Failed to get assignment: 171.67.108.200/204 (Linux)
DocJonz
Post by DocJonz »
I have a Linux machine which finished its last WU today, but is stuck awaiting the next assignment from 171.67.108.200 / 171.67.108.204 ....
14:13:58:WU00:FS00:Connecting to 171.67.108.200:8080
14:13:59:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
14:13:59:WU00:FS00:Connecting to 171.67.108.204:80
14:14:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:14:00:ERROR:WU00:FS00:Exception: Could not get an assignment
14:15:35:WU00:FS00:Connecting to 171.67.108.200:8080
14:15:36:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
14:15:36:WU00:FS00:Connecting to 171.67.108.204:80
14:15:37:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:15:37:ERROR:WU00:FS00:Exception: Could not get an assignment
14:18:12:WU00:FS00:Connecting to 171.67.108.200:8080
14:18:13:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
14:18:13:WU00:FS00:Connecting to 171.67.108.204:80
14:18:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:18:14:ERROR:WU00:FS00:Exception: Could not get an assignment
14:22:27:WU00:FS00:Connecting to 171.67.108.200:8080
14:22:27:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
14:22:27:WU00:FS00:Connecting to 171.67.108.204:80
14:22:28:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:22:28:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: Failed to get assignment: 171.67.108.200/204
Please read bruce's post - viewtopic.php?f=18&t=27225&p=275243#p275243 - and prior posts in that topic. Absent any information about your configuration or which Work Servers your system normally connects to and obtains work from, there is not much anyone can do to help you. The two Assignment Servers are reporting what they can, which is that there is no work suitable for your system as presented to the AS currently available on a WS it could assign you to. The AS has no work itself to assign.
DocJonz
Post by DocJonz »
These were the only IP's I could see in the latter part of the log.
Did a F@H uninstall and re-install - things now seem to be working again.
You can always either use the Refresh function to load the log from the beginning, and then scroll to a point before the failed assignment messages, or access the current and older logs directly to find what WS IP's had been used for assignments in the past.
If this occurs again, also posting system and configuration information as shown in the beginning section of the log is most useful.
Unfortuntely you didn't provide enough information for us to help you. The message you reported doesn't provide the necessary information.
Suppose you have a slot with (7 CPUs) on a (Linux) machine which is set to Client-type=('normal'), (Client=V6) Further suppose all of the work servers which have projects for the criteria of V6/normal/Linux/CPU:7 are either Down or they've run out of WUs. Your client will contact the first assignment server which will report that no Work Servers can satisfy your request. Then the second assignment server will report the same issue. Now suppose you change client-type to 'advanced" and now the Assignment Server is able to find a Work Server that has WUs from and Adanced project. The assignment server will successfully ASSIGN YOU TO THAT WORK SERVER which will allow you to download a WU for that slot. Of course if in the meantime, somebody returns a few normal WUs to one of the servers, you may also be assigned to that Work Server.
In any case there are only two Assignment Servers which help direct you to a suitable Work Server (if there is one).
[Replace those criteria with whatever is applicable; they're just an example and I could have used the ones that apply to you if you had posted that part of your log.)
If necessary, the Pande Group might be able to repair a specific work server which is Down or add some WUs to a specific Work server for (critera1)(critera2)(criteria3)... if you had provided that information.
See the same explanation here: 171.67.108.200 [You MUST report a different server.]
DocJonz
Post by DocJonz »
Spoke too soon (and Bruce locked the other thread) ...
Attached is the log since the re-install - seems it struggles to get an assignment and it has sat in the current 'coma' state for the last 8 hrs, and it doesn't appear to want to re-awaken.
*********************** Log Started 2015-04-12T15:46:55Z ***********************
15:46:55:************************* Folding@home Client *************************
15:46:55:    Website: http://folding.stanford.edu/
15:46:55:  Copyright: (c) 2009-2014 Stanford University
15:46:55:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:46:55:       Args: --child --lifeline 1643 /etc/fahclient/config.xml --run-as
15:46:55:             fahclient --pid-file=/var/run/fahclient.pid --daemon
15:46:55:     Config: /etc/fahclient/config.xml
15:46:55:******************************** Build ********************************
15:46:55:    Version: 7.4.4
15:46:55:       Date: Mar 4 2014
15:46:55:       Time: 12:02:38
15:46:55:    SVN Rev: 4130
15:46:55:     Branch: fah/trunk/client
15:46:55:   Compiler: GNU 4.4.7
15:46:55:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
15:46:55:             -fno-unsafe-math-optimizations -msse2
15:46:55:   Platform: linux2 3.2.0-1-amd64
15:46:55:       Bits: 64
15:46:55:       Mode: Release
15:46:55:******************************* System ********************************
15:46:55:        CPU: AMD Opteron(tm) Processor 6338P
15:46:55:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
15:46:55:       CPUs: 48
15:46:55:     Memory: 31.40GiB
15:46:55:Free Memory: 30.71GiB
15:46:55:    Threads: POSIX_THREADS
15:46:55: OS Version: 3.13
15:46:55:Has Battery: false
15:46:55: On Battery: false
15:46:55: UTC Offset: 1
15:46:55:        PID: 1645
15:46:55:        CWD: /var/lib/fahclient
15:46:55:         OS: Linux 3.13.0-49-generic x86_64
15:46:55:    OS Arch: AMD64
15:46:55:       GPUs: 1
15:46:55:      GPU 0: NVIDIA:2 GF116 [GeForce GTS 450]
15:46:55:       CUDA: 2.1
15:46:55:CUDA Driver: 6000
15:46:55:***********************************************************************
15:46:55:<config>
15:46:55:  <!-- Client Control -->
15:46:55:  <fold-anon v='true'/>
15:46:55:
15:46:55:  <!-- Folding Slot Configuration -->
15:46:55:  <gpu v='false'/>
15:46:55:
15:46:55:  <!-- HTTP Server -->
15:46:55:  <allow v='127.0.0.1,192.168.1.0/24'/>
15:46:55:
15:46:55:  <!-- Network -->
15:46:55:  <proxy v=':8080'/>
15:46:55:
15:46:55:  <!-- Remote Command Server -->
15:46:55:  <password v='*******'/>
15:46:55:
15:46:55:  <!-- Slot Control -->
15:46:55:  <power v='full'/>
15:46:55:
15:46:55:  <!-- User Information -->
15:46:55:  <passkey v='********************************'/>
15:46:55:  <team v='35947'/>
15:46:55:  <user v='DocJonz'/>
15:46:55:
15:46:55:  <!-- Folding Slots -->
15:46:55:  <slot id='0' type='CPU'>
15:46:55:</config>
15:46:55:Switching to user fahclient
15:46:55:Trying to access database...
