Gtx 970 yelding lower PPD lately?
So, I remember that when I got into folding at the beginning of the year, my gtx 970 used to have a 240k PPD on Core 17 units. I have stopped folding for sometime; recently I got back, and to my surprise, Core 17 is only handing out around 110k PPD. It also seems that WUs are taking a lot longer to complete. They would generally finish at around 5h, but not it seems that each WU is taking close to 11~12h for completition.
Is something wrong with my system? Or has the servers/WUs changed recently, and I'm having a normal behavior?
ChristianVirtual
Re: Gtx 970 yelding lower PPD lately?
Some WU/projects take more time then others; that's normal, but the resulting PPD should be comparable.
Any other change in your system or configuration ? What driver version for NV you use ?
What projects you got assigned ? Can you share the relevant part of your log files ?
Yes, some do take longer and some are shorter. But regardless, both are giving a lot less than it used to. The only major changes are the upgrade to Windows 8.1 and the driver updtates. Currently using 350.12.ChristianVirtual wrote:Some WU/projects take more time then others; that's normal, but the resulting PPD should be comparable.
Have fun with around as much of a log as the 6k charachter limit allows me. Btw, isn't there a spoiler tag?
02:04:53:WU01:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
02:07:43:WU01:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
02:10:33:WU01:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
02:13:22:WU01:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
02:16:12:WU01:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
02:19:02:WU01:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
02:21:51:WU01:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
02:24:42:WU01:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
02:24:48:WU00:FS01:Connecting to 171.67.108.200:80
02:24:49:WU00:FS01:Assigned to work server 171.67.108.142
02:24:49:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.67.108.142
02:24:49:WU00:FS01:Connecting to 171.67.108.142:8080
02:24:50:WU00:FS01:Downloading 142.58KiB
02:24:52:WU00:FS01:Download complete
02:24:52:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8018 run:174 clone:1 gen:372 core:0x15 unit:0x000001b96953ee2e500f1be206d3aa69
02:27:32:WU01:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
02:27:38:WU01:FS01:0x17:Saving result file logfile_01.txt
02:27:39:WU01:FS01:0x17:Saving result file checkpointState.xml
02:27:40:WU01:FS01:0x17:Saving result file checkpt.crc
02:27:40:WU01:FS01:0x17:Saving result file log.txt
02:27:40:WU01:FS01:0x17:Saving result file positions.xtc
02:27:43:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
02:27:43:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:27:43:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9201 run:255 clone:3 gen:318 core:0x17 unit:0x000001cd6652edc45399e00d149d0934
02:27:43:WU01:FS01:Uploading 8.33MiB to 171.67.108.52
02:27:43:WU01:FS01:Connecting to 171.67.108.52:8080
02:27:43:WU00:FS01:Starting
02:27:43:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rafael/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 2084 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
02:27:43:WU00:FS01:Started FahCore on PID 6776
02:27:43:WU00:FS01:Core PID:6076
02:27:43:WU00:FS01:FahCore 0x15 started
02:27:44:WU00:FS01:0x15:
02:27:44:WU00:FS01:0x15:*------------------------------*
02:27:44:WU00:FS01:0x15:Folding@Home GPU Core
02:27:44:WU00:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
02:27:44:WU00:FS01:0x15:Build host AmoebaRemote
02:27:44:WU00:FS01:0x15:Board Type NVIDIA/CUDA
02:27:44:WU00:FS01:0x15:Core 15
02:27:44:WU00:FS01:0x15:Window's signal control handler registered.
02:27:44:WU00:FS01:0x15:Preparing to commence simulation
02:27:44:WU00:FS01:0x15:- Looking at optimizations...
02:27:44:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
02:27:44:WU00:FS01:0x15:- Created dyn
02:27:44:WU00:FS01:0x15:- Files status OK
02:27:44:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
02:27:44:WU00:FS01:0x15:- Expanded 145490 -> 660986 (decompressed 454.3 percent)
02:27:44:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=145490 data_size=660986, decompressed_data_size=660986 diff=0
02:27:44:WU00:FS01:0x15:- Digital signature verified
02:27:44:WU00:FS01:0x15:Project: 8018 (Run 174, Clone 1, Gen 372)
02:27:44:WU00:FS01:0x15:Assembly optimizations on if available.
02:27:44:WU00:FS01:0x15:Entering M.D.
02:27:46:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr: 1254533055 2452790923 4116738299 94256902 2019172265
02:27:46:WU00:FS01:0x15:GPU device id=0
02:27:46:WU00:FS01:0x15:Working on GRowing Old MAkes el Chrono Sweat
02:27:46:WU00:FS01:0x15:Client config unavailable.
02:27:46:WU00:FS01:0x15:Starting GUI Server
02:27:49:WU01:FS01:Upload 3.75%
02:28:18:WU01:FS01:Upload 4.50%
02:28:18:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
02:28:18:WU01:FS01:Trying to send results to collection server
02:28:18:WU01:FS01:Uploading 8.33MiB to 171.65.103.160
02:28:18:WU01:FS01:Connecting to 171.65.103.160:8080
02:28:24:WU01:FS01:Upload 3.00%
02:28:30:WU01:FS01:Upload 7.50%
02:28:36:WU01:FS01:Upload 15.01%
02:28:42:WU01:FS01:Upload 22.51%
02:28:48:WU01:FS01:Upload 30.02%
02:28:49:WU00:FS01:0x15:Setting checkpoint frequency: 250000
02:28:49:WU00:FS01:0x15:Completed 3 out of 25000000 steps (0%).
02:28:54:WU01:FS01:Upload 33.77%
02:29:00:WU01:FS01:Upload 41.28%
02:29:06:WU01:FS01:Upload 47.28%
02:29:12:WU01:FS01:Upload 54.79%
02:29:18:WU01:FS01:Upload 61.54%
02:29:24:WU01:FS01:Upload 66.79%
02:29:30:WU01:FS01:Upload 74.30%
02:29:36:WU01:FS01:Upload 82.55%
02:29:42:WU01:FS01:Upload 88.56%
02:29:48:WU01:FS01:Upload 96.06%
02:29:55:WU01:FS01:Upload complete
02:29:56:WU01:FS01:Server responded WORK_ACK (400)
02:29:56:WU01:FS01:Final credit estimate, 28122.00 points
02:29:56:WU01:FS01:Cleaning up
02:30:56:WU00:FS01:0x15:Completed 250000 out of 25000000 steps (1%).
02:33:02:WU00:FS01:0x15:Completed 500000 out of 25000000 steps (2%).
02:35:08:WU00:FS01:0x15:Completed 750000 out of 25000000 steps (3%).
02:37:15:WU00:FS01:0x15:Completed 1000000 out of 25000000 steps (4%).
02:39:21:WU00:FS01:0x15:Completed 1250000 out of 25000000 steps (5%).
02:41:27:WU00:FS01:0x15:Completed 1500000 out of 25000000 steps (6%).
02:43:34:WU00:FS01:0x15:Completed 1750000 out of 25000000 steps (7%).
02:45:40:WU00:FS01:0x15:Completed 2000000 out of 25000000 steps (8%).
02:47:46:WU00:FS01:0x15:Completed 2250000 out of 25000000 steps (9%).
02:49:53:WU00:FS01:0x15:Completed 2500000 out of 25000000 steps (10%).
02:51:59:WU00:FS01:0x15:Completed 2750000 out of 25000000 steps (11%).
02:54:05:WU00:FS01:0x15:Completed 3000000 out of 25000000 steps (12%).
02:56:12:WU00:FS01:0x15:Completed 3250000 out of 25000000 steps (13%).
02:58:18:WU00:FS01:0x15:Completed 3500000 out of 25000000 steps (14%).
03:00:25:WU00:FS01:0x15:Completed 3750000 out of 25000000 steps (15%).
03:02:31:WU00:FS01:0x15:Completed 4000000 out of 25000000 steps (16%).
03:04:37:WU00:FS01:0x15:Completed 4250000 out of 25000000 steps (17%).
03:06:44:WU00:FS01:0x15:Completed 4500000 out of 25000000 steps (18%).
03:08:50:WU00:FS01:0x15:Completed 4750000 out of 25000000 steps (19%).
03:10:56:WU00:FS01:0x15:Completed 5000000 out of 25000000 steps (20%).
03:13:02:WU00:FS01:0x15:Completed 5250000 out of 25000000 steps (21%).
03:15:14:WU00:FS01:0x15:Completed 5500000 out of 25000000 steps (22%).
03:17:27:WU00:FS01:0x15:Completed 5750000 out of 25000000 steps (23%).
03:19:40:WU00:FS01:0x15:Completed 6000000 out of 25000000 steps (24%).
03:21:55:WU00:FS01:0x15:Completed 6250000 out of 25000000 steps (25%).
03:24:08:WU00:FS01:0x15:Completed 6500000 out of 25000000 steps (26%).
