No GPUWU assigned
No GPUWU assigned
Hi all,
i'm writing because i can't fold with my GPU. The client tries to download a WU but the answer received is "Empty work server assignment"... Is the first time i install FAH 7.4.4 on this machine.
Maybe there is no WU for my graphic board available but this start to be suspiciuos as already 5 days are passed.
I have a Nvidia Quadro FX 4800 with driver 344.41 fresh installed CUDA 1.3 and the file GPUs.txt (where i confirm the presence of my Graphic board) updated in %appdata%.
the Server 171.67.108.200 and 171.67.108.204 where the client request the WU are NOT down. Therefore i don't know what else to check.
Someone else is getting WU for their GPU? It is possible none of them are available still after so long?
Thank you very much
Tondo
Thank you very much
Tondo
Re: No GPUWU assigned
Your Quadro FX 4800 is an older, pre-Fermi card. The GPU projects that used to be assigned to them ran out last year. Some pre-Fermi cards can fold a newer batch of projects, also approaching end of life, but not all. The projects that ran out used Core_11, these slightly newer ones use Core_15.
You can opt in to folding these Core_15 projects and seeing if your card can successfully fold them by adding two options to your GPU folding slot. Add the option client-type and set it to beta, and also add the option max-packet-size and set that to small.
Thank you for the reply... It still don't get any WU... It may be core-11 then...
I'll just use CPU then...
Thank you very much...
Please post your log. Maybe something was missed.
I post the the log. I just added back the gpu slot and set the options as u said...
let me know if u need more infos..
thanks
thanks
11:46:22:Adding folding slot 01: READY gpu:0:GT200GL [Quadro FX 4800]
11:46:23:Removing old file 'configs/config-20150716-102606.xml'
11:46:23:Saving configuration to config.xml
11:46:23:<config>
11:46:23: <!-- Folding Slot Configuration -->
11:46:23: <cause v='CANCER'/>
11:46:23:
11:46:23: <!-- Logging -->
11:46:23: <verbosity v='4'/>
11:46:23:
11:46:23: <!-- Network -->
11:46:23: <proxy v=':8080'/>
11:46:23:
11:46:23: <!-- Slot Control -->
11:46:23: <power v='full'/>
11:46:23:
11:46:23: <!-- User Information -->
11:46:23: <passkey v='********************************'/>
11:46:23: <team v='123'/>
11:46:23: <user v='Tondo5'/>
11:46:23:
11:46:23: <!-- Folding Slots -->
11:46:23: <slot id='0' type='CPU'>
11:46:23: <cpus v='3'/>
11:46:23: </slot>
11:46:23: <slot id='1' type='GPU'>
11:46:23: <client-type v='beta'/>
11:46:23: <max-packet-size v='small'/>
11:46:23: </slot>
11:46:23:</config>
11:46:23:WU01:FS01:Connecting to 171.67.108.200:80
11:46:24:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
11:46:24:WU01:FS01:Connecting to 171.67.108.204:80
11:46:24:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:46:24:ERROR:WU01:FS01:Exception: Could not get an assignment
11:46:25:WU01:FS01:Connecting to 171.67.108.200:80
11:46:25:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
11:46:25:WU01:FS01:Connecting to 171.67.108.204:80
11:46:26:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:46:26:ERROR:WU01:FS01:Exception: Could not get an assignment
11:47:01:Removing old file 'configs/config-20150716-102609.xml'
11:47:01:Saving configuration to config.xml
11:47:01:<config>
11:47:01: <!-- Folding Slot Configuration -->
11:47:01: <cause v='CANCER'/>
11:47:01:
11:47:01: <!-- Logging -->
11:47:01: <verbosity v='4'/>
11:47:01:
11:47:01: <!-- Network -->
11:47:01: <proxy v=':8080'/>
11:47:01:
11:47:01: <!-- Slot Control -->
11:47:01: <power v='full'/>
11:47:01:
11:47:01: <!-- User Information -->
11:47:01: <passkey v='********************************'/>
11:47:01: <team v='123'/>
11:47:01: <user v='Tondo5'/>
11:47:01:
11:47:01: <!-- Folding Slots -->
11:47:01: <slot id='0' type='CPU'>
11:47:01: <cpus v='3'/>
11:47:01: </slot>
11:47:01: <slot id='1' type='GPU'>
11:47:01: <client-type v='beta'/>
11:47:01: <max-packet-size v='small'/>
11:47:01: </slot>
11:47:01:</config>
11:47:25:WU01:FS01:Connecting to 171.67.108.200:80
11:47:26:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
11:47:26:WU01:FS01:Connecting to 171.67.108.204:80
11:47:26:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:47:26:ERROR:WU01:FS01:Exception: Could not get an assignmentRe: No GPUWU assigned
Try changing your Cause Preference to Any ... the server should do that automatically if there are no WUs for your cause but I'm not sure that's completely setup yet.