15:46:55:Successfully acquired database lock
15:46:55:Enabled folding slot 00: PAUSED cpu:48 (by user)
15:48:08:FS00:Unpaused
15:48:08:WU00:FS00:Starting
15:48:08:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 00 -suffix 01 -version 704 -lifeline 1645 -checkpoint 15 -np 48
15:48:08:WU00:FS00:Started FahCore on PID 3452
15:48:08:WU00:FS00:Core PID:3456
15:48:08:WU00:FS00:FahCore 0xa3 started
15:48:09:WU00:FS00:0xa3:
15:48:09:WU00:FS00:0xa3:*------------------------------*
15:48:09:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
15:48:09:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
15:48:09:WU00:FS00:0xa3:Preparing to commence simulation
15:48:09:WU00:FS00:0xa3:- Looking at optimizations...
15:48:09:WU00:FS00:0xa3:- Files status OK
15:48:09:WU00:FS00:0xa3:- Expanded 3804230 -> 4176600 (decompressed 109.7 percent)
15:48:09:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3804230 data_size=4176600, decompressed_data_size=4176600 diff=0
15:48:09:WU00:FS00:0xa3:- Digital signature verified
15:48:09:WU00:FS00:0xa3:Project: 8804 (Run 0, Clone 24, Gen 460)
15:48:09:WU00:FS00:0xa3:Assembly optimizations on if available.
15:48:09:WU00:FS00:0xa3:Entering M.D.
15:48:15:WU00:FS00:0xa3:Mapping NT from 48 to 48
15:48:16:WU00:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
15:51:09:WU00:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
15:53:56:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
15:56:03:</config>
15:56:04:Saving configuration to /etc/fahclient/config.xml
15:56:04:<config>
15:56:04:  <!-- Client Control -->
15:56:04:  <fold-anon v='true'/>
15:56:04:
15:56:04:  <!-- Folding Slot Configuration -->
15:56:04:  <gpu v='false'/>
15:56:04:
15:56:04:  <!-- HTTP Server -->
15:56:04:  <allow v='127.0.0.1,192.168.1.0/24'/>
15:56:04:
15:56:04:  <!-- Network -->
15:56:04:  <proxy v=':8080'/>
15:56:04:
15:56:04:  <!-- Remote Command Server -->
15:56:04:  <password v='*******'/>
15:56:04:
15:56:04:  <!-- Slot Control -->
15:56:04:  <power v='full'/>
15:56:04:
15:56:04:  <!-- User Information -->
15:56:04:  <passkey v='********************************'/>
15:56:04:  <team v='35947'/>
15:56:04:  <user v='DocJonz'/>
15:56:04:
15:56:04:  <!-- Folding Slots -->
15:56:04:  <slot id='0' type='CPU'/>
15:56:04:</config>
15:56:44:WU00:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
15:59:34:WU00:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
16:02:24:WU00:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
16:05:15:WU00:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
16:08:11:WU00:FS00:0xa3:Completed 35000 out of 500000 steps  (7%)
16:11:06:WU00:FS00:0xa3:Completed 40000 out of 500000 steps  (8%)
16:14:04:WU00:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
16:17:00:WU00:FS00:0xa3:Completed 50000 out of 500000 steps  (10%)
16:19:58:WU00:FS00:0xa3:Completed 55000 out of 500000 steps  (11%)
16:22:54:WU00:FS00:0xa3:Completed 60000 out of 500000 steps  (12%)
16:25:47:WU00:FS00:0xa3:Completed 65000 out of 500000 steps  (13%)
16:28:34:WU00:FS00:0xa3:Completed 70000 out of 500000 steps  (14%)
16:31:22:WU00:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
16:34:13:WU00:FS00:0xa3:Completed 80000 out of 500000 steps  (16%)
16:37:07:WU00:FS00:0xa3:Completed 85000 out of 500000 steps  (17%)
16:40:01:WU00:FS00:0xa3:Completed 90000 out of 500000 steps  (18%)
16:42:57:WU00:FS00:0xa3:Completed 95000 out of 500000 steps  (19%)
16:45:52:WU00:FS00:0xa3:Completed 100000 out of 500000 steps  (20%)
16:48:47:WU00:FS00:0xa3:Completed 105000 out of 500000 steps  (21%)
16:51:42:WU00:FS00:0xa3:Completed 110000 out of 500000 steps  (22%)
16:54:37:WU00:FS00:0xa3:Completed 115000 out of 500000 steps  (23%)
16:57:36:WU00:FS00:0xa3:Completed 120000 out of 500000 steps  (24%)
17:00:33:WU00:FS00:0xa3:Completed 125000 out of 500000 steps  (25%)
17:03:25:WU00:FS00:0xa3:Completed 130000 out of 500000 steps  (26%)
17:06:15:WU00:FS00:0xa3:Completed 135000 out of 500000 steps  (27%)
17:09:09:WU00:FS00:0xa3:Completed 140000 out of 500000 steps  (28%)
17:12:01:WU00:FS00:0xa3:Completed 145000 out of 500000 steps  (29%)
17:14:50:WU00:FS00:0xa3:Completed 150000 out of 500000 steps  (30%)
17:17:48:WU00:FS00:0xa3:Completed 155000 out of 500000 steps  (31%)
17:20:42:WU00:FS00:0xa3:Completed 160000 out of 500000 steps  (32%)
17:23:36:WU00:FS00:0xa3:Completed 165000 out of 500000 steps  (33%)
17:26:32:WU00:FS00:0xa3:Completed 170000 out of 500000 steps  (34%)
17:29:26:WU00:FS00:0xa3:Completed 175000 out of 500000 steps  (35%)
17:32:26:WU00:FS00:0xa3:Completed 180000 out of 500000 steps  (36%)
17:35:22:WU00:FS00:0xa3:Completed 185000 out of 500000 steps  (37%)
17:38:15:WU00:FS00:0xa3:Completed 190000 out of 500000 steps  (38%)
17:41:11:WU00:FS00:0xa3:Completed 195000 out of 500000 steps  (39%)
17:44:05:WU00:FS00:0xa3:Completed 200000 out of 500000 steps  (40%)
17:46:59:WU00:FS00:0xa3:Completed 205000 out of 500000 steps  (41%)
17:49:50:WU00:FS00:0xa3:Completed 210000 out of 500000 steps  (42%)
17:52:41:WU00:FS00:0xa3:Completed 215000 out of 500000 steps  (43%)
17:55:31:WU00:FS00:0xa3:Completed 220000 out of 500000 steps  (44%)
17:58:19:WU00:FS00:0xa3:Completed 225000 out of 500000 steps  (45%)
18:01:07:WU00:FS00:0xa3:Completed 230000 out of 500000 steps  (46%)
18:03:57:WU00:FS00:0xa3:Completed 235000 out of 500000 steps  (47%)