03:26:21:WU00:FS01:0x15:Completed 6750000 out of 25000000 steps (27%).
03:28:34:WU00:FS01:0x15:Completed 7000000 out of 25000000 steps (28%).
03:30:47:WU00:FS01:0x15:Completed 7250000 out of 25000000 steps (29%).
03:33:00:WU00:FS01:0x15:Completed 7500000 out of 25000000 steps (30%).
03:35:13:WU00:FS01:0x15:Completed 7750000 out of 25000000 steps (31%).
03:37:26:WU00:FS01:0x15:Completed 8000000 out of 25000000 steps (32%).
03:39:39:WU00:FS01:0x15:Completed 8250000 out of 25000000 steps (33%).
03:41:52:WU00:FS01:0x15:Completed 8500000 out of 25000000 steps (34%).
03:44:05:WU00:FS01:0x15:Completed 8750000 out of 25000000 steps (35%).
03:46:18:WU00:FS01:0x15:Completed 9000000 out of 25000000 steps (36%).
******************************* Date: 2015-04-19 *******************************
03:48:31:WU00:FS01:0x15:Completed 9250000 out of 25000000 steps (37%).
03:50:44:WU00:FS01:0x15:Completed 9500000 out of 25000000 steps (38%).
03:52:58:WU00:FS01:0x15:Completed 9750000 out of 25000000 steps (39%).
03:55:11:WU00:FS01:0x15:Completed 10000000 out of 25000000 steps (40%).
03:57:24:WU00:FS01:0x15:Completed 10250000 out of 25000000 steps (41%).
03:59:38:WU00:FS01:0x15:Completed 10500000 out of 25000000 steps (42%).
04:01:51:WU00:FS01:0x15:Completed 10750000 out of 25000000 steps (43%).
04:04:04:WU00:FS01:0x15:Completed 11000000 out of 25000000 steps (44%).
04:06:17:WU00:FS01:0x15:Completed 11250000 out of 25000000 steps (45%).
04:08:30:WU00:FS01:0x15:Completed 11500000 out of 25000000 steps (46%).
04:10:43:WU00:FS01:0x15:Completed 11750000 out of 25000000 steps (47%).
04:12:56:WU00:FS01:0x15:Completed 12000000 out of 25000000 steps (48%).
04:15:10:WU00:FS01:0x15:Completed 12250000 out of 25000000 steps (49%).
04:17:23:WU00:FS01:0x15:Completed 12500000 out of 25000000 steps (50%).
04:19:36:WU00:FS01:0x15:Completed 12750000 out of 25000000 steps (51%).
04:21:49:WU00:FS01:0x15:Completed 13000000 out of 25000000 steps (52%).
04:24:03:WU00:FS01:0x15:Completed 13250000 out of 25000000 steps (53%).
04:26:16:WU00:FS01:0x15:Completed 13500000 out of 25000000 steps (54%).
04:28:30:WU00:FS01:0x15:Completed 13750000 out of 25000000 steps (55%).
04:30:43:WU00:FS01:0x15:Completed 14000000 out of 25000000 steps (56%).
04:32:55:WU00:FS01:0x15:Completed 14250000 out of 25000000 steps (57%).
04:35:07:WU00:FS01:0x15:Completed 14500000 out of 25000000 steps (58%).
04:37:21:WU00:FS01:0x15:Completed 14750000 out of 25000000 steps (59%).
04:39:36:WU00:FS01:0x15:Completed 15000000 out of 25000000 steps (60%).
04:41:49:WU00:FS01:0x15:Completed 15250000 out of 25000000 steps (61%).
04:43:59:WU00:FS01:0x15:Completed 15500000 out of 25000000 steps (62%).
04:46:11:WU00:FS01:0x15:Completed 15750000 out of 25000000 steps (63%).
04:48:29:WU00:FS01:0x15:Completed 16000000 out of 25000000 steps (64%).
04:51:13:WU00:FS01:0x15:Completed 16250000 out of 25000000 steps (65%).
04:54:06:WU00:FS01:0x15:Completed 16500000 out of 25000000 steps (66%).
04:57:15:WU00:FS01:0x15:Completed 16750000 out of 25000000 steps (67%).
05:00:00:WU00:FS01:0x15:Completed 17000000 out of 25000000 steps (68%).
05:02:44:WU00:FS01:0x15:Completed 17250000 out of 25000000 steps (69%).
05:05:21:WU00:FS01:0x15:Completed 17500000 out of 25000000 steps (70%).
05:08:08:WU00:FS01:0x15:Completed 17750000 out of 25000000 steps (71%).
05:10:45:WU00:FS01:0x15:Completed 18000000 out of 25000000 steps (72%).
05:13:22:WU00:FS01:0x15:Completed 18250000 out of 25000000 steps (73%).
05:16:05:WU00:FS01:0x15:Completed 18500000 out of 25000000 steps (74%).
05:18:49:WU00:FS01:0x15:Completed 18750000 out of 25000000 steps (75%).
05:21:26:WU00:FS01:0x15:Completed 19000000 out of 25000000 steps (76%).
05:24:03:WU00:FS01:0x15:Completed 19250000 out of 25000000 steps (77%).
05:26:37:WU00:FS01:0x15:Completed 19500000 out of 25000000 steps (78%).
05:29:16:WU00:FS01:0x15:Completed 19750000 out of 25000000 steps (79%).
05:32:05:WU00:FS01:0x15:Completed 20000000 out of 25000000 steps (80%).
05:34:53:WU00:FS01:0x15:Completed 20250000 out of 25000000 steps (81%).
05:37:43:WU00:FS01:0x15:Completed 20500000 out of 25000000 steps (82%).
05:40:32:WU00:FS01:0x15:Completed 20750000 out of 25000000 steps (83%).
05:43:03:WU00:FS01:0x15:Completed 21000000 out of 25000000 steps (84%).
05:45:42:WU00:FS01:0x15:Completed 21250000 out of 25000000 steps (85%).
05:47:58:WU00:FS01:0x15:Completed 21500000 out of 25000000 steps (86%).
05:50:10:WU00:FS01:0x15:Completed 21750000 out of 25000000 steps (87%).
05:52:20:WU00:FS01:0x15:Completed 22000000 out of 25000000 steps (88%).
05:54:29:WU00:FS01:0x15:Completed 22250000 out of 25000000 steps (89%).
05:56:38:WU00:FS01:0x15:Completed 22500000 out of 25000000 steps (90%).
05:58:52:WU00:FS01:0x15:Completed 22750000 out of 25000000 steps (91%).
06:01:03:WU00:FS01:0x15:Completed 23000000 out of 25000000 steps (92%).
06:03:12:WU00:FS01:0x15:Completed 23250000 out of 25000000 steps (93%).
06:05:23:WU00:FS01:0x15:Completed 23500000 out of 25000000 steps (94%).
06:07:42:WU00:FS01:0x15:Completed 23750000 out of 25000000 steps (95%).
06:10:02:WU00:FS01:0x15:Completed 24000000 out of 25000000 steps (96%).
06:12:21:WU00:FS01:0x15:Completed 24250000 out of 25000000 steps (97%).
06:14:42:WU00:FS01:0x15:Completed 24500000 out of 25000000 steps (98%).
06:17:00:WU00:FS01:0x15:Completed 24750000 out of 25000000 steps (99%).
06:17:05:WU01:FS01:Connecting to 171.67.108.200:80
06:17:06:WU01:FS01:Assigned to work server 171.67.108.52
06:17:06:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
06:17:06:WU01:FS01:Connecting to 171.67.108.52:8080
06:17:07:WU01:FS01:Downloading 1.52MiB
06:17:12:WU01:FS01:Download complete
06:17:13:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:766 clone:4 gen:316 core:0x17 unit:0x000001bd6652edc45399f42e701c7ed8
06:19:16:WU00:FS01:0x15:Completed 25000000 out of 25000000 steps (100%).
06:19:16:WU00:FS01:0x15:Finished fah_main status=0
06:19:16:WU00:FS01:0x15:Successful run
06:19:16:WU00:FS01:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
06:19:26:WU00:FS01:0x15:Reserved 434456 bytes for xtc file; Cosm status=0
06:19:26:WU00:FS01:0x15:Allocated 434456 bytes for xtc file
06:19:26:WU00:FS01:0x15:- Reading up to 434456 from "00/wudata_01.xtc": Read 434456
06:19:26:WU00:FS01:0x15:Read 434456 bytes from xtc file; available packet space=785996008
06:19:26:WU00:FS01:0x15:xtc file hash check passed.
06:19:26:WU00:FS01:0x15:Reserved 54408 54408 785996008 bytes for arc file=<00/wudata_01.trr> Cosm status=0
06:19:26:WU00:FS01:0x15:Allocated 54408 bytes for arc file
06:19:26:WU00:FS01:0x15:- Reading up to 54408 from "00/wudata_01.trr": Read 54408
06:19:26:WU00:FS01:0x15:Read 54408 bytes from arc file; available packet space=785941600
06:19:27:WU00:FS01:0x15:trr file hash check passed.
