New to GPU folding - BAD WORK UNIT
enroscado
Post by enroscado »
Hi Guys,
Back folding after a few years out, got a dedicated Ubuntu rig for it, with 2 x GTX 970 (EVGA 04G-P4-2974-KR GeForce GTX 970 4GB)
Just installed 14.04.
After that installed Nvidia 352 drivers using this guide.
Everything goes well, although in the System Info tab in FAHControl I see "CUDA Not detected".
Anyway, thing is, I get "Failed" status in both GPUS, and log read "BAD WORK UNIT".
Here it goes:
21:54:02:Adding folding slot 00: READY gpu:0:GM204 [GeForce GTX 970]
21:54:02:Adding folding slot 01: READY gpu:1:GM204 [GeForce GTX 970]
21:54:02:Removing old file 'configs/config-20150626-210146.xml'
21:54:02:Saving configuration to /etc/fahclient/config.xml
21:54:02:<config>
21:54:02:  <!-- Client Control -->
21:54:02:  <fold-anon v='true'/>
21:54:02:
21:54:02:  <!-- Folding Slot Configuration -->
21:54:02:  <gpu v='false'/>
21:54:02:
21:54:02:  <!-- Network -->
21:54:02:  <proxy v=':8080'/>
21:54:02:
21:54:02:  <!-- User Information -->
21:54:02:  <passkey v='********************************'/>
21:54:02:  <team v='1747'/>
21:54:02:  <user v='enroscado'/>
21:54:02:
21:54:02:  <!-- Folding Slots -->
21:54:02:  <slot id='0' type='GPU'/>
21:54:02:  <slot id='1' type='GPU'/>
21:54:02:</config>
21:54:02:WU00:FS00:Connecting to 171.67.108.200:80
21:54:02:WU01:FS01:Connecting to 171.67.108.200:80
21:54:03:WU01:FS01:Assigned to work server 171.67.108.34
21:54:03:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.34
21:54:03:WU01:FS01:Connecting to 171.67.108.34:8080
21:54:03:WU00:FS00:Assigned to work server 171.64.65.84
21:54:03:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.84
21:54:03:WU00:FS00:Connecting to 171.64.65.84:8080
21:54:04:WU00:FS00:Downloading 3.69MiB
21:54:04:WU01:FS01:Downloading 1.43MiB
21:54:04:WU01:FS01:Download complete
21:54:05:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9832 run:75 clone:4 gen:0 core:0x18 unit:0x000000006652edb25570d4191a0ff341
21:54:05:WU01:FS01:Starting
21:54:05:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:05:WU01:FS01:Started FahCore on PID 3106
21:54:05:WU01:FS01:Core PID:3110
21:54:05:WU01:FS01:FahCore 0x18 started
21:54:05:WU01:FS01:0x18:*********************** Log Started 2015-06-26T21:54:05Z ***********************
21:54:05:WU01:FS01:0x18:Project: 9832 (Run 75, Clone 4, Gen 0)
21:54:05:WU01:FS01:0x18:Unit: 0x000000006652edb25570d4191a0ff341
21:54:05:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:05:WU01:FS01:0x18:Machine: 1
21:54:05:WU01:FS01:0x18:Reading tar file system.xml
21:54:05:WU01:FS01:0x18:Reading tar file integrator.xml
21:54:05:WU01:FS01:0x18:Reading tar file state.xml
21:54:05:WU01:FS01:0x18:Reading tar file core.xml
21:54:05:WU01:FS01:0x18:Digital signatures verified
21:54:05:WU01:FS01:0x18:Folding@home GPU core18
21:54:05:WU01:FS01:0x18:Version 0.0.4
21:54:05:WU01:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:05:WU01:FS01:0x18:Saving result file logfile_01.txt
21:54:05:WU01:FS01:0x18:Saving result file log.txt
21:54:05:WU01:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:05:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:05:WU00:FS00:Download complete
21:54:05:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9832 run:75 clone:4 gen:0 core:0x18 unit:0x000000006652edb25570d4191a0ff341
21:54:05:WU01:FS01:Uploading 1.96KiB to 171.67.108.34
21:54:05:WU01:FS01:Connecting to 171.67.108.34:8080
21:54:06:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9121 run:24 clone:6 gen:17 core:0x18 unit:0x000000130a3b1e78553ea263c1c0fc88
21:54:06:WU00:FS00:Starting
21:54:06:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:06:WU00:FS00:Started FahCore on PID 3115
21:54:06:WU00:FS00:Core PID:3119
21:54:06:WU00:FS00:FahCore 0x18 started
21:54:06:WU02:FS01:Connecting to 171.67.108.200:80
21:54:06:WU01:FS01:Upload complete
21:54:06:WU01:FS01:Server responded WORK_ACK (400)
21:54:06:WU01:FS01:Cleaning up
21:54:06:WU00:FS00:0x18:*********************** Log Started 2015-06-26T21:54:06Z ***********************
21:54:06:WU00:FS00:0x18:Project: 9121 (Run 24, Clone 6, Gen 17)
21:54:06:WU00:FS00:0x18:Unit: 0x000000130a3b1e78553ea263c1c0fc88
21:54:06:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:06:WU00:FS00:0x18:Machine: 0
21:54:06:WU00:FS00:0x18:Reading tar file state.xml
21:54:06:WU00:FS00:0x18:Reading tar file system.xml
21:54:06:WU00:FS00:0x18:Reading tar file integrator.xml
21:54:06:WU00:FS00:0x18:Reading tar file core.xml
21:54:06:WU00:FS00:0x18:Digital signatures verified
21:54:06:WU00:FS00:0x18:Folding@home GPU core18
21:54:06:WU00:FS00:0x18:Version 0.0.4
21:54:06:WU00:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:06:WU00:FS00:0x18:Saving result file logfile_01.txt
21:54:06:WU00:FS00:0x18:Saving result file log.txt
21:54:06:WU00:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:07:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:07:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9121 run:24 clone:6 gen:17 core:0x18 unit:0x000000130a3b1e78553ea263c1c0fc88
21:54:07:WU00:FS00:Uploading 1.97KiB to 171.64.65.84
21:54:07:WU02:FS01:Assigned to work server 171.64.65.84
21:54:07:WU00:FS00:Connecting to 171.64.65.84:8080
21:54:07:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.64.65.84
21:54:07:WU02:FS01:Connecting to 171.64.65.84:8080
21:54:07:WU01:FS00:Connecting to 171.67.108.200:80
21:54:07:WU00:FS00:Upload complete
21:54:07:WU02:FS01:Downloading 3.32MiB
21:54:07:WU00:FS00:Server responded WORK_ACK (400)
21:54:07:WU00:FS00:Cleaning up
21:54:08:WU01:FS00:Assigned to work server 171.64.65.61
21:54:08:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.61
21:54:08:WU01:FS00:Connecting to 171.64.65.61:8080
