Missing credit for 3 x P8106?
-alias-
Post by -alias- »
I uploaded earlier today three P8106 WUS, but can not see that I am credited for the points?
The logs are provided below:
[February 2 08:43:43 UTC]
[08:43:05] Completed 250000 out of 250000 steps  (100%)
[08:43:17] DynamicWrapper: Finished Work Unit: sleep=10000
[08:43:27]
[08:43:27] Finished Work Unit:
[08:43:27] - Reading up to 64206000 from "work/wudata_01.trr": Read 64206000
[08:43:27] trr file hash check passed.
[08:43:27] - Reading up to 31606788 from "work/wudata_01.xtc": Read 31606788
[08:43:27] xtc file hash check passed.
[08:43:27] edr file hash check passed.
[08:43:27] logfile size: 196790
[08:43:27] Leaving Run
[08:43:28] - Writing 96170454 bytes of core data to disk...
[08:43:42] Done: 96169942 -> 91102758 (compressed to 5.4 percent)
[08:43:42]   ... Done.
[08:43:43] - Shutting down core
[08:43:43]
[08:43:43] Folding@home Core Shutdown: FINISHED_UNIT
[08:43:43] CoreStatus = 64 (100)
[08:43:43] Unit 1 finished with 99 percent of time to deadline remaining.
[08:43:43] Updated performance fraction: 0.991777
[08:43:43] Sending work to server
[08:43:43] Project: 8106 (Run 0, Clone 31, Gen 0)
[08:43:43] + Attempting to send results [February 2 08:43:43 UTC]
[08:43:43] - Reading file work/wuresults_01.dat from core
[08:43:43]   (Read 91103270 bytes from disk)
[08:43:43] Connecting to http://128.143.231.201:8080/
[08:45:50] Posted data.
[08:45:50] Initial: 0000; - Uploaded at ~700 kB/s
[08:45:50] - Averaged speed for that direction ~700 kB/s
[08:45:50] + Results successfully sent
[08:45:50] Thank you for your contribution to Folding@Home.
[08:45:50] + Number of Units Completed: 444
[February 2 08:44:17 UTC]
[08:43:21] Completed 250000 out of 250000 steps  (100%)
[08:43:33] DynamicWrapper: Finished Work Unit: sleep=10000
[08:43:43]
[08:43:43] Finished Work Unit:
[08:43:43] - Reading up to 64206000 from "work/wudata_01.trr": Read 64206000
[08:43:43] trr file hash check passed.
[08:43:43] - Reading up to 31553096 from "work/wudata_01.xtc": Read 31553096
[08:43:44] xtc file hash check passed.
[08:43:44] edr file hash check passed.
[08:43:44] logfile size: 196975
[08:43:44] Leaving Run
[08:43:46] - Writing 96116947 bytes of core data to disk...
[08:44:00] Done: 96116435 -> 91047039 (compressed to 5.3 percent)
[08:44:00]   ... Done.
[08:44:16] - Shutting down core
[08:44:16]
[08:44:16] Folding@home Core Shutdown: FINISHED_UNIT
[08:44:17] CoreStatus = 64 (100)
[08:44:17] Unit 1 finished with 99 percent of time to deadline remaining.
[08:44:17] Updated performance fraction: 0.991629
[08:44:17] Sending work to server
[08:44:17] Project: 8106 (Run 0, Clone 30, Gen 0)
[08:44:17] + Attempting to send results [February 2 08:44:17 UTC]
[08:44:17] - Reading file work/wuresults_01.dat from core
[08:44:17]   (Read 91047551 bytes from disk)
[08:44:17] Connecting to http://128.143.231.201:8080/
[08:46:32] Posted data.
[08:46:32] Initial: 0000; - Uploaded at ~658 kB/s
[08:46:32] - Averaged speed for that direction ~658 kB/s
[08:46:32] + Results successfully sent
[08:46:32] Thank you for your contribution to Folding@Home.
[08:46:32] + Number of Units Completed: 1500
[February 2 11:29:49 UTC]
[11:28:55] Completed 250000 out of 250000 steps  (100%)
[11:29:06] DynamicWrapper: Finished Work Unit: sleep=10000
[11:29:16]
[11:29:16] Finished Work Unit:
[11:29:16] - Reading up to 64206000 from "work/wudata_01.trr": Read 64206000
[11:29:17] trr file hash check passed.
[11:29:17] - Reading up to 31553404 from "work/wudata_01.xtc": Read 31553404
[11:29:17] xtc file hash check passed.
[11:29:17] edr file hash check passed.
[11:29:17] logfile size: 195781
[11:29:17] Leaving Run
[11:29:20] - Writing 96116061 bytes of core data to disk...
