GTX 750 Ti has stopped folding....
ETA: 2/27 11AM Folding! Uninstall FAH, clean install of 347.52. I'll let it run, see what happens.
It has been working fine up until today. Came home to see a failure message, and I managed to delete the log file. Sigh. I deleted the GPU slot, added, started. The control panel (and web) is currently showing the slot is running, but there has been no change in the progress percentage, and OpenHardware monitor shows zero activity on the GPU.
Running Wndows 7 Ultimate, 340.52 Nvidia driver.
What have I broken?
Thanks!
What have I broken?
Thanks!
ChristianVirtual
Re: GTX 750 Ti has stopped folding....
Can you share the current log ?
Update driver to 347.xx version.
Will do. How much do you need?ChristianVirtual wrote:Can you share the current log ?
ETA: How do I post it? Just paste into a message, or is there an option for the scrolling window I can't find?
ETA: Found, thanks!
ETA: Downloading, going to install in a bit after CPU slot finishes current work.7im wrote:Update driver to 347.xx version.
I'll do that as well. I had been using the latest driver installed by the CUDA package, but went back because that was rock-solid for me.
Thanks!
Content of current log. I removed the some of the end, the CPU client happily chugging along.
*********************** Log Started 2015-02-27T10:35:06Z ***********************
10:35:06:************************* Folding@home Client *************************
10:35:06: Website: http://folding.stanford.edu/
10:35:06: Copyright: (c) 2009-2014 Stanford University
10:35:06: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:35:06: Args: --open-web-control
10:35:06: Config: C:/ProgramData/FAHClient/config.xml
10:35:06:******************************** Build ********************************
10:35:06: Version: 7.4.4
10:35:06: Date: Mar 4 2014
10:35:06: Time: 20:26:54
10:35:06: SVN Rev: 4130
10:35:06: Branch: fah/trunk/client
10:35:06: Compiler: Intel(R) C++ MSVC 1500 mode 1200
10:35:06: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
10:35:06: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
10:35:06: Platform: win32 XP
10:35:06: Bits: 32
10:35:06: Mode: Release
10:35:06:******************************* System ********************************
10:35:06: CPU: AMD A10-5800K APU with Radeon(tm) HD Graphics
10:35:06: CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
10:35:06: CPUs: 4
10:35:06: Memory: 15.95GiB
10:35:06: Free Memory: 14.64GiB
10:35:06: Threads: WINDOWS_THREADS
10:35:06: OS Version: 6.1
10:35:06: Has Battery: false
10:35:06: On Battery: false
10:35:06: UTC Offset: -8
10:35:06: PID: 4016
10:35:06: CWD: C:/ProgramData/FAHClient
10:35:06: OS: Windows 7 Ultimate
10:35:06: OS Arch: AMD64
10:35:06: GPUs: 1
10:35:06: GPU 0: NVIDIA:4 GM107 [GeForce GTX 750 Ti]
10:35:06: CUDA: 5.0
10:35:06: CUDA Driver: 6050
10:35:06:Win32 Service: false
10:35:06:***********************************************************************
10:35:06:<config>
10:35:06: <!-- Folding Core -->
10:35:06: <checkpoint v='30'/>
10:35:06:
10:35:06: <!-- Network -->
10:35:06: <proxy v=':8080'/>
10:35:06:
10:35:06: <!-- Slot Control -->
10:35:06: <power v='FULL'/>
10:35:06:
10:35:06: <!-- User Information -->
10:35:06: <passkey v='********************************'/>
10:35:06: <user v='******************************'/>
10:35:06:
10:35:06: <!-- Folding Slots -->
10:35:06: <slot id='0' type='CPU'/>
10:35:06: <slot id='1' type='GPU'/>
10:35:06:</config>
10:35:06:Trying to access database...
10:35:06:Successfully acquired database lock
10:35:06:Enabled folding slot 00: READY cpu:3
10:35:06:Enabled folding slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti]
10:35:06:WU00:FS00:Starting
10:35:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -np 3
10:35:06:WU00:FS00:Started FahCore on PID 4088
10:35:06:WU00:FS00:Core PID:1912
10:35:06:WU00:FS00:FahCore 0xa4 started
10:35:06:WU02:FS01:Starting
10:35:06:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
10:35:06:WU02:FS01:Started FahCore on PID 720
10:35:06:WU02:FS01:Core PID:3156
10:35:06:WU02:FS01:FahCore 0x17 started
10:35:07:WU00:FS00:0xa4:
10:35:07:WU00:FS00:0xa4:*------------------------------*
10:35:07:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
10:35:07:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:35:07:WU00:FS00:0xa4:Preparing to commence simulation
10:35:07:WU00:FS00:0xa4:- Looking at optimizations...