21:54:09:WU02:FS01:Download complete
21:54:09:WU01:FS00:Downloading 2.76MiB
21:54:09:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9104 run:15 clone:9 gen:115 core:0x18 unit:0x000000970a3b1e78546a58af0d592423
21:54:09:WU02:FS01:Starting
21:54:09:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:09:WU02:FS01:Started FahCore on PID 3124
21:54:09:WU02:FS01:Core PID:3128
21:54:09:WU02:FS01:FahCore 0x18 started
21:54:10:WU02:FS01:0x18:*********************** Log Started 2015-06-26T21:54:09Z ***********************
21:54:10:WU02:FS01:0x18:Project: 9104 (Run 15, Clone 9, Gen 115)
21:54:10:WU02:FS01:0x18:Unit: 0x000000970a3b1e78546a58af0d592423
21:54:10:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:10:WU02:FS01:0x18:Machine: 1
21:54:10:WU02:FS01:0x18:Reading tar file state.xml
21:54:10:WU02:FS01:0x18:Reading tar file system.xml
21:54:10:WU02:FS01:0x18:Reading tar file integrator.xml
21:54:10:WU02:FS01:0x18:Reading tar file core.xml
21:54:10:WU02:FS01:0x18:Digital signatures verified
21:54:10:WU02:FS01:0x18:Folding@home GPU core18
21:54:10:WU02:FS01:0x18:Version 0.0.4
21:54:10:WU02:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:10:WU02:FS01:0x18:Saving result file logfile_01.txt
21:54:10:WU02:FS01:0x18:Saving result file log.txt
21:54:10:WU02:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:10:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:10:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9104 run:15 clone:9 gen:115 core:0x18 unit:0x000000970a3b1e78546a58af0d592423
21:54:10:WU02:FS01:Uploading 1.97KiB to 171.64.65.84
21:54:10:WU02:FS01:Connecting to 171.64.65.84:8080
21:54:10:WU00:FS01:Connecting to 171.67.108.200:80
21:54:10:WU01:FS00:Download complete
21:54:10:WU02:FS01:Upload complete
21:54:11:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9135 run:224 clone:0 gen:1 core:0x18 unit:0x000000020a3b1e615564ed8d6c5c73d6
21:54:11:WU01:FS00:Starting
21:54:11:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:11:WU01:FS00:Started FahCore on PID 3133
21:54:11:WU01:FS00:Core PID:3137
21:54:11:WU01:FS00:FahCore 0x18 started
21:54:11:WU02:FS01:Server responded WORK_ACK (400)
21:54:11:WU02:FS01:Cleaning up
21:54:11:WU01:FS00:0x18:*********************** Log Started 2015-06-26T21:54:11Z ***********************
21:54:11:WU01:FS00:0x18:Project: 9135 (Run 224, Clone 0, Gen 1)
21:54:11:WU01:FS00:0x18:Unit: 0x000000020a3b1e615564ed8d6c5c73d6
21:54:11:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:11:WU01:FS00:0x18:Machine: 0
21:54:11:WU01:FS00:0x18:Reading tar file core.xml
21:54:11:WU01:FS00:0x18:Reading tar file system.xml
21:54:11:WU01:FS00:0x18:Reading tar file integrator.xml
21:54:11:WU01:FS00:0x18:Reading tar file state.xml
21:54:11:WU01:FS00:0x18:Digital signatures verified
21:54:11:WU01:FS00:0x18:Folding@home GPU core18
21:54:11:WU01:FS00:0x18:Version 0.0.4
21:54:11:WU01:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:11:WU01:FS00:0x18:Saving result file logfile_01.txt
21:54:11:WU01:FS00:0x18:Saving result file log.txt
21:54:11:WU01:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:11:WU00:FS01:Assigned to work server 171.67.108.34
21:54:11:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.34
21:54:11:WU00:FS01:Connecting to 171.67.108.34:8080
21:54:12:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:12:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9135 run:224 clone:0 gen:1 core:0x18 unit:0x000000020a3b1e615564ed8d6c5c73d6
21:54:12:WU01:FS00:Uploading 1.97KiB to 171.64.65.61
21:54:12:WU01:FS00:Connecting to 171.64.65.61:8080
21:54:12:WU02:FS00:Connecting to 171.67.108.200:80
21:54:12:WU01:FS00:Upload complete
21:54:12:WU00:FS01:Downloading 1.43MiB
21:54:13:WU01:FS00:Server responded WORK_ACK (400)
21:54:13:WU01:FS00:Cleaning up
21:54:13:WU00:FS01:Download complete
21:54:13:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9832 run:75 clone:5 gen:0 core:0x18 unit:0x000000006652edb25570d419797b1924
21:54:13:WU00:FS01:Starting
21:54:13:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:13:WU00:FS01:Started FahCore on PID 3142
21:54:13:WU00:FS01:Core PID:3146
21:54:13:WU00:FS01:FahCore 0x18 started
21:54:14:WU02:FS00:Assigned to work server 171.67.108.31
21:54:14:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.31
21:54:14:WU02:FS00:Connecting to 171.67.108.31:8080
21:54:14:WU00:FS01:0x18:*********************** Log Started 2015-06-26T21:54:13Z ***********************
21:54:14:WU00:FS01:0x18:Project: 9832 (Run 75, Clone 5, Gen 0)
21:54:14:WU00:FS01:0x18:Unit: 0x000000006652edb25570d419797b1924
21:54:14:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:14:WU00:FS01:0x18:Machine: 1
21:54:14:WU00:FS01:0x18:Reading tar file system.xml
21:54:14:WU00:FS01:0x18:Reading tar file integrator.xml
21:54:14:WU00:FS01:0x18:Reading tar file state.xml
21:54:14:WU00:FS01:0x18:Reading tar file core.xml
21:54:14:WU00:FS01:0x18:Digital signatures verified
21:54:14:WU00:FS01:0x18:Folding@home GPU core18
21:54:14:WU00:FS01:0x18:Version 0.0.4
21:54:14:WU00:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:14:WU00:FS01:0x18:Saving result file logfile_01.txt
21:54:14:WU00:FS01:0x18:Saving result file log.txt
21:54:14:WU00:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:14:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:14:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9832 run:75 clone:5 gen:0 core:0x18 unit:0x000000006652edb25570d419797b1924
21:54:14:WU00:FS01:Uploading 1.97KiB to 171.67.108.34
21:54:14:WU00:FS01:Connecting to 171.67.108.34:8080
21:54:14:WU01:FS01:Connecting to 171.67.108.200:80
21:54:14:WU02:FS00:Downloading 951.57KiB
21:54:15:WU00:FS01:Upload complete
21:54:15:WU00:FS01:Server responded WORK_ACK (400)
21:54:15:WU00:FS01:Cleaning up