18:06:45:WU00:FS00:0xa3:Completed 240000 out of 500000 steps  (48%)
18:09:35:WU00:FS00:0xa3:Completed 245000 out of 500000 steps  (49%)
18:12:26:WU00:FS00:0xa3:Completed 250000 out of 500000 steps  (50%)
18:15:14:WU00:FS00:0xa3:Completed 255000 out of 500000 steps  (51%)
18:18:03:WU00:FS00:0xa3:Completed 260000 out of 500000 steps  (52%)
18:20:57:WU00:FS00:0xa3:Completed 265000 out of 500000 steps  (53%)
18:23:50:WU00:FS00:0xa3:Completed 270000 out of 500000 steps  (54%)
18:26:45:WU00:FS00:0xa3:Completed 275000 out of 500000 steps  (55%)
18:29:40:WU00:FS00:0xa3:Completed 280000 out of 500000 steps  (56%)
18:32:35:WU00:FS00:0xa3:Completed 285000 out of 500000 steps  (57%)
18:35:29:WU00:FS00:0xa3:Completed 290000 out of 500000 steps  (58%)
18:38:19:WU00:FS00:0xa3:Completed 295000 out of 500000 steps  (59%)
18:41:14:WU00:FS00:0xa3:Completed 300000 out of 500000 steps  (60%)
18:44:12:WU00:FS00:0xa3:Completed 305000 out of 500000 steps  (61%)
18:47:07:WU00:FS00:0xa3:Completed 310000 out of 500000 steps  (62%)
18:50:02:WU00:FS00:0xa3:Completed 315000 out of 500000 steps  (63%)
18:52:58:WU00:FS00:0xa3:Completed 320000 out of 500000 steps  (64%)
18:55:54:WU00:FS00:0xa3:Completed 325000 out of 500000 steps  (65%)
18:58:44:WU00:FS00:0xa3:Completed 330000 out of 500000 steps  (66%)
19:01:38:WU00:FS00:0xa3:Completed 335000 out of 500000 steps  (67%)
19:04:28:WU00:FS00:0xa3:Completed 340000 out of 500000 steps  (68%)
19:07:18:WU00:FS00:0xa3:Completed 345000 out of 500000 steps  (69%)
19:10:04:WU00:FS00:0xa3:Completed 350000 out of 500000 steps  (70%)
19:12:53:WU00:FS00:0xa3:Completed 355000 out of 500000 steps  (71%)
19:15:44:WU00:FS00:0xa3:Completed 360000 out of 500000 steps  (72%)
19:18:35:WU00:FS00:0xa3:Completed 365000 out of 500000 steps  (73%)
19:21:28:WU00:FS00:0xa3:Completed 370000 out of 500000 steps  (74%)
19:24:21:WU00:FS00:0xa3:Completed 375000 out of 500000 steps  (75%)
19:27:13:WU00:FS00:0xa3:Completed 380000 out of 500000 steps  (76%)
19:30:08:WU00:FS00:0xa3:Completed 385000 out of 500000 steps  (77%)
19:33:05:WU00:FS00:0xa3:Completed 390000 out of 500000 steps  (78%)
19:36:00:WU00:FS00:0xa3:Completed 395000 out of 500000 steps  (79%)
19:38:49:WU00:FS00:0xa3:Completed 400000 out of 500000 steps  (80%)
19:41:41:WU00:FS00:0xa3:Completed 405000 out of 500000 steps  (81%)
19:44:35:WU00:FS00:0xa3:Completed 410000 out of 500000 steps  (82%)
19:47:28:WU00:FS00:0xa3:Completed 415000 out of 500000 steps  (83%)
19:50:24:WU00:FS00:0xa3:Completed 420000 out of 500000 steps  (84%)
19:53:20:WU00:FS00:0xa3:Completed 425000 out of 500000 steps  (85%)
19:56:19:WU00:FS00:0xa3:Completed 430000 out of 500000 steps  (86%)
19:59:16:WU00:FS00:0xa3:Completed 435000 out of 500000 steps  (87%)
20:02:18:WU00:FS00:0xa3:Completed 440000 out of 500000 steps  (88%)
20:05:19:WU00:FS00:0xa3:Completed 445000 out of 500000 steps  (89%)
20:08:19:WU00:FS00:0xa3:Completed 450000 out of 500000 steps  (90%)
20:11:18:WU00:FS00:0xa3:Completed 455000 out of 500000 steps  (91%)
20:14:14:WU00:FS00:0xa3:Completed 460000 out of 500000 steps  (92%)
20:17:09:WU00:FS00:0xa3:Completed 465000 out of 500000 steps  (93%)
20:20:06:WU00:FS00:0xa3:Completed 470000 out of 500000 steps  (94%)
20:23:05:WU00:FS00:0xa3:Completed 475000 out of 500000 steps  (95%)
20:26:01:WU00:FS00:0xa3:Completed 480000 out of 500000 steps  (96%)
20:28:55:WU00:FS00:0xa3:Completed 485000 out of 500000 steps  (97%)
20:31:50:WU00:FS00:0xa3:Completed 490000 out of 500000 steps  (98%)
20:34:44:WU00:FS00:0xa3:Completed 495000 out of 500000 steps  (99%)
20:34:45:WU01:FS00:Connecting to 171.67.108.200:8080
20:34:46:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:34:46:WU01:FS00:Connecting to 171.67.108.204:80
20:34:47:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:34:47:ERROR:WU01:FS00:Exception: Could not get an assignment
20:34:47:WU01:FS00:Connecting to 171.67.108.200:8080
20:34:48:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:34:48:WU01:FS00:Connecting to 171.67.108.204:80
20:34:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:34:49:ERROR:WU01:FS00:Exception: Could not get an assignment
20:35:47:WU01:FS00:Connecting to 171.67.108.200:8080
20:35:48:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:35:48:WU01:FS00:Connecting to 171.67.108.204:80
20:35:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:35:49:ERROR:WU01:FS00:Exception: Could not get an assignment
20:37:25:WU01:FS00:Connecting to 171.67.108.200:8080
20:37:26:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:37:26:WU01:FS00:Connecting to 171.67.108.204:80
20:37:26:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:37:26:ERROR:WU01:FS00:Exception: Could not get an assignment
20:37:41:WU00:FS00:0xa3:Completed 500000 out of 500000 steps  (100%)
20:37:43:WU00:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
20:37:53:WU00:FS00:0xa3:
20:37:53:WU00:FS00:0xa3:Finished Work Unit:
20:37:53:WU00:FS00:0xa3:- Reading up to 8032368 from "00/wudata_01.trr": Read 8032368
20:37:53:WU00:FS00:0xa3:trr file hash check passed.
20:37:53:WU00:FS00:0xa3:edr file hash check passed.
20:37:53:WU00:FS00:0xa3:logfile size: 56609
20:37:53:WU00:FS00:0xa3:Leaving Run
20:37:55:WU00:FS00:0xa3:- Writing 8125809 bytes of core data to disk...
20:37:57:WU00:FS00:0xa3:Done: 8125297 -> 7503472 (compressed to 92.3 percent)
20:37:57:WU00:FS00:0xa3:  ... Done.
