Linux Core_18
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Linux Core_18
Post by billford »
I'm slightly confused (not unusual, some would say)- according to this announcement of over a week ago and the spec of my clients I think I should be receiving at least a few Core_18 WUs amongst all the Core_17s, but I'm not getting them.
I realise this could be just a matter of luck, but usually I seem to get anything new fairly promptly and I'd like some reassurance that I haven't set something wrongly if possible?
(I'd like to keep an eye on at least the first few to make sure there are no problems)
edit- I'm also uncertain as to the status of Core_21, mpharrigan's post here rather implies it's out of beta.
General spec (3 PCs) is 64-bit Linux Mint 17.1, 2x GTX 980, 1x GTX 780Ti, drivers NV346.35, FAHClient v7.4.4, all clients set to advanced, sample config:
12:44:06:************************* Folding@home Client *************************
12:44:06:    Website: http://folding.stanford.edu/
12:44:06:  Copyright: (c) 2009-2014 Stanford University
12:44:06:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:44:06:       Args: --child --lifeline 1529 /etc/fahclient/config.xml --run-as
12:44:06:             fahclient --pid-file=/var/run/fahclient.pid --daemon
12:44:06:     Config: /etc/fahclient/config.xml
12:44:06:******************************** Build ********************************
12:44:06:    Version: 7.4.4
12:44:06:       Date: Mar 4 2014
12:44:06:       Time: 12:02:38
12:44:06:    SVN Rev: 4130
12:44:06:     Branch: fah/trunk/client
12:44:06:   Compiler: GNU 4.4.7
12:44:06:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
12:44:06:             -fno-unsafe-math-optimizations -msse2
12:44:06:   Platform: linux2 3.2.0-1-amd64
12:44:06:       Bits: 64
12:44:06:       Mode: Release
12:44:06:******************************* System ********************************
12:44:06:        CPU: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz
12:44:06:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:44:06:       CPUs: 4
12:44:06:     Memory: 3.82GiB
12:44:06:Free Memory: 3.28GiB
12:44:06:    Threads: POSIX_THREADS
12:44:06: OS Version: 3.13
12:44:06:Has Battery: false
12:44:06: On Battery: false
12:44:06: UTC Offset: 1
12:44:06:        PID: 1531
12:44:06:        CWD: /var/lib/fahclient
12:44:06:         OS: Linux 3.13.0-37-generic x86_64
12:44:06:    OS Arch: AMD64
12:44:06:       GPUs: 1
12:44:06:      GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
12:44:06:       CUDA: 5.2
12:44:06:CUDA Driver: 7000
12:44:06:***********************************************************************
12:44:06:<config>
12:44:06:  <!-- Client Control -->
12:44:06:  <fold-anon v='true'/>
12:44:06:
12:44:06:  <!-- Folding Slot Configuration -->
12:44:06:  <gpu v='false'/>
12:44:06:
12:44:06:  <!-- HTTP Server -->
12:44:06:  <allow v='127.0.0.1 192.168.1.0/24'/>
12:44:06:
12:44:06:  <!-- Network -->
12:44:06:  <proxy v=':8080'/>
12:44:06:
12:44:06:  <!-- Remote Command Server -->
12:44:06:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
12:44:06:
12:44:06:  <!-- Slot Control -->
12:44:06:  <power v='full'/>
12:44:06:
12:44:06:  <!-- User Information -->
12:44:06:  <passkey v='********************************'/>
12:44:06:  <user v='[removed]'/>
12:44:06:
12:44:06:  <!-- Work Unit Control -->
12:44:06:  <next-unit-percentage v='100'/>
12:44:06:
12:44:06:  <!-- Folding Slots -->
12:44:06:  <slot id='0' type='CPU'>
12:44:06:    <client-type v='advanced'/>
12:44:06:    <cpus v='3'/>
12:44:06:  </slot>
12:44:06:  <slot id='1' type='GPU'>
12:44:06:  </slot>
12:44:06:</config>
mpharrigan
Pande Group Member
Re: Linux Core_18
Post by mpharrigan »
bruce and vijay have urged caution on rolling out the new version (for windows users). To ease our cognitive load, this unfort. means the linux rollout will also be slowed.