It looks like the small projects are currently off-line. I'll try to find somebody to notify.
Bruce did u manage to get any news?
My small WU GPU is still folding away. I'll check when I grabbed the current WU.
Did changing the cause to None have an affect?
Mine grabbed a new download 07/29 at 8 PM Pacific. Project 7623
changing the cause to any didn't do any effect... still no WU on the assignment server...
Well it might be my GPU is core 11... Bad luck...
i'll just use cpus then...
thanks all
thanks all
The only way to be sure is to see the System section of the fah log. Please post that.
hi 7im,
here is the log.
in this log the GPU Slot is disabled but the log i posted before has already the error i receive...
i don't know if this is the "system section of the fah log" but i set the verbosity to 5 and copy the only log i found.
if you need something else please let me know.
Thank you
here is the log.
Thank you
*********************** Log Started 2015-08-06T09:26:09Z ***********************
09:26:09:************************* Folding@home Client *************************
09:26:09: Website: http://folding.stanford.edu/
09:26:09: Copyright: (c) 2009-2014 Stanford University
09:26:09: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:26:09: Args:
09:26:09: Config: C:/Users/EN33560/AppData/Roaming/FAHClient/config.xml
09:26:09:******************************** Build ********************************
09:26:09: Version: 7.4.4
09:26:09: Date: Mar 4 2014
09:26:09: Time: 20:26:54
09:26:09: SVN Rev: 4130
09:26:09: Branch: fah/trunk/client
09:26:09: Compiler: Intel(R) C++ MSVC 1500 mode 1200
09:26:09: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
09:26:09: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
09:26:09: Platform: win32 XP
09:26:09: Bits: 32
09:26:09: Mode: Release
09:26:09:******************************* System ********************************
09:26:09: CPU: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz
09:26:09: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
09:26:09: CPUs: 4
09:26:09: Memory: 12.00GiB
09:26:09: Free Memory: 10.17GiB
09:26:09: Threads: WINDOWS_THREADS
09:26:09: OS Version: 6.1
09:26:09: Has Battery: false
09:26:09: On Battery: false
09:26:09: UTC Offset: 2
09:26:09: PID: 4724
09:26:09: CWD: C:/Users/EN33560/AppData/Roaming/FAHClient
09:26:09: OS: Windows 7 Enterprise
09:26:09: OS Arch: AMD64
09:26:09: GPUs: 1
09:26:09: GPU 0: NVIDIA:0 GT200GL [Quadro FX 4800]
09:26:09: CUDA: 1.3
09:26:09: CUDA Driver: 6050
09:26:09:Win32 Service: false
09:26:09:***********************************************************************
09:26:09:<config>
09:26:09: <service-description v='Folding@home Client'/>
09:26:09: <service-restart v='true'/>
09:26:09: <service-restart-delay v='5000'/>
09:26:09:
09:26:09: <!-- Client Control -->
09:26:09: <client-threads v='6'/>
09:26:09: <cycle-rate v='4'/>
09:26:09: <cycles v='-1'/>
09:26:09: <data-directory v='.'/>
09:26:09: <disable-sleep-when-active v='true'/>
09:26:09: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
09:26:09: <exit-when-done v='false'/>