10:35:07:WU00:FS00:0xa4:- Files status OK
10:35:07:WU00:FS00:0xa4:- Expanded 881116 -> 1463992 (decompressed 166.1 percent)
10:35:07:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=881116 data_size=1463992, decompressed_data_size=1463992 diff=0
10:35:07:WU00:FS00:0xa4:- Digital signature verified
10:35:07:WU00:FS00:0xa4:Project: 9008 (Run 690, Clone 2, Gen 234)
10:35:07:WU00:FS00:0xa4:Assembly optimizations on if available.
10:35:07:WU00:FS00:0xa4:Entering M.D.
10:35:07:WU02:FS01:0x17:*********************** Log Started 2015-02-27T10:35:07Z ***********************
10:35:07:WU02:FS01:0x17:Project: 13000 (Run 33, Clone 6, Gen 46)
10:35:07:WU02:FS01:0x17:Unit: 0x00000065538b3db7530fa5932f0d3fa6
10:35:07:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:35:07:WU02:FS01:0x17:Machine: 1
10:35:07:WU02:FS01:0x17:Reading tar file state.xml
10:35:08:WU02:FS01:0x17:Reading tar file system.xml
10:35:08:WU02:FS01:0x17:Reading tar file integrator.xml
10:35:08:WU02:FS01:0x17:Reading tar file core.xml
10:35:08:WU02:FS01:0x17:Digital signatures verified
10:35:08:WU02:FS01:0x17:Folding@home GPU core17
10:35:08:WU02:FS01:0x17:Version 0.0.52
10:35:13:WU00:FS00:0xa4:Using Gromacs checkpoints
10:35:13:WU00:FS00:0xa4:Mapping NT from 3 to 3
10:35:13:WU00:FS00:0xa4:Resuming from checkpoint
10:35:13:WU00:FS00:0xa4:Verified 00/wudata_01.log
10:35:13:WU00:FS00:0xa4:Verified 00/wudata_01.trr
10:35:13:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
10:35:13:WU00:FS00:0xa4:Verified 00/wudata_01.edr
10:35:14:WU00:FS00:0xa4:Completed 7375 out of 250000 steps (2%)
10:35:33:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
10:39:40:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 455.199 with threshold of 5
10:39:40:WU02:FS01:0x17:Saving result file logfile_01.txt
10:39:40:WU02:FS01:0x17:Saving result file log.txt
10:39:40:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
10:39:41:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:39:41:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:33 clone:6 gen:46 core:0x17 unit:0x00000065538b3db7530fa5932f0d3fa6
10:39:41:WU02:FS01:Uploading 2.24KiB to 140.163.4.231
10:39:41:WU02:FS01:Connecting to 140.163.4.231:8080
10:39:41:WU02:FS01:Upload complete
10:39:41:WU02:FS01:Server responded WORK_ACK (400)
10:39:41:WU02:FS01:Cleaning up
10:39:41:WU01:FS01:Connecting to 171.67.108.200:80
10:39:44:WU01:FS01:Assigned to work server 140.163.4.231
10:39:44:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
10:39:44:WU01:FS01:Connecting to 140.163.4.231:8080
10:39:44:WU01:FS01:Downloading 4.84MiB
10:39:50:WU01:FS01:Download 91.74%
10:39:50:WU01:FS01:Download complete
10:39:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:9 clone:2 gen:120 core:0x17 unit:0x000000e0538b3db753285256ad5056b2
10:39:50:WU01:FS01:Starting
10:39:50:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
10:39:50:WU01:FS01:Started FahCore on PID 3928
10:39:50:WU01:FS01:Core PID:1460
10:39:50:WU01:FS01:FahCore 0x17 started
10:39:51:WU01:FS01:0x17:*********************** Log Started 2015-02-27T10:39:50Z ***********************
10:39:51:WU01:FS01:0x17:Project: 13001 (Run 9, Clone 2, Gen 120)
10:39:51:WU01:FS01:0x17:Unit: 0x000000e0538b3db753285256ad5056b2
10:39:51:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:39:51:WU01:FS01:0x17:Machine: 1
10:39:51:WU01:FS01:0x17:Reading tar file state.xml
10:39:53:WU01:FS01:0x17:Reading tar file system.xml
10:39:54:WU01:FS01:0x17:Reading tar file integrator.xml
10:39:54:WU01:FS01:0x17:Reading tar file core.xml
10:39:54:WU01:FS01:0x17:Digital signatures verified
10:39:54:WU01:FS01:0x17:Folding@home GPU core17
10:39:54:WU01:FS01:0x17:Version 0.0.52
10:40:39:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
10:44:32:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 451.639 with threshold of 5
10:44:32:WU01:FS01:0x17:Saving result file logfile_01.txt
10:44:32:WU01:FS01:0x17:Saving result file log.txt
10:44:32:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
