Project: 2665 (Run 0, Clone 910, Gen 7)
I keep getting corestatus=63(99) then error message saying + Error starting Folding@Home core or unexpected system termination of core. then the client trys to download a new core but can't access it and downloads again in a loop . shutting the client down solved this once but after a bit (5%) it did it again (suggests a file already open sort of error so can't access it ). I'm trying a client/machine reboot and see if it helps. The linux VM also running is having no problems.
Re: Project 2665 (run 0 clone 910 gen 7)
i deleted parts of the core downloading to get the post size to fit
--- Opening Log file [May 25 09:09:42]
# SMP Client ##################################################################
Folding@Home Client Version 5.92beta
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\keith.PARLOUR\Desktop\folding\FAH5.92beta-win32-SMP-update
Executable: C:\Documents and Settings\keith.PARLOUR\Desktop\folding\FAH5.92beta-win32-SMP-update\fah.exe
Arguments: -forceasm -verbosity 9 -local
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[09:09:42] - Ask before connecting: No
[09:09:42] - User name: keith (Team 46590)
[09:09:42] - User ID: 6B67132427192125
[09:09:42] - Machine ID: 1
[09:09:42]
[09:09:42] Loaded queue successfully.
[09:09:42]
[09:09:42] + Processing work unit
[09:09:42] - Autosending finished units...
[09:09:42] Core required: FahCore_a1.exe
[09:09:42] Trying to send all finished work units
[09:09:42] + No unsent completed units remaining.
[09:09:42] - Autosend completed
[09:09:42] Core found.
[09:09:42] Working on Unit 05 [May 25 09:09:42]
[09:09:42] + Working ...
[09:09:42] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 3688 -version 592'
[09:09:44]
[09:09:44] *------------------------------*
[09:09:44] Folding@Home Gromacs SMP Core
[09:09:44] Version 1.76 (February 23, 2008)
[09:09:44]
[09:09:44] Preparing to commence simulation
[09:09:44] - Ensuring status. Please wait.
[09:10:01] - Assembly optimizations manually forced on.
[09:10:01] - Not checking prior termination.
[09:10:32] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[09:10:34]
[09:10:34] Project: 2665 (Run 0, Clone 910, Gen 7)
[09:10:34]
[09:10:37] Assembly optimizations on if available.
[09:10:37] Entering M.D.
[09:10:46] Calling FAH init
[09:10:48] ater
[09:10:48] Writing local files
[09:10:48] rom checkpoint)
[09:10:48] Read checkpoint
[09:10:49] eps (11 percent)
[09:10:49] ter
[09:10:49] Writing local files
[09:10:49] Completed 27500 out of 250000 steps (11 percent)
[09:11:02] Extra SSE boost OK.
[09:26:03] Timered checkpoint triggered.
[09:32:38] Writing local files
[09:32:38] Completed 30000 out of 250000 steps (12 percent)
[09:47:39] Timered checkpoint triggered.
[09:54:33] Writing local files
[09:54:34] Completed 32500 out of 250000 steps (13 percent)
[10:09:34] Timered checkpoint triggered.
[10:16:22] Writing local files
[10:16:23] Completed 35000 out of 250000 steps (14 percent)
[10:31:23] Timered checkpoint triggered.
[10:38:03] Writing local files
[10:38:04] Completed 37500 out of 250000 steps (15 percent)
[10:53:04] Timered checkpoint triggered.
[10:59:29] Writing local files
[10:59:29] Completed 40000 out of 250000 steps (16 percent)
[11:14:31] Timered checkpoint triggered.
[11:20:56] Writing local files
[11:20:57] Completed 42500 out of 250000 steps (17 percent)
[11:35:57] Timered checkpoint triggered.
[11:42:22] Writing local files
[11:42:22] Completed 45000 out of 250000 steps (18 percent)
[11:57:23] Timered checkpoint triggered.
[12:03:34] Writing local files
[12:03:35] Completed 47500 out of 250000 steps (19 percent)
[12:18:35] Timered checkpoint triggered.
[12:23:31] Writing local files
[12:23:31] Completed 50000 out of 250000 steps (20 percent)
[12:38:31] Timered checkpoint triggered.
[12:44:59] Writing local files
[12:45:00] Completed 52500 out of 250000 steps (21 percent)
[13:00:00] Timered checkpoint triggered.
[13:06:26] Writing local files
[13:06:26] Completed 55000 out of 250000 steps (22 percent)
[13:21:27] Timered checkpoint triggered.
[13:27:53] Writing local files
[13:27:53] Completed 57500 out of 250000 steps (23 percent)
[13:42:54] Timered checkpoint triggered.
[13:49:18] Writing local files
[13:49:19] Completed 60000 out of 250000 steps (24 percent)
[14:04:19] Timered checkpoint triggered.
[14:10:45] Writing local files
[14:10:46] Completed 62500 out of 250000 steps (25 percent)
[14:25:46] Timered checkpoint triggered.
--- Opening Log file [May 25 16:52:15]
Warning:
use of the flag.
[16:52:15] - Ask before connecting: No
[16:52:15] - User name: keith (Team 46590)
[16:52:15] - User ID: 6B67132427192125
[16:52:15] - Machine ID: 1
[16:52:15]
[16:52:15] Loaded queue successfully.
[16:52:15]
[16:52:15] - Autosending finished units...
[16:52:15] + Processing work unit
[16:52:15] Trying to send all finished work units
[16:52:15] Core required: FahCore_a1.exe
[16:52:15] + No unsent completed units remaining.
[16:52:15] - Autosend completed
[16:52:15] Core found.
[16:52:15] Working on Unit 05 [May 25 16:52:15]
[16:52:15] + Working ...
[16:52:15] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2948 -version 592'
[16:52:18]
[16:52:18] *------------------------------*
[16:52:18] Folding@Home Gromacs SMP Core
[16:52:18] Version 1.76 (February 23, 2008)
[16:52:18]
[16:52:18] Preparing to commence simulation
[16:52:18] - Ensuring status. Please wait.
[16:52:35] - Assembly optimizations manually forced on.
[16:52:35] - Not checking prior termination.
[16:52:58] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[16:53:00]
[16:53:00] Project: 2665 (Run 0, Clone 910, Gen 7)
[16:53:00]
[16:53:08] Assembly optimizations on if available.
[16:53:08] Entering M.D.
[16:53:20] Calling FAH init
[16:53:22] Read topology
[16:53:22] ocal files
[16:53:22] rom checkpoint)
[16:53:22] Read checkpoint
[16:53:22] Protein: HGG in water
[16:53:22] Writing local files
[16:53:23] Completed 64248 out of 250000 steps (25 percent)
[16:53:36] Extra SSE boost OK.
[17:00:14] Writing local files
[17:00:15] Completed 65000 out of 250000 steps (26 percent)
[17:15:15] Timered checkpoint triggered.
[17:21:58] Writing local files
[17:21:58] Completed 67500 out of 250000 steps (27 percent)
[17:36:59] Timered checkpoint triggered.
[17:43:36] Writing local files
[17:43:36] Completed 70000 out of 250000 steps (28 percent)
[17:49:29] CoreStatus = 63 (99)
[17:49:29] + Error starting Folding@Home core or unexpected system termination of core.
[17:49:34]
[17:49:34] + Processing work unit
[17:49:34] Core required: FahCore_a1.exe
[17:49:34] Core found.
[17:49:34] Working on Unit 05 [May 25 17:49:34]
[17:49:34] + Working ...
[17:49:34] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2948 -version 592'
[17:49:37]
[17:49:37] *------------------------------*
[17:49:37] Folding@Home Gromacs SMP Core
[17:49:37] Version 1.76 (February 23, 2008)
[17:49:37]
[17:49:37] Preparing to commence simulation
[17:49:37] - Ensuring status. Please wait.
[17:49:54] - Assembly optimizations manually forced on.
[17:49:54] - Not checking prior termination.
[17:50:14] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[17:50:14]
[17:50:14] Project: 2665 (Run 0, Clone 910, Gen 7)
[17:50:14]
[17:50:23] Assembly optimizations on if available.
[17:50:23] Entering M.D.
[17:50:36] Calling FAH init
[17:50:38] Read topology
[17:50:38] (Starting from checkpoint)
[17:50:38] Read checkpoint
[17:50:38] eps (28 percent)
[17:50:38] ter
[17:50:38] Writing local files
[17:50:38] Completed 70000 out of 250000 steps (28 percent)
[17:50:51] Extra SSE boost OK.
[18:05:52] Timered checkpoint triggered.
[18:11:33] CoreStatus = 63 (99)
[18:11:33] + Error starting Folding@Home core or unexpected system termination of core.
[18:11:38]
[18:11:38] + Processing work unit
[18:11:38] Core required: FahCore_a1.exe
[18:11:38] Core found.
[18:11:38] Working on Unit 05 [May 25 18:11:38]
[18:11:38] + Working ...
[18:11:38] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2948 -version 592'
[18:11:40]
[18:11:40] *------------------------------*
[18:11:40] Folding@Home Gromacs SMP Core
[18:11:40] Version 1.76 (February 23, 2008)
[18:11:40]
[18:11:40] Preparing to commence simulation
[18:11:40] - Ensuring status. Please wait.
[18:11:57] - Assembly optimizations manually forced on.
[18:11:57] - Not checking prior termination.
[18:12:16] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[18:12:16]
[18:12:16] Project: 2665 (Run 0, Clone 910, Gen 7)
[18:12:16]
[18:12:22] Assembly optimizations on if available.
[18:12:22] Entering M.D.
[18:12:41] Calling FAH init
[18:12:43] Read topology
[18:12:43] ocal files
[18:12:43] rom checkpoint)
[18:12:43] Read checkpoint
[18:12:43] Protein: HGG in water
[18:12:43] Writing local files
[18:12:44] Completed 71775 out of 250000 steps (28 percent)
[18:12:57] Extra SSE boost OK.
[18:19:49] Writing local files
[18:19:49] Completed 72500 out of 250000 steps (29 percent)
[18:34:50] Timered checkpoint triggered.
[18:43:30] Writing local files
[18:43:30] Completed 75000 out of 250000 steps (30 percent)
[18:58:31] Timered checkpoint triggered.
[19:07:10] Writing local files
[19:07:10] Completed 77500 out of 250000 steps (31 percent)
[19:22:11] Timered checkpoint triggered.
[19:30:47] Writing local files
[19:30:47] Completed 80000 out of 250000 steps (32 percent)
[19:45:48] Timered checkpoint triggered.
[19:54:25] Writing local files
[19:54:25] Completed 82500 out of 250000 steps (33 percent)
[20:09:25] Timered checkpoint triggered.
[20:18:21] Writing local files
[20:18:21] Completed 85000 out of 250000 steps (34 percent)
[20:33:22] Timered checkpoint triggered.
[20:42:45] Writing local files
[20:42:45] Completed 87500 out of 250000 steps (35 percent)
[20:57:46] Timered checkpoint triggered.
[21:06:44] Writing local files
[21:06:44] Completed 90000 out of 250000 steps (36 percent)
[21:21:44] Timered checkpoint triggered.
[21:30:21] Writing local files
[21:30:21] Completed 92500 out of 250000 steps (37 percent)
[21:45:22] Timered checkpoint triggered.
[21:53:54] Writing local files
[21:53:54] Completed 95000 out of 250000 steps (38 percent)
[22:08:55] Timered checkpoint triggered.
[22:15:08] CoreStatus = 63 (99)
[22:15:08] + Error starting Folding@Home core or unexpected system termination of core.
[22:15:08] - Attempting to download new core...
[22:15:08] + Downloading new core: FahCore_a1.exe
[22:15:08] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[22:15:10] Initial: AFDE; + 10240 bytes downloaded
[22:15:10] Initial: 10F0; + 20480 bytes downloaded
[22:15:11] Initial: DB70; + 30720 bytes downloaded
[22:15:11] Initial: 865E; + 40960 bytes downloaded
[22:15:11] Initial: 8F87; + 51200 bytes downloaded
[22:15:11] Initial: C48B; + 61440 bytes downloaded
[22:15:11] Initial: 92B3; + 71680 bytes downloaded
[22:15:11] Initial: C102; + 81920 bytes downloaded
[22:15:11] Initial: 1996; + 92160 bytes downloaded
[22:15:11] Initial: BFFE; + 102400 bytes downloaded
[22:15:12] Initial: 1810; + 112640 bytes downloaded
[22:15:12] Initial: 0626; + 122880 bytes downloaded
[22:15:12] Initial: 7B53; + 133120 bytes downloaded
[22:15:12] Initial: 0441; + 143360 bytes downloaded
[22:15:12] Initial: FECE; + 153600 bytes downloaded
[22:15:12] Initial: D346; + 163840 bytes downloaded
[22:15:13] Initial: 2DE8; + 174080 bytes downloaded
[22:15:13] Initial: B3F0; + 184320 bytes downloaded
[22:15:14] Initial: 2881; + 194560 bytes downloaded
[22:15:14] Initial: 9507; + 204800 bytes downloaded
[22:15:14] Initial: 1BAF; + 215040 bytes downloaded
[22:15:14] Initial: 717C; + 225280 bytes downloaded
[22:15:15] Initial: 23FD; + 235520 bytes downloaded
[22:15:15] Initial: 915F; + 245760 bytes downloaded
[22:15:15] Initial: CE52; + 256000 bytes downloaded
[22:15:15] Initial: ED88; + 266240 bytes downloaded
[22:15:15] Initial: 2579; + 276480 bytes downloaded
[22:15:15] Initial: 3396; + 286720 bytes downloaded
[22:15:16] Initial: 410C; + 296960 bytes downloaded
[22:15:16] Initial: 56D1; + 307200 bytes downloaded
[22:15:16] Initial: 1EBD; + 317440 bytes downloaded
[22:15:16] Initial: 6AD9; + 327680 bytes downloaded
[22:15:16] Initial: F931; + 337920 bytes downloaded
[22:15:16] Initial: 1C40; + 348160 bytes downloaded
[22:15:16] Initial: C4AE; + 358400 bytes downloaded
[22:15:16] Initial: 57E4; + 368640 bytes downloaded
[22:15:17] Initial: 1843; + 378880 bytes downloaded
[22:15:17] Initial: B0C0; + 389120 bytes downloaded
[22:15:17] Initial: AAAA; + 399360 bytes downloaded
[22:15:17] Initial: D737; + 409600 bytes downloaded
[22:15:17] Initial: 762A; + 419840 bytes downloaded
[22:15:17] Initial: 8685; + 430080 bytes downloaded
[22:15:18] Initial: 25B1; + 440320 bytes downloaded
[22:15:18] Initial: 44F1; + 450560 bytes downloaded
[22:15:18] Initial: EF81; + 460800 bytes downloaded
[22:15:18] Initial: 900E; + 471040 bytes downloaded
[22:15:18] Initial: 906E; + 481280 bytes downloaded
[22:15:18] Initial: D59F; + 491520 bytes downloaded
[22:15:18] Initial: 2406; + 501760 bytes downloaded
[22:15:18] Initial: 9777; + 512000 bytes downloaded
[22:15:19] Initial: 7783; + 522240 bytes downloaded
[22:15:19] Initial: AEC5; + 532480 bytes downloaded
[22:15:19] Initial: B8A1; + 542720 bytes downloaded
[22:15:19] Initial: D50E; + 552960 bytes downloaded
[22:15:19] Initial: BDEE; + 563200 bytes downloaded
[22:15:19] Initial: E433; + 573440 bytes downloaded
[22:15:19] Initial: 667A; + 583680 bytes downloaded
[22:15:19] Initial: C413; + 593920 bytes downloaded
[22:15:19] Initial: DB64; + 604160 bytes downloaded
[22:15:19] Initial: 313C; + 614400 bytes downloaded
[22:15:20] Initial: 4B8A; + 624640 bytes downloaded
[22:15:20] Initial: 1B3A; + 634880 bytes downloaded
[22:15:20] Initial: E39B; + 645120 bytes downloaded
[22:15:21] Initial: F9FD; + 655360 bytes downloaded
[22:15:21] Initial: BFF6; + 665600 bytes downloaded
[22:15:21] Initial: 0552; + 675840 bytes downloaded
[22:15:21] Initial: 14A7; + 686080 bytes downloaded
[22:15:21] Initial: 99A6; + 696320 bytes downloaded
[22:15:21] Initial: 06B2; + 706560 bytes downloaded
[22:15:21] Initial: 445D; + 716800 bytes downloaded
[22:15:21] Initial: 62C1; + 727040 bytes downloaded
[22:15:21] Initial: 0E27; + 737280 bytes downloaded
[22:15:22] Initial: EF9A; + 747520 bytes downloaded
[22:15:22] Initial: C105; + 757760 bytes downloaded
[22:15:22] Initial: 46D3; + 768000 bytes downloaded
[22:15:22] Initial: 33C7; + 778240 bytes downloaded
[22:15:23] Initial: 7E92; + 788480 bytes downloaded
[22:15:23] Initial: 24B3; + 795847 bytes downloaded
[22:15:23] Verifying core Core_a1.fah...
[22:15:23] Signature is VALID
[22:15:23]
[22:15:23] Trying to unzip core FahCore_a1.exe
[22:17:23] - Couldn't open file FahCore_a1.exe
[22:17:23] + Error: Could not extract core
[22:17:23] + Core download error (#2), waiting before retry...
[22:17:32] Initial: 1810; + 112640 bytes downloaded
[22:20:11] Initial: 1B3A; + 634880 bytes downloaded
[22:20:11] Initial: E39B; + 645120 bytes downloaded
[22:20:11] Initial: F9FD; + 655360 bytes downloade
[22:20:11] Initial: BFF6; + 665600 bytes downloaded
[22:20:12] Initial: 0552; + 675840 bytes downloaded
[22:20:12] Initial: 14A7; + 686080 bytes downloaded
[22:20:12] Initial: 99A6; + 696320 bytes downloaded
[22:20:12] Initial: 06B2; + 706560 bytes downloaded
[22:20:13] Initial: 445D; + 716800 bytes downloaded
[22:20:13] Initial: 62C1; + 727040 bytes downloaded
[22:20:13] Initial: 0E27; + 737280 bytes downloaded
[22:20:13] Initial: EF9A; + 747520 bytes downloaded
[22:20:13] Initial: C105; + 757760 bytes downloaded
[22:20:13] Initial: 46D3; + 768000 bytes downloade
[22:20:13] Initial: 33C7; + 778240 bytes downloaded
[22:20:13] Initial: 7E92; + 788480 bytes downloaded
[22:20:14] Initial: 24B3; + 795847 bytes downloaded
[22:20:14] Verifying core Core_a1.fah...
[22:20:14] Signature is VALID
[22:20:14]
[22:20:14] Trying to unzip core FahCore_a1.exe
[22:22:14] - Couldn't open file FahCore_a1.exe
[22:22:14] + Error: Could not extract core
[22:22:14] + Core download error (#4), waiting before retry...
