Core 21 not working on Radeon 6850
_r2w_ben
Post by _r2w_ben »
System configuration is as follows:
AMD A8-7600 Kaveri (SMP 2 cores)
APU R7 Graphics (Spectre) (GPU slot)
GPU: Radeon 6850 (Barts) (GPU slot)
Core 17 runs fine on both GPUs. Core 21 runs fine on the graphics portion of the APU. Core 21 on the 6850 causes a display driver reset several times and a complete lock-up once.
Does Core 21 require OpenCL 2.0 support or does it have an OpenCL 1.2 code path as well?
In the log below you can see that Spectre supports OpenCL 2.0 but the CPU and 6850 do not. Is it possible the detection code finds that one GPU supports 2.0 and then incorrectly attempts to use that on the 6850, which only supports 1.2?
Project: 9704 (Run 98, Clone 12, Gen 0)
Unit: 0x00000001ab404162553ecb2213baaae0
CPU: 0x00000000000000000000000000000000
Machine: 1
Reading tar file core.xml
Reading tar file system.xml
Reading tar file integrator.xml
Reading tar file state.xml
Digital signatures verified
*************************** Core21 Folding@home Core ***************************
       Type: 33
       Core: Core21
    Website: http://folding.stanford.edu/
  Copyright: (c) 2009-2014 Stanford University
     Author: Yutong Zhao <yutong.zhao@stanford.edu>
       Args: -dir 01 -suffix 01 -version 704 -lifeline 3740 -checkpoint 15 -gpu
             0 -gpu-vendor ati
     Config: <none>
************************************ Build *************************************
    Version: 0.0.11
       Date: Aug 4 2015
       Time: 12:04:34
   Compiler: Visual C++ 2008
    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE2 /MT
   Platform: win32 7
       Bits: 64
       Mode: Release
************************************ System ************************************
        CPU: Unknown
     CPU ID:
       CPUs: 4
     Memory: 6.94GiB
Free Memory: 5.41GiB
    Threads: WINDOWS_THREADS
 OS Version: 6.2
Has Battery: true
 On Battery: false
 UTC Offset: -4
        PID: 4456
        CWD: C:\Users\<snip>\AppData\Roaming\FAHClient\work
         OS: Windows 8.1
    OS Arch: AMD64
       GPUs: 2
      GPU 0: Bus:0 Slot:1 ATI:5 xxxx [Radeon R7]
      GPU 1: Bus:1 Slot:0 ATI:4 Barts PRO [Radeon HD 6800 Series]
       CUDA: Not detected
     OpenCL: Not detected
Folding@home GPU Core21 Folding@home Core
Version 0.0.11
[1] compatible platform(s):
  -- 0 --
  PROFILE = FULL_PROFILE
  VERSION = OpenCL 2.0 AMD-APP (1800.8)
  NAME = AMD Accelerated Parallel Processing
  VENDOR = Advanced Micro Devices, Inc.
(3) device(s) found on platform 0:
  -- 0 --
  DEVICE_NAME = Barts
  DEVICE_VENDOR = Advanced Micro Devices, Inc.
  DEVICE_VERSION = OpenCL 1.2 AMD-APP (1800.8)
  -- 1 --
  DEVICE_NAME = Spectre
  DEVICE_VERSION = OpenCL 2.0 AMD-APP (1800.8)
  -- 2 --
  DEVICE_NAME = AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G
  DEVICE_VENDOR = AuthenticAMD
[ Entering Init ]
  Launch time: 2015-09-01T02:11:39Z
  Arguments passed: -dir 01 -suffix 01 -version 704 -lifeline 3740 -checkpoint 15 -gpu 0 -gpu-vendor ati
[ Leaving  Init ]
[ Entering Main ]
  Reading core settings...
  Total number of steps: 640000
  XTC write frequency: 80000
[ Initializing Core Contexts ]
  Using platform OpenCL
  Looking for vendor: ati...found on platformId 0
  Deserializing System...
  Setting up Force Groups:
    Group 0: Everything Else
    Group 1: Nonbonded Direct Space
    Group 2: Nonbonded Reciprocal Space
  Found MonteCarloBarostat @ 1.01325 (default) Bar, 300 Kelvin, 25 pressure change frequency.
    Found: 171944 atoms, 6 forces.
  Deserializing State...  done.
    Integrator Type: class OpenMM::LangevinIntegrator
    Constraint Tolerance: 1e-005
    Time Step in PS: 0.002
    Temperature: 300
    Friction Coeff: 1
  Checking core state against reference...
