ALL have failed in the last 24 hours. In my mind there is a 0% chance that four different video cards could exhibit hardware failures at the same time. (while other GTX 560 and GTX 650 cards in different systems are not having issues)
After perhaps a dozen BAD WORK units, the version 7 client just marks that slot as FAILED and shuts off Folding
I suspect that Stanford has once again tweeked the assignment or work server - with BAD results.
*********************** Log Started 2015-02-14T21:10:39Z ***********************
21:10:39:************************* Folding@home Client *************************
21:10:39: Website: http://folding.stanford.edu/
21:10:39: Copyright: (c) 2009-2014 Stanford University
21:10:39: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:10:39: Args:
21:10:39: Config: C:/Users/Dells Bells/AppData/Roaming/FAHClient/config.xml
21:10:39:******************************** Build ********************************
21:10:39: Version: 7.4.4
21:10:39: Date: Mar 4 2014
21:10:39: Time: 20:26:54
21:10:39: SVN Rev: 4130
21:10:39: Branch: fah/trunk/client
21:10:39: Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:10:39: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:10:39: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
21:10:39: Platform: win32 XP
21:10:39: Bits: 32
21:10:39: Mode: Release
21:10:39:******************************* System ********************************
21:10:39: CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
21:10:39: CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
21:10:39: CPUs: 8
21:10:39: Memory: 3.99GiB
21:10:39: Free Memory: 2.82GiB
21:10:39: Threads: WINDOWS_THREADS
21:10:39: OS Version: 6.1
21:10:39: Has Battery: false
21:10:39: On Battery: false
21:10:39: UTC Offset: -5
21:10:39: PID: 2752
21:10:39: CWD: C:/Users/Dells Bells/AppData/Roaming/FAHClient
21:10:39: OS: Windows 7 Professional
21:10:39: OS Arch: AMD64
21:10:39: GPUs: 1
21:10:39: GPU 0: NVIDIA:4 GM107 [GeForce GTX 750 Ti]
21:10:39: CUDA: 5.0
21:10:39: CUDA Driver: 6050
21:10:39:Win32 Service: false
21:10:39:***********************************************************************
21:10:39:<config>
21:10:39: <!-- Network -->
21:10:39: <proxy v=':8080'/>
21:10:39:
21:10:39: <!-- Slot Control -->
21:10:39: <power v='full'/>
21:10:39:
21:10:39: <!-- User Information -->
21:10:39: <passkey v='********************************'/>
21:10:39: <team v='11108'/>
21:10:39: <user v='Gary480six'/>
21:10:39:
21:10:39: <!-- Folding Slots -->
21:10:39: <slot id='1' type='GPU'>
21:10:39: <paused v='true'/>
21:10:39: </slot>
21:10:39:</config>
21:10:39:Trying to access database...
Above is the machine data - Below is log file before the version 7 client marked the GPU slot as failed
12:21:17:WU00:FS01:Assigned to work server 140.163.4.231
12:21:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:21:17:WU00:FS01:Connecting to 140.163.4.231:8080
12:21:17:WU00:FS01:Downloading 4.84MiB
12:21:20:WU00:FS01:Download complete
12:21:20:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13000 run:466 clone:0 gen:152 core:0x17 unit:0x00000104538b3db753101f5e2f35e90c
12:21:20:WU00:FS01:Starting
12:21:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:21:20:WU00:FS01:Started FahCore on PID 912
12:21:20:WU00:FS01:Core PID:3064
12:21:20:WU00:FS01:FahCore 0x17 started
12:21:20:WU00:FS01:0x17:*********************** Log Started 2015-02-26T12:21:20Z ***********************
12:21:20:WU00:FS01:0x17:Project: 13000 (Run 466, Clone 0, Gen 152)
12:21:20:WU00:FS01:0x17:Unit: 0x00000104538b3db753101f5e2f35e90c
12:21:20:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:21:20:WU00:FS01:0x17:Machine: 1
12:21:20:WU00:FS01:0x17:Reading tar file state.xml
12:21:21:WU00:FS01:0x17:Reading tar file system.xml
