I tried new AMD driver 15.7 on Windows and had no problem so far.
The performance is the same as AMD driver 14.12 on my GPU AMD R9 280.
AMD driver 15.7
SuperVeloce
Re: AMD driver 15.7
ah, so the tweak with older opencl files is still a must for us with gcn1.0 :/
DarkFoss
- Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5043 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR/Sony Bravia 3(2024) EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.3 LTS Kernel 6.14.x HWE Generic UPS BX1500G
Re: AMD driver 15.7
I can't comment on the older gnc cards anymore since I upgraded from my 2 7970's to the Amd Fury X. Just fired up FAH and it's outperforming both of them on core 17 Project 9201(210,4,513) TPF 1min 36 sec, PPD 340040 ish seems to fluctuate a bit depending on how many browser tabs I have up Temp is a steady 48c fan speed 994 rpm. 15.7 driver seems pretty stable so far.
Re: AMD driver 15.7
If they're active tabs and using the GPU for rendering, that can be expected, Otherwise it might be you've got enough things running to consume enough RAM to thrash (Is your disk light on continuously?).DarkFoss wrote:...seems to fluctuate a bit depending on how many browser tabs I have up...
For most folks who fold with a GPU, it often helps to reconfigure your browser and video player to use the CPU rather than the GPU.
DarkFoss
Re: AMD driver 15.7
Thanks for the tip Bruce. I'm pretty sure I have Firefox hardware acceleration enabled that must be it. I didn't have anything else running at the time.
