Problems with new GTX 980
Nick200
Post by Nick200 »
Hi
The GTX 980 that I have just installed to improve my folding output is giving a series of error messages - it fails to download and then start folding work units and then craps out giving a Failed error status.
If I reboot, the cycle just repeats.
I attach the log file from the latest run.
*********************** Log Started 2015-01-15T23:30:01Z ***********************
23:30:01:************************* Folding@home Client *************************
23:30:01:      Website: http://folding.stanford.edu/
23:30:01:    Copyright: (c) 2009-2014 Stanford University
23:30:01:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:30:01:         Args:
23:30:01:       Config: C:/ProgramData/FAHClient/config.xml
23:30:01:******************************** Build ********************************
23:30:01:      Version: 7.4.4
23:30:01:         Date: Mar 4 2014
23:30:01:         Time: 20:26:54
23:30:01:      SVN Rev: 4130
23:30:01:       Branch: fah/trunk/client
23:30:01:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:30:01:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:30:01:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:30:01:     Platform: win32 XP
23:30:01:         Bits: 32
23:30:01:         Mode: Release
23:30:01:******************************* System ********************************
23:30:01:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
23:30:01:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:30:01:         CPUs: 8
23:30:01:       Memory: 15.89GiB
23:30:01:  Free Memory: 12.06GiB
23:30:01:      Threads: WINDOWS_THREADS
23:30:01:   OS Version: 6.2
23:30:01:  Has Battery: false
23:30:01:   On Battery: false
23:30:01:   UTC Offset: 13
23:30:01:          PID: 3792
23:30:01:          CWD: C:/ProgramData/FAHClient
23:30:01:           OS: Windows 8.1 Pro with Media Center
23:30:01:      OS Arch: AMD64
23:30:01:         GPUs: 1
23:30:01:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
23:30:01:         CUDA: Not detected
23:30:01:Win32 Service: false
23:30:01:***********************************************************************
23:30:01:<config>
23:30:01:  <!-- Folding Slot Configuration -->
23:30:01:  <client-type v='advanced'/>
23:30:01:
23:30:01:  <!-- Network -->
23:30:01:  <proxy v=':8080'/>
23:30:01:
23:30:01:  <!-- Slot Control -->
23:30:01:  <power v='full'/>
23:30:01:
23:30:01:  <!-- User Information -->
23:30:01:  <passkey v='********************************'/>
23:30:01:  <team v='142900'/>
23:30:01:  <user v='Montague-Cripps'/>
23:30:01:
23:30:01:  <!-- Folding Slots -->
23:30:01:  <slot id='1' type='CPU'>
23:30:01:    <paused v='true'/>
23:30:01:  </slot>
23:30:01:  <slot id='0' type='GPU'/>
23:30:01:</config>
23:30:01:Trying to access database...
23:30:01:Successfully acquired database lock
23:30:01:Enabled folding slot 01: PAUSED cpu:7 (by user)
23:30:01:Enabled folding slot 00: READY gpu:0:GM204 [GeForce GTX 980]
23:30:01:WU00:FS00:Starting
23:30:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:30:01:WU00:FS00:Started FahCore on PID 6024
23:30:01:WU00:FS00:Core PID:416
23:30:01:WU00:FS00:FahCore 0x15 started
23:30:01:WU00:FS00:0x15:
23:30:01:WU00:FS00:0x15:*------------------------------*
23:30:01:WU00:FS00:0x15:Folding@Home GPU Core
23:30:01:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:30:01:WU00:FS00:0x15:Build host             AmoebaRemote
23:30:01:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:30:01:WU00:FS00:0x15:Core                   15
23:30:01:WU00:FS00:0x15:Window's signal control handler registered.
23:30:01:WU00:FS00:0x15:Preparing to commence simulation
23:30:01:WU00:FS00:0x15:- Looking at optimizations...
23:30:01:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:30:01:WU00:FS00:0x15:- Created dyn
23:30:01:WU00:FS00:0x15:- Files status OK
23:30:01:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:30:01:WU00:FS00:0x15:- Expanded 125179 -> 501826 (decompressed 400.8 percent)
23:30:01:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=125179 data_size=501826, decompressed_data_size=501826 diff=0
23:30:01:WU00:FS00:0x15:- Digital signature verified
23:30:01:WU00:FS00:0x15:Project: 7621 (Run 818, Clone 0, Gen 346)
23:30:01:WU00:FS00:0x15:Assembly optimizations on if available.
23:30:01:WU00:FS00:0x15:Entering M.D.
23:30:03:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  1453363964 1464544015 1992798151 1833775854 2200758379
23:30:03:WU00:FS00:0x15:GPU device id=0
23:30:03:WU00:FS00:0x15:Working on Protein
23:30:03:WU00:FS00:0x15:Client config unavailable.
23:30:03:WU00:FS00:0x15:Finished fah_main status=59
23:30:03:WU00:FS00:0x15:mdrun_gpu returned 59
23:30:03:WU00:FS00:0x15:GPU memtest failure
23:30:03:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:30:03:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:30:04:WU00:FS00:Starting
23:30:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:30:04:WU00:FS00:Started FahCore on PID 2272
23:30:04:WU00:FS00:Core PID:5884
23:30:04:WU00:FS00:FahCore 0x15 started
23:30:04:WU00:FS00:0x15:
23:30:04:WU00:FS00:0x15:*------------------------------*
23:30:04:WU00:FS00:0x15:Folding@Home GPU Core
23:30:04:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:30:04:WU00:FS00:0x15:Build host             AmoebaRemote
23:30:04:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:30:04:WU00:FS00:0x15:Core                   15
23:30:04:WU00:FS00:0x15:Window's signal control handler registered.
