Team numbers [solved]
Hey guys i put a second machine running this and entered in my team number,it put me on a team of my own....Is there anyway to get my machine back onto my team?If the points cant be put back i understand,but given the fact that i am the only member of the team that the second machine is on it would be cool if i could.Any help would be appreciated.
Re: Team numbers
Welcome to the FoldingForum, [OBC]TECH_
You're right: The points will not be adjusted.
As long as you use the same team number in both clients, they'll both contribute to the same team.
If you also spell you name exactly the same in both clients, the points will be indistinguishable from those coming from the other machine.
Re: Team numbers
Both the team numbers on both machines are identical,however when i look at the stats the number of the second machine has command in front of the number...I didnt put that there.If this cant be transferred how does one go about changing the machine to the team that i want it on?
Re: Team numbers
Post the first 30 or so lines of FAHlog.txt and a copy of client.cfg from each machine.
Which clients are you running?
Re: Team numbers
[14:00:36] - Ask before connecting: No
[14:00:36] - User name: [OBC]TECH_ (Team 126458)
[14:00:36] - User ID not found locally
[14:00:36] + Requesting User ID from server
[14:00:37] - Machine ID: 1
[14:00:37]
[14:00:37] Work directory not found. Creating...
[14:00:37] Could not open work queue, generating new queue...
[14:00:37] Initialization complete
[14:00:37] + Benchmarking ...
[14:00:39] - Preparing to get new work unit...
[14:00:39] + Attempting to get work packet
[14:00:39] - Connecting to assignment server
[14:00:39] - Successful: assigned to (171.64.122.78).
[14:00:39] + News From Folding@Home: Welcome to Folding@Home
[14:00:39] Loaded queue successfully.
[14:00:39] - Couldn't send HTTP request to server
[14:00:39] (Got status 503)
[14:00:39] + Could not connect to Work Server
[14:00:39] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[14:00:58] + Attempting to get work packet
[14:00:58] - Connecting to assignment server
[14:00:59] - Successful: assigned to (171.64.122.78).
[14:00:59] + News From Folding@Home: Welcome to Folding@Home
[14:00:59] Loaded queue successfully.
Re: Team numbers
# Windows Graphical Edition ###################################################
Folding@Home Client Version 5.03
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[23:03:56] - Ask before connecting: No
[23:03:56] - Use IE connection settings: Yes
[23:03:56] - User name: [OBC]TECH_ (Team 126485)
[23:03:56] - User ID: 404FC3A442930652
[23:03:56] - Machine ID: 1
[23:03:56]
[23:03:56] Loaded queue successfully.
[23:03:56] Initialization complete
[23:03:56] + Benchmarking ...
[23:04:00]
[23:04:00] + Processing work unit
[23:04:00] Core required: FahCore_82.exe
[23:04:00] Core found.
[23:04:00] Working on Unit 08 [May 21 23:04:00]
[23:04:00] + Working ...
[23:04:01] + Working...
[23:04:01]
[23:04:01] *------------------------------*
[23:04:01] Folding@Home PMD Core
[23:04:01] Version 1.03 (September 7, 2005)
[23:04:01]
[23:04:01] Preparing to commence simulation
[23:04:01] - Looking at optimizations...
[23:04:01] - Files status OK
[23:04:01] - Expanded 10693 -> 73764 (decompressed 689.8 percent)
[23:04:01]
[23:04:01] Project: 4544 (Run 92, Clone 21, Gen 0)
[23:04:01]
[23:04:01] Assembly optimizations on if available.
[23:04:01] Entering M.D.
[23:05:23] Protein: p4544_T0396_2-8_minout
[23:05:23]
[23:05:23] Completed 650000 out of 2500000 steps (26)
[23:09:43] Writing local files
[23:09:43] Completed 675000 out of 2500000 steps (27)
[23:13:55] Writing local files
[23:13:55] Completed 700000 out of 2500000 steps (28)
[23:13:55] Writing checkpoint files
[23:17:58] Writing local files
[23:17:58] Completed 725000 out of 2500000 steps (29)
[23:21:59] Writing local files
[23:21:59] Completed 750000 out of 2500000 steps (30)
[23:21:59] Writing checkpoint files
[23:25:59] Writing local files
[23:25:59] Completed 775000 out of 2500000 steps (31)
[23:03:56]
[23:04:00]
[23:04:01]
[23:04:01]
[23:04:01]
[23:04:01]
[23:05:23]
Re: Team numbers
ok i see what i did.Sorry to waste your time!
Re: Team numbers
Do you want to be on team 126458 or team 126485?
Re: Team numbers
No problem. We're here to help, and sometimes it's something trivial like that.[OBC]TECH_ wrote:ok i see what i did.Sorry to waste your time!
I don't see the "command" that you mentioned, but as long as you fixed your problem, I consider the issue closed.
