the system lacked sufficient buffer space ... error Help
Nert
Post by Nert »
I've been folding for quite a while on my Windows Vista System using a GTX 750 Ti. I have started having problems whereby I get the following error messages in the FAH log:
08:22:47:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
When this error happens, I also seem to lose some network connectivity. I can ping out to web sites, but cannot connect to them. This system also runs Go To MY PC. I use this to access the Vista machine remotely when I'm away. When this error occurs, I am unable to connect to Go to MY PC on the Vista machine. When folding runs, Go To MY PC works fine. (Don't know if that's significant, but thought I'd throw it in).
This has happened three times over the past two months. Since I'm gone from home a lot, I don't get any folding done until I can have someone reboot the system for me. I'd like to get this fixed, but don't really know where to start. I'll leave the system running in it's error state in case someone thinks of additional diagnostics that I might run to gather additional info.
Any help is appreciate. Thanks.
Here's the log from one of the past failures:
*********************** Log Started 2015-01-14T16:58:57Z ***********************
16:58:57:************************* Folding@home Client *************************
16:58:57:      Website: http://folding.stanford.edu/
16:58:57:    Copyright: (c) 2009-2013 Stanford University
16:58:57:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:58:57:         Args:
16:58:57:       Config: C:/ProgramData/FAHClient/config.xml
16:58:57:******************************** Build ********************************
16:58:57:      Version: 7.3.6
16:58:57:         Date: Feb 18 2013
16:58:57:         Time: 15:25:17
16:58:57:      SVN Rev: 3923
16:58:57:       Branch: fah/trunk/client
16:58:57:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:58:57:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:58:57:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:58:57:     Platform: win32 XP
16:58:57:         Bits: 32
16:58:57:         Mode: Release
16:58:57:******************************* System ********************************
16:58:57:          CPU: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
16:58:57:       CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
16:58:57:         CPUs: 2
16:58:57:       Memory: 2.87GiB
16:58:57:  Free Memory: 1.50GiB
16:58:57:      Threads: WINDOWS_THREADS
16:58:57:  Has Battery: false
16:58:57:   On Battery: false
16:58:57:   UTC offset: -6
16:58:57:          PID: 4944
16:58:57:          CWD: C:/ProgramData/FAHClient
16:58:57:           OS: Windows Vista (TM) Home Premium Service Pack 2
16:58:57:      OS Arch: X86
16:58:57:         GPUs: 1
16:58:57:        GPU 0: NVIDIA:4 GM107 [GeForce GTX 750 Ti]
16:58:57:         CUDA: 5.0
16:58:57:  CUDA Driver: 6050
16:58:57:Win32 Service: false
16:58:57:***********************************************************************
16:58:57:<config>
16:58:57:  <!-- Folding Core -->
16:58:57:  <checkpoint v='30'/>
16:58:57:
16:58:57:  <!-- Folding Slot Configuration -->
16:58:57:  <client-type v='advanced'/>
16:58:57:  <power v='FULL'/>
16:58:57:
16:58:57:  <!-- Network -->
16:58:57:  <proxy v=':8080'/>
16:58:57:
16:58:57:  <!-- User Information -->
16:58:57:  <passkey v='********************************'/>
16:58:57:  <team v='165780'/>
16:58:57:  <user v='nert'/>
16:58:57:
16:58:57:  <!-- Folding Slots -->
16:58:57:  <slot id='0' type='GPU'/>
16:58:57:</config>
16:58:57:Trying to access database...
16:59:03:Successfully acquired database lock
16:59:03:Enabled folding slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti]
16:59:04:WU00:FS00:Starting
16:59:04:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 4944 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
16:59:05:WU00:FS00:Started FahCore on PID 4144
16:59:15:WU00:FS00:Core PID:5352
16:59:15:WU00:FS00:FahCore 0x17 started
16:59:28:WU00:FS00:0x17:*********************** Log Started 2015-01-14T16:59:28Z ***********************16:59:28:WU00:FS00:0x17:Project: 9201 (Run 988, Clone 4, Gen 123)
16:59:28:WU00:FS00:0x17:Unit: 0x000000b16652edc45399fce8ea2fbd6d
16:59:28:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
16:59:28:WU00:FS00:0x17:Machine: 0
16:59:28:WU00:FS00:0x17:Digital signatures verified
16:59:28:WU00:FS00:0x17:Folding@home GPU core17
16:59:28:WU00:FS00:0x17:Version 0.0.52
16:59:28:WU00:FS00:0x17:  Found a checkpoint file
17:00:25:WU00:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
17:00:25:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
<ENTRIES DELETE TO SHORTEN LOG TO ACCEPTABLE MAXIMUM >
08:22:45:WU00:FS00:0x18:Completed 2500000 out of 2500000 steps (100%)
08:22:46:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:22:47:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:22:47:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:22:47:ERROR:WU01:FS00:Exception: Could not get an assignment
08:22:48:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:22:48:ERROR:WU01:FS00:Exception: Could not get an assignment
08:23:14:WU00:FS00:0x18:Saving result file logfile_01.txt
08:23:14:WU00:FS00:0x18:Saving result file checkpointState.xml
08:23:16:WU00:FS00:0x18:Saving result file checkpt.crc
08:23:16:WU00:FS00:0x18:Saving result file log.txt
08:23:16:WU00:FS00:0x18:Saving result file positions.xtc
08:23:17:WU00:FS00:0x18:Folding@home Core Shutdown: FINISHED_UNIT
08:23:18:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:23:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9113 run:36 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e815473874a2a0be831
08:23:18:WU00:FS00:Uploading 6.93MiB to 171.64.65.93
08:23:18:WU00:FS00:Connecting to 171.64.65.93:8080
08:23:18:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:23:18:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:23:18:WU00:FS00:Trying to send results to collection server
08:23:18:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:23:18:WU00:FS00:Connecting to 171.65.103.160:8080
08:23:18:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:23:19:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:23:19:WU00:FS00:Trying to send results to collection server
08:23:19:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:23:19:WU00:FS00:Connecting to 171.65.103.160:8080
