Project 2653 credit not received
Doctor_Love
Hello
On two projects send yesterday evening one seems not credite in my statistics
Thank you in advance of retablir the missing credit.
User => Doctor_Love
Team => 35819
Project => 2653 (Run 34, Clone 10, Gen 65)
[06:38:41] *------------------------------*
[06:38:41] Folding@Home Gromacs SMP Core
[06:38:41] Version 1.74 (March 10, 2007)
[06:38:41]
[06:38:41] Preparing to commence simulation
[06:38:41] - Ensuring status. Please wait.
[06:38:43]
[06:38:43] Project: 265- Starting from initial work packet
[06:38:43]
[06:38:43] Project: 2653 (Run 34, Clone 10, Gen 65)
[06:38:43]
[06:38:44] M.D.
[06:38:44] ing M.D.
[06:39:00] a- Starting from initial work packet
[06:39:00]
[06:39:00] Project: 2653 (Run 34, Clone 10, Gen 65)
[06:39:00]
[06:39:01] Entering M.D.
[06:39:07] Rejecting checkpoint
[06:39:08] Protein: Protein in POPC
[06:39:08] Writing local files
[06:39:09] Extra SSE boost OK.
[06:39:09] Writing local files
[06:39:09] Completed 0 out of 500000 steps (0 percent)
[06:47:58] Writing local files
[06:47:58] Completed 5000 out of 500000 steps (1 percent)
[19:49:24] Completed 500000 out of 500000 steps (100 percent)
[19:49:24] Writing final coordinates.
[19:49:24] Past main M.D. loop
[19:49:24] Will end MPI now
[19:50:24]
[19:50:24] Finished Work Unit:
[19:50:24] - Reading up to 3724992 from "work/wudata_01.arc": Read 3724992
[19:50:24] - Reading up to 1943372 from "work/wudata_01.xtc": Read 1943372
[19:50:24] goefile size: 0
[19:50:24] logfile size: 42317
[19:50:24] Leaving Run
[19:50:27] - Writing 5715081 bytes of core data to disk...
[19:50:27] ... Done.
[19:50:27] - Failed to delete work/wudata_01.sas
[19:50:27] - Failed to delete work/wudata_01.goe
[19:50:27] Warning: check for stray files
[19:50:27] - Shutting down core
[19:52:27]
[19:52:27] Folding@home Core Shutdown: FINISHED_UNIT
[19:52:27]
[19:52:31] CoreStatus = 64 (100)
[19:52:31] Unit 1 finished with 61 percent of time to deadline remaining.
[19:52:31] Updated performance fraction: 0.612153
[19:52:31] Sending work to server
[19:52:31] + Attempting to send results
[19:52:31] - Reading file work/wuresults_01.dat from core
[19:52:31] (Read 5715081 bytes from disk)
[19:52:31] Connecting to http://171.64.65.64:8080/
[19:53:40] Posted data.
[19:53:40] Initial: 0000; - Uploaded at ~80 kB/s
[19:53:40] - Averaged speed for that direction ~80 kB/s
[19:53:40] + Results successfully sent
[19:53:40] Thank you for your contribution to Folding@Home.
[19:53:40] + Number of Units Completed: 260
unitinfo.txt => Due time: May 28 06:38:31
Project => 2653 (Run 11, Clone 10, Gen 67)
[01:20:38] *------------------------------*
[01:20:38] Folding@Home Gromacs SMP Core
[01:20:38] Version 1.74 (March 10, 2007)
[01:20:38]
[01:20:38] Preparing to commence simulation
[01:20:38] - Looking at optimizations...
[01:20:38] - Created dyn
[01:20:38] - Files status OK
[01:20:40] - Expanded 2449291 -> 12901369 (decompressed 526.7 percent)
[01:20:40] - Starting from initial work packet
[01:20:40]
[01:20:40] Project: 2653 (Run 11, Clone 10, Gen 67)
[01:20:40]
[01:20:40] Assembly optimizations on if available.
[01:20:40] Entering M.D.
[01:20:59] al work pa- Starting from initial work packet
[01:20:59] 0, Gen 67)
[01:20:59]
[01:20:59] 53 (Run 11, Clone 10, Gen 67)
[01:20:59]
[01:21:00] Entering M.D.
[01:21:06] Rejecting checkpoint
[01:21:07] Protein: Protein in POPC
[01:21:07] Writing local files
[01:21:08] Extra SSE boost OK.
[01:21:08] Writing local files
[01:21:08] Completed 0 out of 500000 steps (0 percent)
[01:36:08] Timered checkpoint triggered.
[01:37:42] Writing local files
[01:37:42] Completed 5000 out of 500000 steps (1 percent)
[22:15:14] Completed 500000 out of 500000 steps (100 percent)
[22:15:14] Writing final coordinates.
[22:15:15] Past main M.D. loop
[22:15:15] Will end MPI now
[22:16:15]
[22:16:15] Finished Work Unit:
[22:16:15] - Reading up to 3724128 from "work/wudata_04.arc": Read 3724128
[22:16:15] - Reading up to 1780328 from "work/wudata_04.xtc": Read 1780328
[22:16:15] goefile size: 0
[22:16:15] logfile size: 33706
[22:16:15] Leaving Run
[22:16:17] - Writing 5542562 bytes of core data to disk...