09:26:09: <fold-anon v='false'/>
09:26:09: <open-web-control v='false'/>
09:26:09:
09:26:09: <!-- Configuration -->
09:26:09: <config-rotate v='true'/>
09:26:09: <config-rotate-dir v='configs'/>
09:26:09: <config-rotate-max v='16'/>
09:26:09:
09:26:09: <!-- Debugging -->
09:26:09: <assignment-servers>
09:26:09: assign3.stanford.edu:8080 assign4.stanford.edu:80
09:26:09: </assignment-servers>
09:26:09: <auth-as v='true'/>
09:26:09: <capture-directory v='capture'/>
09:26:09: <capture-on-error v='false'/>
09:26:09: <capture-packets v='false'/>
09:26:09: <capture-requests v='false'/>
09:26:09: <capture-responses v='false'/>
09:26:09: <capture-sockets v='false'/>
09:26:09: <core-exec v='FahCore_$type'/>
09:26:09: <core-wrapper-exec v='FAHCoreWrapper'/>
09:26:09: <debug-sockets v='false'/>
09:26:09: <exception-locations v='true'/>
09:26:09: <gpu-assignment-servers>
09:26:09: assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
09:26:09: </gpu-assignment-servers>
09:26:09: <stack-traces v='false'/>
09:26:09:
09:26:09: <!-- Error Handling -->
09:26:09: <max-slot-errors v='10'/>
09:26:09: <max-unit-errors v='5'/>
09:26:09:
09:26:09: <!-- Folding Core -->
09:26:09: <checkpoint v='15'/>
09:26:09: <core-dir v='cores'/>
09:26:09: <core-priority v='idle'/>
09:26:09: <cpu-affinity v='false'/>
09:26:09: <cpu-usage v='100'/>
09:26:09: <gpu-usage v='100'/>
09:26:09: <no-assembly v='false'/>
09:26:09:
09:26:09: <!-- Folding Slot Configuration -->
09:26:09: <cause v='ANY'/>
09:26:09: <client-subtype v='STDCLI'/>
09:26:09: <client-type v='normal'/>
09:26:09: <cpu-species v='X86_PENTIUM_II'/>
09:26:09: <cpu-type v='AMD64'/>
09:26:09: <cpus v='-1'/>
09:26:09: <gpu v='true'/>
09:26:09: <max-packet-size v='normal'/>
09:26:09: <os-species v='UNKNOWN'/>
09:26:09: <os-type v='WIN32'/>
09:26:09: <project-key v='0'/>
09:26:09: <smp v='true'/>
09:26:09:
09:26:09: <!-- GUI -->
09:26:09: <gui-enabled v='true'/>
09:26:09:
09:26:09: <!-- HTTP Server -->
09:26:09: <allow v='127.0.0.1'/>
09:26:09: <connection-timeout v='60'/>
09:26:09: <deny v='0/0'/>
09:26:09: <http-addresses v='0:7396'/>
09:26:09: <https-addresses v=''/>
09:26:09: <max-connect-time v='900'/>
09:26:09: <max-connections v='800'/>
09:26:09: <max-request-length v='52428800'/>
09:26:09: <min-connect-time v='300'/>
09:26:09: <threads v='4'/>
09:26:09:
09:26:09: <!-- Logging -->
09:26:09: <log v='log.txt'/>
09:26:09: <log-color v='false'/>
09:26:09: <log-crlf v='true'/>
09:26:09: <log-date v='false'/>
09:26:09: <log-date-periodically v='21600'/>
09:26:09: <log-debug v='true'/>
09:26:09: <log-domain v='false'/>
09:26:09: <log-header v='true'/>
09:26:09: <log-level v='true'/>
09:26:09: <log-no-info-header v='true'/>
09:26:09: <log-redirect v='false'/>
09:26:09: <log-rotate v='true'/>
09:26:09: <log-rotate-dir v='logs'/>
09:26:09: <log-rotate-max v='16'/>
09:26:09: <log-short-level v='false'/>
09:26:09: <log-simple-domains v='true'/>
09:26:09: <log-thread-id v='false'/>
09:26:09: <log-thread-prefix v='true'/>
09:26:09: <log-time v='true'/>
09:26:09: <log-to-screen v='true'/>
09:26:09: <log-truncate v='false'/>
