171.64.65.56
ChristianVirtual
171.64.65.56
Post by ChristianVirtual »
CentOS 7, N970, 355.11
Any trouble with the WU before ? Finished 100% but refused
04:52:04:WU00:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
04:57:44:WU00:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
04:57:45:WU01:FS01:Connecting to 171.67.108.200:80
04:57:46:WU00:FS01:0x18:Saving result file logfile_01.txt
04:57:46:WU00:FS01:0x18:Saving result file checkpointState.xml
04:57:46:WU00:FS01:0x18:Saving result file checkpt.crc
04:57:46:WU00:FS01:0x18:Saving result file log.txt
04:57:46:WU00:FS01:0x18:Saving result file positions.xtc
04:57:49:WU00:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
04:57:50:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:57:50:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:5 clone:4 gen:81 core:0x18 unit:0x0000006cab40413855474b79a98b5adb
04:57:50:WU00:FS01:Uploading 24.01MiB to 171.64.65.56
04:57:50:WU00:FS01:Connecting to 171.64.65.56:8080
04:57:56:WU00:FS01:Upload 68.99%
04:57:58:WU00:FS01:Upload complete
04:57:58:WU00:FS01:Server responded WORK_QUIT (404)
04:57:58:WARNING:WU00:FS01:Server did not like results, dumping
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Re: project:9430 run:5 clone:4 gen:81 , disliked
Post by billford »
Similar here:
11:09:26:WU01:FS01:0x18:Completed 15680000 out of 16000000 steps (98%)
11:15:38:WU01:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
11:21:50:WU01:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
1:21:52:WU01:FS01:0x18:Saving result file logfile_01.txt
11:21:52:WU01:FS01:0x18:Saving result file checkpointState.xml
11:21:53:WU01:FS01:0x18:Saving result file checkpt.crc
11:21:53:WU01:FS01:0x18:Saving result file log.txt
11:21:53:WU01:FS01:0x18:Saving result file positions.xtc
1:21:57:WU01:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
11:21:57:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:21:57:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9430 run:57 clone:3 gen:131 core:0x18 unit:0x00000097ab40413855474cc5d675106a
11:21:57:WU01:FS01:Uploading 24.03MiB to 171.64.65.56
11:21:57:WU01:FS01:Connecting to 171.64.65.56:8080
11:22:03:WU01:FS01:Upload 32.52%
11:22:09:WU01:FS01:Upload 72.58%
11:22:13:WU01:FS01:Upload complete
11:22:13:WU01:FS01:Server responded WORK_QUIT (404)
11:22:13:WARNING:WU01:FS01:Server did not like results, dumping
11:22:14:WU01:FS01:Cleaning up
I've had a couple of oddities with P9430s over the last few days- failed to upload until I restarted the client (then the WS failed to connect, it went to the CS ok), then didn't get any for a longer period than usual (which could be coincidence of course). Problem with the server?
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Project: 9430 (Run 17, Clone 2, Gen 131) Server ... dumping
Post by artoar_11 »
The same project, the same server and the same problem
GTX 970; Win7/64b
02:52:32:WU00:FS00:Starting
02:52:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version 704 -lifeline 4052 -checkpoint 12 -gpu 0 -gpu-vendor nvidia
02:52:32:WU00:FS00:Started FahCore on PID 1164
02:52:32:WU00:FS00:Core PID:3832
02:52:32:WU00:FS00:FahCore 0x18 started
02:52:33:WU00:FS00:0x18:*********************** Log Started 2015-09-18T02:52:32Z ***********************
02:52:33:WU00:FS00:0x18:Project: 9430 (Run 17, Clone 2, Gen 131)
02:52:33:WU00:FS00:0x18:Unit: 0x00000099ab40413855474bb8cb7ae733
02:52:33:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
02:52:33:WU00:FS00:0x18:Machine: 0
02:52:33:WU00:FS00:0x18:Reading tar file state.xml
02:52:33:WU00:FS00:0x18:Reading tar file system.xml
02:52:33:WU00:FS00:0x18:Reading tar file integrator.xml
02:52:33:WU00:FS00:0x18:Reading tar file core.xml
02:52:33:WU00:FS00:0x18:Digital signatures verified
02:52:33:WU00:FS00:0x18:Folding@home GPU core18
02:52:33:WU00:FS00:0x18:Version 0.0.4
02:52:44:WU00:FS00:0x18:Completed 0 out of 16000000 steps (0%)
02:52:44:WU00:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:58:23:WU00:FS00:0x18:Completed 160000 out of 16000000 steps (1%)
03:03:58:WU00:FS00:0x18:Completed 320000 out of 16000000 steps (2%)
03:09:33:WU00:FS00:0x18:Completed 480000 out of 16000000 steps (3%)
03:15:07:WU00:FS00:0x18:Completed 640000 out of 16000000 steps (4%)
03:20:42:WU00:FS00:0x18:Completed 800000 out of 16000000 steps (5%)
03:26:21:WU00:FS00:0x18:Completed 960000 out of 16000000 steps (6%)
12:00:21:WU00:FS00:0x18:Completed 15520000 out of 16000000 steps (97%)
12:05:57:WU00:FS00:0x18:Completed 15680000 out of 16000000 steps (98%)
12:11:33:WU00:FS00:0x18:Completed 15840000 out of 16000000 steps (99%)
12:17:09:WU00:FS00:0x18:Completed 16000000 out of 16000000 steps (100%)
12:17:09:WU01:FS00:Connecting to 171.67.108.200:80
12:17:13:WU01:FS00:Assigned to work server 171.64.65.98
12:17:13:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.98
12:17:13:WU01:FS00:Connecting to 171.64.65.98:8080
12:17:14:WU00:FS00:0x18:Saving result file logfile_01.txt
12:17:14:WU00:FS00:0x18:Saving result file checkpointState.xml
12:17:14:WU01:FS00:Downloading 15.70MiB
12:17:14:WU00:FS00:0x18:Saving result file checkpt.crc
12:17:14:WU00:FS00:0x18:Saving result file log.txt
12:17:14:WU00:FS00:0x18:Saving result file positions.xtc
12:17:18:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:17:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:17 clone:2 gen:131 core:0x18 unit:0x00000099ab40413855474bb8cb7ae733
12:17:18:WU00:FS00:Uploading 24.16MiB to 171.64.65.56
12:17:18:WU00:FS00:Connecting to 171.64.65.56:8080
12:17:21:WU01:FS00:Download 1.59%
12:17:24:WU00:FS00:Upload 1.29%
12:17:28:WU01:FS00:Download 2.79%
12:17:30:WU00:FS00:Upload 2.59%
12:24:29:WU00:FS00:Upload 92.87%
12:24:29:WU01:FS00:Download 98.74%
12:24:35:WU01:FS00:Download 99.94%
12:24:35:WU01:FS00:Download complete
12:24:35:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9704 run:21 clone:10 gen:30 core:0x21 unit:0x0000002dab404162553ebf01628d6ea4
12:24:35:WU01:FS00:Starting
12:24:35:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4052 -checkpoint 12 -gpu 0 -gpu-vendor nvidia
12:24:35:WU01:FS00:Started FahCore on PID 5116
12:24:35:WU01:FS00:Core PID:5504
12:24:35:WU01:FS00:FahCore 0x21 started
12:24:36:WU01:FS00:0x21:*********************** Log Started 2015-09-18T12:24:35Z ***********************
12:24:36:WU01:FS00:0x21:Project: 9704 (Run 21, Clone 10, Gen 30)
12:24:36:WU01:FS00:0x21:Unit: 0x0000002dab404162553ebf01628d6ea4
12:24:36:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
12:24:36:WU01:FS00:0x21:Machine: 0
12:24:36:WU01:FS00:0x21:Reading tar file core.xml
12:24:36:WU01:FS00:0x21:Reading tar file system.xml
12:24:36:WU00:FS00:Upload 94.42%
12:24:38:WU01:FS00:0x21:Reading tar file integrator.xml
12:24:38:WU01:FS00:0x21:Reading tar file state.xml
12:24:40:WU01:FS00:0x21:Digital signatures verified
12:24:40:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
12:24:40:WU01:FS00:0x21:Version 0.0.11
12:24:42:WU00:FS00:Upload 95.71%
12:24:48:WU00:FS00:Upload 97.00%
12:24:54:WU00:FS00:Upload 98.30%
12:25:00:WU00:FS00:Upload 99.59%
12:25:02:WU00:FS00:Upload complete
12:25:02:WU00:FS00:Server responded WORK_QUIT (404)
12:25:02:WARNING:WU00:FS00:Server did not like results, dumping
12:25:02:WU00:FS00:Cleaning up
DutchForce
Post by DutchForce »
I have the same problem with a P9430 WU.