[22:22:42] + Downloading new core: FahCore_a1.exe
[22:22:42] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[22:22:43] Initial: AFDE; + 10240 bytes downloaded
[22:22:43] Initial: 10F0; + 20480 bytes downloaded
[22:22:43] Initial: DB70; + 30720 bytes downloaded
[22:22:44] Initial: 865E; + 40960 bytes downloaded
[22:22:44] Initial: 8F87; + 51200 bytes downloaded
[22:22:44] Initial: C48B; + 61440 bytes downloaded
[22:22:44] Initial: 92B3; + 71680 bytes downloaded
[22:22:44] Initial: C102; + 81920 bytes downloaded
[22:22:44] Initial: 1996; + 92160 bytes downloaded
[22:22:44] Initial: BFFE; + 102400 bytes downloaded
[22:22:44] Initial: 1810; + 112640 bytes downloaded
[22:22:45] Initial: 0626; + 122880 bytes downloaded
[22:22:45] Initial: 7B53; + 133120 bytes downloaded
[22:22:45] Initial: 0441; + 143360 bytes downloaded
[22:22:45] Initial: FECE; + 153600 bytes downloaded
[22:22:46] Initial: D346; + 163840 bytes downloaded
[22:22:46] Initial: 2DE8; + 174080 bytes downloaded
[22:22:46] Initial: B3F0; + 184320 bytes downloaded
[22:22:46] Initial: 2881; + 194560 bytes downloaded
[22:22:46] Initial: 9507; + 204800 bytes downloaded
[22:22:46] Initial: 1BAF; + 215040 bytes downloaded
[22:22:46] Initial: 717C; + 225280 bytes downloaded
[22:22:46] Initial: 23FD; + 235520 bytes downloaded
[22:22:46] Initial: 915F; + 245760 bytes downloaded
[22:22:47] Initial: CE52; + 256000 bytes downloaded
[22:22:47] Initial: ED88; + 266240 bytes downloaded
[22:22:47] Initial: 2579; + 276480 bytes downloaded
[22:22:47] Initial: 3396; + 286720 bytes downloaded
[22:22:47] Initial: 410C; + 296960 bytes downloaded
[22:22:48] Initial: 56D1; + 307200 bytes downloaded
[22:22:48] Initial: 1EBD; + 317440 bytes downloaded
[22:22:48] Initial: 6AD9; + 327680 bytes downloaded
[22:22:49] Initial: F931; + 337920 bytes downloaded
[22:22:49] Initial: 1C40; + 348160 bytes downloaded
[22:22:49] Initial: C4AE; + 358400 bytes downloaded
[22:22:49] Initial: 57E4; + 368640 bytes downloaded
[22:22:49] Initial: 1843; + 378880 bytes downloaded
[22:22:49] Initial: B0C0; + 389120 bytes downloaded
[22:22:50] Initial: AAAA; + 399360 bytes downloaded
[22:22:50] Initial: D737; + 409600 bytes downloaded
[22:22:50] Initial: 762A; + 419840 bytes downloaded
[22:22:50] Initial: 8685; + 430080 bytes downloaded
[22:22:50] Initial: 25B1; + 440320 bytes downloaded
[22:22:50] Initial: 44F1; + 450560 bytes downloaded
[22:22:50] Initial: EF81; + 460800 bytes downloaded
[22:22:50] Initial: 900E; + 471040 bytes downloaded
[22:22:51] Initial: 906E; + 481280 bytes downloaded
[22:22:51] Initial: D59F; + 491520 bytes downloaded
[22:22:51] Initial: 2406; + 501760 bytes downloaded
[22:22:51] Initial: 9777; + 512000 bytes downloaded
[22:22:51] Initial: 7783; + 522240 bytes downloaded
[22:22:51] Initial: AEC5; + 532480 bytes downloaded
[22:22:52] Initial: B8A1; + 542720 bytes downloaded
[22:22:52] Initial: D50E; + 552960 bytes downloaded
[22:22:52] Initial: BDEE; + 563200 bytes downloaded
[22:22:52] Initial: E433; + 573440 bytes downloaded
[22:22:52] Initial: 667A; + 583680 bytes downloaded
[22:22:52] Initial: C413; + 593920 bytes downloaded
[22:22:53] Initial: DB64; + 604160 bytes downloaded
[22:22:53] Initial: 313C; + 614400 bytes downloaded
[22:22:53] Initial: 4B8A; + 624640 bytes downloaded
[22:22:53] Initial: 1B3A; + 634880 bytes downloaded
[22:22:53] Initial: E39B; + 645120 bytes downloaded
[22:22:53] Initial: F9FD; + 655360 bytes downloaded
[22:22:53] Initial: BFF6; + 665600 bytes downloaded
[22:22:53] Initial: 0552; + 675840 bytes downloaded
[22:22:53] Initial: 14A7; + 686080 bytes downloaded
[22:22:54] Initial: 99A6; + 696320 bytes downloaded
[22:22:54] Initial: 06B2; + 706560 bytes downloaded
[22:22:54] Initial: 445D; + 716800 bytes downloaded
[22:22:54] Initial: 62C1; + 727040 bytes downloaded
[22:22:54] Initial: 0E27; + 737280 bytes downloaded
[22:22:54] Initial: EF9A; + 747520 bytes downloaded
[22:22:54] Initial: C105; + 757760 bytes downloaded
[22:22:54] Initial: 46D3; + 768000 bytes downloaded
[22:22:55] Initial: 33C7; + 778240 bytes downloaded
[22:22:55] Initial: 7E92; + 788480 bytes downloaded
[22:22:55] Initial: 24B3; + 795847 bytes downloaded
[22:22:55] Verifying core Core_a1.fah...
[22:22:55] Signature is VALID
[22:22:55]
[22:22:55] Trying to unzip core FahCore_a1.exe
[22:24:55] - Couldn't open file FahCore_a1.exe
[22:24:55] + Error: Could not extract core
[22:24:55] + Core download error (#5), waiting before retry...
[22:29:28] Initial: 0E27; + 737280 bytes downloaded
[22:29:28] Initial: EF9A; + 747520 bytes downloaded
[22:29:28] Initial: C105; + 757760 bytes downloaded
[22:29:28] Initial: 46D3; + 768000 bytes downloade
[22:29:28] Initial: 33C7; + 778240 bytes downloade
[22:29:28] Initial: 7E92; + 788480 bytes downloaded
[22:29:28] Initial: 24B3; + 795847 bytes downloaded
[22:29:28] Verifying core Core_a1.fah...
[22:29:28] Signature is VALID
[22:29:28]
[22:29:28] Trying to unzip core FahCore_a1.exe
[22:31:28] - Couldn't open file FahCore_a1.exe
[22:31:28] + Error: Could not extract core
[22:31:28] + Core download error (#7), waiting before retry...
[22:34:20] + Downloading new core: FahCore_a1.exe
[22:34:20] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[22:34:21] Initial: AFDE; + 10240 bytes downloaded
[22:34:21] Initial: 10F0; + 20480 bytes downloaded
[22:34:21] Initial: DB70; + 30720 bytes downloaded
[22:34:21] Initial: 865E; + 40960 bytes downloaded
[22:34:21] Initial: 8F87; + 51200 bytes downloaded
[22:34:21] Initial: C48B; + 61440 bytes downloaded
[22:34:22] Initial: 92B3; + 71680 bytes downloaded
[22:34:22] Initial: C102; + 81920 bytes downloaded
[22:34:22] Initial: 1996; + 92160 bytes downloaded
[22:34:22] Initial: BFFE; + 102400 bytes downloaded
[22:34:23] Initial: 1810; + 112640 bytes downloaded
[22:34:23] Initial: 0626; + 122880 bytes downloaded
[22:34:23] Initial: 7B53; + 133120 bytes downloaded
[22:34:23] Initial: 0441; + 143360 bytes downloaded
[22:34:23] Initial: FECE; + 153600 bytes downloaded
[22:34:23] Initial: D346; + 163840 bytes downloaded
[22:34:23] Initial: 2DE8; + 174080 bytes downloaded
[22:34:23] Initial: B3F0; + 184320 bytes downloaded
[22:34:24] Initial: 2881; + 194560 bytes downloaded
[22:34:24] Initial: 9507; + 204800 bytes downloaded
[22:34:24] Initial: 1BAF; + 215040 bytes downloaded
[22:34:24] Initial: 717C; + 225280 bytes downloaded
[22:34:25] Initial: 23FD; + 235520 bytes downloaded
[22:34:25] Initial: 915F; + 245760 bytes downloaded
[22:34:25] Initial: CE52; + 256000 bytes downloaded
[22:34:26] Initial: ED88; + 266240 bytes downloaded
[22:34:26] Initial: 2579; + 276480 bytes downloaded
[22:34:26] Initial: 3396; + 286720 bytes downloaded
[22:34:26] Initial: 410C; + 296960 bytes downloaded
[22:34:26] Initial: 56D1; + 307200 bytes downloaded
[22:34:26] Initial: 1EBD; + 317440 bytes downloaded
[22:34:27] Initial: 6AD9; + 327680 bytes downloaded
[22:34:27] Initial: F931; + 337920 bytes downloaded
[22:34:27] Initial: 1C40; + 348160 bytes downloaded
[22:34:27] Initial: C4AE; + 358400 bytes downloaded
[22:34:27] Initial: 57E4; + 368640 bytes downloaded
[22:34:27] Initial: 1843; + 378880 bytes downloaded
[22:34:27] Initial: B0C0; + 389120 bytes downloaded
[22:34:27] Initial: AAAA; + 399360 bytes downloaded
[22:34:27] Initial: D737; + 409600 bytes downloaded
[22:34:28] Initial: 762A; + 419840 bytes downloaded
[22:34:28] Initial: 8685; + 430080 bytes downloaded
[22:34:28] Initial: 25B1; + 440320 bytes downloaded
[22:34:28] Initial: 44F1; + 450560 bytes downloaded
[22:34:28] Initial: EF81; + 460800 bytes downloaded
[22:34:28] Initial: 900E; + 471040 bytes downloaded
[22:34:28] Initial: 906E; + 481280 bytes downloaded
[22:34:29] Initial: D59F; + 491520 bytes downloaded
[22:34:29] Initial: 2406; + 501760 bytes downloaded
[22:34:29] Initial: 9777; + 512000 bytes downloaded
[22:34:29] Initial: 7783; + 522240 bytes downloaded
[22:34:29] Initial: AEC5; + 532480 bytes downloaded
[22:34:29] Initial: B8A1; + 542720 bytes downloaded
[22:34:30] Initial: D50E; + 552960 bytes downloaded
[22:34:30] Initial: BDEE; + 563200 bytes downloaded
[22:34:30] Initial: E433; + 573440 bytes downloaded
[22:34:30] Initial: 667A; + 583680 bytes downloaded
[22:34:30] Initial: C413; + 593920 bytes downloaded
[22:34:30] Initial: DB64; + 604160 bytes downloaded
[22:34:30] Initial: 313C; + 614400 bytes downloaded
[22:34:30] Initial: 4B8A; + 624640 bytes downloaded
[22:34:30] Initial: 1B3A; + 634880 bytes downloaded
[22:34:31] Initial: E39B; + 645120 bytes downloaded
[22:34:31] Initial: F9FD; + 655360 bytes downloaded
[22:34:31] Initial: BFF6; + 665600 bytes downloaded
[22:34:31] Initial: 0552; + 675840 bytes downloaded
[22:34:31] Initial: 14A7; + 686080 bytes downloaded
[22:34:31] Initial: 99A6; + 696320 bytes downloaded
[22:34:31] Initial: 06B2; + 706560 bytes downloaded
[22:34:31] Initial: 445D; + 716800 bytes downloaded
[22:34:31] Initial: 62C1; + 727040 bytes downloaded
[22:34:32] Initial: 0E27; + 737280 bytes downloaded
[22:34:32] Initial: EF9A; + 747520 bytes downloaded
[22:34:32] Initial: C105; + 757760 bytes downloaded
[22:34:32] Initial: 46D3; + 768000 bytes downloaded
[22:34:33] Initial: 33C7; + 778240 bytes downloaded
[22:34:33] Initial: 7E92; + 788480 bytes downloaded
[22:34:33] Initial: 24B3; + 795847 bytes downloaded
[22:34:33] Verifying core Core_a1.fah...
[22:34:33] Signature is VALID
[22:34:33]
[22:34:33] Trying to unzip core FahCore_a1.exe
[22:36:33] - Couldn't open file FahCore_a1.exe
[22:36:33] + Error: Could not extract core
[22:36:33] + Core download error (#8), waiting before retry...
[22:42:06] + Downloading new core: FahCore_a1.exe
[22:42:06] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[22:42:06] Initial: AFDE; + 10240 bytes downloaded
[22:42:07] Initial: 10F0; + 20480 bytes downloaded
[22:42:07] Initial: DB70; + 30720 bytes downloaded
[22:42:07] Initial: 865E; + 40960 bytes downloaded
[22:42:07] Initial: 8F87; + 51200 bytes downloaded
[22:42:07] Initial: C48B; + 61440 bytes downloaded
[22:42:08] Initial: 92B3; + 71680 bytes downloaded
[22:42:08] Initial: C102; + 81920 bytes downloaded
[22:42:08] Initial: 1996; + 92160 bytes downloaded
[22:42:08] Initial: BFFE; + 102400 bytes downloaded
[22:42:08] Initial: 1810; + 112640 bytes downloaded
[22:42:08] Initial: 0626; + 122880 bytes downloaded
[22:42:08] Initial: 7B53; + 133120 bytes downloaded
[22:42:09] Initial: 0441; + 143360 bytes downloaded
[22:42:09] Initial: FECE; + 153600 bytes downloaded
[22:42:09] Initial: D346; + 163840 bytes downloaded
[22:42:09] Initial: 2DE8; + 174080 bytes downloaded
[22:42:10] Initial: B3F0; + 184320 bytes downloaded
[22:42:10] Initial: 2881; + 194560 bytes downloaded
[22:42:11] Initial: 9507; + 204800 bytes downloaded
[22:42:11] Initial: 1BAF; + 215040 bytes downloaded
[22:42:11] Initial: 717C; + 225280 bytes downloaded
[22:42:11] Initial: 23FD; + 235520 bytes downloaded
[22:42:11] Initial: 915F; + 245760 bytes downloaded
[22:42:11] Initial: CE52; + 256000 bytes downloaded
[22:42:11] Initial: ED88; + 266240 bytes downloaded
[22:42:11] Initial: 2579; + 276480 bytes downloaded
[22:42:11] Initial: 3396; + 286720 bytes downloaded
[22:42:12] Initial: 410C; + 296960 bytes downloaded
[22:42:12] Initial: 56D1; + 307200 bytes downloaded
[22:42:12] Initial: 1EBD; + 317440 bytes downloaded
[22:42:12] Initial: 6AD9; + 327680 bytes downloaded
[22:42:12] Initial: F931; + 337920 bytes downloaded
[22:42:12] Initial: 1C40; + 348160 bytes downloaded
[22:42:12] Initial: C4AE; + 358400 bytes downloaded
[22:42:12] Initial: 57E4; + 368640 bytes downloaded
[22:42:13] Initial: 1843; + 378880 bytes downloaded
[22:42:13] Initial: B0C0; + 389120 bytes downloaded
[22:42:13] Initial: AAAA; + 399360 bytes downloaded
[22:42:13] Initial: D737; + 409600 bytes downloaded
[22:42:13] Initial: 762A; + 419840 bytes downloaded
[22:42:13] Initial: 8685; + 430080 bytes downloaded
[22:42:14] Initial: 25B1; + 440320 bytes downloaded
[22:42:14] Initial: 44F1; + 450560 bytes downloaded
[22:42:14] Initial: EF81; + 460800 bytes downloaded
[22:42:14] Initial: 900E; + 471040 bytes downloaded
[22:42:14] Initial: 906E; + 481280 bytes downloaded
[22:42:14] Initial: D59F; + 491520 bytes downloaded
[22:42:14] Initial: 2406; + 501760 bytes downloaded
[22:42:14] Initial: 9777; + 512000 bytes downloaded
[22:42:15] Initial: 7783; + 522240 bytes downloaded
[22:42:15] Initial: AEC5; + 532480 bytes downloaded
[22:42:15] Initial: B8A1; + 542720 bytes downloaded
[22:42:15] Initial: D50E; + 552960 bytes downloaded
[22:42:15] Initial: BDEE; + 563200 bytes downloaded
[22:42:15] Initial: E433; + 573440 bytes downloaded
[22:42:15] Initial: 667A; + 583680 bytes downloaded
[22:42:15] Initial: C413; + 593920 bytes downloaded
[22:42:15] Initial: DB64; + 604160 bytes downloaded
[22:42:16] Initial: 313C; + 614400 bytes downloaded
[22:42:16] Initial: 4B8A; + 624640 bytes downloaded
[22:42:16] Initial: 1B3A; + 634880 bytes downloaded
[22:42:16] Initial: E39B; + 645120 bytes downloaded
[22:42:16] Initial: F9FD; + 655360 bytes downloaded
[22:42:16] Initial: BFF6; + 665600 bytes downloaded
[22:42:17] Initial: 0552; + 675840 bytes downloaded
[22:42:17] Initial: 14A7; + 686080 bytes downloaded
[22:42:17] Initial: 99A6; + 696320 bytes downloaded
[22:42:17] Initial: 06B2; + 706560 bytes downloaded
[22:42:17] Initial: 445D; + 716800 bytes downloaded
[22:42:17] Initial: 62C1; + 727040 bytes downloaded
[22:42:18] Initial: 0E27; + 737280 bytes downloaded
[22:42:18] Initial: EF9A; + 747520 bytes downloaded
[22:42:18] Initial: C105; + 757760 bytes downloaded
[22:42:18] Initial: 46D3; + 768000 bytes downloaded
[22:42:18] Initial: 33C7; + 778240 bytes downloaded
[22:42:18] Initial: 7E92; + 788480 bytes downloaded
[22:42:18] Initial: 24B3; + 795847 bytes downloaded
[22:42:18] Verifying core Core_a1.fah...
[22:42:18] Signature is VALID
[22:42:18]
[22:42:18] Trying to unzip core FahCore_a1.exe
[22:44:18] - Couldn't open file FahCore_a1.exe
[22:44:18] + Error: Could not extract core
[22:44:18] + Core download error (#9), waiting before retry...
[22:52:15] - Autosending finished units...
[22:52:15] Trying to send all finished work units
[22:52:15] + No unsent completed units remaining.
[22:52:15] - Autosend completed
[22:55:09] + Downloading new core: FahCore_a1.exe
[22:55:09] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[22:55:10] Initial: AFDE; + 10240 bytes downloaded
[22:55:10] Initial: 10F0; + 20480 bytes downloaded
[22:55:11] Initial: DB70; + 30720 bytes downloaded
[22:55:11] Initial: 865E; + 40960 bytes downloaded
[22:55:11] Initial: 8F87; + 51200 bytes downloaded
[22:55:11] Initial: C48B; + 61440 bytes downloaded
[22:55:11] Initial: 92B3; + 71680 bytes downloaded
[22:55:11] Initial: C102; + 81920 bytes downloaded
[22:55:11] Initial: 1996; + 92160 bytes downloaded
[22:55:11] Initial: BFFE; + 102400 bytes downloaded
[22:55:11] Initial: 1810; + 112640 bytes downloaded
[22:55:12] Initial: 0626; + 122880 bytes downloaded
[22:55:12] Initial: 7B53; + 133120 bytes downloaded
[22:55:12] Initial: 0441; + 143360 bytes downloaded
[22:55:12] Initial: FECE; + 153600 bytes downloaded
[22:55:12] Initial: D346; + 163840 bytes downloaded
[22:55:12] Initial: 2DE8; + 174080 bytes downloaded
[22:55:12] Initial: B3F0; + 184320 bytes downloaded
[22:55:12] Initial: 2881; + 194560 bytes downloaded
[22:55:12] Initial: 9507; + 204800 bytes downloaded
[22:55:13] Initial: 1BAF; + 215040 bytes downloaded
[22:55:13] Initial: 717C; + 225280 bytes downloaded
[22:55:13] Initial: 23FD; + 235520 bytes downloaded
[22:55:13] Initial: 915F; + 245760 bytes downloaded
[22:55:13] Initial: CE52; + 256000 bytes downloaded
[22:55:13] Initial: ED88; + 266240 bytes downloaded
[22:55:14] Initial: 2579; + 276480 bytes downloaded
[22:55:14] Initial: 3396; + 286720 bytes downloaded
[22:55:14] Initial: 410C; + 296960 bytes downloaded
[22:55:14] Initial: 56D1; + 307200 bytes downloaded
[22:55:14] Initial: 1EBD; + 317440 bytes downloaded
[22:55:15] Initial: 6AD9; + 327680 bytes downloaded
[22:55:15] Initial: F931; + 337920 bytes downloaded
[22:55:15] Initial: 1C40; + 348160 bytes downloaded
[22:55:15] Initial: C4AE; + 358400 bytes downloaded
[22:55:15] Initial: 57E4; + 368640 bytes downloaded
[22:55:15] Initial: 1843; + 378880 bytes downloaded
[22:55:15] Initial: B0C0; + 389120 bytes downloaded
[22:55:15] Initial: AAAA; + 399360 bytes downloaded
[22:55:15] Initial: D737; + 409600 bytes downloaded
[22:55:15] Initial: 762A; + 419840 bytes downloaded
[22:55:15] Initial: 8685; + 430080 bytes downloaded
[22:55:16] Initial: 25B1; + 440320 bytes downloaded
[22:55:16] Initial: 44F1; + 450560 bytes downloaded
[22:55:16] Initial: EF81; + 460800 bytes downloaded
[22:55:16] Initial: 900E; + 471040 bytes downloaded
[22:55:16] Initial: 906E; + 481280 bytes downloaded
[22:55:16] Initial: D59F; + 491520 bytes downloaded
[22:55:16] Initial: 2406; + 501760 bytes downloaded
[22:55:17] Initial: 9777; + 512000 bytes downloaded
[22:55:17] Initial: 7783; + 522240 bytes downloaded
[22:55:17] Initial: AEC5; + 532480 bytes downloaded
[22:55:17] Initial: B8A1; + 542720 bytes downloaded
[22:55:17] Initial: D50E; + 552960 bytes downloaded
[22:55:17] Initial: BDEE; + 563200 bytes downloaded
[22:55:18] Initial: E433; + 573440 bytes downloaded
[22:55:18] Initial: 667A; + 583680 bytes downloaded
[22:55:18] Initial: C413; + 593920 bytes downloaded
[22:55:18] Initial: DB64; + 604160 bytes downloaded
[22:55:18] Initial: 313C; + 614400 bytes downloaded
[22:55:18] Initial: 4B8A; + 624640 bytes downloaded
[22:55:18] Initial: 1B3A; + 634880 bytes downloaded
[22:55:18] Initial: E39B; + 645120 bytes downloaded
[22:55:18] Initial: F9FD; + 655360 bytes downloaded
[22:55:19] Initial: BFF6; + 665600 bytes downloaded
[22:55:19] Initial: 0552; + 675840 bytes downloaded
[22:55:19] Initial: 14A7; + 686080 bytes downloaded
[22:55:19] Initial: 99A6; + 696320 bytes downloaded
[22:55:19] Initial: 06B2; + 706560 bytes downloaded
[22:55:19] Initial: 445D; + 716800 bytes downloaded
[22:55:19] Initial: 62C1; + 727040 bytes downloaded
[22:55:19] Initial: 0E27; + 737280 bytes downloaded
[22:55:19] Initial: EF9A; + 747520 bytes downloaded
[22:55:20] Initial: C105; + 757760 bytes downloaded
[22:55:20] Initial: 46D3; + 768000 bytes downloaded
[22:55:20] Initial: 33C7; + 778240 bytes downloaded
[22:55:21] Initial: 7E92; + 788480 bytes downloaded
[22:55:21] Initial: 24B3; + 795847 bytes downloaded
[22:55:21] Verifying core Core_a1.fah...