20:40:02:WU01:FS00:Connecting to 171.67.108.200:8080
20:40:03:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:40:03:WU01:FS00:Connecting to 171.67.108.204:80
20:40:03:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:40:03:ERROR:WU01:FS00:Exception: Could not get an assignment
20:42:44:WU00:FS00:0xa3:- Shutting down core
20:42:44:WU00:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
20:43:22:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:43:22:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8804 run:0 clone:24 gen:460 core:0xa3 unit:0x000002b8fbcb017c5193d3c127d80b34
20:43:23:WU00:FS00:Uploading 7.16MiB to 128.143.199.96
20:43:23:WU00:FS00:Connecting to 128.143.199.96:8080
20:43:29:WU00:FS00:Upload complete
20:43:29:WU00:FS00:Server responded WORK_ACK (400)
20:43:29:WU00:FS00:Final credit estimate, 22005.00 points
20:43:30:WU00:FS00:Cleaning up
20:44:16:WU01:FS00:Connecting to 171.67.108.200:8080
20:44:17:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:44:17:WU01:FS00:Connecting to 171.67.108.204:80
20:44:18:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:44:18:ERROR:WU01:FS00:Exception: Could not get an assignment
20:51:08:WU01:FS00:Connecting to 171.67.108.200:8080
20:51:09:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
20:51:09:WU01:FS00:Connecting to 171.67.108.204:80
20:51:09:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:51:09:ERROR:WU01:FS00:Exception: Could not get an assignment
21:02:13:WU01:FS00:Connecting to 171.67.108.200:8080
21:02:14:WU01:FS00:Assigned to work server 128.143.199.96
21:02:14:WU01:FS00:Requesting new work unit for slot 00: READY cpu:48 from 128.143.199.96
21:02:14:WU01:FS00:Connecting to 128.143.199.96:8080
21:02:16:WU01:FS00:Downloading 3.63MiB
21:02:17:WU01:FS00:Download complete
21:02:17:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8827 run:0 clone:13 gen:411 core:0xa3 unit:0x00000263fbcb017c51a4d0442f6fd9f4
21:02:17:WU01:FS00:Starting
21:02:17:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 01 -suffix 01 -version 704 -lifeline 1645 -checkpoint 15 -np 48
21:02:17:WU01:FS00:Started FahCore on PID 4776
21:02:17:WU01:FS00:Core PID:4780
21:02:17:WU01:FS00:FahCore 0xa3 started
21:02:18:WU01:FS00:0xa3:
21:02:18:WU01:FS00:0xa3:*------------------------------*
21:02:18:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
21:02:18:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
21:02:18:WU01:FS00:0xa3:Preparing to commence simulation
21:02:18:WU01:FS00:0xa3:- Looking at optimizations...
21:02:18:WU01:FS00:0xa3:- Created dyn
21:02:18:WU01:FS00:0xa3:- Files status OK
21:02:18:WU01:FS00:0xa3:- Expanded 3803311 -> 4169644 (decompressed 109.6 percent)
21:02:18:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3803311 data_size=4169644, decompressed_data_size=4169644 diff=0
21:02:18:WU01:FS00:0xa3:- Digital signature verified
21:02:18:WU01:FS00:0xa3:Project: 8827 (Run 0, Clone 13, Gen 411)
21:02:18:WU01:FS00:0xa3:Assembly optimizations on if available.
21:02:18:WU01:FS00:0xa3:Entering M.D.
21:02:24:WU01:FS00:0xa3:Mapping NT from 48 to 48
21:02:25:WU01:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
21:05:17:WU01:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
21:08:08:WU01:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
21:10:55:WU01:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
21:13:42:WU01:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
21:16:29:WU01:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
21:19:18:WU01:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
21:22:05:WU01:FS00:0xa3:Completed 35000 out of 500000 steps  (7%)
21:24:51:WU01:FS00:0xa3:Completed 40000 out of 500000 steps  (8%)
21:27:36:WU01:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
21:30:25:WU01:FS00:0xa3:Completed 50000 out of 500000 steps  (10%)
21:33:16:WU01:FS00:0xa3:Completed 55000 out of 500000 steps  (11%)
21:36:03:WU01:FS00:0xa3:Completed 60000 out of 500000 steps  (12%)
21:38:53:WU01:FS00:0xa3:Completed 65000 out of 500000 steps  (13%)
21:41:44:WU01:FS00:0xa3:Completed 70000 out of 500000 steps  (14%)
21:44:33:WU01:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
******************************* Date: 2015-04-12 *******************************
21:47:25:WU01:FS00:0xa3:Completed 80000 out of 500000 steps  (16%)
21:50:14:WU01:FS00:0xa3:Completed 85000 out of 500000 steps  (17%)
21:53:00:WU01:FS00:0xa3:Completed 90000 out of 500000 steps  (18%)
21:55:48:WU01:FS00:0xa3:Completed 95000 out of 500000 steps  (19%)
21:58:36:WU01:FS00:0xa3:Completed 100000 out of 500000 steps  (20%)
22:01:25:WU01:FS00:0xa3:Completed 105000 out of 500000 steps  (21%)
22:04:14:WU01:FS00:0xa3:Completed 110000 out of 500000 steps  (22%)
22:07:08:WU01:FS00:0xa3:Completed 115000 out of 500000 steps  (23%)
22:10:01:WU01:FS00:0xa3:Completed 120000 out of 500000 steps  (24%)
22:12:56:WU01:FS00:0xa3:Completed 125000 out of 500000 steps  (25%)
22:15:52:WU01:FS00:0xa3:Completed 130000 out of 500000 steps  (26%)
22:18:49:WU01:FS00:0xa3:Completed 135000 out of 500000 steps  (27%)
22:21:45:WU01:FS00:0xa3:Completed 140000 out of 500000 steps  (28%)
22:24:40:WU01:FS00:0xa3:Completed 145000 out of 500000 steps  (29%)
22:27:35:WU01:FS00:0xa3:Completed 150000 out of 500000 steps  (30%)
22:30:29:WU01:FS00:0xa3:Completed 155000 out of 500000 steps  (31%)
22:33:24:WU01:FS00:0xa3:Completed 160000 out of 500000 steps  (32%)
22:36:22:WU01:FS00:0xa3:Completed 165000 out of 500000 steps  (33%)
22:39:16:WU01:FS00:0xa3:Completed 170000 out of 500000 steps  (34%)
22:42:10:WU01:FS00:0xa3:Completed 175000 out of 500000 steps  (35%)
22:45:04:WU01:FS00:0xa3:Completed 180000 out of 500000 steps  (36%)
22:48:01:WU01:FS00:0xa3:Completed 185000 out of 500000 steps  (37%)