And I noticed the same as Billford... 3 days ago (Sept 15th) I had a P9430 stuck at ~99% upload (~7 hours) to server 171.64.65.56, and did not get an "Upload complete" and "Server responded WORK_ACK (400)" message.
After I restarted FAHClient it "Failed to send results to work server" 171.64.65.56 and returned it successfully to the Collecting server 171.65.103.160.
I noticed that the Net Load of server 171.64.65.56 was high at that time (~1000 instead of ~5) and I also did not get P9430 WUs for a few days.
System and Config info GTX780 Ti's:
*********************** Log Started 2015-09-15T20:20:26Z ***********************
20:20:26:************************* Folding@home Client *************************
20:20:26:      Website: http://folding.stanford.edu/
20:20:26:    Copyright: (c) 2009-2014 Stanford University
20:20:26:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:20:26:         Args:
20:20:26:       Config: C:/FAHClient/config.xml
20:20:26:******************************** Build ********************************
20:20:26:      Version: 7.4.4
20:20:26:         Date: Mar 4 2014
20:20:26:         Time: 20:26:54
20:20:26:      SVN Rev: 4130
20:20:26:       Branch: fah/trunk/client
20:20:26:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:20:26:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:20:26:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:20:26:     Platform: win32 XP
20:20:26:         Bits: 32
20:20:26:         Mode: Release
20:20:26:******************************* System ********************************
20:20:26:          CPU: AMD Phenom(tm) II X4 965 Processor
20:20:26:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
20:20:26:         CPUs: 4
20:20:26:       Memory: 4.00GiB
20:20:26:  Free Memory: 3.28GiB
20:20:26:      Threads: WINDOWS_THREADS
20:20:26:   OS Version: 6.1
20:20:26:  Has Battery: false
20:20:26:   On Battery: false
20:20:26:   UTC Offset: 2
20:20:26:          PID: 2144
20:20:26:          CWD: C:/FAHClient
20:20:26:           OS: Windows 7 Professional
20:20:26:      OS Arch: AMD64
20:20:26:         GPUs: 2
20:20:26:        GPU 0: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
20:20:26:        GPU 1: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
20:20:26:         CUDA: 3.5
20:20:26:  CUDA Driver: 7000
20:20:26:Win32 Service: false
20:20:26:***********************************************************************
20:20:26:<config>
20:20:26:  <!-- Folding Core -->
20:20:26:  <core-priority v='low'/>
20:20:26:
20:20:26:  <!-- Network -->
20:20:26:  <proxy v=':8080'/>
20:20:26:
20:20:26:  <!-- Slot Control -->
20:20:26:  <power v='full'/>
20:20:26:
20:20:26:  <!-- User Information -->
20:20:26:  <passkey v='********************************'/>
20:20:26:  <team v='111065'/>
20:20:26:  <user v='DutchForce'/>
20:20:26:
20:20:26:  <!-- Work Unit Control -->
20:20:26:  <next-unit-percentage v='100'/>
20:20:26:
20:20:26:  <!-- Folding Slots -->
20:20:26:  <slot id='0' type='GPU'>
20:20:26:    <client-type v='advanced'/>
20:20:26:  </slot>
20:20:26:  <slot id='1' type='GPU'>
20:20:26:  </slot>
20:20:26:</config>
20:20:26:Trying to access database...
20:20:26:Successfully acquired database lock
20:20:26:Enabled folding slot 00: READY gpu:0:GK110 [GeForce GTX 780 Ti]
20:20:26:Enabled folding slot 01: READY gpu:1:GK110 [GeForce GTX 780 Ti]
Log Project: 9430 (Run 55, Clone 8, Gen 97):
******************************* Date: 2015-09-18 *******************************
00:45:40:WU02:FS01:Assigned to work server 171.64.65.56
00:45:40:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GK110 [GeForce GTX 780 Ti] from 171.64.65.56
00:45:40:WU02:FS01:Connecting to 171.64.65.56:8080
00:45:41:WU02:FS01:Downloading 1.51MiB
00:45:45:WU02:FS01:Download complete
00:45:46:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9430 run:55 clone:8 gen:97 core:0x18
unit:0x0000006fab40413855474cbbbec3c872
00:45:49:WU02:FS01:Starting
00:45:49:WU02:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\"
C:/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 1640 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
00:45:49:WU02:FS01:Started FahCore on PID 2428
00:45:49:WU02:FS01:Core PID:616
00:45:49:WU02:FS01:FahCore 0x18 started
00:45:49:WU02:FS01:0x18:*********************** Log Started 2015-09-18T00:45:49Z ***********************
00:45:49:WU02:FS01:0x18:Project: 9430 (Run 55, Clone 8, Gen 97)
00:45:49:WU02:FS01:0x18:Unit: 0x0000006fab40413855474cbbbec3c872
00:45:49:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
00:45:49:WU02:FS01:0x18:Machine: 1
00:45:49:WU02:FS01:0x18:Reading tar file state.xml
00:45:49:WU02:FS01:0x18:Reading tar file system.xml
00:45:49:WU02:FS01:0x18:Reading tar file integrator.xml
00:45:49:WU02:FS01:0x18:Reading tar file core.xml
00:45:49:WU02:FS01:0x18:Digital signatures verified
00:45:49:WU02:FS01:0x18:Folding@home GPU core18
00:45:49:WU02:FS01:0x18:Version 0.0.4
00:46:04:WU02:FS01:0x18:Completed 0 out of 16000000 steps (0%)
00:52:40:WU02:FS01:0x18:Completed 160000 out of 16000000 steps (1%)
00:59:10:WU02:FS01:0x18:Completed 320000 out of 16000000 steps (2%)
01:05:40:WU02:FS01:0x18:Completed 480000 out of 16000000 steps (3%)
11:25:57:WU02:FS01:0x18:Completed 15680000 out of 16000000 steps (98%)
11:32:27:WU02:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
11:38:58:WU02:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
11:39:05:WU02:FS01:0x18:Saving result file logfile_01.txt
11:39:05:WU02:FS01:0x18:Saving result file checkpointState.xml
11:39:06:WU02:FS01:0x18:Saving result file checkpt.crc
11:39:06:WU02:FS01:0x18:Saving result file log.txt
11:39:06:WU02:FS01:0x18:Saving result file positions.xtc
11:39:11:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
11:39:12:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:39:12:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9430 run:55 clone:8 gen:97 core:0x18
11:39:12:WU02:FS01:Uploading 24.11MiB to 171.64.65.56
11:39:12:WU02:FS01:Connecting to 171.64.65.56:8080
11:39:18:WU02:FS01:Upload 1.81%
11:44:54:WU02:FS01:Upload 99.53%
11:44:56:WU02:FS01:Upload complete
11:44:56:WU02:FS01:Server responded WORK_QUIT (404)
11:44:56:WARNING:WU02:FS01:Server did not like results, dumping
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
DutchForce wrote:I noticed that the Net Load of server 171.64.65.56 was high at that time (~1000 instead of ~5)
Confirmed- I noticed that too, forgot to mention it.