21:54:16:WU01:FS01:Assigned to work server 140.163.4.235
21:54:16:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 140.163.4.235
21:54:16:WU01:FS01:Connecting to 140.163.4.235:8080
21:54:16:WU02:FS00:Download complete
21:54:16:WU01:FS01:Downloading 4.83MiB
21:54:16:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9616 run:0 clone:25 gen:156 core:0x18 unit:0x000000c50a3b1e815546ef8402c8e89c
21:54:16:WU02:FS00:Starting
21:54:16:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:16:WU02:FS00:Started FahCore on PID 3151
21:54:16:WU02:FS00:Core PID:3155
21:54:16:WU02:FS00:FahCore 0x18 started
21:54:17:WU02:FS00:0x18:*********************** Log Started 2015-06-26T21:54:17Z ***********************
21:54:17:WU02:FS00:0x18:Project: 9616 (Run 0, Clone 25, Gen 156)
21:54:17:WU02:FS00:0x18:Unit: 0x000000c50a3b1e815546ef8402c8e89c
21:54:17:WU02:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:17:WU02:FS00:0x18:Machine: 0
21:54:17:WU02:FS00:0x18:Reading tar file core.xml
21:54:17:WU02:FS00:0x18:Reading tar file system.xml
21:54:17:WU02:FS00:0x18:Reading tar file integrator.xml
21:54:17:WU02:FS00:0x18:Reading tar file state.xml
21:54:17:WU02:FS00:0x18:Digital signatures verified
21:54:17:WU02:FS00:0x18:Folding@home GPU core18
21:54:17:WU02:FS00:0x18:Version 0.0.4
21:54:17:WU02:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:17:WU02:FS00:0x18:Saving result file logfile_01.txt
21:54:17:WU02:FS00:0x18:Saving result file log.txt
21:54:17:WU02:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:17:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:17:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9616 run:0 clone:25 gen:156 core:0x18 unit:0x000000c50a3b1e815546ef8402c8e89c
21:54:17:WU02:FS00:Uploading 1.97KiB to 171.67.108.31
21:54:17:WU02:FS00:Connecting to 171.67.108.31:8080
21:54:18:WU00:FS00:Connecting to 171.67.108.200:80
21:54:18:WU02:FS00:Upload complete
21:54:18:WU02:FS00:Server responded WORK_ACK (400)
21:54:18:WU02:FS00:Cleaning up
21:54:18:WU00:FS00:Assigned to work server 171.64.65.93
21:54:18:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.93
21:54:18:WU00:FS00:Connecting to 171.64.65.93:8080
21:54:19:WU00:FS00:Downloading 3.54MiB
21:54:19:WU01:FS01:Download complete
21:54:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10473 run:0 clone:73 gen:127 core:0x18 unit:0x000000b1538b3dbb53bec1570c415c6d
21:54:20:WU01:FS01:Starting
21:54:20:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:20:WU01:FS01:Started FahCore on PID 3160
21:54:20:WU01:FS01:Core PID:3164
21:54:20:WU01:FS01:FahCore 0x18 started
21:54:20:WU01:FS01:0x18:*********************** Log Started 2015-06-26T21:54:20Z ***********************
21:54:20:WU01:FS01:0x18:Project: 10473 (Run 0, Clone 73, Gen 127)
21:54:20:WU01:FS01:0x18:Unit: 0x000000b1538b3dbb53bec1570c415c6d
21:54:20:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:20:WU01:FS01:0x18:Machine: 1
21:54:20:WU01:FS01:0x18:Reading tar file state.xml
21:54:20:WU01:FS01:0x18:Reading tar file system.xml
21:54:21:WU01:FS01:0x18:Reading tar file integrator.xml
21:54:21:WU01:FS01:0x18:Reading tar file core.xml
21:54:21:WU01:FS01:0x18:Digital signatures verified
21:54:21:WU01:FS01:0x18:Folding@home GPU core18
21:54:21:WU01:FS01:0x18:Version 0.0.4
21:54:21:WU01:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:21:WU01:FS01:0x18:Saving result file logfile_01.txt
21:54:21:WU01:FS01:0x18:Saving result file log.txt
21:54:21:WU01:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:21:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:21:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:10473 run:0 clone:73 gen:127 core:0x18 unit:0x000000b1538b3dbb53bec1570c415c6d
21:54:21:WU01:FS01:Uploading 1.97KiB to 140.163.4.235
21:54:21:WU01:FS01:Connecting to 140.163.4.235:8080
21:54:21:WU02:FS01:Connecting to 171.67.108.200:80
21:54:21:WU01:FS01:Upload complete
21:54:21:WU01:FS01:Server responded WORK_ACK (400)
21:54:21:WU01:FS01:Cleaning up
21:54:22:WU00:FS00:Download complete
21:54:22:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9129 run:19 clone:1 gen:6 core:0x18 unit:0x000000090a3b1e815549373aebac7b4e
21:54:22:WU00:FS00:Starting
21:54:22:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:22:WU00:FS00:Started FahCore on PID 3169
21:54:22:WU00:FS00:Core PID:3173
21:54:22:WU00:FS00:FahCore 0x18 started
21:54:22:WU02:FS01:Assigned to work server 171.67.108.31
21:54:22:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.31
21:54:22:WU02:FS01:Connecting to 171.67.108.31:8080
21:54:23:WU00:FS00:0x18:*********************** Log Started 2015-06-26T21:54:22Z ***********************
21:54:23:WU00:FS00:0x18:Project: 9129 (Run 19, Clone 1, Gen 6)
21:54:23:WU00:FS00:0x18:Unit: 0x000000090a3b1e815549373aebac7b4e
21:54:23:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:23:WU00:FS00:0x18:Machine: 0
21:54:23:WU00:FS00:0x18:Reading tar file state.xml
21:54:23:WU00:FS00:0x18:Reading tar file system.xml
21:54:23:WU00:FS00:0x18:Reading tar file integrator.xml
21:54:23:WU00:FS00:0x18:Reading tar file core.xml
21:54:23:WU00:FS00:0x18:Digital signatures verified
21:54:23:WU00:FS00:0x18:Folding@home GPU core18
21:54:23:WU00:FS00:0x18:Version 0.0.4
21:54:23:WU00:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:23:WU00:FS00:0x18:Saving result file logfile_01.txt
21:54:23:WU00:FS00:0x18:Saving result file log.txt
21:54:23:WU00:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:23:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:23:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9129 run:19 clone:1 gen:6 core:0x18 unit:0x000000090a3b1e815549373aebac7b4e
21:54:23:WU00:FS00:Uploading 1.97KiB to 171.64.65.93
21:54:23:WU02:FS01:Downloading 1.11MiB
