CPU WU does not finish or progress
ChuckSommer
Post by ChuckSommer »
I have a CPU WU that has been running a long time but not making progress.
On the FAHControl window it makes some progress, but the log does not reflect that progress.
The job is listed at 50,500,000 steps (yes I double checked counting the zeros).
I am running on a Win 8.1 machine, Intel I7 Quad Core, NVIDIA GeForce GTX 980 Ti
I just started folding on Folding@Home having loaded the SW something after 1-Sep.
Below is a portion of my LOG file. I had caused a PAUSE then FOLD to restart things so the log file starts from the restart:
17:11:42:WU00:FS00:Starting
17:11:42:WARNING:WU00:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail
17:11:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chuck/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5680 -checkpoint 5 -np 1
17:11:42:WU00:FS00:Started FahCore on PID 1480
17:11:42:WU00:FS00:Core PID:280
17:11:42:WU00:FS00:FahCore 0xa4 started
17:11:42:WU00:FS00:0xa4:
17:11:42:WU00:FS00:0xa4:*------------------------------*
17:11:42:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:11:42:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:11:42:WU00:FS00:0xa4:Preparing to commence simulation
17:11:42:WU00:FS00:0xa4:- Looking at optimizations...
17:11:42:WU00:FS00:0xa4:- Files status OK
17:11:42:WU00:FS00:0xa4:- Expanded 1866264 -> 3294644 (decompressed 176.5 percent)
17:11:42:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1866264 data_size=3294644, decompressed_data_size=3294644 diff=0
17:11:42:WU00:FS00:0xa4:- Digital signature verified
17:11:42:WU00:FS00:0xa4:Project: 7520 (Run 19, Clone 27, Gen 99)
17:11:42:WU00:FS00:0xa4:Assembly optimizations on if available.
17:11:42:WU00:FS00:0xa4:Entering M.D.
17:11:48:WU00:FS00:0xa4:Using Gromacs checkpoints
17:11:48:WU00:FS00:0xa4:Mapping NT from 1 to 1
17:11:48:WU00:FS00:0xa4:Resuming from checkpoint
17:11:48:WU00:FS00:0xa4:Verified 00/wudata_01.log
17:11:48:WU00:FS00:0xa4:Verified 00/wudata_01.trr
17:11:48:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
17:11:48:WU00:FS00:0xa4:Verified 00/wudata_01.edr
17:11:49:WU00:FS00:0xa4:Completed 606150 out of 50500000 steps  (1%)
17:11:59:Removing old file 'configs/config-20150909-135939.xml'
17:11:59:Saving configuration to config.xml
17:11:59:<config>
17:11:59:  <!-- Folding Core -->
17:11:59:  <checkpoint v='5'/>
17:11:59:
17:11:59:  <!-- Network -->
17:11:59:  <proxy v=':8080'/>
17:11:59:
17:11:59:  <!-- User Information -->
17:11:59:  <passkey v='********************************'/>
17:11:59:  <team v='40051'/>
17:11:59:  <user v='ChuckSommer'/>
17:11:59:
17:11:59:  <!-- Folding Slots -->
17:11:59:  <slot id='0' type='CPU'>
17:11:59:    <cpus v='1'/>
17:11:59:  </slot>
17:11:59:  <slot id='1' type='GPU'>
17:11:59:    <client-type v='bigadv'/>
17:11:59:  </slot>
17:11:59:</config>
17:13:48:108:127.0.0.1:New Web connection
17:14:28:WU02:FS01:0x18:Completed 7840000 out of 16000000 steps (49%)
17:18:35:WU02:FS01:0x18:Completed 8000000 out of 16000000 steps (50%)
17:20:20:FS00:Paused
17:20:20:FS01:Paused
17:20:20:FS00:Shutting core down
17:20:20:FS01:Shutting core down
17:20:20:WU02:FS01:0x18:WARNING:Console control signal 1 on PID 5196
17:20:20:WU02:FS01:0x18:Exiting, please wait. . .