12:21:22:WU00:FS01:0x17:Reading tar file integrator.xml
12:21:22:WU00:FS01:0x17:Reading tar file core.xml
12:21:22:WU00:FS01:0x17:Digital signatures verified
12:21:22:WU00:FS01:0x17:Folding@home GPU core17
12:21:22:WU00:FS01:0x17:Version 0.0.52
12:24:46:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 449.706 with threshold of 5
12:24:46:WU00:FS01:0x17:Saving result file logfile_01.txt
12:24:46:WU00:FS01:0x17:Saving result file log.txt
12:24:46:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:24:46:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:24:46:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:466 clone:0 gen:152 core:0x17 unit:0x00000104538b3db753101f5e2f35e90c
12:24:46:WU00:FS01:Uploading 2.26KiB to 140.163.4.231
12:24:46:WU00:FS01:Connecting to 140.163.4.231:8080
12:24:47:WU01:FS01:Connecting to 171.67.108.200:80
12:24:47:WU00:FS01:Upload complete
12:24:47:WU00:FS01:Server responded WORK_ACK (400)
12:24:47:WU00:FS01:Cleaning up
12:24:48:WU01:FS01:Assigned to work server 140.163.4.231
12:24:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:24:48:WU01:FS01:Connecting to 140.163.4.231:8080
12:24:48:WU01:FS01:Downloading 4.83MiB
12:24:50:WU01:FS01:Download complete
12:24:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:463 clone:2 gen:45 core:0x17 unit:0x0000004f538b3db753101e953ce58f70
12:24:51:WU01:FS01:Starting
12:24:51:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:24:51:WU01:FS01:Started FahCore on PID 2128
12:24:51:WU01:FS01:Core PID:3056
12:24:51:WU01:FS01:FahCore 0x17 started
12:24:51:WU01:FS01:0x17:*********************** Log Started 2015-02-26T12:24:51Z ***********************
12:24:51:WU01:FS01:0x17:Project: 13000 (Run 463, Clone 2, Gen 45)
12:24:51:WU01:FS01:0x17:Unit: 0x0000004f538b3db753101e953ce58f70
12:24:51:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:24:51:WU01:FS01:0x17:Machine: 1
12:24:51:WU01:FS01:0x17:Reading tar file state.xml
12:24:52:WU01:FS01:0x17:Reading tar file system.xml
12:24:53:WU01:FS01:0x17:Reading tar file integrator.xml
12:24:53:WU01:FS01:0x17:Reading tar file core.xml
12:24:53:WU01:FS01:0x17:Digital signatures verified
12:24:53:WU01:FS01:0x17:Folding@home GPU core17
12:24:53:WU01:FS01:0x17:Version 0.0.52
12:28:16:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 454.726 with threshold of 5
12:28:16:WU01:FS01:0x17:Saving result file logfile_01.txt
12:28:16:WU01:FS01:0x17:Saving result file log.txt
12:28:16:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:28:17:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:28:17:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:463 clone:2 gen:45 core:0x17 unit:0x0000004f538b3db753101e953ce58f70
12:28:17:WU01:FS01:Uploading 2.24KiB to 140.163.4.231
12:28:17:WU01:FS01:Connecting to 140.163.4.231:8080
12:28:17:WU01:FS01:Upload complete
12:28:17:WU01:FS01:Server responded WORK_ACK (400)
12:28:17:WU01:FS01:Cleaning up
12:28:17:WU00:FS01:Connecting to 171.67.108.200:80
12:28:18:WU00:FS01:Assigned to work server 140.163.4.231
12:28:18:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:28:18:WU00:FS01:Connecting to 140.163.4.231:8080
12:28:18:WU00:FS01:Downloading 4.84MiB
12:28:20:WU00:FS01:Download complete
12:28:20:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13001 run:289 clone:0 gen:93 core:0x17 unit:0x000000aa538b3db75328a1989a078b20
12:28:20:WU00:FS01:Starting
12:28:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:28:20:WU00:FS01:Started FahCore on PID 2836
12:28:20:WU00:FS01:Core PID:1844
12:28:20:WU00:FS01:FahCore 0x17 started
12:28:21:WU00:FS01:0x17:*********************** Log Started 2015-02-26T12:28:21Z ***********************
12:28:21:WU00:FS01:0x17:Project: 13001 (Run 289, Clone 0, Gen 93)
12:28:21:WU00:FS01:0x17:Unit: 0x000000aa538b3db75328a1989a078b20
