Problem with the server 171.64.65.105 (core_15)?
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
I have two WUs successfully returned, but on EOC statistics are not visible. Client Version 6.41r2.
[15:55:49] Sending work to server
[15:55:49] Project: 7620 (Run 23, Clone 0, Gen 341)
[15:55:49] + Attempting to send results [January 20 15:55:49 UTC]
[15:55:49] - Reading file work/wuresults_03.dat from core
[15:55:49]   (Read 816027 bytes from disk)
[15:55:49] Gpu type=3 species=20.
[15:55:49] Connecting to http://171.64.65.105:8080/
[15:55:52] Posted data.
[15:55:52] Initial: 0000; - Uploaded at ~265 kB/s
[15:55:52] - Averaged speed for that direction ~307 kB/s
[15:55:52] + Results successfully sent
[15:55:52] Thank you for your contribution to Folding@Home.
[15:55:52] + Number of Units Completed: 432
[06:49:48] Sending work to server
[06:49:48] Project: 7626 (Run 117, Clone 0, Gen 400)
[06:49:48] + Attempting to send results [January 21 06:49:48 UTC]
[06:49:48] - Reading file work/wuresults_04.dat from core
[06:49:48]   (Read 826597 bytes from disk)
[06:49:48] Gpu type=3 species=20.
[06:49:48] Connecting to http://171.64.65.105:8080/
[06:49:51] Posted data.
[06:49:51] Initial: 0000; - Uploaded at ~269 kB/s
[06:49:51] - Averaged speed for that direction ~299 kB/s
[06:49:51] + Results successfully sent
[06:49:51] Thank you for your contribution to Folding@Home.
[06:49:51] + Number of Units Completed: 433
Re: Problem with the server 171.64.65.105 (core_15)?
Looking at the Server Status page it does appear that a backlog of results are waiting to be entered into the stats database from that WS. From the log it started sometime yesterday. I will send notification to the appropriate persons.
artoar_11
Post by artoar_11 »
Thank you Joe_H.
jadeshi
Pande Group Member
Post by jadeshi »
Currently looking into this. Will keep you guys posted.
Librarian
0x15 core units not posting
Post by Librarian »
Mod edit: merged with existing topic on this problem
Hello,
I've been noticing in the past 36hr that a majority of my 0x15 core units are finishing, stating that they are uploading and finish uploading. But then never show up on the stats either as WU or points. I'm not sure if this is just me. It is only 0x15 core units as well. All 0x17, 0x18, 0xa4 units I've been getting are running/posting fine. The two most recent projects that didn't show up are below.
project:7620 run:144 clone:0 gen:298 core:0x15
project:7626 run:224 clone:0 gen:399 core:0x15
05:34:51:WU02:FS01:0x15:Completed  40000000 out of 40000000 steps (100%).
05:34:51:WU02:FS01:0x15:Finished fah_main status=0
05:34:51:WU02:FS01:0x15:Successful run
05:34:51:WU02:FS01:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
05:34:59:WU01:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
05:35:01:WU02:FS01:0x15:Reserved 768656 bytes for xtc file; Cosm status=0
05:35:01:WU02:FS01:0x15:Allocated 768656 bytes for xtc file
05:35:01:WU02:FS01:0x15:- Reading up to 768656 from "02/wudata_01.xtc": Read 768656
05:35:01:WU02:FS01:0x15:Read 768656 bytes from xtc file; available packet space=785661808
05:35:01:WU02:FS01:0x15:xtc file hash check passed.
05:35:01:WU02:FS01:0x15:Reserved 48264 48264 785661808 bytes for arc file=<02/wudata_01.trr> Cosm status=0
05:35:01:WU02:FS01:0x15:Allocated 48264 bytes for arc file
05:35:01:WU02:FS01:0x15:- Reading up to 48264 from "02/wudata_01.trr": Read 48264
05:35:01:WU02:FS01:0x15:Read 48264 bytes from arc file; available packet space=785613544
05:35:01:WU02:FS01:0x15:trr file hash check passed.
