anyway, i have a couple machines that have 2 threads, and are unable to get wus when set to smp:2. i could use nacl but i'd like to save that for last resort since it requires more tending than using v7 (which is more or less set-and-forget).
system: (yes, i know it's not the fastest thing in the world, but it's better than nothing
21:29:17:************************* Folding@home Client *************************
21:29:17: Website: http://folding.stanford.edu/
21:29:17: Copyright: (c) 2009-2014 Stanford University
21:29:17: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:29:17: Args:
21:29:17: Config: C:/Users/Demonfang Arun/AppData/Roaming/FAHClient/config.xml
21:29:17:******************************** Build ********************************
21:29:17: Version: 7.4.4
21:29:17: Date: Mar 4 2014
21:29:17: Time: 20:26:54
21:29:17: SVN Rev: 4130
21:29:17: Branch: fah/trunk/client
21:29:17: Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:29:17: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:29:17: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
21:29:17: Platform: win32 XP
21:29:17: Bits: 32
21:29:17: Mode: Release
21:29:17:******************************* System ********************************
21:29:17: CPU: Intel(R) Pentium(R) CPU 2127U @ 1.90GHz
21:29:17: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:29:17: CPUs: 2
21:29:17: Memory: 3.88GiB
21:29:17: Free Memory: 2.54GiB
21:29:17: Threads: WINDOWS_THREADS
21:29:17: OS Version: 6.1
21:29:17: Has Battery: true
21:29:17: On Battery: true
21:29:17: UTC Offset: -4
21:29:17: PID: 1924
21:29:17: CWD: C:/Windows/system32
21:29:17: OS: Windows 7 Professional
21:29:17: OS Arch: AMD64
21:29:17: GPUs: 0
21:29:17: CUDA: Not detected
21:29:17:Win32 Service: true
21:29:17:***********************************************************************
00:52:35:Saving configuration to config.xml
00:52:35:<config>
00:52:35: <!-- HTTP Server -->
00:52:35: <allow v='10.0.0.10'/>
00:52:35:
00:52:35: <!-- Network -->
00:52:35: <proxy v=':8080'/>
00:52:35:
00:52:35: <!-- Remote Command Server -->
00:52:35: <password v='********'/>
00:52:35:
00:52:35: <!-- Slot Control -->
00:52:35: <power v='full'/>
00:52:35:
00:52:35: <!-- User Information -->
00:52:35: <passkey v='********************************'/>
00:52:35: <team v='194826'/>
00:52:35: <user v='Kinata'/>
00:52:35:
00:52:35: <!-- Folding Slots -->
00:52:35: <slot id='0' type='CPU'>
00:52:35: <cpus v='2'/>
00:52:35: </slot>
00:52:35:</config>
00:52:37:Removing old file 'configs/config-20150408-214432.xml'
00:52:37:Saving configuration to config.xml
00:52:37:<config>
00:52:37: <!-- HTTP Server -->
00:52:37: <allow v='10.0.0.10'/>
00:52:37:
00:52:37: <!-- Network -->
00:52:37: <proxy v=':8080'/>
00:52:37:
00:52:37: <!-- Remote Command Server -->
00:52:37: <password v='********'/>
00:52:37:
00:52:37: <!-- Slot Control -->
00:52:37: <power v='full'/>
00:52:37:
00:52:37: <!-- User Information -->
00:52:37: <passkey v='********************************'/>
00:52:37: <team v='194826'/>
00:52:37: <user v='Kinata'/>
00:52:37:
00:52:37: <!-- Folding Slots -->
00:52:37: <slot id='0' type='CPU'>
00:52:37: <cpus v='2'/>
00:52:37: </slot>
00:52:37:</config>
00:53:08:WU00:FS00:Connecting to 171.67.108.200:8080
00:53:29:WARNING:WU00:FS00:Failed to get ID from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:53:29:WU00:FS00:Connecting to 171.67.108.204:80
00:53:50:WARNING:WU00:FS00:Failed to get ID from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:53:50:ERROR:WU00:FS00:Exception: Could not get an assignment ID
00:59:59:WU00:FS00:Connecting to 171.67.108.200:8080
01:00:20:WARNING:WU00:FS00:Failed to get ID from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:00:20:WU00:FS00:Connecting to 171.67.108.204:80
01:00:41:WARNING:WU00:FS00:Failed to get ID from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:00:41:ERROR:WU00:FS00:Exception: Could not get an assignment ID
iirc, 171.67.108.200 assigns classic wu's (uni/non-smp) and 171.67.108.204 is a ws that is set to accept only (and has no units either).
this said, why am i not getting redirected to an appropriate AS for smp units and then getting forwarded to a WS with wu's for my config? i see at least several WS that have compatible units and ample supply. hopefully someone can point me in the right direction with this, and thanks in advance
