The first time I opened the desktop client, it opened a web browser that had stats and the "While I'm working" / "Only when idle" setting.
How do I get back to that browser page? It doesn't open when I restart the application.
Thanks
Web Browser View
- Hardware configuration: Intel G3258 oc 4.3ghz
Asus 6970 DC II (2gb)
Corsair Vengance 1600 8gb
3x 2tb WD Green
Toshiba 120gb SSD
EVGA SuperNOVA 650w G2
H110 CPU Watercooling - Location: Exeter, Devon
Re: Web Browser View
If using Windows, click the fah icon in your task bar and select web view...
If you installed in the default location, go to the Folding@home folder in your Applications folder. The Web Control URL is located there. You can create an alias or bookmark it. That is also the location for the advanced FAHControl and FAHViewer as well as the uninstaller.