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Several Projects 9430: Server did not like results, dumping
Post by folding_hoomer »
Got two Projects of WU9430, both results were dumped by the Server:
Project: 9430 (R 34, C 6, G 89) and
Project: 9430 (R 19, C 7, G 111)
System: i7 3820, GTX970, Ubuntu 14.04 64Bit, Driver 346.72
*********************** Log Started 2015-09-04T06:35:29Z ***********************
06:35:29:************************* Folding@home Client *************************
06:35:29:    Website: http://folding.stanford.edu/
06:35:29:  Copyright: (c) 2009-2014 Stanford University
06:35:29:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:35:29:       Args: --child --lifeline 1047 /etc/fahclient/config.xml --run-as
06:35:29:             fahclient --pid-file=/var/run/fahclient.pid --daemon
06:35:29:     Config: /etc/fahclient/config.xml
06:35:29:******************************** Build ********************************
06:35:29:    Version: 7.4.4
06:35:29:       Date: Mar 4 2014
06:35:29:       Time: 12:02:38
06:35:29:    SVN Rev: 4130
06:35:29:     Branch: fah/trunk/client
06:35:29:   Compiler: GNU 4.4.7
06:35:29:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
06:35:29:             -fno-unsafe-math-optimizations -msse2
06:35:29:   Platform: linux2 3.2.0-1-amd64
06:35:29:       Bits: 64
06:35:29:       Mode: Release
06:35:29:******************************* System ********************************
06:35:29:        CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
06:35:29:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
06:35:29:       CPUs: 8
06:35:29:     Memory: 7.71GiB
06:35:29:Free Memory: 7.32GiB
06:35:29:    Threads: POSIX_THREADS
06:35:29: OS Version: 3.13
06:35:29:Has Battery: false
06:35:29: On Battery: false
06:35:29: UTC Offset: 2
06:35:29:        PID: 1049
06:35:29:        CWD: /var/lib/fahclient
06:35:29:         OS: Linux 3.13.0-54-generic x86_64
06:35:29:    OS Arch: AMD64
06:35:29:       GPUs: 1
06:35:29:      GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
06:35:29:       CUDA: 5.2
06:35:29:CUDA Driver: 7000
06:35:29:***********************************************************************
06:35:29:<config>
06:35:29:  <!-- Client Control -->
06:35:29:  <fold-anon v='true'/>
06:35:29:
06:35:29:  <!-- Folding Slot Configuration -->
06:35:29:  <gpu v='false'/>
06:35:29:
06:35:29:  <!-- HTTP Server -->
06:35:29:  <allow v='127.0.0.1 192.168.2.100-192.168.2.110'/>
06:35:29:
06:35:29:  <!-- Logging -->
06:35:29:  <log-rotate-max v='100'/>
06:35:29:
06:35:29:  <!-- Network -->
06:35:29:  <proxy v=':8080'/>
06:35:29:
06:35:29:  <!-- Remote Command Server -->
06:35:29:  <command-allow-no-pass v='127.0.0.1 192.168.2.100-192.168.2.110'/>
06:35:29:
06:35:29:  <!-- Slot Control -->
06:35:29:  <pause-on-start v='true'/>
06:35:29:  <power v='full'/>
06:35:29:
06:35:29:  <!-- User Information -->
06:35:29:  <passkey v='********************************'/>
06:35:29:  <team v='111065'/>
06:35:29:  <user v='Amigafan'/>
06:35:29:
06:35:29:  <!-- Folding Slots -->
06:35:29:  <slot id='1' type='GPU'>
06:35:29:    <client-type v='advanced'/>
06:35:29:    <next-unit-percentage v='100'/>
06:35:29:    <paused v='true'/>
06:35:29:  </slot>
06:35:29:</config>
22:01:03:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9430 run:34 clone:6 gen:89 core:0x18 unit:0x0000006fab40413855474c2e1aa7441b
22:01:03:WU00:FS01:Starting
22:01:03:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 1049 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:01:03:WU00:FS01:Started FahCore on PID 12337
22:01:03:WU00:FS01:Core PID:12341
22:01:03:WU00:FS01:FahCore 0x18 started
22:01:04:WU00:FS01:0x18:*********************** Log Started 2015-09-17T22:01:03Z ***********************
22:01:04:WU00:FS01:0x18:Project: 9430 (Run 34, Clone 6, Gen 89)
22:01:04:WU00:FS01:0x18:Unit: 0x0000006fab40413855474c2e1aa7441b
22:01:04:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
22:01:04:WU00:FS01:0x18:Machine: 1
22:01:04:WU00:FS01:0x18:Reading tar file state.xml
22:01:04:WU00:FS01:0x18:Reading tar file system.xml
22:01:04:WU00:FS01:0x18:Reading tar file integrator.xml
22:01:04:WU00:FS01:0x18:Reading tar file core.xml
22:01:04:WU00:FS01:0x18:Digital signatures verified
22:01:04:WU00:FS01:0x18:Folding@home GPU core18
22:01:04:WU00:FS01:0x18:Version 0.0.4
22:01:08:WU01:FS01:Upload 10.11%
22:01:09:WU00:FS01:0x18:Completed 0 out of 16000000 steps (0%)
22:01:09:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:11:57:WU00:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
06:11:58:WU01:FS01:Connecting to 171.67.108.200:80
06:11:59:WU00:FS01:0x18:Saving result file logfile_01.txt
06:11:59:WU00:FS01:0x18:Saving result file checkpointState.xml
06:11:59:WU00:FS01:0x18:Saving result file checkpt.crc
06:11:59:WU00:FS01:0x18:Saving result file log.txt
06:11:59:WU00:FS01:0x18:Saving result file positions.xtc
06:11:59:WU01:FS01:Assigned to work server 171.64.65.56
06:11:59:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56
06:11:59:WU01:FS01:Connecting to 171.64.65.56:8080
06:12:01:WU01:FS01:Downloading 1.50MiB
06:12:03:WU00:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
06:12:03:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:12:03:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:34 clone:6 gen:89 core:0x18 unit:0x0000006fab40413855474c2e1aa7441b
06:12:03:WU00:FS01:Uploading 24.00MiB to 171.64.65.56
06:12:03:WU00:FS01:Connecting to 171.64.65.56:8080
06:12:07:WU01:FS01:Download 100.00%
06:12:07:WU01:FS01:Download complete
06:12:07:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9430 run:19 clone:7 gen:111 core:0x18 unit:0x00000087ab40413855474bc9f290af54
06:12:07:WU01:FS01:Starting
06:12:07:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 1049 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:12:07:WU01:FS01:Started FahCore on PID 12768
06:12:07:WU01:FS01:Core PID:12772
06:12:07:WU01:FS01:FahCore 0x18 started
06:12:07:WU01:FS01:0x18:*********************** Log Started 2015-09-18T06:12:07Z ***********************
06:12:07:WU01:FS01:0x18:Project: 9430 (Run 19, Clone 7, Gen 111)
06:12:07:WU01:FS01:0x18:Unit: 0x00000087ab40413855474bc9f290af54
06:12:07:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
06:12:07:WU01:FS01:0x18:Machine: 1
06:12:07:WU01:FS01:0x18:Reading tar file state.xml
06:12:07:WU01:FS01:0x18:Reading tar file system.xml
06:12:07:WU01:FS01:0x18:Reading tar file integrator.xml
06:12:07:WU01:FS01:0x18:Reading tar file core.xml
06:12:07:WU01:FS01:0x18:Digital signatures verified
06:12:07:WU01:FS01:0x18:Folding@home GPU core18
06:12:07:WU01:FS01:0x18:Version 0.0.4
06:12:09:WU00:FS01:Upload 1.82%
06:12:12:WU01:FS01:0x18:Completed 0 out of 16000000 steps (0%)
06:12:12:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:15:34:WU00:FS01:Upload 98.16%
06:15:40:WU00:FS01:Upload complete
06:15:40:WU00:FS01:Server responded WORK_QUIT (404)
06:15:40:WARNING:WU00:FS01:Server did not like results, dumping
06:15:40:WU00:FS01:Cleaning up
14:23:18:WU01:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
14:23:20:WU00:FS01:Connecting to 171.67.108.200:80
14:23:21:WU01:FS01:0x18:Saving result file logfile_01.txt
14:23:21:WU01:FS01:0x18:Saving result file checkpointState.xml
14:23:21:WU00:FS01:Assigned to work server 171.64.65.93
14:23:21:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.93
14:23:21:WU00:FS01:Connecting to 171.64.65.93:8080
14:23:21:WU01:FS01:0x18:Saving result file checkpt.crc
14:23:21:WU01:FS01:0x18:Saving result file log.txt
14:23:21:WU01:FS01:0x18:Saving result file positions.xtc
14:23:22:WU00:FS01:Downloading 2.80MiB
14:23:24:WU01:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
14:23:25:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:23:25:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9430 run:19 clone:7 gen:111 core:0x18 unit:0x00000087ab40413855474bc9f290af54
14:23:25:WU01:FS01:Uploading 24.00MiB to 171.64.65.56
14:23:25:WU01:FS01:Connecting to 171.64.65.56:8080
14:23:31:WU01:FS01:Upload 1.30%
14:26:31:WU01:FS01:Upload 98.71%
14:26:35:WU01:FS01:Upload complete
14:26:35:WU01:FS01:Server responded WORK_QUIT (404)
14:26:35:WARNING:WU01:FS01:Server did not like results, dumping
14:26:35:WU01:FS01:Cleaning up
A Teammember has had the same problem with:
Project: 9430 (R 1, C 5, G 141)
06:18:59:WU02:FS01:0x18:*********************** Log Started 2015-09-18T06:18:59Z ***********************
06:18:59:WU02:FS01:0x18roject: 9430 (Run 1, Clone 5, Gen 141)