10:44:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:44:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:9 clone:2 gen:120 core:0x17 unit:0x000000e0538b3db753285256ad5056b2
10:44:32:WU01:FS01:Uploading 2.24KiB to 140.163.4.231
10:44:32:WU01:FS01:Connecting to 140.163.4.231:8080
10:44:33:WU01:FS01:Upload complete
10:44:33:WU01:FS01:Server responded WORK_ACK (400)
10:44:33:WU01:FS01:Cleaning up
10:44:33:WU02:FS01:Connecting to 171.67.108.200:80
10:44:33:WU02:FS01:Assigned to work server 140.163.4.233
10:44:33:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.233
10:44:33:WU02:FS01:Connecting to 140.163.4.233:8080
10:44:34:WU02:FS01:Downloading 4.27MiB
10:44:39:WU02:FS01:Download complete
10:44:39:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10467 run:0 clone:456 gen:83 core:0x17 unit:0x00000097538b3db9538bc4fa97d5ff6e
10:44:39:WU02:FS01:Starting
10:44:39:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
10:44:39:WU02:FS01:Started FahCore on PID 1412
10:44:39:WU02:FS01:Core PID:844
10:44:39:WU02:FS01:FahCore 0x17 started
10:44:39:WU02:FS01:0x17:*********************** Log Started 2015-02-27T10:44:39Z ***********************
10:44:39:WU02:FS01:0x17:Project: 10467 (Run 0, Clone 456, Gen 83)
10:44:39:WU02:FS01:0x17:Unit: 0x00000097538b3db9538bc4fa97d5ff6e
10:44:39:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:44:39:WU02:FS01:0x17:Machine: 1
10:44:39:WU02:FS01:0x17:Reading tar file state.xml
10:44:40:WU02:FS01:0x17:Reading tar file system.xml
10:44:41:WU02:FS01:0x17:Reading tar file integrator.xml
10:44:41:WU02:FS01:0x17:Reading tar file core.xml
10:44:41:WU02:FS01:0x17:Digital signatures verified
10:44:41:WU02:FS01:0x17:Folding@home GPU core17
10:44:41:WU02:FS01:0x17:Version 0.0.52
10:45:37:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
10:48:14:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 410.644 with threshold of 5
10:48:14:WU02:FS01:0x17:Saving result file logfile_01.txt
10:48:14:WU02:FS01:0x17:Saving result file log.txt
10:48:14:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
10:48:14:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:48:14:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10467 run:0 clone:456 gen:83 core:0x17 unit:0x00000097538b3db9538bc4fa97d5ff6e
10:48:14:WU02:FS01:Uploading 2.18KiB to 140.163.4.233
10:48:14:WU02:FS01:Connecting to 140.163.4.233:8080
10:48:14:WU02:FS01:Upload complete
10:48:14:WU02:FS01:Server responded WORK_ACK (400)
10:48:14:WU02:FS01:Cleaning up
10:48:14:WU01:FS01:Connecting to 171.67.108.200:80
10:48:15:WU01:FS01:Assigned to work server 140.163.4.231
10:48:15:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
10:48:15:WU01:FS01:Connecting to 140.163.4.231:8080
10:48:16:WU01:FS01:Downloading 4.84MiB
10:48:20:WU01:FS01:Download complete
10:48:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:240 clone:7 gen:73 core:0x17 unit:0x0000009c538b3db7532893e5d8655271
10:48:20:WU01:FS01:Starting
10:48:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
10:48:20:WU01:FS01:Started FahCore on PID 3444
10:48:20:WU01:FS01:Core PID:3572
10:48:20:WU01:FS01:FahCore 0x17 started
10:48:21:WU01:FS01:0x17:*********************** Log Started 2015-02-27T10:48:21Z ***********************
10:48:21:WU01:FS01:0x17:Project: 13001 (Run 240, Clone 7, Gen 73)
10:48:21:WU01:FS01:0x17:Unit: 0x0000009c538b3db7532893e5d8655271
10:48:21:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:48:21:WU01:FS01:0x17:Machine: 1
10:48:21:WU01:FS01:0x17:Reading tar file state.xml
10:48:22:WU01:FS01:0x17:Reading tar file system.xml
10:48:23:WU01:FS01:0x17:Reading tar file integrator.xml
10:48:23:WU01:FS01:0x17:Reading tar file core.xml
10:48:23:WU01:FS01:0x17:Digital signatures verified
10:48:23:WU01:FS01:0x17:Folding@home GPU core17
10:48:23:WU01:FS01:0x17:Version 0.0.52
10:50:44:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
10:52:46:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 457.232 with threshold of 5
10:52:46:WU01:FS01:0x17:Saving result file logfile_01.txt
10:52:46:WU01:FS01:0x17:Saving result file log.txt