09:26:09: <verbosity v='5'/>
09:26:09:
09:26:09: <!-- Network -->
09:26:09: <proxy v=':8080'/>
09:26:09: <proxy-enable v='false'/>
09:26:09: <proxy-pass v=''/>
09:26:09: <proxy-user v=''/>
09:26:09:
09:26:09: <!-- Process Control -->
09:26:09: <child v='false'/>
09:26:09: <daemon v='false'/>
09:26:09: <pid v='false'/>
09:26:09: <pid-file v='Folding@home Client.pid'/>
09:26:09: <respawn v='false'/>
09:26:09: <service v='false'/>
09:26:09:
09:26:09: <!-- Remote Command Server -->
09:26:09: <command-address v='0.0.0.0'/>
09:26:09: <command-allow-no-pass v='127.0.0.1'/>
09:26:09: <command-deny-no-pass v='0/0'/>
09:26:09: <command-enable v='true'/>
09:26:09: <command-port v='36330'/>
09:26:09:
09:26:09: <!-- Slot Control -->
09:26:09: <idle v='false'/>
09:26:09: <max-shutdown-wait v='60'/>
09:26:09: <pause-on-battery v='true'/>
09:26:09: <pause-on-start v='false'/>
09:26:09: <paused v='false'/>
09:26:09: <power v='full'/>
09:26:09:
09:26:09: <!-- User Information -->
09:26:09: <machine-id v='0'/>
09:26:09: <passkey v='********************************'/>
09:26:09: <team v='123'/>
09:26:09: <user v='Tondo5'/>
09:26:09:
09:26:09: <!-- Web Server -->
09:26:09: <web-allow v='127.0.0.1'/>
09:26:09: <web-deny v='0/0'/>
09:26:09: <web-enable v='true'/>
09:26:09:
09:26:09: <!-- Web Server Sessions -->
09:26:09: <session-cookie v='sid'/>
09:26:09: <session-lifetime v='86400'/>
09:26:09: <session-timeout v='3600'/>
09:26:09:
09:26:09: <!-- Work Unit Control -->
09:26:09: <dump-after-deadline v='true'/>
09:26:09: <max-queue v='16'/>
09:26:09: <max-units v='0'/>
09:26:09: <next-unit-percentage v='99'/>
09:26:09: <stall-detection-enabled v='false'/>
09:26:09: <stall-percent v='5'/>
09:26:09: <stall-timeout v='1800'/>
09:26:09:
09:26:09: <!-- Folding Slots -->
09:26:09: <slot id='0' type='CPU'>
09:26:09: <cpus v='4'/>
09:26:09: </slot>
09:26:09:</config>
09:26:09:Trying to access database...
09:26:09:Successfully acquired database lock
09:26:09:Enabled folding slot 00: READY cpu:4
09:26:09:Started thread 6 on PID 4724
09:26:09:Started thread 5 on PID 4724
09:26:09:Started thread 4 on PID 4724
09:26:09:Started thread 8 on PID 4724
09:26:09:Started thread 9 on PID 4724
09:26:09:Started thread 7 on PID 4724
09:26:09:WU00:FS00:Starting
09:26:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/EN33560/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4724 -checkpoint 15 -np 4
09:26:09:WU00:FS00:Started FahCore on PID 5064
09:26:09:Started thread 10 on PID 4724
09:26:09:WU00:FS00:Core PID:5080
09:26:09:WU00:FS00:FahCore 0xa4 started
09:26:09:WU00:FS00:0xa4:
09:26:09:WU00:FS00:0xa4:*------------------------------*
09:26:09:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
09:26:09:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
09:26:09:WU00:FS00:0xa4:Preparing to commence simulation
09:26:09:WU00:FS00:0xa4:- Ensuring status. Please wait.
09:26:19:WU00:FS00:0xa4:- Looking at optimizations...
09:26:19:WU00:FS00:0xa4:- Working with standard loops on this execution.
09:26:19:WU00:FS00:0xa4:- Previous termination of core was improper.