12:28:21:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:28:21:WU00:FS01:0x17:Machine: 1
12:28:21:WU00:FS01:0x17:Reading tar file state.xml
12:28:22:WU00:FS01:0x17:Reading tar file system.xml
12:28:23:WU00:FS01:0x17:Reading tar file integrator.xml
12:28:23:WU00:FS01:0x17:Reading tar file core.xml
12:28:23:WU00:FS01:0x17:Digital signatures verified
12:28:23:WU00:FS01:0x17:Folding@home GPU core17
12:28:23:WU00:FS01:0x17:Version 0.0.52
12:31:46:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 450.572 with threshold of 5
12:31:46:WU00:FS01:0x17:Saving result file logfile_01.txt
12:31:46:WU00:FS01:0x17:Saving result file log.txt
12:31:46:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:31:47:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:31:47:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13001 run:289 clone:0 gen:93 core:0x17 unit:0x000000aa538b3db75328a1989a078b20
12:31:47:WU00:FS01:Uploading 2.25KiB to 140.163.4.231
12:31:47:WU00:FS01:Connecting to 140.163.4.231:8080
12:31:47:WU01:FS01:Connecting to 171.67.108.200:80
12:31:48:WU01:FS01:Assigned to work server 140.163.4.231
12:31:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:31:48:WU01:FS01:Connecting to 140.163.4.231:8080
12:31:49:WU00:FS01:Upload complete
12:31:49:WU00:FS01:Server responded WORK_ACK (400)
12:31:49:WU00:FS01:Cleaning up
12:31:50:WU01:FS01:Downloading 4.83MiB
12:31:52:WU01:FS01:Download complete
12:31:52:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:77 clone:1 gen:123 core:0x17 unit:0x000000e0538b3db75328658362add919
12:31:52:WU01:FS01:Starting
12:31:52:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:31:52:WU01:FS01:Started FahCore on PID 2700
12:31:52:WU01:FS01:Core PID:1076
12:31:52:WU01:FS01:FahCore 0x17 started
12:31:53:WU01:FS01:0x17:*********************** Log Started 2015-02-26T12:31:52Z ***********************
12:31:53:WU01:FS01:0x17:Project: 13001 (Run 77, Clone 1, Gen 123)
12:31:53:WU01:FS01:0x17:Unit: 0x000000e0538b3db75328658362add919
12:31:53:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:31:53:WU01:FS01:0x17:Machine: 1
12:31:53:WU01:FS01:0x17:Reading tar file state.xml
12:31:54:WU01:FS01:0x17:Reading tar file system.xml
12:31:55:WU01:FS01:0x17:Reading tar file integrator.xml
12:31:55:WU01:FS01:0x17:Reading tar file core.xml
12:31:55:WU01:FS01:0x17:Digital signatures verified
12:31:55:WU01:FS01:0x17:Folding@home GPU core17
12:31:55:WU01:FS01:0x17:Version 0.0.52
12:35:18:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 451.976 with threshold of 5
12:35:18:WU01:FS01:0x17:Saving result file logfile_01.txt
12:35:18:WU01:FS01:0x17:Saving result file log.txt
12:35:18:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:35:18:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:35:18:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:77 clone:1 gen:123 core:0x17 unit:0x000000e0538b3db75328658362add919
12:35:18:WU01:FS01:Uploading 2.25KiB to 140.163.4.231
12:35:18:WU01:FS01:Connecting to 140.163.4.231:8080
12:35:18:WU00:FS01:Connecting to 171.67.108.200:80
12:35:19:WU01:FS01:Upload complete
12:35:19:WU01:FS01:Server responded WORK_ACK (400)
12:35:19:WU01:FS01:Cleaning up
12:35:19:WU00:FS01:Assigned to work server 140.163.4.231
12:35:19:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:35:19:WU00:FS01:Connecting to 140.163.4.231:8080
12:35:20:WU00:FS01:Downloading 4.84MiB
12:35:22:WU00:FS01:Download complete
12:35:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13001 run:102 clone:4 gen:129 core:0x17 unit:0x000000d6538b3db753286ca35fa9c662
12:35:22:WU00:FS01:Starting
12:35:22:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:35:22:WU00:FS01:Started FahCore on PID 2548
12:35:22:WU00:FS01:Core PID:2204
12:35:22:WU00:FS01:FahCore 0x17 started