10:52:46:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
10:52:46:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:52:46:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:240 clone:7 gen:73 core:0x17 unit:0x0000009c538b3db7532893e5d8655271
10:52:46:WU01:FS01:Uploading 2.23KiB to 140.163.4.231
10:52:46:WU01:FS01:Connecting to 140.163.4.231:8080
10:52:46:WU01:FS01:Upload complete
10:52:46:WU01:FS01:Server responded WORK_ACK (400)
10:52:46:WU01:FS01:Cleaning up
10:52:46:WU02:FS01:Connecting to 171.67.108.200:80
10:52:47:WU02:FS01:Assigned to work server 140.163.4.231
10:52:47:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
10:52:47:WU02:FS01:Connecting to 140.163.4.231:8080
10:52:47:WU02:FS01:Downloading 4.84MiB
10:52:52:WU02:FS01:Download complete
10:52:52:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:850 clone:0 gen:103 core:0x17 unit:0x000000c8538b3db753108b853bad2eb1
10:52:52:WU02:FS01:Starting
10:52:52:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
10:52:52:WU02:FS01:Started FahCore on PID 3256
10:52:53:WU02:FS01:Core PID:3548
10:52:53:WU02:FS01:FahCore 0x17 started
10:52:53:WU02:FS01:0x17:*********************** Log Started 2015-02-27T10:52:53Z ***********************
10:52:53:WU02:FS01:0x17:Project: 13000 (Run 850, Clone 0, Gen 103)
10:52:53:WU02:FS01:0x17:Unit: 0x000000c8538b3db753108b853bad2eb1
10:52:53:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:52:53:WU02:FS01:0x17:Machine: 1
10:52:53:WU02:FS01:0x17:Reading tar file state.xml
10:52:54:WU02:FS01:0x17:Reading tar file system.xml
10:52:55:WU02:FS01:0x17:Reading tar file integrator.xml
10:52:55:WU02:FS01:0x17:Reading tar file core.xml
10:52:55:WU02:FS01:0x17:Digital signatures verified
10:52:55:WU02:FS01:0x17:Folding@home GPU core17
10:52:55:WU02:FS01:0x17:Version 0.0.52
10:55:37:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
10:57:24:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 452.81 with threshold of 5
10:57:24:WU02:FS01:0x17:Saving result file logfile_01.txt
10:57:24:WU02:FS01:0x17:Saving result file log.txt
10:57:24:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
10:57:24:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:57:24:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:850 clone:0 gen:103 core:0x17 unit:0x000000c8538b3db753108b853bad2eb1
10:57:24:WU02:FS01:Uploading 2.24KiB to 140.163.4.231
10:57:24:WU02:FS01:Connecting to 140.163.4.231:8080
10:57:24:WU02:FS01:Upload complete
10:57:24:WU02:FS01:Server responded WORK_ACK (400)
10:57:24:WU02:FS01:Cleaning up
10:57:24:WU01:FS01:Connecting to 171.67.108.200:80
10:57:25:WU01:FS01:Assigned to work server 140.163.4.231
10:57:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
10:57:25:WU01:FS01:Connecting to 140.163.4.231:8080
10:57:25:WU01:FS01:Downloading 4.84MiB
10:57:30:WU01:FS01:Download complete
10:57:30:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:114 clone:4 gen:134 core:0x17 unit:0x000000dc538b3db75328700725864b40
10:57:30:WU01:FS01:Starting
10:57:30:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
10:57:30:WU01:FS01:Started FahCore on PID 1612
10:57:30:WU01:FS01:Core PID:3512
10:57:30:WU01:FS01:FahCore 0x17 started
10:57:30:WU01:FS01:0x17:*********************** Log Started 2015-02-27T10:57:30Z ***********************
10:57:30:WU01:FS01:0x17:Project: 13001 (Run 114, Clone 4, Gen 134)
10:57:30:WU01:FS01:0x17:Unit: 0x000000dc538b3db75328700725864b40
10:57:30:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:57:30:WU01:FS01:0x17:Machine: 1
10:57:30:WU01:FS01:0x17:Reading tar file state.xml
10:57:31:WU01:FS01:0x17:Reading tar file system.xml
10:57:32:WU01:FS01:0x17:Reading tar file integrator.xml
10:57:32:WU01:FS01:0x17:Reading tar file core.xml
10:57:32:WU01:FS01:0x17:Digital signatures verified
10:57:32:WU01:FS01:0x17:Folding@home GPU core17
10:57:32:WU01:FS01:0x17:Version 0.0.52
10:59:37:FS00:Shutting core down
10:59:38:FS01:Shutting core down
10:59:38:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 3512
10:59:38:WU01:FS01:0x17:Exiting, please wait. . .