09:26:19:WU00:FS00:0xa4:- Files status OK
09:26:19:WU00:FS00:0xa4:- Expanded 931739 -> 1546812 (decompressed 166.0 percent)
09:26:19:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=931739 data_size=1546812, decompressed_data_size=1546812 diff=0
09:26:19:WU00:FS00:0xa4:- Digital signature verified
09:26:19:WU00:FS00:0xa4:Project: 9013 (Run 399, Clone 3, Gen 50)
09:26:19:WU00:FS00:0xa4:Entering M.D.
09:26:25:WU00:FS00:0xa4:Using Gromacs checkpoints
09:26:25:WU00:FS00:0xa4:Mapping NT from 4 to 4
09:26:26:WU00:FS00:0xa4:Resuming from checkpoint
09:26:26:WU00:FS00:0xa4:Verified 00/wudata_01.log
09:26:26:WU00:FS00:0xa4:Verified 00/wudata_01.trr
09:26:26:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
09:26:26:WU00:FS00:0xa4:Verified 00/wudata_01.edr
09:26:26:WU00:FS00:0xa4:Completed 71740 out of 250000 steps (28%)
09:27:06:Started thread 11 on PID 4724
09:27:36:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
09:30:42:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
09:33:35:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
09:36:37:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
09:39:42:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
09:42:41:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
09:48:53:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
09:51:41:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
09:54:31:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
09:57:34:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
10:00:33:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
10:03:29:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
10:06:22:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
10:09:05:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
10:11:51:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
10:14:37:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
10:17:28:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
10:20:19:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
10:23:32:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
10:26:40:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
10:29:50:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
10:33:09:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
10:36:18:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
10:39:34:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
10:42:22:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
10:45:10:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
10:47:56:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
10:50:41:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
10:53:27:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
10:56:15:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
10:59:00:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
11:01:47:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
11:04:39:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
11:07:42:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
11:10:29:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
11:13:16:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
11:16:03:WU00:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
11:18:50:WU00:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
11:21:37:WU00:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
11:24:24:WU00:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
11:27:14:WU00:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
11:29:59:WU00:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
11:32:45:WU00:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
11:35:33:WU00:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
11:38:21:WU00:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
11:41:08:WU00:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
11:43:55:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
11:46:42:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
11:49:32:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
11:52:31:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
11:55:39:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
11:58:37:WU00:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
12:01:31:WU00:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
12:04:28:WU00:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
12:07:19:WU00:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
12:10:08:WU00:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
12:12:56:WU00:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
12:15:44:WU00:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
12:18:29:WU00:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
12:21:16:WU00:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
12:24:01:WU00:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
12:26:50:WU00:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
12:29:41:WU00:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
12:32:36:WU00:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
12:35:30:WU00:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
12:38:27:WU00:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
12:41:21:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
12:44:09:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
12:47:36:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
12:50:56:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
12:54:05:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
12:54:06:WU01:FS00:Connecting to 171.67.108.200:8080
12:54:07:WU01:FS00:Assigned to work server 171.64.65.99
12:54:07:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.64.65.99
12:54:07:WU01:FS00:Connecting to 171.64.65.99:8080
12:54:10:WU01:FS00:Downloading 6.26MiB
12:54:16:WU01:FS00:Download 18.97%
12:54:22:WU01:FS00:Download 47.92%
12:54:28:WU01:FS00:Download 78.87%
12:54:32:WU01:FS00:Download complete
12:54:32:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9752 run:2561 clone:0 gen:85 core:0xa4 unit:0x00000071ab404163554174eb8d655971
12:57:46:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
12:57:47:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:57:57:WU00:FS00:0xa4:
12:57:57:WU00:FS00:0xa4:Finished Work Unit:
12:57:57:WU00:FS00:0xa4:- Reading up to 922512 from "00/wudata_01.trr": Read 922512
12:57:57:WU00:FS00:0xa4:trr file hash check passed.
12:57:57:WU00:FS00:0xa4:- Reading up to 845328 from "00/wudata_01.xtc": Read 845328
12:57:57:WU00:FS00:0xa4:xtc file hash check passed.
12:57:57:WU00:FS00:0xa4:edr file hash check passed.
12:57:57:WU00:FS00:0xa4:logfile size: 24612
12:57:57:WU00:FS00:0xa4:Leaving Run
12:57:58:WU00:FS00:0xa4:- Writing 1794940 bytes of core data to disk...
