[Arch Linux] "FahCore returned: UNKNOWN_ENUM (127 = 0x7f)"
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
VadimP
Post by VadimP »
I keep getting "FahCore returned: UNKNOWN_ENUM (127 = 0x7f)" trying to start a GPU slot. Here is the log:
*********************** Log Started 2015-06-01T21:41:49Z ***********************
******************************* Date: 2015-06-02 *******************************
21:53:59:WU02:FS01:Connecting to 171.67.108.200:80
21:54:01:WU02:FS01:Assigned to work server 171.67.108.52
21:54:01:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Mars [Radeon HD 8500/8700M Series] from 171.67.108.52
21:54:01:WU02:FS01:Connecting to 171.67.108.52:8080
21:54:02:WU02:FS01:Downloading 1.52MiB
21:54:05:WU02:FS01:Download complete
21:54:05:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:718 clone:2 gen:384 core:0x17 unit:0x000002226652edc45399f246af186024
21:54:05:WU02:FS01:Starting
21:54:05:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:54:05:WU02:FS01:Started FahCore on PID 21591
21:54:05:WU02:FS01:Core PID:21595
21:54:05:WU02:FS01:FahCore 0x17 started
21:54:06:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
21:54:06:WU02:FS01:Starting
21:54:06:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:54:06:WU02:FS01:Started FahCore on PID 21596
21:54:06:WU02:FS01:Core PID:21600
21:54:06:WU02:FS01:FahCore 0x17 started
21:55:06:WU02:FS01:Starting
21:55:06:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:55:06:WU02:FS01:Started FahCore on PID 21618
21:55:06:WU02:FS01:Core PID:21622
21:55:06:WU02:FS01:FahCore 0x17 started
21:55:06:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
21:56:06:WU02:FS01:Starting
21:56:06:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:56:06:WU02:FS01:Started FahCore on PID 21662
21:56:06:WU02:FS01:Core PID:21666
21:56:06:WU02:FS01:FahCore 0x17 started
21:56:06:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
21:57:06:WU02:FS01:Starting
21:57:06:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:57:06:WU02:FS01:Started FahCore on PID 21687
21:57:06:WU02:FS01:Core PID:21691
21:57:06:WU02:FS01:FahCore 0x17 started
21:57:06:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
21:57:06:WARNING:WU02:FS01:Too many errors, failing
21:57:06:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:9201 run:718 clone:2 gen:384 core:0x17 unit:0x000002226652edc45399f246af186024
21:57:06:WU02:FS01:Connecting to 171.67.108.52:8080
21:57:07:WU02:FS01:Server responded WORK_ACK (400)
21:57:07:WU02:FS01:Cleaning up
22:00:13:WU02:FS01:Connecting to 171.67.108.200:80
22:00:14:WU02:FS01:Assigned to work server 140.163.4.233
22:00:14:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Mars [Radeon HD 8500/8700M Series] from 140.163.4.233
22:00:14:WU02:FS01:Connecting to 140.163.4.233:8080
22:00:15:WU02:FS01:Downloading 4.94MiB
22:00:21:WU02:FS01:Download 70.89%
22:00:22:WU02:FS01:Download complete
22:00:22:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10469 run:0 clone:211 gen:166 core:0x17 unit:0x00000125538b3db9538f3dd053e7f06f
22:00:22:WU02:FS01:Starting
22:00:22:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:00:22:WU02:FS01:Started FahCore on PID 21821
22:00:22:WU02:FS01:Core PID:21825
22:00:22:WU02:FS01:FahCore 0x17 started
22:00:23:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:00:23:WU02:FS01:Starting
22:00:23:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:00:23:WU02:FS01:Started FahCore on PID 21826
22:00:23:WU02:FS01:Core PID:21830
22:00:23:WU02:FS01:FahCore 0x17 started
22:00:24:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:01:23:WU02:FS01:Starting
22:01:23:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:01:23:WU02:FS01:Started FahCore on PID 21859
22:01:23:WU02:FS01:Core PID:21863
22:01:23:WU02:FS01:FahCore 0x17 started
22:01:24:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:02:23:WU02:FS01:Starting
22:02:23:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:02:23:WU02:FS01:Started FahCore on PID 21903
22:02:23:WU02:FS01:Core PID:21907
22:02:23:WU02:FS01:FahCore 0x17 started
22:02:24:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:03:23:WU02:FS01:Starting
22:03:23:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:03:23:WU02:FS01:Started FahCore on PID 21921
22:03:23:WU02:FS01:Core PID:21925
22:03:23:WU02:FS01:FahCore 0x17 started
22:03:24:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:03:24:WARNING:WU02:FS01:Too many errors, failing
22:03:24:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:10469 run:0 clone:211 gen:166 core:0x17 unit:0x00000125538b3db9538f3dd053e7f06f
22:03:24:WU02:FS01:Connecting to 140.163.4.233:8080
22:03:25:WU02:FS01:Server responded WORK_ACK (400)
22:03:25:WU02:FS01:Cleaning up
22:06:34:WU02:FS01:Connecting to 171.67.108.200:80
22:06:35:WU02:FS01:Assigned to work server 140.163.4.233
22:06:35:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Mars [Radeon HD 8500/8700M Series] from 140.163.4.233
22:06:35:WU02:FS01:Connecting to 140.163.4.233:8080
22:06:36:WU02:FS01:Downloading 2.30MiB
22:06:40:WU02:FS01:Download complete
22:06:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10466 run:0 clone:156 gen:133 core:0x17 unit:0x000000d4538b3db953822e2702414424
22:08:10:WU02:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah
22:08:10:WU02:FS01:Connecting to web.stanford.edu:80
