Won't start folding [Failed to Read Stream]
blade7658
Post by blade7658 »
I am new to this and nothing is happening. I suspect it is because my computer is not reaching the server, but I don't know what to do. Any help is much appreciated!
*********************** Log Started 2015-08-30T19:42:34Z ***********************
19:42:34:************************* Folding@home Client *************************
19:42:34:      Website: http://folding.stanford.edu/
19:42:34:    Copyright: (c) 2009-2014 Stanford University
19:42:34:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:42:34:         Args:
19:42:34:       Config: C:/Users/Scott/AppData/Roaming/FAHClient/config.xml
19:42:34:******************************** Build ********************************
19:42:34:      Version: 7.4.4
19:42:34:         Date: Mar 4 2014
19:42:34:         Time: 20:26:54
19:42:34:      SVN Rev: 4130
19:42:34:       Branch: fah/trunk/client
19:42:34:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:42:34:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:42:34:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:42:34:     Platform: win32 XP
19:42:34:         Bits: 32
19:42:34:         Mode: Release
19:42:34:******************************* System ********************************
19:42:34:          CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
19:42:34:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
19:42:34:         CPUs: 8
19:42:34:       Memory: 15.94GiB
19:42:34:  Free Memory: 13.61GiB
19:42:34:      Threads: WINDOWS_THREADS
19:42:34:   OS Version: 6.2
19:42:34:  Has Battery: false
19:42:34:   On Battery: false
19:42:34:   UTC Offset: 2
19:42:34:          PID: 9764
19:42:34:          CWD: C:/Users/Scott/AppData/Roaming/FAHClient
19:42:34:           OS: Windows 10 Home
19:42:34:      OS Arch: AMD64
19:42:34:         GPUs: 1
19:42:34:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
19:42:34:         CUDA: 3.0
19:42:34:  CUDA Driver: 7050
19:42:34:Win32 Service: false
19:42:34:***********************************************************************
19:42:35:<config>
19:42:35:  <!-- Network -->
19:42:35:  <proxy v=':8080'/>
19:42:35:
19:42:35:  <!-- Folding Slots -->
19:42:35:  <slot id='0' type='CPU'/>
19:42:35:  <slot id='1' type='GPU'/>
19:42:35:</config>
19:42:35:Connecting to assign-GPU.stanford.edu:80
19:42:37:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:42:37:Connecting to assign-GPU2.stanford.edu:80
19:42:38:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:42:38:Trying to access database...
19:42:38:Successfully acquired database lock
19:42:38:Enabled folding slot 00: READY cpu:6
19:42:38:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770]
19:42:38:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:42:38:WU00:FS00:Connecting to web.stanford.edu:80
19:42:38:WU01:FS01:Connecting to 171.67.108.200:80
19:42:39:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:42:40:WU01:FS01:Connecting to 171.67.108.204:80
19:42:40:ERROR:WU00:FS00:Exception: Failed to read stream
19:42:40:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:42:40:ERROR:WU01:FS01:Exception: Could not get an assignment
19:42:40:WU01:FS01:Connecting to 171.67.108.200:80
19:42:41:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:42:41:WU01:FS01:Connecting to 171.67.108.204:80
19:42:42:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:42:42:ERROR:WU01:FS01:Exception: Could not get an assignment
19:43:38:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:43:38:WU00:FS00:Connecting to web.stanford.edu:80
19:43:39:ERROR:WU00:FS00:Exception: Failed to read stream
19:43:40:WU01:FS01:Connecting to 171.67.108.200:80
19:43:41:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:43:41:WU01:FS01:Connecting to 171.67.108.204:80
19:43:42:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:43:42:ERROR:WU01:FS01:Exception: Could not get an assignment
19:45:16:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:45:16:WU00:FS00:Connecting to web.stanford.edu:80
19:45:16:ERROR:WU00:FS00:Exception: Failed to read stream
19:45:18:WU01:FS01:Connecting to 171.67.108.200:80
19:45:18:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:45:18:WU01:FS01:Connecting to 171.67.108.204:80
19:45:19:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:45:19:ERROR:WU01:FS01:Exception: Could not get an assignment
19:47:35:Connecting to assign-GPU.stanford.edu:80
19:47:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:47:36:Connecting to assign-GPU2.stanford.edu:80
19:47:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:47:53:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:47:53:WU00:FS00:Connecting to web.stanford.edu:80
19:47:54:ERROR:WU00:FS00:Exception: Failed to read stream
19:47:55:WU01:FS01:Connecting to 171.67.108.200:80
19:47:56:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:47:56:WU01:FS01:Connecting to 171.67.108.204:80
19:47:57:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:47:57:ERROR:WU01:FS01:Exception: Could not get an assignment
19:52:07:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:52:07:WU00:FS00:Connecting to web.stanford.edu:80
19:52:08:ERROR:WU00:FS00:Exception: Failed to read stream
19:52:09:WU01:FS01:Connecting to 171.67.108.200:80
19:52:10:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:52:10:WU01:FS01:Connecting to 171.67.108.204:80
19:52:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:52:11:ERROR:WU01:FS01:Exception: Could not get an assignment
19:52:35:Connecting to assign-GPU.stanford.edu:80
19:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:52:35:Connecting to assign-GPU2.stanford.edu:80
19:52:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:57:35:Connecting to assign-GPU.stanford.edu:80
19:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:57:35:Connecting to assign-GPU2.stanford.edu:80
19:57:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:58:58:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:58:58:WU00:FS00:Connecting to web.stanford.edu:80
19:58:59:ERROR:WU00:FS00:Exception: Failed to read stream
19:59:00:WU01:FS01:Connecting to 171.67.108.200:80
19:59:01:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
19:59:01:WU01:FS01:Connecting to 171.67.108.204:80
19:59:02:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
19:59:02:ERROR:WU01:FS01:Exception: Could not get an assignment
20:02:35:Connecting to assign-GPU.stanford.edu:80
20:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:02:35:Connecting to assign-GPU2.stanford.edu:80
20:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:07:35:Connecting to assign-GPU.stanford.edu:80
20:07:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:07:36:Connecting to assign-GPU2.stanford.edu:80
20:07:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:10:04:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:10:04:WU00:FS00:Connecting to web.stanford.edu:80