06:18:59:WU02:FS01:0x18:Unit: 0x0000009bab404138554746560c91dd3e
06:18:59:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
06:18:59:WU02:FS01:0x18:Machine: 1
06:18:59:WU02:FS01:0x18:Reading tar file state.xml
06:18:59:WU02:FS01:0x18:Reading tar file system.xml
06:18:59:WU02:FS01:0x18:Reading tar file integrator.xml
06:18:59:WU02:FS01:0x18:Reading tar file core.xml
06:18:59:WU02:FS01:0x18igital signatures verified
06:18:59:WU02:FS01:0x18:Folding@home GPU core18
06:18:59:WU02:FS01:0x18:Version 0.0.4
06:19:04:WU02:FS01:0x18:Completed 0 out of 16000000 steps (0%)
06:19:04:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:18:05:WU02:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
14:18:07:WU02:FS01:0x18:Saving result file logfile_01.txt
14:18:07:WU02:FS01:0x18:Saving result file checkpointState.xml
14:18:08:WU02:FS01:0x18:Saving result file checkpt.crc
14:18:08:WU02:FS01:0x18:Saving result file log.txt
14:18:08:WU02:FS01:0x18:Saving result file positions.xtc
14:18:12:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
14:18:13:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:18:13:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9430 run:1 clone:5 gen:141 core:0x18 unit:0x0000009bab404138554746560c91dd3e
14:18:13:WU02:FS01:Uploading 24.12MiB to 171.64.65.56
14:18:13:WU02:FS01:Connecting to 171.64.65.56:8080
14:18:20:WU02:FS01:Upload 26.69%
14:18:26:WU02:FS01:Upload 44.05%
14:18:33:WU02:FS01:Upload 66.08%
14:18:39:WU02:FS01:Upload 84.73%
14:18:47:WU02:FS01:Upload complete
14:18:47:WU02:FS01:Server responded WORK_QUIT (404)
14:18:47:WARNING:WU02:FS01:Server did not like results, dumping
14:18:47:WU02:FS01:Cleaning up
A problem with the CS?
cxh
Pande Group Member
Post by cxh »
Thanks for the report! The work server hosting that project was running out of disk space. I've since freed up some more. Please let me know if the problem persists!
folding_hoomer
Optional:
Re: New Core18 Project: 9430
What has happened with the porject-data - were they lost?
And - a question of some teammembers: will they get the points for those dumped WU´s?
DutchForce
Re: 171.64.65.56
There seems to be a problem with this server again.
I have returned a WU to server 171.64.65.56 today and I got the message: Server did not like results, dumping
- Project: 9430 (Run 148, Clone 8, Gen 68)
It's from a folding system with a GTX970 and did not have any issues during folding.
System and Config info GTX970:
*********************** Log Started 2015-11-01T12:25:27Z ***********************
12:25:27:************************* Folding@home Client *************************
12:25:27:      Website: http://folding.stanford.edu/
12:25:27:    Copyright: (c) 2009-2014 Stanford University
12:25:27:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:25:27:         Args:
12:25:27:       Config: D:/FAHClient/config.xml
12:25:27:******************************** Build ********************************
12:25:27:      Version: 7.4.4
12:25:27:         Date: Mar 4 2014
12:25:27:         Time: 20:26:54
12:25:27:      SVN Rev: 4130
12:25:27:       Branch: fah/trunk/client
12:25:27:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:25:27:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:25:27:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:25:27:     Platform: win32 XP
12:25:27:         Bits: 32
12:25:27:         Mode: Release
12:25:27:******************************* System ********************************
12:25:27:          CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
12:25:27:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:25:27:         CPUs: 4
12:25:27:       Memory: 7.98GiB
12:25:27:  Free Memory: 6.35GiB
12:25:27:      Threads: WINDOWS_THREADS
12:25:27:   OS Version: 6.1
12:25:27:  Has Battery: false
12:25:27:   On Battery: false
12:25:27:   UTC Offset: 1
12:25:27:          PID: 4204
12:25:27:          CWD: D:/FAHClient
12:25:27:           OS: Windows 7 Professional
12:25:27:      OS Arch: AMD64
12:25:27:         GPUs: 1
12:25:27:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
12:25:27:         CUDA: 5.2
12:25:27:  CUDA Driver: 7000
12:25:27:Win32 Service: false
12:25:27:***********************************************************************
12:25:27:<config>
12:25:27:  <!-- Folding Core -->
12:25:27:  <core-priority v='low'/>
12:25:27:
12:25:27:  <!-- Network -->
12:25:27:  <proxy v=':8080'/>
12:25:27:
12:25:27:  <!-- Slot Control -->
12:25:27:  <power v='full'/>
12:25:27:
12:25:27:  <!-- User Information -->
12:25:27:  <passkey v='********************************'/>
12:25:27:  <team v='111065'/>
12:25:27:  <user v='DutchForce'/>
12:25:27:
12:25:27:  <!-- Work Unit Control -->
12:25:27:  <next-unit-percentage v='100'/>
12:25:27:
12:25:27:  <!-- Folding Slots -->
12:25:27:  <slot id='0' type='GPU'/>
12:25:27:</config>
12:25:27:Trying to access database...
12:25:27:Successfully acquired database lock
12:25:27:Enabled folding slot 00: READY gpu:0:GM204 [GeForce GTX 970]
Here is the log, Project: 9430 (Run 148, Clone 8, Gen 68):
22:28:43:WU00:FS00:Assigned to work server 171.64.65.56
22:28:43:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56
22:28:43:WU00:FS00:Connecting to 171.64.65.56:8080
22:28:50:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9430 run:148 clone:8 gen:68 core:0x18
unit:0x0000004dab40413855474e6d270a56fd
22:28:52:WU00:FS00:Starting
22:28:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version
704 -lifeline 4204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:28:52:WU00:FS00:Started FahCore on PID 2128
22:28:52:WU00:FS00:Core PID:1648
22:28:52:WU00:FS00:FahCore 0x18 started
22:28:53:WU00:FS00:0x18:*********************** Log Started 2015-11-09T22:28:52Z ***********************
22:28:53:WU00:FS00:0x18:Project: 9430 (Run 148, Clone 8, Gen 68)
22:28:53:WU00:FS00:0x18:Unit: 0x0000004dab40413855474e6d270a56fd
22:28:53:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
22:28:53:WU00:FS00:0x18:Machine: 0
22:28:53:WU00:FS00:0x18:Reading tar file state.xml
22:28:53:WU00:FS00:0x18:Reading tar file system.xml
22:28:53:WU00:FS00:0x18:Reading tar file integrator.xml
22:28:53:WU00:FS00:0x18:Reading tar file core.xml
22:28:53:WU00:FS00:0x18:Digital signatures verified
22:28:53:WU00:FS00:0x18:Folding@home GPU core18
22:28:53:WU00:FS00:0x18:Version 0.0.4
22:29:04:WU00:FS00:0x18:Completed 0 out of 16000000 steps (0%)
22:29:04:WU00:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:35:05:WU00:FS00:0x18:Completed 160000 out of 16000000 steps (1%)
22:41:01:WU00:FS00:0x18:Completed 320000 out of 16000000 steps (2%)
22:46:56:WU00:FS00:0x18:Completed 480000 out of 16000000 steps (3%)
22:52:51:WU00:FS00:0x18:Completed 640000 out of 16000000 steps (4%)
22:58:47:WU00:FS00:0x18:Completed 800000 out of 16000000 steps (5%)
******************************* Date: 2015-11-10 *******************************
07:54:34:WU00:FS00:0x18:Completed 15200000 out of 16000000 steps (95%)
08:00:36:WU00:FS00:0x18:Completed 15360000 out of 16000000 steps (96%)
08:06:32:WU00:FS00:0x18:Completed 15520000 out of 16000000 steps (97%)
08:12:29:WU00:FS00:0x18:Completed 15680000 out of 16000000 steps (98%)
08:18:26:WU00:FS00:0x18:Completed 15840000 out of 16000000 steps (99%)
08:24:23:WU00:FS00:0x18:Completed 16000000 out of 16000000 steps (100%)
08:24:28:WU00:FS00:0x18:Saving result file logfile_01.txt
08:24:28:WU00:FS00:0x18:Saving result file checkpointState.xml
08:24:29:WU00:FS00:0x18:Saving result file checkpt.crc
08:24:29:WU00:FS00:0x18:Saving result file log.txt
08:24:29:WU00:FS00:0x18:Saving result file positions.xtc
08:24:33:WU00:FS00:0x18:Folding@home Core Shutdown: FINISHED_UNIT
08:24:33:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:24:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:148 clone:8 gen:68 core:0x18
08:24:34:WU00:FS00:Uploading 24.06MiB to 171.64.65.56
08:24:34:WU00:FS00:Connecting to 171.64.65.56:8080
08:24:40:WU00:FS00:Upload 1.30%
08:24:46:WU00:FS00:Upload 2.60%
08:31:07:WU00:FS00:Upload 97.95%
08:31:13:WU00:FS00:Upload 99.51%
08:31:16:WU00:FS00:Upload complete
08:31:16:WU00:FS00:Server responded WORK_QUIT (404)
08:31:16:WARNING:WU00:FS00:Server did not like results, dumping
EDIT: I've just returned another P9430 WU to this server and got the same message: Server did not like results, dumping
- Project: 9430 (Run 147, Clone 1, Gen 70)
It's from another folding system with a GTX980 Ti and GTX780 Ti (Win7 64-bit) and did not have any issues during folding.