21:54:23:WU00:FS00:Connecting to 171.64.65.93:8080
21:54:23:WU01:FS00:Connecting to 171.67.108.200:80
21:54:24:WU00:FS00:Upload complete
21:54:24:WU00:FS00:Server responded WORK_ACK (400)
21:54:24:WU00:FS00:Cleaning up
21:54:25:Removing old file 'configs/config-20150626-210156.xml'
21:54:25:Saving configuration to /etc/fahclient/config.xml
21:54:25:<config>
21:54:25:  <!-- Client Control -->
21:54:25:  <fold-anon v='true'/>
21:54:25:
21:54:25:  <!-- Folding Slot Configuration -->
21:54:25:  <gpu v='false'/>
21:54:25:
21:54:25:  <!-- Network -->
21:54:25:  <proxy v=':8080'/>
21:54:25:
21:54:25:  <!-- Slot Control -->
21:54:25:  <power v='full'/>
21:54:25:
21:54:25:  <!-- User Information -->
21:54:25:  <passkey v='********************************'/>
21:54:25:  <team v='1747'/>
21:54:25:  <user v='enroscado'/>
21:54:25:
21:54:25:  <!-- Folding Slots -->
21:54:25:  <slot id='0' type='GPU'/>
21:54:25:  <slot id='1' type='GPU'/>
21:54:25:</config>
21:54:25:WU02:FS01:Download complete
21:54:25:WU01:FS00:Assigned to work server 171.64.65.93
21:54:25:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.93
21:54:25:WU01:FS00:Connecting to 171.64.65.93:8080
21:54:25:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9617 run:0 clone:62 gen:17 core:0x18 unit:0x000000130a3b1e815546e65de2099bcf
21:54:25:WU02:FS01:Starting
21:54:25:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:25:WU02:FS01:Started FahCore on PID 3178
21:54:25:WU02:FS01:Core PID:3182
21:54:25:WU02:FS01:FahCore 0x18 started
21:54:26:WU02:FS01:0x18:*********************** Log Started 2015-06-26T21:54:25Z ***********************
21:54:26:WU02:FS01:0x18:Project: 9617 (Run 0, Clone 62, Gen 17)
21:54:26:WU02:FS01:0x18:Unit: 0x000000130a3b1e815546e65de2099bcf
21:54:26:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:26:WU02:FS01:0x18:Machine: 1
21:54:26:WU02:FS01:0x18:Reading tar file core.xml
21:54:26:WU02:FS01:0x18:Reading tar file system.xml
21:54:26:WU02:FS01:0x18:Reading tar file integrator.xml
21:54:26:WU02:FS01:0x18:Reading tar file state.xml
21:54:26:WU02:FS01:0x18:Digital signatures verified
21:54:26:WU02:FS01:0x18:Folding@home GPU core18
21:54:26:WU02:FS01:0x18:Version 0.0.4
21:54:26:WU02:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:26:WU02:FS01:0x18:Saving result file logfile_01.txt
21:54:26:WU02:FS01:0x18:Saving result file log.txt
21:54:26:WU02:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:26:WU01:FS00:Downloading 3.76MiB
21:54:26:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:26:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9617 run:0 clone:62 gen:17 core:0x18 unit:0x000000130a3b1e815546e65de2099bcf
21:54:26:WU02:FS01:Uploading 1.97KiB to 171.67.108.31
21:54:26:WU02:FS01:Connecting to 171.67.108.31:8080
21:54:26:WU00:FS01:Connecting to 171.67.108.200:80
21:54:26:WU01:FS00:Download complete
21:54:26:WU02:FS01:Upload complete
21:54:27:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9113 run:21 clone:3 gen:96 core:0x18 unit:0x000000820a3b1e815473870feb849adb
21:54:27:WU01:FS00:Starting
21:54:27:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:27:WU01:FS00:Started FahCore on PID 3187
21:54:27:WU01:FS00:Core PID:3191
21:54:27:WU01:FS00:FahCore 0x18 started
21:54:27:WU02:FS01:Server responded WORK_ACK (400)
21:54:27:WU02:FS01:Cleaning up
21:54:27:WU01:FS00:0x18:*********************** Log Started 2015-06-26T21:54:27Z ***********************
21:54:27:WU01:FS00:0x18:Project: 9113 (Run 21, Clone 3, Gen 96)
21:54:27:WU01:FS00:0x18:Unit: 0x000000820a3b1e815473870feb849adb
21:54:27:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:27:WU01:FS00:0x18:Machine: 0
21:54:27:WU01:FS00:0x18:Reading tar file state.xml
21:54:27:WU01:FS00:0x18:Reading tar file system.xml
21:54:27:WU01:FS00:0x18:Reading tar file integrator.xml
21:54:27:WU01:FS00:0x18:Reading tar file core.xml
21:54:27:WU01:FS00:0x18:Digital signatures verified
21:54:27:WU01:FS00:0x18:Folding@home GPU core18
21:54:27:WU01:FS00:0x18:Version 0.0.4
21:54:27:WU01:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:27:WU01:FS00:0x18:Saving result file logfile_01.txt
21:54:27:WU01:FS00:0x18:Saving result file log.txt
21:54:27:WU01:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:27:WU00:FS01:Assigned to work server 171.67.108.31
21:54:27:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.31
21:54:27:WU00:FS01:Connecting to 171.67.108.31:8080
21:54:28:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:28:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9113 run:21 clone:3 gen:96 core:0x18 unit:0x000000820a3b1e815473870feb849adb
21:54:28:WU01:FS00:Uploading 1.97KiB to 171.64.65.93
21:54:28:WU01:FS00:Connecting to 171.64.65.93:8080
21:54:28:WU02:FS00:Connecting to 171.67.108.200:80
21:54:28:WU00:FS01:Downloading 561.69KiB
21:54:28:WU01:FS00:Upload complete
21:54:28:WU01:FS00:Server responded WORK_ACK (400)
21:54:28:WU01:FS00:Cleaning up
21:54:29:WU02:FS00:Assigned to work server 171.64.65.93
21:54:29:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.93
21:54:29:WU02:FS00:Connecting to 171.64.65.93:8080
21:54:29:WU00:FS01:Download complete
21:54:30:WU02:FS00:Downloading 3.54MiB
21:54:30:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9609 run:0 clone:66 gen:2 core:0x18 unit:0x000000030a3b1e815546e8a01c125aa3
21:54:30:WU00:FS01:Starting
21:54:30:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:30:WU00:FS01:Started FahCore on PID 3196
21:54:30:WU00:FS01:Core PID:3200
21:54:30:WU00:FS01:FahCore 0x18 started
21:54:30:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:30:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9609 run:0 clone:66 gen:2 core:0x18 unit:0x000000030a3b1e815546e8a01c125aa3
21:54:30:WU00:FS01:Uploading 1.97KiB to 171.67.108.31