06:19:27:WU00:FS01:0x15:Allocated 544 bytes for edr file
06:19:27:WU00:FS01:0x15:Read bedfile
06:19:27:WU00:FS01:0x15:edr file hash check passed.
06:19:27:WU00:FS01:0x15:Allocated 32123 bytes for logfile
06:19:27:WU00:FS01:0x15:Read logfile
06:19:27:WU00:FS01:0x15:GuardedRun: success in DynamicWrapper
06:19:27:WU00:FS01:0x15:GuardedRun: done
06:19:27:WU00:FS01:0x15:Run: GuardedRun completed.
06:19:28:WU00:FS01:0x15:+ Opened results file
06:19:28:WU00:FS01:0x15:- Writing 522043 bytes of core data to disk...
06:19:28:WU00:FS01:0x15:Done: 521531 -> 499200 (compressed to 95.7 percent)
06:19:28:WU00:FS01:0x15: ... Done.
06:19:28:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:19:28:WU00:FS01:0x15:Shutting down core
06:19:29:WU00:FS01:0x15:
06:19:29:WU00:FS01:0x15:Folding@home Core Shutdown: FINISHED_UNIT
06:19:29:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:19:29:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:8018 run:174 clone:1 gen:372 core:0x15 unit:0x000001b96953ee2e500f1be206d3aa69
06:19:29:WU00:FS01:Uploading 488.00KiB to 171.67.108.142
06:19:29:WU00:FS01:Connecting to 171.67.108.142:8080
06:19:29:WU01:FS01:Starting
06:19:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rafael/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2084 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:19:29:WU01:FS01:Started FahCore on PID 2992
06:19:29:WU01:FS01:Core PID:6724
06:19:29:WU01:FS01:FahCore 0x17 started
06:19:30:WU01:FS01:0x17:*********************** Log Started 2015-04-19T06:19:30Z ***********************
06:19:30:WU01:FS01:0x17:Project: 9201 (Run 766, Clone 4, Gen 316)
06:19:30:WU01:FS01:0x17:Unit: 0x000001bd6652edc45399f42e701c7ed8
06:19:30:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
06:19:30:WU01:FS01:0x17:Machine: 1
06:19:30:WU01:FS01:0x17:Reading tar file state.xml
06:19:31:WU01:FS01:0x17:Reading tar file system.xml
06:19:31:WU01:FS01:0x17:Reading tar file integrator.xml
06:19:31:WU01:FS01:0x17:Reading tar file core.xml
06:19:31:WU01:FS01:0x17:Digital signatures verified
06:19:31:WU01:FS01:0x17:Folding@home GPU core17
06:19:31:WU01:FS01:0x17:Version 0.0.52
06:19:36:WU00:FS01:Upload 78.69%
06:19:39:WU00:FS01:Upload complete
06:19:39:WU00:FS01:Server responded WORK_ACK (400)
06:19:39:WU00:FS01:Final credit estimate, 5757.00 points
06:19:39:WU00:FS01:Cleaning up
06:20:30:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
06:20:30:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:23:43:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
06:26:56:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
06:30:07:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
06:33:14:WU01:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
06:36:19:WU01:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
06:39:14:WU01:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
06:42:05:WU01:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
06:45:01:WU01:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
06:47:51:WU01:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
06:50:41:WU01:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
06:53:32:WU01:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
06:56:22:WU01:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
06:59:12:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
07:02:02:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
07:04:52:WU01:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
07:07:43:WU01:FS01:0x17:Completed 800000 out of 5000000 steps (16%)
07:10:33:WU01:FS01:0x17:Completed 850000 out of 5000000 steps (17%)
07:13:23:WU01:FS01:0x17:Completed 900000 out of 5000000 steps (18%)
07:16:13:WU01:FS01:0x17:Completed 950000 out of 5000000 steps (19%)
07:19:04:WU01:FS01:0x17:Completed 1000000 out of 5000000 steps (20%)
07:21:54:WU01:FS01:0x17:Completed 1050000 out of 5000000 steps (21%)
07:24:44:WU01:FS01:0x17:Completed 1100000 out of 5000000 steps (22%)
07:27:34:WU01:FS01:0x17:Completed 1150000 out of 5000000 steps (23%)
07:30:25:WU01:FS01:0x17:Completed 1200000 out of 5000000 steps (24%)
07:33:15:WU01:FS01:0x17:Completed 1250000 out of 5000000 steps (25%)
07:36:04:WU01:FS01:0x17:Completed 1300000 out of 5000000 steps (26%)
07:38:54:WU01:FS01:0x17:Completed 1350000 out of 5000000 steps (27%)
07:41:45:WU01:FS01:0x17:Completed 1400000 out of 5000000 steps (28%)
07:44:35:WU01:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
07:47:25:WU01:FS01:0x17:Completed 1500000 out of 5000000 steps (30%)
07:50:15:WU01:FS01:0x17:Completed 1550000 out of 5000000 steps (31%)
07:53:05:WU01:FS01:0x17:Completed 1600000 out of 5000000 steps (32%)
07:55:56:WU01:FS01:0x17:Completed 1650000 out of 5000000 steps (33%)
07:58:47:WU01:FS01:0x17:Completed 1700000 out of 5000000 steps (34%)
08:01:37:WU01:FS01:0x17:Completed 1750000 out of 5000000 steps (35%)
08:04:27:WU01:FS01:0x17:Completed 1800000 out of 5000000 steps (36%)
08:07:18:WU01:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
08:10:08:WU01:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
08:12:58:WU01:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
08:15:48:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
08:18:40:WU01:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
08:21:29:WU01:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
08:24:19:WU01:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
08:27:09:WU01:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
08:31:50:WU01:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
08:36:35:WU01:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
08:41:00:WU01:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
08:45:15:WU01:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
08:48:36:WU01:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
08:51:46:WU01:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
08:54:37:WU01:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
08:57:30:WU01:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
09:00:26:WU01:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
09:03:20:WU01:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
09:06:14:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
09:09:07:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
09:11:59:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
09:14:57:WU01:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
09:17:50:WU01:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
09:20:46:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
09:23:39:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
09:26:33:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
09:29:23:WU01:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
09:32:14:WU01:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
09:35:03:WU01:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
09:37:54:WU01:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
09:40:45:WU01:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
09:43:35:WU01:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
09:46:25:WU01:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
09:49:15:WU01:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
09:52:06:WU01:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
09:54:56:WU01:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
09:57:46:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
10:00:37:WU01:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
10:03:28:WU01:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
10:06:18:WU01:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
10:09:08:WU01:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
10:11:58:WU01:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
10:14:50:WU01:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
10:17:40:WU01:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
10:20:30:WU01:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
10:23:20:WU01:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
10:26:11:WU01:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
10:29:01:WU01:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
10:31:52:WU01:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
10:34:41:WU01:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
10:37:32:WU01:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
10:40:23:WU01:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
10:43:12:WU01:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
10:46:03:WU01:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
10:48:53:WU01:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
10:51:44:WU01:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
10:54:34:WU01:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
10:57:24:WU01:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
11:00:14:WU01:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
11:03:06:WU01:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
11:05:56:WU01:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
11:08:46:WU01:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
11:11:36:WU01:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
11:11:39:WU00:FS01:Connecting to 171.67.108.200:80
11:11:41:WU00:FS01:Assigned to work server 171.67.108.142
11:11:41:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.67.108.142
11:11:41:WU00:FS01:Connecting to 171.67.108.142:8080
11:11:42:WU00:FS01:Downloading 143.16KiB
11:11:43:WU00:FS01:Download complete
11:11:43:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8018 run:75 clone:0 gen:365 core:0x15 unit:0x000001b96953ee2e500f1b89ee10e67a
11:14:28:WU01:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
11:14:35:WU01:FS01:0x17:Saving result file logfile_01.txt
11:14:35:WU01:FS01:0x17:Saving result file checkpointState.xml
11:14:36:WU01:FS01:0x17:Saving result file checkpt.crc
11:14:36:WU01:FS01:0x17:Saving result file log.txt
11:14:36:WU01:FS01:0x17:Saving result file positions.xtc
11:14:39:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
11:14:39:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:14:40:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9201 run:766 clone:4 gen:316 core:0x17 unit:0x000001bd6652edc45399f42e701c7ed8
11:14:40:WU01:FS01:Uploading 8.40MiB to 171.67.108.52
11:14:40:WU01:FS01:Connecting to 171.67.108.52:8080
11:14:40:WU00:FS01:Starting
11:14:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rafael/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 2084 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:14:40:WU00:FS01:Started FahCore on PID 6776
11:14:40:WU00:FS01:Core PID:4056
11:14:40:WU00:FS01:FahCore 0x15 started
11:14:40:WU00:FS01:0x15:
11:14:40:WU00:FS01:0x15:*------------------------------*
11:14:40:WU00:FS01:0x15:Folding@Home GPU Core
11:14:40:WU00:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
11:14:40:WU00:FS01:0x15:Build host AmoebaRemote
11:14:40:WU00:FS01:0x15:Board Type NVIDIA/CUDA
11:14:40:WU00:FS01:0x15:Core 15
11:14:40:WU00:FS01:0x15:Window's signal control handler registered.
