a couple of months a go, my fah client was unreachable. after a few weeks of nothing accomplished I remove the program and reloaded it from the information page and got it to accept my user name and team 142900. apparently I was not the only one on the team to have this problem.
since I started folding I was receiving both cpu and gpu wu and have it set up to fold any project cpu use 7 of 8 cores and gpu. most of the time I am folding on high except when I go into battle in a game. to reduce lag in game I set to light or pause until battle is finished, 30 to 45 minutes.
when I started folding in march I was getting 35 to 65k ppd. now I am lucky if I get 20k ppd?
so, am I now doing 1/3 the work?
my system is i7-4710mq 2.5 to 3.5 ghz 6m smartcashe/NVidia 860m x 4gb ram/ 16gb ddr3/1333 matched ram on a hm87 board
what has changed
rediornot
- Hardware configuration: fangbook 3 laptop i4710mq 6m smartcashe 2.5 to 3.50 mghz turbo
adata sata 3 6.0 Gb/s 256gb ssd, 16gb gskill ddr3-1333 ram, 1920x1080 fhd, nvida gtx 860m 4gb video - Location: Georgia, USA
what has changed
cyberpowerpc fangbook III hx6-200 6m smartcashe, i4710mq quadcore dual thread 2.5 to 3.5ghz turbo nvida gtx 860m 4gb, ADATA SATA 3 256gb 6.0 Gb/s SSD,1920x1080 FHD 15.6" laptop
Re: what has changed
When you reinstalled the folding client, did you remember to also set the passkey? That is the most likely reason for the drop in points.
We need to see you log : How to provide enough info to get helpful support.
rediornot
I did not use passkey, I entered user name and team number
rediornot
ok, thank you. found and entered passkey and points generated for the team will be close to 65k per day. didn't know that would make that much difference.
It makes that much difference because without one your WU's returned after the reinstall did not earn the Quick Return Bonus (QRB). The QRB significantly increases the points awarded, especially on faster CPU's and GPU's.