21:54:30:WU00:FS01:Connecting to 171.67.108.31:8080
21:54:30:WU01:FS01:Connecting to 171.67.108.200:80
21:54:31:WU00:FS01:Upload complete
21:54:31:WU00:FS01:Server responded WORK_ACK (400)
21:54:31:WU00:FS01:Cleaning up
21:54:31:WU01:FS01:Assigned to work server 171.64.65.93
21:54:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.64.65.93
21:54:31:WU01:FS01:Connecting to 171.64.65.93:8080
21:54:32:WU01:FS01:Downloading 3.61MiB
21:54:32:WU02:FS00:Download complete
21:54:33:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9129 run:19 clone:3 gen:2 core:0x18 unit:0x000000030a3b1e815549373afe02f7cb
21:54:33:WU02:FS00:Starting
21:54:33:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:33:WU02:FS00:Started FahCore on PID 3205
21:54:33:WU02:FS00:Core PID:3209
21:54:33:WU02:FS00:FahCore 0x18 started
21:54:33:WU01:FS01:Download complete
21:54:33:WU02:FS00:0x18:*********************** Log Started 2015-06-26T21:54:33Z ***********************
21:54:33:WU02:FS00:0x18:Project: 9129 (Run 19, Clone 3, Gen 2)
21:54:33:WU02:FS00:0x18:Unit: 0x000000030a3b1e815549373afe02f7cb
21:54:33:WU02:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:33:WU02:FS00:0x18:Machine: 0
21:54:33:WU02:FS00:0x18:Reading tar file state.xml
21:54:33:WU02:FS00:0x18:Reading tar file system.xml
21:54:33:WU02:FS00:0x18:Reading tar file integrator.xml
21:54:33:WU02:FS00:0x18:Reading tar file core.xml
21:54:33:WU02:FS00:0x18:Digital signatures verified
21:54:33:WU02:FS00:0x18:Folding@home GPU core18
21:54:33:WU02:FS00:0x18:Version 0.0.4
21:54:33:WU02:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:33:WU02:FS00:0x18:Saving result file logfile_01.txt
21:54:33:WU02:FS00:0x18:Saving result file log.txt
21:54:33:WU02:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:33:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9105 run:2 clone:5 gen:266 core:0x18 unit:0x0000014f0a3b1e81546bd1da8fa37261
21:54:34:WU01:FS01:Starting
21:54:34:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:34:WU01:FS01:Started FahCore on PID 3214
21:54:34:WU01:FS01:Core PID:3218
21:54:34:WU01:FS01:FahCore 0x18 started
21:54:34:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:34:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9129 run:19 clone:3 gen:2 core:0x18 unit:0x000000030a3b1e815549373afe02f7cb
21:54:34:WU02:FS00:Uploading 1.97KiB to 171.64.65.93
21:54:34:WU02:FS00:Connecting to 171.64.65.93:8080
21:54:34:WU01:FS01:0x18:*********************** Log Started 2015-06-26T21:54:34Z ***********************
21:54:34:WU01:FS01:0x18:Project: 9105 (Run 2, Clone 5, Gen 266)
21:54:34:WU01:FS01:0x18:Unit: 0x0000014f0a3b1e81546bd1da8fa37261
21:54:34:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:34:WU01:FS01:0x18:Machine: 1
21:54:34:WU01:FS01:0x18:Reading tar file state.xml
21:54:34:WU01:FS01:0x18:Reading tar file system.xml
21:54:34:WU00:FS00:Connecting to 171.67.108.200:80
21:54:34:WU02:FS00:Upload complete
21:54:34:WU01:FS01:0x18:Reading tar file integrator.xml
21:54:34:WU01:FS01:0x18:Reading tar file core.xml
21:54:34:WU01:FS01:0x18:Digital signatures verified
21:54:34:WU01:FS01:0x18:Folding@home GPU core18
21:54:34:WU01:FS01:0x18:Version 0.0.4
21:54:34:WU01:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:34:WU01:FS01:0x18:Saving result file logfile_01.txt
21:54:34:WU01:FS01:0x18:Saving result file log.txt
21:54:34:WU01:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:35:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:35:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9105 run:2 clone:5 gen:266 core:0x18 unit:0x0000014f0a3b1e81546bd1da8fa37261
21:54:35:WU01:FS01:Uploading 1.98KiB to 171.64.65.93
21:54:35:WU02:FS00:Server responded WORK_ACK (400)
21:54:35:WU01:FS01:Connecting to 171.64.65.93:8080
21:54:35:WU02:FS00:Cleaning up
21:54:35:WU02:FS01:Connecting to 171.67.108.200:80
21:54:35:WU00:FS00:Assigned to work server 171.67.108.31
21:54:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.31
21:54:35:WU00:FS00:Connecting to 171.67.108.31:8080
21:54:36:WU00:FS00:Downloading 1.11MiB
21:54:36:WU02:FS01:Assigned to work server 171.64.65.93
21:54:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.64.65.93
21:54:36:WU02:FS01:Connecting to 171.64.65.93:8080
21:54:36:WU01:FS01:Upload complete
21:54:36:WU01:FS01:Server responded WORK_ACK (400)
21:54:36:WU01:FS01:Cleaning up
21:54:37:WU02:FS01:Downloading 3.35MiB
21:54:37:WU00:FS00:Download complete
21:54:38:WU02:FS01:Download complete
21:54:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9617 run:0 clone:65 gen:9 core:0x18 unit:0x0000000d0a3b1e815546e65de7ea0f25
21:54:38:WU00:FS00:Starting
21:54:38:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:38:WU00:FS00:Started FahCore on PID 3223
21:54:38:WU00:FS00:Core PID:3227
21:54:38:WU00:FS00:FahCore 0x18 started
21:54:38:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9129 run:20 clone:2 gen:2 core:0x18 unit:0x000000040a3b1e815549373e87ebdda2
21:54:38:WU02:FS01:Starting
21:54:38:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:38:WU02:FS01:Started FahCore on PID 3232
21:54:38:WU02:FS01:Core PID:3236
21:54:38:WU02:FS01:FahCore 0x18 started
21:54:38:WU00:FS00:0x18:*********************** Log Started 2015-06-26T21:54:38Z ***********************
21:54:38:WU00:FS00:0x18:Project: 9617 (Run 0, Clone 65, Gen 9)
21:54:38:WU00:FS00:0x18:Unit: 0x0000000d0a3b1e815546e65de7ea0f25
21:54:38:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:38:WU00:FS00:0x18:Machine: 0
21:54:38:WU00:FS00:0x18:Reading tar file core.xml
21:54:38:WU00:FS00:0x18:Reading tar file system.xml
21:54:38:WU00:FS00:0x18:Reading tar file integrator.xml
21:54:38:WU00:FS00:0x18:Reading tar file state.xml
21:54:38:WU00:FS00:0x18:Digital signatures verified