11:14:40:WU00:FS01:0x15:Preparing to commence simulation
11:14:40:WU00:FS01:0x15:- Looking at optimizations...
11:14:40:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
11:14:40:WU00:FS01:0x15:- Created dyn
11:14:40:WU00:FS01:0x15:- Files status OK
11:14:40:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
11:14:40:WU00:FS01:0x15:- Expanded 146087 -> 660986 (decompressed 452.4 percent)
11:14:40:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=146087 data_size=660986, decompressed_data_size=660986 diff=0
11:14:40:WU00:FS01:0x15:- Digital signature verified
11:14:40:WU00:FS01:0x15:Project: 8018 (Run 75, Clone 0, Gen 365)
11:14:40:WU00:FS01:0x15:Assembly optimizations on if available.
11:14:40:WU00:FS01:0x15:Entering M.D.
11:14:42:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr: 2970862045 2466214656 2493232094 3360251002 131931993
11:14:42:WU00:FS01:0x15:GPU device id=0
11:14:42:WU00:FS01:0x15:Working on GRowing Old MAkes el Chrono Sweat
11:14:42:WU00:FS01:0x15:Client config unavailable.
11:14:42:WU00:FS01:0x15:Starting GUI Server
11:14:46:WU01:FS01:Upload 4.46%
11:14:52:WU01:FS01:Upload 13.39%
11:14:58:WU01:FS01:Upload 20.09%
11:15:04:WU01:FS01:Upload 26.79%
11:15:10:WU01:FS01:Upload 34.23%
11:15:16:WU01:FS01:Upload 40.18%
11:15:22:WU01:FS01:Upload 47.62%
11:15:28:WU01:FS01:Upload 55.06%
11:15:34:WU01:FS01:Upload 63.25%
11:15:40:WU01:FS01:Upload 71.43%
11:15:45:WU00:FS01:0x15:Setting checkpoint frequency: 250000
11:15:45:WU00:FS01:0x15:Completed 3 out of 25000000 steps (0%).
11:15:46:WU01:FS01:Upload 79.61%
11:15:52:WU01:FS01:Upload 86.31%
11:15:58:WU01:FS01:Upload 94.50%
11:16:08:WU01:FS01:Upload complete
11:16:08:WU01:FS01:Server responded WORK_ACK (400)
11:16:08:WU01:FS01:Final credit estimate, 28034.00 points
11:16:08:WU01:FS01:Cleaning up
11:17:51:WU00:FS01:0x15:Completed 250000 out of 25000000 steps (1%).
11:19:57:WU00:FS01:0x15:Completed 500000 out of 25000000 steps (2%).
11:22:03:WU00:FS01:0x15:Completed 750000 out of 25000000 steps (3%).
11:24:09:WU00:FS01:0x15:Completed 1000000 out of 25000000 steps (4%).
11:26:16:WU00:FS01:0x15:Completed 1250000 out of 25000000 steps (5%).
11:28:23:WU00:FS01:0x15:Completed 1500000 out of 25000000 steps (6%).
11:30:29:WU00:FS01:0x15:Completed 1750000 out of 25000000 steps (7%).
11:32:36:WU00:FS01:0x15:Completed 2000000 out of 25000000 steps (8%).
11:34:42:WU00:FS01:0x15:Completed 2250000 out of 25000000 steps (9%).
11:36:48:WU00:FS01:0x15:Completed 2500000 out of 25000000 steps (10%).
11:38:56:WU00:FS01:0x15:Completed 2750000 out of 25000000 steps (11%).
11:41:02:WU00:FS01:0x15:Completed 3000000 out of 25000000 steps (12%).
11:43:08:WU00:FS01:0x15:Completed 3250000 out of 25000000 steps (13%).
11:45:14:WU00:FS01:0x15:Completed 3500000 out of 25000000 steps (14%).
11:47:20:WU00:FS01:0x15:Completed 3750000 out of 25000000 steps (15%).
11:49:27:WU00:FS01:0x15:Completed 4000000 out of 25000000 steps (16%).
11:51:34:WU00:FS01:0x15:Completed 4250000 out of 25000000 steps (17%).
11:53:40:WU00:FS01:0x15:Completed 4500000 out of 25000000 steps (18%).
11:55:46:WU00:FS01:0x15:Completed 4750000 out of 25000000 steps (19%).
11:57:53:WU00:FS01:0x15:Completed 5000000 out of 25000000 steps (20%).
11:59:59:WU00:FS01:0x15:Completed 5250000 out of 25000000 steps (21%).
12:02:06:WU00:FS01:0x15:Completed 5500000 out of 25000000 steps (22%).
12:04:13:WU00:FS01:0x15:Completed 5750000 out of 25000000 steps (23%).
12:06:19:WU00:FS01:0x15:Completed 6000000 out of 25000000 steps (24%).
12:08:26:WU00:FS01:0x15:Completed 6250000 out of 25000000 steps (25%).
12:10:32:WU00:FS01:0x15:Completed 6500000 out of 25000000 steps (26%).
12:12:38:WU00:FS01:0x15:Completed 6750000 out of 25000000 steps (27%).
12:14:46:WU00:FS01:0x15:Completed 7000000 out of 25000000 steps (28%).
12:16:52:WU00:FS01:0x15:Completed 7250000 out of 25000000 steps (29%).
12:18:58:WU00:FS01:0x15:Completed 7500000 out of 25000000 steps (30%).
12:21:05:WU00:FS01:0x15:Completed 7750000 out of 25000000 steps (31%).
12:23:11:WU00:FS01:0x15:Completed 8000000 out of 25000000 steps (32%).
12:25:18:WU00:FS01:0x15:Completed 8250000 out of 25000000 steps (33%).
12:27:26:WU00:FS01:0x15:Completed 8500000 out of 25000000 steps (34%).
12:29:32:WU00:FS01:0x15:Completed 8750000 out of 25000000 steps (35%).
12:31:38:WU00:FS01:0x15:Completed 9000000 out of 25000000 steps (36%).
12:33:44:WU00:FS01:0x15:Completed 9250000 out of 25000000 steps (37%).
12:35:50:WU00:FS01:0x15:Completed 9500000 out of 25000000 steps (38%).
12:37:57:WU00:FS01:0x15:Completed 9750000 out of 25000000 steps (39%).
12:40:04:WU00:FS01:0x15:Completed 10000000 out of 25000000 steps (40%).
12:42:10:WU00:FS01:0x15:Completed 10250000 out of 25000000 steps (41%).
12:44:17:WU00:FS01:0x15:Completed 10500000 out of 25000000 steps (42%).
12:46:24:WU00:FS01:0x15:Completed 10750000 out of 25000000 steps (43%).
12:48:29:WU00:FS01:0x15:Completed 11000000 out of 25000000 steps (44%).
12:50:38:WU00:FS01:0x15:Completed 11250000 out of 25000000 steps (45%).
12:52:45:WU00:FS01:0x15:Completed 11500000 out of 25000000 steps (46%).
12:54:51:WU00:FS01:0x15:Completed 11750000 out of 25000000 steps (47%).
12:56:59:WU00:FS01:0x15:Completed 12000000 out of 25000000 steps (48%).
12:59:05:WU00:FS01:0x15:Completed 12250000 out of 25000000 steps (49%).
13:01:13:WU00:FS01:0x15:Completed 12500000 out of 25000000 steps (50%).
13:03:20:WU00:FS01:0x15:Completed 12750000 out of 25000000 steps (51%).
13:05:27:WU00:FS01:0x15:Completed 13000000 out of 25000000 steps (52%).
13:07:34:WU00:FS01:0x15:Completed 13250000 out of 25000000 steps (53%).
13:09:41:WU00:FS01:0x15:Completed 13500000 out of 25000000 steps (54%).
13:11:47:WU00:FS01:0x15:Completed 13750000 out of 25000000 steps (55%).
13:13:54:WU00:FS01:0x15:Completed 14000000 out of 25000000 steps (56%).
13:16:02:WU00:FS01:0x15:Completed 14250000 out of 25000000 steps (57%).
13:18:08:WU00:FS01:0x15:Completed 14500000 out of 25000000 steps (58%).
13:20:15:WU00:FS01:0x15:Completed 14750000 out of 25000000 steps (59%).
13:22:21:WU00:FS01:0x15:Completed 15000000 out of 25000000 steps (60%).
13:24:27:WU00:FS01:0x15:Completed 15250000 out of 25000000 steps (61%).
13:26:35:WU00:FS01:0x15:Completed 15500000 out of 25000000 steps (62%).