22:50:55:WU01:FS00:0xa3:Completed 190000 out of 500000 steps  (38%)
22:53:49:WU01:FS00:0xa3:Completed 195000 out of 500000 steps  (39%)
22:56:39:WU01:FS00:0xa3:Completed 200000 out of 500000 steps  (40%)
22:59:29:WU01:FS00:0xa3:Completed 205000 out of 500000 steps  (41%)
23:02:15:WU01:FS00:0xa3:Completed 210000 out of 500000 steps  (42%)
23:05:01:WU01:FS00:0xa3:Completed 215000 out of 500000 steps  (43%)
23:07:46:WU01:FS00:0xa3:Completed 220000 out of 500000 steps  (44%)
23:10:34:WU01:FS00:0xa3:Completed 225000 out of 500000 steps  (45%)
23:13:24:WU01:FS00:0xa3:Completed 230000 out of 500000 steps  (46%)
23:16:11:WU01:FS00:0xa3:Completed 235000 out of 500000 steps  (47%)
23:19:01:WU01:FS00:0xa3:Completed 240000 out of 500000 steps  (48%)
23:21:50:WU01:FS00:0xa3:Completed 245000 out of 500000 steps  (49%)
23:24:36:WU01:FS00:0xa3:Completed 250000 out of 500000 steps  (50%)
23:27:25:WU01:FS00:0xa3:Completed 255000 out of 500000 steps  (51%)
23:30:13:WU01:FS00:0xa3:Completed 260000 out of 500000 steps  (52%)
23:33:00:WU01:FS00:0xa3:Completed 265000 out of 500000 steps  (53%)
23:35:48:WU01:FS00:0xa3:Completed 270000 out of 500000 steps  (54%)
23:38:40:WU01:FS00:0xa3:Completed 275000 out of 500000 steps  (55%)
23:41:29:WU01:FS00:0xa3:Completed 280000 out of 500000 steps  (56%)
23:44:15:WU01:FS00:0xa3:Completed 285000 out of 500000 steps  (57%)
23:47:04:WU01:FS00:0xa3:Completed 290000 out of 500000 steps  (58%)
23:49:51:WU01:FS00:0xa3:Completed 295000 out of 500000 steps  (59%)
23:52:39:WU01:FS00:0xa3:Completed 300000 out of 500000 steps  (60%)
23:55:31:WU01:FS00:0xa3:Completed 305000 out of 500000 steps  (61%)
23:58:22:WU01:FS00:0xa3:Completed 310000 out of 500000 steps  (62%)
00:01:13:WU01:FS00:0xa3:Completed 315000 out of 500000 steps  (63%)
00:04:04:WU01:FS00:0xa3:Completed 320000 out of 500000 steps  (64%)
00:06:56:WU01:FS00:0xa3:Completed 325000 out of 500000 steps  (65%)
00:09:45:WU01:FS00:0xa3:Completed 330000 out of 500000 steps  (66%)
00:12:34:WU01:FS00:0xa3:Completed 335000 out of 500000 steps  (67%)
00:15:22:WU01:FS00:0xa3:Completed 340000 out of 500000 steps  (68%)
00:18:14:WU01:FS00:0xa3:Completed 345000 out of 500000 steps  (69%)
00:21:04:WU01:FS00:0xa3:Completed 350000 out of 500000 steps  (70%)
00:23:54:WU01:FS00:0xa3:Completed 355000 out of 500000 steps  (71%)
00:26:46:WU01:FS00:0xa3:Completed 360000 out of 500000 steps  (72%)
00:29:37:WU01:FS00:0xa3:Completed 365000 out of 500000 steps  (73%)
00:32:28:WU01:FS00:0xa3:Completed 370000 out of 500000 steps  (74%)
00:35:19:WU01:FS00:0xa3:Completed 375000 out of 500000 steps  (75%)
00:38:10:WU01:FS00:0xa3:Completed 380000 out of 500000 steps  (76%)
00:41:00:WU01:FS00:0xa3:Completed 385000 out of 500000 steps  (77%)
00:43:52:WU01:FS00:0xa3:Completed 390000 out of 500000 steps  (78%)
00:46:43:WU01:FS00:0xa3:Completed 395000 out of 500000 steps  (79%)
00:49:33:WU01:FS00:0xa3:Completed 400000 out of 500000 steps  (80%)
00:52:26:WU01:FS00:0xa3:Completed 405000 out of 500000 steps  (81%)
00:55:19:WU01:FS00:0xa3:Completed 410000 out of 500000 steps  (82%)
00:58:08:WU01:FS00:0xa3:Completed 415000 out of 500000 steps  (83%)
01:01:03:WU01:FS00:0xa3:Completed 420000 out of 500000 steps  (84%)
01:03:54:WU01:FS00:0xa3:Completed 425000 out of 500000 steps  (85%)
01:06:46:WU01:FS00:0xa3:Completed 430000 out of 500000 steps  (86%)
01:09:38:WU01:FS00:0xa3:Completed 435000 out of 500000 steps  (87%)
01:12:31:WU01:FS00:0xa3:Completed 440000 out of 500000 steps  (88%)
01:15:19:WU01:FS00:0xa3:Completed 445000 out of 500000 steps  (89%)
01:18:10:WU01:FS00:0xa3:Completed 450000 out of 500000 steps  (90%)
01:21:01:WU01:FS00:0xa3:Completed 455000 out of 500000 steps  (91%)
01:23:55:WU01:FS00:0xa3:Completed 460000 out of 500000 steps  (92%)
01:26:46:WU01:FS00:0xa3:Completed 465000 out of 500000 steps  (93%)
01:29:37:WU01:FS00:0xa3:Completed 470000 out of 500000 steps  (94%)
01:32:30:WU01:FS00:0xa3:Completed 475000 out of 500000 steps  (95%)
01:35:20:WU01:FS00:0xa3:Completed 480000 out of 500000 steps  (96%)
01:38:14:WU01:FS00:0xa3:Completed 485000 out of 500000 steps  (97%)
01:41:04:WU01:FS00:0xa3:Completed 490000 out of 500000 steps  (98%)
01:43:51:WU01:FS00:0xa3:Completed 495000 out of 500000 steps  (99%)
01:43:52:WU00:FS00:Connecting to 171.67.108.200:8080
01:43:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
01:43:53:WU00:FS00:Connecting to 171.67.108.204:80
01:43:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
01:43:54:ERROR:WU00:FS00:Exception: Could not get an assignment
01:43:54:WU00:FS00:Connecting to 171.67.108.200:8080
01:43:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
01:43:55:WU00:FS00:Connecting to 171.67.108.204:80
01:43:56:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
01:43:56:ERROR:WU00:FS00:Exception: Could not get an assignment
01:44:54:WU00:FS00:Connecting to 171.67.108.200:8080
01:44:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
01:44:55:WU00:FS00:Connecting to 171.67.108.204:80
01:44:56:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
01:44:56:ERROR:WU00:FS00:Exception: Could not get an assignment
01:46:32:WU00:FS00:Connecting to 171.67.108.200:8080
01:46:32:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
01:46:32:WU00:FS00:Connecting to 171.67.108.204:80
01:46:33:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
01:46:33:ERROR:WU00:FS00:Exception: Could not get an assignment
01:46:40:WU01:FS00:0xa3:Completed 500000 out of 500000 steps  (100%)
01:46:42:WU01:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
01:46:52:WU01:FS00:0xa3:
01:46:52:WU01:FS00:0xa3:Finished Work Unit:
01:46:52:WU01:FS00:0xa3:- Reading up to 8031600 from "01/wudata_01.trr": Read 8031600
01:46:52:WU01:FS00:0xa3:trr file hash check passed.
