      GPU 0: NVIDIA:2 GF108 [Quadro 600]
16:04:53:      GPU 1: NVIDIA:2 GF108 [Quadro 600]
16:04:53:       CUDA: 2.1
16:04:53:CUDA Driver: 7000
16:04:53:***********************************************************************
16:04:53:<config>
16:04:53:  <!-- Client Control -->
16:04:53:  <fold-anon v='true'/>
16:04:53:
16:04:53:  <!-- Folding Slot Configuration -->
16:04:53:  <gpu v='false'/>
16:04:53:
16:04:53:  <!-- Network -->
16:04:53:  <proxy v=':8080'/>
16:04:53:
16:04:53:  <!-- Slot Control -->
16:04:53:  <power v='full'/>
16:04:53:
16:04:53:  <!-- User Information -->
16:04:53:  <passkey v='********************************'/>
16:04:53:  <team v='229226'/>
16:04:53:  <user v='Kebast'/>
16:04:53:
16:04:53:  <!-- Folding Slots -->
16:04:53:  <slot id='0' type='CPU'>
16:04:53:    <cpus v='8'/>
16:04:53:    <paused v='true'/>
16:04:53:  </slot>
16:04:53:  <slot id='1' type='GPU'>
16:04:53:    <max-packet-size v='small'/>
16:04:53:  </slot>
16:04:53:  <slot id='2' type='GPU'>
16:04:53:  </slot>
16:04:53:</config>
16:04:53:Switching to user fahclient
16:04:53:Trying to access database...
16:04:53:Successfully acquired database lock
16:04:53:Enabled folding slot 00: PAUSED cpu:8 (by user)
16:04:53:Enabled folding slot 01: PAUSED gpu:0:GF108 [Quadro 600] (by user)
16:04:53:Enabled folding slot 02: PAUSED gpu:1:GF108 [Quadro 600] (by user)
16:05:47:FS00:Unpaused
16:05:47:FS01:Unpaused
16:05:47:FS02:Unpaused
16:05:47:WU00:FS00:Starting
16:05:47:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1278 -checkpoint 15 -np 8
16:05:47:WU00:FS00:Started FahCore on PID 2590
16:05:47:WU00:FS00:Core PID:2594
16:05:47:WU00:FS00:FahCore 0xa4 started
16:05:48:WU01:FS01:Connecting to 171.67.108.45:80
16:05:48:WU02:FS02:Connecting to 171.67.108.45:80
16:05:48:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
16:05:48:WU01:FS01:Connecting to 171.67.108.204:80
16:05:48:WARNING:WU02:FS02:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
16:05:48:WU02:FS02:Connecting to 171.67.108.204:80
16:05:48:WU00:FS00:0xa4:
16:05:48:WU00:FS00:0xa4:*------------------------------*
16:05:48:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
16:05:48:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
16:05:48:WU00:FS00:0xa4:Preparing to commence simulation
16:05:48:WU00:FS00:0xa4:- Looking at optimizations...
16:05:48:WU00:FS00:0xa4:- Files status OK
16:05:48:WU00:FS00:0xa4:- Expanded 825562 -> 1399936 (decompressed 169.5 percent)
16:05:48:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825562 data_size=1399936, decompressed_data_size=1399936 diff=0
16:05:48:WU00:FS00:0xa4:- Digital signature verified
16:05:48:WU00:FS00:0xa4:Project: 9018 (Run 200, Clone 2, Gen 23)
16:05:48:WU00:FS00:0xa4:Assembly optimizations on if available.
16:05:48:WU00:FS00:0xa4:Entering M.D.
16:05:48:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
16:05:48:ERROR:WU01:FS01:Exception: Could not get an assignment
16:05:48:WARNING:WU02:FS02:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
16:05:48:ERROR:WU02:FS02:Exception: Could not get an assignment
16:05:49:WU01:FS01:Connecting to 171.67.108.45:80
16:05:49:WU02:FS02:Connecting to 171.67.108.45:80
16:05:49:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
16:05:49:WU01:FS01:Connecting to 171.67.108.204:80
16:05:49:WARNING:WU02:FS02:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
16:05:49:WU02:FS02:Connecting to 171.67.108.204:80
16:05:49:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
16:05:49:ERROR:WU01:FS01:Exception: Could not get an assignment
16:05:50:WARNING:WU02:FS02:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
16:05:50:ERROR:WU02:FS02:Exception: Could not get an assignment
16:05:54:Removing old file 'configs/config-20151012-142446.xml'
16:05:54:Saving configuration to /etc/fahclient/config.xml
16:05:54:<config>
16:05:54:  <!-- Client Control -->
16:05:54:  <fold-anon v='true'/>
16:05:54:
16:05:54:  <!-- Folding Slot Configuration -->
16:05:54:  <gpu v='false'/>
16:05:54:
16:05:54:  <!-- Network -->
16:05:54:  <proxy v=':8080'/>
16:05:54:
16:05:54:  <!-- Slot Control -->
16:05:54:  <power v='full'/>
16:05:54:
16:05:54:  <!-- User Information -->
16:05:54:  <passkey v='********************************'/>
16:05:54:  <team v='229226'/>
16:05:54:  <user v='Kebast'/>
16:05:54:
16:05:54:  <!-- Folding Slots -->
16:05:54:  <slot id='0' type='CPU'>
16:05:54:    <cpus v='8'/>
16:05:54:  </slot>
16:05:54:  <slot id='1' type='GPU'>
16:05:54:    <max-packet-size v='small'/>
16:05:54:  </slot>
16:05:54:  <slot id='2' type='GPU'>
16:05:54:  </slot>
16:05:54:</config>
16:05:55:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
Ryzen 5900x 12T - RTX 4070 TI
Re: GPU Empty work server assignment in Ubuntu
Core_15 was only made available for Windows, a Linux version is not available. So any of the WU's from the remaining 8 Core_15 projects are Windows only and setting the options to indicate a preference for Core_15 will only work for assignments to Windows machines.
Kebast
Post by Kebast »
Thanks for the clarification. I'll just switch this one back to windows then.
