Project: 9009 (Run 262, Clone 2, Gen 0) Won't start
parkut
Post by parkut »
I see a few other 9009 Gen 0 work units are having this same issue
10:02:36:WU01:FS00:0xa4:Completed 0 out of 250000 steps (0%)
10:02:36:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Intel i7-2600 CPU, CentOS Linux system
Config:
*********************** Log Started 2015-06-04T10:01:01Z ***********************
10:01:01:************************* Folding@home Client *************************
10:01:01:    Website: http://folding.stanford.edu/
10:01:01:  Copyright: (c) 2009-2014 Stanford University
10:01:01:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:01:01:       Args: --child --lifeline 16345 /etc/fahclient/config.xml --run-as
10:01:01:             fahclient --pid-file=/var/run/fahclient.pid --daemon
10:01:01:     Config: /etc/fahclient/config.xml
10:01:01:******************************** Build ********************************
10:01:01:    Version: 7.4.4
10:01:01:       Date: Mar 4 2014
10:01:01:       Time: 12:01:17
10:01:01:    SVN Rev: 4130
10:01:01:     Branch: fah/trunk/client
10:01:01:   Compiler: GNU 4.1.2 20080704 (Red Hat 4.1.2-46)
10:01:01:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
10:01:01:             -fno-unsafe-math-optimizations -msse2
10:01:01:   Platform: linux2 2.6.18-164.11.1.el5
10:01:01:       Bits: 64
10:01:01:       Mode: Release
10:01:01:******************************* System ********************************
10:01:01:        CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
10:01:01:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:01:01:       CPUs: 8
10:01:01:     Memory: 7.71GiB
10:01:01:Free Memory: 6.78GiB
10:01:01:    Threads: POSIX_THREADS
10:01:01: OS Version: 2.6
10:01:01:Has Battery: false
10:01:01: On Battery: false
10:01:01: UTC Offset: -4
10:01:01:        PID: 16347
10:01:01:        CWD: /var/lib/fahclient
10:01:01:         OS: Linux 2.6.18-404.el5 x86_64
10:01:01:    OS Arch: AMD64
10:01:01:       GPUs: 0
10:01:01:       CUDA: Not detected
10:01:01:***********************************************************************
10:01:01:<config>
10:01:01:  <!-- HTTP Server -->
10:01:01:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255'/>
10:01:01:
10:01:01:  <!-- Network -->
10:01:01:  <proxy v='192.168.1.188:3128'/>
10:01:01:
10:01:01:  <!-- Remote Command Server -->
10:01:01:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255'/>
10:01:01:
10:01:01:  <!-- Slot Control -->
10:01:01:  <power v='full'/>
10:01:01:
10:01:01:  <!-- User Information -->
10:01:01:  <passkey v='********************************'/>
10:01:01:  <team v='4'/>
10:01:01:  <user v='parkut'/>
10:01:01:
10:01:01:  <!-- Folding Slots -->
10:01:01:  <slot id='0' type='CPU'>
10:01:01:    <client-type v='advanced'/>
10:01:01:  </slot>
10:01:01:</config>
constant retries to start, then exit
10:01:01:Switching to user fahclient
10:01:01:Trying to access database...
10:01:03:Successfully acquired database lock
10:01:03:Enabled folding slot 00: READY cpu:8
10:01:03:WU01:FS00:Starting
10:01:03:WU01:FS00:Removing old file './work/01/logfile_01-20150604-093027.txt'
10:01:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 16347 -checkpoint 15 -np 8
10:01:03:WU01:FS00:Started FahCore on PID 16360
10:01:03:WU01:FS00:Core PID:16364
10:01:03:WU01:FS00:FahCore 0xa4 started
10:01:04:WU01:FS00:0xa4:
10:01:04:WU01:FS00:0xa4:*------------------------------*
10:01:04:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
10:01:04:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:01:04:WU01:FS00:0xa4:Preparing to commence simulation
10:01:04:WU01:FS00:0xa4:- Ensuring status. Please wait.
10:01:13:WU01:FS00:0xa4:- Looking at optimizations...
10:01:13:WU01:FS00:0xa4:- Working with standard loops on this execution.
10:01:13:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
10:01:13:WU01:FS00:0xa4:- Expanded 704701 -> 1476032 (decompressed 209.4 percent)
10:01:13:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=704701 data_size=1476032, decompressed_data_size=1476032 diff=0
10:01:13:WU01:FS00:0xa4:- Digital signature verified
10:01:13:WU01:FS00:0xa4:Project: 9009 (Run 262, Clone 2, Gen 0)
10:01:13:WU01:FS00:0xa4:Entering M.D.
10:01:19:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
10:01:19:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:01:20:WU01:FS00:Starting
10:01:20:WU01:FS00:Removing old file './work/01/logfile_01-20150604-093103.txt'
10:01:20:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 16347 -checkpoint 15 -np 8
10:01:20:WU01:FS00:Started FahCore on PID 16375
10:01:20:WU01:FS00:Core PID:16379
10:01:20:WU01:FS00:FahCore 0xa4 started
10:01:20:WU01:FS00:0xa4:
10:01:20:WU01:FS00:0xa4:*------------------------------*
10:01:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
10:01:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:01:20:WU01:FS00:0xa4:Preparing to commence simulation
10:01:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
10:01:29:WU01:FS00:0xa4:- Looking at optimizations...
10:01:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
10:01:29:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
10:01:29:WU01:FS00:0xa4:- Expanded 704701 -> 1476032 (decompressed 209.4 percent)
10:01:29:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=704701 data_size=1476032, decompressed_data_size=1476032 diff=0
10:01:29:WU01:FS00:0xa4:- Digital signature verified
10:01:29:WU01:FS00:0xa4:Project: 9009 (Run 262, Clone 2, Gen 0)
10:01:29:WU01:FS00:0xa4:Entering M.D.
10:01:36:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
10:01:36:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:02:20:WU01:FS00:Starting
10:02:20:WU01:FS00:Removing old file './work/01/logfile_01-20150604-093120.txt'
10:02:20:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 16347 -checkpoint 15 -np 8
10:02:20:WU01:FS00:Started FahCore on PID 16392
10:02:20:WU01:FS00:Core PID:16396
10:02:20:WU01:FS00:FahCore 0xa4 started
10:02:20:WU01:FS00:0xa4:
10:02:20:WU01:FS00:0xa4:*------------------------------*
10:02:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
10:02:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:02:20:WU01:FS00:0xa4:Preparing to commence simulation
10:02:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
10:02:29:WU01:FS00:0xa4:- Looking at optimizations...
10:02:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
10:02:29:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
10:02:30:WU01:FS00:0xa4:- Expanded 704701 -> 1476032 (decompressed 209.4 percent)
10:02:30:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=704701 data_size=1476032, decompressed_data_size=1476032 diff=0
10:02:30:WU01:FS00:0xa4:- Digital signature verified
10:02:30:WU01:FS00:0xa4:Project: 9009 (Run 262, Clone 2, Gen 0)
10:02:30:WU01:FS00:0xa4:Entering M.D.
10:03:10:Lost lifeline PID 16345, exiting
10:03:11:Clean exit