08:23:19:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:23:19:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:23:47:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:23:47:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:23:47:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:23:47:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:23:47:ERROR:WU01:FS00:Exception: Could not get an assignment
08:24:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9113 run:36 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e815473874a2a0be831
08:24:18:WU00:FS00:Uploading 6.93MiB to 171.64.65.93
08:24:18:WU00:FS00:Connecting to 171.64.65.93:8080
08:24:18:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:24:18:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:24:18:WU00:FS00:Trying to send results to collection server
08:24:19:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:24:19:WU00:FS00:Connecting to 171.65.103.160:8080
08:24:19:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:24:19:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:25:24:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:25:24:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:25:24:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:25:24:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:25:24:ERROR:WU01:FS00:Exception: Could not get an assignment
08:25:55:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9113 run:36 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e815473874a2a0be831
08:25:56:WU00:FS00:Uploading 6.93MiB to 171.64.65.93
08:25:56:WU00:FS00:Connecting to 171.64.65.93:8080
08:25:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:25:56:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:25:56:WU00:FS00:Trying to send results to collection server
08:25:56:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:25:56:WU00:FS00:Connecting to 171.65.103.160:8080
08:25:56:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:28:02:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:28:02:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:28:02:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:28:02:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:28:02:ERROR:WU01:FS00:Exception: Could not get an assignment
08:28:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9113 run:36 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e815473874a2a0be831
08:28:33:WU00:FS00:Uploading 6.93MiB to 171.64.65.93
08:28:33:WU00:FS00:Connecting to 171.64.65.93:8080
08:28:33:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:28:33:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:28:33:WU00:FS00:Trying to send results to collection server
08:28:33:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:28:33:WU00:FS00:Connecting to 171.65.103.160:8080
08:28:33:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:32:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:32:16:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:32:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:32:16:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:32:16:ERROR:WU01:FS00:Exception: Could not get an assignment
08:32:47:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9113 run:36 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e815473874a2a0be831
08:32:47:WU00:FS00:Uploading 6.93MiB to 171.64.65.93
08:32:47:WU00:FS00:Connecting to 171.64.65.93:8080
08:32:47:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:32:47:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:32:47:WU00:FS00:Trying to send results to collection server
08:32:47:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:32:47:WU00:FS00:Connecting to 171.65.103.160:8080
08:32:47:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:39:07:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:39:07:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:39:07:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:39:07:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:39:07:ERROR:WU01:FS00:Exception: Could not get an assignment
08:39:38:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9113 run:36 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e815473874a2a0be831
08:39:38:WU00:FS00:Uploading 6.93MiB to 171.64.65.93
08:39:38:WU00:FS00:Connecting to 171.64.65.93:8080
08:39:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:39:38:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.93:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
08:39:38:WU00:FS00:Trying to send results to collection server
08:39:38:WU00:FS00:Uploading 6.93MiB to 171.65.103.160
08:39:38:WU00:FS00:Connecting to 171.65.103.160:8080
<MANY REPEATS OF THIS SEQUENCE DELETED TO MEET FORUM'S LENGTH REQUIREMENTS>
10:24:44:WU00:FS00:Connecting to 171.65.103.160:80
10:24:44:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full.
16:20:46:WARNING:Console control signal 6 on PID 4944
16:20:46:Exiting, please wait. . .
Re: the system lacked sufficient buffer space ... error Help
This is looking like an issue within the networking stack of the Vista OS, not the folding client. Have you rebooted the PC?
Nert
Post by Nert »
I did reboot the system when the problem popped up before and everything resumed normally following the reboot. Then after 4-8 days the problem re-occurs. I also thought that the problem sounded like something wrong with the networking stack. But I'm at a loss as to what might be the root cause of the problem. I haven't rebooted following this most recent failure in case there are additional diagnostics that might provide more info. I'm also doing some google research but haven't found anything yet.
uncle_fungus
Post by uncle_fungus »
This looks like it might be of some help: http://blogs.msdn.com/b/sql_protocols/a ... -full.aspx
They should be easy fixes to apply if that really is the problem (it's difficult to tell, but judging by your system information from the top of the log you DO have 3GB RAM).
Nert
Post by Nert »
Thanks uncle_fungus. I'm looking at the article now. There are some wrinkles for Vista. It uses bcdedit to modify the parameters instead of storing values in boot.ini. I displayed the current values and it doesn't look like the /3gb switch is set. So my problem is probably related to running out of ports. I'll look at that part next.
