404 Error with 155.247.166.219
ashleylist
Post by ashleylist »
hi there,
Just fired up folding after the summer. I've updated the client to the most recent one today.
Both GPU are receiving data and are working hard.
My CPU cannot access the server. clicking on the link i get a 404 Not found error.
The requested URL /logs/155.247.166.219.log.html was not found on this server.
Apache/2.0.52 (CentOS) Server at fah-web.stanford.edu Port 80
for the CPU i get
*********************** Log Started 2015-04-08T10:50:51Z ***********************
10:50:51:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
10:50:51:WU02:FS02:Connecting to web.stanford.edu:80
10:50:53:ERROR:WU02:FS02:Exception: Failed to access core package.
10:51:51:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
10:51:51:WU02:FS02:Connecting to web.stanford.edu:80
10:51:52:ERROR:WU02:FS02:Exception: Failed to access core package.
10:52:33:FS02:Finishing
10:53:28:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
10:53:28:WU02:FS02:Connecting to web.stanford.edu:80
10:53:29:ERROR:WU02:FS02:Exception: Failed to access core package.
10:56:05:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
10:56:05:WU02:FS02:Connecting to web.stanford.edu:80
10:56:06:ERROR:WU02:FS02:Exception: Failed to access core package.
11:00:20:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
11:00:20:WU02:FS02:Connecting to web.stanford.edu:80
11:00:20:ERROR:WU02:FS02:Exception: Failed to access core package.
11:07:11:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
11:07:11:WU02:FS02:Connecting to web.stanford.edu:80
11:07:12:ERROR:WU02:FS02:Exception: Failed to access core package.
11:18:17:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
11:18:17:WU02:FS02:Connecting to web.stanford.edu:80
11:18:17:ERROR:WU02:FS02:Exception: Failed to access core package.
11:36:13:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
11:36:13:WU02:FS02:Connecting to web.stanford.edu:80
11:36:14:ERROR:WU02:FS02:Exception: Failed to access core package.
12:05:16:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_18.fah
12:05:16:WU02:FS02:Connecting to web.stanford.edu:80
12:05:16:ERROR:WU02:FS02:Exception: Failed to access core package.
Is the error at my end your yours?
Ash
Mod edit: Added Code tags to log file
Re: 404 Error with 155.247.166.219
Please also post the first 100 or so lines of your log file as that shows your folding setup.
Are you sure folding slot 2 is a CPU slot? The core being requested is one for a GPU, and should not be requested for a CPU folding slot. If that is the case, it appears your configuration has been corrupted. The simplest fix may be to reinstall the folding client after finishing the current GPU WU's you have processing.
Finish the two GPU work units. Then uninstall the client, and reinstall the client. Updating over the top won't work.
Earlier this year, an assignment server issue corrupted the cpu slot on many systems. The only way to recover that error was to delete the CPU Slot folder (manually or via uninstall).
ashleylist wrote:The requested URL /logs/155.247.166.219.log.html was not found on this server.
logs/155.247.166.219.log.html works for me and the server does look like it's sending and receiving WUs.