[11:29:48] Done: 96115549 -> 91047053 (compressed to 5.3 percent)
[11:29:49]   ... Done.
[11:29:49] - Shutting down core
[11:29:49]
[11:29:49] Folding@home Core Shutdown: FINISHED_UNIT
[11:29:49] CoreStatus = 64 (100)
[11:29:49] Unit 1 finished with 99 percent of time to deadline remaining.
[11:29:49] Updated performance fraction: 0.987616
[11:29:49] Sending work to server
[11:29:49] Project: 8106 (Run 0, Clone 1, Gen 0)
[11:29:49] + Attempting to send results [February 2 11:29:49 UTC]
[11:29:49] - Reading file work/wuresults_01.dat from core
[11:29:50]   (Read 91047565 bytes from disk)
[11:29:50] Connecting to http://128.143.231.201:8080/
[12:04:51] Posted data.
[12:04:51] Initial: 0000; - Uploaded at ~42 kB/s
[12:04:51] - Averaged speed for that direction ~42 kB/s
[12:04:51] + Results successfully sent
[12:04:51] Thank you for your contribution to Folding@Home.
[12:04:51] + Number of Units Completed: 838
bollix47
Re: Missing credit for 3 x P8106?
Post by bollix47 »
Project 8106 has only been receiving base credit so far:
viewtopic.php?f=66&t=27322&p=273520#p273520
-alias-
Post by -alias- »
Is this correct, seem to remember that this was released to full FAH, but possible I do not remember correctly?
bollix47
Post by bollix47 »
Yes, 8106 was released straight to full fah as stated in the first post at that link. Unfortunately it did not go thru beta testing and a problem like this that would have been caught there has slipped thru. PG is aware of the problem and are looking into it.
-alias-
Post by -alias- »
Can I understand it so that these will be credited for qrb-ponts later then?
-alias- wrote:Can I understand it so that these will be credited for qrb-ponts later then?
Yes. See Kasson's most recent post in the beta topic. (See link above.) I have every reason to believe that what he said there applies to you, too.
And there's no prediction about when the Stats team will re-process the credits for the past WUs, but they will. It's a manual operation that requires a lot of checking and rechecking.
-alias-
Post by -alias- »
Thanks.
And here comes another two pieces finished folded P8106 WUS:
[February 2 17:27:04 UTC]
[17:26:06] Completed 250000 out of 250000 steps  (100%)
[17:26:18] DynamicWrapper: Finished Work Unit: sleep=10000
[17:26:28]
[17:26:28] Finished Work Unit:
[17:26:28] - Reading up to 64206000 from "work/wudata_02.trr": Read 64206000
[17:26:28] trr file hash check passed.
[17:26:28] - Reading up to 31553188 from "work/wudata_02.xtc": Read 31553188
[17:26:29] xtc file hash check passed.
[17:26:29] edr file hash check passed.
[17:26:29] logfile size: 196992
[17:26:29] Leaving Run
[17:26:32] - Writing 96117056 bytes of core data to disk...
[17:26:46] Done: 96116544 -> 91361573 (compressed to 5.6 percent)
[17:26:46]   ... Done.
[17:27:02] - Shutting down core
[17:27:02]
[17:27:02] Folding@home Core Shutdown: FINISHED_UNIT
[17:27:04] CoreStatus = 64 (100)
[17:27:04] Unit 2 finished with 99 percent of time to deadline remaining.
[17:27:04] Updated performance fraction: 0.991615
[17:27:04] Sending work to server
[17:27:04] Project: 8106 (Run 0, Clone 30, Gen 1)
[17:27:04] + Attempting to send results [February 2 17:27:04 UTC]
[17:27:04] - Reading file work/wuresults_02.dat from core
[17:27:04]   (Read 91362085 bytes from disk)
[17:27:04] Connecting to http://128.143.231.201:8080/
[17:28:28] Posted data.
[17:28:28] Initial: 0000; - Uploaded at ~1062 kB/s
[17:28:28] - Averaged speed for that direction ~860 kB/s
[17:28:28] + Results successfully sent
[17:28:28] Thank you for your contribution to Folding@Home.
[17:28:28] + Number of Units Completed: 1501
[February 2 17:16:21 UTC]
[17:15:41] Completed 250000 out of 250000 steps  (100%)
[17:15:53] DynamicWrapper: Finished Work Unit: sleep=10000
[17:16:03]
[17:16:03] Finished Work Unit:
[17:16:03] - Reading up to 64206000 from "work/wudata_02.trr": Read 64206000
[17:16:04] trr file hash check passed.
[17:16:04] - Reading up to 31555264 from "work/wudata_02.xtc": Read 31555264
[17:16:04] xtc file hash check passed.