21:54:38:WU00:FS00:0x18:Folding@home GPU core18
21:54:38:WU00:FS00:0x18:Version 0.0.4
21:54:38:WU00:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:38:WU00:FS00:0x18:Saving result file logfile_01.txt
21:54:38:WU00:FS00:0x18:Saving result file log.txt
21:54:38:WU00:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:38:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:39:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9617 run:0 clone:65 gen:9 core:0x18 unit:0x0000000d0a3b1e815546e65de7ea0f25
21:54:39:WU00:FS00:Uploading 1.98KiB to 171.67.108.31
21:54:39:WU00:FS00:Connecting to 171.67.108.31:8080
21:54:39:WU02:FS01:0x18:*********************** Log Started 2015-06-26T21:54:38Z ***********************
21:54:39:WU02:FS01:0x18:Project: 9129 (Run 20, Clone 2, Gen 2)
21:54:39:WU02:FS01:0x18:Unit: 0x000000040a3b1e815549373e87ebdda2
21:54:39:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:39:WU02:FS01:0x18:Machine: 1
21:54:39:WU02:FS01:0x18:Reading tar file state.xml
21:54:39:WU02:FS01:0x18:Reading tar file system.xml
21:54:39:WU02:FS01:0x18:Reading tar file integrator.xml
21:54:39:WU02:FS01:0x18:Reading tar file core.xml
21:54:39:WU02:FS01:0x18:Digital signatures verified
21:54:39:WU02:FS01:0x18:Folding@home GPU core18
21:54:39:WU02:FS01:0x18:Version 0.0.4
21:54:39:WU02:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:39:WU02:FS01:0x18:Saving result file logfile_01.txt
21:54:39:WU02:FS01:0x18:Saving result file log.txt
21:54:39:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:39:WU00:FS00:Upload complete
21:54:39:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9129 run:20 clone:2 gen:2 core:0x18 unit:0x000000040a3b1e815549373e87ebdda2
21:54:39:WU02:FS01:Uploading 1.97KiB to 171.64.65.93
21:54:39:WU02:FS01:Connecting to 171.64.65.93:8080
21:54:39:WU01:FS00:Connecting to 171.67.108.200:80
21:54:39:WU03:FS01:Connecting to 171.67.108.200:80
21:54:39:WU00:FS00:Server responded WORK_ACK (400)
21:54:39:WU02:FS01:Upload complete
21:54:39:WU00:FS00:Cleaning up
21:54:40:WU01:FS00:Assigned to work server 140.163.4.235
21:54:40:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 140.163.4.235
21:54:40:WU01:FS00:Connecting to 140.163.4.235:8080
21:54:40:WU02:FS01:Server responded WORK_ACK (400)
21:54:40:WU02:FS01:Cleaning up
21:54:40:WU03:FS01:Assigned to work server 171.67.108.31
21:54:40:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.31
21:54:40:WU03:FS01:Connecting to 171.67.108.31:8080
21:54:40:WU01:FS00:Downloading 4.48MiB
21:54:41:WU03:FS01:Downloading 771.83KiB
21:54:41:WU03:FS01:Download complete
21:54:42:WU01:FS00:Download complete
21:54:42:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9612 run:0 clone:58 gen:5 core:0x18 unit:0x000000060a3b1e815546eb7457cc80d5
21:54:42:WU03:FS01:Starting
21:54:42:WU03:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 03 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:42:WU03:FS01:Started FahCore on PID 3241
21:54:42:WU03:FS01:Core PID:3245
21:54:42:WU03:FS01:FahCore 0x18 started
21:54:42:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10484 run:0 clone:19 gen:78 core:0x18 unit:0x00000069538b3dbb54ac2a44201ad7eb
21:54:43:WU01:FS00:Starting
21:54:43:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:43:WU01:FS00:Started FahCore on PID 3250
21:54:43:WU03:FS01:0x18:*********************** Log Started 2015-06-26T21:54:42Z ***********************
21:54:43:WU03:FS01:0x18:Project: 9612 (Run 0, Clone 58, Gen 5)
21:54:43:WU03:FS01:0x18:Unit: 0x000000060a3b1e815546eb7457cc80d5
21:54:43:WU03:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:43:WU03:FS01:0x18:Machine: 1
21:54:43:WU03:FS01:0x18:Reading tar file core.xml
21:54:43:WU03:FS01:0x18:Reading tar file system.xml
21:54:43:WU03:FS01:0x18:Reading tar file integrator.xml
21:54:43:WU03:FS01:0x18:Reading tar file state.xml
21:54:43:WU03:FS01:0x18:Digital signatures verified
21:54:43:WU03:FS01:0x18:Folding@home GPU core18
21:54:43:WU03:FS01:0x18:Version 0.0.4
21:54:43:WU03:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:43:WU03:FS01:0x18:Saving result file logfile_01.txt
21:54:43:WU03:FS01:0x18:Saving result file log.txt
21:54:43:WU03:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:43:WU01:FS00:Core PID:3254
21:54:43:WU01:FS00:FahCore 0x18 started
21:54:43:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:43:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:9612 run:0 clone:58 gen:5 core:0x18 unit:0x000000060a3b1e815546eb7457cc80d5
21:54:43:WU03:FS01:Uploading 1.97KiB to 171.67.108.31
21:54:43:WU03:FS01:Connecting to 171.67.108.31:8080
21:54:43:WU01:FS00:0x18:*********************** Log Started 2015-06-26T21:54:43Z ***********************
21:54:43:WU01:FS00:0x18:Project: 10484 (Run 0, Clone 19, Gen 78)
21:54:43:WU01:FS00:0x18:Unit: 0x00000069538b3dbb54ac2a44201ad7eb
21:54:43:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:43:WU01:FS00:0x18:Machine: 0
21:54:43:WU01:FS00:0x18:Reading tar file state.xml
21:54:43:WU01:FS00:0x18:Reading tar file system.xml
21:54:43:WU00:FS01:Connecting to 171.67.108.200:80
21:54:43:WU03:FS01:Upload complete
21:54:43:WU01:FS00:0x18:Reading tar file integrator.xml
21:54:43:WU01:FS00:0x18:Reading tar file core.xml
21:54:43:WU01:FS00:0x18:Digital signatures verified
21:54:43:WU01:FS00:0x18:Folding@home GPU core18
21:54:43:WU01:FS00:0x18:Version 0.0.4
21:54:43:WU01:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:43:WU01:FS00:0x18:Saving result file logfile_01.txt
21:54:43:WU01:FS00:0x18:Saving result file log.txt
21:54:43:WU01:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:44:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:44:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:10484 run:0 clone:19 gen:78 core:0x18 unit:0x00000069538b3dbb54ac2a44201ad7eb
