Project 10468 0x17:Bad State detected... attempting to resum
"Project 10468 0x17:Bad State detected... attempting to resum" What causing this and should I delete the work unit?
Re: Project 10468 0x17:Bad State detected... attempting to r
Please post the applicable portions of the log.
The wu was able to resume and seams to end normaly ....
18:04:17:WU01:FS02:0x17:Bad State detected... attempting to resume from last good checkpoint
18:04:43:WU00:FS03:0x17:Completed 1950000 out of 5000000 steps (39%)
18:06:05:WU02:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
18:06:38:WU01:FS02:0x17:Completed 1650000 out of 5000000 steps (33%)
Please post the applicable portions of the log. [Hint: see bruce's signature]
Bad State errors have been reported by others. Since resuming from the last good checkpoint seems to finish (almost) all WUs, nobody seems worried enough about it to figure out what causes it and what to do about it.
It happen again with an other wu under the same project, project 10468. The processing seams to stop for 20 - 30 minutes and then restarts again and seams to finish with no error so I guess it is no big deal.
Mod edit: Please use Code tags from the Full Editor when posting logs
*********************** Log Started 2015-08-16T09:35:51Z ***********************
09:35:51:WU03:FS02:Starting
09:35:51:WU03:FS02:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:/Folding/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 704 -lifeline 1952 -checkpoint 15 -gpu 1 -gpu-vendor ati
09:35:51:WU03:FS02:Started FahCore on PID 1624
09:35:51:WU03:FS02:Core PID:1860
09:35:51:WU03:FS02:FahCore 0x17 started
09:35:51:WU03:FS02:0x17:*********************** Log Started 2015-08-16T09:35:51Z ***********************
09:35:51:WU03:FS02:0x17:Project: 10468 (Run 0, Clone 332, Gen 129)
09:35:51:WU03:FS02:0x17:Unit: 0x000000eb538b3db9538cb2ed0b7c4b9e
09:35:51:WU03:FS02:0x17:CPU: 0x00000000000000000000000000000000
09:35:51:WU03:FS02:0x17:Machine: 2
09:35:51:WU03:FS02:0x17:Digital signatures verified
09:35:51:WU03:FS02:0x17:Folding@home GPU core17
09:35:51:WU03:FS02:0x17:Version 0.0.52
09:35:52:WU03:FS02:0x17: Found a checkpoint file
09:38:21:WU03:FS02:0x17:Completed 4750000 out of 5000000 steps (95%)
09:38:21:WU03:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:43:14:WU03:FS02:0x17:Completed 4800000 out of 5000000 steps (96%)
09:47:57:WU03:FS02:0x17:Completed 4850000 out of 5000000 steps (97%)
09:52:52:WU03:FS02:0x17:Completed 4900000 out of 5000000 steps (98%)
09:57:35:WU03:FS02:0x17:Completed 4950000 out of 5000000 steps (99%)
10:02:18:WU03:FS02:0x17:Completed 5000000 out of 5000000 steps (100%)
10:02:18:WU01:FS02:Connecting to 171.67.108.200:80
10:02:19:WU01:FS02:Assigned to work server 140.163.4.233
10:02:19:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Hawaii [Radeon R9 200/300 Series] from 140.163.4.233
10:02:19:WU01:FS02:Connecting to 140.163.4.233:8080
10:02:19:WU01:FS02:Downloading 4.32MiB
10:02:25:WU01:FS02:Download 86.83%
10:02:25:WU01:FS02:Download complete