17:20:21:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:20:22:WU00:FS00:0xa4:Client no longer detected. Shutting down core
17:20:22:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
17:20:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:20:39:FS00:Unpaused
17:20:39:FS01:Unpaused
17:20:39:WU00:FS00:Starting
17:20:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chuck/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5680 -checkpoint 5 -np 1
17:20:39:WU00:FS00:Started FahCore on PID 5288
17:20:39:WU00:FS00:Core PID:1052
17:20:39:WU00:FS00:FahCore 0xa4 started
17:20:39:WU02:FS01:Starting
17:20:39:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chuck/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 5680 -checkpoint 5 -gpu 0 -gpu-vendor nvidia
17:20:39:WU02:FS01:Started FahCore on PID 4360
17:20:39:WU02:FS01:Core PID:932
17:20:39:WU02:FS01:FahCore 0x18 started
17:20:40:WU00:FS00:0xa4:
17:20:40:WU00:FS00:0xa4:*------------------------------*
17:20:40:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:20:40:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:20:40:WU00:FS00:0xa4:Preparing to commence simulation
17:20:40:WU00:FS00:0xa4:- Looking at optimizations...
17:20:40:WU00:FS00:0xa4:- Files status OK
17:20:40:WU00:FS00:0xa4:- Expanded 1866264 -> 3294644 (decompressed 176.5 percent)
17:20:40:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1866264 data_size=3294644, decompressed_data_size=3294644 diff=0
17:20:40:WU00:FS00:0xa4:- Digital signature verified
17:20:40:WU00:FS00:0xa4:Project: 7520 (Run 19, Clone 27, Gen 99)
17:20:40:WU00:FS00:0xa4:Assembly optimizations on if available.
17:20:40:WU00:FS00:0xa4:Entering M.D.
17:20:40:WU02:FS01:0x18:*********************** Log Started 2015-09-10T17:20:39Z ***********************
17:20:40:WU02:FS01:0x18:Project: 9430 (Run 30, Clone 1, Gen 115)
17:20:40:WU02:FS01:0x18:Unit: 0x00000087ab40413855474c1071a0c13e
17:20:40:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
17:20:40:WU02:FS01:0x18:Machine: 1
17:20:40:WU02:FS01:0x18:Digital signatures verified
17:20:40:WU02:FS01:0x18:Folding@home GPU core18
17:20:40:WU02:FS01:0x18:Version 0.0.4
17:20:40:WU02:FS01:0x18:  Found a checkpoint file
17:20:45:WU00:FS00:0xa4:Using Gromacs checkpoints
17:20:45:WU00:FS00:0xa4:Mapping NT from 1 to 1
17:20:46:WU00:FS00:0xa4:Resuming from checkpoint
17:20:46:WU00:FS00:0xa4:Verified 00/wudata_01.log
17:20:46:WU00:FS00:0xa4:Verified 00/wudata_01.trr
17:20:46:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
17:20:46:WU00:FS00:0xa4:Verified 00/wudata_01.edr
17:20:46:WU00:FS00:0xa4:Completed 607130 out of 50500000 steps  (1%)
17:20:48:WU02:FS01:0x18:Completed 8050000 out of 16000000 steps (50%)
17:20:48:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:23:43:WU02:FS01:0x18:Completed 8160000 out of 16000000 steps (51%)
Mod edit: Please use Code tags around log file listings
Re: CPU WU does not finish or progress
Please include the first couple of pages of your log (where the configuration is shown).
There is no "bigadv" for GPU projects and for CPU projects, you need a minimum of 12 threads so it doesn't apply to your dual CPU. Apparently there's a new source circulating inaccurate recommendations.
With only a single CPU thread folding project 7520, it's going to take a very, very long time to complete such a big assignment.
ChuckSommer
Hi Bruce,
Thanks for telling me what I am doing wrong.
I thought there was a 24 thread minimum for the 'bigadv' switch.
I had been using 6 CPUs for this project, but reduced it to 1 when I saw it was not making progress.