Here is the log (from GTX780 Ti), Project: 9430 (Run 147, Clone 1, Gen 70):
23:51:48:WU00:FS00:Assigned to work server 171.64.65.56
23:51:48:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GK110 [GeForce GTX 780 Ti] from 171.64.65.56
23:51:48:WU00:FS00:Connecting to 171.64.65.56:8080
23:51:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9430 run:147 clone:1 gen:70 core:0x18
unit:0x00000052ab40413855474e63637058c0
23:51:55:WU00:FS00:Starting
23:51:55:WU00:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\"
C:/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version
704 -lifeline 2176 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
23:51:55:WU00:FS00:Started FahCore on PID 2744
23:51:55:WU00:FS00:Core PID:3032
23:51:55:WU00:FS00:FahCore 0x18 started
23:51:55:WU00:FS00:0x18:*********************** Log Started 2015-11-09T23:51:55Z ***********************
23:51:55:WU00:FS00:0x18:Project: 9430 (Run 147, Clone 1, Gen 70)
23:51:55:WU00:FS00:0x18:Unit: 0x00000052ab40413855474e63637058c0
23:51:55:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
23:51:55:WU00:FS00:0x18:Machine: 0
23:51:55:WU00:FS00:0x18:Reading tar file state.xml
23:51:55:WU00:FS00:0x18:Reading tar file system.xml
23:51:55:WU00:FS00:0x18:Reading tar file integrator.xml
23:51:55:WU00:FS00:0x18:Reading tar file core.xml
23:51:55:WU00:FS00:0x18:Digital signatures verified
23:51:55:WU00:FS00:0x18:Folding@home GPU core18
23:51:55:WU00:FS00:0x18:Version 0.0.4
23:52:12:WU00:FS00:0x18:Completed 0 out of 16000000 steps (0%)
23:52:12:WU00:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:58:58:WU00:FS00:0x18:Completed 160000 out of 16000000 steps (1%)
00:05:39:WU00:FS00:0x18:Completed 320000 out of 16000000 steps (2%)
00:12:20:WU00:FS00:0x18:Completed 480000 out of 16000000 steps (3%)
00:18:59:WU00:FS00:0x18:Completed 640000 out of 16000000 steps (4%)
00:25:39:WU00:FS00:0x18:Completed 800000 out of 16000000 steps (5%)
10:28:27:WU00:FS00:0x18:Completed 15200000 out of 16000000 steps (95%)
10:35:15:WU00:FS00:0x18:Completed 15360000 out of 16000000 steps (96%)
10:41:58:WU00:FS00:0x18:Completed 15520000 out of 16000000 steps (97%)
10:48:40:WU00:FS00:0x18:Completed 15680000 out of 16000000 steps (98%)
10:55:23:WU00:FS00:0x18:Completed 15840000 out of 16000000 steps (99%)
11:02:05:WU00:FS00:0x18:Completed 16000000 out of 16000000 steps (100%)
11:02:14:WU00:FS00:0x18:Saving result file checkpt.crc
11:02:14:WU00:FS00:0x18:Saving result file log.txt
11:02:14:WU00:FS00:0x18:Saving result file positions.xtc
11:02:20:WU00:FS00:0x18:Folding@home Core Shutdown: FINISHED_UNIT
11:02:22:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:02:23:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:147 clone:1 gen:70 core:0x18
11:02:23:WU00:FS00:Uploading 24.00MiB to 171.64.65.56
11:02:23:WU00:FS00:Connecting to 171.64.65.56:8080
11:02:29:WU00:FS00:Upload 1.82%
11:02:35:WU00:FS00:Upload 3.39%
11:08:23:WU00:FS00:Upload 97.39%
11:08:29:WU00:FS00:Upload 98.95%
11:08:33:WU00:FS00:Upload complete
11:08:33:WU00:FS00:Server responded WORK_QUIT (404)
11:08:33:WARNING:WU00:FS00:Server did not like results, dumping
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: 171.64.65.56
Post by billford »
And again:
15:02:54:WU00:FS01:0x18:Completed 15520000 out of 16000000 steps (97%)
15:09:01:WU00:FS01:0x18:Completed 15680000 out of 16000000 steps (98%)
15:15:08:WU00:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
15:21:15:WU00:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
15:21:17:WU00:FS01:0x18:Saving result file logfile_01.txt
15:21:17:WU00:FS01:0x18:Saving result file checkpointState.xml
15:21:17:WU00:FS01:0x18:Saving result file checkpt.crc
15:21:17:WU00:FS01:0x18:Saving result file log.txt
15:21:17:WU00:FS01:0x18:Saving result file positions.xtc
15:21:21:WU00:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
15:21:21:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:21:21:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:54 clone:9 gen:109 core:0x18 unit:0x0000008cab40413855474cb6ea6b71d2
15:21:21:WU00:FS01:Uploading 24.01MiB to 171.64.65.56
15:21:21:WU00:FS01:Connecting to 171.64.65.56:8080
15:21:27:WU00:FS01:Upload 36.44%
15:21:33:WU00:FS01:Upload 85.90%
15:21:35:WU00:FS01:Upload complete
15:21:35:WU00:FS01:Server responded WORK_QUIT (404)
15:21:35:WARNING:WU00:FS01:Server did not like results, dumping
15:21:35:WU00:FS01:Cleaning up
parkut
Re: 171.64.65.56 Dumping
Post by parkut »
Had this one get dumped about 5 hrs 45 minutes ago
Project: 9137 (Run 64, Clone 0, Gen 86)
10:32:08:WU01:FS01:Uploading 24.06MiB to 171.64.65.56
10:33:19:WU01:FS01:Server responded WORK_QUIT (404)
10:33:19:WARNING:WU01:FS01:Server did not like results, dumping
Model Name: NVIDIA:5 GM206 [GeForce GTX 960]
Driver Version: 352.41
Gpu temp: 66C
Re: 171.64.65.56
I have sent a message to cxh about the new reports of WU's getting dumped.
sticks435
Re: 171.64.65.56
Post by sticks435 »
Add me to this list. Had project:9430 run:12 clone:0 gen:130 get dumped early this morning. Was at work by the time I realized when I didn't see the points come across on extremeOC folding stats.