20:10:04:ERROR:WU00:FS00:Exception: Failed to read stream
20:10:06:WU01:FS01:Connecting to 171.67.108.200:80
20:10:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
20:10:06:WU01:FS01:Connecting to 171.67.108.204:80
20:10:07:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
20:10:07:ERROR:WU01:FS01:Exception: Could not get an assignment
20:12:35:Connecting to assign-GPU.stanford.edu:80
20:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:12:35:Connecting to assign-GPU2.stanford.edu:80
20:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:17:35:Connecting to assign-GPU.stanford.edu:80
20:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:17:35:Connecting to assign-GPU2.stanford.edu:80
20:17:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:22:35:Connecting to assign-GPU.stanford.edu:80
20:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:22:35:Connecting to assign-GPU2.stanford.edu:80
20:22:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:27:35:Connecting to assign-GPU.stanford.edu:80
20:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:27:35:Connecting to assign-GPU2.stanford.edu:80
20:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:28:01:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:28:01:WU00:FS00:Connecting to web.stanford.edu:80
20:28:02:ERROR:WU00:FS00:Exception: Failed to read stream
20:28:03:WU01:FS01:Connecting to 171.67.108.200:80
20:28:03:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
20:28:03:WU01:FS01:Connecting to 171.67.108.204:80
20:28:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
20:28:04:ERROR:WU01:FS01:Exception: Could not get an assignment
20:32:35:Connecting to assign-GPU.stanford.edu:80
20:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:32:36:Connecting to assign-GPU2.stanford.edu:80
20:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:37:35:Connecting to assign-GPU.stanford.edu:80
20:37:37:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:37:37:Connecting to assign-GPU2.stanford.edu:80
20:37:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:42:35:Connecting to assign-GPU.stanford.edu:80
20:42:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:42:36:Connecting to assign-GPU2.stanford.edu:80
20:42:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:47:35:Connecting to assign-GPU.stanford.edu:80
20:47:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:47:36:Connecting to assign-GPU2.stanford.edu:80
20:47:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:52:35:Connecting to assign-GPU.stanford.edu:80
20:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:52:35:Connecting to assign-GPU2.stanford.edu:80
20:52:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:57:03:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:57:03:WU00:FS00:Connecting to web.stanford.edu:80
20:57:03:ERROR:WU00:FS00:Exception: Failed to read stream
20:57:05:WU01:FS01:Connecting to 171.67.108.200:80
20:57:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
20:57:05:WU01:FS01:Connecting to 171.67.108.204:80
20:57:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
20:57:06:ERROR:WU01:FS01:Exception: Could not get an assignment
20:57:35:Connecting to assign-GPU.stanford.edu:80
20:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:57:35:Connecting to assign-GPU2.stanford.edu:80
20:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:02:35:Connecting to assign-GPU.stanford.edu:80
21:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:02:35:Connecting to assign-GPU2.stanford.edu:80
21:02:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:07:35:Connecting to assign-GPU.stanford.edu:80
21:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:07:35:Connecting to assign-GPU2.stanford.edu:80
21:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:12:35:Connecting to assign-GPU.stanford.edu:80
21:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:12:35:Connecting to assign-GPU2.stanford.edu:80
21:12:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:17:35:Connecting to assign-GPU.stanford.edu:80
21:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:17:35:Connecting to assign-GPU2.stanford.edu:80
21:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:22:35:Connecting to assign-GPU.stanford.edu:80
21:22:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:22:36:Connecting to assign-GPU2.stanford.edu:80
21:22:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:27:35:Connecting to assign-GPU.stanford.edu:80
21:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:27:35:Connecting to assign-GPU2.stanford.edu:80
21:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:32:35:Connecting to assign-GPU.stanford.edu:80
21:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:32:35:Connecting to assign-GPU2.stanford.edu:80
21:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:37:35:Connecting to assign-GPU.stanford.edu:80
21:37:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:37:36:Connecting to assign-GPU2.stanford.edu:80
21:37:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:42:35:Connecting to assign-GPU.stanford.edu:80
21:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:42:35:Connecting to assign-GPU2.stanford.edu:80
21:42:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:44:02:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
21:44:02:WU00:FS00:Connecting to web.stanford.edu:80
21:44:03:ERROR:WU00:FS00:Exception: Failed to read stream
21:44:03:WU01:FS01:Connecting to 171.67.108.200:80
21:44:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
21:44:04:WU01:FS01:Connecting to 171.67.108.204:80
21:44:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
21:44:05:ERROR:WU01:FS01:Exception: Could not get an assignment
21:47:35:Connecting to assign-GPU.stanford.edu:80
21:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:47:35:Connecting to assign-GPU2.stanford.edu:80
21:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:52:35:Connecting to assign-GPU.stanford.edu:80
21:52:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:52:36:Connecting to assign-GPU2.stanford.edu:80
21:52:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:57:35:Connecting to assign-GPU.stanford.edu:80
21:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:57:35:Connecting to assign-GPU2.stanford.edu:80
21:57:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:02:35:Connecting to assign-GPU.stanford.edu:80
22:02:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:02:36:Connecting to assign-GPU2.stanford.edu:80
22:02:38:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:07:35:Connecting to assign-GPU.stanford.edu:80
22:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:07:35:Connecting to assign-GPU2.stanford.edu:80
22:07:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:12:35:Connecting to assign-GPU.stanford.edu:80
22:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:12:35:Connecting to assign-GPU2.stanford.edu:80