23:30:04:WU00:FS00:0x15:Preparing to commence simulation
23:30:04:WU00:FS00:0x15:- Looking at optimizations...
23:30:04:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:30:04:WU00:FS00:0x15:- Created dyn
23:30:04:WU00:FS00:0x15:- Files status OK
23:30:04:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:30:04:WU00:FS00:0x15:- Expanded 125179 -> 501826 (decompressed 400.8 percent)
23:30:04:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=125179 data_size=501826, decompressed_data_size=501826 diff=0
23:30:04:WU00:FS00:0x15:- Digital signature verified
23:30:04:WU00:FS00:0x15:Project: 7621 (Run 818, Clone 0, Gen 346)
23:30:04:WU00:FS00:0x15:Assembly optimizations on if available.
23:30:04:WU00:FS00:0x15:Entering M.D.
23:30:06:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  1453363964 1464544015 1992798151 1833775854 2200758379
23:30:06:WU00:FS00:0x15:GPU device id=0
23:30:06:WU00:FS00:0x15:Working on Protein
23:30:06:WU00:FS00:0x15:Client config unavailable.
23:30:06:WU00:FS00:0x15:Finished fah_main status=59
23:30:06:WU00:FS00:0x15:mdrun_gpu returned 59
23:30:06:WU00:FS00:0x15:GPU memtest failure
23:30:06:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:30:06:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:30:18:FS01:Unpaused
23:30:18:WU01:FS01:Starting
23:30:18:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -np 7
23:30:18:WU01:FS01:Started FahCore on PID 1360
23:30:18:WU01:FS01:Core PID:6996
23:30:18:WU01:FS01:FahCore 0xa3 started
23:30:19:WU01:FS01:0xa3:
23:30:19:WU01:FS01:0xa3:*------------------------------*
23:30:19:WU01:FS01:0xa3:Folding@Home Gromacs SMP Core
23:30:19:WU01:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
23:30:19:WU01:FS01:0xa3:Preparing to commence simulation
23:30:19:WU01:FS01:0xa3:- Looking at optimizations...
23:30:19:WU01:FS01:0xa3:- Files status OK
23:30:19:WU01:FS01:0xa3:- Expanded 3552200 -> 3880552 (decompressed 109.2 percent)
23:30:19:WU01:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3552200 data_size=3880552, decompressed_data_size=3880552 diff=0
23:30:19:WU01:FS01:0xa3:- Digital signature verified
23:30:19:WU01:FS01:0xa3:Project: 7505 (Run 0, Clone 4, Gen 414)
23:30:19:WU01:FS01:0xa3:Assembly optimizations on if available.
23:30:19:WU01:FS01:0xa3:Entering M.D.
23:30:25:WU01:FS01:0xa3:Using Gromacs checkpoints
23:30:25:WU01:FS01:0xa3:Mapping NT from 7 to 7
23:30:25:WU01:FS01:0xa3:Resuming from checkpoint
23:30:25:WU01:FS01:0xa3:Verified 01/wudata_01.log
23:30:25:WU01:FS01:0xa3:Verified 01/wudata_01.trr
23:30:25:WU01:FS01:0xa3:Verified 01/wudata_01.xtc
23:30:25:WU01:FS01:0xa3:Verified 01/wudata_01.edr
23:30:25:WU01:FS01:0xa3:Completed 505350 out of 1000000 steps  (50%)
23:31:02:Removing old file 'configs/config-20141228-230831.xml'
23:31:02:Saving configuration to config.xml
23:31:02:<config>
23:31:02:  <!-- Folding Slot Configuration -->
23:31:02:  <client-type v='advanced'/>
23:31:02:
23:31:02:  <!-- Network -->
23:31:02:  <proxy v=':8080'/>
23:31:02:
23:31:02:  <!-- Slot Control -->
23:31:02:  <power v='full'/>
23:31:02:
23:31:02:  <!-- User Information -->
23:31:02:  <passkey v='********************************'/>
23:31:02:  <team v='142900'/>
23:31:02:  <user v='Montague-Cripps'/>
23:31:02:
23:31:02:  <!-- Folding Slots -->
23:31:02:  <slot id='1' type='CPU'/>
23:31:02:  <slot id='0' type='GPU'/>
23:31:02:</config>
23:31:04:WU00:FS00:Starting
23:31:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:04:WU00:FS00:Started FahCore on PID 3960
23:31:04:WU00:FS00:Core PID:456
23:31:04:WU00:FS00:FahCore 0x15 started
23:31:04:WU00:FS00:0x15:
23:31:04:WU00:FS00:0x15:*------------------------------*
23:31:04:WU00:FS00:0x15:Folding@Home GPU Core
23:31:04:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:31:04:WU00:FS00:0x15:Build host             AmoebaRemote
23:31:04:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:31:04:WU00:FS00:0x15:Core                   15
23:31:04:WU00:FS00:0x15:Window's signal control handler registered.
23:31:04:WU00:FS00:0x15:Preparing to commence simulation
23:31:04:WU00:FS00:0x15:- Looking at optimizations...
23:31:04:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:31:04:WU00:FS00:0x15:- Created dyn
23:31:04:WU00:FS00:0x15:- Files status OK
23:31:04:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:31:04:WU00:FS00:0x15:- Expanded 125179 -> 501826 (decompressed 400.8 percent)
23:31:04:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=125179 data_size=501826, decompressed_data_size=501826 diff=0
23:31:04:WU00:FS00:0x15:- Digital signature verified
23:31:04:WU00:FS00:0x15:Project: 7621 (Run 818, Clone 0, Gen 346)
23:31:04:WU00:FS00:0x15:Assembly optimizations on if available.
23:31:04:WU00:FS00:0x15:Entering M.D.
