Project: 9108 (Run 0, Clone 8, Gen 153)
davidcoton
Post by davidcoton »
21:26:59:WU00:FS01:0x18:*********************** Log Started 2015-06-14T21:26:58Z ***********************
21:26:59:WU00:FS01:0x18:Project: 9108 (Run 0, Clone 8, Gen 153)
21:26:59:WU00:FS01:0x18:Unit: 0x000000c70a3b1e80546a95cfca53aa28
21:26:59:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:26:59:WU00:FS01:0x18:Machine: 1
21:26:59:WU00:FS01:0x18:Reading tar file state.xml
21:26:59:WU00:FS01:0x18:Reading tar file system.xml
21:27:00:WU00:FS01:0x18:Reading tar file integrator.xml
21:27:00:WU00:FS01:0x18:Reading tar file core.xml
21:27:00:WU00:FS01:0x18:Digital signatures verified
21:27:00:WU00:FS01:0x18:Folding@home GPU core18
21:27:00:WU00:FS01:0x18:Version 0.0.4
21:27:46:WU00:FS01:0x18:Completed 0 out of 2500000 steps (0%)
21:27:46:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:29:51:WU00:FS01:0x18:Completed 25000 out of 2500000 steps (1%)
21:31:40:WU00:FS01:0x18:Completed 50000 out of 2500000 steps (2%)
21:33:29:WU00:FS01:0x18:Completed 75000 out of 2500000 steps (3%)
21:35:19:WU00:FS01:0x18:Completed 100000 out of 2500000 steps (4%)
21:37:28:WU00:FS01:0x18:Completed 125000 out of 2500000 steps (5%)
21:39:18:WU00:FS01:0x18:Completed 150000 out of 2500000 steps (6%)
21:41:26:WU00:FS01:0x18:ERROR:exception: Error downloading array velm: clEnqueueReadBuffer (-5)
21:41:26:WU00:FS01:0x18:Saving result file logfile_01.txt
21:41:26:WU00:FS01:0x18:Saving result file log.txt
21:41:26:WU00:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:41:27:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:41:28:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9108 run:0 clone:8 gen:153 core:0x18 unit:0x000000c70a3b1e80546a95cfca53aa28
21:41:28:WU00:FS01:Uploading 2.60KiB to 171.64.65.92
21:41:28:WU00:FS01:Connecting to 171.64.65.92:8080
21:41:29:WU00:FS01:Upload complete
21:41:29:WU00:FS01:Server responded WORK_ACK (400)
21:41:30:WU00:FS01:Cleaning up
*********************** Log Started 2015-06-06T22:15:31Z ***********************
22:15:31:************************* Folding@home Client *************************
22:15:31:      Website: http://folding.stanford.edu/
22:15:31:    Copyright: (c) 2009-2014 Stanford University
22:15:31:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:15:31:         Args:
22:15:31:       Config: C:/Users/David/AppData/Roaming/FAHClient/config.xml
22:15:31:******************************** Build ********************************
22:15:31:      Version: 7.4.4
22:15:31:         Date: Mar 4 2014
22:15:31:         Time: 20:26:54
22:15:31:      SVN Rev: 4130
22:15:31:       Branch: fah/trunk/client
22:15:31:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:15:31:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:15:31:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:15:31:     Platform: win32 XP
22:15:31:         Bits: 32
22:15:31:         Mode: Release
22:15:31:******************************* System ********************************
22:15:31:          CPU: AMD Athlon(tm) II X4 640 Processor
22:15:31:       CPU ID: AuthenticAMD Family 16 Model 5 Stepping 3
22:15:31:         CPUs: 4
22:15:31:       Memory: 3.12GiB
22:15:31:  Free Memory: 1.80GiB
22:15:31:      Threads: WINDOWS_THREADS
22:15:31:   OS Version: 6.0
22:15:31:  Has Battery: false
22:15:31:   On Battery: false
22:15:31:   UTC Offset: 1
22:15:31:          PID: 4496
22:15:31:          CWD: C:/Users/David/AppData/Roaming/FAHClient
22:15:31:           OS: Windows Vista (TM) Home Premium Service Pack 2
22:15:31:      OS Arch: X86
22:15:31:         GPUs: 1
22:15:31:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
22:15:31:         CUDA: 5.2
22:15:31:  CUDA Driver: 7000
22:15:31:Win32 Service: false
22:15:31:***********************************************************************
22:15:31:<config>
22:15:31:  <!-- Folding Core -->
22:15:31:  <checkpoint v='5'/>
22:15:31:
22:15:31:  <!-- HTTP Server -->
22:15:31:  <allow v='127.0.0.1 192.168.1.0/24'/>
22:15:31:  <deny v='0.0.0.0/0'/>
22:15:31:  <http-addresses v='127.0.0.1:7396 david-ubuntu:7396'/>
22:15:31:
22:15:31:  <!-- Network -->
22:15:31:  <proxy v=':8080'/>
22:15:31:
22:15:31:  <!-- Remote Command Server -->
22:15:31:  <password v='*******'/>
22:15:31:
22:15:31:  <!-- Slot Control -->
22:15:31:  <power v='full'/>
22:15:31:
22:15:31:  <!-- User Information -->
22:15:31:  <passkey v='********************************'/>
22:15:31:  <user v='davidcoton'/>
22:15:31:
22:15:31:  <!-- Web Server -->
22:15:31:  <web-allow v='127.0.0.1 168.192.1.0/24'/>
22:15:31:
22:15:31:  <!-- Folding Slots -->
22:15:31:  <slot id='0' type='CPU'>
22:15:31:    <client-type v='advanced'/>
22:15:31:    <cpus v='3'/>
22:15:31:    <paused v='true'/>
22:15:31:  </slot>
22:15:31:  <slot id='1' type='GPU'>
22:15:31:  </slot>
22:15:31:</config>
Re: Project: 9108 (Run 0, Clone 8, Gen 153)
Someone else was able to successfully complete this WU:
Your WU (P9108 R0 C8 G153) was added to the stats database on 2015-06-14 18:09:32 for 41215.5 points of credit.
