Strange Error Messages
RMouse
Post by RMouse »
What is going on with my machine here? Can anyone help me fix this? It does not stop me from folding but something wrong seems to be going on behind the scenes.
Thanks!
*********************** Log Started 2015-02-12T01:19:16Z ***********************
01:19:16:************************* Folding@home Client *************************
01:19:16:      Website: http://folding.stanford.edu/
01:19:16:    Copyright: (c) 2009-2013 Stanford University
01:19:16:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:19:16:         Args: --open-web-control
01:19:16:       Config: C:/Users//AppData/Roaming/FAHClient/config.xml
01:19:16:******************************** Build ********************************
01:19:16:      Version: 7.3.6
01:19:16:         Date: Feb 18 2013
01:19:16:         Time: 15:25:17
01:19:16:      SVN Rev: 3923
01:19:16:       Branch: fah/trunk/client
01:19:16:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:19:16:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:19:16:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:19:16:     Platform: win32 XP
01:19:16:         Bits: 32
01:19:16:         Mode: Release
01:19:16:******************************* System ********************************
01:19:16:          CPU: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
01:19:16:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
01:19:16:         CPUs: 4
01:19:16:       Memory: 7.88GiB
01:19:16:  Free Memory: 3.91GiB
01:19:16:      Threads: WINDOWS_THREADS
01:19:16:  Has Battery: true
01:19:16:   On Battery: false
01:19:16:   UTC offset: 8
01:19:16:          PID: 6516
01:19:16:          CWD: C:/Users/tomribaudo/AppData/Roaming/FAHClient
01:19:16:           OS: Windows 7 Professional
01:19:16:      OS Arch: AMD64
01:19:16:         GPUs: 0
01:19:16:         CUDA: Not detected
01:19:16:Win32 Service: false
01:19:16:***********************************************************************
01:19:16:<config>
01:19:16:  <!-- Folding Slot Configuration -->
01:19:16:  <power v='full'/>
01:19:16:
01:19:16:  <!-- Network -->
01:19:16:  <proxy v=':8080'/>
01:19:16:
01:19:16:  <!-- Slot Control -->
01:19:16:  <pause-on-battery v='false'/>
01:19:16:
01:19:16:  <!-- User Information -->
01:19:16:  <passkey v='********************************'/>
01:19:16:  <user v='rattym'/>
01:19:16:
01:19:16:  <!-- Folding Slots -->
01:19:16:  <slot id='0' type='CPU'/>
01:19:16:</config>
01:19:16:Trying to access database...
01:19:16:Successfully acquired database lock
01:19:16:Enabled folding slot 00: READY cpu:4
01:19:16:WU01:FS00:Starting
01:19:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 6516 -checkpoint 15 -np 4
01:19:16:WU01:FS00:Started FahCore on PID 7472
01:19:16:WU01:FS00:Core PID:6604
01:19:16:WU01:FS00:FahCore 0xa4 started
01:19:17:WU01:FS00:0xa4:
01:19:17:WU01:FS00:0xa4:*------------------------------*
01:19:17:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
01:19:17:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:19:17:WU01:FS00:0xa4:Preparing to commence simulation
01:19:17:WU01:FS00:0xa4:- Looking at optimizations...
01:19:17:WU01:FS00:0xa4:- Files status OK
01:19:17:WU01:FS00:0xa4:- Expanded 118596 -> 268552 (decompressed 226.4 percent)
01:19:17:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=118596 data_size=268552, decompressed_data_size=268552 diff=0
01:19:17:WU01:FS00:0xa4:- Digital signature verified
01:19:17:WU01:FS00:0xa4:Project: 6393 (Run 76, Clone 6, Gen 21)
01:19:17:WU01:FS00:0xa4:Assembly optimizations on if available.
01:19:17:WU01:FS00:0xa4:Entering M.D.
01:19:22:WU01:FS00:0xa4:Using Gromacs checkpoints
01:19:22:WU01:FS00:0xa4:Mapping NT from 4 to 4
01:19:23:WU01:FS00:0xa4:Resuming from checkpoint
01:19:23:WU01:FS00:0xa4:Verified 01/wudata_01.log
01:19:23:WU01:FS00:0xa4:Verified 01/wudata_01.trr
01:19:23:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
01:19:23:WU01:FS00:0xa4:Verified 01/wudata_01.edr
01:19:23:WU01:FS00:0xa4:Completed 809890 out of 5000000 steps  (16%)
01:19:27:WARNING:Exception: 3:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:27:WARNING:Exception: 4:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:27:WARNING:Exception: 5:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:27:WARNING:Exception: 6:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:27:9:127.0.0.1:New Web connection
01:19:27:WARNING:Exception: 7:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:27:WARNING:Exception: 8:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:28:WARNING:Exception: 11:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:28:WARNING:Exception: 12:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:28:WARNING:Exception: 13:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:28:WARNING:Exception: 14:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:28:WARNING:Exception: 15:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
01:19:29:WARNING:Exception: 16:127.0.0.1: Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:19:29:WARNING:Exception: 17:127.0.0.1: Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:26:15:WU01:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
01:33:51:WU01:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
01:42:16:WU01:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
01:53:53:WU01:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
02:05:46:WU01:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
ChristianVirtual
Re: Strange Error Messages
Post by ChristianVirtual »
Sound like some trouble with some security software blocking local communication. Looks your FAHControl run on the same computer. 127.0.0.1 as IP address indicate that. Do you some local port scan at the same time ? Any other software using port 36330 on that system (which is also used by FAHControl).
You could try to configure FAHControl to use a real network address /name of that computer to cross check.
RMouse
Post by RMouse »
ChristianVirtual wrote:Sound like some trouble with some security software blocking local communication. Looks your FAHControl run on the same computer. 127.0.0.1 as IP address indicate that. Do you some local port scan at the same time ? Any other software using port 36330 on that system (which is also used by FAHControl).
I dont understand your answer so I'll have to learn to live with this. As long as I can keep on folding I am OK.
ChristianVirtual
No problem, let's start differently: please tell us more about your system: Any information about what security applications you might run ?
davidcoton
Post by davidcoton »
It might be worth upgrading to the latest client (7.4.4). IIRC the upgrade is painless and it did solve some of the comms problems.