13:28:42:WU00:FS01:0x15:Completed 15750000 out of 25000000 steps (63%).
13:30:48:WU00:FS01:0x15:Completed 16000000 out of 25000000 steps (64%).
13:32:55:WU00:FS01:0x15:Completed 16250000 out of 25000000 steps (65%).
13:35:01:WU00:FS01:0x15:Completed 16500000 out of 25000000 steps (66%).
13:37:08:WU00:FS01:0x15:Completed 16750000 out of 25000000 steps (67%).
13:39:15:WU00:FS01:0x15:Completed 17000000 out of 25000000 steps (68%).
13:41:22:WU00:FS01:0x15:Completed 17250000 out of 25000000 steps (69%).
13:43:28:WU00:FS01:0x15:Completed 17500000 out of 25000000 steps (70%).
13:45:34:WU00:FS01:0x15:Completed 17750000 out of 25000000 steps (71%).
13:47:40:WU00:FS01:0x15:Completed 18000000 out of 25000000 steps (72%).
13:49:47:WU00:FS01:0x15:Completed 18250000 out of 25000000 steps (73%).
13:51:54:WU00:FS01:0x15:Completed 18500000 out of 25000000 steps (74%).
13:54:00:WU00:FS01:0x15:Completed 18750000 out of 25000000 steps (75%).
13:56:07:WU00:FS01:0x15:Completed 19000000 out of 25000000 steps (76%).
13:58:13:WU00:FS01:0x15:Completed 19250000 out of 25000000 steps (77%).
14:00:19:WU00:FS01:0x15:Completed 19500000 out of 25000000 steps (78%).
14:02:26:WU00:FS01:0x15:Completed 19750000 out of 25000000 steps (79%).
14:04:33:WU00:FS01:0x15:Completed 20000000 out of 25000000 steps (80%).
14:06:39:WU00:FS01:0x15:Completed 20250000 out of 25000000 steps (81%).
14:08:46:WU00:FS01:0x15:Completed 20500000 out of 25000000 steps (82%).
14:10:52:WU00:FS01:0x15:Completed 20750000 out of 25000000 steps (83%).
14:12:59:WU00:FS01:0x15:Completed 21000000 out of 25000000 steps (84%).
14:15:06:WU00:FS01:0x15:Completed 21250000 out of 25000000 steps (85%).
14:17:12:WU00:FS01:0x15:Completed 21500000 out of 25000000 steps (86%).
14:19:18:WU00:FS01:0x15:Completed 21750000 out of 25000000 steps (87%).
14:21:25:WU00:FS01:0x15:Completed 22000000 out of 25000000 steps (88%).
14:23:31:WU00:FS01:0x15:Completed 22250000 out of 25000000 steps (89%).
14:25:39:WU00:FS01:0x15:Completed 22500000 out of 25000000 steps (90%).
14:27:46:WU00:FS01:0x15:Completed 22750000 out of 25000000 steps (91%).
14:29:52:WU00:FS01:0x15:Completed 23000000 out of 25000000 steps (92%).
14:31:59:WU00:FS01:0x15:Completed 23250000 out of 25000000 steps (93%).
14:34:05:WU00:FS01:0x15:Completed 23500000 out of 25000000 steps (94%).
14:36:11:WU00:FS01:0x15:Completed 23750000 out of 25000000 steps (95%).
14:38:18:WU00:FS01:0x15:Completed 24000000 out of 25000000 steps (96%).
14:40:25:WU00:FS01:0x15:Completed 24250000 out of 25000000 steps (97%).
14:42:31:WU00:FS01:0x15:Completed 24500000 out of 25000000 steps (98%).
14:44:38:WU00:FS01:0x15:Completed 24750000 out of 25000000 steps (99%).
14:44:42:WU01:FS01:Connecting to 171.67.108.200:80
14:44:43:WU01:FS01:Assigned to work server 171.64.65.56
14:44:43:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56
14:44:43:WU01:FS01:Connecting to 171.64.65.56:8080
14:44:45:WU01:FS01:Downloading 892.15KiB
14:44:48:WU01:FS01:Download complete
14:44:48:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9411 run:2331 clone:0 gen:50 core:0x17 unit:0x0000003cab40413854d27ead2c0b41be
14:46:44:WU00:FS01:0x15:Completed 25000000 out of 25000000 steps (100%).
14:46:44:WU00:FS01:0x15:Finished fah_main status=0
14:46:44:WU00:FS01:0x15:Successful run
14:46:44:WU00:FS01:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
14:46:54:WU00:FS01:0x15:Reserved 436744 bytes for xtc file; Cosm status=0
14:46:54:WU00:FS01:0x15:Allocated 436744 bytes for xtc file
14:46:54:WU00:FS01:0x15:- Reading up to 436744 from "00/wudata_01.xtc": Read 436744
14:46:54:WU00:FS01:0x15:Read 436744 bytes from xtc file; available packet space=785993720
14:46:54:WU00:FS01:0x15:xtc file hash check passed.
14:46:54:WU00:FS01:0x15:Reserved 54408 54408 785993720 bytes for arc file=<00/wudata_01.trr> Cosm status=0
14:46:54:WU00:FS01:0x15:Allocated 54408 bytes for arc file
14:46:54:WU00:FS01:0x15:- Reading up to 54408 from "00/wudata_01.trr": Read 54408
14:46:54:WU00:FS01:0x15:Read 54408 bytes from arc file; available packet space=785939312
14:46:54:WU00:FS01:0x15:trr file hash check passed.
14:46:54:WU00:FS01:0x15:Allocated 544 bytes for edr file
14:46:54:WU00:FS01:0x15:Read bedfile
14:46:54:WU00:FS01:0x15:edr file hash check passed.
14:46:54:WU00:FS01:0x15:Allocated 32122 bytes for logfile
14:46:54:WU00:FS01:0x15:Read logfile
14:46:54:WU00:FS01:0x15:GuardedRun: success in DynamicWrapper
14:46:54:WU00:FS01:0x15:GuardedRun: done
14:46:54:WU00:FS01:0x15:Run: GuardedRun completed.
14:46:56:WU00:FS01:0x15:+ Opened results file
14:46:56:WU00:FS01:0x15:- Writing 524330 bytes of core data to disk...
14:46:56:WU00:FS01:0x15:Done: 523818 -> 501566 (compressed to 95.7 percent)
14:46:56:WU00:FS01:0x15: ... Done.