[22:55:21] Signature is VALID
[22:55:21]
[22:55:21] Trying to unzip core FahCore_a1.exe
[22:57:21] - Couldn't open file FahCore_a1.exe
[22:57:21] + Error: Could not extract core
[22:57:21] + Core download error (#10), waiting before retry...
[23:18:48] + Downloading new core: FahCore_a1.exe
[23:18:48] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[23:18:49] Initial: AFDE; + 10240 bytes downloaded
[23:18:49] Initial: 10F0; + 20480 bytes downloaded
[23:18:50] Initial: DB70; + 30720 bytes downloaded
[23:18:50] Initial: 865E; + 40960 bytes downloaded
[23:18:50] Initial: 8F87; + 51200 bytes downloaded
[23:18:50] Initial: C48B; + 61440 bytes downloaded
[23:18:50] Initial: 92B3; + 71680 bytes downloaded
[23:18:50] Initial: C102; + 81920 bytes downloaded
[23:18:50] Initial: 1996; + 92160 bytes downloaded
[23:18:50] Initial: BFFE; + 102400 bytes downloaded
[23:18:50] Initial: 1810; + 112640 bytes downloaded
[23:18:51] Initial: 0626; + 122880 bytes downloaded
[23:18:51] Initial: 7B53; + 133120 bytes downloaded
[23:18:51] Initial: 0441; + 143360 bytes downloaded
[23:18:51] Initial: FECE; + 153600 bytes downloaded
[23:18:51] Initial: D346; + 163840 bytes downloaded
[23:18:52] Initial: 2DE8; + 174080 bytes downloaded
[23:18:52] Initial: B3F0; + 184320 bytes downloaded
[23:18:52] Initial: 2881; + 194560 bytes downloaded
[23:18:52] Initial: 9507; + 204800 bytes downloaded
[23:18:52] Initial: 1BAF; + 215040 bytes downloaded
[23:18:52] Initial: 717C; + 225280 bytes downloaded
[23:18:52] Initial: 23FD; + 235520 bytes downloaded
[23:18:52] Initial: 915F; + 245760 bytes downloaded
[23:18:52] Initial: CE52; + 256000 bytes downloaded
[23:18:53] Initial: ED88; + 266240 bytes downloaded
[23:18:53] Initial: 2579; + 276480 bytes downloaded
[23:18:53] Initial: 3396; + 286720 bytes downloaded
[23:18:53] Initial: 410C; + 296960 bytes downloaded
[23:18:53] Initial: 56D1; + 307200 bytes downloaded
[23:18:53] Initial: 1EBD; + 317440 bytes downloaded
[23:18:53] Initial: 6AD9; + 327680 bytes downloaded
[23:18:53] Initial: F931; + 337920 bytes downloaded
[23:18:53] Initial: 1C40; + 348160 bytes downloaded
[23:18:54] Initial: C4AE; + 358400 bytes downloaded
[23:18:54] Initial: 57E4; + 368640 bytes downloaded
[23:18:54] Initial: 1843; + 378880 bytes downloaded
[23:18:54] Initial: B0C0; + 389120 bytes downloaded
[23:18:54] Initial: AAAA; + 399360 bytes downloaded
[23:18:55] Initial: D737; + 409600 bytes downloaded
[23:18:55] Initial: 762A; + 419840 bytes downloaded
[23:18:55] Initial: 8685; + 430080 bytes downloaded
[23:18:55] Initial: 25B1; + 440320 bytes downloaded
[23:18:55] Initial: 44F1; + 450560 bytes downloaded
[23:18:55] Initial: EF81; + 460800 bytes downloaded
[23:18:55] Initial: 900E; + 471040 bytes downloaded
[23:18:56] Initial: 906E; + 481280 bytes downloaded
[23:18:56] Initial: D59F; + 491520 bytes downloaded
[23:18:56] Initial: 2406; + 501760 bytes downloaded
[23:18:56] Initial: 9777; + 512000 bytes downloaded
[23:18:56] Initial: 7783; + 522240 bytes downloaded
[23:18:56] Initial: AEC5; + 532480 bytes downloaded
[23:18:56] Initial: B8A1; + 542720 bytes downloaded
[23:18:56] Initial: D50E; + 552960 bytes downloaded
[23:18:56] Initial: BDEE; + 563200 bytes downloaded
[23:18:56] Initial: E433; + 573440 bytes downloaded
[23:18:57] Initial: 667A; + 583680 bytes downloaded
[23:18:57] Initial: C413; + 593920 bytes downloaded
[23:18:57] Initial: DB64; + 604160 bytes downloaded
[23:18:57] Initial: 313C; + 614400 bytes downloaded
[23:18:57] Initial: 4B8A; + 624640 bytes downloaded
[23:18:57] Initial: 1B3A; + 634880 bytes downloaded
[23:18:57] Initial: E39B; + 645120 bytes downloaded
[23:18:58] Initial: F9FD; + 655360 bytes downloaded
[23:18:58] Initial: BFF6; + 665600 bytes downloaded
[23:18:58] Initial: 0552; + 675840 bytes downloaded
[23:18:58] Initial: 14A7; + 686080 bytes downloaded
[23:18:58] Initial: 99A6; + 696320 bytes downloaded
[23:18:58] Initial: 06B2; + 706560 bytes downloaded
[23:18:58] Initial: 445D; + 716800 bytes downloaded
[23:18:59] Initial: 62C1; + 727040 bytes downloaded
[23:18:59] Initial: 0E27; + 737280 bytes downloaded
[23:18:59] Initial: EF9A; + 747520 bytes downloaded
[23:18:59] Initial: C105; + 757760 bytes downloaded
[23:18:59] Initial: 46D3; + 768000 bytes downloaded
[23:18:59] Initial: 33C7; + 778240 bytes downloaded
[23:18:59] Initial: 7E92; + 788480 bytes downloaded
[23:18:59] Initial: 24B3; + 795847 bytes downloaded
[23:18:59] Verifying core Core_a1.fah...
[23:18:59] Signature is VALID
[23:18:59]
[23:18:59] Trying to unzip core FahCore_a1.exe
[23:20:59] - Couldn't open file FahCore_a1.exe
[23:20:59] + Error: Could not extract core
[23:20:59] + Core download error (#11), waiting before retry...
[00:03:40] + Downloading new core: FahCore_a1.exe
[00:03:40] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[00:03:41] Initial: AFDE; + 10240 bytes downloaded
[00:03:42] Initial: 10F0; + 20480 bytes downloaded
[00:03:42] Initial: DB70; + 30720 bytes downloaded
[00:03:42] Initial: 865E; + 40960 bytes downloaded
[00:03:42] Initial: 8F87; + 51200 bytes downloaded
[00:03:42] Initial: C48B; + 61440 bytes downloaded
[00:03:42] Initial: 92B3; + 71680 bytes downloaded
[00:03:42] Initial: C102; + 81920 bytes downloaded
[00:03:43] Initial: 1996; + 92160 bytes downloaded
[00:03:43] Initial: BFFE; + 102400 bytes downloaded
[00:03:43] Initial: 1810; + 112640 bytes downloaded
[00:03:44] Initial: 0626; + 122880 bytes downloaded
[00:03:44] Initial: 7B53; + 133120 bytes downloaded
[00:03:44] Initial: 0441; + 143360 bytes downloaded
[00:03:44] Initial: FECE; + 153600 bytes downloaded
[00:03:44] Initial: D346; + 163840 bytes downloaded
[00:03:44] Initial: 2DE8; + 174080 bytes downloaded
[00:03:44] Initial: B3F0; + 184320 bytes downloaded
[00:03:44] Initial: 2881; + 194560 bytes downloaded
[00:03:44] Initial: 9507; + 204800 bytes downloaded
[00:03:45] Initial: 1BAF; + 215040 bytes downloaded
[00:03:45] Initial: 717C; + 225280 bytes downloaded
[00:03:45] Initial: 23FD; + 235520 bytes downloaded
[00:03:45] Initial: 915F; + 245760 bytes downloaded
[00:03:45] Initial: CE52; + 256000 bytes downloaded
[00:03:45] Initial: ED88; + 266240 bytes downloaded
[00:03:45] Initial: 2579; + 276480 bytes downloaded
[00:03:45] Initial: 3396; + 286720 bytes downloaded
[00:03:46] Initial: 410C; + 296960 bytes downloaded
[00:03:46] Initial: 56D1; + 307200 bytes downloaded
[00:03:47] Initial: 1EBD; + 317440 bytes downloaded
[00:03:47] Initial: 6AD9; + 327680 bytes downloaded
[00:03:47] Initial: F931; + 337920 bytes downloaded
[00:03:47] Initial: 1C40; + 348160 bytes downloaded
[00:03:48] Initial: C4AE; + 358400 bytes downloaded
[00:03:48] Initial: 57E4; + 368640 bytes downloaded
[00:03:48] Initial: 1843; + 378880 bytes downloaded
[00:03:48] Initial: B0C0; + 389120 bytes downloaded
[00:03:48] Initial: AAAA; + 399360 bytes downloaded
[00:03:48] Initial: D737; + 409600 bytes downloaded
[00:03:48] Initial: 762A; + 419840 bytes downloaded
[00:03:48] Initial: 8685; + 430080 bytes downloaded
[00:03:49] Initial: 25B1; + 440320 bytes downloaded
[00:03:49] Initial: 44F1; + 450560 bytes downloaded
[00:03:49] Initial: EF81; + 460800 bytes downloaded
[00:03:49] Initial: 900E; + 471040 bytes downloaded
[00:03:49] Initial: 906E; + 481280 bytes downloaded
[00:03:49] Initial: D59F; + 491520 bytes downloaded
[00:03:49] Initial: 2406; + 501760 bytes downloaded
[00:03:49] Initial: 9777; + 512000 bytes downloaded
[00:03:50] Initial: 7783; + 522240 bytes downloaded
[00:03:50] Initial: AEC5; + 532480 bytes downloaded
[00:03:50] Initial: B8A1; + 542720 bytes downloaded
[00:03:50] Initial: D50E; + 552960 bytes downloaded
[00:03:50] Initial: BDEE; + 563200 bytes downloaded
[00:03:51] Initial: E433; + 573440 bytes downloaded
[00:03:51] Initial: 667A; + 583680 bytes downloaded
[00:03:51] Initial: C413; + 593920 bytes downloaded
[00:03:51] Initial: DB64; + 604160 bytes downloaded
[00:03:51] Initial: 313C; + 614400 bytes downloaded
[00:03:51] Initial: 4B8A; + 624640 bytes downloaded
[00:03:51] Initial: 1B3A; + 634880 bytes downloaded
[00:03:51] Initial: E39B; + 645120 bytes downloaded
[00:03:52] Initial: F9FD; + 655360 bytes downloaded
[00:03:52] Initial: BFF6; + 665600 bytes downloaded
[00:03:52] Initial: 0552; + 675840 bytes downloaded
[00:03:52] Initial: 14A7; + 686080 bytes downloaded
[00:03:52] Initial: 99A6; + 696320 bytes downloaded
[00:03:52] Initial: 06B2; + 706560 bytes downloaded
[00:03:52] Initial: 445D; + 716800 bytes downloaded
[00:03:52] Initial: 62C1; + 727040 bytes downloaded
[00:03:52] Initial: 0E27; + 737280 bytes downloaded
[00:03:53] Initial: EF9A; + 747520 bytes downloaded
[00:03:53] Initial: C105; + 757760 bytes downloaded
[00:03:53] Initial: 46D3; + 768000 bytes downloaded
[00:03:53] Initial: 33C7; + 778240 bytes downloaded
[00:03:53] Initial: 7E92; + 788480 bytes downloaded
[00:03:54] Initial: 24B3; + 795847 bytes downloaded
[00:03:54] Verifying core Core_a1.fah...
[00:03:54] Signature is VALID
[00:03:54]
[00:03:54] Trying to unzip core FahCore_a1.exe
[00:05:54] - Couldn't open file FahCore_a1.exe
[00:05:54] + Error: Could not extract core
[00:05:54] + Core download error (#12), waiting before retry...
deleted as its just a repeat
[04:15:24] + Downloading new core: FahCore_a1.exe
[04:15:24] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[04:15:26] Initial: AFDE; + 10240 bytes downloaded
[04:15:26] Initial: 10F0; + 20480 bytes downloaded
[04:15:26] Initial: DB70; + 30720 bytes downloaded
[04:15:26] Initial: 865E; + 40960 bytes downloaded
[04:15:26] Initial: 8F87; + 51200 bytes downloaded
[04:15:26] Initial: C48B; + 61440 bytes downloaded
[04:15:27] Initial: 92B3; + 71680 bytes downloaded
[04:15:27] Initial: C102; + 81920 bytes downloaded
[04:15:27] Initial: 1996; + 92160 bytes downloaded
[04:15:27] Initial: BFFE; + 102400 bytes downloaded
[04:15:27] Initial: 1810; + 112640 bytes downloaded
[04:15:27] Initial: 0626; + 122880 bytes downloaded
[04:15:28] Initial: 7B53; + 133120 bytes downloaded
[04:15:28] Initial: 0441; + 143360 bytes downloaded
[04:15:28] Initial: FECE; + 153600 bytes downloaded
[04:15:28] Initial: D346; + 163840 bytes downloaded
[04:15:28] Initial: 2DE8; + 174080 bytes downloaded
[04:15:28] Initial: B3F0; + 184320 bytes downloaded
[04:15:28] Initial: 2881; + 194560 bytes downloaded
[04:15:28] Initial: 9507; + 204800 bytes downloaded
[04:15:28] Initial: 1BAF; + 215040 bytes downloaded
[04:15:29] Initial: 717C; + 225280 bytes downloaded
[04:15:29] Initial: 23FD; + 235520 bytes downloaded
[04:15:29] Initial: 915F; + 245760 bytes downloaded
[04:15:29] Initial: CE52; + 256000 bytes downloaded
[04:15:29] Initial: ED88; + 266240 bytes downloaded
[04:15:29] Initial: 2579; + 276480 bytes downloaded
[04:15:29] Initial: 3396; + 286720 bytes downloaded
[04:15:29] Initial: 410C; + 296960 bytes downloaded
[04:15:29] Initial: 56D1; + 307200 bytes downloaded
[04:15:30] Initial: 1EBD; + 317440 bytes downloaded
[04:15:30] Initial: 6AD9; + 327680 bytes downloaded
[04:15:30] Initial: F931; + 337920 bytes downloaded
[04:15:30] Initial: 1C40; + 348160 bytes downloaded
[04:15:30] Initial: C4AE; + 358400 bytes downloaded
[04:15:31] Initial: 57E4; + 368640 bytes downloaded
[04:15:31] Initial: 1843; + 378880 bytes downloaded
[04:15:31] Initial: B0C0; + 389120 bytes downloaded
[04:15:31] Initial: AAAA; + 399360 bytes downloaded
[04:15:31] Initial: D737; + 409600 bytes downloaded
[04:15:31] Initial: 762A; + 419840 bytes downloaded
[04:15:31] Initial: 8685; + 430080 bytes downloaded
[04:15:32] Initial: 25B1; + 440320 bytes downloaded
[04:15:32] Initial: 44F1; + 450560 bytes downloaded
[04:15:32] Initial: EF81; + 460800 bytes downloaded
[04:15:32] Initial: 900E; + 471040 bytes downloaded
[04:15:32] Initial: 906E; + 481280 bytes downloaded
[04:15:32] Initial: D59F; + 491520 bytes downloaded
[04:15:32] Initial: 2406; + 501760 bytes downloaded
[04:15:32] Initial: 9777; + 512000 bytes downloaded
[04:15:32] Initial: 7783; + 522240 bytes downloaded
[04:15:33] Initial: AEC5; + 532480 bytes downloaded
[04:15:33] Initial: B8A1; + 542720 bytes downloaded
[04:15:33] Initial: D50E; + 552960 bytes downloaded
[04:15:33] Initial: BDEE; + 563200 bytes downloaded
[04:15:33] Initial: E433; + 573440 bytes downloaded
[04:15:33] Initial: 667A; + 583680 bytes downloaded
[04:15:33] Initial: C413; + 593920 bytes downloaded
[04:15:33] Initial: DB64; + 604160 bytes downloaded
[04:15:34] Initial: 313C; + 614400 bytes downloaded
[04:15:34] Initial: 4B8A; + 624640 bytes downloaded
[04:15:34] Initial: 1B3A; + 634880 bytes downloaded
[04:15:34] Initial: E39B; + 645120 bytes downloaded
[04:15:34] Initial: F9FD; + 655360 bytes downloaded
[04:15:34] Initial: BFF6; + 665600 bytes downloaded
[04:15:35] Initial: 0552; + 675840 bytes downloaded
[04:15:35] Initial: 14A7; + 686080 bytes downloaded
[04:15:35] Initial: 99A6; + 696320 bytes downloaded
[04:15:35] Initial: 06B2; + 706560 bytes downloaded
[04:15:35] Initial: 445D; + 716800 bytes downloaded
[04:15:35] Initial: 62C1; + 727040 bytes downloaded
[04:15:35] Initial: 0E27; + 737280 bytes downloaded
[04:15:35] Initial: EF9A; + 747520 bytes downloaded
[04:15:35] Initial: C105; + 757760 bytes downloaded
[04:15:35] Initial: 46D3; + 768000 bytes downloaded
[04:15:35] Initial: 33C7; + 778240 bytes downloaded
[04:15:38] Initial: 7E92; + 788480 bytes downloaded
[04:15:38] Initial: 24B3; + 795847 bytes downloaded
[04:15:38] Verifying core Core_a1.fah...
[04:15:38] Signature is VALID
[04:15:38]
[04:15:38] Trying to unzip core FahCore_a1.exe
[04:17:38] - Couldn't open file FahCore_a1.exe
[04:17:38] + Error: Could not extract core
[04:17:38] + Core download error (#17), waiting before retry...
[04:52:15] - Autosending finished units...
[04:52:15] Trying to send all finished work units
[04:52:15] + No unsent completed units remaining.