10:59:44:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:59:44:WU00:FS00:Starting
10:59:44:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
10:59:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -np 2
10:59:44:WU00:FS00:Started FahCore on PID 3912
10:59:44:WU00:FS00:Core PID:2196
10:59:44:WU00:FS00:FahCore 0xa4 started
10:59:45:WU00:FS00:0xa4:
10:59:45:WU00:FS00:0xa4:*------------------------------*
10:59:45:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
10:59:45:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:59:45:WU00:FS00:0xa4:Preparing to commence simulation
10:59:45:WU00:FS00:0xa4:- Looking at optimizations...
10:59:45:WU00:FS00:0xa4:- Files status OK
10:59:45:WU00:FS00:0xa4:- Expanded 881116 -> 1463992 (decompressed 166.1 percent)
10:59:45:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=881116 data_size=1463992, decompressed_data_size=1463992 diff=0
10:59:45:WU00:FS00:0xa4:- Digital signature verified
10:59:45:WU00:FS00:0xa4:Project: 9008 (Run 690, Clone 2, Gen 234)
10:59:45:WU00:FS00:0xa4:Assembly optimizations on if available.
10:59:45:WU00:FS00:0xa4:Entering M.D.
10:59:51:WU00:FS00:0xa4:Using Gromacs checkpoints
10:59:51:WU00:FS00:0xa4:Mapping NT from 2 to 2
10:59:51:WU00:FS00:0xa4:Resuming from checkpoint
10:59:51:WU00:FS00:0xa4:Verified 00/wudata_01.log
10:59:51:WU00:FS00:0xa4:Verified 00/wudata_01.trr
10:59:51:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
10:59:51:WU00:FS00:0xa4:Verified 00/wudata_01.edr
10:59:51:WU00:FS00:0xa4:Completed 7375 out of 250000 steps (2%)
11:00:10:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
11:00:31:Saving configuration to config.xml
11:00:31:<config>
11:00:31: <!-- Folding Core -->
11:00:31: <checkpoint v='30'/>
11:00:31:
11:00:31: <!-- Network -->
11:00:31: <proxy v=':8080'/>
11:00:31:
11:00:31: <!-- Slot Control -->
11:00:31: <power v='light'/>
11:00:31:
11:00:31: <!-- User Information -->
11:00:31: <passkey v='********************************'/>
11:00:31: <user v='*****************************'/>
11:00:31:
11:00:31: <!-- Folding Slots -->
11:00:31: <slot id='0' type='CPU'/>
11:00:31: <slot id='1' type='GPU'/>
11:00:31:</config>
11:00:39:WARNING:FS01:Killing WU01
11:00:39:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:01:32:WU01:FS01:Starting
11:01:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
11:01:32:WU01:FS01:Started FahCore on PID 716
11:01:32:WU01:FS01:Core PID:3972
11:01:32:WU01:FS01:FahCore 0x17 started
11:01:32:FS00:Shutting core down
11:01:32:WU01:FS01:0x17:*********************** Log Started 2015-02-27T11:01:32Z ***********************
11:01:32:WU01:FS01:0x17:Project: 13001 (Run 114, Clone 4, Gen 134)
11:01:32:WU01:FS01:0x17:Unit: 0x000000dc538b3db75328700725864b40
11:01:32:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:01:32:WU01:FS01:0x17:Machine: 1
11:01:32:WU01:FS01:0x17:Reading tar file state.xml
11:01:33:WU01:FS01:0x17:Reading tar file system.xml
11:01:34:WU01:FS01:0x17:Reading tar file integrator.xml
11:01:34:WU01:FS01:0x17:Reading tar file core.xml
11:01:34:WU01:FS01:0x17:Digital signatures verified
11:01:34:WU01:FS01:0x17:Folding@home GPU core17
11:01:34:WU01:FS01:0x17:Version 0.0.52
11:01:35:WU00:FS00:0xa4:Client no longer detected. Shutting down core
11:01:35:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
11:01:35:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:01:35:WU00:FS00:Starting
11:01:35:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
11:01:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -np 3
11:01:35:WU00:FS00:Started FahCore on PID 2752
11:01:35:WU00:FS00:Core PID:1236
11:01:35:WU00:FS00:FahCore 0xa4 started
11:01:36:WU00:FS00:0xa4:
11:01:36:WU00:FS00:0xa4:*------------------------------*
11:01:36:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
11:01:36:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:01:36:WU00:FS00:0xa4:Preparing to commence simulation
11:01:36:WU00:FS00:0xa4:- Looking at optimizations...