14:46:56:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
14:46:56:WU00:FS01:0x15:Shutting down core
14:46:56:WU00:FS01:0x15:Folding@home Core Shutdown: FINISHED_UNIT
14:46:56:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:46:56:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:8018 run:75 clone:0 gen:365 core:0x15 unit:0x000001b96953ee2e500f1b89ee10e67a
14:46:56:WU00:FS01:Uploading 490.31KiB to 171.67.108.142
14:46:56:WU00:FS01:Connecting to 171.67.108.142:8080
14:46:56:WU01:FS01:Starting
14:46:56:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rafael/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2084 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
14:46:56:WU01:FS01:Started FahCore on PID 8068
14:46:56:WU01:FS01:Core PID:7764
14:46:56:WU01:FS01:FahCore 0x17 started
14:46:57:WU01:FS01:0x17:*********************** Log Started 2015-04-19T14:46:56Z ***********************
14:46:57:WU01:FS01:0x17:Project: 9411 (Run 2331, Clone 0, Gen 50)
14:46:57:WU01:FS01:0x17:Unit: 0x0000003cab40413854d27ead2c0b41be
14:46:57:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
14:46:57:WU01:FS01:0x17:Machine: 1
14:46:57:WU01:FS01:0x17:Reading tar file state.xml
14:46:57:WU01:FS01:0x17:Reading tar file system.xml
14:46:57:WU01:FS01:0x17:Reading tar file integrator.xml
14:46:57:WU01:FS01:0x17:Reading tar file core.xml
14:46:57:WU01:FS01:0x17:Digital signatures verified
14:46:57:WU01:FS01:0x17:Folding@home GPU core17
14:46:57:WU01:FS01:0x17:Version 0.0.52
14:47:01:WU00:FS01:Upload complete
14:47:01:WU00:FS01:Server responded WORK_ACK (400)
14:47:01:WU00:FS01:Final credit estimate, 5757.00 points
14:47:01:WU00:FS01:Cleaning up
14:47:20:WU01:FS01:0x17:Completed 0 out of 16000000 steps (0%)
14:47:20:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:54:48:WU01:FS01:0x17:Completed 160000 out of 16000000 steps (1%)
15:02:10:WU01:FS01:0x17:Completed 320000 out of 16000000 steps (2%)
15:09:32:WU01:FS01:0x17:Completed 480000 out of 16000000 steps (3%)
15:16:55:WU01:FS01:0x17:Completed 640000 out of 16000000 steps (4%)
15:24:16:WU01:FS01:0x17:Completed 800000 out of 16000000 steps (5%)
15:31:46:WU01:FS01:0x17:Completed 960000 out of 16000000 steps (6%)
15:39:09:WU01:FS01:0x17:Completed 1120000 out of 16000000 steps (7%)
15:46:31:WU01:FS01:0x17:Completed 1280000 out of 16000000 steps (8%)
15:53:54:WU01:FS01:0x17:Completed 1440000 out of 16000000 steps (9%)
16:01:17:WU01:FS01:0x17:Completed 1600000 out of 16000000 steps (10%)
16:08:46:WU01:FS01:0x17:Completed 1760000 out of 16000000 steps (11%)
16:16:46:WU01:FS01:0x17:Completed 1920000 out of 16000000 steps (12%)
16:24:43:WU01:FS01:0x17:Completed 2080000 out of 16000000 steps (13%)
16:32:58:WU01:FS01:0x17:Completed 2240000 out of 16000000 steps (14%)
16:41:00:WU01:FS01:0x17:Completed 2400000 out of 16000000 steps (15%)
16:49:10:WU01:FS01:0x17:Completed 2560000 out of 16000000 steps (16%)
16:56:32:WU01:FS01:0x17:Completed 2720000 out of 16000000 steps (17%)
17:03:53:WU01:FS01:0x17:Completed 2880000 out of 16000000 steps (18%)
17:11:15:WU01:FS01:0x17:Completed 3040000 out of 16000000 steps (19%)
17:18:37:WU01:FS01:0x17:Completed 3200000 out of 16000000 steps (20%)
17:26:04:WU01:FS01:0x17:Completed 3360000 out of 16000000 steps (21%)
17:33:26:WU01:FS01:0x17:Completed 3520000 out of 16000000 steps (22%)
17:40:47:WU01:FS01:0x17:Completed 3680000 out of 16000000 steps (23%)
17:48:09:WU01:FS01:0x17:Completed 3840000 out of 16000000 steps (24%)
17:55:31:WU01:FS01:0x17:Completed 4000000 out of 16000000 steps (25%)
18:02:59:WU01:FS01:0x17:Completed 4160000 out of 16000000 steps (26%)
18:10:21:WU01:FS01:0x17:Completed 4320000 out of 16000000 steps (27%)
18:17:42:WU01:FS01:0x17:Completed 4480000 out of 16000000 steps (28%)
18:25:03:WU01:FS01:0x17:Completed 4640000 out of 16000000 steps (29%)
18:32:25:WU01:FS01:0x17:Completed 4800000 out of 16000000 steps (30%)
18:39:53:WU01:FS01:0x17:Completed 4960000 out of 16000000 steps (31%)
18:48:03:WU01:FS01:0x17:Completed 5120000 out of 16000000 steps (32%)
18:56:04:WU01:FS01:0x17:Completed 5280000 out of 16000000 steps (33%)
19:04:49:WU01:FS01:0x17:Completed 5440000 out of 16000000 steps (34%)
19:13:56:WU01:FS01:0x17:Completed 5600000 out of 16000000 steps (35%)
19:23:09:WU01:FS01:0x17:Completed 5760000 out of 16000000 steps (36%)
19:32:47:WU01:FS01:0x17:Completed 5920000 out of 16000000 steps (37%)
19:42:17:WU01:FS01:0x17:Completed 6080000 out of 16000000 steps (38%)
19:52:02:WU01:FS01:0x17:Completed 6240000 out of 16000000 steps (39%)
20:00:55:WU01:FS01:0x17:Completed 6400000 out of 16000000 steps (40%)
20:08:34:WU01:FS01:0x17:Completed 6560000 out of 16000000 steps (41%)
20:16:00:WU01:FS01:0x17:Completed 6720000 out of 16000000 steps (42%)
20:23:31:WU01:FS01:0x17:Completed 6880000 out of 16000000 steps (43%)
20:30:57:WU01:FS01:0x17:Completed 7040000 out of 16000000 steps (44%)
20:38:26:WU01:FS01:0x17:Completed 7200000 out of 16000000 steps (45%)
20:46:02:WU01:FS01:0x17:Completed 7360000 out of 16000000 steps (46%)
20:53:30:WU01:FS01:0x17:Completed 7520000 out of 16000000 steps (47%)
21:00:54:WU01:FS01:0x17:Completed 7680000 out of 16000000 steps (48%)
21:08:21:WU01:FS01:0x17:Completed 7840000 out of 16000000 steps (49%)
21:15:48:WU01:FS01:0x17:Completed 8000000 out of 16000000 steps (50%)
21:23:18:WU01:FS01:0x17:Completed 8160000 out of 16000000 steps (51%)
21:30:45:WU01:FS01:0x17:Completed 8320000 out of 16000000 steps (52%)
21:38:05:WU01:FS01:0x17:Completed 8480000 out of 16000000 steps (53%)
21:45:48:WU01:FS01:0x17:Completed 8640000 out of 16000000 steps (54%)
21:53:25:WU01:FS01:0x17:Completed 8800000 out of 16000000 steps (55%)
22:01:02:WU01:FS01:0x17:Completed 8960000 out of 16000000 steps (56%)
22:08:22:WU01:FS01:0x17:Completed 9120000 out of 16000000 steps (57%)
22:15:45:WU01:FS01:0x17:Completed 9280000 out of 16000000 steps (58%)
22:23:05:WU01:FS01:0x17:Completed 9440000 out of 16000000 steps (59%)
22:30:27:WU01:FS01:0x17:Completed 9600000 out of 16000000 steps (60%)
22:37:55:WU01:FS01:0x17:Completed 9760000 out of 16000000 steps (61%)
22:45:16:WU01:FS01:0x17:Completed 9920000 out of 16000000 steps (62%)
22:52:38:WU01:FS01:0x17:Completed 10080000 out of 16000000 steps (63%)
22:59:59:WU01:FS01:0x17:Completed 10240000 out of 16000000 steps (64%)
23:07:21:WU01:FS01:0x17:Completed 10400000 out of 16000000 steps (65%)
23:14:49:WU01:FS01:0x17:Completed 10560000 out of 16000000 steps (66%)
23:22:10:WU01:FS01:0x17:Completed 10720000 out of 16000000 steps (67%)
23:29:32:WU01:FS01:0x17:Completed 10880000 out of 16000000 steps (68%)
23:36:54:WU01:FS01:0x17:Completed 11040000 out of 16000000 steps (69%)
23:44:15:WU01:FS01:0x17:Completed 11200000 out of 16000000 steps (70%)
23:51:44:WU01:FS01:0x17:Completed 11360000 out of 16000000 steps (71%)
23:59:05:WU01:FS01:0x17:Completed 11520000 out of 16000000 steps (72%)
00:06:27:WU01:FS01:0x17:Completed 11680000 out of 16000000 steps (73%)
00:13:49:WU01:FS01:0x17:Completed 11840000 out of 16000000 steps (74%)
00:21:11:WU01:FS01:0x17:Completed 12000000 out of 16000000 steps (75%)
00:28:39:WU01:FS01:0x17:Completed 12160000 out of 16000000 steps (76%)
00:36:00:WU01:FS01:0x17:Completed 12320000 out of 16000000 steps (77%)
00:43:23:WU01:FS01:0x17:Completed 12480000 out of 16000000 steps (78%)
00:50:45:WU01:FS01:0x17:Completed 12640000 out of 16000000 steps (79%)
00:58:06:WU01:FS01:0x17:Completed 12800000 out of 16000000 steps (80%)
01:05:35:WU01:FS01:0x17:Completed 12960000 out of 16000000 steps (81%)