11:39:55:WU00:FS00:0x18:Folding@home Core Shutdown: FINISHED_UNIT
11:39:55:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:39:55:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:12 clone:0 gen:130 core:0x18 unit:0x00000095ab40413855474b922aa708ce
11:39:56:WU00:FS00:Uploading 23.99MiB to 171.64.65.56
11:39:56:WU00:FS00:Connecting to 171.64.65.56:8080
11:40:02:WU00:FS00:Upload 14.85%
11:40:08:WU00:FS00:Upload 47.68%
11:40:14:WU00:FS00:Upload 89.11%
11:40:15:WU00:FS00:Upload complete
11:40:15:WU00:FS00:Server responded WORK_QUIT (404)
11:40:15:WARNING:WU00:FS00:Server did not like results, dumping
11:40:15:WU00:FS00:Cleaning up
This is on a 980Ti.
Re: 171.64.65.56
cxh has responded that he is looking into this. Reports of additional failed WU's are not needed at this time.
valvehead
171.64.65.56 WORK_QUIT failed upload
Post by valvehead »
The my client just finished uploading results to this server, but it dumped the results.
Config:
*********************** Log Started 2016-01-01T07:52:20Z ***********************
07:52:20:************************* Folding@home Client *************************
07:52:20:Started thread 1 on PID 1317
07:52:20:    Website: http://folding.stanford.edu/
07:52:20:  Copyright: (c) 2009-2014 Stanford University
07:52:20:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:52:20:       Args: --child --lifeline 1315 /etc/fahclient/config.xml --run-as
07:52:20:             fahclient --pid-file=/var/run/fahclient.pid --daemon
07:52:20:     Config: /etc/fahclient/config.xml
07:52:20:******************************** Build ********************************
07:52:20:    Version: 7.4.4
07:52:20:       Date: Mar 4 2014
07:52:20:       Time: 12:02:38
07:52:20:    SVN Rev: 4130
07:52:20:     Branch: fah/trunk/client
07:52:20:   Compiler: GNU 4.4.7
07:52:20:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
07:52:20:             -fno-unsafe-math-optimizations -msse2
07:52:20:   Platform: linux2 3.2.0-1-amd64
07:52:20:       Bits: 64
07:52:20:       Mode: Release
07:52:20:******************************* System ********************************
07:52:20:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
07:52:20:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
07:52:20:       CPUs: 8
07:52:20:     Memory: 7.76GiB
07:52:20:Free Memory: 7.47GiB
07:52:20:    Threads: POSIX_THREADS
07:52:20: OS Version: 3.13
07:52:20:Has Battery: false
07:52:20: On Battery: false
07:52:20: UTC Offset: -5
07:52:20:        PID: 1317
07:52:20:        CWD: /var/lib/fahclient
07:52:20:         OS: Linux 3.13.0-74-generic x86_64
07:52:20:    OS Arch: AMD64
07:52:20:       GPUs: 2
07:52:20:      GPU 0: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
07:52:20:      GPU 1: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
07:52:20:       CUDA: 5.2
07:52:20:CUDA Driver: 7050
07:52:20:***********************************************************************
07:52:20:<config>
07:52:20:  <!-- Client Control -->
07:52:20:  <client-threads v='6'/>
07:52:20:  <cycle-rate v='4'/>
07:52:20:  <cycles v='-1'/>
07:52:20:  <data-directory v='.'/>
07:52:20:  <disable-sleep-when-active v='true'/>
07:52:20:  <exec-directory v='/usr/bin'/>
07:52:20:  <exit-when-done v='false'/>
07:52:20:  <fold-anon v='false'/>
07:52:20:  <idle-seconds v='300'/>
07:52:20:  <open-web-control v='false'/>
07:52:20:
07:52:20:  <!-- Configuration -->
07:52:20:  <config-rotate v='true'/>
07:52:20:  <config-rotate-dir v='configs'/>
07:52:20:  <config-rotate-max v='16'/>
07:52:20:
07:52:20:  <!-- Debugging -->
07:52:20:  <assignment-servers>
07:52:20:    assign3.stanford.edu:8080 assign4.stanford.edu:80
07:52:20:  </assignment-servers>
07:52:20:  <auth-as v='true'/>
07:52:20:  <capture-directory v='capture'/>
07:52:20:  <capture-on-error v='false'/>
07:52:20:  <capture-packets v='false'/>
07:52:20:  <capture-requests v='false'/>
07:52:20:  <capture-responses v='false'/>
07:52:20:  <capture-sockets v='false'/>
07:52:20:  <core-exec v='FahCore_$type'/>
07:52:20:  <core-wrapper-exec v='FAHCoreWrapper'/>
07:52:20:  <debug-sockets v='false'/>
07:52:20:  <exception-locations v='true'/>
07:52:20:  <gpu-assignment-servers>
07:52:20:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
07:52:20:  </gpu-assignment-servers>
07:52:20:  <stack-traces v='false'/>
07:52:20:
07:52:20:  <!-- Error Handling -->
07:52:20:  <max-slot-errors v='10'/>
07:52:20:  <max-unit-errors v='5'/>
07:52:20:
07:52:20:  <!-- Folding Core -->
07:52:20:  <checkpoint v='3'/>
07:52:20:  <core-dir v='cores'/>
07:52:20:  <core-priority v='low'/>
07:52:20:  <cpu-affinity v='false'/>
07:52:20:  <cpu-usage v='100'/>
07:52:20:  <gpu-usage v='100'/>
07:52:20:  <no-assembly v='false'/>
07:52:20:
07:52:20:  <!-- Folding Slot Configuration -->
07:52:20:  <cause v='ANY'/>
07:52:20:  <client-subtype v='LINUX'/>
07:52:20:  <client-type v='normal'/>
07:52:20:  <cpu-species v='X86_PENTIUM_II'/>
07:52:20:  <cpu-type v='AMD64'/>
07:52:20:  <cpus v='-1'/>
07:52:20:  <gpu v='true'/>
07:52:20:  <max-packet-size v='normal'/>
07:52:20:  <os-species v='UNKNOWN'/>
07:52:20:  <os-type v='LINUX'/>
07:52:20:  <project-key v='0'/>
07:52:20:  <smp v='true'/>
07:52:20:
07:52:20:  <!-- GUI -->
07:52:20:  <gui-enabled v='true'/>
07:52:20:
07:52:20:  <!-- HTTP Server -->
07:52:20:  <allow v='192.168.1.0/24'/>
07:52:20:  <connection-timeout v='60'/>
07:52:20:  <deny v='0/0'/>
07:52:20:  <http-addresses v='0:7396'/>
07:52:20:  <https-addresses v=''/>
07:52:20:  <max-connect-time v='900'/>
07:52:20:  <max-connections v='800'/>
07:52:20:  <max-request-length v='52428800'/>
07:52:20:  <min-connect-time v='300'/>
07:52:20:  <threads v='8'/>
07:52:20:
07:52:20:  <!-- Logging -->
07:52:20:  <log v='log.txt'/>
07:52:20:  <log-color v='true'/>
07:52:20:  <log-crlf v='false'/>
07:52:20:  <log-date v='false'/>
07:52:20:  <log-date-periodically v='21600'/>
07:52:20:  <log-debug v='true'/>
07:52:20:  <log-domain v='false'/>
07:52:20:  <log-header v='true'/>
07:52:20:  <log-level v='true'/>
07:52:20:  <log-no-info-header v='true'/>
07:52:20:  <log-redirect v='false'/>
07:52:20:  <log-rotate v='true'/>
07:52:20:  <log-rotate-dir v='logs'/>
07:52:20:  <log-rotate-max v='16'/>
07:52:20:  <log-short-level v='false'/>
07:52:20:  <log-simple-domains v='true'/>
07:52:20:  <log-thread-id v='false'/>
07:52:20:  <log-thread-prefix v='true'/>
07:52:20:  <log-time v='true'/>
07:52:20:  <log-to-screen v='true'/>
