Project: 9752 (Run 133, Clone 0, Gen 16)
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Post by billford »
Found this in the log this morning:
04:40:54:WU02:FS00:0xa4:Project: 9752 (Run 133, Clone 0, Gen 16)
04:40:54:WU02:FS00:0xa4:Assembly optimizations on if available.
04:40:54:WU02:FS00:0xa4:Entering M.D.
04:41:00:WU02:FS00:0xa4:mdrun returned 255
04:41:00:WU02:FS00:0xa4:Going to send back what have done -- stepsTotalG=0
04:41:00:WU02:FS00:0xa4:Work fraction=0.0000 steps=0.
04:41:04:WU02:FS00:0xa4:logfile size=2226 infoLength=2226 edr=25 trr=1
04:41:04:WU02:FS00:0xa4:logfile size: 2226 info=2226 bed=25 hdr=1
04:41:04:WU02:FS00:0xa4:- Writing 2764 bytes of core data to disk...
04:41:04:WU02:FS00:0xa4:Done: 2252 -> 1158 (compressed to 51.4 percent)
04:41:04:WU02:FS00:0xa4:  ... Done.
04:42:02:WU02:FS00:0xa4:
04:42:02:WU02:FS00:0xa4:Folding@home Core Shutdown: UNSTABLE_MACHINE
04:42:02:WARNING:WU02:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
04:42:02:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9752 run:133 clone:0 gen:16 core:0xa4 unit:0x00000017ab404163554171c1cc1889ad
04:42:02:WU02:FS00:Uploading 1.63KiB to 171.64.65.99
04:42:02:WU02:FS00:Connecting to 171.64.65.99:8080
04:42:03:WU02:FS00:Upload complete
04:42:03:WU00:FS00:Connecting to 171.67.108.200:8080
04:42:03:WU02:FS00:Server responded WORK_ACK (400)
04:42:03:WU02:FS00:Cleaning up
Bog standard PC, no overclock and it's processed about 15 P9752's before without issue. Possible bad WU?
Config etc:
12:44:18:************************* Folding@home Client *************************
12:44:18:    Website: http://folding.stanford.edu/
12:44:18:  Copyright: (c) 2009-2014 Stanford University
12:44:18:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:44:18:       Args: --child --lifeline 1394 /etc/fahclient/config.xml --run-as
12:44:18:             fahclient --pid-file=/var/run/fahclient.pid --daemon
12:44:18:     Config: /etc/fahclient/config.xml
12:44:18:******************************** Build ********************************
12:44:18:    Version: 7.4.4
12:44:18:       Date: Mar 4 2014
12:44:18:       Time: 12:02:38
12:44:18:    SVN Rev: 4130
12:44:18:     Branch: fah/trunk/client
12:44:18:   Compiler: GNU 4.4.7
12:44:18:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
12:44:18:             -fno-unsafe-math-optimizations -msse2
12:44:18:   Platform: linux2 3.2.0-1-amd64
12:44:18:       Bits: 64
12:44:18:       Mode: Release
12:44:18:******************************* System ********************************
12:44:18:        CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
12:44:18:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:44:18:       CPUs: 4
12:44:18:     Memory: 3.82GiB
12:44:18:Free Memory: 3.30GiB
12:44:18:    Threads: POSIX_THREADS
12:44:18: OS Version: 3.13
12:44:18:Has Battery: false
12:44:18: On Battery: false
12:44:18: UTC Offset: 1
12:44:18:        PID: 1396
12:44:18:        CWD: /var/lib/fahclient
12:44:18:         OS: Linux 3.13.0-37-generic x86_64
12:44:18:    OS Arch: AMD64
12:44:18:       GPUs: 1
12:44:18:      GPU 0: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
12:44:18:       CUDA: 3.5
12:44:18:CUDA Driver: 7000
12:44:18:***********************************************************************
12:44:18:<config>
12:44:18:  <!-- Client Control -->
12:44:18:  <fold-anon v='true'/>
12:44:18:
12:44:18:  <!-- Folding Slot Configuration -->
12:44:18:  <gpu v='false'/>
12:44:18:
12:44:18:  <!-- HTTP Server -->
12:44:18:  <allow v='127.0.0.1 192.168.1.0/24'/>
12:44:18:
12:44:18:  <!-- Network -->
12:44:18:  <proxy v=':8080'/>
12:44:18:
12:44:18:  <!-- Remote Command Server -->
12:44:18:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
12:44:18:
12:44:18:  <!-- Slot Control -->
12:44:18:  <power v='full'/>
12:44:18:
12:44:18:  <!-- User Information -->
12:44:18:  <passkey v='********************************'/>
12:44:18:  <user v='[removed'/>
12:44:18:
12:44:18:  <!-- Work Unit Control -->
12:44:18:  <next-unit-percentage v='100'/>
12:44:18:
12:44:18:  <!-- Folding Slots -->
12:44:18:  <slot id='0' type='CPU'>
12:44:18:    <client-type v='advanced'/>
12:44:18:    <cpus v='3'/>
12:44:18:  </slot>
12:44:18:  <slot id='1' type='GPU'>
12:44:18:    <pause-on-start v='true'/>
12:44:18:  </slot>
12:44:18:</config>
Re: Project: 9752 (Run 133, Clone 0, Gen 16)
billford wrote:Found this in the log this morning:
Confirmed: bad WU.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
bruce wrote: Confirmed: bad WU.
That's a relief :ewink:
Thanks.