11:01:36:WU00:FS00:0xa4:- Files status OK
11:01:36:WU00:FS00:0xa4:- Expanded 881116 -> 1463992 (decompressed 166.1 percent)
11:01:36:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=881116 data_size=1463992, decompressed_data_size=1463992 diff=0
11:01:36:WU00:FS00:0xa4:- Digital signature verified
11:01:36:WU00:FS00:0xa4:Project: 9008 (Run 690, Clone 2, Gen 234)
11:01:36:WU00:FS00:0xa4:Assembly optimizations on if available.
11:01:36:WU00:FS00:0xa4:Entering M.D.
11:01:41:WU00:FS00:0xa4:Using Gromacs checkpoints
11:01:41:WU00:FS00:0xa4:Mapping NT from 3 to 3
11:01:42:WU00:FS00:0xa4:Resuming from checkpoint
11:01:42:WU00:FS00:0xa4:Verified 00/wudata_01.log
11:01:42:WU00:FS00:0xa4:Verified 00/wudata_01.trr
11:01:42:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
11:01:42:WU00:FS00:0xa4:Verified 00/wudata_01.edr
11:01:42:WU00:FS00:0xa4:Completed 7375 out of 250000 steps (2%)
11:01:56:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
11:02:33:Saving configuration to config.xml
11:02:33:<config>
11:02:33: <!-- Folding Core -->
11:02:33: <checkpoint v='30'/>
11:02:33:
11:02:33: <!-- Network -->
11:02:33: <proxy v=':8080'/>
11:02:33:
11:02:33: <!-- Slot Control -->
11:02:33: <power v='full'/>
11:02:33:
11:02:33: <!-- User Information -->
11:02:33: <passkey v='********************************'/>
11:02:33: <user v='**************************'/>
11:02:33:
11:02:33: <!-- Folding Slots -->
11:02:33: <slot id='0' type='CPU'/>
11:02:33: <slot id='1' type='GPU'/>
11:02:33:</config>
11:06:00:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 451.434 with threshold of 5
11:06:00:WU01:FS01:0x17:Saving result file logfile_01.txt
11:06:00:WU01:FS01:0x17:Saving result file log.txt
11:06:00:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:00:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:00:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:114 clone:4 gen:134 core:0x17 unit:0x000000dc538b3db75328700725864b40
11:06:00:WU01:FS01:Uploading 2.60KiB to 140.163.4.231
11:06:00:WU01:FS01:Connecting to 140.163.4.231:8080
11:06:01:WU02:FS01:Connecting to 171.67.108.200:80
11:06:01:WU01:FS01:Upload complete
11:06:01:WU01:FS01:Server responded WORK_ACK (400)
11:06:01:WU01:FS01:Cleaning up
11:06:01:WU02:FS01:Assigned to work server 140.163.4.231
11:06:01:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
11:06:01:WU02:FS01:Connecting to 140.163.4.231:8080
11:06:02:WU02:FS01:Downloading 4.84MiB
11:06:07:WU02:FS01:Download complete
11:06:07:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:455 clone:0 gen:112 core:0x17 unit:0x000000dc538b3db753101c49291d7d2c
11:06:07:WU02:FS01:Starting
11:06:07:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
11:06:07:WU02:FS01:Started FahCore on PID 2488
11:06:07:WU02:FS01:Core PID:3600
11:06:07:WU02:FS01:FahCore 0x17 started
11:06:08:WU02:FS01:0x17:*********************** Log Started 2015-02-27T11:06:07Z ***********************
11:06:08:WU02:FS01:0x17:Project: 13000 (Run 455, Clone 0, Gen 112)
11:06:08:WU02:FS01:0x17:Unit: 0x000000dc538b3db753101c49291d7d2c
11:06:08:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:08:WU02:FS01:0x17:Machine: 1
11:06:08:WU02:FS01:0x17:Reading tar file state.xml
11:06:09:WU02:FS01:0x17:Reading tar file system.xml
11:06:10:WU02:FS01:0x17:Reading tar file integrator.xml
11:06:10:WU02:FS01:0x17:Reading tar file core.xml
11:06:10:WU02:FS01:0x17:Digital signatures verified
11:06:10:WU02:FS01:0x17:Folding@home GPU core17
11:06:10:WU02:FS01:0x17:Version 0.0.52
11:06:50:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
11:10:36:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 453.092 with threshold of 5
11:10:36:WU02:FS01:0x17:Saving result file logfile_01.txt
11:10:36:WU02:FS01:0x17:Saving result file log.txt
11:10:36:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:10:37:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:10:37:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:455 clone:0 gen:112 core:0x17 unit:0x000000dc538b3db753101c49291d7d2c
11:10:37:WU02:FS01:Uploading 2.25KiB to 140.163.4.231
11:10:37:WU02:FS01:Connecting to 140.163.4.231:8080
11:10:37:WU02:FS01:Upload complete
11:10:37:WU02:FS01:Server responded WORK_ACK (400)
11:10:37:WU02:FS01:Cleaning up
11:10:37:WU01:FS01:Connecting to 171.67.108.200:80
11:10:38:WU01:FS01:Assigned to work server 140.163.4.231
11:10:38:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
11:10:38:WU01:FS01:Connecting to 140.163.4.231:8080
11:10:38:WU01:FS01:Downloading 4.84MiB
11:10:43:WU01:FS01:Download complete
11:10:43:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:489 clone:0 gen:130 core:0x17 unit:0x000000cd538b3db7532c86ae6411c58e
11:10:43:WU01:FS01:Starting