I did not make it clear, but I think this WU (or project) is broken and wish to flush it from my machine.
It looked suspicious that a CPU project would require 50.50MegaSteps where the largest GPU project I saw took 16.00MegaSteps.
I will remove the 'bigadv' switch from my GPU as I have been told (another thread) that it does not apply to GPU projects.
ChuckSommer
Hi Bruce,
I have paused the folding, rebooted my system and restarted folding.
Below is the log
*********************** Log Started 2015-09-10T18:17:49Z ***********************
18:17:49:************************* Folding@home Client *************************
18:17:49:      Website: http://folding.stanford.edu/
18:17:49:    Copyright: (c) 2009-2014 Stanford University
18:17:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:17:49:         Args:
18:17:49:       Config: C:/Users/Chuck/AppData/Roaming/FAHClient/config.xml
18:17:49:******************************** Build ********************************
18:17:49:      Version: 7.4.4
18:17:49:         Date: Mar 4 2014
18:17:49:         Time: 20:26:54
18:17:49:      SVN Rev: 4130
18:17:49:       Branch: fah/trunk/client
18:17:49:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:17:49:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:17:49:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:17:49:     Platform: win32 XP
18:17:49:         Bits: 32
18:17:49:         Mode: Release
18:17:49:******************************* System ********************************
18:17:49:          CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
18:17:49:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:17:49:         CPUs: 8
18:17:49:       Memory: 31.95GiB
18:17:49:  Free Memory: 30.15GiB
18:17:49:      Threads: WINDOWS_THREADS
18:17:49:   OS Version: 6.2
18:17:49:  Has Battery: false
18:17:49:   On Battery: false
18:17:49:   UTC Offset: -4
18:17:49:          PID: 5408
18:17:49:          CWD: C:/Users/Chuck/AppData/Roaming/FAHClient
18:17:49:           OS: Windows 8.1 Pro
18:17:49:      OS Arch: AMD64
18:17:49:         GPUs: 1
18:17:49:        GPU 0: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
18:17:49:         CUDA: 5.2
18:17:49:  CUDA Driver: 7050
18:17:49:Win32 Service: false
18:17:49:***********************************************************************
18:17:49:<config>
18:17:49:  <!-- Folding Core -->
18:17:49:  <checkpoint v='5'/>
18:17:49:
18:17:49:  <!-- Network -->
18:17:49:  <proxy v=':8080'/>
18:17:49:
18:17:49:  <!-- User Information -->
18:17:49:  <passkey v='********************************'/>
18:17:49:  <team v='40051'/>
18:17:49:  <user v='ChuckSommer'/>
18:17:49:
18:17:49:  <!-- Folding Slots -->
18:17:49:  <slot id='0' type='CPU'>
18:17:49:    <cpus v='1'/>
18:17:49:    <paused v='true'/>
18:17:49:  </slot>
18:17:49:  <slot id='1' type='GPU'>
18:17:49:    <client-type v='bigadv'/>
18:17:49:  </slot>
18:17:49:</config>
18:17:49:Trying to access database...