12:57:58:WU00:FS00:0xa4:Done: 1794428 -> 1732964 (compressed to 96.5 percent)
12:57:58:WU00:FS00:0xa4: ... Done.
12:57:59:WU00:FS00:0xa4:- Shutting down core
12:57:59:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
12:57:59:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:57:59:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9013 run:399 clone:3 gen:50 core:0xa4 unit:0x00000043ab40417c554e97d316c50c5b
12:57:59:WU00:FS00:Uploading 1.65MiB to 171.64.65.124
12:57:59:WU00:FS00:Connecting to 171.64.65.124:8080
12:57:59:WU01:FS00:Starting
12:57:59:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/EN33560/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 4724 -checkpoint 15 -np 4
12:57:59:WU01:FS00:Started FahCore on PID 4252
12:57:59:Started thread 12 on PID 4724
12:57:59:WU01:FS00:Core PID:6120
12:57:59:WU01:FS00:FahCore 0xa4 started
12:58:00:WU01:FS00:0xa4:
12:58:00:WU01:FS00:0xa4:*------------------------------*
12:58:00:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:58:00:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:58:00:WU01:FS00:0xa4:Preparing to commence simulation
12:58:00:WU01:FS00:0xa4:- Looking at optimizations...
12:58:00:WU01:FS00:0xa4:- Created dyn
12:58:00:WU01:FS00:0xa4:- Files status OK
12:58:03:WU01:FS00:0xa4:- Expanded 6563850 -> 22561724 (decompressed 343.7 percent)
12:58:03:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=6563850 data_size=22561724, decompressed_data_size=22561724 diff=0
12:58:03:WU01:FS00:0xa4:- Digital signature verified
12:58:03:WU01:FS00:0xa4:Project: 9752 (Run 2561, Clone 0, Gen 85)
12:58:03:WU01:FS00:0xa4:Assembly optimizations on if available.
12:58:03:WU01:FS00:0xa4:Entering M.D.
12:58:05:WU00:FS00:Upload 98.30%
12:58:06:WU00:FS00:Upload complete
12:58:06:WU00:FS00:Server responded WORK_ACK (400)
12:58:06:WU00:FS00:Final credit estimate, 1160.00 points
12:58:06:WU00:FS00:Cleaning up
12:58:09:WU01:FS00:0xa4:Mapping NT from 4 to 4
12:58:11:WU01:FS00:0xa4:Completed 0 out of 80000 steps (0%)
13:01:45:WU01:FS00:0xa4:Completed 800 out of 80000 steps (1%)
13:07:46:WU01:FS00:0xa4:Completed 1600 out of 80000 steps (2%)
13:11:17:WU01:FS00:0xa4:Completed 2400 out of 80000 steps (3%)
here i just added the GPU Slot
13:14:57:WU01:FS00:0xa4:Completed 3200 out of 80000 steps (4%)
13:18:55:WU01:FS00:0xa4:Completed 4000 out of 80000 steps (5%)
13:20:03:Adding folding slot 01: READY gpu:0:GT200GL [Quadro FX 4800]
13:20:03:FS00:Shutting core down
13:20:03:Removing old file 'configs/config-20150803-095935.xml'
13:20:03:Saving configuration to config.xml
13:20:03:<config>
13:20:03: <!-- Logging -->
13:20:03: <verbosity v='5'/>
13:20:03:
13:20:03: <!-- Network -->
13:20:03: <proxy v=':8080'/>
13:20:03:
13:20:03: <!-- Slot Control -->
13:20:03: <power v='full'/>
13:20:03:
13:20:03: <!-- User Information -->
13:20:03: <passkey v='********************************'/>
13:20:03: <team v='123'/>
13:20:03: <user v='Tondo5'/>
13:20:03:
13:20:03: <!-- Folding Slots -->
13:20:03: <slot id='0' type='CPU'/>
13:20:03: <slot id='1' type='GPU'>
13:20:03: <client-type v='beta'/>
13:20:03: <max-packet-size v='small'/>
13:20:03: </slot>
13:20:03:</config>
13:20:03:WU00:FS01:Connecting to 171.67.108.200:80
13:20:04:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
13:20:04:WU00:FS01:Connecting to 171.67.108.204:80
13:20:05:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
13:20:05:ERROR:WU00:FS01:Exception: Could not get an assignment
