Project: 7528 (Run 40, Clone 0, Gen 77)
Locked
Corrupted WU and/or transfer :
07:34:32:WU01:FS00:Connecting to 171.67.108.200:8080
07:34:33:WU01:FS00:Assigned to work server 128.143.199.97
07:34:33:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 128.143.199.97
07:34:33:WU01:FS00:Connecting to 128.143.199.97:8080
07:34:35:WU01:FS00:Downloading 1.90KiB
07:34:35:WU01:FS00:Download complete
07:34:35:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7528 run:40 clone:0 gen:77 core:0xa4 unit:0x00000069fbcb017d55990a04f0a99bd5
One error : WARNING:WU01:FS00:FahCore returned: FAILED_3 (255 = 0xff)
Then four errors :
WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
Each error matches with an application crash report in Action center :
Nom d’événement du problème :	BEX
Nom de l’application:	FahCore_a4.exe
Version de l’application:	0.0.0.0
Horodatage de l’application:	4d23eafc
Nom du module par défaut:	FahCore_a4.exe
Version du module par défaut:	0.0.0.0
Horodateur du module par défaut:	4d23eafc
Décalage de l’exception:	0008816d
Code de l’exception:	c0000417
Données d’exception:	00000000
Version du système:	6.3.9600.2.0.0.768.101
Identificateur de paramètres régionaux:	1036
Information supplémentaire n° 1:	ca10
Information supplémentaire n° 2:	ca1028ccb4a7c36cfce7636d6f685cc4
Information supplémentaire n° 3:	2f5d
Information supplémentaire n° 4:	2f5d8ca64134d4f026612082a1dd66df
07:36:12:WU01:FS00:FahCore 0xa4 started
07:36:12:WU01:FS00:0xa4:
07:36:12:WU01:FS00:0xa4:*------------------------------*
07:36:12:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
07:36:12:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:36:12:WU01:FS00:0xa4:Preparing to commence simulation
07:36:12:WU01:FS00:0xa4:- Looking at optimizations...
07:36:12:WU01:FS00:0xa4:- Created dyn
07:36:12:WU01:FS00:0xa4:- Files status OK
07:36:12:WU01:FS00:0xa4:- Expanded 1433 -> 8192 (decompressed 571.6 percent)
07:36:12:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1433 data_size=8192, decompressed_data_size=8192 diff=0
07:36:12:WU01:FS00:0xa4:- Digital signature verified
07:36:12:WU01:FS00:0xa4:Project: 7528 (Run 40, Clone 0, Gen 77)
07:36:12:WU01:FS00:0xa4:Assembly optimizations on if available.
07:36:12:WU01:FS00:0xa4:Entering M.D.
07:36:18:WU01:FS00:0xa4:Mapping NT from 7 to 7
07:36:18:WU00:FS00:Upload complete
07:36:18:WU00:FS00:Server responded WORK_ACK (400)
07:36:18:WU00:FS00:Final credit estimate, 1596.00 points
07:36:18:WU00:FS00:Cleaning up
07:36:19:WARNING:WU01:FS00:FahCore returned: FAILED_3 (255 = 0xff)
07:36:20:WU01:FS00:Starting
07:36:20:WU01:FS00:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe D:/FAHClientData/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5704 -checkpoint 15 -np 7
07:36:20:WU01:FS00:Started FahCore on PID 6384
07:36:20:WU01:FS00:Core PID:6164
07:36:20:WU01:FS00:FahCore 0xa4 started
07:36:20:WU01:FS00:0xa4:
07:36:20:WU01:FS00:0xa4:*------------------------------*
07:36:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
07:36:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:36:20:WU01:FS00:0xa4:Preparing to commence simulation
07:36:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
07:36:29:WU01:FS00:0xa4:- Looking at optimizations...
07:36:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
07:36:29:WU01:FS00:0xa4:- Previous termination of core was improper.
07:36:29:WU01:FS00:0xa4:- Files status OK
07:36:29:WU01:FS00:0xa4:- Expanded 1433 -> 8192 (decompressed 571.6 percent)
07:36:29:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1433 data_size=8192, decompressed_data_size=8192 diff=0
07:36:29:WU01:FS00:0xa4:- Digital signature verified
07:36:29:WU01:FS00:0xa4:Project: 7528 (Run 40, Clone 0, Gen 77)
07:36:29:WU01:FS00:0xa4:Entering M.D.
07:36:35:WU01:FS00:0xa4:Mapping NT from 7 to 7
07:36:37:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:36:37:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
07:37:20:WU01:FS00:Starting
07:37:20:WU01:FS00:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe D:/FAHClientData/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5704 -checkpoint 15 -np 7
07:37:20:WU01:FS00:Started FahCore on PID 2312
07:37:20:WU01:FS00:Core PID:2124
07:37:20:WU01:FS00:FahCore 0xa4 started
07:37:20:WU01:FS00:0xa4:
07:37:20:WU01:FS00:0xa4:*------------------------------*
07:37:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
07:37:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:37:20:WU01:FS00:0xa4:Preparing to commence simulation
07:37:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
07:37:29:WU01:FS00:0xa4:- Looking at optimizations...