22:12:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:17:35:Connecting to assign-GPU.stanford.edu:80
22:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:17:35:Connecting to assign-GPU2.stanford.edu:80
22:17:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:22:35:Connecting to assign-GPU.stanford.edu:80
22:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:22:35:Connecting to assign-GPU2.stanford.edu:80
22:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:27:35:Connecting to assign-GPU.stanford.edu:80
22:27:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:27:36:Connecting to assign-GPU2.stanford.edu:80
22:27:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:32:35:Connecting to assign-GPU.stanford.edu:80
22:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:32:35:Connecting to assign-GPU2.stanford.edu:80
22:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:37:35:Connecting to assign-GPU.stanford.edu:80
22:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:37:35:Connecting to assign-GPU2.stanford.edu:80
22:37:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:42:35:Connecting to assign-GPU.stanford.edu:80
22:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:42:35:Connecting to assign-GPU2.stanford.edu:80
22:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:47:35:Connecting to assign-GPU.stanford.edu:80
22:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:47:35:Connecting to assign-GPU2.stanford.edu:80
22:47:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:52:35:Connecting to assign-GPU.stanford.edu:80
22:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:52:35:Connecting to assign-GPU2.stanford.edu:80
22:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
22:57:35:Connecting to assign-GPU.stanford.edu:80
22:57:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
22:57:36:Connecting to assign-GPU2.stanford.edu:80
22:57:37:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:00:03:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
23:00:03:WU00:FS00:Connecting to web.stanford.edu:80
23:00:04:ERROR:WU00:FS00:Exception: Failed to read stream
23:00:04:WU01:FS01:Connecting to 171.67.108.200:80
23:00:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
23:00:05:WU01:FS01:Connecting to 171.67.108.204:80
23:00:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
23:00:06:ERROR:WU01:FS01:Exception: Could not get an assignment
23:02:35:Connecting to assign-GPU.stanford.edu:80
23:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:02:35:Connecting to assign-GPU2.stanford.edu:80
23:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:07:35:Connecting to assign-GPU.stanford.edu:80
23:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:07:35:Connecting to assign-GPU2.stanford.edu:80
23:07:38:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:12:35:Connecting to assign-GPU.stanford.edu:80
23:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:12:35:Connecting to assign-GPU2.stanford.edu:80
23:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:17:35:Connecting to assign-GPU.stanford.edu:80
23:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:17:35:Connecting to assign-GPU2.stanford.edu:80
23:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:22:35:Connecting to assign-GPU.stanford.edu:80
23:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:22:35:Connecting to assign-GPU2.stanford.edu:80
23:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:27:35:Connecting to assign-GPU.stanford.edu:80
23:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:27:35:Connecting to assign-GPU2.stanford.edu:80
23:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:32:35:Connecting to assign-GPU.stanford.edu:80
23:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:32:36:Connecting to assign-GPU2.stanford.edu:80
23:32:38:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:37:35:Connecting to assign-GPU.stanford.edu:80
23:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:37:35:Connecting to assign-GPU2.stanford.edu:80
23:37:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:42:35:Connecting to assign-GPU.stanford.edu:80
23:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:42:35:Connecting to assign-GPU2.stanford.edu:80
23:42:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:47:35:Connecting to assign-GPU.stanford.edu:80
23:47:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:47:36:Connecting to assign-GPU2.stanford.edu:80
23:47:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:52:35:Connecting to assign-GPU.stanford.edu:80
23:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:52:35:Connecting to assign-GPU2.stanford.edu:80
23:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
23:57:35:Connecting to assign-GPU.stanford.edu:80
23:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
23:57:35:Connecting to assign-GPU2.stanford.edu:80
23:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:02:35:Connecting to assign-GPU.stanford.edu:80
00:02:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:02:36:Connecting to assign-GPU2.stanford.edu:80
00:02:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:07:35:Connecting to assign-GPU.stanford.edu:80
00:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:07:35:Connecting to assign-GPU2.stanford.edu:80
00:07:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:12:35:Connecting to assign-GPU.stanford.edu:80
00:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:12:35:Connecting to assign-GPU2.stanford.edu:80
00:12:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:17:35:Connecting to assign-GPU.stanford.edu:80
00:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:17:35:Connecting to assign-GPU2.stanford.edu:80
00:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:22:35:Connecting to assign-GPU.stanford.edu:80
00:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:22:35:Connecting to assign-GPU2.stanford.edu:80
00:22:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:27:35:Connecting to assign-GPU.stanford.edu:80
00:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:27:35:Connecting to assign-GPU2.stanford.edu:80
00:27:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:32:35:Connecting to assign-GPU.stanford.edu:80
00:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:32:36:Connecting to assign-GPU2.stanford.edu:80
00:32:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:37:35:Connecting to assign-GPU.stanford.edu:80
00:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:37:35:Connecting to assign-GPU2.stanford.edu:80
00:37:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:42:35:Connecting to assign-GPU.stanford.edu:80
00:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:42:35:Connecting to assign-GPU2.stanford.edu:80
00:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:47:35:Connecting to assign-GPU.stanford.edu:80
00:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:47:35:Connecting to assign-GPU2.stanford.edu:80
00:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:52:35:Connecting to assign-GPU.stanford.edu:80
00:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:52:35:Connecting to assign-GPU2.stanford.edu:80
00:52:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
00:57:35:Connecting to assign-GPU.stanford.edu:80
00:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
00:57:35:Connecting to assign-GPU2.stanford.edu:80
00:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:02:35:Connecting to assign-GPU.stanford.edu:80
01:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:02:35:Connecting to assign-GPU2.stanford.edu:80
01:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:03:02:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
01:03:02:WU00:FS00:Connecting to web.stanford.edu:80
01:03:03:ERROR:WU00:FS00:Exception: Failed to read stream
01:03:04:WU01:FS01:Connecting to 171.67.108.200:80
01:03:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
01:03:05:WU01:FS01:Connecting to 171.67.108.204:80
01:03:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
01:03:05:ERROR:WU01:FS01:Exception: Could not get an assignment
01:07:35:Connecting to assign-GPU.stanford.edu:80
01:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:07:35:Connecting to assign-GPU2.stanford.edu:80
01:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:12:35:Connecting to assign-GPU.stanford.edu:80
01:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:12:35:Connecting to assign-GPU2.stanford.edu:80
01:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:17:35:Connecting to assign-GPU.stanford.edu:80
01:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:17:35:Connecting to assign-GPU2.stanford.edu:80
01:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:22:35:Connecting to assign-GPU.stanford.edu:80
01:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:22:35:Connecting to assign-GPU2.stanford.edu:80
01:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:27:35:Connecting to assign-GPU.stanford.edu:80
01:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:27:35:Connecting to assign-GPU2.stanford.edu:80
01:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:32:35:Connecting to assign-GPU.stanford.edu:80
01:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:32:35:Connecting to assign-GPU2.stanford.edu:80
01:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:37:35:Connecting to assign-GPU.stanford.edu:80
01:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:37:35:Connecting to assign-GPU2.stanford.edu:80
01:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
******************************* Date: 2015-08-31 *******************************
01:42:35:Connecting to assign-GPU.stanford.edu:80
01:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:42:35:Connecting to assign-GPU2.stanford.edu:80
01:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:47:35:Connecting to assign-GPU.stanford.edu:80
01:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:47:35:Connecting to assign-GPU2.stanford.edu:80
01:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:52:35:Connecting to assign-GPU.stanford.edu:80
01:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:52:35:Connecting to assign-GPU2.stanford.edu:80
01:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
01:57:35:Connecting to assign-GPU.stanford.edu:80
01:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
01:57:35:Connecting to assign-GPU2.stanford.edu:80
01:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:02:35:Connecting to assign-GPU.stanford.edu:80
02:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:02:35:Connecting to assign-GPU2.stanford.edu:80
02:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:07:35:Connecting to assign-GPU.stanford.edu:80
02:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:07:35:Connecting to assign-GPU2.stanford.edu:80
02:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:12:35:Connecting to assign-GPU.stanford.edu:80
02:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:12:35:Connecting to assign-GPU2.stanford.edu:80
02:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:17:35:Connecting to assign-GPU.stanford.edu:80
02:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:17:35:Connecting to assign-GPU2.stanford.edu:80
02:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:22:35:Connecting to assign-GPU.stanford.edu:80
02:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:22:35:Connecting to assign-GPU2.stanford.edu:80
02:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:27:35:Connecting to assign-GPU.stanford.edu:80
02:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:27:35:Connecting to assign-GPU2.stanford.edu:80
02:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:32:35:Connecting to assign-GPU.stanford.edu:80
02:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:32:35:Connecting to assign-GPU2.stanford.edu:80
02:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:37:35:Connecting to assign-GPU.stanford.edu:80
02:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:37:35:Connecting to assign-GPU2.stanford.edu:80
02:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:42:35:Connecting to assign-GPU.stanford.edu:80
02:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:42:35:Connecting to assign-GPU2.stanford.edu:80
02:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:47:35:Connecting to assign-GPU.stanford.edu:80
02:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:47:35:Connecting to assign-GPU2.stanford.edu:80
02:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:52:35:Connecting to assign-GPU.stanford.edu:80
02:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:52:35:Connecting to assign-GPU2.stanford.edu:80
02:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
02:57:35:Connecting to assign-GPU.stanford.edu:80
02:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
02:57:35:Connecting to assign-GPU2.stanford.edu:80
02:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:02:35:Connecting to assign-GPU.stanford.edu:80
03:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:02:35:Connecting to assign-GPU2.stanford.edu:80
03:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:07:35:Connecting to assign-GPU.stanford.edu:80
03:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:07:35:Connecting to assign-GPU2.stanford.edu:80
03:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:12:35:Connecting to assign-GPU.stanford.edu:80
03:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:12:35:Connecting to assign-GPU2.stanford.edu:80
03:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:17:35:Connecting to assign-GPU.stanford.edu:80
03:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:17:35:Connecting to assign-GPU2.stanford.edu:80
03:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:22:35:Connecting to assign-GPU.stanford.edu:80
03:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:22:35:Connecting to assign-GPU2.stanford.edu:80
03:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:27:35:Connecting to assign-GPU.stanford.edu:80
03:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:27:35:Connecting to assign-GPU2.stanford.edu:80
03:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:32:35:Connecting to assign-GPU.stanford.edu:80
03:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:32:35:Connecting to assign-GPU2.stanford.edu:80
03:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:37:35:Connecting to assign-GPU.stanford.edu:80
03:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:37:35:Connecting to assign-GPU2.stanford.edu:80
03:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:42:35:Connecting to assign-GPU.stanford.edu:80
03:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:42:35:Connecting to assign-GPU2.stanford.edu:80
03:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:47:35:Connecting to assign-GPU.stanford.edu:80
03:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:47:35:Connecting to assign-GPU2.stanford.edu:80
03:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:52:35:Connecting to assign-GPU.stanford.edu:80
03:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:52:35:Connecting to assign-GPU2.stanford.edu:80
03:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
03:57:35:Connecting to assign-GPU.stanford.edu:80
03:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
03:57:35:Connecting to assign-GPU2.stanford.edu:80
03:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:02:35:Connecting to assign-GPU.stanford.edu:80
04:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:02:35:Connecting to assign-GPU2.stanford.edu:80
04:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:07:35:Connecting to assign-GPU.stanford.edu:80
04:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:07:35:Connecting to assign-GPU2.stanford.edu:80
04:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:12:35:Connecting to assign-GPU.stanford.edu:80
04:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:12:35:Connecting to assign-GPU2.stanford.edu:80
04:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:17:35:Connecting to assign-GPU.stanford.edu:80
04:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:17:35:Connecting to assign-GPU2.stanford.edu:80
04:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:22:03:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
04:22:03:WU00:FS00:Connecting to web.stanford.edu:80
04:22:03:ERROR:WU00:FS00:Exception: Failed to read stream
04:22:05:WU01:FS01:Connecting to 171.67.108.200:80
04:22:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
04:22:05:WU01:FS01:Connecting to 171.67.108.204:80
04:22:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
04:22:05:ERROR:WU01:FS01:Exception: Could not get an assignment
04:22:35:Connecting to assign-GPU.stanford.edu:80
04:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:22:35:Connecting to assign-GPU2.stanford.edu:80
04:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:27:35:Connecting to assign-GPU.stanford.edu:80
04:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:27:35:Connecting to assign-GPU2.stanford.edu:80
04:27:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:32:35:Connecting to assign-GPU.stanford.edu:80
04:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:32:35:Connecting to assign-GPU2.stanford.edu:80
04:32:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:37:35:Connecting to assign-GPU.stanford.edu:80
04:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:37:35:Connecting to assign-GPU2.stanford.edu:80
04:37:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:42:35:Connecting to assign-GPU.stanford.edu:80
04:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:42:35:Connecting to assign-GPU2.stanford.edu:80
04:42:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:47:35:Connecting to assign-GPU.stanford.edu:80
04:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:47:35:Connecting to assign-GPU2.stanford.edu:80
04:47:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:52:35:Connecting to assign-GPU.stanford.edu:80
04:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:52:35:Connecting to assign-GPU2.stanford.edu:80
04:52:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
04:57:35:Connecting to assign-GPU.stanford.edu:80
04:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
04:57:35:Connecting to assign-GPU2.stanford.edu:80
04:57:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
05:02:35:Connecting to assign-GPU.stanford.edu:80
05:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
05:02:35:Connecting to assign-GPU2.stanford.edu:80
05:02:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
05:07:35:Connecting to assign-GPU.stanford.edu:80
05:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
05:07:35:Connecting to assign-GPU2.stanford.edu:80
05:07:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
05:12:35:Connecting to assign-GPU.stanford.edu:80
05:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
05:12:35:Connecting to assign-GPU2.stanford.edu:80
05:12:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
05:17:35:Connecting to assign-GPU.stanford.edu:80
05:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
05:17:35:Connecting to assign-GPU2.stanford.edu:80
05:17:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
05:22:35:Connecting to assign-GPU.stanford.edu:80
05:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
05:22:35:Connecting to assign-GPU2.stanford.edu:80
05:22:35:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
Re: Won't start folding
Generally, messages such as "Failed to read stream" and "Received short response, expected 272 bytes, got 0" point to the folding client being blocked by either a firewall or anti-malware software. The FAHClient process needs to have the same access as a browser, HTTP, over ports 80 and/or 8080 to send and receive data.
You can test this out by temporarily disabling such software. If you can then download the various data and work files, that is where the problem exists and you would need to adjust the rules to allow access.
In addition you may have to exclude the FAHClient data directory from anti-malware scans. The binary data and executable files sometimes can trigger false positives for malware.
It's the 0 bytes GPUs.txt download bug ... it's back, and unfortunately I don't know where to get it manually ...
davidcoton
Post by davidcoton »
No, in this case it's a more general failure to receive packets from Stanford -- it affected a core download as well. Follow Joe's advice.
You may have 0 bytes GPU.txt as well -- see here for that.
blade7658
Post by blade7658 »
Joe_H wrote:Welcome to the folding support forum.
