Hey folders!
I have never played with folding@home before, and I have a dedicated Linux server (Ubuntu Server 14.04) which could help with the research project.
I also did a lot research about it, and also readed the Linux Install Guide several times, without finding the informationen I need.
Problem is - my Linux server runs without X11, and also without Apache. SSH is the only way in.
That excludes Web Control, FAHControl and FAHViewer as I understand.
Are there other ways to install and control the folding only using SSH?
Install on Linux without X11?
Re: Install on Linux without X11?
Welcome to the forums pazau!
You can download a tarball only release of the client from here https://fah-web.stanford.edu/projects/F ... llReleases (they aren't actually beta releases), which you can use to run the Folding@home client from a terminal with no X server.
You can also just use the regular install package on the server; I have that on my virtual folding box (Ubuntu 12.04) but only for CPU folding. Not sure if GPU folding would work w/o X; think not; but that's more a driver issue.
Once you configure the folding client you can also remote connect from a windows/Mac/Linus version of FAHcontrol to the server; works pretty well.
Thanks uncle_fungus, but I prefer to install from a .deb since I have received a lot of problems with tarballs... :p
ChristianVirtual: Do you mean the installer-script from the Linux Install Guide or? Which packages do I need?
EDIT: I forgot to mention that because it is a dedicated server, there is no graphics card onboard. Only the built-in Intel, which isn't for much use for this project.
Mainly his one
https://fah.stanford.edu/file-releases/ ... _amd64.deb
You can find it via this forum in header area and "The Software"; always download from there ...
See also the questions and answers provided here viewtopic.php?f=96&t=27619
Also, a single FAHControl instance (using X11 or Windows or MacOS) can monitor and control all instances of FAHClient on your LAN.
Take the "beta" out of the URL for the public version. (same exact files, at this time, may be different in the future)uncle_fungus wrote:Welcome to the forums pazau!
And no need to be concerned about these tarballs. It's just the client executable in compressed format. Nothing else.
But please note:
FAH V7 WIKI wrote:These are .tar.bz2 releases of the console only client for experts only. They are without installer, and are self-supported: FAHClient --help
Sorry for the VERY late reply, and many thanks for the answers folks!
I only downloaded the standalone FAHClient and started it under a screen session - that way I could configure and control it over the SSH connection.
What I realized, was that the client spawns slots with the lowest thread priority - meaning that ressources for the other programs shouln't be a problem at all!
