GTX 960 stopped being used when GTX 980 added (Resolved)
Ricky
Hardware configuration: 1. 2 each E5-2630 V3 processors, 64 GB RAM, GTX980SC GPU, and GTX980 GPU running on windows 8.1 operating system.
2. I7-6950X V3 processor, 32 GB RAM, 1 GTX980tiFTW, and 2 each GTX1080FTW GPUs running on windows 8.1 operating system.
Post by Ricky »
I added a GTX 980 and it assumed work, but the GTX 960 is no longer being used by the client. Both cards are using the 357.52 driver, and the client recognizes both GPUs. I have uninstalled and reinstalled the client, with no benefit. Any suggestions?
Re: GTX 960 stopped being use when GTX 980 added
Post a log. See my .sig.
Urbanfreestyle
Hardware configuration: Intel G3258 oc 4.3ghz
Asus 6970 DC II (2gb)
Corsair Vengance 1600 8gb
3x 2tb WD Green
Toshiba 120gb SSD
EVGA SuperNOVA 650w G2
H110 CPU Watercooling
Post by Urbanfreestyle »
i'm not amazing with F@H but have you got 2 separate slots set up?
Ricky
Post by Ricky »
I had a CPU slot and 1 GPU slot. Last night by looking at the FAH installation guides, I found how to add another GPU slot in the client control. So, the issue is now resolved. I thank you for offering help.
Adding the second slot probably was needed because you did not do a full reinstall. You would have had to also remove the existing data and configuration files when uninstalling. Then the client would have set up both slots for the two GPU's.
Urbanfreestyle
3x 2tb WD Green
Toshiba 120gb SSD
if that was aimed at me; you're welcome :-)
