Project:9752 (run:865 clone:0 gen:1)
goodyca
Post by goodyca »
The subject WU was completed June 3, 2015 at 18:18 UTC. I am unable to find it being credited. Will someone please check to see that it was added as completed? Below is the related log file showing completion and upload.
16:38:08:WU00:FS00:Connecting to 171.67.108.200:8080
16:38:09:WU00:FS00:Assigned to work server 171.64.65.99
16:38:09:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.99
16:38:09:WU00:FS00:Connecting to 171.64.65.99:8080
16:38:12:WU00:FS00:Downloading 6.23MiB
16:38:16:WU00:FS00:Download complete
16:38:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9752 run:865 clone:0 gen:1 core:0xa4 unit:0x00000007ab404163554172d8a654831c
16:39:22:WU00:FS00:Starting
16:39:22:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/beta/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1408 -checkpoint 15 -np 12
16:39:22:WU00:FS00:Started FahCore on PID 13629
16:39:22:WU00:FS00:Core PID:13633
16:39:22:WU00:FS00:FahCore 0xa4 started
16:39:22:WU00:FS00:0xa4:
16:39:22:WU00:FS00:0xa4:*------------------------------*
16:39:22:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
16:39:22:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
16:39:22:WU00:FS00:0xa4:Preparing to commence simulation
16:39:22:WU00:FS00:0xa4:- Looking at optimizations...
16:39:22:WU00:FS00:0xa4:- Created dyn
16:39:22:WU00:FS00:0xa4:- Files status OK
16:39:23:WU00:FS00:0xa4:- Expanded 6535809 -> 22431316 (decompressed 343.2 percent)
16:39:23:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=6535809 data_size=22431316, decompressed_data_size=22431316 diff=0
16:39:23:WU00:FS00:0xa4:- Digital signature verified
16:39:23:WU00:FS00:0xa4:Project: 9752 (Run 865, Clone 0, Gen 1)
16:39:23:WU00:FS00:0xa4:Assembly optimizations on if available.
16:39:23:WU00:FS00:0xa4:Entering M.D.
16:39:30:WU00:FS00:0xa4:Completed 0 out of 80000 steps  (0%)
16:40:25:WU00:FS00:0xa4:Completed 800 out of 80000 steps  (1%)
16:41:19:WU00:FS00:0xa4:Completed 1600 out of 80000 steps  (2%)
18:09:25:WU00:FS00:0xa4:Completed 78400 out of 80000 steps  (98%)
18:10:21:WU00:FS00:0xa4:Completed 79200 out of 80000 steps  (99%)
18:11:16:WU00:FS00:0xa4:Completed 80000 out of 80000 steps  (100%)
18:11:17:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:11:27:WU00:FS00:0xa4:
18:11:27:WU00:FS00:0xa4:Finished Work Unit:
18:11:27:WU00:FS00:0xa4:- Reading up to 4123296 from "00/wudata_01.trr": Read 4123296
18:11:27:WU00:FS00:0xa4:trr file hash check passed.
18:11:27:WU00:FS00:0xa4:- Reading up to 3193768 from "00/wudata_01.xtc": Read 3193768
18:11:27:WU00:FS00:0xa4:xtc file hash check passed.
18:11:27:WU00:FS00:0xa4:edr file hash check passed.
18:11:27:WU00:FS00:0xa4:logfile size: 19604
18:11:27:WU00:FS00:0xa4:Leaving Run
18:11:29:WU00:FS00:0xa4:- Writing 7339060 bytes of core data to disk...
18:11:30:WU00:FS00:0xa4:Done: 7338548 -> 7067684 (compressed to 96.3 percent)
18:11:30:WU00:FS00:0xa4:  ... Done.
18:17:09:WU00:FS00:0xa4:- Shutting down core
18:17:09:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:18:00:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:18:00:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9752 run:865 clone:0 gen:1 core:0xa4 unit:0x00000007ab404163554172d8a654831c
18:18:00:WU00:FS00:Uploading 6.74MiB to 171.64.65.99
18:18:00:WU00:FS00:Connecting to 171.64.65.99:8080
18:18:06:WU00:FS00:Upload 44.51%
18:18:12:WU00:FS00:Upload 73.25%
18:18:21:WU00:FS00:Upload complete
18:18:22:WU00:FS00:Server responded WORK_ACK (400)
18:18:22:WU00:FS00:Final credit estimate, 3283.00 points
18:18:22:WU00:FS00:Cleaning up
Re: Project:9752 (run:865 clone:0 gen:1)
I can't find it in the stats DB :(
goodyca
Post by goodyca »
Thanks for your help.
msultan found the issue, the WU should be credited later today :)
msultan
Pande Group Member
Post by msultan »
It should show up as credited now. Thanks for letting us know about the problem.
Indeed it does :
Hi goodyca (team 439),
Your WU (P9752 R865 C0 G1) was added to the stats database on 2015-06-04 14:34:12 for 3283 points of credit.