21:54:44:WU01:FS00:Uploading 1.97KiB to 140.163.4.235
21:54:44:WU01:FS00:Connecting to 140.163.4.235:8080
21:54:44:WU03:FS01:Server responded WORK_ACK (400)
21:54:44:WU01:FS00:Upload complete
21:54:44:WU03:FS01:Cleaning up
21:54:44:WU02:FS00:Connecting to 171.67.108.200:80
21:54:45:WU01:FS00:Server responded WORK_ACK (400)
21:54:45:WU01:FS00:Cleaning up
21:54:45:WU00:FS01:Assigned to work server 171.64.65.93
21:54:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GM204 [GeForce GTX 970] from 171.64.65.93
21:54:45:WU00:FS01:Connecting to 171.64.65.93:8080
21:54:45:WU02:FS00:Assigned to work server 171.64.65.84
21:54:45:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.84
21:54:45:WU02:FS00:Connecting to 171.64.65.84:8080
21:54:46:WU02:FS00:Downloading 3.27MiB
21:54:46:WU00:FS01:Downloading 3.66MiB
21:54:49:WU00:FS01:Download complete
21:54:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9106 run:16 clone:7 gen:118 core:0x18 unit:0x000000a00a3b1e81546bd31645c12fcb
21:54:49:WU00:FS01:Starting
21:54:49:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:54:49:WU00:FS01:Started FahCore on PID 3259
21:54:49:WU00:FS01:Core PID:3263
21:54:49:WU00:FS01:FahCore 0x18 started
21:54:49:WU02:FS00:Download complete
21:54:49:WU00:FS01:0x18:*********************** Log Started 2015-06-26T21:54:49Z ***********************
21:54:49:WU00:FS01:0x18:Project: 9106 (Run 16, Clone 7, Gen 118)
21:54:49:WU00:FS01:0x18:Unit: 0x000000a00a3b1e81546bd31645c12fcb
21:54:49:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:54:49:WU00:FS01:0x18:Machine: 1
21:54:49:WU00:FS01:0x18:Reading tar file state.xml
21:54:49:WU00:FS01:0x18:Reading tar file system.xml
21:54:49:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9104 run:18 clone:2 gen:99 core:0x18 unit:0x000000810a3b1e78546a58b924dfc6fa
21:54:50:WU02:FS00:Starting
21:54:50:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:50:WU02:FS00:Started FahCore on PID 3268
21:54:50:WU02:FS00:Core PID:3272
21:54:50:WU02:FS00:FahCore 0x18 started
21:54:50:WU00:FS01:0x18:Reading tar file integrator.xml
21:54:50:WU00:FS01:0x18:Reading tar file core.xml
21:54:50:WU00:FS01:0x18:Digital signatures verified
21:54:50:WU00:FS01:0x18:Folding@home GPU core18
21:54:50:WU00:FS01:0x18:Version 0.0.4
21:54:50:WU00:FS01:0x18:ERROR:exception: Bad platformId size.
21:54:50:WU00:FS01:0x18:Saving result file logfile_01.txt
21:54:50:WU00:FS01:0x18:Saving result file log.txt
21:54:50:WU00:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:50:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:50:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9106 run:16 clone:7 gen:118 core:0x18 unit:0x000000a00a3b1e81546bd31645c12fcb
21:54:50:WU00:FS01:Uploading 1.98KiB to 171.64.65.93
21:54:50:WU00:FS01:Connecting to 171.64.65.93:8080
21:54:50:WU02:FS00:0x18:*********************** Log Started 2015-06-26T21:54:50Z ***********************
21:54:50:WU02:FS00:0x18:Project: 9104 (Run 18, Clone 2, Gen 99)
21:54:50:WU02:FS00:0x18:Unit: 0x000000810a3b1e78546a58b924dfc6fa
21:54:50:WU02:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:50:WU02:FS00:0x18:Machine: 0
21:54:50:WU02:FS00:0x18:Reading tar file state.xml
21:54:50:WU02:FS00:0x18:Reading tar file system.xml
21:54:50:WU00:FS01:Upload complete
21:54:50:WU02:FS00:0x18:Reading tar file integrator.xml
21:54:50:WU02:FS00:0x18:Reading tar file core.xml
21:54:50:WU02:FS00:0x18:Digital signatures verified
21:54:50:WU02:FS00:0x18:Folding@home GPU core18
21:54:50:WU02:FS00:0x18:Version 0.0.4
21:54:50:WU02:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:50:WU02:FS00:0x18:Saving result file logfile_01.txt
21:54:50:WU02:FS00:0x18:Saving result file log.txt
21:54:50:WU02:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:51:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:51:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9104 run:18 clone:2 gen:99 core:0x18 unit:0x000000810a3b1e78546a58b924dfc6fa
21:54:51:WU02:FS00:Uploading 1.97KiB to 171.64.65.84
21:54:51:WU00:FS01:Server responded WORK_ACK (400)
21:54:51:WU02:FS00:Connecting to 171.64.65.84:8080
21:54:51:WU00:FS01:Cleaning up
21:54:51:WU02:FS00:Upload complete
21:54:51:WU00:FS00:Connecting to 171.67.108.200:80
21:54:51:WU02:FS00:Server responded WORK_ACK (400)
21:54:51:WU02:FS00:Cleaning up
21:54:52:WU00:FS00:Assigned to work server 171.64.65.92
21:54:52:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.92
21:54:52:WU00:FS00:Connecting to 171.64.65.92:8080
21:54:53:WU00:FS00:Downloading 3.20MiB
21:54:54:WU00:FS00:Download complete
21:54:55:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9111 run:20 clone:1 gen:136 core:0x18 unit:0x000000b10a3b1e80547385e0bff104bd
21:54:55:WU00:FS00:Starting
21:54:55:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 2603 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:54:55:WU00:FS00:Started FahCore on PID 3288
21:54:55:WU00:FS00:Core PID:3292
21:54:55:WU00:FS00:FahCore 0x18 started
21:54:55:WU00:FS00:0x18:*********************** Log Started 2015-06-26T21:54:55Z ***********************
21:54:55:WU00:FS00:0x18:Project: 9111 (Run 20, Clone 1, Gen 136)
21:54:55:WU00:FS00:0x18:Unit: 0x000000b10a3b1e80547385e0bff104bd
21:54:55:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
21:54:55:WU00:FS00:0x18:Machine: 0
21:54:55:WU00:FS00:0x18:Reading tar file state.xml
21:54:55:WU00:FS00:0x18:Reading tar file system.xml
21:54:55:WU00:FS00:0x18:Reading tar file integrator.xml
21:54:55:WU00:FS00:0x18:Reading tar file core.xml
21:54:55:WU00:FS00:0x18:Digital signatures verified
21:54:55:WU00:FS00:0x18:Folding@home GPU core18
21:54:55:WU00:FS00:0x18:Version 0.0.4
21:54:55:WU00:FS00:0x18:ERROR:exception: Bad platformId size.