23:31:06:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  1453363964 1464544015 1992798151 1833775854 2200758379
23:31:06:WU00:FS00:0x15:GPU device id=0
23:31:06:WU00:FS00:0x15:Working on Protein
23:31:06:WU00:FS00:0x15:Client config unavailable.
23:31:06:WU00:FS00:0x15:Finished fah_main status=59
23:31:06:WU00:FS00:0x15:mdrun_gpu returned 59
23:31:06:WU00:FS00:0x15:GPU memtest failure
23:31:06:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:31:06:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:31:06:WARNING:WU00:FS00:Too many errors, failing
23:31:06:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:7621 run:818 clone:0 gen:346 core:0x15 unit:0x0000019e664f2dd14e430944da2c27ae
23:31:07:WU00:FS00:Connecting to 171.64.65.105:8080
23:31:07:WU02:FS00:Connecting to 171.67.108.200:80
23:31:07:WU00:FS00:Server responded WORK_QUIT (404)
23:31:07:WARNING:WU00:FS00:Server did not like results, dumping
23:31:07:WU00:FS00:Cleaning up
23:31:08:WU02:FS00:Assigned to work server 171.67.108.52
23:31:08:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:31:08:WU02:FS00:Connecting to 171.67.108.52:8080
23:31:09:WU02:FS00:Downloading 1.52MiB
23:31:12:WU02:FS00:Download complete
23:31:12:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:809 clone:2 gen:177 core:0x17 unit:0x000000e96652edc45399f5da2d60bc8d
23:31:12:WU02:FS00:Starting
23:31:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:12:WU02:FS00:Started FahCore on PID 2612
23:31:12:WU02:FS00:Core PID:6676
23:31:12:WU02:FS00:FahCore 0x17 started
23:31:12:WU02:FS00:0x17:*********************** Log Started 2015-01-15T23:31:12Z ***********************
23:31:12:WU02:FS00:0x17:Project: 9201 (Run 809, Clone 2, Gen 177)
23:31:12:WU02:FS00:0x17:Unit: 0x000000e96652edc45399f5da2d60bc8d
23:31:12:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:31:12:WU02:FS00:0x17:Machine: 0
23:31:12:WU02:FS00:0x17:Reading tar file state.xml
23:31:12:WU02:FS00:0x17:Reading tar file system.xml
23:31:12:WU02:FS00:0x17:Reading tar file integrator.xml
23:31:12:WU02:FS00:0x17:Reading tar file core.xml
23:31:12:WU02:FS00:0x17:Digital signatures verified
23:31:12:WU02:FS00:0x17:Folding@home GPU core17
23:31:12:WU02:FS00:0x17:Version 0.0.52
23:31:12:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
23:31:12:WU02:FS00:0x17:Saving result file logfile_01.txt
23:31:12:WU02:FS00:0x17:Saving result file log.txt
23:31:13:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:31:13:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:31:13:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:809 clone:2 gen:177 core:0x17 unit:0x000000e96652edc45399f5da2d60bc8d
23:31:13:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
23:31:13:WU02:FS00:Connecting to 171.67.108.52:8080
23:31:13:WU00:FS00:Connecting to 171.67.108.200:80
23:31:13:WU02:FS00:Upload complete
23:31:13:WU02:FS00:Server responded WORK_ACK (400)
23:31:13:WU02:FS00:Cleaning up
23:31:14:WU00:FS00:Assigned to work server 171.67.108.52
23:31:14:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:31:14:WU00:FS00:Connecting to 171.67.108.52:8080
23:31:15:WU00:FS00:Downloading 1.52MiB
23:31:18:WU00:FS00:Download complete
23:31:18:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:206 clone:3 gen:154 core:0x17 unit:0x000000d96652edc45399de1ee1b0ab45
23:31:18:WU00:FS00:Starting
23:31:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:18:WU00:FS00:Started FahCore on PID 6580
23:31:18:WU00:FS00:Core PID:2108
23:31:18:WU00:FS00:FahCore 0x17 started
23:31:19:WU00:FS00:0x17:*********************** Log Started 2015-01-15T23:31:18Z ***********************
23:31:19:WU00:FS00:0x17:Project: 9201 (Run 206, Clone 3, Gen 154)
23:31:19:WU00:FS00:0x17:Unit: 0x000000d96652edc45399de1ee1b0ab45
23:31:19:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:31:19:WU00:FS00:0x17:Machine: 0
23:31:19:WU00:FS00:0x17:Reading tar file state.xml
23:31:19:WU00:FS00:0x17:Reading tar file system.xml
23:31:19:WU00:FS00:0x17:Reading tar file integrator.xml
23:31:19:WU00:FS00:0x17:Reading tar file core.xml
23:31:19:WU00:FS00:0x17:Digital signatures verified
23:31:19:WU00:FS00:0x17:Folding@home GPU core17
23:31:19:WU00:FS00:0x17:Version 0.0.52
23:31:19:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
23:31:19:WU00:FS00:0x17:Saving result file logfile_01.txt
23:31:19:WU00:FS00:0x17:Saving result file log.txt
23:31:19:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:31:20:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:31:20:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:206 clone:3 gen:154 core:0x17 unit:0x000000d96652edc45399de1ee1b0ab45
23:31:20:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
23:31:20:WU00:FS00:Connecting to 171.67.108.52:8080
23:31:20:WU02:FS00:Connecting to 171.67.108.200:80
23:31:20:WU00:FS00:Upload complete
23:31:20:WU00:FS00:Server responded WORK_ACK (400)
23:31:20:WU00:FS00:Cleaning up
23:31:21:WU02:FS00:Assigned to work server 171.67.108.52