The only other report in the database is from your system with an error code reported.
davidcoton wrote:WU00:FS01:0x18:ERROR:exception: Error downloading array velm: clEnqueueReadBuffer (-5)
That error has been observed by others but data are still being gathered to determine the exact cause.
Was the machine idle at the time or were you using it? If the latter, what programs were running that might be using the GPU concurrently?
davidcoton
From the log times, I was actually using the PC at the time -- probably web browsing (this forum and others).
At about the same time (and probably related) Firefox was misbehaving and I had to kill its process, and there was a video driver error (recovered itself).
There had been an earlier video driver error while the PC was idle, which may correlate that to this (sorry I didn't notice this earlier. HFM is not reporting failed units properly.):
10:32:42:WU02:FS01:Connecting to 171.67.108.200:80
10:32:43:WU02:FS01:Assigned to work server 171.64.65.56
10:32:43:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 980] from 171.64.65.56
10:32:43:WU02:FS01:Connecting to 171.64.65.56:8080
10:32:44:WU02:FS01:Downloading 1.50MiB
10:32:46:WU02:FS01:Download complete
10:32:46:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9430 run:33 clone:6 gen:28 core:0x18 unit:0x00000020ab40413855474c29d18df935
10:33:04:WU02:FS01:Starting
10:33:04:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 5420 -checkpoint 5 -gpu 0 -gpu-vendor nvidia
10:33:04:WU02:FS01:Started FahCore on PID 13392
10:33:04:WU02:FS01:Core PID:13064
10:33:04:WU02:FS01:FahCore 0x18 started
10:33:05:WU02:FS01:0x18:*********************** Log Started 2015-06-14T10:33:05Z ***********************
10:33:05:WU02:FS01:0x18:Project: 9430 (Run 33, Clone 6, Gen 28)
10:33:05:WU02:FS01:0x18:Unit: 0x00000020ab40413855474c29d18df935
10:33:05:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
10:33:05:WU02:FS01:0x18:Machine: 1
10:33:05:WU02:FS01:0x18:Reading tar file state.xml
10:33:05:WU02:FS01:0x18:Reading tar file system.xml
10:33:05:WU02:FS01:0x18:Reading tar file integrator.xml
10:33:05:WU02:FS01:0x18:Reading tar file core.xml
10:33:05:WU02:FS01:0x18:Digital signatures verified
10:33:05:WU02:FS01:0x18:Folding@home GPU core18
10:33:05:WU02:FS01:0x18:Version 0.0.4
10:33:27:WU02:FS01:0x18:Completed 0 out of 16000000 steps (0%)
10:33:27:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:39:33:WU02:FS01:0x18:Completed 160000 out of 16000000 steps (1%)
10:45:31:WU02:FS01:0x18:Completed 320000 out of 16000000 steps (2%)
10:51:24:WU02:FS01:0x18:Completed 480000 out of 16000000 steps (3%)
15:17:51:WU02:FS01:0x18:Completed 7680000 out of 16000000 steps (48%)
15:23:46:WU02:FS01:0x18:Completed 7840000 out of 16000000 steps (49%)
15:29:40:WU02:FS01:0x18:Completed 8000000 out of 16000000 steps (50%)
15:35:42:WU02:FS01:0x18:Completed 8160000 out of 16000000 steps (51%)
15:37:52:WU02:FS01:0x18:ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-5)
15:37:52:WU02:FS01:0x18:Saving result file logfile_01.txt
15:37:52:WU02:FS01:0x18:Saving result file log.txt
15:37:52:WU02:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
15:38:35:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:38:35:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9430 run:33 clone:6 gen:28 core:0x18 unit:0x00000020ab40413855474c29d18df935
15:38:35:WU02:FS01:Uploading 2.92KiB to 171.64.65.56
15:38:35:WU02:FS01:Connecting to 171.64.65.56:8080
15:38:36:WU02:FS01:Upload complete
15:38:37:WU02:FS01:Server responded WORK_ACK (400)
This PC is my main desktop for personal and business use, it usually has many programs open (about a dozen) and Firefox has may tabs open (maybe 15-20). It is normally stable,
Firefox crash info from Windows log:
Faulting application plugin-container.exe,
version 38.0.5.5623,
time stamp 0x5563c49a,
faulting module mozalloc.dll,
time stamp 0x5563b229,
exception code 0x80000003,
fault offset 0x00001aa1,
process id 0x21b4,
application start time 0x01d0a54b2c0e0170.
davidcoton wrote:HFM is not reporting failed units properly.):
The error messages don't follow the pattern that the parser is looking for.