12:35:23:WU00:FS01:0x17:*********************** Log Started 2015-02-26T12:35:22Z ***********************
12:35:23:WU00:FS01:0x17:Project: 13001 (Run 102, Clone 4, Gen 129)
12:35:23:WU00:FS01:0x17:Unit: 0x000000d6538b3db753286ca35fa9c662
12:35:23:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:35:23:WU00:FS01:0x17:Machine: 1
12:35:23:WU00:FS01:0x17:Reading tar file state.xml
12:35:24:WU00:FS01:0x17:Reading tar file system.xml
12:35:25:WU00:FS01:0x17:Reading tar file integrator.xml
12:35:25:WU00:FS01:0x17:Reading tar file core.xml
12:35:25:WU00:FS01:0x17:Digital signatures verified
12:35:25:WU00:FS01:0x17:Folding@home GPU core17
12:35:25:WU00:FS01:0x17:Version 0.0.52
12:38:48:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 449.688 with threshold of 5
12:38:48:WU00:FS01:0x17:Saving result file logfile_01.txt
12:38:48:WU00:FS01:0x17:Saving result file log.txt
12:38:48:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:38:48:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:38:48:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13001 run:102 clone:4 gen:129 core:0x17 unit:0x000000d6538b3db753286ca35fa9c662
12:38:48:WU00:FS01:Uploading 2.26KiB to 140.163.4.231
12:38:48:WU00:FS01:Connecting to 140.163.4.231:8080
12:38:49:WU01:FS01:Connecting to 171.67.108.200:80
12:38:49:WU01:FS01:Assigned to work server 140.163.4.231
12:38:49:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:38:49:WU01:FS01:Connecting to 140.163.4.231:8080
12:38:50:WU00:FS01:Upload complete
12:38:50:WU00:FS01:Server responded WORK_ACK (400)
12:38:50:WU00:FS01:Cleaning up
12:38:51:WU01:FS01:Downloading 4.84MiB
12:38:53:WU01:FS01:Download complete
12:38:53:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:330 clone:2 gen:44 core:0x17 unit:0x00000055538b3db75328ad44db025d48
12:38:53:WU01:FS01:Starting
12:38:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:38:53:WU01:FS01:Started FahCore on PID 708
12:38:53:WU01:FS01:Core PID:1872
12:38:53:WU01:FS01:FahCore 0x17 started
12:38:53:WU01:FS01:0x17:*********************** Log Started 2015-02-26T12:38:53Z ***********************
12:38:53:WU01:FS01:0x17:Project: 13001 (Run 330, Clone 2, Gen 44)
12:38:53:WU01:FS01:0x17:Unit: 0x00000055538b3db75328ad44db025d48
12:38:53:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:38:53:WU01:FS01:0x17:Machine: 1
12:38:53:WU01:FS01:0x17:Reading tar file state.xml
12:38:54:WU01:FS01:0x17:Reading tar file system.xml
12:38:55:WU01:FS01:0x17:Reading tar file integrator.xml
12:38:55:WU01:FS01:0x17:Reading tar file core.xml
12:38:55:WU01:FS01:0x17:Digital signatures verified
12:38:55:WU01:FS01:0x17:Folding@home GPU core17
12:38:55:WU01:FS01:0x17:Version 0.0.52
12:42:19:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 456.48 with threshold of 5
12:42:19:WU01:FS01:0x17:Saving result file logfile_01.txt
12:42:19:WU01:FS01:0x17:Saving result file log.txt
12:42:19:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:42:19:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:42:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:330 clone:2 gen:44 core:0x17 unit:0x00000055538b3db75328ad44db025d48
12:42:19:WU01:FS01:Uploading 2.24KiB to 140.163.4.231
12:42:19:WU01:FS01:Connecting to 140.163.4.231:8080
12:42:20:WU01:FS01:Upload complete
12:42:20:WU01:FS01:Server responded WORK_ACK (400)
12:42:20:WU01:FS01:Cleaning up
12:42:20:WU00:FS01:Connecting to 171.67.108.200:80
12:42:20:WU00:FS01:Assigned to work server 140.163.4.231
12:42:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:42:20:WU00:FS01:Connecting to 140.163.4.231:8080
12:42:20:WU00:FS01:Downloading 4.83MiB
12:42:23:WU00:FS01:Download complete
12:42:23:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13000 run:233 clone:0 gen:126 core:0x17 unit:0x000000d1538b3db7530fdda459e147a3
12:42:23:WU00:FS01:Starting