23:31:21:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:31:21:WU02:FS00:Connecting to 171.67.108.52:8080
23:31:21:WU02:FS00:Downloading 1.52MiB
23:31:25:WU02:FS00:Download complete
23:31:25:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:273 clone:4 gen:151 core:0x17 unit:0x000000cf6652edc45399e0c4dc683da5
23:31:25:WU02:FS00:Starting
23:31:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:25:WU02:FS00:Started FahCore on PID 4988
23:31:25:WU02:FS00:Core PID:6028
23:31:25:WU02:FS00:FahCore 0x17 started
23:31:26:WU02:FS00:0x17:*********************** Log Started 2015-01-15T23:31:25Z ***********************
23:31:26:WU02:FS00:0x17:Project: 9201 (Run 273, Clone 4, Gen 151)
23:31:26:WU02:FS00:0x17:Unit: 0x000000cf6652edc45399e0c4dc683da5
23:31:26:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:31:26:WU02:FS00:0x17:Machine: 0
23:31:26:WU02:FS00:0x17:Reading tar file state.xml
23:31:26:WU02:FS00:0x17:Reading tar file system.xml
23:31:26:WU02:FS00:0x17:Reading tar file integrator.xml
23:31:26:WU02:FS00:0x17:Reading tar file core.xml
23:31:26:WU02:FS00:0x17:Digital signatures verified
23:31:26:WU02:FS00:0x17:Folding@home GPU core17
23:31:26:WU02:FS00:0x17:Version 0.0.52
23:31:26:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
23:31:26:WU02:FS00:0x17:Saving result file logfile_01.txt
23:31:26:WU02:FS00:0x17:Saving result file log.txt
23:31:26:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:31:27:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:31:27:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:273 clone:4 gen:151 core:0x17 unit:0x000000cf6652edc45399e0c4dc683da5
23:31:27:WU02:FS00:Uploading 1.97KiB to 171.67.108.52
23:31:27:WU02:FS00:Connecting to 171.67.108.52:8080
23:31:27:WU00:FS00:Connecting to 171.67.108.200:80
23:31:27:WU02:FS00:Upload complete
23:31:27:WU02:FS00:Server responded WORK_ACK (400)
23:31:27:WU02:FS00:Cleaning up
23:31:28:WU00:FS00:Assigned to work server 171.67.108.52
23:31:28:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:31:28:WU00:FS00:Connecting to 171.67.108.52:8080
23:31:28:WU00:FS00:Downloading 1.52MiB
23:31:32:WU00:FS00:Download complete
23:31:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:641 clone:2 gen:150 core:0x17 unit:0x000000df6652edc45399ef3cd46754d7
23:31:32:WU00:FS00:Starting
23:31:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:32:WU00:FS00:Started FahCore on PID 4200
23:31:32:WU00:FS00:Core PID:4748
23:31:32:WU00:FS00:FahCore 0x17 started
23:31:32:WU00:FS00:0x17:*********************** Log Started 2015-01-15T23:31:32Z ***********************
23:31:32:WU00:FS00:0x17:Project: 9201 (Run 641, Clone 2, Gen 150)
23:31:32:WU00:FS00:0x17:Unit: 0x000000df6652edc45399ef3cd46754d7
23:31:32:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:31:32:WU00:FS00:0x17:Machine: 0
23:31:32:WU00:FS00:0x17:Reading tar file state.xml
23:31:32:WU00:FS00:0x17:Reading tar file system.xml
23:31:32:WU00:FS00:0x17:Reading tar file integrator.xml
23:31:32:WU00:FS00:0x17:Reading tar file core.xml
23:31:32:WU00:FS00:0x17:Digital signatures verified
23:31:32:WU00:FS00:0x17:Folding@home GPU core17
23:31:32:WU00:FS00:0x17:Version 0.0.52
23:31:32:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
23:31:32:WU00:FS00:0x17:Saving result file logfile_01.txt
23:31:32:WU00:FS00:0x17:Saving result file log.txt
23:31:32:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:31:33:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:31:33:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:641 clone:2 gen:150 core:0x17 unit:0x000000df6652edc45399ef3cd46754d7
23:31:33:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
23:31:33:WU00:FS00:Connecting to 171.67.108.52:8080
23:31:33:WU02:FS00:Connecting to 171.67.108.200:80
23:31:33:WU00:FS00:Upload complete
23:31:33:WU00:FS00:Server responded WORK_ACK (400)
23:31:33:WU00:FS00:Cleaning up
23:31:34:WU02:FS00:Assigned to work server 171.64.65.105
23:31:34:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.64.65.105
23:31:34:WU02:FS00:Connecting to 171.64.65.105:8080
23:31:35:WU02:FS00:Downloading 122.79KiB
23:31:36:WU02:FS00:Download complete
23:31:36:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:7627 run:93 clone:0 gen:164 core:0x15 unit:0x000000e3664f2dd152a3c4747f1cd2ca
23:31:36:WU02:FS00:Starting
23:31:36:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:36:WU02:FS00:Started FahCore on PID 6992
23:31:36:WU02:FS00:Core PID:2292
23:31:36:WU02:FS00:FahCore 0x15 started
23:31:36:WU02:FS00:0x15:
23:31:36:WU02:FS00:0x15:*------------------------------*
23:31:36:WU02:FS00:0x15:Folding@Home GPU Core
23:31:36:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:31:36:WU02:FS00:0x15:Build host             AmoebaRemote
23:31:36:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
23:31:36:WU02:FS00:0x15:Core                   15
23:31:36:WU02:FS00:0x15:Window's signal control handler registered.
23:31:36:WU02:FS00:0x15:Preparing to commence simulation
23:31:36:WU02:FS00:0x15:- Looking at optimizations...
