Intermittent Fault
NikolaiDante
Intermittent Fault
Post by NikolaiDante »
Hi
My PC will successfully fold and post results for a few days (CPU & GPU) but will then suddenly not be able to contact the servers to post the results
Here is a snippet of the log :
08:15:38:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9121 run:3 clone:8 gen:213 core:0x18 unit:0x000000fc0a3b1e78553ea1f55ab05145
08:15:38:WU01:FS01:Uploading 6.62MiB to 171.64.65.84
08:15:38:WU01:FS01:Connecting to 171.64.65.84:8080
08:15:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:15:38:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.84:80: A socket operation was attempted to an unreachable network.
08:15:38:WU01:FS01:Trying to send results to collection server
08:15:39:WU01:FS01:Uploading 6.62MiB to 171.65.103.160
08:15:39:WU01:FS01:Connecting to 171.65.103.160:8080
08:15:39:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:15:39:ERROR:WU01:FS01:Exception: Failed to connect to 171.65.103.160:80: A socket operation was attempted to an unreachable network.
08:25:00:WARNING:WU03:FS00:Exception: Could not get IP address for assign3.stanford.edu: No such host is known.
08:25:00:ERROR:WU03:FS00:Exception: Could not get an assignment
08:27:04:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9022 run:237 clone:9 gen:23 core:0xa4 unit:0x00000020ab40417c55e8a3040bf586d6
08:27:04:WU00:FS00:Uploading 1.47MiB to 171.64.65.124
08:27:04:WU00:FS00:Connecting to 171.64.65.124:8080
08:27:04:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:27:04:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.124:80: A socket operation was attempted to an unreachable network.
08:27:04:WU00:FS00:Trying to send results to collection server
08:27:04:WU00:FS00:Uploading 1.47MiB to 171.65.103.160
08:27:04:WU00:FS00:Connecting to 171.65.103.160:8080
08:27:04:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: A socket operation was attempted to an unreachable network.
Currently I have WU that has tried 12 times to post and is now waiting over an hour before having another go.
The odd thing is that if I try to access the above IP address in a browser I get an instant response.
Any ideas what could cause this and how to get around it?
Also is there a way to get my PC to download several WU at a time so if this happens it can continue to work?
Barny
Mod edit: Please use Code tags instead of Quote tags around log postings
Re: Intermittent Fault
Do you have some security tool (firewall, anti virus, ...) that might prevent you from uploading ?
