Project: 9704 (Run 0, Clone 4, Gen 53)
davidcoton
Post by davidcoton »
12:08:17:WU00:FS01:Starting
12:08:17:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1035 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:08:17:WU00:FS01:Started FahCore on PID 29177
12:08:17:WU00:FS01:Core PID:29181
12:08:17:WU00:FS01:FahCore 0x21 started
12:08:18:WU00:FS01:0x21:*********************** Log Started 2015-05-19T12:08:17Z ***********************
12:08:18:WU00:FS01:0x21:Project: 9704 (Run 0, Clone 4, Gen 53)
12:08:18:WU00:FS01:0x21:Unit: 0x0000003dab404162551ce8cb2ac088d2
12:08:18:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:08:18:WU00:FS01:0x21:Machine: 1
12:08:18:WU00:FS01:0x21:Reading tar file core.xml
12:08:18:WU00:FS01:0x21:Reading tar file system.xml
12:08:20:WU00:FS01:0x21:Reading tar file integrator.xml
12:08:20:WU00:FS01:0x21:Reading tar file state.xml
12:08:21:WU00:FS01:0x21:Digital signatures verified
12:08:21:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:08:21:WU00:FS01:0x21:Version 0.0.3
12:11:15:WU00:FS01:0x21:Completed 0 out of 640000 steps (0%)
12:11:15:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:13:30:WU00:FS01:0x21:Completed 6400 out of 640000 steps (1%)
12:15:20:WU00:FS01:0x21:Completed 12800 out of 640000 steps (2%)
12:17:09:WU00:FS01:0x21:Completed 19200 out of 640000 steps (3%)
13:26:18:WU00:FS01:0x21:Completed 256000 out of 640000 steps (40%)
13:28:08:WU00:FS01:0x21:Completed 262400 out of 640000 steps (41%)
13:29:57:WU00:FS01:0x21:Completed 268800 out of 640000 steps (42%)
13:31:47:WU00:FS01:0x21:Completed 275200 out of 640000 steps (43%)
13:33:36:WU00:FS01:0x21:Completed 281600 out of 640000 steps (44%)
13:35:26:WU00:FS01:0x21:Completed 288000 out of 640000 steps (45%)
13:43:49:WU00:FS01:0x21:Completed 294400 out of 640000 steps (46%)
15:40:29:WU00:FS01:0x21:Completed 300800 out of 640000 steps (47%)
No further progress reported in 1.5 hours!
Same hardware had problems with a 9704 WU earlier, but now has Ubuntu 15.04 and 346.59 driver.
Pause/unpause has returned it to a checkpoint at 37%
Edit: it has stalled again (and again there is no error or warning) at 78%. Again, pause/fold has resumed from checkpoint.
Setup:
*********************** Log Started 2015-05-10T14:22:57Z ***********************
14:22:57:************************* Folding@home Client *************************
14:22:57:    Website: http://folding.stanford.edu/
14:22:57:  Copyright: (c) 2009-2014 Stanford University
14:22:57:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:22:57:       Args: --child --lifeline 1033 /etc/fahclient/config.xml --run-as
14:22:57:             fahclient --pid-file=/var/run/fahclient.pid --daemon
14:22:57:     Config: /etc/fahclient/config.xml
14:22:57:******************************** Build ********************************
14:22:57:    Version: 7.4.4
14:22:57:       Date: Mar 4 2014
14:22:57:       Time: 12:02:38
14:22:57:    SVN Rev: 4130
14:22:57:     Branch: fah/trunk/client
14:22:57:   Compiler: GNU 4.4.7
14:22:57:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
14:22:57:             -fno-unsafe-math-optimizations -msse2
14:22:57:   Platform: linux2 3.2.0-1-amd64
14:22:57:       Bits: 64
14:22:57:       Mode: Release
14:22:57:******************************* System ********************************
14:22:57:        CPU: AMD Phenom(tm) II X6 1055T Processor
14:22:57:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
14:22:57:       CPUs: 6
14:22:57:     Memory: 3.86GiB
14:22:57:Free Memory: 3.44GiB
14:22:57:    Threads: POSIX_THREADS
14:22:57: OS Version: 3.19
14:22:57:Has Battery: false
14:22:57: On Battery: false
14:22:57: UTC Offset: 1
14:22:57:        PID: 1035
14:22:57:        CWD: /var/lib/fahclient
14:22:57:         OS: Linux 3.19.0-16-generic x86_64
14:22:57:    OS Arch: AMD64
14:22:57:       GPUs: 1
14:22:57:      GPU 0: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
14:22:57:       CUDA: 3.5
14:22:57:CUDA Driver: 7000
14:22:57:***********************************************************************
14:22:57:<config>
14:22:57:  <!-- Client Control -->
14:22:57:  <fold-anon v='true'/>
14:22:57:
14:22:57:  <!-- Folding Slot Configuration -->
14:22:57:  <gpu v='false'/>
14:22:57:
14:22:57:  <!-- HTTP Server -->
14:22:57:  <allow v='127.0.0.1 192.168.1.0/24'/>
14:22:57:
14:22:57:  <!-- Network -->
14:22:57:  <proxy v=':8080'/>
14:22:57:
14:22:57:  <!-- Remote Command Server -->
14:22:57:  <password v='*******'/>
14:22:57:
14:22:57:  <!-- Slot Control -->
14:22:57:  <power v='full'/>
14:22:57:
14:22:57:  <!-- User Information -->
14:22:57:  <passkey v='********************************'/>
14:22:57:  <user v='davidcoton'/>
14:22:57:
14:22:57:  <!-- Folding Slots -->
14:22:57:  <slot id='0' type='CPU'>
14:22:57:    <client-type v='beta'/>
14:22:57:  </slot>
14:22:57:  <slot id='1' type='GPU'>
14:22:57:  </slot>
14:22:57:</config>
Re: Project: 9704 (Run 0, Clone 4, Gen 53)
Most often this type of stoppage of processing on Windows is related to a video driver crash or reset, check your Linux console log to see if that is what happened here.
Beyond that, even though the project has been released to advanced, you should report issues using the beta flag in the Beta Team forum.
davidcoton
Nothing showing in Syslog -- any other places to check?
Are you suggesting that ALL reports of WU issues on Beta enabled PCs should be in the Beta forum? If not what is the criterion (eg, what about Core15 WUs?)? Shall I re-report in Beta, or does one of the Mods want to move the thread?