23:31:36:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:31:36:WU02:FS00:0x15:- Created dyn
23:31:36:WU02:FS00:0x15:- Files status OK
23:31:36:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:31:36:WU02:FS00:0x15:- Expanded 125229 -> 503186 (decompressed 401.8 percent)
23:31:36:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=125229 data_size=503186, decompressed_data_size=503186 diff=0
23:31:36:WU02:FS00:0x15:- Digital signature verified
23:31:36:WU02:FS00:0x15:Project: 7627 (Run 93, Clone 0, Gen 164)
23:31:36:WU02:FS00:0x15:Assembly optimizations on if available.
23:31:36:WU02:FS00:0x15:Entering M.D.
23:31:38:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1046332698 2343364475 3308215627 1378266450 773854941
23:31:38:WU02:FS00:0x15:GPU device id=0
23:31:38:WU02:FS00:0x15:Working on Protein
23:31:38:WU02:FS00:0x15:Client config unavailable.
23:31:38:WU02:FS00:0x15:Finished fah_main status=59
23:31:38:WU02:FS00:0x15:mdrun_gpu returned 59
23:31:38:WU02:FS00:0x15:GPU memtest failure
23:31:38:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:31:39:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:31:39:WU02:FS00:Starting
23:31:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:31:39:WU02:FS00:Started FahCore on PID 6024
23:31:39:WU02:FS00:Core PID:4908
23:31:39:WU02:FS00:FahCore 0x15 started
23:31:39:WU02:FS00:0x15:
23:31:39:WU02:FS00:0x15:*------------------------------*
23:31:39:WU02:FS00:0x15:Folding@Home GPU Core
23:31:39:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:31:39:WU02:FS00:0x15:Build host             AmoebaRemote
23:31:39:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
23:31:39:WU02:FS00:0x15:Core                   15
23:31:39:WU02:FS00:0x15:Window's signal control handler registered.
23:31:39:WU02:FS00:0x15:Preparing to commence simulation
23:31:39:WU02:FS00:0x15:- Looking at optimizations...
23:31:39:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:31:39:WU02:FS00:0x15:- Created dyn
23:31:39:WU02:FS00:0x15:- Files status OK
23:31:39:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:31:39:WU02:FS00:0x15:- Expanded 125229 -> 503186 (decompressed 401.8 percent)
23:31:39:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=125229 data_size=503186, decompressed_data_size=503186 diff=0
23:31:39:WU02:FS00:0x15:- Digital signature verified
23:31:39:WU02:FS00:0x15:Project: 7627 (Run 93, Clone 0, Gen 164)
23:31:39:WU02:FS00:0x15:Assembly optimizations on if available.
23:31:39:WU02:FS00:0x15:Entering M.D.
23:31:41:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1046332698 2343364475 3308215627 1378266450 773854941
23:31:41:WU02:FS00:0x15:GPU device id=0
23:31:41:WU02:FS00:0x15:Working on Protein
23:31:41:WU02:FS00:0x15:Client config unavailable.
23:31:41:WU02:FS00:0x15:Finished fah_main status=59
23:31:41:WU02:FS00:0x15:mdrun_gpu returned 59
23:31:41:WU02:FS00:0x15:GPU memtest failure
23:31:41:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:31:41:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:32:39:WU02:FS00:Starting
23:32:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:32:39:WU02:FS00:Started FahCore on PID 6136
23:32:39:WU02:FS00:Core PID:6676
23:32:39:WU02:FS00:FahCore 0x15 started
23:32:40:WU02:FS00:0x15:
23:32:40:WU02:FS00:0x15:*------------------------------*
23:32:40:WU02:FS00:0x15:Folding@Home GPU Core
23:32:40:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:32:40:WU02:FS00:0x15:Build host             AmoebaRemote
23:32:40:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
23:32:40:WU02:FS00:0x15:Core                   15
23:32:40:WU02:FS00:0x15:Window's signal control handler registered.
23:32:40:WU02:FS00:0x15:Preparing to commence simulation
23:32:40:WU02:FS00:0x15:- Looking at optimizations...
23:32:40:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:32:40:WU02:FS00:0x15:- Created dyn
23:32:40:WU02:FS00:0x15:- Files status OK
23:32:40:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:32:40:WU02:FS00:0x15:- Expanded 125229 -> 503186 (decompressed 401.8 percent)
23:32:40:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=125229 data_size=503186, decompressed_data_size=503186 diff=0
23:32:40:WU02:FS00:0x15:- Digital signature verified
23:32:40:WU02:FS00:0x15:Project: 7627 (Run 93, Clone 0, Gen 164)
23:32:40:WU02:FS00:0x15:Assembly optimizations on if available.
23:32:40:WU02:FS00:0x15:Entering M.D.
23:32:41:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1046332698 2343364475 3308215627 1378266450 773854941
23:32:41:WU02:FS00:0x15:GPU device id=0
23:32:41:WU02:FS00:0x15:Working on Protein
23:32:41:WU02:FS00:0x15:Client config unavailable.
23:32:42:WU02:FS00:0x15:Finished fah_main status=59
23:32:42:WU02:FS00:0x15:mdrun_gpu returned 59
23:32:42:WU02:FS00:0x15:GPU memtest failure
23:32:42:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:32:42:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:33:39:WU02:FS00:Starting
23:33:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:33:39:WU02:FS00:Started FahCore on PID 1088
23:33:39:WU02:FS00:Core PID:4988
23:33:39:WU02:FS00:FahCore 0x15 started
23:33:40:WU02:FS00:0x15:
23:33:40:WU02:FS00:0x15:*------------------------------*
23:33:40:WU02:FS00:0x15:Folding@Home GPU Core
23:33:40:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:33:40:WU02:FS00:0x15:Build host             AmoebaRemote
23:33:40:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
23:33:40:WU02:FS00:0x15:Core                   15
23:33:40:WU02:FS00:0x15:Window's signal control handler registered.
