Connecting to assign3.stanford.edu
jinjonBoo
Post by jinjonBoo »
Hey guys.
I'm behind a proxy/DNS at work, and i can't download the Work Units, the log says
11:15:04:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
Is there any way to download a Work Unit manually?
Yes, i've already set up the proxy on FAH client 7.7.4, i can't ping assign3.stanford.edu, i can however open it on http//assign3.stanford.edu on IE
Thanks in advance
Re: Connecting to assign3.stanford.edu
First, the terms of use for the folding client do require that you have permission to use work computers for folding. This may at some businesses extend to also having permission to use your own system such as a laptop on the work network. Just mentioning this as while we appreciate contributions from persons at work, we also don't want them getting into trouble for what some some businesses consider unauthorized use.
That said, you may need to talk with your corporate IT people as they would have the local knowledge of the proxy settings required. There may also be firewall issues. The folding client uses http connections over ports 80 and/or 8080 to connect and many firewalls or anti-malware software are by default set to only allow that type of connection from known "browsers" such as IE, Firefox, etc. If this is the case, then the FAHClient process needs to be given the same ability to connect and download or upload data over the network.
jinjonBoo wrote:I can't ping assign3.stanford.edu, i can however open it on http//assign3.stanford.edu on IE
Being able to ping is not a requirement -- and some server admins configure their servers to ignore pings.
The FAHClient uses the same http protocol and the same ports that your browser uses (provided you've set up your proxy server correctly and) provided your security settings allow connections on ports 8080 or 80.
MP3Mike
Post by MP3Mike »
I am getting an error that assign3.stanford.edu does not resolve to an IP address. I have tried via two different Internet connections/Name Servers, so I think the problem is on the Stanford side right now...
DemonfangArun
Post by DemonfangArun »
23:12:41:WARNING:WU01:FS00:Exception: Could not get IP address for assign3.stanford.edu: No such host is known.
23:12:41:ERROR:WU01:FS00:Exception: Could not get an assignment
can confirm same here, unable to connect to assign3.stanford.edu
This user has stopped using F@H because it supports fake crap!
cxh
Pande Group Member
Post by cxh »
Thanks for reporting! We're currently on the case! We'll keep you all posted once a fix is made.
cxh
Pande Group Member
Post by cxh »
Seems like this issue has been corrected, but will take an hour or so to propagate throughout the system. See here for more details: viewtopic.php?f=24&t=28029
sco01
Hardware configuration: Core i7 3930K(C2)@4,2 (1.30v)
Swiftech Apogee Drive II + MCR-H220 Radiator
Asus P9X79
4*4Gb SEC 1600@1866 1.5v
GeForce GTX780ti ref (nztx G10+zalman lq315)
Creative X-Fi Titanium Fatal1ty
Lite-On iHAS124-34
HDD- WD3000GLFS + 2*Hitaсhi HDS723030BLE640 + 2*HDT721010SLA360
case-Corsair Obsidian 700D
PSU - Seasonic Platinum 860W (SS-860XP2)
2) Xeon E5645@4Ghz (1,34v)
ASUS P6T
Thermalright Silver Arrow
Corsair TR3X6G1600C7 (3x2048Mb, 7-7-7-20 1,62v)
GeForce GTX780 ref (nztx G10+corsair H75)
Zotac GTX980 AMP! Edition (ZT-90204-10P)
Hitachi 320Gb HTS543232A7A384
case - Chieftec LBX-03B Dremel edition :-)
PSU - Zalman ZM-850HP+ (Enhance silver)
APC SUA1500RMI2U
APC SUA1500RMI2U
Post by sco01 »
jcoffland » Wed Aug 26, 2015 3:17 am
assign3.stanford.edu and fah.stanford.edu are both back up.
NO
5:23:49:WARNING:WU00:FS01:Exception: Could not get IP address for assign3.stanford.edu: Этот хост неизвестен.
05:23:49:ERROR:WU00:FS01:Exception: Could not get an assignment
05:23:49:WARNING:WU00:FS01:Exception: Could not get IP address for assign3.stanford.edu: Этот хост неизвестен.
on two computers, client I rebooted
Yes, assign3 and 4 are up, but you may need to have your system update its DNS lookup tables. I can reach both without problems now, the change took a couple hours to propagate to my system.