01:12:57:WU01:FS01:0x17:Completed 13120000 out of 16000000 steps (82%)
01:20:18:WU01:FS01:0x17:Completed 13280000 out of 16000000 steps (83%)
01:27:40:WU01:FS01:0x17:Completed 13440000 out of 16000000 steps (84%)
01:35:01:WU01:FS01:0x17:Completed 13600000 out of 16000000 steps (85%)
01:42:29:WU01:FS01:0x17:Completed 13760000 out of 16000000 steps (86%)
01:49:52:WU01:FS01:0x17:Completed 13920000 out of 16000000 steps (87%)
01:57:12:WU01:FS01:0x17:Completed 14080000 out of 16000000 steps (88%)
02:05:26:WU01:FS01:0x17:Completed 14240000 out of 16000000 steps (89%)
02:14:24:WU01:FS01:0x17:Completed 14400000 out of 16000000 steps (90%)
02:23:34:WU01:FS01:0x17:Completed 14560000 out of 16000000 steps (91%)
02:32:38:WU01:FS01:0x17:Completed 14720000 out of 16000000 steps (92%)
02:41:57:WU01:FS01:0x17:Completed 14880000 out of 16000000 steps (93%)
02:51:17:WU01:FS01:0x17:Completed 15040000 out of 16000000 steps (94%)
03:00:23:WU01:FS01:0x17:Completed 15200000 out of 16000000 steps (95%)
03:09:39:WU01:FS01:0x17:Completed 15360000 out of 16000000 steps (96%)
03:18:51:WU01:FS01:0x17:Completed 15520000 out of 16000000 steps (97%)
03:28:27:WU01:FS01:0x17:Completed 15680000 out of 16000000 steps (98%)
03:38:02:WU01:FS01:0x17:Completed 15840000 out of 16000000 steps (99%)
03:38:06:WU00:FS01:Connecting to 171.67.108.200:80
03:38:07:WU00:FS01:Assigned to work server 171.64.65.56
03:38:07:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56
03:38:07:WU00:FS01:Connecting to 171.64.65.56:8080
03:38:09:WU00:FS01:Downloading 888.72KiB
03:38:13:WU00:FS01:Download complete
03:38:13:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9411 run:979 clone:0 gen:48 core:0x17 unit:0x0000003bab40413854d27c910c190ee6
03:47:16:WU01:FS01:0x17:Completed 16000000 out of 16000000 steps (100%)
03:47:24:WU01:FS01:0x17:Saving result file logfile_01.txt
03:47:24:WU01:FS01:0x17:Saving result file checkpointState.xml
03:47:25:WU01:FS01:0x17:Saving result file checkpt.crc
03:47:25:WU01:FS01:0x17:Saving result file log.txt
03:47:25:WU01:FS01:0x17:Saving result file positions.xtc
03:47:32:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
03:47:32:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:47:32:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9411 run:2331 clone:0 gen:50 core:0x17 unit:0x0000003cab40413854d27ead2c0b41be
03:47:32:WU01:FS01:Uploading 13.66MiB to 171.64.65.56
03:47:32:WU01:FS01:Connecting to 171.64.65.56:8080
03:47:32:WU00:FS01:Starting
03:47:32:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rafael/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 2084 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:47:32:WU00:FS01:Started FahCore on PID 452
03:47:32:WU00:FS01:Core PID:5140
03:47:32:WU00:FS01:FahCore 0x17 started
03:47:33:WU00:FS01:0x17:*********************** Log Started 2015-04-20T03:47:33Z ***********************
03:47:33:WU00:FS01:0x17:Project: 9411 (Run 979, Clone 0, Gen 48)
03:47:33:WU00:FS01:0x17:Unit: 0x0000003bab40413854d27c910c190ee6
03:47:33:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
03:47:33:WU00:FS01:0x17:Machine: 1
03:47:33:WU00:FS01:0x17:Reading tar file state.xml
03:47:33:WU00:FS01:0x17:Reading tar file system.xml
03:47:33:WU00:FS01:0x17:Reading tar file integrator.xml
03:47:33:WU00:FS01:0x17:Reading tar file core.xml
03:47:33:WU00:FS01:0x17:Digital signatures verified
03:47:33:WU00:FS01:0x17:Folding@home GPU core17
03:47:33:WU00:FS01:0x17:Version 0.0.52
03:47:39:WU01:FS01:Upload 4.12%
03:47:45:WU01:FS01:Upload 8.24%
03:47:51:WU01:FS01:Upload 10.52%
03:47:58:WU01:FS01:Upload 16.47%
03:48:04:WU01:FS01:Upload 18.76%
03:48:05:WU00:FS01:0x17:Completed 0 out of 16000000 steps (0%)
03:48:05:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:48:11:WU01:FS01:Upload 21.05%
03:48:17:WU01:FS01:Upload 30.66%
03:48:23:WU01:FS01:Upload 32.95%
03:48:29:WU01:FS01:Upload 34.78%
03:48:35:WU01:FS01:Upload 37.06%
03:48:41:WU01:FS01:Upload 39.35%
03:48:47:WU01:FS01:Upload 41.18%
03:48:53:WU01:FS01:Upload 43.93%
03:48:59:WU01:FS01:Upload 46.22%
03:49:05:WU01:FS01:Upload 62.69%
03:49:11:WU01:FS01:Upload 65.43%
03:49:17:WU01:FS01:Upload 67.72%
03:49:23:WU01:FS01:Upload 69.55%
03:49:29:WU01:FS01:Upload 71.84%
03:49:35:WU01:FS01:Upload 74.13%
03:49:41:WU01:FS01:Upload 76.42%
03:49:47:WU01:FS01:Upload 78.70%
03:49:53:WU01:FS01:Upload 80.99%
03:49:59:WU01:FS01:Upload 82.82%
03:50:05:WU01:FS01:Upload 85.11%
03:50:11:WU01:FS01:Upload 87.40%
03:50:18:WU01:FS01:Upload 89.69%
03:50:24:WU01:FS01:Upload 91.97%
03:50:31:WU01:FS01:Upload 94.26%
03:50:37:WU01:FS01:Upload 96.55%
03:50:43:WU01:FS01:Upload 98.84%
03:52:12:WU01:FS01:Upload complete
03:52:12:WU01:FS01:Server responded WORK_ACK (400)
03:52:12:WU01:FS01:Final credit estimate, 62061.00 points
03:52:12:WU01:FS01:Cleaning up
03:57:42:WU00:FS01:0x17:Completed 160000 out of 16000000 steps (1%)
******************************* Date: 2015-04-20 *******************************
04:07:03:WU00:FS01:0x17:Completed 320000 out of 16000000 steps (2%)
04:15:30:WU00:FS01:0x17:Completed 480000 out of 16000000 steps (3%)
04:23:07:WU00:FS01:0x17:Completed 640000 out of 16000000 steps (4%)
04:30:53:WU00:FS01:0x17:Completed 800000 out of 16000000 steps (5%)
04:38:54:WU00:FS01:0x17:Completed 960000 out of 16000000 steps (6%)
04:46:51:WU00:FS01:0x17:Completed 1120000 out of 16000000 steps (7%)
04:54:34:WU00:FS01:0x17:Completed 1280000 out of 16000000 steps (8%)
05:02:20:WU00:FS01:0x17:Completed 1440000 out of 16000000 steps (9%)
05:10:09:WU00:FS01:0x17:Completed 1600000 out of 16000000 steps (10%)
05:18:03:WU00:FS01:0x17:Completed 1760000 out of 16000000 steps (11%)
05:25:45:WU00:FS01:0x17:Completed 1920000 out of 16000000 steps (12%)
05:33:12:WU00:FS01:0x17:Completed 2080000 out of 16000000 steps (13%)
05:40:35:WU00:FS01:0x17:Completed 2240000 out of 16000000 steps (14%)
05:47:55:WU00:FS01:0x17:Completed 2400000 out of 16000000 steps (15%)
05:55:21:WU00:FS01:0x17:Completed 2560000 out of 16000000 steps (16%)
06:02:41:WU00:FS01:0x17:Completed 2720000 out of 16000000 steps (17%)
06:10:01:WU00:FS01:0x17:Completed 2880000 out of 16000000 steps (18%)
06:17:20:WU00:FS01:0x17:Completed 3040000 out of 16000000 steps (19%)
06:24:40:WU00:FS01:0x17:Completed 3200000 out of 16000000 steps (20%)
06:32:07:WU00:FS01:0x17:Completed 3360000 out of 16000000 steps (21%)
06:39:27:WU00:FS01:0x17:Completed 3520000 out of 16000000 steps (22%)
06:46:47:WU00:FS01:0x17:Completed 3680000 out of 16000000 steps (23%)
06:54:06:WU00:FS01:0x17:Completed 3840000 out of 16000000 steps (24%)
07:01:27:WU00:FS01:0x17:Completed 4000000 out of 16000000 steps (25%)
07:08:53:WU00:FS01:0x17:Completed 4160000 out of 16000000 steps (26%)
07:16:12:WU00:FS01:0x17:Completed 4320000 out of 16000000 steps (27%)
07:23:33:WU00:FS01:0x17:Completed 4480000 out of 16000000 steps (28%)
07:30:53:WU00:FS01:0x17:Completed 4640000 out of 16000000 steps (29%)
07:38:13:WU00:FS01:0x17:Completed 4800000 out of 16000000 steps (30%)
07:45:39:WU00:FS01:0x17:Completed 4960000 out of 16000000 steps (31%)
07:52:58:WU00:FS01:0x17:Completed 5120000 out of 16000000 steps (32%)
08:00:20:WU00:FS01:0x17:Completed 5280000 out of 16000000 steps (33%)
08:07:40:WU00:FS01:0x17:Completed 5440000 out of 16000000 steps (34%)
08:15:00:WU00:FS01:0x17:Completed 5600000 out of 16000000 steps (35%)
08:22:27:WU00:FS01:0x17:Completed 5760000 out of 16000000 steps (36%)
08:29:46:WU00:FS01:0x17:Completed 5920000 out of 16000000 steps (37%)
08:37:07:WU00:FS01:0x17:Completed 6080000 out of 16000000 steps (38%)