[04:52:15] - Autosend completed
[05:05:52] + Downloading new core: FahCore_a1.exe
[05:05:52] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[05:05:53] Initial: AFDE; + 10240 bytes downloaded
[05:05:54] Initial: 10F0; + 20480 bytes downloaded
[05:05:54] Initial: DB70; + 30720 bytes downloaded
[05:05:54] Initial: 865E; + 40960 bytes downloaded
[05:05:54] Initial: 8F87; + 51200 bytes downloaded
[05:05:54] Initial: C48B; + 61440 bytes downloaded
[05:05:55] Initial: 92B3; + 71680 bytes downloaded
[05:05:55] Initial: C102; + 81920 bytes downloaded
[05:05:55] Initial: 1996; + 92160 bytes downloaded
[05:05:55] Initial: BFFE; + 102400 bytes downloaded
[05:05:55] Initial: 1810; + 112640 bytes downloaded
[05:05:55] Initial: 0626; + 122880 bytes downloaded
[05:05:55] Initial: 7B53; + 133120 bytes downloaded
[05:05:55] Initial: 0441; + 143360 bytes downloaded
[05:05:56] Initial: FECE; + 153600 bytes downloaded
[05:05:56] Initial: D346; + 163840 bytes downloaded
[05:05:56] Initial: 2DE8; + 174080 bytes downloaded
[05:05:56] Initial: B3F0; + 184320 bytes downloaded
[05:05:56] Initial: 2881; + 194560 bytes downloaded
[05:05:56] Initial: 9507; + 204800 bytes downloaded
[05:05:56] Initial: 1BAF; + 215040 bytes downloaded
[05:05:56] Initial: 717C; + 225280 bytes downloaded
[05:05:56] Initial: 23FD; + 235520 bytes downloaded
[05:05:57] Initial: 915F; + 245760 bytes downloaded
[05:05:57] Initial: CE52; + 256000 bytes downloaded
[05:05:57] Initial: ED88; + 266240 bytes downloaded
[05:05:57] Initial: 2579; + 276480 bytes downloaded
[05:05:57] Initial: 3396; + 286720 bytes downloaded
[05:05:57] Initial: 410C; + 296960 bytes downloaded
[05:05:57] Initial: 56D1; + 307200 bytes downloaded
[05:05:58] Initial: 1EBD; + 317440 bytes downloaded
[05:05:58] Initial: 6AD9; + 327680 bytes downloaded
[05:05:58] Initial: F931; + 337920 bytes downloaded
[05:05:58] Initial: 1C40; + 348160 bytes downloaded
[05:05:58] Initial: C4AE; + 358400 bytes downloaded
[05:05:59] Initial: 57E4; + 368640 bytes downloaded
[05:05:59] Initial: 1843; + 378880 bytes downloaded
[05:05:59] Initial: B0C0; + 389120 bytes downloaded
[05:05:59] Initial: AAAA; + 399360 bytes downloaded
[05:05:59] Initial: D737; + 409600 bytes downloaded
[05:05:59] Initial: 762A; + 419840 bytes downloaded
[05:05:59] Initial: 8685; + 430080 bytes downloaded
[05:05:59] Initial: 25B1; + 440320 bytes downloaded
[05:06:00] Initial: 44F1; + 450560 bytes downloaded
[05:06:00] Initial: EF81; + 460800 bytes downloaded
[05:06:00] Initial: 900E; + 471040 bytes downloaded
[05:06:00] Initial: 906E; + 481280 bytes downloaded
[05:06:00] Initial: D59F; + 491520 bytes downloaded
[05:06:00] Initial: 2406; + 501760 bytes downloaded
[05:06:00] Initial: 9777; + 512000 bytes downloaded
[05:06:00] Initial: 7783; + 522240 bytes downloaded
[05:06:00] Initial: AEC5; + 532480 bytes downloaded
[05:06:01] Initial: B8A1; + 542720 bytes downloaded
[05:06:01] Initial: D50E; + 552960 bytes downloaded
[05:06:01] Initial: BDEE; + 563200 bytes downloaded
[05:06:01] Initial: E433; + 573440 bytes downloaded
[05:06:01] Initial: 667A; + 583680 bytes downloaded
[05:06:02] Initial: C413; + 593920 bytes downloaded
[05:06:02] Initial: DB64; + 604160 bytes downloaded
[05:06:02] Initial: 313C; + 614400 bytes downloaded
[05:06:02] Initial: 4B8A; + 624640 bytes downloaded
[05:06:02] Initial: 1B3A; + 634880 bytes downloaded
[05:06:02] Initial: E39B; + 645120 bytes downloaded
[05:06:02] Initial: F9FD; + 655360 bytes downloaded
[05:06:02] Initial: BFF6; + 665600 bytes downloaded
[05:06:02] Initial: 0552; + 675840 bytes downloaded
[05:06:02] Initial: 14A7; + 686080 bytes downloaded
[05:06:03] Initial: 99A6; + 696320 bytes downloaded
[05:06:03] Initial: 06B2; + 706560 bytes downloaded
[05:06:03] Initial: 445D; + 716800 bytes downloaded
[05:06:03] Initial: 62C1; + 727040 bytes downloaded
[05:06:03] Initial: 0E27; + 737280 bytes downloaded
[05:06:03] Initial: EF9A; + 747520 bytes downloaded
[05:06:03] Initial: C105; + 757760 bytes downloaded
[05:06:03] Initial: 46D3; + 768000 bytes downloaded
[05:06:04] Initial: 33C7; + 778240 bytes downloaded
[05:06:04] Initial: 7E92; + 788480 bytes downloaded
[05:06:04] Initial: 24B3; + 795847 bytes downloaded
[05:06:04] Verifying core Core_a1.fah...
[05:06:04] Signature is VALID
[05:06:04]
[05:06:04] Trying to unzip core FahCore_a1.exe
[05:08:04] - Couldn't open file FahCore_a1.exe
[05:08:04] + Error: Could not extract core
[05:08:04] + Core download error (#18), waiting before retry...
[05:29:20] Killing all core threads
Folding@Home Client Shutdown at user request.
[05:29:20] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
--- Opening Log file [May 26 05:29:30]
Warning:
use of the flag.
[05:29:30] - Ask before connecting: No
[05:29:30] - User name: keith (Team 46590)
[05:29:30] - User ID: 6B67132427192125
[05:29:30] - Machine ID: 1
[05:29:30]
[05:29:30] Loaded queue successfully.
[05:29:30]
[05:29:30] - Autosending finished units...
[05:29:30] + Processing work unit
[05:29:30] Trying to send all finished work units
[05:29:30] Core required: FahCore_a1.exe
[05:29:30] + No unsent completed units remaining.
[05:29:30] - Autosend completed
[05:29:30] Core found.
[05:29:30] Working on Unit 05 [May 26 05:29:30]
[05:29:30] + Working ...
[05:29:30] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2828 -version 592'
[05:29:32]
[05:29:32] *------------------------------*
[05:29:32] Folding@Home Gromacs SMP Core
[05:29:32] Version 1.76 (February 23, 2008)
[05:29:32]
[05:29:32] Preparing to commence simulation
[05:29:32] - Ensuring status. Please wait.
[05:29:49] - Assembly optimizations manually forced on.
[05:29:49] - Not checking prior termination.
[05:30:11] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[05:30:11]
[05:30:11] Project: 2665 (Run 0, Clone 910, Gen 7)
[05:30:11]
[05:30:15] Assembly optimizations on if available.
[05:30:15] Entering M.D.
[05:30:33] Calling FAH init
[05:30:35] ater
[05:30:35] Writing local files
[05:30:36] rom checkpoint)
[05:30:36] Read checkpoint
[05:30:36] eps (38 percent)
[05:30:36] ter
[05:30:36] Writing local files
[05:30:36] Completed 96587 out of 250000 steps (38 percent)
[05:30:50] Extra SSE boost OK.
[05:38:44] Writing local files
[05:38:44] Completed 97500 out of 250000 steps (39 percent)
[05:53:44] Timered checkpoint triggered.
[06:00:18] Writing local files
[06:00:18] Completed 100000 out of 250000 steps (40 percent)
[06:15:19] Timered checkpoint triggered.
[06:21:46] Writing local files
[06:21:47] Completed 102500 out of 250000 steps (41 percent)
[06:36:47] Timered checkpoint triggered.
[06:41:17] CoreStatus = 63 (99)
[06:41:17] + Error starting Folding@Home core or unexpected system termination of core.
[06:41:22]
[06:41:22] + Processing work unit
[06:41:22] Core required: FahCore_a1.exe
[06:41:22] Core found.
[06:41:22] Working on Unit 05 [May 26 06:41:22]
[06:41:22] + Working ...
[06:41:22] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2828 -version 592'
[06:41:24]
[06:41:24] *------------------------------*
[06:41:24] Folding@Home Gromacs SMP Core
[06:41:24] Version 1.76 (February 23, 2008)
[06:41:24]
[06:41:24] Preparing to commence simulation
[06:41:24] - Ensuring status. Please wait.
[06:41:41] - Assembly optimizations manually forced on.
[06:41:41] - Not checking prior termination.
[06:42:00] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[06:42:01]
[06:42:01] Project: 2665 (Run 0, Clone 910, Gen 7)
[06:42:01]
[06:42:05] Assembly optimizations on if available.
[06:42:05] Entering M.D.
[06:42:25] Calling FAH init
[06:42:27] Read topology
[06:42:27] (Starting from checkpoint)
[06:42:27] Read checkpoint
[06:42:27] teps (41 percent)
[06:42:27] er
[06:42:27] Writing local files
[06:42:27] Completed 104254 out of 250000 steps (41 percent)
[06:42:41] Extra SSE boost OK.
[06:49:43] Writing local files
[06:49:43] Completed 105000 out of 250000 steps (42 percent)
[07:03:20] CoreStatus = 63 (99)
[07:03:20] + Error starting Folding@Home core or unexpected system termination of core.
[07:03:25]
[07:03:25] + Processing work unit
[07:03:25] Core required: FahCore_a1.exe
[07:03:25] Core found.
[07:03:25] Working on Unit 05 [May 26 07:03:25]
[07:03:25] + Working ...
[07:03:25] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2828 -version 592'
[07:03:27]
[07:03:27] *------------------------------*
[07:03:27] Folding@Home Gromacs SMP Core
[07:03:27] Version 1.76 (February 23, 2008)
[07:03:27]
[07:03:27] Preparing to commence simulation
[07:03:27] - Ensuring status. Please wait.
[07:03:44] - Assembly optimizations manually forced on.
[07:03:44] - Not checking prior termination.
[07:04:03] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[07:04:04]
[07:04:04] Project: 2665 (Run 0, Clone 910, Gen 7)
[07:04:04]
[07:04:11] Assembly optimizations on if available.
[07:04:11] Entering M.D.
[07:04:28] Calling FAH init
[07:04:29] Read topology
[07:04:30] ocal files
[07:04:30] rom checkpoint)
[07:04:30] Read checkpoint
[07:04:30] Protein: HGG in water
[07:04:30] Writing local files
[07:04:30] Completed 105000 out of 250000 steps (42 percent)
[07:04:43] Extra SSE boost OK.
[07:19:45] Timered checkpoint triggered.
[07:26:02] Writing local files
[07:26:02] Completed 107500 out of 250000 steps (43 percent)
[07:41:03] Timered checkpoint triggered.
[07:47:19] Writing local files
[07:47:20] Completed 110000 out of 250000 steps (44 percent)
[07:47:28] CoreStatus = 63 (99)
[07:47:28] + Error starting Folding@Home core or unexpected system termination of core.
[07:47:28] - Attempting to download new core...
[07:47:28] + Downloading new core: FahCore_a1.exe
[07:47:28] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[07:47:29] Initial: AFDE; + 10240 bytes downloaded
[07:47:29] Initial: 10F0; + 20480 bytes downloaded
[07:47:29] Initial: DB70; + 30720 bytes downloaded
[07:47:30] Initial: 865E; + 40960 bytes downloaded
[07:47:30] Initial: 8F87; + 51200 bytes downloaded
[07:47:30] Initial: C48B; + 61440 bytes downloaded
[07:47:30] Initial: 92B3; + 71680 bytes downloaded
[07:47:30] Initial: C102; + 81920 bytes downloaded
[07:47:30] Initial: 1996; + 92160 bytes downloaded
[07:47:30] Initial: BFFE; + 102400 bytes downloaded
[07:47:31] Initial: 1810; + 112640 bytes downloaded
[07:47:31] Initial: 0626; + 122880 bytes downloaded
[07:47:31] Initial: 7B53; + 133120 bytes downloaded
[07:47:31] Initial: 0441; + 143360 bytes downloaded
[07:47:32] Initial: FECE; + 153600 bytes downloaded
[07:47:32] Initial: D346; + 163840 bytes downloaded
[07:47:32] Initial: 2DE8; + 174080 bytes downloaded
[07:47:32] Initial: B3F0; + 184320 bytes downloaded
[07:47:32] Initial: 2881; + 194560 bytes downloaded
[07:47:33] Initial: 9507; + 204800 bytes downloaded
[07:47:33] Initial: 1BAF; + 215040 bytes downloaded
[07:47:33] Initial: 717C; + 225280 bytes downloaded
[07:47:33] Initial: 23FD; + 235520 bytes downloaded
[07:47:33] Initial: 915F; + 245760 bytes downloaded
[07:47:33] Initial: CE52; + 256000 bytes downloaded
[07:47:33] Initial: ED88; + 266240 bytes downloaded
[07:47:33] Initial: 2579; + 276480 bytes downloaded
[07:47:34] Initial: 3396; + 286720 bytes downloaded
[07:47:34] Initial: 410C; + 296960 bytes downloaded
[07:47:35] Initial: 56D1; + 307200 bytes downloaded
[07:47:35] Initial: 1EBD; + 317440 bytes downloaded
[07:47:35] Initial: 6AD9; + 327680 bytes downloaded
[07:47:35] Initial: F931; + 337920 bytes downloaded
[07:47:35] Initial: 1C40; + 348160 bytes downloaded
[07:47:35] Initial: C4AE; + 358400 bytes downloaded
[07:47:35] Initial: 57E4; + 368640 bytes downloaded
[07:47:35] Initial: 1843; + 378880 bytes downloaded
[07:47:36] Initial: B0C0; + 389120 bytes downloaded
[07:47:36] Initial: AAAA; + 399360 bytes downloaded
[07:47:36] Initial: D737; + 409600 bytes downloaded
[07:47:36] Initial: 762A; + 419840 bytes downloaded
[07:47:36] Initial: 8685; + 430080 bytes downloaded
[07:47:36] Initial: 25B1; + 440320 bytes downloaded
[07:47:36] Initial: 44F1; + 450560 bytes downloaded
[07:47:36] Initial: EF81; + 460800 bytes downloaded
[07:47:37] Initial: 900E; + 471040 bytes downloaded
[07:47:37] Initial: 906E; + 481280 bytes downloaded
[07:47:37] Initial: D59F; + 491520 bytes downloaded
[07:47:37] Initial: 2406; + 501760 bytes downloaded
[07:47:38] Initial: 9777; + 512000 bytes downloaded
[07:47:38] Initial: 7783; + 522240 bytes downloaded
[07:47:38] Initial: AEC5; + 532480 bytes downloaded
[07:47:38] Initial: B8A1; + 542720 bytes downloaded
[07:47:38] Initial: D50E; + 552960 bytes downloaded
[07:47:38] Initial: BDEE; + 563200 bytes downloaded
[07:47:38] Initial: E433; + 573440 bytes downloaded
[07:47:39] Initial: 667A; + 583680 bytes downloaded
[07:47:39] Initial: C413; + 593920 bytes downloaded
[07:47:39] Initial: DB64; + 604160 bytes downloaded
[07:47:39] Initial: 313C; + 614400 bytes downloaded
[07:47:40] Initial: 4B8A; + 624640 bytes downloaded
[07:47:40] Initial: 1B3A; + 634880 bytes downloaded
[07:47:40] Initial: E39B; + 645120 bytes downloaded
[07:47:41] Initial: F9FD; + 655360 bytes downloaded
[07:47:41] Initial: BFF6; + 665600 bytes downloaded
[07:47:42] Initial: 0552; + 675840 bytes downloaded
[07:47:42] Initial: 14A7; + 686080 bytes downloaded
[07:47:42] Initial: 99A6; + 696320 bytes downloaded
[07:47:42] Initial: 06B2; + 706560 bytes downloaded
[07:47:43] Initial: 445D; + 716800 bytes downloaded
[07:47:43] Initial: 62C1; + 727040 bytes downloaded
[07:47:44] Initial: 0E27; + 737280 bytes downloaded
[07:47:44] Initial: EF9A; + 747520 bytes downloaded
[07:47:45] Initial: C105; + 757760 bytes downloaded
[07:47:45] Initial: 46D3; + 768000 bytes downloaded
[07:47:45] Initial: 33C7; + 778240 bytes downloaded
[07:47:45] Initial: 7E92; + 788480 bytes downloaded
[07:47:45] Initial: 24B3; + 795847 bytes downloaded
[07:47:45] Verifying core Core_a1.fah...
[07:47:46] Signature is VALID
[07:47:46]
[07:47:46] Trying to unzip core FahCore_a1.exe
[07:49:46] - Couldn't open file FahCore_a1.exe
[07:49:46] + Error: Could not extract core
[07:49:46] + Core download error (#2), waiting before retry...
[07:49:52] + Downloading new core: FahCore_a1.exe
[07:49:52] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[07:49:53] Initial: AFDE; + 10240 bytes downloaded
[07:49:53] Initial: 10F0; + 20480 bytes downloaded
[07:49:54] Initial: DB70; + 30720 bytes downloaded
[07:49:54] Initial: 865E; + 40960 bytes downloaded
[07:49:54] Initial: 8F87; + 51200 bytes downloaded
[07:49:54] Initial: C48B; + 61440 bytes downloaded
[07:49:54] Initial: 92B3; + 71680 bytes downloaded
[07:49:54] Initial: C102; + 81920 bytes downloaded
[07:49:55] Initial: 1996; + 92160 bytes downloaded
[07:49:55] Initial: BFFE; + 102400 bytes downloaded
[07:49:55] Initial: 1810; + 112640 bytes downloaded
[07:49:55] Initial: 0626; + 122880 bytes downloaded
[07:49:55] Initial: 7B53; + 133120 bytes downloaded
[07:49:55] Initial: 0441; + 143360 bytes downloaded
[07:49:55] Initial: FECE; + 153600 bytes downloaded
[07:49:55] Initial: D346; + 163840 bytes downloaded
[07:49:56] Initial: 2DE8; + 174080 bytes downloaded
[07:49:56] Initial: B3F0; + 184320 bytes downloaded
[07:49:56] Initial: 2881; + 194560 bytes downloaded
[07:49:56] Initial: 9507; + 204800 bytes downloaded
[07:49:56] Initial: 1BAF; + 215040 bytes downloaded
[07:49:56] Initial: 717C; + 225280 bytes downloaded
[07:49:56] Initial: 23FD; + 235520 bytes downloaded
[07:49:57] Initial: 915F; + 245760 bytes downloaded
[07:49:57] Initial: CE52; + 256000 bytes downloaded
[07:49:57] Initial: ED88; + 266240 bytes downloaded
[07:49:57] Initial: 2579; + 276480 bytes downloaded
[07:49:57] Initial: 3396; + 286720 bytes downloaded
[07:49:57] Initial: 410C; + 296960 bytes downloaded
[07:49:58] Initial: 56D1; + 307200 bytes downloaded
[07:49:58] Initial: 1EBD; + 317440 bytes downloaded
[07:49:58] Initial: 6AD9; + 327680 bytes downloaded
[07:49:58] Initial: F931; + 337920 bytes downloaded
[07:49:58] Initial: 1C40; + 348160 bytes downloaded
[07:49:58] Initial: C4AE; + 358400 bytes downloaded
[07:49:58] Initial: 57E4; + 368640 bytes downloaded
[07:49:58] Initial: 1843; + 378880 bytes downloaded
[07:49:59] Initial: B0C0; + 389120 bytes downloaded
[07:49:59] Initial: AAAA; + 399360 bytes downloaded
[07:49:59] Initial: D737; + 409600 bytes downloaded
[07:49:59] Initial: 762A; + 419840 bytes downloaded
[07:49:59] Initial: 8685; + 430080 bytes downloaded
[07:49:59] Initial: 25B1; + 440320 bytes downloaded
[07:49:59] Initial: 44F1; + 450560 bytes downloaded
[07:49:59] Initial: EF81; + 460800 bytes downloaded
[07:50:00] Initial: 900E; + 471040 bytes downloaded
[07:50:00] Initial: 906E; + 481280 bytes downloaded
[07:50:00] Initial: D59F; + 491520 bytes downloaded
[07:50:00] Initial: 2406; + 501760 bytes downloaded
[07:50:01] Initial: 9777; + 512000 bytes downloaded
[07:50:01] Initial: 7783; + 522240 bytes downloaded
[07:50:01] Initial: AEC5; + 532480 bytes downloaded
[07:50:01] Initial: B8A1; + 542720 bytes downloaded
[07:50:01] Initial: D50E; + 552960 bytes downloaded
[07:50:01] Initial: BDEE; + 563200 bytes downloaded
[07:50:01] Initial: E433; + 573440 bytes downloaded
[07:50:01] Initial: 667A; + 583680 bytes downloaded
[07:50:02] Initial: C413; + 593920 bytes downloaded
[07:50:02] Initial: DB64; + 604160 bytes downloaded
[07:50:02] Initial: 313C; + 614400 bytes downloaded
[07:50:02] Initial: 4B8A; + 624640 bytes downloaded
[07:50:02] Initial: 1B3A; + 634880 bytes downloaded
[07:50:02] Initial: E39B; + 645120 bytes downloaded
[07:50:02] Initial: F9FD; + 655360 bytes downloaded
[07:50:02] Initial: BFF6; + 665600 bytes downloaded
[07:50:03] Initial: 0552; + 675840 bytes downloaded
[07:50:03] Initial: 14A7; + 686080 bytes downloaded
[07:50:03] Initial: 99A6; + 696320 bytes downloaded
[07:50:03] Initial: 06B2; + 706560 bytes downloaded
[07:50:03] Initial: 445D; + 716800 bytes downloaded
[07:50:04] Initial: 62C1; + 727040 bytes downloaded
[07:50:04] Initial: 0E27; + 737280 bytes downloaded
[07:50:04] Initial: EF9A; + 747520 bytes downloaded
[07:50:04] Initial: C105; + 757760 bytes downloaded
[07:50:04] Initial: 46D3; + 768000 bytes downloaded
[07:50:04] Initial: 33C7; + 778240 bytes downloaded
[07:50:04] Initial: 7E92; + 788480 bytes downloaded
[07:50:05] Initial: 24B3; + 795847 bytes downloaded
[07:50:05] Verifying core Core_a1.fah...
