OpenCL
maxorsson
OpenCL
Post by maxorsson »
Hello,
AMD Catalyst's version 12.1 have a built-in OpenCL but latest versions doesn't include it. So my question is where to get OpenCL libraries/stuff and how to get them work with newer Catalyst versions. I found an OpenCL.msi package and installed it but GPU-Z shows no OpenCL computing enabled (with Catalyst ver. 12.1 it is marked as working). Thanks.
ATI Radeon Sapphire HD6790 / WinXP sp3
Re: OpenCL
As I recall, AMD dropped further support for OpenCL past version 12.1 for drivers installed on Win XP. To get support for newer drivers you would have to upgrade your OS to at least Vista, Windows 7 would probably be the better minimum to choose if you stay with Windows. Other paths to getting OpenCL working on XP with newer drivers are not going to work.
