Unknown_Enum x7f error
Nert
Post by Nert »
I got an "Unknown_Enum" error last night on my system. It appears that the unit restarts after the error and does eventually completed. My system is a core 2 duo running two GTX 750 TI's.
I have gotten these from time to time in the past but didn't report them because the units seem to finish. I thought I'd better report this in case there is something that needs to be looked at. Here's the log:
*********************** Log Started 2015-06-14T20:59:49Z ***********************
20:59:49:************************* Folding@home Client *************************
20:59:49:      Website: http://folding.stanford.edu/
20:59:49:    Copyright: (c) 2009-2014 Stanford University
20:59:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:59:49:         Args:
20:59:49:       Config: C:/Users/roger/AppData/Roaming/FAHClient/config.xml
20:59:49:******************************** Build ********************************
20:59:49:      Version: 7.4.4
20:59:49:         Date: Mar 4 2014
20:59:49:         Time: 20:26:54
20:59:49:      SVN Rev: 4130
20:59:49:       Branch: fah/trunk/client
20:59:49:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:59:49:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:59:49:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:59:49:     Platform: win32 XP
20:59:49:         Bits: 32
20:59:49:         Mode: Release
20:59:49:******************************* System ********************************
20:59:49:          CPU: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
20:59:49:       CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
20:59:49:         CPUs: 2
20:59:49:       Memory: 2.31GiB
20:59:49:  Free Memory: 672.96MiB
20:59:49:      Threads: WINDOWS_THREADS
20:59:49:   OS Version: 6.0
20:59:49:  Has Battery: false
20:59:49:   On Battery: false
20:59:49:   UTC Offset: -5
20:59:49:          PID: 5384
20:59:49:          CWD: C:/Users/roger/AppData/Roaming/FAHClient
20:59:49:           OS: Windows Vista (TM) Home Premium Service Pack 2
20:59:49:      OS Arch: X86
20:59:49:         GPUs: 2
20:59:49:        GPU 0: NVIDIA:4 GM107 [GeForce GTX 750 Ti]
20:59:49:        GPU 1: NVIDIA:4 GM107 [GeForce GTX 750 Ti]
20:59:49:         CUDA: 5.0
20:59:49:  CUDA Driver: 7000
20:59:49:Win32 Service: false
20:59:49:***********************************************************************
20:59:49:<config>
20:59:49:  <!-- Network -->
20:59:49:  <proxy v=':8080'/>
20:59:49:
20:59:49:  <!-- User Information -->
20:59:49:  <passkey v='********************************'/>
20:59:49:  <team v='165780'/>
20:59:49:  <user v='Nert'/>
20:59:49:
20:59:49:  <!-- Folding Slots -->
20:59:49:  <slot id='1' type='GPU'/>
20:59:49:  <slot id='2' type='GPU'/>
20:59:49:</config>
20:59:49:Trying to access database...
20:59:52:Successfully acquired database lock
20:59:52:Enabled folding slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti]
20:59:52:Enabled folding slot 02: READY gpu:1:GM107 [GeForce GTX 750 Ti]
20:59:52:WU00:FS02:Starting
++++ Deleted Stuff ++++
02:41:33:WU00:FS02:0x18:Completed 2125000 out of 2500000 steps (85%)
02:43:09:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
02:43:09:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
02:43:09:WARNING:WU00:FS02:FahCore returned an unknown error code which probably indicates that it crashed
02:43:09:WARNING:WU00:FS02:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
02:43:09:WU01:FS01:Starting
02:43:09:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/roger/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 5384 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
02:43:10:WU01:FS01:Started FahCore on PID 4540
02:43:12:WU01:FS01:Core PID:5168
02:43:12:WU01:FS01:FahCore 0x18 started
02:43:12:WU00:FS02:Starting
02:43:12:WU00:FS02:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/roger/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version 704 -lifeline 5384 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
02:43:12:WU00:FS02:Started FahCore on PID 1032
02:43:12:WU00:FS02:Core PID:3456
02:43:12:WU00:FS02:FahCore 0x18 started
02:43:13:WU00:FS02:0x18:*********************** Log Started 2015-06-16T02:43:13Z ***********************
02:43:13:WU00:FS02:0x18:Project: 9122 (Run 18, Clone 1, Gen 8)
02:43:13:WU00:FS02:0x18:Unit: 0x0000000b0a3b1e805543ea8477cd6c1f
02:43:13:WU00:FS02:0x18:CPU: 0x00000000000000000000000000000000
02:43:13:WU00:FS02:0x18:Machine: 2
02:43:13:WU00:FS02:0x18:Digital signatures verified
02:43:13:WU00:FS02:0x18:Folding@home GPU core18
02:43:13:WU00:FS02:0x18:Version 0.0.4
02:43:13:WU01:FS01:0x18:*********************** Log Started 2015-06-16T02:43:13Z ***********************
02:43:13:WU01:FS01:0x18:Project: 10477 (Run 1, Clone 27, Gen 73)
02:43:13:WU01:FS01:0x18:Unit: 0x0000005e538b3dba548b26331684fe28
02:43:13:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
02:43:13:WU01:FS01:0x18:Machine: 1
02:43:13:WU01:FS01:0x18:Digital signatures verified
02:43:13:WU01:FS01:0x18:Folding@home GPU core18
02:43:13:WU01:FS01:0x18:Version 0.0.4
02:43:13:WU00:FS02:0x18:  Found a checkpoint file
02:43:13:WU01:FS01:0x18:  Found a checkpoint file
02:44:25:WU01:FS01:0x18:Completed 4750000 out of 5000000 steps (95%)
02:44:25:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:44:29:WU00:FS02:0x18:Completed 2100000 out of 2500000 steps (84%)
02:44:29:WU00:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:51:26:WU00:FS02:0x18:Completed 2125000 out of 2500000 steps (85%)
02:56:03:WU01:FS01:0x18:Completed 4800000 out of 5000000 steps (96%)
02:57:54:WU00:FS02:0x18:Completed 2150000 out of 2500000 steps (86%)
03:04:19:WU00:FS02:0x18:Completed 2175000 out of 2500000 steps (87%)
******************************* Date: 2015-06-16 *******************************
03:07:21:WU01:FS01:0x18:Completed 4850000 out of 5000000 steps (97%)
03:10:47:WU00:FS02:0x18:Completed 2200000 out of 2500000 steps (88%)
03:17:47:WU00:FS02:0x18:Completed 2225000 out of 2500000 steps (89%)
03:19:01:WU01:FS01:0x18:Completed 4900000 out of 5000000 steps (98%)
03:24:14:WU00:FS02:0x18:Completed 2250000 out of 2500000 steps (90%)