[07:50:05] Signature is VALID
[07:50:05]
[07:50:05] Trying to unzip core FahCore_a1.exe
[07:52:05] - Couldn't open file FahCore_a1.exe
[07:52:05] + Error: Could not extract core
[07:52:05] + Core download error (#3), waiting before retry...
[07:52:21] + Downloading new core: FahCore_a1.exe
[07:52:21] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[07:52:24] Initial: AFDE; + 10240 bytes downloaded
[07:52:24] Initial: 10F0; + 20480 bytes downloaded
[07:52:24] Initial: DB70; + 30720 bytes downloaded
[07:52:24] Initial: 865E; + 40960 bytes downloaded
[07:52:24] Initial: 8F87; + 51200 bytes downloaded
[07:52:24] Initial: C48B; + 61440 bytes downloaded
[07:52:25] Initial: 92B3; + 71680 bytes downloaded
[07:52:25] Initial: C102; + 81920 bytes downloaded
[07:52:25] Initial: 1996; + 92160 bytes downloaded
[07:52:25] Initial: BFFE; + 102400 bytes downloaded
[07:52:25] Initial: 1810; + 112640 bytes downloaded
[07:52:25] Initial: 0626; + 122880 bytes downloaded
[07:52:25] Initial: 7B53; + 133120 bytes downloaded
[07:52:25] Initial: 0441; + 143360 bytes downloaded
[07:52:25] Initial: FECE; + 153600 bytes downloaded
[07:52:26] Initial: D346; + 163840 bytes downloaded
[07:52:26] Initial: 2DE8; + 174080 bytes downloaded
[07:52:26] Initial: B3F0; + 184320 bytes downloaded
[07:52:27] Initial: 2881; + 194560 bytes downloaded
[07:52:27] Initial: 9507; + 204800 bytes downloaded
[07:52:27] Initial: 1BAF; + 215040 bytes downloaded
[07:52:27] Initial: 717C; + 225280 bytes downloaded
[07:52:27] Initial: 23FD; + 235520 bytes downloaded
[07:52:27] Initial: 915F; + 245760 bytes downloaded
[07:52:27] Initial: CE52; + 256000 bytes downloaded
[07:52:28] Initial: ED88; + 266240 bytes downloaded
[07:52:28] Initial: 2579; + 276480 bytes downloaded
[07:52:28] Initial: 3396; + 286720 bytes downloaded
[07:52:28] Initial: 410C; + 296960 bytes downloaded
[07:52:28] Initial: 56D1; + 307200 bytes downloaded
[07:52:28] Initial: 1EBD; + 317440 bytes downloaded
[07:52:28] Initial: 6AD9; + 327680 bytes downloaded
[07:52:28] Initial: F931; + 337920 bytes downloaded
[07:52:29] Initial: 1C40; + 348160 bytes downloaded
[07:52:29] Initial: C4AE; + 358400 bytes downloaded
[07:52:29] Initial: 57E4; + 368640 bytes downloaded
[07:52:29] Initial: 1843; + 378880 bytes downloaded
[07:52:29] Initial: B0C0; + 389120 bytes downloaded
[07:52:29] Initial: AAAA; + 399360 bytes downloaded
[07:52:29] Initial: D737; + 409600 bytes downloaded
[07:52:30] Initial: 762A; + 419840 bytes downloaded
[07:52:30] Initial: 8685; + 430080 bytes downloaded
[07:52:30] Initial: 25B1; + 440320 bytes downloaded
[07:52:30] Initial: 44F1; + 450560 bytes downloaded
[07:52:30] Initial: EF81; + 460800 bytes downloaded
[07:52:30] Initial: 900E; + 471040 bytes downloaded
[07:52:31] Initial: 906E; + 481280 bytes downloaded
[07:52:31] Initial: D59F; + 491520 bytes downloaded
[07:52:31] Initial: 2406; + 501760 bytes downloaded
[07:52:31] Initial: 9777; + 512000 bytes downloaded
[07:52:31] Initial: 7783; + 522240 bytes downloaded
[07:52:31] Initial: AEC5; + 532480 bytes downloaded
[07:52:31] Initial: B8A1; + 542720 bytes downloaded
[07:52:31] Initial: D50E; + 552960 bytes downloaded
[07:52:32] Initial: BDEE; + 563200 bytes downloaded
[07:52:32] Initial: E433; + 573440 bytes downloaded
[07:52:32] Initial: 667A; + 583680 bytes downloaded
[07:52:32] Initial: C413; + 593920 bytes downloaded
[07:52:32] Initial: DB64; + 604160 bytes downloaded
[07:52:32] Initial: 313C; + 614400 bytes downloaded
[07:52:32] Initial: 4B8A; + 624640 bytes downloaded
[07:52:33] Initial: 1B3A; + 634880 bytes downloaded
[07:52:33] Initial: E39B; + 645120 bytes downloaded
[07:52:33] Initial: F9FD; + 655360 bytes downloaded
[07:52:33] Initial: BFF6; + 665600 bytes downloaded
[07:52:34] Initial: 0552; + 675840 bytes downloaded
[07:52:34] Initial: 14A7; + 686080 bytes downloaded
[07:52:34] Initial: 99A6; + 696320 bytes downloaded
[07:52:34] Initial: 06B2; + 706560 bytes downloaded
[07:52:34] Initial: 445D; + 716800 bytes downloaded
[07:52:34] Initial: 62C1; + 727040 bytes downloaded
[07:52:34] Initial: 0E27; + 737280 bytes downloaded
[07:52:34] Initial: EF9A; + 747520 bytes downloaded
[07:52:35] Initial: C105; + 757760 bytes downloaded
[07:52:35] Initial: 46D3; + 768000 bytes downloaded
[07:52:35] Initial: 33C7; + 778240 bytes downloaded
[07:52:35] Initial: 7E92; + 788480 bytes downloaded
[07:52:35] Initial: 24B3; + 795847 bytes downloaded
[07:52:35] Verifying core Core_a1.fah...
[07:52:35] Signature is VALID
[07:52:35]
[07:52:35] Trying to unzip core FahCore_a1.exe
[07:54:35] - Couldn't open file FahCore_a1.exe
[07:54:35] + Error: Could not extract core
[07:54:35] + Core download error (#4), waiting before retry...
[07:55:06] + Downloading new core: FahCore_a1.exe
[07:55:06] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[07:55:07] Initial: AFDE; + 10240 bytes downloaded
[07:55:07] Initial: 10F0; + 20480 bytes downloaded
[07:55:07] Initial: DB70; + 30720 bytes downloaded
[07:55:08] Initial: 865E; + 40960 bytes downloaded
[07:55:08] Initial: 8F87; + 51200 bytes downloaded
[07:55:08] Initial: C48B; + 61440 bytes downloaded
[07:55:08] Initial: 92B3; + 71680 bytes downloaded
[07:55:08] Initial: C102; + 81920 bytes downloaded
[07:55:08] Initial: 1996; + 92160 bytes downloaded
[07:55:09] Initial: BFFE; + 102400 bytes downloaded
[07:55:09] Initial: 1810; + 112640 bytes downloaded
[07:55:10] Initial: 0626; + 122880 bytes downloaded
[07:55:10] Initial: 7B53; + 133120 bytes downloaded
[07:55:10] Initial: 0441; + 143360 bytes downloaded
[07:55:10] Initial: FECE; + 153600 bytes downloaded
[07:55:11] Initial: D346; + 163840 bytes downloaded
[07:55:11] Initial: 2DE8; + 174080 bytes downloaded
[07:55:11] Initial: B3F0; + 184320 bytes downloaded
[07:55:11] Initial: 2881; + 194560 bytes downloaded
[07:55:11] Initial: 9507; + 204800 bytes downloaded
[07:55:12] Initial: 1BAF; + 215040 bytes downloaded
[07:55:12] Initial: 717C; + 225280 bytes downloaded
[07:55:12] Initial: 23FD; + 235520 bytes downloaded
[07:55:12] Initial: 915F; + 245760 bytes downloaded
[07:55:13] Initial: CE52; + 256000 bytes downloaded
[07:55:13] Initial: ED88; + 266240 bytes downloaded
[07:55:13] Initial: 2579; + 276480 bytes downloaded
[07:55:13] Initial: 3396; + 286720 bytes downloaded
[07:55:13] Initial: 410C; + 296960 bytes downloaded
[07:55:13] Initial: 56D1; + 307200 bytes downloaded
[07:55:14] Initial: 1EBD; + 317440 bytes downloaded
[07:55:14] Initial: 6AD9; + 327680 bytes downloaded
[07:55:14] Initial: F931; + 337920 bytes downloaded
[07:55:15] Initial: 1C40; + 348160 bytes downloaded
[07:55:15] Initial: C4AE; + 358400 bytes downloaded
[07:55:15] Initial: 57E4; + 368640 bytes downloaded
[07:55:15] Initial: 1843; + 378880 bytes downloaded
[07:55:16] Initial: B0C0; + 389120 bytes downloaded
[07:55:16] Initial: AAAA; + 399360 bytes downloaded
[07:55:16] Initial: D737; + 409600 bytes downloaded
[07:55:16] Initial: 762A; + 419840 bytes downloaded
[07:55:16] Initial: 8685; + 430080 bytes downloaded
[07:55:17] Initial: 25B1; + 440320 bytes downloaded
[07:55:17] Initial: 44F1; + 450560 bytes downloaded
[07:55:17] Initial: EF81; + 460800 bytes downloaded
[07:55:17] Initial: 900E; + 471040 bytes downloaded
[07:55:17] Initial: 906E; + 481280 bytes downloaded
[07:55:17] Initial: D59F; + 491520 bytes downloaded
[07:55:17] Initial: 2406; + 501760 bytes downloaded
[07:55:18] Initial: 9777; + 512000 bytes downloaded
[07:55:18] Initial: 7783; + 522240 bytes downloaded
[07:55:18] Initial: AEC5; + 532480 bytes downloaded
[07:55:18] Initial: B8A1; + 542720 bytes downloaded
[07:55:18] Initial: D50E; + 552960 bytes downloaded
[07:55:18] Initial: BDEE; + 563200 bytes downloaded
[07:55:19] Initial: E433; + 573440 bytes downloaded
[07:55:19] Initial: 667A; + 583680 bytes downloaded
[07:55:19] Initial: C413; + 593920 bytes downloaded
[07:55:19] Initial: DB64; + 604160 bytes downloaded
[07:55:20] Initial: 313C; + 614400 bytes downloaded
[07:55:20] Initial: 4B8A; + 624640 bytes downloaded
[07:55:20] Initial: 1B3A; + 634880 bytes downloaded
[07:55:20] Initial: E39B; + 645120 bytes downloaded
[07:55:20] Initial: F9FD; + 655360 bytes downloaded
[07:55:20] Initial: BFF6; + 665600 bytes downloaded
[07:55:20] Initial: 0552; + 675840 bytes downloaded
[07:55:21] Initial: 14A7; + 686080 bytes downloaded
[07:55:21] Initial: 99A6; + 696320 bytes downloaded
[07:55:21] Initial: 06B2; + 706560 bytes downloaded
[07:55:21] Initial: 445D; + 716800 bytes downloaded
[07:55:21] Initial: 62C1; + 727040 bytes downloaded
[07:55:21] Initial: 0E27; + 737280 bytes downloaded
[07:55:21] Initial: EF9A; + 747520 bytes downloaded
[07:55:21] Initial: C105; + 757760 bytes downloaded
[07:55:21] Initial: 46D3; + 768000 bytes downloaded
[07:55:22] Initial: 33C7; + 778240 bytes downloaded
[07:55:22] Initial: 7E92; + 788480 bytes downloaded
[07:55:22] Initial: 24B3; + 795847 bytes downloaded
[07:55:22] Verifying core Core_a1.fah...
[07:55:22] Signature is VALID
[07:55:22]
[07:55:22] Trying to unzip core FahCore_a1.exe
[07:57:22] - Couldn't open file FahCore_a1.exe
[07:57:22] + Error: Could not extract core
[07:57:22] + Core download error (#5), waiting before retry...
[07:58:08] + Downloading new core: FahCore_a1.exe
[07:58:08] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[07:58:09] Initial: AFDE; + 10240 bytes downloaded
[07:58:09] Initial: 10F0; + 20480 bytes downloaded
[07:58:10] Initial: DB70; + 30720 bytes downloaded
[07:58:10] Initial: 865E; + 40960 bytes downloaded
[07:58:10] Initial: 8F87; + 51200 bytes downloaded
[07:58:10] Initial: C48B; + 61440 bytes downloaded
[07:58:10] Initial: 92B3; + 71680 bytes downloaded
[07:58:10] Initial: C102; + 81920 bytes downloaded
[07:58:11] Initial: 1996; + 92160 bytes downloaded
[07:58:11] Initial: BFFE; + 102400 bytes downloaded
[07:58:11] Initial: 1810; + 112640 bytes downloaded
[07:58:11] Initial: 0626; + 122880 bytes downloaded
[07:58:11] Initial: 7B53; + 133120 bytes downloaded
[07:58:12] Initial: 0441; + 143360 bytes downloaded
[07:58:12] Initial: FECE; + 153600 bytes downloaded
[07:58:12] Initial: D346; + 163840 bytes downloaded
[07:58:12] Initial: 2DE8; + 174080 bytes downloaded
[07:58:12] Initial: B3F0; + 184320 bytes downloaded
[07:58:12] Initial: 2881; + 194560 bytes downloaded
[07:58:12] Initial: 9507; + 204800 bytes downloaded
[07:58:13] Initial: 1BAF; + 215040 bytes downloaded
[07:58:13] Initial: 717C; + 225280 bytes downloaded
[07:58:13] Initial: 23FD; + 235520 bytes downloaded
[07:58:13] Initial: 915F; + 245760 bytes downloaded
[07:58:13] Initial: CE52; + 256000 bytes downloaded
[07:58:13] Initial: ED88; + 266240 bytes downloaded
[07:58:13] Initial: 2579; + 276480 bytes downloaded
[07:58:13] Initial: 3396; + 286720 bytes downloaded
[07:58:14] Initial: 410C; + 296960 bytes downloaded
[07:58:14] Initial: 56D1; + 307200 bytes downloaded
[07:58:14] Initial: 1EBD; + 317440 bytes downloaded
[07:58:14] Initial: 6AD9; + 327680 bytes downloaded
[07:58:14] Initial: F931; + 337920 bytes downloaded
[07:58:14] Initial: 1C40; + 348160 bytes downloaded
[07:58:14] Initial: C4AE; + 358400 bytes downloaded
[07:58:15] Initial: 57E4; + 368640 bytes downloaded
[07:58:15] Initial: 1843; + 378880 bytes downloaded
[07:58:15] Initial: B0C0; + 389120 bytes downloaded
[07:58:15] Initial: AAAA; + 399360 bytes downloaded
[07:58:15] Initial: D737; + 409600 bytes downloaded
[07:58:16] Initial: 762A; + 419840 bytes downloaded
[07:58:16] Initial: 8685; + 430080 bytes downloaded
[07:58:16] Initial: 25B1; + 440320 bytes downloaded
[07:58:16] Initial: 44F1; + 450560 bytes downloaded
[07:58:16] Initial: EF81; + 460800 bytes downloaded
[07:58:16] Initial: 900E; + 471040 bytes downloaded
[07:58:16] Initial: 906E; + 481280 bytes downloaded
[07:58:16] Initial: D59F; + 491520 bytes downloaded
[07:58:17] Initial: 2406; + 501760 bytes downloaded
[07:58:17] Initial: 9777; + 512000 bytes downloaded
[07:58:17] Initial: 7783; + 522240 bytes downloaded
[07:58:17] Initial: AEC5; + 532480 bytes downloaded
[07:58:17] Initial: B8A1; + 542720 bytes downloaded
[07:58:17] Initial: D50E; + 552960 bytes downloaded
[07:58:17] Initial: BDEE; + 563200 bytes downloaded
[07:58:17] Initial: E433; + 573440 bytes downloaded
[07:58:18] Initial: 667A; + 583680 bytes downloaded
[07:58:18] Initial: C413; + 593920 bytes downloaded
[07:58:18] Initial: DB64; + 604160 bytes downloaded
[07:58:18] Initial: 313C; + 614400 bytes downloaded
[07:58:19] Initial: 4B8A; + 624640 bytes downloaded
[07:58:19] Initial: 1B3A; + 634880 bytes downloaded
[07:58:19] Initial: E39B; + 645120 bytes downloaded
[07:58:19] Initial: F9FD; + 655360 bytes downloaded
[07:58:19] Initial: BFF6; + 665600 bytes downloaded
[07:58:19] Initial: 0552; + 675840 bytes downloaded
[07:58:19] Initial: 14A7; + 686080 bytes downloaded
[07:58:19] Initial: 99A6; + 696320 bytes downloaded
[07:58:20] Initial: 06B2; + 706560 bytes downloaded
[07:58:20] Initial: 445D; + 716800 bytes downloaded
[07:58:20] Initial: 62C1; + 727040 bytes downloaded
[07:58:20] Initial: 0E27; + 737280 bytes downloaded
[07:58:20] Initial: EF9A; + 747520 bytes downloaded
[07:58:20] Initial: C105; + 757760 bytes downloaded
[07:58:20] Initial: 46D3; + 768000 bytes downloaded
[07:58:20] Initial: 33C7; + 778240 bytes downloaded
[07:58:21] Initial: 7E92; + 788480 bytes downloaded
[07:58:21] Initial: 24B3; + 795847 bytes downloaded
[07:58:21] Verifying core Core_a1.fah...
[07:58:21] Signature is VALID
[07:58:21]
[07:58:21] Trying to unzip core FahCore_a1.exe
[08:00:21] - Couldn't open file FahCore_a1.exe
[08:00:21] + Error: Could not extract core
[08:00:21] + Core download error (#6), waiting before retry...