10:02:25:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10468 run:0 clone:207 gen:94 core:0x17 unit:0x000000bc538b3db9538cafcce788fcfd
10:02:31:WU03:FS02:0x17:Saving result file logfile_01.txt
10:02:31:WU03:FS02:0x17:Saving result file checkpointState.xml
10:02:33:WU03:FS02:0x17:Saving result file checkpt.crc
10:02:33:WU03:FS02:0x17:Saving result file log.txt
10:02:33:WU03:FS02:0x17:Saving result file positions.xtc
10:02:35:WU03:FS02:0x17:Folding@home Core Shutdown: FINISHED_UNIT
10:02:36:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:02:36:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:10468 run:0 clone:332 gen:129 core:0x17 unit:0x000000eb538b3db9538cb2ed0b7c4b9e
10:02:36:WU03:FS02:Uploading 13.05MiB to 140.163.4.233
10:02:36:WU03:FS02:Connecting to 140.163.4.233:8080
10:02:36:WU01:FS02:Starting
10:02:36:WU01:FS02:Running FahCore: D:\Folding\FAHClient/FAHCoreWrapper.exe D:/Folding/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 1952 -checkpoint 15 -gpu 1 -gpu-vendor ati
10:02:36:WU01:FS02:Started FahCore on PID 1800
10:02:36:WU01:FS02:Core PID:4332
10:02:36:WU01:FS02:FahCore 0x17 started
10:02:36:WU01:FS02:0x17:*********************** Log Started 2015-08-16T10:02:36Z ***********************
10:02:36:WU01:FS02:0x17:Project: 10468 (Run 0, Clone 207, Gen 94)
10:02:36:WU01:FS02:0x17:Unit: 0x000000bc538b3db9538cafcce788fcfd
10:02:36:WU01:FS02:0x17:CPU: 0x00000000000000000000000000000000
10:02:36:WU01:FS02:0x17:Machine: 2
10:02:36:WU01:FS02:0x17:Reading tar file state.xml
10:02:37:WU01:FS02:0x17:Reading tar file system.xml
10:02:38:WU01:FS02:0x17:Reading tar file integrator.xml
10:02:38:WU01:FS02:0x17:Reading tar file core.xml
10:02:38:WU01:FS02:0x17:Digital signatures verified
10:02:38:WU01:FS02:0x17:Folding@home GPU core17
10:02:38:WU01:FS02:0x17:Version 0.0.52
10:02:42:WU03:FS02:Upload 4.79%
10:02:48:WU03:FS02:Upload 9.58%
10:02:54:WU03:FS02:Upload 14.84%
10:03:00:WU03:FS02:Upload 17.24%
10:03:06:WU03:FS02:Upload 20.59%
10:03:12:WU03:FS02:Upload 24.42%
10:03:18:WU03:FS02:Upload 28.25%
10:03:24:WU03:FS02:Upload 32.08%
10:03:30:WU03:FS02:Upload 35.91%
10:03:36:WU03:FS02:Upload 40.70%
10:03:42:WU03:FS02:Upload 45.48%
10:03:48:WU03:FS02:Upload 50.27%
10:03:55:WU03:FS02:Upload 55.54%
10:04:01:WU03:FS02:Upload 60.33%
10:04:07:WU03:FS02:Upload 65.11%
10:04:13:WU03:FS02:Upload 69.42%
10:04:19:WU03:FS02:Upload 74.21%
10:04:25:WU03:FS02:Upload 77.56%
10:04:31:WU03:FS02:Upload 82.83%
10:04:37:WU03:FS02:Upload 86.18%
10:04:43:WU03:FS02:Upload 90.97%
10:04:49:WU03:FS02:Upload 95.76%
10:04:50:WU01:FS02:0x17:Completed 0 out of 5000000 steps (0%)
10:04:50:WU01:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:05:04:WU03:FS02:Upload complete
10:05:04:WU03:FS02:Server responded WORK_ACK (400)
10:05:04:WU03:FS02:Final credit estimate, 49006.00 points
10:05:04:WU03:FS02:Cleaning up
10:09:43:WU01:FS02:0x17:Completed 50000 out of 5000000 steps (1%)
10:14:26:WU01:FS02:0x17:Completed 100000 out of 5000000 steps (2%)
10:19:21:WU01:FS02:0x17:Completed 150000 out of 5000000 steps (3%)
10:24:03:WU01:FS02:0x17:Completed 200000 out of 5000000 steps (4%)
10:28:46:WU01:FS02:0x17:Completed 250000 out of 5000000 steps (5%)