Re: Core 21 not working on Radeon 6850
Please post the fah log including the System section.
_r2w_ben
Post by _r2w_ben »
System Section:
*********************** Log Started 2015-09-01T03:15:07Z ***********************
03:15:07:************************* Folding@home Client *************************
03:15:07:      Website: http://folding.stanford.edu/
03:15:07:    Copyright: (c) 2009-2014 Stanford University
03:15:07:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:15:07:         Args: --open-web-control
03:15:07:       Config: C:/Users/****/AppData/Roaming/FAHClient/config.xml
03:15:07:******************************** Build ********************************
03:15:07:      Version: 7.4.4
03:15:07:         Date: Mar 4 2014
03:15:07:         Time: 20:26:54
03:15:07:      SVN Rev: 4130
03:15:07:       Branch: fah/trunk/client
03:15:07:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:15:07:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:15:07:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:15:07:     Platform: win32 XP
03:15:07:         Bits: 32
03:15:07:         Mode: Release
03:15:07:******************************* System ********************************
03:15:07:          CPU: AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G
03:15:07:       CPU ID: AuthenticAMD Family 21 Model 48 Stepping 1
03:15:07:         CPUs: 4
03:15:07:       Memory: 6.94GiB
03:15:07:  Free Memory: 5.62GiB
03:15:07:      Threads: WINDOWS_THREADS
03:15:07:   OS Version: 6.2
03:15:07:  Has Battery: true
03:15:07:   On Battery: false
03:15:07:   UTC Offset: -4
03:15:07:          PID: 176
03:15:07:          CWD: C:/Users/****/AppData/Roaming/FAHClient
03:15:07:           OS: Windows 8.1
03:15:07:      OS Arch: AMD64
03:15:07:         GPUs: 2
03:15:07:        GPU 0: ATI:5 xxxx [Radeon R7]
03:15:07:        GPU 1: ATI:4 Barts PRO [Radeon HD 6800 Series]
03:15:07:         CUDA: Not detected
03:15:07:Win32 Service: false
03:15:07:***********************************************************************
03:15:07:<config>
03:15:07:  <!-- Network -->
03:15:07:  <proxy v=':8080'/>
03:15:07:
03:15:07:  <!-- Slot Control -->
03:15:07:  <power v='full'/>
03:15:07:
03:15:07:  <!-- User Information -->
03:15:07:  <passkey v='********************************'/>
03:15:07:  <team v='11108'/>
03:15:07:  <user v='_r2w_ben'/>
03:15:07:
03:15:07:  <!-- Folding Slots -->
03:15:07:  <slot id='0' type='CPU'>
03:15:07:    <cpus v='2'/>
03:15:07:  </slot>
03:15:07:  <slot id='1' type='GPU'>
03:15:07:    <gpu-index v='1'/>
03:15:07:    <opencl-index v='0'/>
03:15:07:  </slot>
03:15:07:  <slot id='2' type='GPU'>
03:15:07:    <gpu-index v='0'/>
03:15:07:    <opencl-index v='1'/>
03:15:07:  </slot>
03:15:07:</config>
Filtered Slot 1:
03:15:28:WU02:FS01:Starting
03:15:28:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/****/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 176 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:15:28:WU02:FS01:Started FahCore on PID 3016
03:15:28:WU02:FS01:Core PID:2632
03:15:28:WU02:FS01:FahCore 0x21 started
03:15:28:WU02:FS01:0x21:*********************** Log Started 2015-09-01T03:15:28Z ***********************
03:15:28:WU02:FS01:0x21:Project: 9704 (Run 102, Clone 10, Gen 0)
03:15:28:WU02:FS01:0x21:Unit: 0x00000001ab404162553ecbb5a9cef09e
03:15:28:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:15:28:WU02:FS01:0x21:Machine: 1
03:15:29:WU02:FS01:0x21:Reading tar file core.xml
03:15:29:WU02:FS01:0x21:Reading tar file system.xml
03:15:32:WU02:FS01:0x21:Reading tar file integrator.xml
03:15:32:WU02:FS01:0x21:Reading tar file state.xml
03:15:35:WU02:FS01:0x21:Digital signatures verified
03:15:35:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:15:35:WU02:FS01:0x21:Version 0.0.11
03:18:10:FS01:Paused
03:18:10:FS01:Shutting core down
03:18:10:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 2632
03:18:10:WU02:FS01:0x21:Exiting, please wait. . .