[08:01:51] + Downloading new core: FahCore_a1.exe
[08:01:51] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[08:01:52] Initial: AFDE; + 10240 bytes downloaded
[08:01:52] Initial: 10F0; + 20480 bytes downloaded
[08:01:52] Initial: DB70; + 30720 bytes downloaded
[08:01:53] Initial: 865E; + 40960 bytes downloaded
[08:01:53] Initial: 8F87; + 51200 bytes downloaded
[08:01:53] Initial: C48B; + 61440 bytes downloaded
[08:01:53] Initial: 92B3; + 71680 bytes downloaded
[08:01:53] Initial: C102; + 81920 bytes downloaded
[08:01:53] Initial: 1996; + 92160 bytes downloaded
[08:01:53] Initial: BFFE; + 102400 bytes downloaded
[08:01:53] Initial: 1810; + 112640 bytes downloaded
[08:01:54] Initial: 0626; + 122880 bytes downloaded
[08:01:54] Initial: 7B53; + 133120 bytes downloaded
[08:01:54] Initial: 0441; + 143360 bytes downloaded
[08:01:54] Initial: FECE; + 153600 bytes downloaded
[08:01:54] Initial: D346; + 163840 bytes downloaded
[08:01:55] Initial: 2DE8; + 174080 bytes downloaded
[08:01:55] Initial: B3F0; + 184320 bytes downloaded
[08:01:55] Initial: 2881; + 194560 bytes downloaded
[08:01:55] Initial: 9507; + 204800 bytes downloaded
[08:01:55] Initial: 1BAF; + 215040 bytes downloaded
[08:01:55] Initial: 717C; + 225280 bytes downloaded
[08:01:55] Initial: 23FD; + 235520 bytes downloaded
[08:01:55] Initial: 915F; + 245760 bytes downloaded
[08:01:55] Initial: CE52; + 256000 bytes downloaded
[08:01:56] Initial: ED88; + 266240 bytes downloaded
[08:01:56] Initial: 2579; + 276480 bytes downloaded
[08:01:56] Initial: 3396; + 286720 bytes downloaded
[08:01:56] Initial: 410C; + 296960 bytes downloaded
[08:01:56] Initial: 56D1; + 307200 bytes downloaded
[08:01:56] Initial: 1EBD; + 317440 bytes downloaded
[08:01:56] Initial: 6AD9; + 327680 bytes downloaded
[08:01:56] Initial: F931; + 337920 bytes downloaded
[08:01:57] Initial: 1C40; + 348160 bytes downloaded
[08:01:57] Initial: C4AE; + 358400 bytes downloaded
[08:01:57] Initial: 57E4; + 368640 bytes downloaded
[08:01:58] Initial: 1843; + 378880 bytes downloaded
[08:01:58] Initial: B0C0; + 389120 bytes downloaded
[08:01:58] Initial: AAAA; + 399360 bytes downloaded
[08:01:58] Initial: D737; + 409600 bytes downloaded
[08:01:58] Initial: 762A; + 419840 bytes downloaded
[08:01:58] Initial: 8685; + 430080 bytes downloaded
[08:01:58] Initial: 25B1; + 440320 bytes downloaded
[08:01:59] Initial: 44F1; + 450560 bytes downloaded
[08:01:59] Initial: EF81; + 460800 bytes downloaded
[08:01:59] Initial: 900E; + 471040 bytes downloaded
[08:01:59] Initial: 906E; + 481280 bytes downloaded
[08:01:59] Initial: D59F; + 491520 bytes downloaded
[08:01:59] Initial: 2406; + 501760 bytes downloaded
[08:01:59] Initial: 9777; + 512000 bytes downloaded
[08:01:59] Initial: 7783; + 522240 bytes downloaded
[08:02:00] Initial: AEC5; + 532480 bytes downloaded
[08:02:00] Initial: B8A1; + 542720 bytes downloaded
[08:02:00] Initial: D50E; + 552960 bytes downloaded
[08:02:00] Initial: BDEE; + 563200 bytes downloaded
[08:02:00] Initial: E433; + 573440 bytes downloaded
[08:02:00] Initial: 667A; + 583680 bytes downloaded
[08:02:00] Initial: C413; + 593920 bytes downloaded
[08:02:01] Initial: DB64; + 604160 bytes downloaded
[08:02:01] Initial: 313C; + 614400 bytes downloaded
[08:02:01] Initial: 4B8A; + 624640 bytes downloaded
[08:02:01] Initial: 1B3A; + 634880 bytes downloaded
[08:02:01] Initial: E39B; + 645120 bytes downloaded
[08:02:02] Initial: F9FD; + 655360 bytes downloaded
[08:02:02] Initial: BFF6; + 665600 bytes downloaded
[08:02:02] Initial: 0552; + 675840 bytes downloaded
[08:02:02] Initial: 14A7; + 686080 bytes downloaded
[08:02:02] Initial: 99A6; + 696320 bytes downloaded
[08:02:02] Initial: 06B2; + 706560 bytes downloaded
[08:02:02] Initial: 445D; + 716800 bytes downloaded
[08:02:03] Initial: 62C1; + 727040 bytes downloaded
[08:02:03] Initial: 0E27; + 737280 bytes downloaded
[08:02:03] Initial: EF9A; + 747520 bytes downloaded
[08:02:03] Initial: C105; + 757760 bytes downloaded
[08:02:04] Initial: 46D3; + 768000 bytes downloaded
[08:02:04] Initial: 33C7; + 778240 bytes downloaded
[08:02:05] Initial: 7E92; + 788480 bytes downloaded
[08:02:05] Initial: 24B3; + 795847 bytes downloaded
[08:02:05] Verifying core Core_a1.fah...
[08:02:05] Signature is VALID
[08:02:05]
[08:02:05] Trying to unzip core FahCore_a1.exe
[08:04:05] - Couldn't open file FahCore_a1.exe
[08:04:05] + Error: Could not extract core
[08:04:05] + Core download error (#7), waiting before retry...
[08:06:56] + Downloading new core: FahCore_a1.exe
[08:06:56] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[08:06:57] Initial: AFDE; + 10240 bytes downloaded
[08:06:58] Initial: 10F0; + 20480 bytes downloaded
[08:06:58] Initial: DB70; + 30720 bytes downloaded
[08:06:58] Initial: 865E; + 40960 bytes downloaded
[08:06:58] Initial: 8F87; + 51200 bytes downloaded
[08:06:58] Initial: C48B; + 61440 bytes downloaded
[08:06:58] Initial: 92B3; + 71680 bytes downloaded
[08:06:58] Initial: C102; + 81920 bytes downloaded
[08:06:59] Initial: 1996; + 92160 bytes downloaded
[08:06:59] Initial: BFFE; + 102400 bytes downloaded
[08:06:59] Initial: 1810; + 112640 bytes downloaded
[08:06:59] Initial: 0626; + 122880 bytes downloaded
[08:06:59] Initial: 7B53; + 133120 bytes downloaded
[08:07:00] Initial: 0441; + 143360 bytes downloaded
[08:07:00] Initial: FECE; + 153600 bytes downloaded
[08:07:00] Initial: D346; + 163840 bytes downloaded
[08:07:00] Initial: 2DE8; + 174080 bytes downloaded
[08:07:00] Initial: B3F0; + 184320 bytes downloaded
[08:07:01] Initial: 2881; + 194560 bytes downloaded
[08:07:01] Initial: 9507; + 204800 bytes downloaded
[08:07:01] Initial: 1BAF; + 215040 bytes downloaded
[08:07:01] Initial: 717C; + 225280 bytes downloaded
[08:07:01] Initial: 23FD; + 235520 bytes downloaded
[08:07:01] Initial: 915F; + 245760 bytes downloaded
[08:07:02] Initial: CE52; + 256000 bytes downloaded
[08:07:02] Initial: ED88; + 266240 bytes downloaded
[08:07:02] Initial: 2579; + 276480 bytes downloaded
[08:07:02] Initial: 3396; + 286720 bytes downloaded
[08:07:02] Initial: 410C; + 296960 bytes downloaded
[08:07:02] Initial: 56D1; + 307200 bytes downloaded
[08:07:02] Initial: 1EBD; + 317440 bytes downloaded
[08:07:03] Initial: 6AD9; + 327680 bytes downloaded
[08:07:03] Initial: F931; + 337920 bytes downloaded
[08:07:03] Initial: 1C40; + 348160 bytes downloaded
[08:07:03] Initial: C4AE; + 358400 bytes downloaded
[08:07:04] Initial: 57E4; + 368640 bytes downloaded
[08:07:04] Initial: 1843; + 378880 bytes downloaded
[08:07:04] Initial: B0C0; + 389120 bytes downloaded
[08:07:04] Initial: AAAA; + 399360 bytes downloaded
[08:07:04] Initial: D737; + 409600 bytes downloaded
[08:07:04] Initial: 762A; + 419840 bytes downloaded
[08:07:04] Initial: 8685; + 430080 bytes downloaded
[08:07:04] Initial: 25B1; + 440320 bytes downloaded
[08:07:04] Initial: 44F1; + 450560 bytes downloaded
[08:07:05] Initial: EF81; + 460800 bytes downloaded
[08:07:05] Initial: 900E; + 471040 bytes downloaded
[08:07:05] Initial: 906E; + 481280 bytes downloaded
[08:07:05] Initial: D59F; + 491520 bytes downloaded
[08:07:05] Initial: 2406; + 501760 bytes downloaded
[08:07:05] Initial: 9777; + 512000 bytes downloaded
[08:07:05] Initial: 7783; + 522240 bytes downloaded
[08:07:05] Initial: AEC5; + 532480 bytes downloaded
[08:07:06] Initial: B8A1; + 542720 bytes downloaded
[08:07:06] Initial: D50E; + 552960 bytes downloaded
[08:07:06] Initial: BDEE; + 563200 bytes downloaded
[08:07:06] Initial: E433; + 573440 bytes downloaded
[08:07:07] Initial: 667A; + 583680 bytes downloaded
[08:07:07] Initial: C413; + 593920 bytes downloaded
[08:07:07] Initial: DB64; + 604160 bytes downloaded
[08:07:07] Initial: 313C; + 614400 bytes downloaded
[08:07:07] Initial: 4B8A; + 624640 bytes downloaded
[08:07:07] Initial: 1B3A; + 634880 bytes downloaded
[08:07:07] Initial: E39B; + 645120 bytes downloaded
[08:07:07] Initial: F9FD; + 655360 bytes downloaded
[08:07:08] Initial: BFF6; + 665600 bytes downloaded
[08:07:08] Initial: 0552; + 675840 bytes downloaded
[08:07:08] Initial: 14A7; + 686080 bytes downloaded
[08:07:08] Initial: 99A6; + 696320 bytes downloaded
[08:07:08] Initial: 06B2; + 706560 bytes downloaded
[08:07:08] Initial: 445D; + 716800 bytes downloaded
[08:07:09] Initial: 62C1; + 727040 bytes downloaded
[08:07:09] Initial: 0E27; + 737280 bytes downloaded
[08:07:10] Initial: EF9A; + 747520 bytes downloaded
[08:07:11] Initial: C105; + 757760 bytes downloaded
[08:07:11] Initial: 46D3; + 768000 bytes downloaded
[08:07:11] Initial: 33C7; + 778240 bytes downloaded
[08:07:11] Initial: 7E92; + 788480 bytes downloaded
[08:07:12] Initial: 24B3; + 795847 bytes downloaded
[08:07:12] Verifying core Core_a1.fah...
[08:07:12] Signature is VALID
[08:07:12]
[08:07:12] Trying to unzip core FahCore_a1.exe
[08:09:12] - Couldn't open file FahCore_a1.exe
[08:09:12] + Error: Could not extract core
[08:09:12] + Core download error (#8), waiting before retry...
[08:14:46] + Downloading new core: FahCore_a1.exe
[08:14:46] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[08:14:48] Initial: AFDE; + 10240 bytes downloaded
[08:14:48] Initial: 10F0; + 20480 bytes downloaded
[08:14:48] Initial: DB70; + 30720 bytes downloaded
[08:14:48] Initial: 865E; + 40960 bytes downloaded
[08:14:49] Initial: 8F87; + 51200 bytes downloaded
[08:14:49] Initial: C48B; + 61440 bytes downloaded
[08:14:49] Initial: 92B3; + 71680 bytes downloaded
[08:14:49] Initial: C102; + 81920 bytes downloaded
[08:14:49] Initial: 1996; + 92160 bytes downloaded
[08:14:49] Initial: BFFE; + 102400 bytes downloaded
[08:14:49] Initial: 1810; + 112640 bytes downloaded
[08:14:50] Initial: 0626; + 122880 bytes downloaded
[08:14:50] Initial: 7B53; + 133120 bytes downloaded
[08:14:50] Initial: 0441; + 143360 bytes downloaded
[08:14:50] Initial: FECE; + 153600 bytes downloaded
[08:14:50] Initial: D346; + 163840 bytes downloaded
[08:14:50] Initial: 2DE8; + 174080 bytes downloaded
[08:14:50] Initial: B3F0; + 184320 bytes downloaded
[08:14:51] Initial: 2881; + 194560 bytes downloaded
[08:14:51] Initial: 9507; + 204800 bytes downloaded
[08:14:51] Initial: 1BAF; + 215040 bytes downloaded
[08:14:51] Initial: 717C; + 225280 bytes downloaded
[08:14:51] Initial: 23FD; + 235520 bytes downloaded
[08:14:51] Initial: 915F; + 245760 bytes downloaded
[08:14:52] Initial: CE52; + 256000 bytes downloaded
[08:14:52] Initial: ED88; + 266240 bytes downloaded
[08:14:52] Initial: 2579; + 276480 bytes downloaded
[08:14:52] Initial: 3396; + 286720 bytes downloaded
[08:14:52] Initial: 410C; + 296960 bytes downloaded
[08:14:52] Initial: 56D1; + 307200 bytes downloaded
[08:14:53] Initial: 1EBD; + 317440 bytes downloaded
[08:14:53] Initial: 6AD9; + 327680 bytes downloaded
[08:14:53] Initial: F931; + 337920 bytes downloaded
[08:14:54] Initial: 1C40; + 348160 bytes downloaded
[08:14:54] Initial: C4AE; + 358400 bytes downloaded
[08:14:55] Initial: 57E4; + 368640 bytes downloaded
[08:14:55] Initial: 1843; + 378880 bytes downloaded
[08:14:55] Initial: B0C0; + 389120 bytes downloaded
[08:14:55] Initial: AAAA; + 399360 bytes downloaded
[08:14:55] Initial: D737; + 409600 bytes downloaded
[08:14:55] Initial: 762A; + 419840 bytes downloaded
[08:14:55] Initial: 8685; + 430080 bytes downloaded
[08:14:56] Initial: 25B1; + 440320 bytes downloaded
[08:14:56] Initial: 44F1; + 450560 bytes downloaded
[08:14:56] Initial: EF81; + 460800 bytes downloaded
[08:14:56] Initial: 900E; + 471040 bytes downloaded
[08:14:56] Initial: 906E; + 481280 bytes downloaded
[08:14:56] Initial: D59F; + 491520 bytes downloaded
[08:14:56] Initial: 2406; + 501760 bytes downloaded
[08:14:56] Initial: 9777; + 512000 bytes downloaded
[08:14:57] Initial: 7783; + 522240 bytes downloaded
[08:14:57] Initial: AEC5; + 532480 bytes downloaded
[08:14:57] Initial: B8A1; + 542720 bytes downloaded
[08:14:57] Initial: D50E; + 552960 bytes downloaded
[08:14:57] Initial: BDEE; + 563200 bytes downloaded
[08:14:58] Initial: E433; + 573440 bytes downloaded
[08:14:58] Initial: 667A; + 583680 bytes downloaded
[08:14:58] Initial: C413; + 593920 bytes downloaded
[08:14:58] Initial: DB64; + 604160 bytes downloaded
[08:14:58] Initial: 313C; + 614400 bytes downloaded
[08:14:58] Initial: 4B8A; + 624640 bytes downloaded
[08:14:58] Initial: 1B3A; + 634880 bytes downloaded
[08:14:58] Initial: E39B; + 645120 bytes downloaded
[08:14:59] Initial: F9FD; + 655360 bytes downloaded
[08:14:59] Initial: BFF6; + 665600 bytes downloaded
[08:14:59] Initial: 0552; + 675840 bytes downloaded
[08:14:59] Initial: 14A7; + 686080 bytes downloaded
[08:15:00] Initial: 99A6; + 696320 bytes downloaded
[08:15:00] Initial: 06B2; + 706560 bytes downloaded
[08:15:00] Initial: 445D; + 716800 bytes downloaded
[08:15:01] Initial: 62C1; + 727040 bytes downloaded
[08:15:01] Initial: 0E27; + 737280 bytes downloaded
[08:15:01] Initial: EF9A; + 747520 bytes downloaded
[08:15:02] Initial: C105; + 757760 bytes downloaded
[08:15:02] Initial: 46D3; + 768000 bytes downloaded
[08:15:02] Initial: 33C7; + 778240 bytes downloaded
[08:15:02] Initial: 7E92; + 788480 bytes downloaded
[08:15:02] Initial: 24B3; + 795847 bytes downloaded
[08:15:02] Verifying core Core_a1.fah...
[08:15:02] Signature is VALID
[08:15:02]
[08:15:02] Trying to unzip core FahCore_a1.exe
[08:17:02] - Couldn't open file FahCore_a1.exe
[08:17:02] + Error: Could not extract core
[08:17:02] + Core download error (#9), waiting before retry...
[08:27:45] + Downloading new core: FahCore_a1.exe
[08:27:45] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[08:27:47] Initial: AFDE; + 10240 bytes downloaded
[08:27:47] Initial: 10F0; + 20480 bytes downloaded
[08:27:47] Initial: DB70; + 30720 bytes downloaded
[08:27:48] Initial: 865E; + 40960 bytes downloaded
[08:27:48] Initial: 8F87; + 51200 bytes downloaded
[08:27:48] Initial: C48B; + 61440 bytes downloaded
[08:27:48] Initial: 92B3; + 71680 bytes downloaded
[08:27:48] Initial: C102; + 81920 bytes downloaded
[08:27:49] Initial: 1996; + 92160 bytes downloaded
[08:27:49] Initial: BFFE; + 102400 bytes downloaded
[08:27:49] Initial: 1810; + 112640 bytes downloaded
[08:27:49] Initial: 0626; + 122880 bytes downloaded
[08:27:49] Initial: 7B53; + 133120 bytes downloaded
[08:27:49] Initial: 0441; + 143360 bytes downloaded
[08:27:49] Initial: FECE; + 153600 bytes downloaded
[08:27:49] Initial: D346; + 163840 bytes downloaded
[08:27:50] Initial: 2DE8; + 174080 bytes downloaded
[08:27:50] Initial: B3F0; + 184320 bytes downloaded
[08:27:50] Initial: 2881; + 194560 bytes downloaded
[08:27:50] Initial: 9507; + 204800 bytes downloaded
[08:27:50] Initial: 1BAF; + 215040 bytes downloaded
[08:27:50] Initial: 717C; + 225280 bytes downloaded
[08:27:50] Initial: 23FD; + 235520 bytes downloaded
[08:27:50] Initial: 915F; + 245760 bytes downloaded
[08:27:51] Initial: CE52; + 256000 bytes downloaded
[08:27:51] Initial: ED88; + 266240 bytes downloaded
[08:27:51] Initial: 2579; + 276480 bytes downloaded
[08:27:51] Initial: 3396; + 286720 bytes downloaded
[08:27:51] Initial: 410C; + 296960 bytes downloaded
[08:27:52] Initial: 56D1; + 307200 bytes downloaded
[08:27:52] Initial: 1EBD; + 317440 bytes downloaded
[08:27:52] Initial: 6AD9; + 327680 bytes downloaded
[08:27:52] Initial: F931; + 337920 bytes downloaded
[08:27:52] Initial: 1C40; + 348160 bytes downloaded
[08:27:52] Initial: C4AE; + 358400 bytes downloaded
[08:27:52] Initial: 57E4; + 368640 bytes downloaded
[08:27:52] Initial: 1843; + 378880 bytes downloaded
[08:27:52] Initial: B0C0; + 389120 bytes downloaded
[08:27:53] Initial: AAAA; + 399360 bytes downloaded
[08:27:53] Initial: D737; + 409600 bytes downloaded
[08:27:53] Initial: 762A; + 419840 bytes downloaded
[08:27:53] Initial: 8685; + 430080 bytes downloaded
[08:27:53] Initial: 25B1; + 440320 bytes downloaded
[08:27:53] Initial: 44F1; + 450560 bytes downloaded
[08:27:53] Initial: EF81; + 460800 bytes downloaded
[08:27:53] Initial: 900E; + 471040 bytes downloaded
[08:27:54] Initial: 906E; + 481280 bytes downloaded
[08:27:54] Initial: D59F; + 491520 bytes downloaded
[08:27:54] Initial: 2406; + 501760 bytes downloaded
[08:27:54] Initial: 9777; + 512000 bytes downloaded
[08:27:54] Initial: 7783; + 522240 bytes downloaded
[08:27:54] Initial: AEC5; + 532480 bytes downloaded
[08:27:54] Initial: B8A1; + 542720 bytes downloaded
[08:27:55] Initial: D50E; + 552960 bytes downloaded
[08:27:55] Initial: BDEE; + 563200 bytes downloaded
[08:27:55] Initial: E433; + 573440 bytes downloaded
[08:27:55] Initial: 667A; + 583680 bytes downloaded
[08:27:55] Initial: C413; + 593920 bytes downloaded
[08:27:55] Initial: DB64; + 604160 bytes downloaded
[08:27:55] Initial: 313C; + 614400 bytes downloaded
[08:27:55] Initial: 4B8A; + 624640 bytes downloaded
[08:27:56] Initial: 1B3A; + 634880 bytes downloaded
[08:27:56] Initial: E39B; + 645120 bytes downloaded
[08:27:56] Initial: F9FD; + 655360 bytes downloaded
[08:27:56] Initial: BFF6; + 665600 bytes downloaded
[08:27:56] Initial: 0552; + 675840 bytes downloaded
[08:27:56] Initial: 14A7; + 686080 bytes downloaded
[08:27:56] Initial: 99A6; + 696320 bytes downloaded
[08:27:57] Initial: 06B2; + 706560 bytes downloaded
[08:27:57] Initial: 445D; + 716800 bytes downloaded
[08:27:58] Initial: 62C1; + 727040 bytes downloaded
[08:27:58] Initial: 0E27; + 737280 bytes downloaded
[08:27:58] Initial: EF9A; + 747520 bytes downloaded
[08:27:58] Initial: C105; + 757760 bytes downloaded
[08:27:59] Initial: 46D3; + 768000 bytes downloaded
[08:27:59] Initial: 33C7; + 778240 bytes downloaded
[08:27:59] Initial: 7E92; + 788480 bytes downloaded
[08:27:59] Initial: 24B3; + 795847 bytes downloaded
[08:27:59] Verifying core Core_a1.fah...