21:54:55:WU00:FS00:0x18:Saving result file logfile_01.txt
21:54:55:WU00:FS00:0x18:Saving result file log.txt
21:54:55:WU00:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:54:55:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:54:55:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9111 run:20 clone:1 gen:136 core:0x18 unit:0x000000b10a3b1e80547385e0bff104bd
21:54:55:WU00:FS00:Uploading 1.98KiB to 171.64.65.92
21:54:55:WU00:FS00:Connecting to 171.64.65.92:8080
21:54:56:WU00:FS00:Upload complete
21:54:56:WU00:FS00:Server responded WORK_ACK (400)
21:54:56:WU00:FS00:Cleaning up
Any help will be greatly appreciated, so I put this rig to fold 24/7.
Thank you.
Re: New to GPU folding - BAD WORK UNIT
I'm running ubuntu 14.04 with a couple of NVidia GPUs though not a 970.
If you use the google search tool with "Bad platformId size." (with quotes) and some other key words outside of the quotes (I used ubuntu) to limit the search somewhat, you'll find a variety of discussions but the general impression is that the drivers are either the wrong ones or they're not installed correctly.
My client reports
06:00:25: CUDA: 5.0
06:00:25:CUDA Driver: 7000
on one system and
00:23:43: CUDA: 3.0
00:23:43:CUDA Driver: 6050
on the other.
I tried the install procedure written by Jesse_V but gave up. He wrote it because at one time it was the only method that really worked. Now I find them under the "Extra drivers" that has been located by apt-get and which produce a painless "normal" (novice) installation. Mine happen to be 340.xx and 346.xx. I have not tried 349 or 352 but wouldn't expect any troubles if they had features I needed.
enroscado
Post by enroscado »
Thank you bruce. Going to look into it today, hopefully up and running later.
I have to mention though: I had nothing under "Extra drivers".
Try. su apt-get update.
If that doesn't work, you probably need to add the appropriate repository from xorg-edgers. See https://help.ubuntu.com/community/Binar ... wto/Nvidia
enroscado
Post by enroscado »
Well, managed to figure it out I think, although I had to do a fresh Ubuntu install.
I believe I should be good to go, although can't know because the download page at stanford appears to be acting up.
I'll try again tomorrow and report back.
Thanks!
enroscado
Post by enroscado »
Ok, still no-go...
No GPUs.txt file. Even after several restarts.
System info tabs shows GPUs: 0
When trying to add GPU slot, I get "not found".
*********************** Log Started 2015-06-29T00:21:38Z ***********************
00:21:38:************************* Folding@home Client *************************
00:21:38:    Website: http://folding.stanford.edu/
00:21:38:  Copyright: (c) 2009-2014 Stanford University
00:21:38:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:21:38:       Args: --child --lifeline 1150 /etc/fahclient/config.xml --run-as
00:21:38:             fahclient --pid-file=/var/run/fahclient.pid --daemon
00:21:38:     Config: /etc/fahclient/config.xml
00:21:38:******************************** Build ********************************
00:21:38:    Version: 7.4.4
00:21:38:       Date: Mar 4 2014
00:21:38:       Time: 12:02:38
00:21:38:    SVN Rev: 4130
00:21:38:     Branch: fah/trunk/client
00:21:38:   Compiler: GNU 4.4.7
00:21:38:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
00:21:38:             -fno-unsafe-math-optimizations -msse2
00:21:38:   Platform: linux2 3.2.0-1-amd64
00:21:38:       Bits: 64
00:21:38:       Mode: Release
00:21:38:******************************* System ********************************
00:21:38:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:21:38:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:21:38:       CPUs: 8
00:21:38:     Memory: 15.62GiB
00:21:38:Free Memory: 15.30GiB
00:21:38:    Threads: POSIX_THREADS
00:21:38: OS Version: 3.16
00:21:38:Has Battery: false
00:21:38: On Battery: false
00:21:38: UTC Offset: -4
00:21:38:        PID: 1152
00:21:38:        CWD: /var/lib/fahclient
00:21:38:         OS: Linux 3.16.0-41-generic x86_64
00:21:38:    OS Arch: AMD64
00:21:38:       GPUs: 0
00:21:38:       CUDA: 5.2
00:21:38:CUDA Driver: 7050
00:21:38:***********************************************************************
00:21:38:<config>
00:21:38:  <!-- Client Control -->
00:21:38:  <fold-anon v='true'/>
00:21:38:
00:21:38:  <!-- Folding Slot Configuration -->
00:21:38:  <gpu v='false'/>
00:21:38:
00:21:38:  <!-- Network -->
00:21:38:  <proxy v=':8080'/>
00:21:38:
00:21:38:  <!-- User Information -->
00:21:38:  <passkey v='********************************'/>
00:21:38:  <team v='1747'/>
00:21:38:  <user v='enroscado'/>
00:21:38:
00:21:38:  <!-- Folding Slots -->
00:21:38:  <slot id='0' type='CPU'>
00:21:38:    <paused v='true'/>
00:21:38:  </slot>
00:21:38:</config>
00:21:38:Switching to user fahclient
00:21:38:Trying to access database...
00:21:38:Successfully acquired database lock
00:21:38:Enabled folding slot 00: PAUSED cpu:7 (by user)
Any ideas?
enroscado
Post by enroscado »
Folding!
Downloaded GPUs.txt, restarted, and working.
Thanks bruce.