07:52:20:  <log-truncate v='false'/>
07:52:20:  <verbosity v='5'/>
07:52:20:
07:52:20:  <!-- Network -->
07:52:20:  <proxy v=':8080'/>
07:52:20:  <proxy-enable v='false'/>
07:52:20:  <proxy-pass v=''/>
07:52:20:  <proxy-user v=''/>
07:52:20:
07:52:20:  <!-- Process Control -->
07:52:20:  <child v='true'/>
07:52:20:  <daemon v='true'/>
07:52:20:  <fork v='false'/>
07:52:20:  <pid v='false'/>
07:52:20:  <pid-file v='/var/run/fahclient.pid'/>
07:52:20:  <respawn v='false'/>
07:52:20:  <service v='false'/>
07:52:20:
07:52:20:  <!-- Remote Command Server -->
07:52:20:  <command-address v='0.0.0.0'/>
07:52:20:  <command-allow-no-pass v='127.0.0.1'/>
07:52:20:  <command-deny-no-pass v='0/0'/>
07:52:20:  <command-enable v='true'/>
07:52:20:  <command-port v='36330'/>
07:52:20:  <password v='*******'/>
07:52:20:
07:52:20:  <!-- Slot Control -->
07:52:20:  <idle v='false'/>
07:52:20:  <max-shutdown-wait v='60'/>
07:52:20:  <pause-on-battery v='true'/>
07:52:20:  <pause-on-start v='true'/>
07:52:20:  <paused v='false'/>
07:52:20:  <power v='full'/>
07:52:20:
07:52:20:  <!-- User Information -->
07:52:20:  <machine-id v='0'/>
07:52:20:  <passkey v=''/>
07:52:20:  <team v='37726'/>
07:52:20:  <user v='valvehead'/>
07:52:20:
07:52:20:  <!-- Web Server -->
07:52:20:  <web-allow v='127.0.0.1'/>
07:52:20:  <web-deny v='0/0'/>
07:52:20:  <web-enable v='true'/>
07:52:20:
07:52:20:  <!-- Web Server Sessions -->
07:52:20:  <session-cookie v='sid'/>
07:52:20:  <session-lifetime v='86400'/>
07:52:20:  <session-timeout v='3600'/>
07:52:20:
07:52:20:  <!-- Work Unit Control -->
07:52:20:  <dump-after-deadline v='true'/>
07:52:20:  <max-queue v='16'/>
07:52:20:  <max-units v='0'/>
07:52:20:  <next-unit-percentage v='100'/>
07:52:20:  <stall-detection-enabled v='false'/>
07:52:20:  <stall-percent v='5'/>
07:52:20:  <stall-timeout v='1800'/>
07:52:20:
07:52:20:  <!-- Folding Slots -->
07:52:20:  <slot id='0' type='CPU'>
07:52:20:    <client-type v='advanced'/>
07:52:20:    <cpus v='6'/>
07:52:20:    <passkey v='********************************'/>
07:52:20:  </slot>
07:52:20:  <slot id='1' type='GPU'>
07:52:20:    <paused v='true'/>
07:52:20:  </slot>
07:52:20:  <slot id='2' type='GPU'>
07:52:20:  </slot>
07:52:20:</config>
Failed upload:
10:51:12:WU00:FS01:Connecting to 171.67.108.45:80
10:51:13:WU00:FS01:Assigned to work server 171.64.65.56
10:51:13:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM200 [GeForce GTX 980 Ti] from 171.64.65.56
10:51:13:WU00:FS01:Connecting to 171.64.65.56:8080
10:51:13:WU00:FS01:Downloading 1.50MiB
10:51:19:WU00:FS01:Download 99.71%
10:51:20:WU00:FS01:Download complete
10:51:20:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9430 run:58 clone:9 gen:154 core:0x18 unit:0x000000c2ab40413855474ccfcb7b4630
10:51:20:WU00:FS01:Starting
10:51:20:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 1317 -checkpoint 3 -gpu 0 -gpu-vendor nvidia
10:51:20:WU00:FS01:Started FahCore on PID 27869
10:51:20:WU00:FS01:Core PID:27873
10:51:20:WU00:FS01:FahCore 0x18 started
10:51:20:WU00:FS01:0x18:*********************** Log Started 2016-01-07T10:51:20Z ***********************
10:51:20:WU00:FS01:0x18:Project: 9430 (Run 58, Clone 9, Gen 154)
10:51:20:WU00:FS01:0x18:Unit: 0x000000c2ab40413855474ccfcb7b4630
10:51:20:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
10:51:20:WU00:FS01:0x18:Machine: 1
10:51:20:WU00:FS01:0x18:Reading tar file state.xml
10:51:20:WU00:FS01:0x18:Reading tar file system.xml
10:51:20:WU00:FS01:0x18:Reading tar file integrator.xml
10:51:20:WU00:FS01:0x18:Reading tar file core.xml
10:51:20:WU00:FS01:0x18:Digital signatures verified
10:51:20:WU00:FS01:0x18:Folding@home GPU core18
10:51:20:WU00:FS01:0x18:Version 0.0.4
10:51:25:WU00:FS01:0x18:Completed 0 out of 16000000 steps (0%)
10:51:25:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:55:02:WU00:FS01:0x18:Completed 160000 out of 16000000 steps (1%)
10:58:37:WU00:FS01:0x18:Completed 320000 out of 16000000 steps (2%)
11:02:12:WU00:FS01:0x18:Completed 480000 out of 16000000 steps (3%)
11:05:47:WU00:FS01:0x18:Completed 640000 out of 16000000 steps (4%)
11:09:22:WU00:FS01:0x18:Completed 800000 out of 16000000 steps (5%)
11:12:59:WU00:FS01:0x18:Completed 960000 out of 16000000 steps (6%)
11:16:34:WU00:FS01:0x18:Completed 1120000 out of 16000000 steps (7%)
11:20:09:WU00:FS01:0x18:Completed 1280000 out of 16000000 steps (8%)
11:23:44:WU00:FS01:0x18:Completed 1440000 out of 16000000 steps (9%)
11:27:19:WU00:FS01:0x18:Completed 1600000 out of 16000000 steps (10%)
11:30:56:WU00:FS01:0x18:Completed 1760000 out of 16000000 steps (11%)
11:34:30:WU00:FS01:0x18:Completed 1920000 out of 16000000 steps (12%)
11:38:06:WU00:FS01:0x18:Completed 2080000 out of 16000000 steps (13%)
11:41:40:WU00:FS01:0x18:Completed 2240000 out of 16000000 steps (14%)
11:45:15:WU00:FS01:0x18:Completed 2400000 out of 16000000 steps (15%)
11:48:52:WU00:FS01:0x18:Completed 2560000 out of 16000000 steps (16%)
11:52:27:WU00:FS01:0x18:Completed 2720000 out of 16000000 steps (17%)
11:56:02:WU00:FS01:0x18:Completed 2880000 out of 16000000 steps (18%)
11:59:37:WU00:FS01:0x18:Completed 3040000 out of 16000000 steps (19%)
12:03:11:WU00:FS01:0x18:Completed 3200000 out of 16000000 steps (20%)
12:06:48:WU00:FS01:0x18:Completed 3360000 out of 16000000 steps (21%)
12:10:23:WU00:FS01:0x18:Completed 3520000 out of 16000000 steps (22%)
12:13:58:WU00:FS01:0x18:Completed 3680000 out of 16000000 steps (23%)
12:17:33:WU00:FS01:0x18:Completed 3840000 out of 16000000 steps (24%)
12:21:08:WU00:FS01:0x18:Completed 4000000 out of 16000000 steps (25%)
12:24:44:WU00:FS01:0x18:Completed 4160000 out of 16000000 steps (26%)
12:28:19:WU00:FS01:0x18:Completed 4320000 out of 16000000 steps (27%)
12:31:54:WU00:FS01:0x18:Completed 4480000 out of 16000000 steps (28%)
12:35:29:WU00:FS01:0x18:Completed 4640000 out of 16000000 steps (29%)
12:39:04:WU00:FS01:0x18:Completed 4800000 out of 16000000 steps (30%)
12:42:41:WU00:FS01:0x18:Completed 4960000 out of 16000000 steps (31%)
12:46:16:WU00:FS01:0x18:Completed 5120000 out of 16000000 steps (32%)
12:49:51:WU00:FS01:0x18:Completed 5280000 out of 16000000 steps (33%)
12:53:25:WU00:FS01:0x18:Completed 5440000 out of 16000000 steps (34%)
12:57:00:WU00:FS01:0x18:Completed 5600000 out of 16000000 steps (35%)
13:00:37:WU00:FS01:0x18:Completed 5760000 out of 16000000 steps (36%)
13:04:12:WU00:FS01:0x18:Completed 5920000 out of 16000000 steps (37%)