[08:27:59] Signature is VALID
[08:27:59]
[08:27:59] Trying to unzip core FahCore_a1.exe
[08:29:59] - Couldn't open file FahCore_a1.exe
[08:29:59] + Error: Could not extract core
[08:29:59] + Core download error (#10), waiting before retry...
[08:51:27] + Downloading new core: FahCore_a1.exe
[08:51:27] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[08:51:29] Initial: AFDE; + 10240 bytes downloaded
[08:51:29] Initial: 10F0; + 20480 bytes downloaded
[08:51:29] Initial: DB70; + 30720 bytes downloaded
[08:51:29] Initial: 865E; + 40960 bytes downloaded
[08:51:29] Initial: 8F87; + 51200 bytes downloaded
[08:51:29] Initial: C48B; + 61440 bytes downloaded
[08:51:30] Initial: 92B3; + 71680 bytes downloaded
[08:51:30] Initial: C102; + 81920 bytes downloaded
[08:51:30] Initial: 1996; + 92160 bytes downloaded
[08:51:30] Initial: BFFE; + 102400 bytes downloaded
[08:51:30] Initial: 1810; + 112640 bytes downloaded
[08:51:30] Initial: 0626; + 122880 bytes downloaded
[08:51:30] Initial: 7B53; + 133120 bytes downloaded
[08:51:30] Initial: 0441; + 143360 bytes downloaded
[08:51:30] Initial: FECE; + 153600 bytes downloaded
[08:51:30] Initial: D346; + 163840 bytes downloaded
[08:51:31] Initial: 2DE8; + 174080 bytes downloaded
[08:51:31] Initial: B3F0; + 184320 bytes downloaded
[08:51:31] Initial: 2881; + 194560 bytes downloaded
[08:51:31] Initial: 9507; + 204800 bytes downloaded
[08:51:31] Initial: 1BAF; + 215040 bytes downloaded
[08:51:31] Initial: 717C; + 225280 bytes downloaded
[08:51:31] Initial: 23FD; + 235520 bytes downloaded
[08:51:32] Initial: 915F; + 245760 bytes downloaded
[08:51:32] Initial: CE52; + 256000 bytes downloaded
[08:51:32] Initial: ED88; + 266240 bytes downloaded
[08:51:32] Initial: 2579; + 276480 bytes downloaded
[08:51:33] Initial: 3396; + 286720 bytes downloaded
[08:51:33] Initial: 410C; + 296960 bytes downloaded
[08:51:33] Initial: 56D1; + 307200 bytes downloaded
[08:51:33] Initial: 1EBD; + 317440 bytes downloaded
[08:51:33] Initial: 6AD9; + 327680 bytes downloaded
[08:51:33] Initial: F931; + 337920 bytes downloaded
[08:51:33] Initial: 1C40; + 348160 bytes downloaded
[08:51:34] Initial: C4AE; + 358400 bytes downloaded
[08:51:34] Initial: 57E4; + 368640 bytes downloaded
[08:51:34] Initial: 1843; + 378880 bytes downloaded
[08:51:34] Initial: B0C0; + 389120 bytes downloaded
[08:51:34] Initial: AAAA; + 399360 bytes downloaded
[08:51:34] Initial: D737; + 409600 bytes downloaded
[08:51:34] Initial: 762A; + 419840 bytes downloaded
[08:51:34] Initial: 8685; + 430080 bytes downloaded
[08:51:35] Initial: 25B1; + 440320 bytes downloaded
[08:51:35] Initial: 44F1; + 450560 bytes downloaded
[08:51:35] Initial: EF81; + 460800 bytes downloaded
[08:51:35] Initial: 900E; + 471040 bytes downloaded
[08:51:35] Initial: 906E; + 481280 bytes downloaded
[08:51:36] Initial: D59F; + 491520 bytes downloaded
[08:51:36] Initial: 2406; + 501760 bytes downloaded
[08:51:36] Initial: 9777; + 512000 bytes downloaded
[08:51:36] Initial: 7783; + 522240 bytes downloaded
[08:51:36] Initial: AEC5; + 532480 bytes downloaded
[08:51:36] Initial: B8A1; + 542720 bytes downloaded
[08:51:36] Initial: D50E; + 552960 bytes downloaded
[08:51:37] Initial: BDEE; + 563200 bytes downloaded
[08:51:37] Initial: E433; + 573440 bytes downloaded
[08:51:37] Initial: 667A; + 583680 bytes downloaded
[08:51:37] Initial: C413; + 593920 bytes downloaded
[08:51:37] Initial: DB64; + 604160 bytes downloaded
[08:51:37] Initial: 313C; + 614400 bytes downloaded
[08:51:37] Initial: 4B8A; + 624640 bytes downloaded
[08:51:38] Initial: 1B3A; + 634880 bytes downloaded
[08:51:38] Initial: E39B; + 645120 bytes downloaded
[08:51:38] Initial: F9FD; + 655360 bytes downloaded
[08:51:38] Initial: BFF6; + 665600 bytes downloaded
[08:51:38] Initial: 0552; + 675840 bytes downloaded
[08:51:39] Initial: 14A7; + 686080 bytes downloaded
[08:51:39] Initial: 99A6; + 696320 bytes downloaded
[08:51:39] Initial: 06B2; + 706560 bytes downloaded
[08:51:39] Initial: 445D; + 716800 bytes downloaded
[08:51:39] Initial: 62C1; + 727040 bytes downloaded
[08:51:39] Initial: 0E27; + 737280 bytes downloaded
[08:51:39] Initial: EF9A; + 747520 bytes downloaded
[08:51:39] Initial: C105; + 757760 bytes downloaded
[08:51:40] Initial: 46D3; + 768000 bytes downloaded
[08:51:40] Initial: 33C7; + 778240 bytes downloaded
[08:51:40] Initial: 7E92; + 788480 bytes downloaded
[08:51:40] Initial: 24B3; + 795847 bytes downloaded
[08:51:40] Verifying core Core_a1.fah...
[08:51:40] Signature is VALID
[08:51:40]
[08:51:40] Trying to unzip core FahCore_a1.exe
[08:53:40] - Couldn't open file FahCore_a1.exe
[08:53:40] + Error: Could not extract core
[08:53:40] + Core download error (#11), waiting before retry...
[09:36:26] + Downloading new core: FahCore_a1.exe
[09:36:26] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[09:36:26] Initial: AFDE; + 10240 bytes downloaded
[09:36:27] Initial: 10F0; + 20480 bytes downloaded
[09:36:27] Initial: DB70; + 30720 bytes downloaded
[09:36:27] Initial: 865E; + 40960 bytes downloaded
[09:36:28] Initial: 8F87; + 51200 bytes downloaded
[09:36:28] Initial: C48B; + 61440 bytes downloaded
[09:36:28] Initial: 92B3; + 71680 bytes downloaded
[09:36:28] Initial: C102; + 81920 bytes downloaded
[09:36:28] Initial: 1996; + 92160 bytes downloaded
[09:36:28] Initial: BFFE; + 102400 bytes downloaded
[09:36:28] Initial: 1810; + 112640 bytes downloaded
[09:36:28] Initial: 0626; + 122880 bytes downloaded
[09:36:28] Initial: 7B53; + 133120 bytes downloaded
[09:36:28] Initial: 0441; + 143360 bytes downloaded
[09:36:28] Initial: FECE; + 153600 bytes downloaded
[09:36:29] Initial: D346; + 163840 bytes downloaded
[09:36:29] Initial: 2DE8; + 174080 bytes downloaded
[09:36:29] Initial: B3F0; + 184320 bytes downloaded
[09:36:29] Initial: 2881; + 194560 bytes downloaded
[09:36:29] Initial: 9507; + 204800 bytes downloaded
[09:36:29] Initial: 1BAF; + 215040 bytes downloaded
[09:36:29] Initial: 717C; + 225280 bytes downloaded
[09:36:29] Initial: 23FD; + 235520 bytes downloaded
[09:36:30] Initial: 915F; + 245760 bytes downloaded
[09:36:30] Initial: CE52; + 256000 bytes downloaded
[09:36:30] Initial: ED88; + 266240 bytes downloaded
[09:36:30] Initial: 2579; + 276480 bytes downloaded
[09:36:30] Initial: 3396; + 286720 bytes downloaded
[09:36:30] Initial: 410C; + 296960 bytes downloaded
[09:36:30] Initial: 56D1; + 307200 bytes downloaded
[09:36:31] Initial: 1EBD; + 317440 bytes downloaded
[09:36:31] Initial: 6AD9; + 327680 bytes downloaded
[09:36:31] Initial: F931; + 337920 bytes downloaded
[09:36:31] Initial: 1C40; + 348160 bytes downloaded
[09:36:31] Initial: C4AE; + 358400 bytes downloaded
[09:36:31] Initial: 57E4; + 368640 bytes downloaded
[09:36:32] Initial: 1843; + 378880 bytes downloaded
[09:36:32] Initial: B0C0; + 389120 bytes downloaded
[09:36:32] Initial: AAAA; + 399360 bytes downloaded
[09:36:32] Initial: D737; + 409600 bytes downloaded
[09:36:32] Initial: 762A; + 419840 bytes downloaded
[09:36:32] Initial: 8685; + 430080 bytes downloaded
[09:36:32] Initial: 25B1; + 440320 bytes downloaded
[09:36:32] Initial: 44F1; + 450560 bytes downloaded
[09:36:32] Initial: EF81; + 460800 bytes downloaded
[09:36:32] Initial: 900E; + 471040 bytes downloaded
[09:36:33] Initial: 906E; + 481280 bytes downloaded
[09:36:33] Initial: D59F; + 491520 bytes downloaded
[09:36:33] Initial: 2406; + 501760 bytes downloaded
[09:36:33] Initial: 9777; + 512000 bytes downloaded
[09:36:33] Initial: 7783; + 522240 bytes downloaded
[09:36:33] Initial: AEC5; + 532480 bytes downloaded
[09:36:33] Initial: B8A1; + 542720 bytes downloaded
[09:36:33] Initial: D50E; + 552960 bytes downloaded
[09:36:34] Initial: BDEE; + 563200 bytes downloaded
[09:36:34] Initial: E433; + 573440 bytes downloaded
[09:36:34] Initial: 667A; + 583680 bytes downloaded
[09:36:34] Initial: C413; + 593920 bytes downloaded
[09:36:34] Initial: DB64; + 604160 bytes downloaded
[09:36:35] Initial: 313C; + 614400 bytes downloaded
[09:36:35] Initial: 4B8A; + 624640 bytes downloaded
[09:36:35] Initial: 1B3A; + 634880 bytes downloaded
[09:36:35] Initial: E39B; + 645120 bytes downloaded
[09:36:35] Initial: F9FD; + 655360 bytes downloaded
[09:36:35] Initial: BFF6; + 665600 bytes downloaded
[09:36:35] Initial: 0552; + 675840 bytes downloaded
[09:36:35] Initial: 14A7; + 686080 bytes downloaded
[09:36:35] Initial: 99A6; + 696320 bytes downloaded
[09:36:35] Initial: 06B2; + 706560 bytes downloaded
[09:36:36] Initial: 445D; + 716800 bytes downloaded
[09:36:36] Initial: 62C1; + 727040 bytes downloaded
[09:36:36] Initial: 0E27; + 737280 bytes downloaded
[09:36:36] Initial: EF9A; + 747520 bytes downloaded
[09:36:36] Initial: C105; + 757760 bytes downloaded
[09:36:36] Initial: 46D3; + 768000 bytes downloaded
[09:36:37] Initial: 33C7; + 778240 bytes downloaded
[09:36:37] Initial: 7E92; + 788480 bytes downloaded
[09:36:38] Initial: 24B3; + 795847 bytes downloaded
[09:36:38] Verifying core Core_a1.fah...
[09:36:38] Signature is VALID
[09:36:38]
[09:36:38] Trying to unzip core FahCore_a1.exe
[09:37:14] Decompressed FahCore_a1.exe (2117632 bytes) successfully
[09:37:14] + Core successfully engaged
[09:37:19]
[09:37:19] + Processing work unit
[09:37:19] Core required: FahCore_a1.exe
[09:37:19] Core found.
[09:37:19] Working on Unit 05 [May 26 09:37:19]
[09:37:19] + Working ...
[09:37:19] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 05 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2828 -version 592'
[09:37:21]
[09:37:21] *------------------------------*
[09:37:21] Folding@Home Gromacs SMP Core
[09:37:21] Version 1.76 (February 23, 2008)
[09:37:21]
[09:37:21] Preparing to commence simulation
[09:37:21] - Ensuring status. Please wait.
[09:37:38] - Assembly optimizations manually forced on.
[09:37:38] - Not checking prior termination.
[09:37:58] - Expanded 4765975 -> 24426905 (decompressed 512.5 percent)
[09:37:58]
[09:37:58] Project: 2665 (Run 0, Clone 910, Gen 7)
[09:37:58]
[09:38:05] Assembly optimizations on if available.
[09:38:05] Entering M.D.
[09:38:24] Calling FAH init
[09:38:26] ater
[09:38:26] Writing local files
[09:38:26] rom checkpoint)
[09:38:26] Read checkpoint
[09:38:27] teps (44 percent)
[09:38:27] er
[09:38:27] Writing local files
[09:38:27] Completed 110000 out of 250000 steps (44 percent)
[09:38:42] Extra SSE boost OK.
Re: Project 2665 (run 0 clone 910 gen 7)
had another coreshutdown at 65% but it restarted itself without going into the download new coree loop. The WU has now completed and uploaded and i'll see if theres any problems with the new WU its running now.
Hi Keith,
Thanks for the report and keep us posted.
Paula
Paula
@keith_MM
Could you describe the hardware that this WU is running on.
q6600 overclocked to 2.8Ghz , gigabyte ga-73pvm-s2h mobo,2GB kingston 1.8v ram running a windows SMP client which is the one having the problem. Also running a Linux SMP VM. The computer has been folding 24/7 in this configuration for the last month without any problems. I slowed the overclock down about a month ago as I was gettingthe occasional hang of the machine. currently up to 20% on the next WU.
Re: Project: 2665 (Run 0, Clone 910, Gen 7)
The computer has now been folding for a week with no problems but tonight have just spotted that I've had some more corestatus=63 errors.
[16:18:37] + No unsent completed units remaining.
[16:18:37] + Closed connections
[16:18:37]
[16:18:37] + Processing work unit
[16:18:37] Core required: FahCore_a1.exe
[16:18:37] Core found.
[16:18:37] Working on Unit 00 [June 2 16:18:37]
[16:18:37] + Working ...
[16:18:37] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 00 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2352 -version 592'
[16:18:40]
[16:18:40] *------------------------------*
[16:18:40] Folding@Home Gromacs SMP Core
[16:18:40] Version 1.76 (February 23, 2008)
[16:18:40]
[16:18:40] Preparing to commence simulation
[16:18:40] - Ensuring status. Please wait.
[16:18:57] - Assembly optimizations manually forced on.
[16:18:57] - Not checking prior termination.
[16:19:15] - Expanded 4643987 -> 24111057 (decompressed 519.1 percent)
[16:19:16] - Starting from initial work packet
[16:19:16]
[16:19:16] Project: 2665 (Run 1, Clone 792, Gen 6)
[16:19:16]
[16:19:23] Assembly optimizations on if available.
[16:19:23] Entering M.D.
[16:19:40] Rejecting checkpoint
[16:19:41]
[16:19:41] Writing local files
[16:19:42]
[16:19:42] Writing local files
[16:19:54] Extra SSE boost OK.
[16:19:55] Writing local files
[16:19:55] Completed 0 out of 250000 steps (0 percent)
[16:34:56] Timered checkpoint triggered.
[16:43:36] Writing local files
[16:43:36] Completed 2500 out of 250000 steps (1 percent)
[16:58:37] Timered checkpoint triggered.
[17:07:16] Writing local files
[17:07:17] Completed 5000 out of 250000 steps (2 percent)
[17:22:17] Timered checkpoint triggered.
[17:30:58] Writing local files
[17:30:59] Completed 7500 out of 250000 steps (3 percent)
[17:45:59] Timered checkpoint triggered.
[17:54:43] Writing local files
[17:54:43] Completed 10000 out of 250000 steps (4 percent)
[18:09:44] Timered checkpoint triggered.
[18:18:25] Writing local files
[18:18:25] Completed 12500 out of 250000 steps (5 percent)
[18:18:40] CoreStatus = 63 (99)
[18:18:40] + Error starting Folding@Home core or unexpected system termination of core.
[18:18:45]
[18:18:45] + Processing work unit
[18:18:45] Core required: FahCore_a1.exe
[18:18:45] Core found.
[18:18:45] Working on Unit 00 [June 2 18:18:45]
[18:18:45] + Working ...
[18:18:45] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 00 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2352 -version 592'
[18:18:47]
[18:18:47] *------------------------------*
[18:18:47] Folding@Home Gromacs SMP Core
[18:18:47] Version 1.76 (February 23, 2008)
[18:18:47]
[18:18:47] Preparing to commence simulation
[18:18:47] - Ensuring status. Please wait.
[18:19:04] - Assembly optimizations manually forced on.
[18:19:04] - Not checking prior termination.
[18:19:22] - Expanded 4643987 -> 24111057 (decompressed 519.1 percent)
[18:19:22]
[18:19:22] Project: 2665 (Run 1, Clone 792, Gen 6)
[18:19:22]
[18:19:28] Assembly optimizations on if available.
[18:19:28] Entering M.D.
[18:19:48] Calling FAH init
[18:19:49] Read topology
[18:19:49] (Starting from checkpoint)
[18:19:49] Read checkpoint
[18:19:50] eps (5 percent)
[18:19:50] ater
[18:19:50] Writing local files
[18:19:50] Completed 12500 out of 250000 steps (5 percent)
[18:20:02] Extra SSE boost OK.
[18:35:04] Timered checkpoint triggered.
[18:40:45] CoreStatus = 63 (99)
[18:40:45] + Error starting Folding@Home core or unexpected system termination of core.
[18:40:50]
[18:40:50] + Processing work unit
[18:40:50] Core required: FahCore_a1.exe
[18:40:50] Core found.
[18:40:50] Working on Unit 00 [June 2 18:40:50]
[18:40:50] + Working ...