I use only Windows Defender. I added an exclusion folder and process exclusion with no change. I then disabled Windows Defender totally - no change. I have no other firewall or anti-malware software that I am aware of (new to Windows 10 though, so don't know what they have built in). I wonder about my router (suspect it must have a firewall) but I only know how to do basic stuff in my router. Interestingly, I can get to https://folding.stanford.edu/ but when I tried to go to http://folding.stanford.edu/home it tells me that it can't reach that page. I went into my router and found that my static DNS had changed (probably when I was looking around at things trying to figure this out before I asked for help). Changed it back to the static DNS required for my Unblock-Us.com account and now I can go to the FAH home page, but I still can't get to the work server 155.247.166.220 or collection server 155.247.166.219 - when I clicked the link in FAHControl I got a "can't reach this page". Off to see if I can create a change in my router that lets it through. I won't be making any huge changes, I promise!
Power cycle the router.
Another possibility: I've seen a report of a problem with the security certificate on one or more of Stanford's server. (It has already been reported to Stanford.) If Windows Defender blocks the site without telling you about the problem, that could be what's happening.
I expect it won't take them long to fix it, but in the meantime, post a fresh copy of your log and let us know what happens if you open:
https://assign2.stanford.edu/
blade7658
Post by blade7658 »
bruce wrote:Another possibility: I've seen a report of a problem with the security certificate on one or more of Stanford's server. (It has already been reported to Stanford.) If Windows Defender blocks the site without telling you about the problem, that could be what's happening.
I tried the power solution, no luck.
The assign2.Stanford.edu website said their was a certificate error but when I clicked on the "continue this anyway" I got a picture of a protein and "Assignment Server version 3.5.7"
*********************** Log Started 2015-08-31T17:18:30Z ***********************
17:18:30:************************* Folding@home Client *************************
17:18:30:      Website: http://folding.stanford.edu/
17:18:30:    Copyright: (c) 2009-2014 Stanford University
17:18:30:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:18:30:         Args: --open-web-control
17:18:30:       Config: C:/Users/Scott/AppData/Roaming/FAHClient/config.xml
17:18:30:******************************** Build ********************************
17:18:30:      Version: 7.4.4
17:18:30:         Date: Mar 4 2014
17:18:30:         Time: 20:26:54
17:18:30:      SVN Rev: 4130
17:18:30:       Branch: fah/trunk/client
17:18:30:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:18:30:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:18:30:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:18:30:     Platform: win32 XP
17:18:30:         Bits: 32
17:18:30:         Mode: Release
17:18:30:******************************* System ********************************
17:18:30:          CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
17:18:30:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
17:18:30:         CPUs: 8
17:18:30:       Memory: 15.94GiB
17:18:30:  Free Memory: 12.46GiB
17:18:30:      Threads: WINDOWS_THREADS
17:18:30:   OS Version: 6.2
17:18:30:  Has Battery: false
17:18:30:   On Battery: false
17:18:30:   UTC Offset: 2
17:18:30:          PID: 1536
17:18:30:          CWD: C:/Users/Scott/AppData/Roaming/FAHClient
17:18:30:           OS: Windows 10 Home
17:18:30:      OS Arch: AMD64
17:18:30:         GPUs: 1
17:18:30:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
17:18:30:         CUDA: 3.0
17:18:30:  CUDA Driver: 7050
17:18:30:Win32 Service: false
17:18:30:***********************************************************************
17:18:30:<config>
17:18:30:  <!-- Network -->
17:18:30:  <proxy v=':8080'/>
17:18:30:
17:18:30:  <!-- Folding Slots -->
17:18:30:  <slot id='0' type='CPU'/>
17:18:30:  <slot id='1' type='GPU'/>
17:18:30:</config>
17:18:30:Connecting to assign-GPU.stanford.edu:80
17:18:33:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:18:33:Connecting to assign-GPU2.stanford.edu:80
17:18:36:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:18:36:Trying to access database...
17:18:36:Successfully acquired database lock
17:18:36:Enabled folding slot 00: READY cpu:6
17:18:36:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770]
17:18:36:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:18:36:WU00:FS00:Connecting to web.stanford.edu:80
17:18:36:WU01:FS01:Connecting to 171.67.108.200:80
17:18:39:ERROR:WU00:FS00:Exception: Failed to read stream
17:18:40:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:18:40:WU01:FS01:Connecting to 171.67.108.204:80
17:18:41:16:127.0.0.1:New Web connection
17:18:43:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:18:43:ERROR:WU01:FS01:Exception: Could not get an assignment
17:18:43:WU01:FS01:Connecting to 171.67.108.200:80
17:18:46:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:18:46:WU01:FS01:Connecting to 171.67.108.204:80
17:18:49:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:18:49:ERROR:WU01:FS01:Exception: Could not get an assignment
blade7658 wrote:The assign2.Stanford.edu website said their was a certificate error but when I clicked on the "continue this anyway" I got a picture of a protein and "Assignment Server version 3.5.7"
That's what your browser SHOULD get. Unfortunately FAHClient doesn't give you the option to "continue anyway"
Have you tried storing the exception? (That may not fix the problem but maybe we can confirm that was the initial problem.) Stanford does need to straighten out their security certificates.
Unfortunately, I think the problem is bigger than that. I can get to the Assignment Server but it redirects me to a Work Server and then the download hangs. (Windows 8.1)
17:09:46:WU01:FS02:Connecting to 171.67.108.200:80
17:09:46:WU01:FS02:Assigned to work server 171.64.65.61
17:09:46:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:GK107 [GeForce GT 740] from 171.64.65.61
17:09:46:WU01:FS02:Connecting to 171.64.65.61:8080
17:09:47:WU01:FS02:Downloading 2.69MiB
then nothing more from FS02
17:14:23:WU00:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
17:19:07:WU00:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
17:24:04:WU00:FS00:0xa4:Completed 75000 out of 2500000 steps  (3%)
17:29:07:WU00:FS00:0xa4:Completed 100000 out of 2500000 steps  (4%)
blade7658
Post by blade7658 »
I don't see where on Windows Defender you can except any particular websites. I did turn off Windows Defender and it went straight to that page, but I don't think it is helping. Below is my log right after I turned off Defender.