03:18:16:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:18:41:FS01:Unpaused
03:18:41:WU02:FS01:Starting
03:18:41:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/****/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 176 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:18:41:WU02:FS01:Started FahCore on PID 3548
03:18:41:WU02:FS01:Core PID:1800
03:18:41:WU02:FS01:FahCore 0x21 started
03:18:42:WU02:FS01:0x21:*********************** Log Started 2015-09-01T03:18:41Z ***********************
03:18:42:WU02:FS01:0x21:ERROR:Failed to open '../wudata_01.dat': Failed to open '../wudata_01.dat': The system cannot find the file specified.
03:18:42:WU02:FS01:0x21:ERROR:: The system cannot find the file specified.
03:18:42:WU02:FS01:0x21:Saving result file logfile_01.txt
03:18:42:WU02:FS01:0x21:Saving result file log.txt
03:18:42:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:18:42:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:18:42:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9704 run:102 clone:10 gen:0 core:0x21 unit:0x00000001ab404162553ecbb5a9cef09e
03:18:42:WU02:FS01:Uploading 3.50KiB to 171.64.65.98
03:18:42:WU02:FS01:Connecting to 171.64.65.98:8080
03:18:42:WU02:FS01:Upload complete
03:18:42:WU02:FS01:Server responded WORK_QUIT (404)
03:18:42:WARNING:WU02:FS01:Server did not like results, dumping
03:18:42:WU02:FS01:Cleaning up
03:18:43:WU01:FS01:Connecting to 171.67.108.200:80
03:18:45:WU01:FS01:Assigned to work server 171.64.65.98
03:18:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:Barts PRO [Radeon HD 6800 Series] from 171.64.65.98
03:18:45:WU01:FS01:Connecting to 171.64.65.98:8080
03:18:46:WU01:FS01:Downloading 15.72MiB
03:18:52:WU01:FS01:Download 50.48%
03:18:58:WU01:FS01:Download 89.83%
03:18:59:WU01:FS01:Download complete
03:18:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9704 run:51 clone:10 gen:12 core:0x21 unit:0x00000010ab404162553ec3bc718d9548
03:18:59:WU01:FS01:Starting
03:18:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/****/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 176 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:18:59:WU01:FS01:Started FahCore on PID 2612
03:18:59:WU01:FS01:Core PID:360
03:18:59:WU01:FS01:FahCore 0x21 started
03:18:59:WU01:FS01:0x21:*********************** Log Started 2015-09-01T03:18:59Z ***********************
03:18:59:WU01:FS01:0x21:Project: 9704 (Run 51, Clone 10, Gen 12)
03:18:59:WU01:FS01:0x21:Unit: 0x00000010ab404162553ec3bc718d9548
03:18:59:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:18:59:WU01:FS01:0x21:Machine: 1
03:18:59:WU01:FS01:0x21:Reading tar file core.xml
03:18:59:WU01:FS01:0x21:Reading tar file system.xml
03:19:05:WU01:FS01:0x21:Reading tar file integrator.xml
03:19:05:WU01:FS01:0x21:Reading tar file state.xml
03:19:09:WU01:FS01:0x21:Digital signatures verified
03:19:09:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:19:09:WU01:FS01:0x21:Version 0.0.11
03:23:51:WARNING:WU01:FS01:FahCore returned: FAILED_2 (1 = 0x1)
03:23:51:WU01:FS01:Starting
03:23:52:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/****/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 176 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:23:52:WU01:FS01:Started FahCore on PID 180
03:23:52:WU01:FS01:Core PID:1768
03:23:52:WU01:FS01:FahCore 0x21 started
03:23:52:WU01:FS01:0x21:*********************** Log Started 2015-09-01T03:23:52Z ***********************
03:23:52:WU01:FS01:0x21:Project: 9704 (Run 51, Clone 10, Gen 12)
03:23:52:WU01:FS01:0x21:Unit: 0x00000010ab404162553ec3bc718d9548
03:23:52:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:23:52:WU01:FS01:0x21:Machine: 1
03:23:52:WU01:FS01:0x21:Reading tar file core.xml
03:23:52:WU01:FS01:0x21:Reading tar file system.xml
03:23:58:WU01:FS01:0x21:Reading tar file integrator.xml
03:23:58:WU01:FS01:0x21:Reading tar file state.xml
03:24:02:WU01:FS01:0x21:Digital signatures verified
03:24:02:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:24:02:WU01:FS01:0x21:Version 0.0.11
03:24:19:WARNING:WU01:FS01:FahCore returned: FAILED_2 (1 = 0x1)
03:24:50:FS01:Paused
When the display driver resets, I have to kill FahCore_21.exe via Task Manager after pausing the slot.