18:17:49:Successfully acquired database lock
18:17:49:Enabled folding slot 00: PAUSED cpu:1 (by user)
18:17:49:Enabled folding slot 01: PAUSED gpu:0:GM200 [GeForce GTX 980 Ti] (by user)
18:23:27:FS00:Unpaused
18:23:27:FS01:Unpaused
18:23:27:WU02:FS01:Starting
18:23:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chuck/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 5408 -checkpoint 5 -gpu 0 -gpu-vendor nvidia
18:23:27:WU02:FS01:Started FahCore on PID 2704
18:23:27:WU02:FS01:Core PID:1296
18:23:27:WU02:FS01:FahCore 0x18 started
18:23:27:WU00:FS00:Starting
18:23:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chuck/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5408 -checkpoint 5 -np 1
18:23:27:WU00:FS00:Started FahCore on PID 3760
18:23:27:WU00:FS00:Core PID:668
18:23:27:WU00:FS00:FahCore 0xa4 started
18:23:28:WU02:FS01:0x18:*********************** Log Started 2015-09-10T18:23:27Z ***********************
18:23:28:WU02:FS01:0x18:Project: 9430 (Run 30, Clone 1, Gen 115)
18:23:28:WU02:FS01:0x18:Unit: 0x00000087ab40413855474c1071a0c13e
18:23:28:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
18:23:28:WU02:FS01:0x18:Machine: 1
18:23:28:WU02:FS01:0x18:Digital signatures verified
18:23:28:WU02:FS01:0x18:Folding@home GPU core18
18:23:28:WU02:FS01:0x18:Version 0.0.4
18:23:28:WU02:FS01:0x18:  Found a checkpoint file
18:23:28:WU00:FS00:0xa4:
18:23:28:WU00:FS00:0xa4:*------------------------------*
18:23:28:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
18:23:28:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
18:23:28:WU00:FS00:0xa4:Preparing to commence simulation
18:23:28:WU00:FS00:0xa4:- Looking at optimizations...
18:23:28:WU00:FS00:0xa4:- Files status OK
18:23:28:WU00:FS00:0xa4:- Expanded 1866264 -> 3294644 (decompressed 176.5 percent)
18:23:28:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1866264 data_size=3294644, decompressed_data_size=3294644 diff=0
18:23:28:WU00:FS00:0xa4:- Digital signature verified
18:23:28:WU00:FS00:0xa4:Project: 7520 (Run 19, Clone 27, Gen 99)
18:23:28:WU00:FS00:0xa4:Assembly optimizations on if available.
18:23:28:WU00:FS00:0xa4:Entering M.D.
18:23:34:WU00:FS00:0xa4:Using Gromacs checkpoints
18:23:34:WU00:FS00:0xa4:Mapping NT from 1 to 1
18:23:34:WU00:FS00:0xa4:Resuming from checkpoint
18:23:34:WU00:FS00:0xa4:Verified 00/wudata_01.log
18:23:34:WU00:FS00:0xa4:Verified 00/wudata_01.trr
18:23:34:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
18:23:34:WU00:FS00:0xa4:Verified 00/wudata_01.edr
18:23:35:WU00:FS00:0xa4:Completed 617870 out of 50500000 steps  (1%)
18:23:36:WU02:FS01:0x18:Completed 10150000 out of 16000000 steps (63%)
18:23:36:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:23:55:Removing old file 'configs/config-20150909-153240.xml'
18:23:55:Saving configuration to config.xml
18:23:55:<config>
18:23:55:  <!-- Folding Core -->
18:23:55:  <checkpoint v='5'/>
18:23:55:
18:23:55:  <!-- Network -->
18:23:55:  <proxy v=':8080'/>
18:23:55:
18:23:55:  <!-- User Information -->
18:23:55:  <passkey v='********************************'/>
18:23:55:  <team v='40051'/>
18:23:55:  <user v='ChuckSommer'/>
18:23:55:
18:23:55:  <!-- Folding Slots -->
18:23:55:  <slot id='0' type='CPU'>
18:23:55:    <cpus v='1'/>
18:23:55:  </slot>
18:23:55:  <slot id='1' type='GPU'>
18:23:55:    <client-type v='bigadv'/>
18:23:55:  </slot>
18:23:55:</config>
I agree that t of 50500000 steps must be wrong. I'll report it to the server's owner.
This may just be Project: 7520 (Run 19, Clone 27, Gen 99) but I think that's unlikely.
That server has been having troubles recently.
From This post, the correct number of steps should be 500,000.
ChuckSommer
Thanks for getting back to me.
So how do I flush it and move on to something useful?
Or should I donate to Seti@home instead.
Chuck
The most direct method of dumping a WU is to delete (all of) the slot(s) that could process the WU, save the configuration. Wait briefly, then re-add the slot.
ChuckSommer
Thanks Bruce, I have moved on to
18:59:38:WU00:FS00:0xa4:Project: 9015 (Run 454, Clone 1, Gen 38)
Chuck