11:10:43:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
11:10:43:WU01:FS01:Started FahCore on PID 2104
11:10:43:WU01:FS01:Core PID:3972
11:10:43:WU01:FS01:FahCore 0x17 started
11:10:43:WU01:FS01:0x17:*********************** Log Started 2015-02-27T11:10:43Z ***********************
11:10:43:WU01:FS01:0x17:Project: 13001 (Run 489, Clone 0, Gen 130)
11:10:43:WU01:FS01:0x17:Unit: 0x000000cd538b3db7532c86ae6411c58e
11:10:43:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:10:43:WU01:FS01:0x17:Machine: 1
11:10:43:WU01:FS01:0x17:Reading tar file state.xml
11:10:44:WU01:FS01:0x17:Reading tar file system.xml
11:10:45:WU01:FS01:0x17:Reading tar file integrator.xml
11:10:45:WU01:FS01:0x17:Reading tar file core.xml
11:10:45:WU01:FS01:0x17:Digital signatures verified
11:10:45:WU01:FS01:0x17:Folding@home GPU core17
11:10:45:WU01:FS01:0x17:Version 0.0.52
11:11:34:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
11:15:21:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 453.266 with threshold of 5
11:15:21:WU01:FS01:0x17:Saving result file logfile_01.txt
11:15:21:WU01:FS01:0x17:Saving result file log.txt
11:15:21:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:15:21:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:15:21:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:489 clone:0 gen:130 core:0x17 unit:0x000000cd538b3db7532c86ae6411c58e
11:15:21:WU01:FS01:Uploading 2.23KiB to 140.163.4.231
11:15:21:WU01:FS01:Connecting to 140.163.4.231:8080
11:15:22:WU01:FS01:Upload complete
11:15:22:WU01:FS01:Server responded WORK_ACK (400)
11:15:22:WU01:FS01:Cleaning up
11:15:22:WU02:FS01:Connecting to 171.67.108.200:80
11:15:22:WU02:FS01:Assigned to work server 140.163.4.231
11:15:22:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
11:15:22:WU02:FS01:Connecting to 140.163.4.231:8080
11:15:23:WU02:FS01:Downloading 4.84MiB
11:15:29:WU02:FS01:Download 96.93%
11:15:29:WU02:FS01:Download complete
11:15:29:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:648 clone:0 gen:125 core:0x17 unit:0x000000e5538b3db7531052895dcb033e
11:15:29:WU02:FS01:Starting
11:15:29:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
11:15:29:WU02:FS01:Started FahCore on PID 3592
11:15:29:WU02:FS01:Core PID:3568
11:15:29:WU02:FS01:FahCore 0x17 started
11:15:29:WU02:FS01:0x17:*********************** Log Started 2015-02-27T11:15:29Z ***********************
11:15:29:WU02:FS01:0x17:Project: 13000 (Run 648, Clone 0, Gen 125)
11:15:29:WU02:FS01:0x17:Unit: 0x000000e5538b3db7531052895dcb033e
11:15:29:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:15:29:WU02:FS01:0x17:Machine: 1
11:15:29:WU02:FS01:0x17:Reading tar file state.xml
11:15:30:WU02:FS01:0x17:Reading tar file system.xml
11:15:31:WU02:FS01:0x17:Reading tar file integrator.xml
11:15:31:WU02:FS01:0x17:Reading tar file core.xml
11:15:31:WU02:FS01:0x17:Digital signatures verified
11:15:31:WU02:FS01:0x17:Folding@home GPU core17
11:15:31:WU02:FS01:0x17:Version 0.0.52
11:16:20:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
11:20:11:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 458.818 with threshold of 5
11:20:11:WU02:FS01:0x17:Saving result file logfile_01.txt
11:20:11:WU02:FS01:0x17:Saving result file log.txt
11:20:11:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:20:11:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:20:11:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:648 clone:0 gen:125 core:0x17 unit:0x000000e5538b3db7531052895dcb033e
11:20:11:WU02:FS01:Uploading 2.24KiB to 140.163.4.231
11:20:11:WU02:FS01:Connecting to 140.163.4.231:8080
11:20:11:WU02:FS01:Upload complete
11:20:11:WU02:FS01:Server responded WORK_ACK (400)
11:20:11:WU02:FS01:Cleaning up
11:20:11:WU01:FS01:Connecting to 171.67.108.200:80
11:20:12:WU01:FS01:Assigned to work server 140.163.4.231
11:20:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
11:20:12:WU01:FS01:Connecting to 140.163.4.231:8080
11:20:13:WU01:FS01:Downloading 4.84MiB
11:20:17:WU01:FS01:Download complete
11:20:18:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:308 clone:2 gen:59 core:0x17 unit:0x0000008c538b3db75328a709dbfcda96
11:20:18:WU01:FS01:Starting
11:20:18:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4016 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
11:20:18:WU01:FS01:Started FahCore on PID 3628
11:20:18:WU01:FS01:Core PID:1352
11:20:18:WU01:FS01:FahCore 0x17 started
11:20:18:WU01:FS01:0x17:*********************** Log Started 2015-02-27T11:20:18Z ***********************
11:20:18:WU01:FS01:0x17:Project: 13001 (Run 308, Clone 2, Gen 59)
11:20:18:WU01:FS01:0x17:Unit: 0x0000008c538b3db75328a709dbfcda96