[22:16:17] ... Done.
[22:16:17] - Failed to delete work/wudata_04.sas
[22:16:17] - Failed to delete work/wudata_04.goe
[22:16:17] Warning: check for stray files
[22:16:17] - Shutting down core
[22:18:17]
[22:18:17] Folding@home Core Shutdown: FINISHED_UNIT
[22:18:17]
[22:18:20] CoreStatus = 64 (100)
[22:18:20] Unit 4 finished with 78 percent of time to deadline remaining.
[22:18:20] Updated performance fraction: 0.725352
[22:18:20] Sending work to server
[22:18:20] + Attempting to send results
[22:18:20] - Reading file work/wuresults_04.dat from core
[22:18:20] (Read 5542562 bytes from disk)
[22:18:20] Connecting to http://171.64.65.64:8080/
[22:19:25] Posted data.
[22:19:25] Initial: 0000; - Uploaded at ~80 kB/s
[22:19:27] - Averaged speed for that direction ~80 kB/s
[22:19:27] + Results successfully sent
[22:19:27] Thank you for your contribution to Folding@Home.
[22:19:27] + Number of Units Completed: 168
unitinfo.txt => Due time: May 29 01:20:38
User => Doctor_Love
Team => 35819
[06:38:41]
[06:38:43]
[06:38:43]
[06:38:43]
[06:38:44] M.D.
[06:38:44] ing M.D.
[06:39:00]
[06:39:00]
[19:50:24]
[19:52:27]
[19:52:27]
[01:20:38]
[01:20:40]
[01:20:40]
[01:20:59]
[01:20:59]
[22:16:15]
[22:18:17]
[22:18:17]
ChelseaOilman
Re: Project 2653 credit not received
I'm not sure what happened with the first WU. There's an error code that seems to indicate the WU was already submitted earlier and received credit. I can't see the earlier credit though. Your not doing any sneakernetting are you?
Hi Doctor_Love (team 35819),
Your WU (P2653 R34 C10 G65) was added to the stats database on 2008-05-25 14:20:16 for 0 points of credit.
You received credit for the second WU.
Your WU (P2653 R11 C10 G67) was added to the stats database on 2008-05-25 16:15:54 for 1760 points of credit.
Doctor_Love
I am tres bad in English that this sentence means? (que veut dire cette phrase?)ChelseaOilman wrote:Your not doing any sneakernetting are you?
ChelseaOilman
Doctor_Love
Except a cleaning of the base of register yesterday with (CCleaner) and the purge of Prefetch
I realize regularly these operations without consequence until now on the return of result of the customer SMP
Thank you
Thank you
ChelseaOilman wrote:I'm not sure what happened with the first WU. There's an error code that seems to indicate the WU was already submitted earlier and received credit. I can't see the earlier credit though.
You posted most of FAHlog for this unit. Could you identify both the date and time that the WU was downloaded an the date-time the result was uploaded. Did anything strange happen during the download? Was it downloaded more than once?Doctor_Love wrote:Project => 2653 (Run 34, Clone 10, Gen 65)
sabeyp
- Hardware configuration: Gigabyte GA-K8NXP-9, 2gb DDR@400mhz, Athlon64 X2 @2.2ghz
Asus EN8600GT 512mb (@725/1595/750)
Windows XP Pro, nVidia 178.24 drivers, FAH GPU systray 6.20r1 - Location: Redhill, UK
I see that this thread is rather old but I find that I started suffering the same problem recently - please help !!
I have done 17 project 2653 WUs since April and they have all computed, uploaded and credited fine EXCEPT the last two times.
These last two were run/clone/gen = 18/39/88 and 13/16/92 which computed successfully (on Nov 3 and Dec 2 respectively) but did not upload as they did not get a 'completed' date in the queue info.
So I used qfix to repair the queue info after which they successfully uploaded.
However, no credit has been been added to my stats.
Please could one of the sys admins have a look and see if those WUs are on the system.
What is you UserName ?
18/39/88 has been completed successfully three times (two were after the preferred deadline).
13/16/92 has been completed successfully by someone else. It have a strange report that might match :
Hi PaulSabey (team 53338),
Your WU (P2653 R13 C16 G92) was added to the stats database on 2008-12-02 02:39:39 for 0 points of credit.
The error indicates that you submitted incorrect results (but I can't tell what was wrong ... maybe duplicate results ... or corrupted results ...)
sabeyp
Apologies for not spotting I had not stated my user name - it is indeed PaulSabey in team 53338.
It is quite possible that the first one (18/39/88) was submitted after the deadline since I was flapping about for quite a while working out what went wrong and how to upload the results. The second time (13/16/92) I was clued up and qfixed it and submitted it comfortably within the deadline.
I have taken a closer look at the log from the latter and it does indeed show an error "Client-core communications error: ERROR 0x7b" after the unit completed calculation.
Perhaps that means the results, even though fully calculated, are indeed dud - does that sound right ?
Shame I got no points in return for 3.5 days of compute effort. Oh well.
Thanks anyway for your help, toTOW.
Make sure to run the latest 6.23 client ... it should solve this kind of issue.
