9206 (Run 0, Clone 72, Gen 28) Bad State detected
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
GTX 970 @ 1400 MHz; Win7/64b; Driver 355.60
This WU was running without throttling.
15:06:35:WU01:FS00:0x21:Completed 2400000 out of 2500000 steps (96%)
15:06:56:WU01:FS00:0x21:Bad State detected... attempting to resume from last good checkpoint
15:06:56:WU01:FS00:0x21:Max number of retries reached. Aborting.
04:58:01:WU01:FS00:Started FahCore on PID 4588
04:58:01:WU01:FS00:Core PID:5272
04:58:01:WU01:FS00:FahCore 0x21 started
04:58:01:WU01:FS00:0x21:*********************** Log Started 2015-10-11T04:58:01Z ***********************
04:58:01:WU01:FS00:0x21:Project: 9206 (Run 0, Clone 72, Gen 28)
04:58:01:WU01:FS00:0x21:Unit: 0x00000022664f2dd055db893b37c86e4d
04:58:01:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
04:58:01:WU01:FS00:0x21:Machine: 0
04:58:01:WU01:FS00:0x21:Reading tar file core.xml
04:58:01:WU01:FS00:0x21:Reading tar file system.xml
04:58:02:WU01:FS00:0x21:Reading tar file integrator.xml
04:58:02:WU01:FS00:0x21:Reading tar file state.xml
04:58:03:WU01:FS00:0x21:Digital signatures verified
04:58:03:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
04:58:03:WU01:FS00:0x21:Version 0.0.12
04:59:08:WU01:FS00:0x21:Completed 0 out of 2500000 steps (0%)
04:59:08:WU01:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:05:14:WU01:FS00:0x21:Completed 25000 out of 2500000 steps (1%)
05:10:58:WU01:FS00:0x21:Completed 50000 out of 2500000 steps (2%)
09:56:51:WU01:FS00:0x21:Completed 1275000 out of 2500000 steps (51%)
10:02:35:WU01:FS00:0x21:Completed 1300000 out of 2500000 steps (52%)
10:02:56:WU01:FS00:0x21:Bad State detected... attempting to resume from last good checkpoint
10:08:41:WU01:FS00:0x21:Completed 1225000 out of 2500000 steps (49%)
10:14:25:WU01:FS00:0x21:Completed 1250000 out of 2500000 steps (50%)
11:53:41:WU01:FS00:0x21:Completed 1675000 out of 2500000 steps (67%)
11:59:26:WU01:FS00:0x21:Completed 1700000 out of 2500000 steps (68%)
11:59:47:WU01:FS00:0x21:Bad State detected... attempting to resume from last good checkpoint
12:05:31:WU01:FS00:0x21:Completed 1625000 out of 2500000 steps (65%)
12:11:15:WU01:FS00:0x21:Completed 1650000 out of 2500000 steps (66%)
14:55:03:WU01:FS00:0x21:Completed 2350000 out of 2500000 steps (94%)
15:00:49:WU01:FS00:0x21:Completed 2375000 out of 2500000 steps (95%)
15:06:56:WU01:FS00:0x21:ERROR:Max Retries Reached
15:06:56:WU01:FS00:0x21:Saving result file logfile_01.txt
15:06:56:WU01:FS00:0x21:Saving result file log.txt
15:06:56:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
15:06:57:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:06:57:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9206 run:0 clone:72 gen:28 core:0x21 unit:0x00000022664f2dd055db893b37c86e4d
15:06:57:WU01:FS00:Uploading 3.21KiB to 171.64.65.104
15:06:57:WU01:FS00:Connecting to 171.64.65.104:8080
15:06:57:WU00:FS00:Connecting to 171.67.108.45:80
15:06:57:WU01:FS00:Upload complete
15:06:57:WU01:FS00:Server responded WORK_ACK (400)
15:06:58:WU01:FS00:Cleaning up
Re: 9206 (Run 0, Clone 72, Gen 28) Bad State detected
Only your report is present at the moment ... but that's probably some usual core 21 radom bad states ...
ChristianVirtual
Post by ChristianVirtual »
At 96% it hurts ... :(
ChristianVirtual wrote:At 96% it hurts ... :(
Quite true, but I've seen a lot of WUs which were successfully completed after the first resuming from "a good checkpoint" I don't think you'd be any happier if it aborted at (52%) without even trying to continue.
I checked the DB again, and the WU has been completed by someone else.