Event Viewer entry:
Event ID: 4101 Display driver amdkmdap stopped responding and has successfully recovered.
What catalyst driver version? And how did you determine which custom index settings to use on the GPU slots?
difrago
Post by difrago »
same problem with core 21 GPU.
My system is:
CPU: AMD FX-8150
GPU:ATI RADEON HD-6850
OS: WINDOWS 10 PRO (64bit).
gpu driver constantly crashes with core 21.
_r2w_ben
Post by _r2w_ben »
7im wrote:What catalyst driver version? And how did you determine which custom index settings to use on the GPU slots?
Catalyst 15.7.1
I configured the index settings about a year ago using a guide on this forum. I think I used GPU-Z to monitor load when only one GPU slot was running.
Have you checked recently to see if those index settings are still valid? Connected with the values being not set correctly initially, have been reports in the past that some system changes such as video driver upgrades can cause the indexes to change again.
_r2w_ben
Post by _r2w_ben »
Joe_H wrote:Have you checked recently to see if those index settings are still valid? Connected with the values being not set correctly initially, have been reports in the past that some system changes such as video driver upgrades can cause the indexes to change again.
The indexes are working as expected. The 6850 works great when it is assigned Core 17 work.
My original question about OpenCL versions has not been answered. Does Core 21 require GCN which debuted in the 7xxx series of cards? Can someone check the stats to see if any AMD pre 7xxx series cards have completed p9704 or p9712 work units?
_r2w_ben
Post by _r2w_ben »
I did some digging in the beta forum and found that Core 21 requires OpenCL 1.2 for AMD and OpenCL 1.1 for nVidia.
Is double precision required for Core 21? The 6850 does not have that capability.
GPU Caps Viewer OpenCL Capabilities
6850
	- CL_DEVICE_NAME: Barts
	- CL_DEVICE_VENDOR: Advanced Micro Devices, Inc.
	- CL_DRIVER_VERSION: 1800.8 (VM)
	- CL_DEVICE_PROFILE: FULL_PROFILE
	- CL_DEVICE_VERSION: OpenCL 1.2 AMD-APP (1800.8)
	- CL_DEVICE_TYPE: GPU
	- CL_DEVICE_VENDOR_ID: 0x1002
	- CL_DEVICE_MAX_COMPUTE_UNITS: 12
	- CL_DEVICE_MAX_CLOCK_FREQUENCY: 820MHz
	- CL_DEVICE_ADDRESS_BITS: 32
	- CL_DEVICE_MAX_MEM_ALLOC_SIZE: 524288KB
	- CL_DEVICE_GLOBAL_MEM_SIZE: 1024MB
	- CL_DEVICE_MAX_PARAMETER_SIZE: 1024
	- CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE: 0 Bytes
	- CL_DEVICE_GLOBAL_MEM_CACHE_SIZE: 0KB
	- CL_DEVICE_ERROR_CORRECTION_SUPPORT: NO
	- CL_DEVICE_LOCAL_MEM_TYPE: Local (scratchpad)
	- CL_DEVICE_LOCAL_MEM_SIZE: 32KB
	- CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64KB
	- CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
	- CL_DEVICE_MAX_WORK_ITEM_SIZES: [256 ; 256 ; 256]
	- CL_DEVICE_MAX_WORK_GROUP_SIZE: 256
	- CL_EXEC_NATIVE_KERNEL: 2195144
	- CL_DEVICE_IMAGE_SUPPORT: YES
	- CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
	- CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 8
	- CL_DEVICE_IMAGE2D_MAX_WIDTH: 16384
	- CL_DEVICE_IMAGE2D_MAX_HEIGHT: 16384
	- CL_DEVICE_IMAGE3D_MAX_WIDTH: 2048
	- CL_DEVICE_IMAGE3D_MAX_HEIGHT: 2048
	- CL_DEVICE_IMAGE3D_MAX_DEPTH: 2048
	- CL_DEVICE_MAX_SAMPLERS: 16
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR: 16
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT: 8
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT: 4
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG: 2
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT: 4
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE: 0
	- CL_DEVICE_EXTENSIONS: 20
	- Extensions:
		- cl_khr_global_int32_base_atomics
		- cl_khr_global_int32_extended_atomics
		- cl_khr_local_int32_base_atomics
		- cl_khr_local_int32_extended_atomics
		- cl_khr_3d_image_writes
		- cl_khr_byte_addressable_store
		- cl_khr_gl_sharing
		- cl_ext_atomic_counters_32
		- cl_amd_device_attribute_query