05:35:01:WU02:FS01:0x15:Allocated 544 bytes for edr file
05:35:01:WU02:FS01:0x15:Read bedfile
05:35:01:WU02:FS01:0x15:edr file hash check passed.
05:35:01:WU02:FS01:0x15:Allocated 36749 bytes for logfile
05:35:01:WU02:FS01:0x15:Read logfile
05:35:01:WU02:FS01:0x15:GuardedRun: success in DynamicWrapper
05:35:01:WU02:FS01:0x15:GuardedRun: done
05:35:01:WU02:FS01:0x15:Run: GuardedRun completed.
05:35:01:WU02:FS01:0x15:+ Opened results file
05:35:01:WU02:FS01:0x15:- Writing 854725 bytes of core data to disk...
05:35:01:WU02:FS01:0x15:Done: 854213 -> 826053 (compressed to 96.7 percent)
05:35:01:WU02:FS01:0x15:  ... Done.
05:35:01:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
05:35:01:WU02:FS01:0x15:Shutting down core
05:35:01:WU02:FS01:0x15:Folding@home Core Shutdown: FINISHED_UNIT
05:35:01:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:35:01:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:7626 run:224 clone:0 gen:399 core:0x15 unit:0x0000024a664f2dd14fe61b08e7150cb8
05:35:01:WU02:FS01:Uploading 807.19KiB to 171.64.65.105
05:35:01:WU02:FS01:Connecting to 171.64.65.105:8080
05:35:01:WU00:FS01:Starting
05:35:01:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/adam/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 1264 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
05:35:01:WU00:FS01:Started FahCore on PID 4844
05:35:01:WU00:FS01:Core PID:6628
05:35:01:WU00:FS01:FahCore 0x17 started
05:35:02:WU00:FS01:0x17:*********************** Log Started 2015-01-21T05:35:02Z ***********************
05:35:02:WU00:FS01:0x17:Project: 9201 (Run 983, Clone 2, Gen 176)
05:35:02:WU00:FS01:0x17:Unit: 0x000000ff6652edc45399fcb15e88290e
05:35:02:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
05:35:02:WU00:FS01:0x17:Machine: 1
05:35:02:WU00:FS01:0x17:Reading tar file state.xml
05:35:02:WU00:FS01:0x17:Reading tar file system.xml
05:35:02:WU00:FS01:0x17:Reading tar file integrator.xml
05:35:02:WU00:FS01:0x17:Reading tar file core.xml
05:35:02:WU00:FS01:0x17:Digital signatures verified
05:35:02:WU00:FS01:0x17:Folding@home GPU core17
05:35:02:WU00:FS01:0x17:Version 0.0.52
05:35:07:WU02:FS01:Upload 95.14%
05:35:08:WU02:FS01:Upload complete
05:35:08:WU02:FS01:Server responded WORK_ACK (400)
05:35:08:WU02:FS01:Final credit estimate, 14093.00 points
05:35:08:WU02:FS01:Cleaning up
Just an example of what the log is showing me. Any help is appreciated.
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Post by Napoleon »
Another uncredited WU - Project: 7627 (Run 287, Clone 0, Gen 176). I'm running client v6.41 to make sure that my lowly GT430 receives only core_15 work.
EDIT: Credited now.
jadeshi
Pande Group Member
Post by jadeshi »
This should be resolved now. There were some communication issues between the stats and 171.64.65.105 servers but this has now been fixed. Let me know if anything else comes up.
artoar_11
Post by artoar_11 »
Thank you jadeshi. I received the credit for the missing WUs :D
Schmicki
Post by Schmicki »
The same here, I also received the credit for the missing WUs.
Thank you Jadeshi.
SwingOp3
Post by SwingOp3 »
Missing wu credits received as well.
Thanks