01:46:52:WU01:FS00:0xa3:edr file hash check passed.
01:46:52:WU01:FS00:0xa3:logfile size: 56543
01:46:52:WU01:FS00:0xa3:Leaving Run
01:46:55:WU01:FS00:0xa3:- Writing 8124975 bytes of core data to disk...
01:46:56:WU01:FS00:0xa3:Done: 8124463 -> 7502872 (compressed to 92.3 percent)
01:46:56:WU01:FS00:0xa3:  ... Done.
01:49:09:WU00:FS00:Connecting to 171.67.108.200:8080
01:49:10:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
01:49:10:WU00:FS00:Connecting to 171.67.108.204:80
01:49:10:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
01:49:10:ERROR:WU00:FS00:Exception: Could not get an assignment
01:51:34:WU01:FS00:0xa3:- Shutting down core
01:51:34:WU01:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
01:52:12:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:52:12:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8827 run:0 clone:13 gen:411 core:0xa3 unit:0x00000263fbcb017c51a4d0442f6fd9f4
01:52:13:WU01:FS00:Uploading 7.16MiB to 128.143.199.96
01:52:13:WU01:FS00:Connecting to 128.143.199.96:8080
01:52:20:WU01:FS00:Upload complete
01:52:20:WU01:FS00:Server responded WORK_ACK (400)
01:52:20:WU01:FS00:Final credit estimate, 22846.00 points
01:52:20:WU01:FS00:Cleaning up
01:53:23:WU00:FS00:Connecting to 171.67.108.200:8080
01:53:24:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
01:53:24:WU00:FS00:Connecting to 171.67.108.204:80
01:53:24:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
01:53:24:ERROR:WU00:FS00:Exception: Could not get an assignment
02:00:15:WU00:FS00:Connecting to 171.67.108.200:8080
02:00:15:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:00:15:WU00:FS00:Connecting to 171.67.108.204:80
02:00:16:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:00:16:ERROR:WU00:FS00:Exception: Could not get an assignment
02:11:20:WU00:FS00:Connecting to 171.67.108.200:8080
02:11:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:11:21:WU00:FS00:Connecting to 171.67.108.204:80
02:11:22:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:11:22:ERROR:WU00:FS00:Exception: Could not get an assignment
02:29:17:WU00:FS00:Connecting to 171.67.108.200:8080
02:29:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:29:18:WU00:FS00:Connecting to 171.67.108.204:80
02:29:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:29:18:ERROR:WU00:FS00:Exception: Could not get an assignment
02:58:20:WU00:FS00:Connecting to 171.67.108.200:8080
02:58:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
02:58:21:WU00:FS00:Connecting to 171.67.108.204:80
02:58:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:58:21:ERROR:WU00:FS00:Exception: Could not get an assignment
03:45:19:WU00:FS00:Connecting to 171.67.108.200:8080
03:45:19:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
03:45:19:WU00:FS00:Connecting to 171.67.108.204:80
03:45:20:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
03:45:20:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2015-04-13 *******************************
05:01:20:WU00:FS00:Connecting to 171.67.108.200:8080
05:01:20:WU00:FS00:Assigned to work server 128.143.199.96
05:01:20:WU00:FS00:Requesting new work unit for slot 00: READY cpu:48 from 128.143.199.96
05:01:20:WU00:FS00:Connecting to 128.143.199.96:8080
05:01:22:WU00:FS00:Downloading 3.63MiB
05:01:23:WU00:FS00:Download complete
05:01:24:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8801 run:0 clone:2 gen:436 core:0xa3 unit:0x000002a1fbcb017c5193957ceeb341b4
05:01:24:WU00:FS00:Starting
05:01:24:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 00 -suffix 01 -version 704 -lifeline 1645 -checkpoint 15 -np 48
05:01:24:WU00:FS00:Started FahCore on PID 6348
05:01:24:WU00:FS00:Core PID:6352
05:01:24:WU00:FS00:FahCore 0xa3 started
05:01:24:WU00:FS00:0xa3:
05:01:24:WU00:FS00:0xa3:*------------------------------*
05:01:24:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
05:01:24:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
05:01:24:WU00:FS00:0xa3:Preparing to commence simulation
05:01:24:WU00:FS00:0xa3:- Looking at optimizations...
05:01:24:WU00:FS00:0xa3:- Created dyn
05:01:24:WU00:FS00:0xa3:- Files status OK
05:01:24:WU00:FS00:0xa3:- Expanded 3803847 -> 4173764 (decompressed 109.7 percent)
05:01:24:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3803847 data_size=4173764, decompressed_data_size=4173764 diff=0
05:01:24:WU00:FS00:0xa3:- Digital signature verified
05:01:24:WU00:FS00:0xa3:Project: 8801 (Run 0, Clone 2, Gen 436)
05:01:24:WU00:FS00:0xa3:Assembly optimizations on if available.
05:01:24:WU00:FS00:0xa3:Entering M.D.
