Host Boodles, operated by DMMD, me, had a plethora of failed GPU FAH WU as a result of issues of this host secondary to Win 10 ~upgrade. Issues are now resolved. If FAH servers are blocking this host from receiving GPU tasks, will you please unblock so I may continue to contribute with this host.
Thanks
DMMD
Blocked?
Re: Blocked?
It is rare for a system to be blocked, more common is that the folding client will suspend trying to get WU's after a number of successive errors. Restarting the client or the system it is on usually is enough to reset that.
If that does not result is getting work, there may be an issue with your client setup. If you could post the first 100 or so lines of the log file using the directions in the Welcome posts - viewtopic.php?f=61&t=26036, that would be helpful in identifying the problem. Include enough to show an unsuccessful download attempt.
