I spent quite a bit of time trying to figure out my lowest stable voltage before adjusting the clock speed. I found I could reduce it from 1.131V to 1.000V at 1ghz, pretty decent power savings with equal performance in my mind. furmark ran for a long time on that.
I attempted to start folding with the settings, but voltage jumps right back up to 1.131. so I launched a game and voltage dropped right to 1.000V. I set the profiles in afterburner to be undervolted for 2d and 3d applications. still no go. just to see if maybe the card would only do 1.131v at 1ghz, i overclocked 1.5v and 1.05ghz and and the clocks held through when i started folding.
So why would folding at home be the only application i have found to not undervolt/underclock, but will overvolt/overclock?
If anyone uses a gpu overclock utility that allows for this, I would be excited to hear about it.
I don't know if this is a driver issue, I will move this if it is in the wrong place, just point me in the right direction please.
Hardware:
windows 10 pro 64bit
his iceq x^2 boost clock 280x
i7 4771
asus z87-pro
if you need to know more, just ask.
Unable to undervolt or underclock a 280x with windows 10
Re: Unable to undervolt or underclock a 280x with windows 10
You may find better answers on a hardware support forum that covers under and overclocking of GPU's. However, furmark is not a good test for folding stability. You might want to try FAHbench, it is based on actual folding code and work. I suspect it is not a driver issue.