[17:16:04] edr file hash check passed.
[17:16:04] logfile size: 196806
[17:16:04] Leaving Run
[17:16:05] - Writing 96118946 bytes of core data to disk...
[17:16:20] Done: 96118434 -> 91362672 (compressed to 5.6 percent)
[17:16:20]   ... Done.
[17:16:20] - Shutting down core
[17:16:20]
[17:16:20] Folding@home Core Shutdown: FINISHED_UNIT
[17:16:21] CoreStatus = 64 (100)
[17:16:21] Unit 2 finished with 99 percent of time to deadline remaining.
[17:16:21] Updated performance fraction: 0.991770
[17:16:21] Sending work to server
[17:16:21] Project: 8106 (Run 0, Clone 31, Gen 1)
[17:16:21] + Attempting to send results [February 2 17:16:21 UTC]
[17:16:21] - Reading file work/wuresults_02.dat from core
[17:16:21]   (Read 91363184 bytes from disk)
[17:16:21] Connecting to http://128.143.231.201:8080/
[17:17:46] Posted data.
[17:17:46] Initial: 0000; - Uploaded at ~1049 kB/s
[17:17:46] - Averaged speed for that direction ~875 kB/s
[17:17:46] + Results successfully sent
[17:17:46] Thank you for your contribution to Folding@Home.
[17:17:46] + Number of Units Completed: 445
It's not necessary to list other WUs on the forum. Kasson said he has isolated the ones that need to be re-credited, and (if historic patterns are follwed) they'll all appear simultaneously. If something is missing after the points are updated for other WUs, then we need to know about it.
-alias-
Post by -alias- »
Thank you,
your point is understood!
johnerz
Hardware configuration: Intel 2600K @ stock
EVGA GTX 970 FTW+ @ stock
8gb Samsung green @ 1.55v 2040 9,10,10,1T
Asus P67 Sabertooth bios version 3209
Corsair hx 1000 psu
WD Black 500 GB
Win 7 64, updated,Microsoft Security Essentials - updated daily
SupermicroH8QGi+-F, 4 X AMD 6168 @ 1.9 no OC
Corsair HX 850 PSU 16 x 2GB HyperX 1600 ram
Ubuntu 12.04, using the musky/tear mods
Updated 03 Feb 2015
Post by johnerz »
I take it that from bruce's reply all the 8106 wu's will be reviewed, as there will be a considerable number of us waiting for his to be resolved?
johnerz
Intel 2600K @ stock
EVGA 670 FTW @ stock
12GB 1600
Corsair hx 1000 psu
WD Black 500 GB
Win 7 64, updated
Updated 4 Dec 2012
Nathan_P
Not currently folding
Post by Nathan_P »
They are still not being credited QRB points, I've had 4 go through in the last 18 hrs and base points only. Interestingly though my slower 32 thread rig is getting full points. My 2 48 thread rigs are only getting base. Is there a glitch somewhere else?
johnerz
Corsair hx 1000 psu
WD Black 500 GB
Updated 03 Feb 2015
Post by johnerz »
That's interesting Nathan, as its my 48 thread rig that's is getting base, you may well be onto something there
In this thread:
Yesterday about 21 hours ago Dr Kasson said
"The QRB is fixed going forward. All affected returns with no QRB have been collected and forwarded to the stats team."
This is not the case as work units submitted after that time are having the same issues :(
These are my 3 completed WU, I can only pick up the info from HFM as I'm away until the morning:
8106 R0 C9 G0 Completed 02/Feb/2015 08:40
8106 R0 C62 G0 Completed 02/Feb/2015 22:34
8106 R0 C39 G0 Completed 03/Feb/2015 12:25 submitted after the "fix" was announced
All on 48 threads HFM shows completed units.
Is there still an outstanding issue here?
johnerz
Intel 2600K @ stock
12GB 1600
Corsair hx 1000 psu
WD Black 500 GB
Win 7 64, updated
Updated 4 Dec 2012
-alias-
Post by -alias- »
I have 2 x 64 thread and 1 x 48 thread, all of them only base points so far!
Grandpa_01
Post by Grandpa_01 »
I do not think core count has anything to do with it, 6 of my boxen are 64core and 1 is 48 some have received bonus points others have just received base credit.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Buck Nasty
Post by Buck Nasty »
Grandpa_01 wrote:I do not think core count has anything to do with it, 6 of my boxen are 64core and 1 is 48 some have received bonus points others have just received base credit.
Grandpa, on the WU's that have received QRB....are the points awarded consistent with what HFM was projecting? On my 1st P8106, HFM was projecting 830K PPD with a WU total of 361K points. I have yet to see a QRB that high with the current version of "many cores".