08:45:22:WU00:FS01:0x17:Completed 6240000 out of 16000000 steps (39%)
08:52:52:WU00:FS01:0x17:Completed 6400000 out of 16000000 steps (40%)
09:00:28:WU00:FS01:0x17:Completed 6560000 out of 16000000 steps (41%)
09:07:55:WU00:FS01:0x17:Completed 6720000 out of 16000000 steps (42%)
09:15:19:WU00:FS01:0x17:Completed 6880000 out of 16000000 steps (43%)
09:22:39:WU00:FS01:0x17:Completed 7040000 out of 16000000 steps (44%)
09:29:58:WU00:FS01:0x17:Completed 7200000 out of 16000000 steps (45%)
09:37:24:WU00:FS01:0x17:Completed 7360000 out of 16000000 steps (46%)
09:44:45:WU00:FS01:0x17:Completed 7520000 out of 16000000 steps (47%)
09:52:04:WU00:FS01:0x17:Completed 7680000 out of 16000000 steps (48%)
09:59:26:WU00:FS01:0x17:Completed 7840000 out of 16000000 steps (49%)
10:06:46:WU00:FS01:0x17:Completed 8000000 out of 16000000 steps (50%)
10:14:12:WU00:FS01:0x17:Completed 8160000 out of 16000000 steps (51%)
10:21:33:WU00:FS01:0x17:Completed 8320000 out of 16000000 steps (52%)
10:28:52:WU00:FS01:0x17:Completed 8480000 out of 16000000 steps (53%)
10:36:12:WU00:FS01:0x17:Completed 8640000 out of 16000000 steps (54%)
10:43:33:WU00:FS01:0x17:Completed 8800000 out of 16000000 steps (55%)
10:50:59:WU00:FS01:0x17:Completed 8960000 out of 16000000 steps (56%)
10:58:19:WU00:FS01:0x17:Completed 9120000 out of 16000000 steps (57%)
11:05:38:WU00:FS01:0x17:Completed 9280000 out of 16000000 steps (58%)
11:12:59:WU00:FS01:0x17:Completed 9440000 out of 16000000 steps (59%)
11:20:20:WU00:FS01:0x17:Completed 9600000 out of 16000000 steps (60%)
11:27:45:WU00:FS01:0x17:Completed 9760000 out of 16000000 steps (61%)
11:35:06:WU00:FS01:0x17:Completed 9920000 out of 16000000 steps (62%)
11:42:26:WU00:FS01:0x17:Completed 10080000 out of 16000000 steps (63%)
11:49:46:WU00:FS01:0x17:Completed 10240000 out of 16000000 steps (64%)
11:57:06:WU00:FS01:0x17:Completed 10400000 out of 16000000 steps (65%)
12:04:33:WU00:FS01:0x17:Completed 10560000 out of 16000000 steps (66%)
12:11:54:WU00:FS01:0x17:Completed 10720000 out of 16000000 steps (67%)
12:19:14:WU00:FS01:0x17:Completed 10880000 out of 16000000 steps (68%)
12:26:34:WU00:FS01:0x17:Completed 11040000 out of 16000000 steps (69%)
12:33:55:WU00:FS01:0x17:Completed 11200000 out of 16000000 steps (70%)
12:41:20:WU00:FS01:0x17:Completed 11360000 out of 16000000 steps (71%)
12:48:40:WU00:FS01:0x17:Completed 11520000 out of 16000000 steps (72%)
12:56:01:WU00:FS01:0x17:Completed 11680000 out of 16000000 steps (73%)
13:03:20:WU00:FS01:0x17:Completed 11840000 out of 16000000 steps (74%)
13:10:41:WU00:FS01:0x17:Completed 12000000 out of 16000000 steps (75%)
13:18:06:WU00:FS01:0x17:Completed 12160000 out of 16000000 steps (76%)
13:25:27:WU00:FS01:0x17:Completed 12320000 out of 16000000 steps (77%)
13:32:48:WU00:FS01:0x17:Completed 12480000 out of 16000000 steps (78%)
13:40:07:WU00:FS01:0x17:Completed 12640000 out of 16000000 steps (79%)
13:47:28:WU00:FS01:0x17:Completed 12800000 out of 16000000 steps (80%)
13:54:55:WU00:FS01:0x17:Completed 12960000 out of 16000000 steps (81%)
14:02:15:WU00:FS01:0x17:Completed 13120000 out of 16000000 steps (82%)
14:09:36:WU00:FS01:0x17:Completed 13280000 out of 16000000 steps (83%)
14:16:55:WU00:FS01:0x17:Completed 13440000 out of 16000000 steps (84%)
14:24:16:WU00:FS01:0x17:Completed 13600000 out of 16000000 steps (85%)
14:31:43:WU00:FS01:0x17:Completed 13760000 out of 16000000 steps (86%)
14:39:09:WU00:FS01:0x17:Completed 13920000 out of 16000000 steps (87%)
14:47:00:WU00:FS01:0x17:Completed 14080000 out of 16000000 steps (88%)
14:54:34:WU00:FS01:0x17:Completed 14240000 out of 16000000 steps (89%)
15:02:30:WU00:FS01:0x17:Completed 14400000 out of 16000000 steps (90%)
15:10:23:WU00:FS01:0x17:Completed 14560000 out of 16000000 steps (91%)
15:18:28:WU00:FS01:0x17:Completed 14720000 out of 16000000 steps (92%)
15:26:03:WU00:FS01:0x17:Completed 14880000 out of 16000000 steps (93%)
15:33:41:WU00:FS01:0x17:Completed 15040000 out of 16000000 steps (94%)
15:41:19:WU00:FS01:0x17:Completed 15200000 out of 16000000 steps (95%)
15:48:56:WU00:FS01:0x17:Completed 15360000 out of 16000000 steps (96%)
15:56:34:WU00:FS01:0x17:Completed 15520000 out of 16000000 steps (97%)
16:04:15:WU00:FS01:0x17:Completed 15680000 out of 16000000 steps (98%)
16:11:48:WU00:FS01:0x17:Completed 15840000 out of 16000000 steps (99%)P.S. We do not need the full log, just the first 100 or so lines that show your system information and folding configuration. See this topic for directions on posting logs and other relevant information - viewtopic.php?f=61&t=26036.
yeah, that is what the "Code" box is for, right of the "Quote" box on the post menu.Have fun with around as much of a log as the 6k charachter limit allows me. Btw, isn't there a spoiler tag?
Transparency and Accountability, the necessary foundation of any great endeavor!
ChristianVirtual
The core 17 looks a bit slower compared to mine; but could be a Windows vs Linux and driver version topic. I run CentOS 7/nV346.35 and a bit better PPD (not much).
Since you run windows you also get core 15 ; which will be based on luck, I mean assignments, change your PPD up or down.
Even so, I used to get around 200~240k PPD on Core 17, with Windows 7 (and who knows which driver it was back in January...). I doubt that Windows 8.1 + current drivers would have THAT much of a performance hit.ChristianVirtual wrote:The core 17 looks a bit slower compared to mine; but could be a Windows vs Linux and driver version topic. I run CentOS 7/nV346.35 and a bit better PPD (not much).
Kent Irwin
I'm running 2 970's in 2 different machines running Win 8.1. I'm using driver version 347.88 and get from 270-280k ppd for core 17 projects. Both cards are somewhat overclocked as well. Dropping the overclock the ppd is ~ 250k.
Reading through your log your system is getting a mix of Core_17 and Core_15 WU assignments. Core_15 projects are older and do not get a Quick Return Bonus, just base points, which will drop your PPD. They will be assigned whenever the WS's are out of Core_17 or Core_18 work appropriate for your system and client settings.Imakuni wrote:Even so, I used to get around 200~240k PPD on Core 17, with Windows 7 (and who knows which driver it was back in January...). I doubt that Windows 8.1 + current drivers would have THAT much of a performance hit.ChristianVirtual wrote:The core 17 looks a bit slower compared to mine; but could be a Windows vs Linux and driver version topic. I run CentOS 7/nV346.35 and a bit better PPD (not much).
Correct me if I'm wrong, but on the WU stats, doesn't the "Estimated PPD" that shows up right below "Estimated Credit" take into consideration only that particular WU? I'm not really looking at my overall PPD, I'm looking at Core 17 only PPDs.Joe_H wrote:Reading through your log your system is getting a mix of Core_17 and Core_15 WU assignments. Core_15 projects are older and do not get a Quick Return Bonus, just base points, which will drop your PPD. They will be assigned whenever the WS's are out of Core_17 or Core_18 work appropriate for your system and client settings.Imakuni wrote:Even so, I used to get around 200~240k PPD on Core 17, with Windows 7 (and who knows which driver it was back in January...). I doubt that Windows 8.1 + current drivers would have THAT much of a performance hit.ChristianVirtual wrote:The core 17 looks a bit slower compared to mine; but could be a Windows vs Linux and driver version topic. I run CentOS 7/nV346.35 and a bit better PPD (not much).