12:42:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:42:23:WU00:FS01:Started FahCore on PID 956
12:42:23:WU00:FS01:Core PID:1116
12:42:23:WU00:FS01:FahCore 0x17 started
12:42:23:WU00:FS01:0x17:*********************** Log Started 2015-02-26T12:42:23Z ***********************
12:42:23:WU00:FS01:0x17:Project: 13000 (Run 233, Clone 0, Gen 126)
12:42:23:WU00:FS01:0x17:Unit: 0x000000d1538b3db7530fdda459e147a3
12:42:23:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:42:23:WU00:FS01:0x17:Machine: 1
12:42:23:WU00:FS01:0x17:Reading tar file state.xml
12:42:24:WU00:FS01:0x17:Reading tar file system.xml
12:42:25:WU00:FS01:0x17:Reading tar file integrator.xml
12:42:25:WU00:FS01:0x17:Reading tar file core.xml
12:42:25:WU00:FS01:0x17:Digital signatures verified
12:42:25:WU00:FS01:0x17:Folding@home GPU core17
12:42:25:WU00:FS01:0x17:Version 0.0.52
12:45:49:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 451.446 with threshold of 5
12:45:49:WU00:FS01:0x17:Saving result file logfile_01.txt
12:45:49:WU00:FS01:0x17:Saving result file log.txt
12:45:49:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:45:49:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:45:49:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:233 clone:0 gen:126 core:0x17 unit:0x000000d1538b3db7530fdda459e147a3
12:45:49:WU00:FS01:Uploading 2.25KiB to 140.163.4.231
12:45:49:WU00:FS01:Connecting to 140.163.4.231:8080
12:45:49:WU00:FS01:Upload complete
12:45:49:WU00:FS01:Server responded WORK_ACK (400)
12:45:49:WU00:FS01:Cleaning up
12:45:50:WU01:FS01:Connecting to 171.67.108.200:80
12:45:50:WU01:FS01:Assigned to work server 140.163.4.231
12:45:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 140.163.4.231
12:45:50:WU01:FS01:Connecting to 140.163.4.231:8080
12:45:50:WU01:FS01:Downloading 4.83MiB
12:45:53:WU01:FS01:Download complete
12:45:53:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:480 clone:1 gen:130 core:0x17 unit:0x000000d3538b3db7532c8426bfe0e044
12:45:53:WU01:FS01:Starting
12:45:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Dells Bells/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 2752 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:45:53:WU01:FS01:Started FahCore on PID 2420
12:45:53:WU01:FS01:Core PID:636
12:45:53:WU01:FS01:FahCore 0x17 started
12:45:53:WU01:FS01:0x17:*********************** Log Started 2015-02-26T12:45:53Z ***********************
12:45:53:WU01:FS01:0x17:Project: 13001 (Run 480, Clone 1, Gen 130)
12:45:53:WU01:FS01:0x17:Unit: 0x000000d3538b3db7532c8426bfe0e044
12:45:53:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:45:53:WU01:FS01:0x17:Machine: 1
12:45:53:WU01:FS01:0x17:Reading tar file state.xml
12:45:54:WU01:FS01:0x17:Reading tar file system.xml
12:45:55:WU01:FS01:0x17:Reading tar file integrator.xml
12:45:55:WU01:FS01:0x17:Reading tar file core.xml
12:45:55:WU01:FS01:0x17:Digital signatures verified
12:45:55:WU01:FS01:0x17:Folding@home GPU core17
12:45:55:WU01:FS01:0x17:Version 0.0.52
12:49:19:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 450.859 with threshold of 5
12:49:19:WU01:FS01:0x17:Saving result file logfile_01.txt
12:49:19:WU01:FS01:0x17:Saving result file log.txt
12:49:19:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:49:19:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:49:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:480 clone:1 gen:130 core:0x17 unit:0x000000d3538b3db7532c8426bfe0e044
12:49:19:WU01:FS01:Uploading 2.24KiB to 140.163.4.231
12:49:19:WU01:FS01:Connecting to 140.163.4.231:8080
12:49:19:WU01:FS01:Upload complete
12:49:19:WU01:FS01:Server responded WORK_ACK (400)
12:49:19:WU01:FS01:Cleaning upI plan to just shut off these systems until I see some recognition from Stanford that they have FIXED this issue.