[18:40:50] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 00 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2352 -version 592'
[18:40:53]
[18:40:53] *------------------------------*
[18:40:53] Folding@Home Gromacs SMP Core
[18:40:53] Version 1.76 (February 23, 2008)
[18:40:53]
[18:40:53] Preparing to commence simulation
[18:40:53] - Ensuring status. Please wait.
[18:41:10] - Assembly optimizations manually forced on.
[18:41:10] - Not checking prior termination.
[18:41:28] - Expanded 4643987 -> 24111057 (decompressed 519.1 percent)
[18:41:28]
[18:41:28] Project: 2665 (Run 1, Clone 792, Gen 6)
[18:41:28]
[18:41:36] Assembly optimizations on if available.
[18:41:36] Entering M.D.
[18:41:53] Calling FAH init
[18:41:54] Read topology
[18:41:55] ocal files
[18:41:55] rom checkpoint)
[18:41:55] Read checkpoint
[18:41:55] Protein: IBX in water
[18:41:55] Writing local files
[18:41:55] Completed 14152 out of 250000 steps (5 percent)
[18:42:07] Extra SSE boost OK.
[18:49:25] Writing local files
[18:49:25] Completed 15000 out of 250000 steps (6 percent)
[19:04:26] Timered checkpoint triggered.
[19:10:55] Writing local files
[19:10:55] Completed 17500 out of 250000 steps (7 percent)
[19:25:56] Timered checkpoint triggered.
[19:32:21] Writing local files
[19:32:21] Completed 20000 out of 250000 steps (8 percent)
[19:47:22] Timered checkpoint triggered.
[19:53:47] Writing local files
[19:53:48] Completed 22500 out of 250000 steps (9 percent)
[20:08:48] Timered checkpoint triggered.
[20:15:18] Writing local files
[20:15:18] Completed 25000 out of 250000 steps (10 percent)
[20:30:19] Timered checkpoint triggered.
[20:35:27] Writing local files
[20:35:27] Completed 27500 out of 250000 steps (11 percent)
[20:50:28] Timered checkpoint triggered.
[20:56:12] Writing local files
[20:56:13] Completed 30000 out of 250000 steps (12 percent)
That's the kind of behavior I typically see when I have a network get disconnected/reset, and then continue from where it left off, especially with the v5.92 client. v5.91 would just 0x7b error out at that point, so good thing you upgraded.keith_MM wrote:The computer has now been folding for a week with no problems but tonight have just spotted that I've had some more corestatus=63 errors.
would that explain a new core being downloaded though.?
[18:18:47]
[18:19:22]
[18:19:22]
[18:19:50] ater
[18:40:50]
[18:40:53]
[18:40:53]
[18:41:28]
[18:41:28]
[21:11:13] Timered checkpoint triggered.
[21:18:36] Writing local files
[21:18:37] Completed 32500 out of 250000 steps (13 percent)
[21:33:36] Timered checkpoint triggered.
[21:41:04] Writing local files
[21:41:04] Completed 35000 out of 250000 steps (14 percent)
[21:56:05] Timered checkpoint triggered.
[22:00:25] - Autosending finished units...
[22:00:25] Trying to send all finished work units
[22:00:25] + No unsent completed units remaining.
[22:00:25] - Autosend completed
[22:02:59] Writing local files
[22:02:59] Completed 37500 out of 250000 steps (15 percent)
[22:18:00] Timered checkpoint triggered.
[22:24:49] Writing local files
[22:24:50] Completed 40000 out of 250000 steps (16 percent)
[22:39:51] Timered checkpoint triggered.
[22:46:38] Writing local files
[22:46:38] Completed 42500 out of 250000 steps (17 percent)
[23:01:39] Timered checkpoint triggered.
[23:08:27] Writing local files
[23:08:27] Completed 45000 out of 250000 steps (18 percent)
[23:23:28] Timered checkpoint triggered.
[23:30:15] Writing local files
[23:30:15] Completed 47500 out of 250000 steps (19 percent)
[23:33:43] CoreStatus = 63 (99)
[23:33:43] + Error starting Folding@Home core or unexpected system termination of core.
[23:33:43] - Attempting to download new core...
[23:33:43] + Downloading new core: FahCore_a1.exe
[23:33:43] Downloading core (/~pande/Win32/x86_Deino/Core_a1.fah from www.stanford.edu)
[23:33:44] Initial: AFDE; + 10240 bytes downloaded
[23:33:45] Initial: 10F0; + 20480 bytes downloaded
[23:33:45] Initial: DB70; + 30720 bytes downloaded
[23:33:45] Initial: 865E; + 40960 bytes downloaded
[23:33:45] Initial: 8F87; + 51200 bytes downloaded
[23:33:45] Initial: C48B; + 61440 bytes downloaded
[23:33:45] Initial: 92B3; + 71680 bytes downloaded
[23:33:45] Initial: C102; + 81920 bytes downloaded
[23:33:46] Initial: 1996; + 92160 bytes downloaded
[23:33:46] Initial: BFFE; + 102400 bytes downloaded
[23:33:46] Initial: 1810; + 112640 bytes downloaded
[23:33:46] Initial: 0626; + 122880 bytes downloaded
[23:33:46] Initial: 7B53; + 133120 bytes downloaded
[23:33:46] Initial: 0441; + 143360 bytes downloaded
[23:33:46] Initial: FECE; + 153600 bytes downloaded
[23:33:47] Initial: D346; + 163840 bytes downloaded
[23:33:47] Initial: 2DE8; + 174080 bytes downloaded
[23:33:47] Initial: B3F0; + 184320 bytes downloaded
[23:33:47] Initial: 2881; + 194560 bytes downloaded
[23:33:47] Initial: 9507; + 204800 bytes downloaded
[23:33:47] Initial: 1BAF; + 215040 bytes downloaded
[23:33:48] Initial: 717C; + 225280 bytes downloaded
[23:33:48] Initial: 23FD; + 235520 bytes downloaded
[23:33:48] Initial: 915F; + 245760 bytes downloaded
[23:33:48] Initial: CE52; + 256000 bytes downloaded
[23:33:48] Initial: ED88; + 266240 bytes downloaded
[23:33:48] Initial: 2579; + 276480 bytes downloaded
[23:33:48] Initial: 3396; + 286720 bytes downloaded
[23:33:48] Initial: 410C; + 296960 bytes downloaded
[23:33:49] Initial: 56D1; + 307200 bytes downloaded
[23:33:49] Initial: 1EBD; + 317440 bytes downloaded
[23:33:49] Initial: 6AD9; + 327680 bytes downloaded
[23:33:49] Initial: F931; + 337920 bytes downloaded
[23:33:49] Initial: 1C40; + 348160 bytes downloaded
[23:33:49] Initial: C4AE; + 358400 bytes downloaded
[23:33:49] Initial: 57E4; + 368640 bytes downloaded
[23:33:49] Initial: 1843; + 378880 bytes downloaded
[23:33:49] Initial: B0C0; + 389120 bytes downloaded
[23:33:50] Initial: AAAA; + 399360 bytes downloaded
[23:33:50] Initial: D737; + 409600 bytes downloaded
[23:33:50] Initial: 762A; + 419840 bytes downloaded
[23:33:50] Initial: 8685; + 430080 bytes downloaded
[23:33:51] Initial: 25B1; + 440320 bytes downloaded
[23:33:51] Initial: 44F1; + 450560 bytes downloaded
[23:33:51] Initial: EF81; + 460800 bytes downloaded
[23:33:51] Initial: 900E; + 471040 bytes downloaded
[23:33:51] Initial: 906E; + 481280 bytes downloaded
[23:33:51] Initial: D59F; + 491520 bytes downloaded
[23:33:51] Initial: 2406; + 501760 bytes downloaded
[23:33:51] Initial: 9777; + 512000 bytes downloaded
[23:33:52] Initial: 7783; + 522240 bytes downloaded
[23:33:52] Initial: AEC5; + 532480 bytes downloaded
[23:33:52] Initial: B8A1; + 542720 bytes downloaded
[23:33:52] Initial: D50E; + 552960 bytes downloaded
[23:33:52] Initial: BDEE; + 563200 bytes downloaded
[23:33:52] Initial: E433; + 573440 bytes downloaded
[23:33:52] Initial: 667A; + 583680 bytes downloaded
[23:33:52] Initial: C413; + 593920 bytes downloaded
[23:33:53] Initial: DB64; + 604160 bytes downloaded
[23:33:53] Initial: 313C; + 614400 bytes downloaded
[23:33:53] Initial: 4B8A; + 624640 bytes downloaded
[23:33:53] Initial: 1B3A; + 634880 bytes downloaded
[23:33:53] Initial: E39B; + 645120 bytes downloaded
[23:33:54] Initial: F9FD; + 655360 bytes downloaded
[23:33:54] Initial: BFF6; + 665600 bytes downloaded
[23:33:54] Initial: 0552; + 675840 bytes downloaded
[23:33:54] Initial: 14A7; + 686080 bytes downloaded
[23:33:54] Initial: 99A6; + 696320 bytes downloaded
[23:33:54] Initial: 06B2; + 706560 bytes downloaded
[23:33:54] Initial: 445D; + 716800 bytes downloaded
[23:33:55] Initial: 62C1; + 727040 bytes downloaded
[23:33:55] Initial: 0E27; + 737280 bytes downloaded
[23:33:55] Initial: EF9A; + 747520 bytes downloaded
[23:33:55] Initial: C105; + 757760 bytes downloaded
[23:33:56] Initial: 46D3; + 768000 bytes downloaded
[23:33:56] Initial: 33C7; + 778240 bytes downloaded
[23:33:56] Initial: 7E92; + 788480 bytes downloaded
[23:33:56] Initial: 24B3; + 795847 bytes downloaded
[23:33:56] Verifying core Core_a1.fah...
[23:33:56] Signature is VALID
[23:33:56]
[23:33:56] Trying to unzip core FahCore_a1.exe
[23:33:56] Decompressed FahCore_a1.exe (2117632 bytes) successfully
[23:33:56] + Core successfully engaged
[23:34:01]
[23:34:01] + Processing work unit
[23:34:01] Core required: FahCore_a1.exe
[23:34:01] Core found.
[23:34:01] Working on Unit 00 [June 2 23:34:01]
[23:34:01] + Working ...
[23:34:01] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 00 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2352 -version 592'
[23:34:04]
[23:34:04] *------------------------------*
[23:34:04] Folding@Home Gromacs SMP Core
[23:34:04] Version 1.76 (February 23, 2008)
[23:34:04]
[23:34:04] Preparing to commence simulation
[23:34:04] - Ensuring status. Please wait.
[23:34:21] - Assembly optimizations manually forced on.
[23:34:21] - Not checking prior termination.
[23:34:39] - Expanded 4643987 -> 24111057 (decompressed 519.1 percent)
[23:34:40]
[23:34:40] Project: 2665 (Run 1, Clone 792, Gen 6)
[23:34:40]
[23:34:50] Assembly optimizations on if available.
[23:34:50] Entering M.D.
[23:35:03] Calling FAH init
[23:35:05] Read topology
[23:35:05] ocal files
[23:35:05] rom checkpoint)
[23:35:05] Read checkpoint
[23:35:05] Protein: IBX in water
[23:35:05] Writing local files
[23:35:06] Completed 47500 out of 250000 steps (19 percent)
[23:35:18] Extra SSE boost OK.
[23:50:18] Timered checkpoint triggered.
[23:54:57] Writing local files
[23:54:57] Completed 50000 out of 250000 steps (20 percent)
[00:09:57] Timered checkpoint triggered.
[00:14:35] Writing local files
[00:14:35] Completed 52500 out of 250000 steps (21 percent)
[00:29:35] Timered checkpoint triggered.
[00:34:13] Writing local files
[00:34:13] Completed 55000 out of 250000 steps (22 percent)
[00:49:13] Timered checkpoint triggered.
[00:53:47] Writing local files
[00:53:47] Completed 57500 out of 250000 steps (23 percent)
[01:08:47] Timered checkpoint triggered.
[01:13:21] Writing local files
[01:13:22] Completed 60000 out of 250000 steps (24 percent)
[01:28:21] Timered checkpoint triggered.
[01:32:56] Writing local files
[01:32:57] Completed 62500 out of 250000 steps (25 percent)
[01:47:56] Timered checkpoint triggered.
[01:52:29] Writing local files
[01:52:29] Completed 65000 out of 250000 steps (26 percent)
[02:07:29] Timered checkpoint triggered.
[02:12:02] Writing local files
[02:12:02] Completed 67500 out of 250000 steps (27 percent)
[02:27:02] Timered checkpoint triggered.
[02:31:36] Writing local files
[02:31:37] Completed 70000 out of 250000 steps (28 percent)
[02:46:36] Timered checkpoint triggered.
[02:51:09] Writing local files
[02:51:10] Completed 72500 out of 250000 steps (29 percent)
[03:06:10] Timered checkpoint triggered.
[03:10:44] Writing local files
[03:10:44] Completed 75000 out of 250000 steps (30 percent)
[03:13:12] CoreStatus = 63 (99)
[03:13:12] + Error starting Folding@Home core or unexpected system termination of core.
[03:13:17]
[03:13:17] + Processing work unit
[03:13:17] Core required: FahCore_a1.exe
[03:13:17] Core found.
[03:13:17] Working on Unit 00 [June 3 03:13:17]
[03:13:17] + Working ...
[03:13:17] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 00 -cpu 97 -checkpoint 15 -forceasm -verbose -lifeline 2352 -version 592'
[03:13:19]
[03:13:19] *------------------------------*
[03:13:19] Folding@Home Gromacs SMP Core
[03:13:19] Version 1.76 (February 23, 2008)
[03:13:19]
[03:13:19] Preparing to commence simulation
[03:13:19] - Ensuring status. Please wait.
[03:13:36] - Assembly optimizations manually forced on.
[03:13:36] - Not checking prior termination.
[03:13:56] - Expanded 4643987 -> 24111057 (decompressed 519.1 percent)
[03:13:57]
[03:13:57] Project: 2665 (Run 1, Clone 792, Gen 6)
[03:13:57]
[03:14:05] Assembly optimizations on if available.
[03:14:05] Entering M.D.
[03:14:19] Calling FAH init
[03:14:21] Read topology
[03:14:21] (Starting from checkpoint)
[03:14:21] Read checkpoint
[03:14:21] eps (30 percent)
[03:14:21] ter
[03:14:21] Writing local files
[03:14:21] Completed 75000 out of 250000 steps (30 percent)
[03:14:33] Extra SSE boost OK.
[03:29:35] Timered checkpoint triggered.
[03:34:09] Writing local files
[03:34:09] Completed 77500 out of 250000 steps (31 percent)
[03:49:11] Timered checkpoint triggered.
[03:53:43] Writing local files
[03:53:44] Completed 80000 out of 250000 steps (32 percent)
[04:00:25] - Autosending finished units...
[04:00:25] Trying to send all finished work units
[04:00:25] + No unsent completed units remaining.
[04:00:25] - Autosend completed
[04:08:45] Timered checkpoint triggered.
[04:13:16] Writing local files
[04:13:16] Completed 82500 out of 250000 steps (33 percent)
[04:28:17] Timered checkpoint triggered.
[04:32:52] Writing local files
[04:32:52] Completed 85000 out of 250000 steps (34 percent)
[04:47:53] Timered checkpoint triggered.
[04:52:37] Writing local files
[04:52:37] Completed 87500 out of 250000 steps (35 percent)
[05:07:39] Timered checkpoint triggered.
[05:12:10] Writing local files
[05:12:10] Completed 90000 out of 250000 steps (36 percent)
[05:27:11] Timered checkpoint triggered.
[05:31:43] Writing local files
[05:31:44] Completed 92500 out of 250000 steps (37 percent)
[05:46:44] Timered checkpoint triggered.
[05:51:16] Writing local files
[05:51:16] Completed 95000 out of 250000 steps (38 percent)
[06:06:17] Timered checkpoint triggered.
[06:10:50] Writing local files
[06:10:50] Completed 97500 out of 250000 steps (39 percent)
[06:25:52] Timered checkpoint triggered.
[06:30:23] Writing local files
[06:30:23] Completed 100000 out of 250000 steps (40 percent)
[06:45:24] Timered checkpoint triggered.
[06:49:55] Writing local files
[06:49:55] Completed 102500 out of 250000 steps (41 percent)
[07:04:56] Timered checkpoint triggered.
[07:09:28] Writing local files
[07:09:28] Completed 105000 out of 250000 steps (42 percent)
[07:24:30] Timered checkpoint triggered.
[07:29:02] Writing local files
[07:29:02] Completed 107500 out of 250000 steps (43 percent)
[07:44:03] Timered checkpoint triggered.
[07:48:36] Writing local files
[07:48:36] Completed 110000 out of 250000 steps (44 percent)
[08:03:38] Timered checkpoint triggered.
[08:08:26] Writing local files
[08:08:26] Completed 112500 out of 250000 steps (45 percent)
[08:23:27] Timered checkpoint triggered.
[08:28:45] Writing local files
[08:28:45] Completed 115000 out of 250000 steps (46 percent)
[08:43:46] Timered checkpoint triggered.
[08:48:39] Writing local files
[08:48:39] Completed 117500 out of 250000 steps (47 percent)
[09:03:40] Timered checkpoint triggered.
AFAIK, core downloads are triggered two ways, when a new work unit requires a new version of a fahcore and prompts the download, or when there is a serious client error the client prompts to download a new fahcore hoping either a newer core is available though not required that could fix the problem, or because downloading a new fahcore will fix a corrupted fahcore.keith_MM wrote:would that explain a new core being downloaded though?
The log you posted shows an error that may have been serious enough to prompt for a replacement fahcore.
On my side, I got this kind of error :
[16:31:34] Folding@Home Gromacs SMP Core
[16:31:34] Version 1.74 (March 10, 2007)
[16:31:34]
[16:31:34] Preparing to commence simulation
[16:31:34] - Ensuring status. Please wait.
[16:31:51] - Assembly optimizations manually forced on.
[16:31:51] - Not checking prior termination.
[16:32:08] - Expanded 4721766 -> 24426905 (decompressed 517.3 percent)
[16:32:09] - Starting from initial work packet
[16:32:09]
[16:32:09] Project: 2665 (Run 0, Clone 383, Gen 8)
[16:32:09]
[16:32:12] Assembly optimizations on if available.
[16:32:12] Entering M.D.
[16:32:18] Rejecting checkpoint
[16:32:20]
[16:32:20] Writing local files
[16:32:20]
[16:32:30] Extra SSE boost OK.
[16:32:31] Writing local files
[16:32:31] Completed 0 out of 250000 steps (0 percent)
[16:32:33] d. The run has entered a
[16:32:33] stateQuit 101 - Too many box elem corrections 1
[16:32:33]
[16:32:33] Simulation instability has been encountered. The run has entered a
[16:32:33] state from which no further progress can be made.
[16:32:33] This may be the correct result of the simulation, however if you
[16:32:33] often see other project units terminating early like this
[16:32:33] too, you may wish to check the stability of your computer (issues
[16:32:33] such as high temperature, overclocking, etc.).
[16:32:33] Going to send back what have done.
[16:32:33] logfile size: 9426
[16:32:33] - Writing 9983 bytes of core data to disk...
[16:32:33] ... Done.
[16:32:33] iled to delete work/wudata_08.sas
[16:32:33] - Failed to delete work/wudata_08.goe
[16:32:33] Warning: check for stray files
[16:32:33] ck for stray files
[16:32:33]
[16:32:33] Folding@home Core Shutdown: EARLY_UNIT_END
[16:32:33] Finalizing output
[16:34:36] CoreStatus = 7B (123)
[16:34:36] Client-core communications error: ERROR 0x7bMacpro 2,66 GHz Quad, 6 Go DDR3, ATI Radeon HD 4870 512 Mo
Flathead74
joce, there are some interesting comments regarding this error in the FahWiki,
and one user, MichaelO, reports that faulty RAM seemed to have been the cause.
This, of course, is not an all-inclusive answer to the 0x7b error, so ymmv.
http://fahwiki.net/index.php/CoreStatus_codes
7B, a little more than half way down the page.
I had the same idea : bad memory, or memory allocation issue (with the 2665 eating up to 500 MB of RAM) ...
I don't think it's a memory issue on this machine : the box has 4GB of ECC RAM, and no issue occurs with other WUs / softwares.Flathead74 wrote:joce, there are some interesting comments regarding this error in the FahWiki,
It has folded happily a 3064 WU between the two try of folding the 2665.
Moreover, it displayed the following error before the 0x7b error :