13:20:05:WU00:FS01:Connecting to 171.67.108.200:80
13:20:06:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
13:20:06:WU00:FS01:Connecting to 171.67.108.204:80
13:20:06:WU01:FS00:0xa4:Client no longer detected. Shutting down core
13:20:06:WU01:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
13:20:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:20:06:WU01:FS00:Starting
13:20:06:WARNING:WU01:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
13:20:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/EN33560/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 4724 -checkpoint 15 -np 3
13:20:06:WU01:FS00:Started FahCore on PID 5928
13:20:06:Started thread 13 on PID 4724
13:20:06:WU01:FS00:Core PID:5080
13:20:06:WU01:FS00:FahCore 0xa4 started
13:20:07:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
13:20:07:ERROR:WU00:FS01:Exception: Could not get an assignment
13:20:07:WU01:FS00:0xa4:
13:20:07:WU01:FS00:0xa4:*------------------------------*
13:20:07:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:20:07:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:20:07:WU01:FS00:0xa4:Preparing to commence simulation
13:20:07:WU01:FS00:0xa4:- Looking at optimizations...
13:20:07:WU01:FS00:0xa4:- Files status OK
13:20:09:WU01:FS00:0xa4:- Expanded 6563850 -> 22561724 (decompressed 343.7 percent)
13:20:09:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=6563850 data_size=22561724, decompressed_data_size=22561724 diff=0
13:20:09:WU01:FS00:0xa4:- Digital signature verified
13:20:09:WU01:FS00:0xa4:Project: 9752 (Run 2561, Clone 0, Gen 85)
13:20:10:WU01:FS00:0xa4:Assembly optimizations on if available.
13:20:10:WU01:FS00:0xa4:Entering M.D.
13:20:16:WU01:FS00:0xa4:Using Gromacs checkpoints
13:20:16:WU01:FS00:0xa4:Mapping NT from 3 to 3
13:20:17:WU01:FS00:0xa4:Resuming from checkpoint
13:20:17:WU01:FS00:0xa4:Verified 01/wudata_01.log
13:20:17:WU01:FS00:0xa4:Verified 01/wudata_01.trr
13:20:17:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
13:20:17:WU01:FS00:0xa4:Verified 01/wudata_01.edr
13:20:18:WU01:FS00:0xa4:Completed 2860 out of 80000 steps (3%)
13:21:00:Removing old file 'configs/config-20150803-100454.xml'
13:21:00:Saving configuration to config.xml
13:21:00:<config>
13:21:00: <!-- Logging -->
13:21:00: <verbosity v='5'/>
13:21:00:
13:21:00: <!-- Network -->
13:21:00: <proxy v=':8080'/>
13:21:00:
13:21:00: <!-- Slot Control -->
13:21:00: <power v='full'/>
13:21:00:
13:21:00: <!-- User Information -->
13:21:00: <passkey v='********************************'/>
13:21:00: <team v='123'/>
13:21:00: <user v='Tondo5'/>
13:21:00:
13:21:00: <!-- Folding Slots -->
13:21:00: <slot id='0' type='CPU'/>
13:21:00: <slot id='1' type='GPU'>
13:21:00: <client-type v='beta'/>
13:21:00: <max-packet-size v='small'/>
13:21:00: </slot>
13:21:00:</config>
13:21:05:WU00:FS01:Connecting to 171.67.108.200:80
13:21:06:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
13:21:06:WU00:FS01:Connecting to 171.67.108.204:80
13:21:06:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
13:21:06:ERROR:WU00:FS01:Exception: Could not get an assignment
13:22:10:WU01:FS00:0xa4:Completed 3200 out of 80000 steps (4%)Re: No GPUWU assigned
My Quadro FX 3700 is recognized as a G92 card. I just added the client-type = beta flag and mine started working right away. Sure you have the correct driver? I had to try a couple times to get the right driver for my card.
Ryzen 5900x 12T - RTX 4070 TI