10:33:40:WU01:FS02:0x17:Completed 300000 out of 5000000 steps (6%)
10:38:23:WU01:FS02:0x17:Completed 350000 out of 5000000 steps (7%)
10:43:18:WU01:FS02:0x17:Completed 400000 out of 5000000 steps (8%)
10:48:01:WU01:FS02:0x17:Completed 450000 out of 5000000 steps (9%)
10:52:44:WU01:FS02:0x17:Completed 500000 out of 5000000 steps (10%)
10:57:39:WU01:FS02:0x17:Completed 550000 out of 5000000 steps (11%)
11:02:22:WU01:FS02:0x17:Completed 600000 out of 5000000 steps (12%)
11:07:17:WU01:FS02:0x17:Completed 650000 out of 5000000 steps (13%)
11:12:00:WU01:FS02:0x17:Completed 700000 out of 5000000 steps (14%)
11:16:42:WU01:FS02:0x17:Completed 750000 out of 5000000 steps (15%)
11:21:37:WU01:FS02:0x17:Completed 800000 out of 5000000 steps (16%)
11:26:20:WU01:FS02:0x17:Completed 850000 out of 5000000 steps (17%)
11:31:15:WU01:FS02:0x17:Completed 900000 out of 5000000 steps (18%)
11:35:58:WU01:FS02:0x17:Completed 950000 out of 5000000 steps (19%)
11:40:40:WU01:FS02:0x17:Completed 1000000 out of 5000000 steps (20%)
11:45:36:WU01:FS02:0x17:Completed 1050000 out of 5000000 steps (21%)
11:50:18:WU01:FS02:0x17:Completed 1100000 out of 5000000 steps (22%)
11:55:14:WU01:FS02:0x17:Completed 1150000 out of 5000000 steps (23%)
11:59:56:WU01:FS02:0x17:Completed 1200000 out of 5000000 steps (24%)
12:04:39:WU01:FS02:0x17:Completed 1250000 out of 5000000 steps (25%)
12:09:34:WU01:FS02:0x17:Completed 1300000 out of 5000000 steps (26%)
12:14:16:WU01:FS02:0x17:Completed 1350000 out of 5000000 steps (27%)
12:19:12:WU01:FS02:0x17:Completed 1400000 out of 5000000 steps (28%)
12:23:54:WU01:FS02:0x17:Completed 1450000 out of 5000000 steps (29%)
12:28:37:WU01:FS02:0x17:Completed 1500000 out of 5000000 steps (30%)
12:33:32:WU01:FS02:0x17:Completed 1550000 out of 5000000 steps (31%)
13:16:03:WU01:FS02:0x17:Completed 1600000 out of 5000000 steps (32%)
13:37:56:WU01:FS02:0x17:Bad State detected... attempting to resume from last good checkpoint
13:42:38:WU01:FS02:0x17:Completed 1550000 out of 5000000 steps (31%)
13:47:20:WU01:FS02:0x17:Completed 1600000 out of 5000000 steps (32%)
13:52:16:WU01:FS02:0x17:Completed 1650000 out of 5000000 steps (33%)
13:56:59:WU01:FS02:0x17:Completed 1700000 out of 5000000 steps (34%)
14:01:42:WU01:FS02:0x17:Completed 1750000 out of 5000000 steps (35%)
14:06:38:WU01:FS02:0x17:Completed 1800000 out of 5000000 steps (36%)
14:11:20:WU01:FS02:0x17:Completed 1850000 out of 5000000 steps (37%)
14:16:16:WU01:FS02:0x17:Completed 1900000 out of 5000000 steps (38%)
14:20:58:WU01:FS02:0x17:Completed 1950000 out of 5000000 steps (39%)
14:25:41:WU01:FS02:0x17:Completed 2000000 out of 5000000 steps (40%)
14:30:37:WU01:FS02:0x17:Completed 2050000 out of 5000000 steps (41%)
14:35:20:WU01:FS02:0x17:Completed 2100000 out of 5000000 steps (42%)
14:40:15:WU01:FS02:0x17:Completed 2150000 out of 5000000 steps (43%)
14:44:58:WU01:FS02:0x17:Completed 2200000 out of 5000000 steps (44%)
14:49:41:WU01:FS02:0x17:Completed 2250000 out of 5000000 steps (45%)
14:54:37:WU01:FS02:0x17:Completed 2300000 out of 5000000 steps (46%)