05:01:30:WU00:FS00:0xa3:Mapping NT from 48 to 48
05:01:31:WU00:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
05:04:21:WU00:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
05:07:10:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
05:09:59:WU00:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
05:12:53:WU00:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
05:15:46:WU00:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
05:18:39:WU00:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
05:21:34:WU00:FS00:0xa3:Completed 35000 out of 500000 steps  (7%)
05:24:29:WU00:FS00:0xa3:Completed 40000 out of 500000 steps  (8%)
05:27:20:WU00:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
05:30:14:WU00:FS00:0xa3:Completed 50000 out of 500000 steps  (10%)
05:33:05:WU00:FS00:0xa3:Completed 55000 out of 500000 steps  (11%)
05:35:54:WU00:FS00:0xa3:Completed 60000 out of 500000 steps  (12%)
05:38:48:WU00:FS00:0xa3:Completed 65000 out of 500000 steps  (13%)
05:41:44:WU00:FS00:0xa3:Completed 70000 out of 500000 steps  (14%)
05:44:43:WU00:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
05:47:44:WU00:FS00:0xa3:Completed 80000 out of 500000 steps  (16%)
05:50:41:WU00:FS00:0xa3:Completed 85000 out of 500000 steps  (17%)
05:53:39:WU00:FS00:0xa3:Completed 90000 out of 500000 steps  (18%)
05:56:37:WU00:FS00:0xa3:Completed 95000 out of 500000 steps  (19%)
05:59:31:WU00:FS00:0xa3:Completed 100000 out of 500000 steps  (20%)
06:02:25:WU00:FS00:0xa3:Completed 105000 out of 500000 steps  (21%)
06:05:17:WU00:FS00:0xa3:Completed 110000 out of 500000 steps  (22%)
06:08:07:WU00:FS00:0xa3:Completed 115000 out of 500000 steps  (23%)
06:10:59:WU00:FS00:0xa3:Completed 120000 out of 500000 steps  (24%)
06:13:55:WU00:FS00:0xa3:Completed 125000 out of 500000 steps  (25%)
06:16:52:WU00:FS00:0xa3:Completed 130000 out of 500000 steps  (26%)
06:19:48:WU00:FS00:0xa3:Completed 135000 out of 500000 steps  (27%)
06:22:47:WU00:FS00:0xa3:Completed 140000 out of 500000 steps  (28%)
06:25:43:WU00:FS00:0xa3:Completed 145000 out of 500000 steps  (29%)
06:28:42:WU00:FS00:0xa3:Completed 150000 out of 500000 steps  (30%)
06:31:42:WU00:FS00:0xa3:Completed 155000 out of 500000 steps  (31%)
06:34:37:WU00:FS00:0xa3:Completed 160000 out of 500000 steps  (32%)
06:37:32:WU00:FS00:0xa3:Completed 165000 out of 500000 steps  (33%)
06:40:28:WU00:FS00:0xa3:Completed 170000 out of 500000 steps  (34%)
06:43:24:WU00:FS00:0xa3:Completed 175000 out of 500000 steps  (35%)
06:46:18:WU00:FS00:0xa3:Completed 180000 out of 500000 steps  (36%)
06:49:17:WU00:FS00:0xa3:Completed 185000 out of 500000 steps  (37%)
06:52:13:WU00:FS00:0xa3:Completed 190000 out of 500000 steps  (38%)
06:55:10:WU00:FS00:0xa3:Completed 195000 out of 500000 steps  (39%)
06:58:09:WU00:FS00:0xa3:Completed 200000 out of 500000 steps  (40%)
07:01:05:WU00:FS00:0xa3:Completed 205000 out of 500000 steps  (41%)
07:04:00:WU00:FS00:0xa3:Completed 210000 out of 500000 steps  (42%)
07:07:13:WU00:FS00:0xa3:Completed 215000 out of 500000 steps  (43%)
07:10:04:WU00:FS00:0xa3:Completed 220000 out of 500000 steps  (44%)
07:12:58:WU00:FS00:0xa3:Completed 225000 out of 500000 steps  (45%)
07:15:56:WU00:FS00:0xa3:Completed 230000 out of 500000 steps  (46%)
07:18:51:WU00:FS00:0xa3:Completed 235000 out of 500000 steps  (47%)
07:21:48:WU00:FS00:0xa3:Completed 240000 out of 500000 steps  (48%)
07:24:48:WU00:FS00:0xa3:Completed 245000 out of 500000 steps  (49%)
07:27:43:WU00:FS00:0xa3:Completed 250000 out of 500000 steps  (50%)
07:30:36:WU00:FS00:0xa3:Completed 255000 out of 500000 steps  (51%)
07:33:29:WU00:FS00:0xa3:Completed 260000 out of 500000 steps  (52%)
07:36:24:WU00:FS00:0xa3:Completed 265000 out of 500000 steps  (53%)
07:39:18:WU00:FS00:0xa3:Completed 270000 out of 500000 steps  (54%)
07:42:12:WU00:FS00:0xa3:Completed 275000 out of 500000 steps  (55%)
07:45:07:WU00:FS00:0xa3:Completed 280000 out of 500000 steps  (56%)
07:48:01:WU00:FS00:0xa3:Completed 285000 out of 500000 steps  (57%)
07:50:55:WU00:FS00:0xa3:Completed 290000 out of 500000 steps  (58%)
07:53:51:WU00:FS00:0xa3:Completed 295000 out of 500000 steps  (59%)
07:56:49:WU00:FS00:0xa3:Completed 300000 out of 500000 steps  (60%)
07:59:44:WU00:FS00:0xa3:Completed 305000 out of 500000 steps  (61%)
08:02:34:WU00:FS00:0xa3:Completed 310000 out of 500000 steps  (62%)
08:05:24:WU00:FS00:0xa3:Completed 315000 out of 500000 steps  (63%)
08:08:18:WU00:FS00:0xa3:Completed 320000 out of 500000 steps  (64%)
08:11:10:WU00:FS00:0xa3:Completed 325000 out of 500000 steps  (65%)
08:14:01:WU00:FS00:0xa3:Completed 330000 out of 500000 steps  (66%)
08:16:52:WU00:FS00:0xa3:Completed 335000 out of 500000 steps  (67%)
08:19:45:WU00:FS00:0xa3:Completed 340000 out of 500000 steps  (68%)
08:22:41:WU00:FS00:0xa3:Completed 345000 out of 500000 steps  (69%)
08:25:35:WU00:FS00:0xa3:Completed 350000 out of 500000 steps  (70%)
08:28:29:WU00:FS00:0xa3:Completed 355000 out of 500000 steps  (71%)
08:31:23:WU00:FS00:0xa3:Completed 360000 out of 500000 steps  (72%)
08:34:20:WU00:FS00:0xa3:Completed 365000 out of 500000 steps  (73%)
08:37:15:WU00:FS00:0xa3:Completed 370000 out of 500000 steps  (74%)
08:40:09:WU00:FS00:0xa3:Completed 375000 out of 500000 steps  (75%)
08:43:06:WU00:FS00:0xa3:Completed 380000 out of 500000 steps  (76%)
08:46:04:WU00:FS00:0xa3:Completed 385000 out of 500000 steps  (77%)
08:49:01:WU00:FS00:0xa3:Completed 390000 out of 500000 steps  (78%)
08:51:56:WU00:FS00:0xa3:Completed 395000 out of 500000 steps  (79%)
08:54:47:WU00:FS00:0xa3:Completed 400000 out of 500000 steps  (80%)
08:57:37:WU00:FS00:0xa3:Completed 405000 out of 500000 steps  (81%)
09:00:31:WU00:FS00:0xa3:Completed 410000 out of 500000 steps  (82%)
09:03:24:WU00:FS00:0xa3:Completed 415000 out of 500000 steps  (83%)
09:06:16:WU00:FS00:0xa3:Completed 420000 out of 500000 steps  (84%)
09:09:06:WU00:FS00:0xa3:Completed 425000 out of 500000 steps  (85%)
09:11:59:WU00:FS00:0xa3:Completed 430000 out of 500000 steps  (86%)
09:14:51:WU00:FS00:0xa3:Completed 435000 out of 500000 steps  (87%)
09:17:48:WU00:FS00:0xa3:Completed 440000 out of 500000 steps  (88%)
09:20:42:WU00:FS00:0xa3:Completed 445000 out of 500000 steps  (89%)
09:23:38:WU00:FS00:0xa3:Completed 450000 out of 500000 steps  (90%)
09:26:31:WU00:FS00:0xa3:Completed 455000 out of 500000 steps  (91%)
09:29:26:WU00:FS00:0xa3:Completed 460000 out of 500000 steps  (92%)
09:32:21:WU00:FS00:0xa3:Completed 465000 out of 500000 steps  (93%)
09:35:12:WU00:FS00:0xa3:Completed 470000 out of 500000 steps  (94%)