07:37:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
07:37:29:WU01:FS00:0xa4:- Previous termination of core was improper.
07:37:29:WU01:FS00:0xa4:- Going to use standard loops.
07:37:29:WU01:FS00:0xa4:- Files status OK
07:37:29:WU01:FS00:0xa4:- Expanded 1433 -> 8192 (decompressed 571.6 percent)
07:37:29:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1433 data_size=8192, decompressed_data_size=8192 diff=0
07:37:29:WU01:FS00:0xa4:- Digital signature verified
07:37:29:WU01:FS00:0xa4:Project: 7528 (Run 40, Clone 0, Gen 77)
07:37:29:WU01:FS00:0xa4:Entering M.D.
07:37:35:WU01:FS00:0xa4:Mapping NT from 7 to 7
07:37:37:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:37:37:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
07:38:20:WU01:FS00:Starting
07:38:20:WU01:FS00:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe D:/FAHClientData/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5704 -checkpoint 15 -np 7
07:38:20:WU01:FS00:Started FahCore on PID 2772
07:38:20:WU01:FS00:Core PID:5380
07:38:20:WU01:FS00:FahCore 0xa4 started
07:38:20:WU01:FS00:0xa4:
07:38:20:WU01:FS00:0xa4:*------------------------------*
07:38:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
07:38:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:38:20:WU01:FS00:0xa4:Preparing to commence simulation
07:38:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
07:38:29:WU01:FS00:0xa4:- Looking at optimizations...
07:38:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
07:38:29:WU01:FS00:0xa4:- Previous termination of core was improper.
07:38:29:WU01:FS00:0xa4:- Going to use standard loops.
07:38:29:WU01:FS00:0xa4:- Files status OK
07:38:29:WU01:FS00:0xa4:- Expanded 1433 -> 8192 (decompressed 571.6 percent)
07:38:29:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1433 data_size=8192, decompressed_data_size=8192 diff=0
07:38:29:WU01:FS00:0xa4:- Digital signature verified
07:38:29:WU01:FS00:0xa4:Project: 7528 (Run 40, Clone 0, Gen 77)
07:38:29:WU01:FS00:0xa4:Entering M.D.
07:38:36:WU01:FS00:0xa4:Mapping NT from 7 to 7
07:38:36:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:38:36:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
07:39:20:WU01:FS00:Starting
07:39:20:WU01:FS00:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe D:/FAHClientData/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5704 -checkpoint 15 -np 7
07:39:20:WU01:FS00:Started FahCore on PID 6620
07:39:20:WU01:FS00:Core PID:5048
07:39:20:WU01:FS00:FahCore 0xa4 started
07:39:20:WU01:FS00:0xa4:
07:39:20:WU01:FS00:0xa4:*------------------------------*
07:39:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
07:39:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:39:20:WU01:FS00:0xa4:Preparing to commence simulation
07:39:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
07:39:29:WU01:FS00:0xa4:- Looking at optimizations...
07:39:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
07:39:29:WU01:FS00:0xa4:- Previous termination of core was improper.
07:39:29:WU01:FS00:0xa4:- Going to use standard loops.
07:39:29:WU01:FS00:0xa4:- Files status OK
07:39:29:WU01:FS00:0xa4:- Expanded 1433 -> 8192 (decompressed 571.6 percent)
07:39:29:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1433 data_size=8192, decompressed_data_size=8192 diff=0
07:39:29:WU01:FS00:0xa4:- Digital signature verified
07:39:29:WU01:FS00:0xa4:Project: 7528 (Run 40, Clone 0, Gen 77)
07:39:29:WU01:FS00:0xa4:Entering M.D.
07:39:36:WU01:FS00:0xa4:Mapping NT from 7 to 7
07:39:37:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:39:37:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740777 = 0xc0000417)
07:39:37:WARNING:WU01:FS00:Too many errors, failing
07:39:37:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:7528 run:40 clone:0 gen:77 core:0xa4 unit:0x00000069fbcb017d55990a04f0a99bd5
07:39:37:WU01:FS00:Connecting to 128.143.199.97:8080
07:39:37:WU00:FS00:Connecting to 171.67.108.200:8080
07:39:38:WU01:FS00:Server responded WORK_QUIT (404)
07:39:38:WARNING:WU01:FS00:Server did not like results, dumping
Re: Project: 7528 (Run 40, Clone 0, Gen 77)
PG is working on the problem with Server 128.143.199.97 {projects 75xx}. Topic closed.
Locked