23:33:40:WU02:FS00:0x15:Preparing to commence simulation
23:33:40:WU02:FS00:0x15:- Looking at optimizations...
23:33:40:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:33:40:WU02:FS00:0x15:- Created dyn
23:33:40:WU02:FS00:0x15:- Files status OK
23:33:40:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:33:40:WU02:FS00:0x15:- Expanded 125229 -> 503186 (decompressed 401.8 percent)
23:33:40:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=125229 data_size=503186, decompressed_data_size=503186 diff=0
23:33:40:WU02:FS00:0x15:- Digital signature verified
23:33:40:WU02:FS00:0x15:Project: 7627 (Run 93, Clone 0, Gen 164)
23:33:40:WU02:FS00:0x15:Assembly optimizations on if available.
23:33:40:WU02:FS00:0x15:Entering M.D.
23:33:41:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1046332698 2343364475 3308215627 1378266450 773854941
23:33:41:WU02:FS00:0x15:GPU device id=0
23:33:41:WU02:FS00:0x15:Working on Protein
23:33:41:WU02:FS00:0x15:Client config unavailable.
23:33:42:WU02:FS00:0x15:Finished fah_main status=59
23:33:42:WU02:FS00:0x15:mdrun_gpu returned 59
23:33:42:WU02:FS00:0x15:GPU memtest failure
23:33:42:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:33:42:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:34:39:WU02:FS00:Starting
23:34:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:34:39:WU02:FS00:Started FahCore on PID 4676
23:34:39:WU02:FS00:Core PID:6848
23:34:39:WU02:FS00:FahCore 0x15 started
23:34:40:WU02:FS00:0x15:
23:34:40:WU02:FS00:0x15:*------------------------------*
23:34:40:WU02:FS00:0x15:Folding@Home GPU Core
23:34:40:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:34:40:WU02:FS00:0x15:Build host             AmoebaRemote
23:34:40:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
23:34:40:WU02:FS00:0x15:Core                   15
23:34:40:WU02:FS00:0x15:Window's signal control handler registered.
23:34:40:WU02:FS00:0x15:Preparing to commence simulation
23:34:40:WU02:FS00:0x15:- Looking at optimizations...
23:34:40:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:34:40:WU02:FS00:0x15:- Created dyn
23:34:40:WU02:FS00:0x15:- Files status OK
23:34:40:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:34:40:WU02:FS00:0x15:- Expanded 125229 -> 503186 (decompressed 401.8 percent)
23:34:40:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=125229 data_size=503186, decompressed_data_size=503186 diff=0
23:34:40:WU02:FS00:0x15:- Digital signature verified
23:34:40:WU02:FS00:0x15:Project: 7627 (Run 93, Clone 0, Gen 164)
23:34:40:WU02:FS00:0x15:Assembly optimizations on if available.
23:34:40:WU02:FS00:0x15:Entering M.D.
23:34:42:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1046332698 2343364475 3308215627 1378266450 773854941
23:34:42:WU02:FS00:0x15:GPU device id=0
23:34:42:WU02:FS00:0x15:Working on Protein
23:34:42:WU02:FS00:0x15:Client config unavailable.
23:34:42:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:34:42:WARNING:WU02:FS00:Too many errors, failing
23:34:42:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:7627 run:93 clone:0 gen:164 core:0x15 unit:0x000000e3664f2dd152a3c4747f1cd2ca
23:34:42:WU02:FS00:Connecting to 171.64.65.105:8080
23:34:42:WU00:FS00:Connecting to 171.67.108.200:80
23:34:42:WU02:FS00:Server responded WORK_QUIT (404)
23:34:42:WARNING:WU02:FS00:Server did not like results, dumping
23:34:42:WU02:FS00:Cleaning up
23:34:43:WU00:FS00:Assigned to work server 171.67.108.52
23:34:43:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:34:43:WU00:FS00:Connecting to 171.67.108.52:8080
23:34:44:WU00:FS00:Downloading 1.52MiB
23:34:47:WU00:FS00:Download complete
23:34:47:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:549 clone:3 gen:137 core:0x17 unit:0x000000cb6652edc45399eba0e6bb978a
23:34:47:WU00:FS00:Starting
23:34:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:34:47:WU00:FS00:Started FahCore on PID 712
23:34:47:WU00:FS00:Core PID:6104
23:34:47:WU00:FS00:FahCore 0x17 started
23:34:47:WU00:FS00:0x17:*********************** Log Started 2015-01-15T23:34:47Z ***********************
23:34:47:WU00:FS00:0x17:Project: 9201 (Run 549, Clone 3, Gen 137)
23:34:47:WU00:FS00:0x17:Unit: 0x000000cb6652edc45399eba0e6bb978a
23:34:47:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:34:47:WU00:FS00:0x17:Machine: 0
23:34:47:WU00:FS00:0x17:Reading tar file state.xml
23:34:48:WU00:FS00:0x17:Reading tar file system.xml
23:34:48:WU00:FS00:0x17:Reading tar file integrator.xml
23:34:48:WU00:FS00:0x17:Reading tar file core.xml
23:34:48:WU00:FS00:0x17:Digital signatures verified
23:34:48:WU00:FS00:0x17:Folding@home GPU core17
23:34:48:WU00:FS00:0x17:Version 0.0.52
23:34:48:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
23:34:48:WU00:FS00:0x17:Saving result file logfile_01.txt
23:34:48:WU00:FS00:0x17:Saving result file log.txt
23:34:48:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:34:48:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:34:48:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:549 clone:3 gen:137 core:0x17 unit:0x000000cb6652edc45399eba0e6bb978a
23:34:48:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