14:59:19:WU01:FS02:0x17:Completed 2350000 out of 5000000 steps (47%)
15:04:15:WU01:FS02:0x17:Completed 2400000 out of 5000000 steps (48%)
15:08:58:WU01:FS02:0x17:Completed 2450000 out of 5000000 steps (49%)
15:13:40:WU01:FS02:0x17:Completed 2500000 out of 5000000 steps (50%)
15:18:36:WU01:FS02:0x17:Completed 2550000 out of 5000000 steps (51%)
15:23:19:WU01:FS02:0x17:Completed 2600000 out of 5000000 steps (52%)
15:28:14:WU01:FS02:0x17:Completed 2650000 out of 5000000 steps (53%)
15:32:57:WU01:FS02:0x17:Completed 2700000 out of 5000000 steps (54%)
******************************* Date: 2015-08-16 *******************************
15:37:40:WU01:FS02:0x17:Completed 2750000 out of 5000000 steps (55%)
15:42:36:WU01:FS02:0x17:Completed 2800000 out of 5000000 steps (56%)
15:47:19:WU01:FS02:0x17:Completed 2850000 out of 5000000 steps (57%)
15:52:14:WU01:FS02:0x17:Completed 2900000 out of 5000000 steps (58%)
15:56:56:WU01:FS02:0x17:Completed 2950000 out of 5000000 steps (59%)
16:01:39:WU01:FS02:0x17:Completed 3000000 out of 5000000 steps (60%)
16:06:34:WU01:FS02:0x17:Completed 3050000 out of 5000000 steps (61%)
16:11:17:WU01:FS02:0x17:Completed 3100000 out of 5000000 steps (62%)
16:16:13:WU01:FS02:0x17:Completed 3150000 out of 5000000 steps (63%)
16:20:55:WU01:FS02:0x17:Completed 3200000 out of 5000000 steps (64%)
16:25:38:WU01:FS02:0x17:Completed 3250000 out of 5000000 steps (65%)
16:30:33:WU01:FS02:0x17:Completed 3300000 out of 5000000 steps (66%)
16:35:16:WU01:FS02:0x17:Completed 3350000 out of 5000000 steps (67%)
16:40:12:WU01:FS02:0x17:Completed 3400000 out of 5000000 steps (68%)
16:44:55:WU01:FS02:0x17:Completed 3450000 out of 5000000 steps (69%)
16:49:38:WU01:FS02:0x17:Completed 3500000 out of 5000000 steps (70%)
16:54:34:WU01:FS02:0x17:Completed 3550000 out of 5000000 steps (71%)
17:26:51:WU01:FS02:0x17:Completed 3600000 out of 5000000 steps (72%)
17:48:44:WU01:FS02:0x17:Bad State detected... attempting to resume from last good checkpoint
17:53:27:WU01:FS02:0x17:Completed 3550000 out of 5000000 steps (71%)
17:58:09:WU01:FS02:0x17:Completed 3600000 out of 5000000 steps (72%)
18:03:06:WU01:FS02:0x17:Completed 3650000 out of 5000000 steps (73%)
18:07:48:WU01:FS02:0x17:Completed 3700000 out of 5000000 steps (74%)
18:12:31:WU01:FS02:0x17:Completed 3750000 out of 5000000 steps (75%)
18:17:27:WU01:FS02:0x17:Completed 3800000 out of 5000000 steps (76%)
18:22:10:WU01:FS02:0x17:Completed 3850000 out of 5000000 steps (77%)
18:27:05:WU01:FS02:0x17:Completed 3900000 out of 5000000 steps (78%)
18:31:48:WU01:FS02:0x17:Completed 3950000 out of 5000000 steps (79%)
18:36:31:WU01:FS02:0x17:Completed 4000000 out of 5000000 steps (80%)
18:41:26:WU01:FS02:0x17:Completed 4050000 out of 5000000 steps (81%)
18:46:09:WU01:FS02:0x17:Completed 4100000 out of 5000000 steps (82%)-
Do you have a driver reset at the same time the Bad States occur ?
What is your GPU ? And OS ?
Sorry. I think I have found the problem, it seams that it was heat related and only affected slot 2. I have a 3-way Radeon R9 290 setup running under Windows 8.1
I need to use the vacuum cleaner more frequently