Appreciate all the help from everybody!
*********************** Log Started 2015-08-31T18:17:54Z ***********************
18:17:54:************************* Folding@home Client *************************
18:17:54:      Website: http://folding.stanford.edu/
18:17:54:    Copyright: (c) 2009-2014 Stanford University
18:17:54:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:17:54:         Args: --open-web-control
18:17:54:       Config: C:/Users/Scott/AppData/Roaming/FAHClient/config.xml
18:17:54:******************************** Build ********************************
18:17:54:      Version: 7.4.4
18:17:54:         Date: Mar 4 2014
18:17:54:         Time: 20:26:54
18:17:54:      SVN Rev: 4130
18:17:54:       Branch: fah/trunk/client
18:17:54:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:17:54:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:17:54:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:17:54:     Platform: win32 XP
18:17:54:         Bits: 32
18:17:54:         Mode: Release
18:17:54:******************************* System ********************************
18:17:54:          CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:17:54:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:17:54:         CPUs: 8
18:17:54:       Memory: 15.94GiB
18:17:54:  Free Memory: 12.00GiB
18:17:54:      Threads: WINDOWS_THREADS
18:17:54:   OS Version: 6.2
18:17:54:  Has Battery: false
18:17:54:   On Battery: false
18:17:54:   UTC Offset: 2
18:17:54:          PID: 5128
18:17:54:          CWD: C:/Users/Scott/AppData/Roaming/FAHClient
18:17:54:           OS: Windows 10 Home
18:17:54:      OS Arch: AMD64
18:17:54:         GPUs: 1
18:17:54:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
18:17:54:         CUDA: 3.0
18:17:54:  CUDA Driver: 7050
18:17:54:Win32 Service: false
18:17:54:***********************************************************************
18:17:54:<config>
18:17:54:  <!-- Network -->
18:17:54:  <proxy v=':8080'/>
18:17:54:
18:17:54:  <!-- Folding Slots -->
18:17:54:  <slot id='0' type='CPU'/>
18:17:54:  <slot id='1' type='GPU'/>
18:17:54:</config>
18:17:54:Connecting to assign-GPU.stanford.edu:80
18:17:57:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:17:57:Connecting to assign-GPU2.stanford.edu:80
18:18:00:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:18:00:Trying to access database...
18:18:00:Successfully acquired database lock
18:18:00:Enabled folding slot 00: READY cpu:6
18:18:00:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770]
18:18:00:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
18:18:00:WU00:FS00:Connecting to web.stanford.edu:80
18:18:00:WU01:FS01:Connecting to 171.67.108.200:80
18:18:03:ERROR:WU00:FS00:Exception: Failed to read stream
18:18:03:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
18:18:03:WU01:FS01:Connecting to 171.67.108.204:80
18:18:04:11:127.0.0.1:New Web connection
18:18:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
18:18:06:ERROR:WU01:FS01:Exception: Could not get an assignment
18:18:07:WU01:FS01:Connecting to 171.67.108.200:80
18:18:10:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
18:18:10:WU01:FS01:Connecting to 171.67.108.204:80
18:18:13:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
18:18:13:ERROR:WU01:FS01:Exception: Could not get an assignment
No, the browser blocks bad certs also. PG needs to fix this, and then setup a reminder to renew as this seems to happen every summer.
blade7658
Post by blade7658 »
Anybody have thoughts on how I can configure my router to let me get to the websites? I am still not folding.
blade7658
Post by blade7658 »
Mod - Merged with original topic
I tried getting an answer on the newcomers forum, but no luck. I suspect the same people hang out here, so I doubt I will solve my problem but figured I would ask just in case (no offense meant to anybody who tried to help me before). I installed the software without issue, it seems to be running well, but I get the "failed to read stream" error and it won't start folding. I can get to the public F@H pages, when I click the Project in the Client Advance Control, I see a webpage explaining the project, but when I click two server links I get an error saying the browser can't find that page. I think it is a router issue, but not smart enough to fix it. Any help is much appreciated.
*********************** Log Started 2015-09-03T17:09:52Z ***********************
17:09:52:************************* Folding@home Client *************************
17:09:52:      Website: http://folding.stanford.edu/
17:09:52:    Copyright: (c) 2009-2014 Stanford University
17:09:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:09:52:         Args:
17:09:52:       Config: C:/Users/Scott/AppData/Roaming/FAHClient/config.xml
17:09:52:******************************** Build ********************************
17:09:52:      Version: 7.4.4
17:09:52:         Date: Mar 4 2014
17:09:52:         Time: 20:26:54
17:09:52:      SVN Rev: 4130
17:09:52:       Branch: fah/trunk/client
17:09:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:09:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:09:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:09:52:     Platform: win32 XP
17:09:52:         Bits: 32
17:09:52:         Mode: Release
17:09:52:******************************* System ********************************
17:09:52:          CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
17:09:52:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
17:09:52:         CPUs: 8
17:09:52:       Memory: 15.94GiB
17:09:52:  Free Memory: 13.26GiB
17:09:52:      Threads: WINDOWS_THREADS
17:09:52:   OS Version: 6.2
17:09:52:  Has Battery: false
17:09:52:   On Battery: false
17:09:52:   UTC Offset: 2
17:09:52:          PID: 9460
17:09:52:          CWD: C:/Users/Scott/AppData/Roaming/FAHClient
17:09:52:           OS: Windows 10 Home
17:09:52:      OS Arch: AMD64
17:09:52:         GPUs: 1
17:09:52:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
17:09:52:         CUDA: 3.0
17:09:52:  CUDA Driver: 7050
17:09:52:Win32 Service: false
17:09:52:***********************************************************************
17:09:52:<config>
17:09:52:  <!-- Network -->
17:09:52:  <proxy v=':8080'/>
17:09:52:
17:09:52:  <!-- User Information -->
17:09:52:  <passkey v='********************************'/>
17:09:52:  <team v='229312'/>
17:09:52:  <user v='Blade7658'/>
17:09:52:
17:09:52:  <!-- Folding Slots -->
17:09:52:  <slot id='0' type='CPU'/>
17:09:52:  <slot id='1' type='GPU'/>
17:09:52:</config>
17:09:52:Connecting to assign-GPU.stanford.edu:80
17:09:56:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:09:56:Connecting to assign-GPU2.stanford.edu:80
17:09:59:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:09:59:Trying to access database...