Hang tight!
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Linux Core_18
Post by billford »
Ok thanks, no problem.
mpharrigan wrote:To ease our cognitive load
I like that phrase, I'm sure I can find a use for it elsewhere :wink: :lol:
Re: Linux Core_18
billford wrote:I'm also uncertain as to the status of Core_21, mpharrigan's post here rather implies it's out of beta.
As you've probably heard before, the Pande Group never gives a prediction of when software will be released. Apparently mpharrigan forgot about that policy when he said "throughout this week." :D
Rest assured that Core_21 will be rolled out soon. The Work Servers that will soon distribute projects for that core currently show that they're not issuing WUs. It would be imprudent of me to suggest that nobody wanted to roll out anything new just before a holiday weekend, but that would suggest that my use of the word "soon" means "really soon" and I do not know that to necessarily be true.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Linux Core_18
Post by billford »
Understood, thanks.
mpharrigan
Pande Group Member
Re: Linux Core_18
Sorry for the confusion. cxh and I have made announcements regarding rollout of core18 and core21
Skufer
Re: Linux Core_18
Post by Skufer »
I've been getting a few core_18 WUs on Linux and it's safe to say that the PPD is much worse than core_17, getting nearly 20% less PPD. Is this something that's likely to improve? I fold under Linux in order to avoid core_15 so I'll be a little upset if core_18 turns out to be its successor.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Linux Core_18
Post by billford »
BestPony wrote:I've been getting a few core_18 WUs on Linux and it's safe to say that the PPD is much worse than core_17, getting nearly 20% less PPD. Is this something that's likely to improve? I fold under Linux in order to avoid core_15 so I'll be a little upset if core_18 turns out to be its successor.
I'm not sure it's safe to say that it's much worse than Core_17, but it's certainly a lot more variable and possibly card-dependent. I'm also using Linux with 346.35 drivers.
On my GTX 780Ti (Kepler) a Core_17 would typically return ~220K PPD, Core_18s range from 210K-245K, ie about the same. Core_21s run at ~325K-350K, ie about 50% high.
A GTX 980 (Maxwell) on Core_17 was typically ~410K, Core_18s range from 335K (very low) to 580K (insane!). Core_21s run about the same as Core_17s but with a much wider variation (+/- 40K).
On the distribution of WUs I've had so far my overall PPD seems within a few percent of what it was before.
Re: Linux Core_18
Cores 17. 18, 21 cannot be considered a successor to the lower PPD of Core 15 (at least lower on a fast machine). Core 15 gets a constant number of points no matter how quickly you finish it. (Half the time = double the PPD). The others get bonus points, where the total points awarded increases with speed. (twice the speed = MORE than double the PPD).
Re: Linux Core_18
It's very simple. The work units are benchmarked on X hardware. If you have Y hardware, Y will run some work units faster than X, and some work units slower that X. Not all work units are the same size or same code. Some work units like the faster memory on X, and on some work units it makes no difference. Some work units like the bigger cache size on Y and run faster than X, and on some work units, it doesn't matter.
If you don't have the same hardware as X, the PPD will always vary. Nothing to be concerned about, or anything that can be done about it.
Re: Linux Core_18
Which GPU do you use to fold ?
DarthBaggins
Hardware configuration: i7 5930k @ 4.5 - 1.220
GSkill RipJaw 4 16GB DDR4 2400
Asus Rampage V Extreme
Asus Strix GTX970 (1545)
Samsung 840 Pro 128GB (x2)
Corsair Foce GS 128GB
Seagate Barracuda 2TB 7200 RPM
Corsair RM850
CaseLabs M8 w/ Pedestal
Re: Linux Core_18
Post by DarthBaggins »
You might want to go into the Advnced section under config (pause client first) and remove the GPU = False flag
5930k @ 4.5 - GSkill Ripjaw 4 16GB DDR4 2400 - Strix GTX970 @ 1555
2 x Samsung 840 Pro 128GB - 1 x Corsair Force GS 128GB - 2 x Seagate Barracuda 2TB
Asus Rampage V Extreme - Corsair RM850 - CaseLabs M8 w/ Pedestal (custom loop)