22:08:11:WU02:FS01:FahCore 17: Downloading 3.01MiB
22:08:17:WU02:FS01:FahCore 17: 62.28%
22:08:20:WU02:FS01:FahCore 17: Download complete
22:08:20:WU02:FS01:Valid core signature
22:08:20:WARNING:WU02:FS01:FahCore has not changed since last download, aborting core update
22:08:20:WU02:FS01:Starting
22:08:20:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:08:20:WU02:FS01:Started FahCore on PID 22020
22:08:20:WU02:FS01:Core PID:22024
22:08:20:WU02:FS01:FahCore 0x17 started
22:08:20:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:08:21:WU02:FS01:Starting
22:08:21:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:08:21:WU02:FS01:Started FahCore on PID 22025
22:08:21:WU02:FS01:Core PID:22029
22:08:21:WU02:FS01:FahCore 0x17 started
22:08:21:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:09:21:WU02:FS01:Starting
22:09:21:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:09:21:WU02:FS01:Started FahCore on PID 22055
22:09:21:WU02:FS01:Core PID:22059
22:09:21:WU02:FS01:FahCore 0x17 started
22:09:21:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:10:21:WU02:FS01:Starting
22:10:21:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:10:21:WU02:FS01:Started FahCore on PID 22100
22:10:21:WU02:FS01:Core PID:22104
22:10:21:WU02:FS01:FahCore 0x17 started
22:10:21:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:11:21:WU02:FS01:Starting
22:11:21:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:11:21:WU02:FS01:Started FahCore on PID 22120
22:11:21:WU02:FS01:Core PID:22124
22:11:21:WU02:FS01:FahCore 0x17 started
22:11:21:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:11:21:WARNING:WU02:FS01:Too many errors, failing
22:11:21:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:10466 run:0 clone:156 gen:133 core:0x17 unit:0x000000d4538b3db953822e2702414424
22:11:21:WU02:FS01:Connecting to 140.163.4.233:8080
22:11:22:WU02:FS01:Server responded WORK_ACK (400)
22:11:22:WU02:FS01:Cleaning up
22:14:29:WU02:FS01:Connecting to 171.67.108.200:80
22:14:29:WU02:FS01:Assigned to work server 171.67.108.52
22:14:29:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Mars [Radeon HD 8500/8700M Series] from 171.67.108.52
22:14:29:WU02:FS01:Connecting to 171.67.108.52:8080
22:14:30:WU02:FS01:Downloading 1.53MiB
22:14:35:WU02:FS01:Download complete
22:14:35:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:773 clone:4 gen:296 core:0x17 unit:0x000001bc6652edc45399f475a1e1c8d8
22:14:35:WU02:FS01:Starting
22:14:35:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:14:35:WU02:FS01:Started FahCore on PID 22228
22:14:35:WU02:FS01:Core PID:22232
22:14:35:WU02:FS01:FahCore 0x17 started
22:14:36:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
22:14:36:WU02:FS01:Starting
22:14:36:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:14:36:WU02:FS01:Started FahCore on PID 22241
22:14:36:WU02:FS01:Core PID:22245
22:14:36:WU02:FS01:FahCore 0x17 started
22:15:36:WU02:FS01:Starting
22:15:36:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 4611 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:15:36:WU02:FS01:Started FahCore on PID 22253
22:15:36:WU02:FS01:Core PID:22257
22:15:36:WU02:FS01:FahCore 0x17 started
22:15:36:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
This is the system info. Q&A seems to support my GPU is supported:
Re: "FahCore returned: UNKNOWN_ENUM (127 = 0x7f)"
What drivers are you running on this Linux system? You need to be using the AMD proprietary drivers, and should be using a recent version of them.
seatsea
Post by seatsea »
I've installed the proprietary drivers (Video-catalyst) but I am still getting the same problem.
I am running Manjaro-XFCE 64bit (It's an Arch based distro)
Hello seatsea, welcome to the folding support forum.
Arch Linux is not one of the major 6 Linux variants supported directly by the fah client. See also the https://folding.stanford.edu/home/guide ... all-guide/.
However, there are several topics in this forum where Arch users have worked out how to get FAH running. This Folding Forum Search Link for Arch topics should help.
seatsea
Post by seatsea »
I've managed to get it to work, I didn't know there was a opencl-catalyst package.
Anyone else with this same problem is probably missing that pacakge, to install it, run:
pacman -S opencl-catalyst
compdewd
Hardware configuration: [1] Debian 8 64-bit: EVGA NVIDIA GTX 650 Ti, MSI NVIDIA GTX 460, AMD FX-8120
[2] Windows 7 64-bit: MSI NVIDIA GTX 460, AMD Phenom II X4
Re: [Arch Linux] "FahCore returned: UNKNOWN_ENUM (127 = 0x7f
Post by compdewd »
I know this is an older thread, but I thought it may be worthwhile to add for anyone else that may be experiencing this problem that I was able to resolve this on my installation of Debian 8 thanks to the suggestion of seatsea.
After installing NVIDIA drivers (340.96) as directed at https://wiki.debian.org/NvidiaGraphicsDrivers, I received a `UNKNOWN_ENUM (127 = 0X7f)` error every time I tried to start my GPU slot with a supported graphics card. I had to install the additional NVIDIA packages listed below (along with their dependencies) in order for the FAH Core to start successfully:
  • nvidia-opencl-common - NVIDIA OpenCL Driver
    nvidia-opencl-icd - NVIDIA OpenCL installable client driver (ICD)
    nvidia-libopencl1 - NVIDIA OpenCL ICD Loader library