11:20:18:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:20:18:WU01:FS01:0x17:Machine: 1
11:20:18:WU01:FS01:0x17:Reading tar file state.xml
11:20:19:WU01:FS01:0x17:Reading tar file system.xml
11:20:20:WU01:FS01:0x17:Reading tar file integrator.xml
11:20:20:WU01:FS01:0x17:Reading tar file core.xml
11:20:20:WU01:FS01:0x17:Digital signatures verified
11:20:20:WU01:FS01:0x17:Folding@home GPU core17
11:20:20:WU01:FS01:0x17:Version 0.0.52
11:21:08:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
11:24:49:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 452.958 with threshold of 5
11:24:49:WU01:FS01:0x17:Saving result file logfile_01.txt
11:24:49:WU01:FS01:0x17:Saving result file log.txt
11:24:49:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:24:49:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:24:49:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:308 clone:2 gen:59 core:0x17 unit:0x0000008c538b3db75328a709dbfcda96
11:24:49:WU01:FS01:Uploading 2.24KiB to 140.163.4.231
11:24:49:WU01:FS01:Connecting to 140.163.4.231:8080
11:24:49:WU01:FS01:Upload complete
11:24:49:WU01:FS01:Server responded WORK_ACK (400)
11:24:49:WU01:FS01:Cleaning up
11:25:58:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
11:30:29:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
Thanks, but I would call that "...unhappily..."Tromatic wrote:Content of current log. I removed the some of the end, the CPU client happily chugging along.
10:39:40:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 455.199 with threshold of 5 10:39:41:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 10:39:41:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:33 clone:6 gen:46 core:0x17 10:44:32:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 451.639 with threshold of 5 10:44:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 10:44:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:9 clone:2 gen:120 core:0x17 10:48:14:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 410.644 with threshold of 5 10:48:14:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 10:48:14:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10467 run:0 clone:456 gen:83 core:0x17 10:52:46:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 457.232 with threshold of 5 10:52:46:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 10:52:46:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:240 clone:7 gen:73 core:0x17 10:57:24:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 452.81 with threshold of 5 10:57:24:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 10:57:24:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:850 clone:0 gen:103 core:0x17 11:06:00:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 451.434 with threshold of 5 11:06:00:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 11:06:00:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:114 clone:4 gen:134 core:0x17 11:10:36:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 453.092 with threshold of 5 11:10:37:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 11:10:37:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:455 clone:0 gen:112 core:0x17 11:15:21:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 453.266 with threshold of 5 11:15:21:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 11:15:21:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:489 clone:0 gen:130 core:0x17 11:20:11:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 458.818 with threshold of 5 11:20:11:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 11:20:11:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:648 clone:0 gen:125 core:0x17 11:24:49:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 452.958 with threshold of 5 11:24:49:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 11:24:49:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:308 clone:2 gen:59 core:0x17
These demonstrate the bug which has been fixed provided you update the GPU drivers.
The CPU slot has been solid, it's the GPU that died. Perhaps I am misreading the log. Regardless, it must have been something I did regarding drivers. Seems to be working now, though, according to the control panel and hardware monitor.Thanks, but I would call that "...unhappily..."
Gary480six
I just posted about this yesterday here in another section of the forum.
And what 7im and Bruce are telling you was the exact solution for me.
Update your Nvidia video card drivers to the latest version.
Seems to be folding happily now. I must have installed a way-older driver thinking I was updating. Anyway, thanks much!Gary480six wrote:I just posted about this yesterday here in another section of the forum.
