Hello,
I know this is trivial for my first post but i was wondering why my user stats are wrong on the website but they are correct on my machine?(sorry if I am posting in the wrong thread)
http://www.meandmyplace.net/brokenheart.html
There are screenshots to show what i'm talking about,and why does my "active processor within the last 7 days" show to be zero?I havent turned this machine off in a year.
Like I said it is trivial.I think the distributed computing idea is a great one and I would still donate my spare cpu and bandwidth even if my stat said zero WU.But I am curious as to the difference.
Thanks
User Stats Wrong?
Re: User Stats Wrong?
hi pipedreams, i'm not sure myself when things gets updated as far as stats, possibly a delay or maintenance problem, but i'll forward your post to see if anyone has an answer...
cheers,
nick
cheers,
nick
Hello pipedreams,
I checked the stats for user fred007 which shows that you have one machine folding, a Pentium 4 running Win XP,
and that the last unit it returned was a p4543 run 85 clone 89 gen 0 on 2008-05-22 12:05:46 for 84.69 points (an early end?)
The server time 12:05:46 is Pacific time.
Does this sound about right? If it is, then the "0 processors in 7 days" should read "1" again. (Yep, just checked Stanford and it does)
Did you processor return a finished work unit within the 7 days before you took that screenshot? If it usually takes more than 7 days to finish,
then it's possible that the count would be 0.
Odd, though, that whatever unit you got before the p4543 didn't show up...
Can you post your queue? Thanks!
PipeDreams
Thanks both for the reply
Sorry it has taken me so long to get back.Yes thats what i think happened,the work unit was a time consuming one and I noticed my power flickered last week and FAH didnt restart with my machine so it was probably longer than a week.
http://www.meandmyplace.net/brokenheart.html There is 2 days ago.
I would be more than happy to post my que.where is it located? c/program files/FAH/? Or an easier way to get it?
I wont b able to check this forum for 2 more days probably.Thanks alot for the help/info.
Jeff
Jeff
PipeDreams
Ok I'm finished traveling for a few weeks.
Is this the queue info you referred to SUSATO ?
Thanks.
Thanks.
