Tullball
Posts: 2 Joined: Mon Mar 30, 2015 2:49 pm
Post
by Tullball » Mon Mar 30, 2015 2:56 pm
I installed a Nvidia GTX 970 on my Arch Linux computer, but all the work units are "bad". Sample output:
14:45:40:WU02:FS00:Assigned to work server 171.67.108.52
14:45:40:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
14:45:40:WU02:FS00:Connecting to 171.67.108.52:8080
14:45:41:WU02:FS00:Downloading 1.52MiB
14:45:45:WU02:FS00:Download complete
14:45:45:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:81 clone:1 gen:449 core:0x17 unit:0x000002816652edc45399d9359ca761c6
14:45:45:WU02:FS00:Starting
14:45:45:WU02:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 1799 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
14:45:45:WU02:FS00:Started FahCore on PID 3997
14:45:45:WU02:FS00:Core PID:4001
14:45:45:WU02:FS00:FahCore 0x17 started
14:45:46:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:45:46:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:81 clone:1 gen:449 core:0x17 unit:0x000002816652edc45399d9359ca761c6
14:45:46:WU02:FS00:Uploading 1.81KiB to 171.67.108.52
14:45:46:WU02:FS00:Connecting to 171.67.108.52:8080
14:45:46:WU02:FS00:Upload complete
14:45:46:WU02:FS00:Server responded WORK_ACK (400)
14:45:46:WU02:FS00:Cleaning up
This happens with all the work im getting. Now the status are "failed" in fah control...
So I wondered if someone knew what to do...
Posts: 10179 Joined: Thu Nov 29, 2007 4:30 pm
Post
by 7im » Mon Mar 30, 2015 3:11 pm
V346.xx or newer drivers from NV, not from the oem?
Posts: 20824 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Mon Mar 30, 2015 4:38 pm
7im wrote: V346.xx or newer drivers from NV, not from the oem?
Exactly. Unless you install the latest NV Proprietary drivers (346 or greater) your GPU does not support folding.
Warning: if your distro is a server version, the NV drivers will probably install without difficulty. If your distro run a GUI window manager, the installation will fail without special procedures which shut down that screen manager during the installation. Two such installation guides are
Everyman's Guide to Nvidia GPU Folding on Ubuntu Server and
Tips for installing Nvidia .run files in Linux
ChristianVirtual
Posts: 1576 Joined: Tue May 28, 2013 12:14 pm
Post
by ChristianVirtual » Tue Mar 31, 2015 1:21 am
346.35 works well on CentOS 7; I remember one version newer caused also some trouble for a different fellow folder. I suggest download that version .35 direct from nV and follow the guide as mentioed above.
It fold everything the AS throws at you ...
Tullball
Post
by Tullball » Wed Apr 01, 2015 2:17 pm
I used drivers from "AUR"... but I have solved the problem by switching OS. Thanks.