17:09:59:Successfully acquired database lock
17:09:59:Enabled folding slot 00: READY cpu:6
17:09:59:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770]
17:09:59:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:09:59:WU00:FS00:Connecting to web.stanford.edu:80
17:10:00:WU01:FS01:Connecting to 171.67.108.200:80
17:10:03:ERROR:WU00:FS00:Exception: Failed to read stream
17:10:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:10:04:WU01:FS01:Connecting to 171.67.108.204:80
17:10:07:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:10:07:ERROR:WU01:FS01:Exception: Could not get an assignment
17:10:07:WU01:FS01:Connecting to 171.67.108.200:80
17:10:10:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:10:10:WU01:FS01:Connecting to 171.67.108.204:80
17:10:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: No connection could be made because the target machine actively refused it.
17:10:11:ERROR:WU01:FS01:Exception: Could not get an assignment
17:11:00:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:11:00:WU00:FS00:Connecting to web.stanford.edu:80
17:11:03:ERROR:WU00:FS00:Exception: Failed to read stream
17:11:07:WU01:FS01:Connecting to 171.67.108.200:80
17:11:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:11:11:WU01:FS01:Connecting to 171.67.108.204:80
17:11:14:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:11:14:ERROR:WU01:FS01:Exception: Could not get an assignment
17:12:37:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:12:37:WU00:FS00:Connecting to web.stanford.edu:80
17:12:40:ERROR:WU00:FS00:Exception: Failed to read stream
17:12:45:WU01:FS01:Connecting to 171.67.108.200:80
17:12:48:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:12:48:WU01:FS01:Connecting to 171.67.108.204:80
17:12:51:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:12:51:ERROR:WU01:FS01:Exception: Could not get an assignment
17:14:52:Connecting to assign-GPU.stanford.edu:80
17:14:55:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:14:55:Connecting to assign-GPU2.stanford.edu:80
17:14:58:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:15:14:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:15:14:WU00:FS00:Connecting to web.stanford.edu:80
17:15:17:ERROR:WU00:FS00:Exception: Failed to read stream
17:15:22:WU01:FS01:Connecting to 171.67.108.200:80
17:15:25:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:15:25:WU01:FS01:Connecting to 171.67.108.204:80
17:15:28:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:15:28:ERROR:WU01:FS01:Exception: Could not get an assignment
17:19:28:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:19:28:WU00:FS00:Connecting to web.stanford.edu:80
17:19:31:ERROR:WU00:FS00:Exception: Failed to read stream
17:19:36:WU01:FS01:Connecting to 171.67.108.200:80
17:19:39:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': 10002: Received short response, expected 272 bytes, got 0
17:19:39:WU01:FS01:Connecting to 171.67.108.204:80
17:19:42:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10002: Received short response, expected 272 bytes, got 0
17:19:42:ERROR:WU01:FS01:Exception: Could not get an assignment
17:19:52:Connecting to assign-GPU.stanford.edu:80
17:19:55:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:19:55:Connecting to assign-GPU2.stanford.edu:80
17:19:58:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
Re: Won't start folding [Failed to Read Stream]
Please describe your network set up in detail. Include the type of router and how the PC is connected to the router. Also what kind of Internet service provider.
Then describe what the Unblockus account does. That sounds a lot like a DNS based blacklist, that could easily cause the failed to read stream error. I get the same failed to read stream error at work inside our test lab firewalled sandbox, as one would expect.
blade7658
Post by blade7658 »
Thanks 7im!
My router is a Sitecom X4 N300 using Telecom Italia DSL internet (12 Mbps download speed, 1 Mbps upload speed). The PC is typically connected to router via wireless connection and Speedtest.net tells me I get 11.0-11.5 Mbps speed with that. I currently connected a Cat 5 cable and I get 11.6 Mbps and no change in symptoms. The wireless uses WPA2 for security and the router has a static DNS. The static DNS is to push things through unblock-us.com, which selectively changes your IP address for a small set of websites (like Netflix), but for the vast majority of sites it doesn't change anything (if I go to findmyipaddress.com, it lists an Italian IP address). Thinking that might be the problem, I changed my static DNS to 8.8.8.8 and 8.8.4.4. (Google's DNS) but no change. Likewise, disabled my static DNS, but no luck there either. I am willing to try just about anything, so any advice is welcome.
Thanks!