23:34:48:WU00:FS00:Connecting to 171.67.108.52:8080
23:34:48:WU02:FS00:Connecting to 171.67.108.200:80
23:34:49:WU00:FS00:Upload complete
23:34:49:WU00:FS00:Server responded WORK_ACK (400)
23:34:49:WU00:FS00:Cleaning up
23:34:49:WU02:FS00:Assigned to work server 171.67.108.52
23:34:49:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:34:49:WU02:FS00:Connecting to 171.67.108.52:8080
23:34:50:WU02:FS00:Downloading 1.52MiB
23:34:53:WU02:FS00:Download complete
23:34:53:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:745 clone:3 gen:135 core:0x17 unit:0x000000bf6652edc45399f35755a007ab
23:34:53:WU02:FS00:Starting
23:34:53:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:34:53:WU02:FS00:Started FahCore on PID 5768
23:34:53:WU02:FS00:Core PID:5796
23:34:53:WU02:FS00:FahCore 0x17 started
23:34:54:WU02:FS00:0x17:*********************** Log Started 2015-01-15T23:34:53Z ***********************
23:34:54:WU02:FS00:0x17:Project: 9201 (Run 745, Clone 3, Gen 135)
23:34:54:WU02:FS00:0x17:Unit: 0x000000bf6652edc45399f35755a007ab
23:34:54:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:34:54:WU02:FS00:0x17:Machine: 0
23:34:54:WU02:FS00:0x17:Reading tar file state.xml
23:34:54:WU02:FS00:0x17:Reading tar file system.xml
23:34:54:WU02:FS00:0x17:Reading tar file integrator.xml
23:34:54:WU02:FS00:0x17:Reading tar file core.xml
23:34:54:WU02:FS00:0x17:Digital signatures verified
23:34:54:WU02:FS00:0x17:Folding@home GPU core17
23:34:54:WU02:FS00:0x17:Version 0.0.52
23:34:54:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
23:34:54:WU02:FS00:0x17:Saving result file logfile_01.txt
23:34:54:WU02:FS00:0x17:Saving result file log.txt
23:34:54:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:34:54:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:34:54:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:745 clone:3 gen:135 core:0x17 unit:0x000000bf6652edc45399f35755a007ab
23:34:54:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
23:34:54:WU02:FS00:Connecting to 171.67.108.52:8080
23:34:55:WU00:FS00:Connecting to 171.67.108.200:80
23:34:55:WU02:FS00:Upload complete
23:34:55:WU02:FS00:Server responded WORK_ACK (400)
23:34:55:WU02:FS00:Cleaning up
23:34:57:WU00:FS00:Assigned to work server 171.64.65.105
23:34:57:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.64.65.105
23:34:57:WU00:FS00:Connecting to 171.64.65.105:8080
23:34:58:WU00:FS00:Downloading 122.07KiB
23:34:58:WU00:FS00:Download complete
23:34:59:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7620 run:638 clone:0 gen:296 core:0x15 unit:0x00000188664f2dd14e42f6d83667da0b
23:34:59:WU00:FS00:Starting
23:34:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:34:59:WU00:FS00:Started FahCore on PID 356
23:34:59:WU00:FS00:Core PID:1168
23:34:59:WU00:FS00:FahCore 0x15 started
23:34:59:WU00:FS00:0x15:
23:34:59:WU00:FS00:0x15:*------------------------------*
23:34:59:WU00:FS00:0x15:Folding@Home GPU Core
23:34:59:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:34:59:WU00:FS00:0x15:Build host             AmoebaRemote
23:34:59:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:34:59:WU00:FS00:0x15:Core                   15
23:34:59:WU00:FS00:0x15:Window's signal control handler registered.
23:34:59:WU00:FS00:0x15:Preparing to commence simulation
23:34:59:WU00:FS00:0x15:- Looking at optimizations...
23:34:59:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:34:59:WU00:FS00:0x15:- Created dyn
23:34:59:WU00:FS00:0x15:- Files status OK
23:34:59:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:34:59:WU00:FS00:0x15:- Expanded 124492 -> 501826 (decompressed 403.0 percent)
23:34:59:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124492 data_size=501826, decompressed_data_size=501826 diff=0
23:34:59:WU00:FS00:0x15:- Digital signature verified
23:34:59:WU00:FS00:0x15:Project: 7620 (Run 638, Clone 0, Gen 296)
23:34:59:WU00:FS00:0x15:Assembly optimizations on if available.
23:34:59:WU00:FS00:0x15:Entering M.D.
23:35:01:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  3593168179 3253185958 1232873213 1864185326 41170577
23:35:01:WU00:FS00:0x15:GPU device id=0
23:35:01:WU00:FS00:0x15:Working on Protein
23:35:01:WU00:FS00:0x15:Client config unavailable.
23:35:01:WU00:FS00:0x15:Finished fah_main status=59
23:35:01:WU00:FS00:0x15:mdrun_gpu returned 59
23:35:01:WU00:FS00:0x15:GPU memtest failure
23:35:01:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:35:01:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:35:02:WU00:FS00:Starting
23:35:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:35:02:WU00:FS00:Started FahCore on PID 5908
23:35:02:WU00:FS00:Core PID:6712
23:35:02:WU00:FS00:FahCore 0x15 started
23:35:02:WU00:FS00:0x15:
23:35:02:WU00:FS00:0x15:*------------------------------*
23:35:02:WU00:FS00:0x15:Folding@Home GPU Core
23:35:02:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:35:02:WU00:FS00:0x15:Build host             AmoebaRemote
23:35:02:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:35:02:WU00:FS00:0x15:Core                   15
23:35:02:WU00:FS00:0x15:Window's signal control handler registered.