13:07:47:WU00:FS01:0x18:Completed 6080000 out of 16000000 steps (38%)
13:11:22:WU00:FS01:0x18:Completed 6240000 out of 16000000 steps (39%)
13:14:56:WU00:FS01:0x18:Completed 6400000 out of 16000000 steps (40%)
13:18:33:WU00:FS01:0x18:Completed 6560000 out of 16000000 steps (41%)
13:22:08:WU00:FS01:0x18:Completed 6720000 out of 16000000 steps (42%)
13:25:43:WU00:FS01:0x18:Completed 6880000 out of 16000000 steps (43%)
13:29:18:WU00:FS01:0x18:Completed 7040000 out of 16000000 steps (44%)
13:32:52:WU00:FS01:0x18:Completed 7200000 out of 16000000 steps (45%)
13:36:29:WU00:FS01:0x18:Completed 7360000 out of 16000000 steps (46%)
13:40:04:WU00:FS01:0x18:Completed 7520000 out of 16000000 steps (47%)
13:43:39:WU00:FS01:0x18:Completed 7680000 out of 16000000 steps (48%)
13:47:14:WU00:FS01:0x18:Completed 7840000 out of 16000000 steps (49%)
13:50:49:WU00:FS01:0x18:Completed 8000000 out of 16000000 steps (50%)
13:54:26:WU00:FS01:0x18:Completed 8160000 out of 16000000 steps (51%)
13:58:00:WU00:FS01:0x18:Completed 8320000 out of 16000000 steps (52%)
14:01:35:WU00:FS01:0x18:Completed 8480000 out of 16000000 steps (53%)
14:05:10:WU00:FS01:0x18:Completed 8640000 out of 16000000 steps (54%)
14:08:45:WU00:FS01:0x18:Completed 8800000 out of 16000000 steps (55%)
******************************* Date: 2016-01-07 *******************************
14:12:22:WU00:FS01:0x18:Completed 8960000 out of 16000000 steps (56%)
14:15:57:WU00:FS01:0x18:Completed 9120000 out of 16000000 steps (57%)
14:19:32:WU00:FS01:0x18:Completed 9280000 out of 16000000 steps (58%)
14:23:07:WU00:FS01:0x18:Completed 9440000 out of 16000000 steps (59%)
14:26:42:WU00:FS01:0x18:Completed 9600000 out of 16000000 steps (60%)
14:30:18:WU00:FS01:0x18:Completed 9760000 out of 16000000 steps (61%)
14:33:53:WU00:FS01:0x18:Completed 9920000 out of 16000000 steps (62%)
14:37:28:WU00:FS01:0x18:Completed 10080000 out of 16000000 steps (63%)
14:41:03:WU00:FS01:0x18:Completed 10240000 out of 16000000 steps (64%)
14:44:38:WU00:FS01:0x18:Completed 10400000 out of 16000000 steps (65%)
14:48:15:WU00:FS01:0x18:Completed 10560000 out of 16000000 steps (66%)
14:51:50:WU00:FS01:0x18:Completed 10720000 out of 16000000 steps (67%)
14:55:25:WU00:FS01:0x18:Completed 10880000 out of 16000000 steps (68%)
14:59:00:WU00:FS01:0x18:Completed 11040000 out of 16000000 steps (69%)
15:02:35:WU00:FS01:0x18:Completed 11200000 out of 16000000 steps (70%)
15:06:12:WU00:FS01:0x18:Completed 11360000 out of 16000000 steps (71%)
15:09:46:WU00:FS01:0x18:Completed 11520000 out of 16000000 steps (72%)
15:13:21:WU00:FS01:0x18:Completed 11680000 out of 16000000 steps (73%)
15:16:56:WU00:FS01:0x18:Completed 11840000 out of 16000000 steps (74%)
15:20:31:WU00:FS01:0x18:Completed 12000000 out of 16000000 steps (75%)
15:24:08:WU00:FS01:0x18:Completed 12160000 out of 16000000 steps (76%)
15:27:43:WU00:FS01:0x18:Completed 12320000 out of 16000000 steps (77%)
15:31:18:WU00:FS01:0x18:Completed 12480000 out of 16000000 steps (78%)
15:34:53:WU00:FS01:0x18:Completed 12640000 out of 16000000 steps (79%)
15:38:28:WU00:FS01:0x18:Completed 12800000 out of 16000000 steps (80%)
15:42:05:WU00:FS01:0x18:Completed 12960000 out of 16000000 steps (81%)
15:45:39:WU00:FS01:0x18:Completed 13120000 out of 16000000 steps (82%)
15:49:14:WU00:FS01:0x18:Completed 13280000 out of 16000000 steps (83%)
15:52:49:WU00:FS01:0x18:Completed 13440000 out of 16000000 steps (84%)
15:56:24:WU00:FS01:0x18:Completed 13600000 out of 16000000 steps (85%)
16:00:01:WU00:FS01:0x18:Completed 13760000 out of 16000000 steps (86%)
16:03:36:WU00:FS01:0x18:Completed 13920000 out of 16000000 steps (87%)
16:07:11:WU00:FS01:0x18:Completed 14080000 out of 16000000 steps (88%)
16:10:46:WU00:FS01:0x18:Completed 14240000 out of 16000000 steps (89%)
16:14:20:WU00:FS01:0x18:Completed 14400000 out of 16000000 steps (90%)
16:17:57:WU00:FS01:0x18:Completed 14560000 out of 16000000 steps (91%)
16:21:32:WU00:FS01:0x18:Completed 14720000 out of 16000000 steps (92%)
16:25:07:WU00:FS01:0x18:Completed 14880000 out of 16000000 steps (93%)
16:28:42:WU00:FS01:0x18:Completed 15040000 out of 16000000 steps (94%)
16:32:17:WU00:FS01:0x18:Completed 15200000 out of 16000000 steps (95%)
16:35:54:WU00:FS01:0x18:Completed 15360000 out of 16000000 steps (96%)
16:39:29:WU00:FS01:0x18:Completed 15520000 out of 16000000 steps (97%)
16:43:04:WU00:FS01:0x18:Completed 15680000 out of 16000000 steps (98%)
16:46:39:WU00:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
16:50:14:WU00:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
16:50:16:WU00:FS01:0x18:Saving result file logfile_01.txt
16:50:16:WU00:FS01:0x18:Saving result file checkpointState.xml
16:50:17:WU00:FS01:0x18:Saving result file checkpt.crc
16:50:17:WU00:FS01:0x18:Saving result file log.txt
16:50:17:WU00:FS01:0x18:Saving result file positions.xtc
16:50:20:WU00:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
16:50:21:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:50:21:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9430 run:58 clone:9 gen:154 core:0x18 unit:0x000000c2ab40413855474ccfcb7b4630
16:50:21:WU00:FS01:Uploading 23.98MiB to 171.64.65.56
16:50:21:WU00:FS01:Connecting to 171.64.65.56:8080
16:50:27:WU00:FS01:Upload 2.35%
16:50:33:WU00:FS01:Upload 5.21%
16:50:40:WU00:FS01:Upload 7.82%
16:50:50:WU00:FS01:Upload 11.73%
16:50:56:WU00:FS01:Upload 14.34%
16:51:04:WU00:FS01:Upload 17.72%
16:51:37:WU00:FS01:Upload 21.90%
16:51:44:WU00:FS01:Upload 26.33%
16:52:15:WU00:FS01:Upload 30.50%
16:52:34:WU00:FS01:Upload 34.93%
16:52:46:WU00:FS01:Upload 39.62%
16:53:06:WU00:FS01:Upload 43.79%
16:53:40:WU00:FS01:Upload 47.96%
16:53:49:WU00:FS01:Upload 52.39%
16:54:06:WU00:FS01:Upload 56.56%
16:54:33:WU00:FS01:Upload 60.99%
16:54:49:WU00:FS01:Upload 65.95%
16:55:22:WU00:FS01:Upload 70.12%
16:55:31:WU00:FS01:Upload 74.29%
16:56:04:WU00:FS01:Upload 78.72%
16:56:12:WU00:FS01:Upload 82.89%
16:56:29:WU00:FS01:Upload 87.32%
16:57:01:WU00:FS01:Upload 91.49%
16:57:10:WU00:FS01:Upload 95.66%
16:57:43:WU00:FS01:Upload 100.00%
16:58:09:WU00:FS01:Upload complete
16:58:09:WU00:FS01:Server responded WORK_QUIT (404)
16:58:09:WARNING:WU00:FS01:Server did not like results, dumping
EDIT: I didn't see the other thread when I posted this, but in my defense the last post was about two months ago. It appears that the problem has returned. Please feel free to merge this with the other thread.