09:38:10:WU00:FS00:0xa3:Completed 475000 out of 500000 steps  (95%)
09:41:02:WU00:FS00:0xa3:Completed 480000 out of 500000 steps  (96%)
09:43:54:WU00:FS00:0xa3:Completed 485000 out of 500000 steps  (97%)
09:46:49:WU00:FS00:0xa3:Completed 490000 out of 500000 steps  (98%)
09:49:44:WU00:FS00:0xa3:Completed 495000 out of 500000 steps  (99%)
09:49:45:WU01:FS00:Connecting to 171.67.108.200:8080
09:49:46:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:49:46:WU01:FS00:Connecting to 171.67.108.204:80
09:49:47:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:49:47:ERROR:WU01:FS00:Exception: Could not get an assignment
09:49:47:WU01:FS00:Connecting to 171.67.108.200:8080
09:49:48:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:49:48:WU01:FS00:Connecting to 171.67.108.204:80
09:49:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:49:49:ERROR:WU01:FS00:Exception: Could not get an assignment
09:50:47:WU01:FS00:Connecting to 171.67.108.200:8080
09:50:48:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:50:48:WU01:FS00:Connecting to 171.67.108.204:80
09:50:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:50:49:ERROR:WU01:FS00:Exception: Could not get an assignment
09:52:25:WU01:FS00:Connecting to 171.67.108.200:8080
09:52:25:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:52:25:WU01:FS00:Connecting to 171.67.108.204:80
09:52:26:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:52:26:ERROR:WU01:FS00:Exception: Could not get an assignment
09:52:38:WU00:FS00:0xa3:Completed 500000 out of 500000 steps  (100%)
09:52:39:WU00:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
09:52:49:WU00:FS00:0xa3:
09:52:49:WU00:FS00:0xa3:Finished Work Unit:
09:52:49:WU00:FS00:0xa3:- Reading up to 8031744 from "00/wudata_01.trr": Read 8031744
09:52:49:WU00:FS00:0xa3:trr file hash check passed.
09:52:49:WU00:FS00:0xa3:edr file hash check passed.
09:52:49:WU00:FS00:0xa3:logfile size: 56608
09:52:49:WU00:FS00:0xa3:Leaving Run
09:52:51:WU00:FS00:0xa3:- Writing 8125184 bytes of core data to disk...
09:52:52:WU00:FS00:0xa3:Done: 8124672 -> 7502956 (compressed to 92.3 percent)
09:52:52:WU00:FS00:0xa3:  ... Done.
09:55:02:WU01:FS00:Connecting to 171.67.108.200:8080
09:55:03:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:55:03:WU01:FS00:Connecting to 171.67.108.204:80
09:55:03:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:55:03:ERROR:WU01:FS00:Exception: Could not get an assignment
09:57:31:WU00:FS00:0xa3:- Shutting down core
09:57:31:WU00:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
09:58:10:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:58:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8801 run:0 clone:2 gen:436 core:0xa3 unit:0x000002a1fbcb017c5193957ceeb341b4
09:58:10:WU00:FS00:Uploading 7.16MiB to 128.143.199.96
09:58:10:WU00:FS00:Connecting to 128.143.199.96:8080
09:58:16:WU00:FS00:Upload complete
09:58:16:WU00:FS00:Server responded WORK_ACK (400)
09:58:16:WU00:FS00:Final credit estimate, 22582.00 points
09:58:16:WU00:FS00:Cleaning up
09:59:16:WU01:FS00:Connecting to 171.67.108.200:8080
09:59:17:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:59:17:WU01:FS00:Connecting to 171.67.108.204:80
09:59:17:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:59:17:ERROR:WU01:FS00:Exception: Could not get an assignment
10:06:08:WU01:FS00:Connecting to 171.67.108.200:8080
10:06:08:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
10:06:08:WU01:FS00:Connecting to 171.67.108.204:80
10:06:09:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
10:06:09:ERROR:WU01:FS00:Exception: Could not get an assignment
10:17:13:WU01:FS00:Connecting to 171.67.108.200:8080
10:17:14:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
10:17:14:WU01:FS00:Connecting to 171.67.108.204:80
10:17:14:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
10:17:14:ERROR:WU01:FS00:Exception: Could not get an assignment
10:35:10:WU01:FS00:Connecting to 171.67.108.200:8080
10:35:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
10:35:12:WU01:FS00:Connecting to 171.67.108.204:80
10:35:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
10:35:12:ERROR:WU01:FS00:Exception: Could not get an assignment
11:04:13:WU01:FS00:Connecting to 171.67.108.200:8080
11:04:13:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
11:04:13:WU01:FS00:Connecting to 171.67.108.204:80
11:04:14:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:04:14:ERROR:WU01:FS00:Exception: Could not get an assignment
11:51:12:WU01:FS00:Connecting to 171.67.108.200:8080
11:51:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
11:51:12:WU01:FS00:Connecting to 171.67.108.204:80
11:51:13:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:51:13:ERROR:WU01:FS00:Exception: Could not get an assignment
13:07:12:WU01:FS00:Connecting to 171.67.108.200:8080
13:07:13:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
13:07:13:WU01:FS00:Connecting to 171.67.108.204:80
13:07:14:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
13:07:14:ERROR:WU01:FS00:Exception: Could not get an assignment
15:10:12:WU01:FS00:Connecting to 171.67.108.200:8080
15:10:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:10:12:WU01:FS00:Connecting to 171.67.108.204:80
15:10:14:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:10:14:ERROR:WU01:FS00:Exception: Could not get an assignment
16:16:34:FS00:Paused
16:16:36:FS00:Unpaused
16:16:36:WU01:FS00:Connecting to 171.67.108.200:8080
16:16:37:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
16:16:37:WU01:FS00:Connecting to 171.67.108.204:80
16:16:38:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
16:16:38:ERROR:WU01:FS00:Exception: Could not get an assignment
Yes, 128.143.199.96 is running low on available WU's for large systems. PG has been contacted. However you do have an option to run the very large WU's from another server as you are running Linux and have more than 24 cores available. Add the options "client-type=bigadv" and "max-packet-size=big" to your CPU slot and that will attempt to get the large WU's using Core_A5 that were released after the older Bigadv projects ended in January.
DocJonz
Post by DocJonz »
Thanks for the information.
(I should have added those flags after the re-install).
Re: Failed to get assignment: 171.67.108.200/204 (Linux)
While Windows and Linux are quite different for high-CPU-count machines, it's interesting to note that they share the same problem right now:
Windows CPU30 failed to get assignment