		- cl_amd_vec3
		- cl_amd_printf
		- cl_amd_media_ops
		- cl_amd_media_ops2
		- cl_amd_popcnt
		- cl_khr_d3d10_sharing
		- cl_khr_d3d11_sharing
		- cl_khr_dx9_media_sharing
		- cl_amd_image2d_from_buffer_read_only
		- cl_khr_spir
		- cl_khr_gl_event
Radeon R7
	- CL_DEVICE_NAME: Spectre
	- CL_DEVICE_MAX_COMPUTE_UNITS: 6
	- CL_DEVICE_MAX_MEM_ALLOC_SIZE: 1179072KB
	- CL_DEVICE_GLOBAL_MEM_SIZE: 2559MB
	- CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE: 64 Bytes
	- CL_DEVICE_GLOBAL_MEM_CACHE_SIZE: 16KB
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR: 4
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT: 2
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT: 1
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG: 1
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT: 1
	- CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE: 1
	- CL_DEVICE_EXTENSIONS: 24
	- Extensions:
		- cl_khr_fp64
		- cl_amd_fp64
		- cl_khr_int64_base_atomics
		- cl_khr_int64_extended_atomics
		- cl_khr_gl_sharing
		- cl_amd_vec3
		- cl_amd_printf
		- cl_amd_media_ops
		- cl_amd_media_ops2
		- cl_amd_popcnt
		- cl_khr_image2d_from_buffer
		- cl_khr_spir
		- cl_khr_gl_event
Double precision is not required, and not used. I have asked the core 21 developers about minimum hardware support on AMD GPUs.
mpharrigan
Pande Group Member
Post by mpharrigan »
Hi all, I've been monitoring this thread and I'll try to get some answers out of the devs
Post by foldy »
@_r2w_ben: If you want to do an experiment you can try running FahBench 2.1.2 beta on your device to see if that works.
Because FahBench 2.1.2 uses the same OpenMM like Core_21 just to see if this fails too.
https://github.com/pandegroup/fahbench/ ... -win64.zip
_r2w_ben
Post by _r2w_ben »
foldy wrote:@_r2w_ben: If you want to do an experiment you can try running FahBench 2.1.2 beta on your device to see if that works.
Benchmark Results
Barts: 7.4 ns/day
Spectre: 4.7 ns/day
CPU: crash
Command-line implicit
Barts: 21 ns/day
Spectre: --device-id 1 doesn't seem to work and simulation runs on Barts
CPU: --device-id 2 doesn't seem to work and simulation runs on Barts
_r2w_ben
Post by _r2w_ben »
I had some more time to experiment with FahBench. Since the benchmark ran without crashing, I figured there must be a difference between it and the work units that are failing.
Comparing Integrator.xml, I noticed the benchmark uses VerletIntegrator and p9704 uses LangevinIntegrator. I edited the benchmark explicit file to use LangevinIntegrator and it ran without issue.
Then I noticed that system, state, and integrator can be manually specified as parameters via the command-line. Not knowing if it was possible, I attempted to use the p9704 work unit files I had backed-up. The Display Driver reset within a couple seconds of the 6850 jumping up to it's max clock. Since it started doing something, could it finish if it had more time? To answer that I starting looking for a way to increase the display driver timeout. I ended up here and TdrDelay looked like what I needed. The default of 2 seconds made sense since I was seeing the reset happen very quickly. I added the registry key and set it to 10 seconds. After restarting the machine, I reran the same test with p9704 work unit. This time, the display driver did not reset and FahBench started to report progress at 0.70 ns/day! :D
Based on ns/day, the system in p9704 must be about 10x more complex than the benchmark. It appears that the amount of work in-flight requiring completion before the 6850 can context switch and respond to the Windows heartbeat exceeds the default of 2 seconds. I am going to leave the timeout at 10 seconds and report back the next time the 6850 is assigned a Core 21 work unit.
Development is aware of the TDR issue and is devising a plan to deal with it. In the meantime, your work-around of 10 seconds is a reasonable.
YGPM.