23:35:02:WU00:FS00:0x15:Preparing to commence simulation
23:35:02:WU00:FS00:0x15:- Looking at optimizations...
23:35:02:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:35:02:WU00:FS00:0x15:- Created dyn
23:35:02:WU00:FS00:0x15:- Files status OK
23:35:02:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:35:02:WU00:FS00:0x15:- Expanded 124492 -> 501826 (decompressed 403.0 percent)
23:35:02:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124492 data_size=501826, decompressed_data_size=501826 diff=0
23:35:02:WU00:FS00:0x15:- Digital signature verified
23:35:02:WU00:FS00:0x15:Project: 7620 (Run 638, Clone 0, Gen 296)
23:35:02:WU00:FS00:0x15:Assembly optimizations on if available.
23:35:02:WU00:FS00:0x15:Entering M.D.
23:35:04:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  3593168179 3253185958 1232873213 1864185326 41170577
23:35:04:WU00:FS00:0x15:GPU device id=0
23:35:04:WU00:FS00:0x15:Working on Protein
23:35:04:WU00:FS00:0x15:Client config unavailable.
23:35:04:WU00:FS00:0x15:Finished fah_main status=59
23:35:04:WU00:FS00:0x15:mdrun_gpu returned 59
23:35:04:WU00:FS00:0x15:GPU memtest failure
23:35:04:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:35:04:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:36:02:WU00:FS00:Starting
23:36:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:36:02:WU00:FS00:Started FahCore on PID 1576
23:36:02:WU00:FS00:Core PID:6676
23:36:02:WU00:FS00:FahCore 0x15 started
23:36:02:WU00:FS00:0x15:
23:36:02:WU00:FS00:0x15:*------------------------------*
23:36:02:WU00:FS00:0x15:Folding@Home GPU Core
23:36:02:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:36:02:WU00:FS00:0x15:Build host             AmoebaRemote
23:36:02:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:36:02:WU00:FS00:0x15:Core                   15
23:36:02:WU00:FS00:0x15:Window's signal control handler registered.
23:36:02:WU00:FS00:0x15:Preparing to commence simulation
23:36:02:WU00:FS00:0x15:- Looking at optimizations...
23:36:02:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:36:02:WU00:FS00:0x15:- Created dyn
23:36:02:WU00:FS00:0x15:- Files status OK
23:36:02:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:36:02:WU00:FS00:0x15:- Expanded 124492 -> 501826 (decompressed 403.0 percent)
23:36:02:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124492 data_size=501826, decompressed_data_size=501826 diff=0
23:36:02:WU00:FS00:0x15:- Digital signature verified
23:36:02:WU00:FS00:0x15:Project: 7620 (Run 638, Clone 0, Gen 296)
23:36:02:WU00:FS00:0x15:Assembly optimizations on if available.
23:36:02:WU00:FS00:0x15:Entering M.D.
23:36:04:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  3593168179 3253185958 1232873213 1864185326 41170577
23:36:04:WU00:FS00:0x15:GPU device id=0
23:36:04:WU00:FS00:0x15:Working on Protein
23:36:04:WU00:FS00:0x15:Client config unavailable.
23:36:04:WU00:FS00:0x15:Finished fah_main status=59
23:36:04:WU00:FS00:0x15:mdrun_gpu returned 59
23:36:04:WU00:FS00:0x15:GPU memtest failure
23:36:04:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:36:04:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:37:02:WU00:FS00:Starting
23:37:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:37:02:WU00:FS00:Started FahCore on PID 5596
23:37:02:WU00:FS00:Core PID:1976
23:37:02:WU00:FS00:FahCore 0x15 started
23:37:03:WU00:FS00:0x15:
23:37:03:WU00:FS00:0x15:*------------------------------*
23:37:03:WU00:FS00:0x15:Folding@Home GPU Core
23:37:03:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:37:03:WU00:FS00:0x15:Build host             AmoebaRemote
23:37:03:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:37:03:WU00:FS00:0x15:Core                   15
23:37:03:WU00:FS00:0x15:Window's signal control handler registered.
23:37:03:WU00:FS00:0x15:Preparing to commence simulation
23:37:03:WU00:FS00:0x15:- Looking at optimizations...
23:37:03:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:37:03:WU00:FS00:0x15:- Created dyn
23:37:03:WU00:FS00:0x15:- Files status OK
23:37:03:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:37:03:WU00:FS00:0x15:- Expanded 124492 -> 501826 (decompressed 403.0 percent)
23:37:03:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124492 data_size=501826, decompressed_data_size=501826 diff=0
23:37:03:WU00:FS00:0x15:- Digital signature verified
23:37:03:WU00:FS00:0x15:Project: 7620 (Run 638, Clone 0, Gen 296)
23:37:03:WU00:FS00:0x15:Assembly optimizations on if available.
23:37:03:WU00:FS00:0x15:Entering M.D.
23:37:04:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  3593168179 3253185958 1232873213 1864185326 41170577
23:37:04:WU00:FS00:0x15:GPU device id=0
23:37:04:WU00:FS00:0x15:Working on Protein
23:37:04:WU00:FS00:0x15:Client config unavailable.
23:37:05:WU00:FS00:0x15:Finished fah_main status=59
23:37:05:WU00:FS00:0x15:mdrun_gpu returned 59
23:37:05:WU00:FS00:0x15:GPU memtest failure
23:37:05:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:37:05:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:38:02:WU00:FS00:Starting
23:38:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:38:02:WU00:FS00:Started FahCore on PID 5532
23:38:02:WU00:FS00:Core PID:4908
23:38:02:WU00:FS00:FahCore 0x15 started
23:38:03:WU00:FS00:0x15:
23:38:03:WU00:FS00:0x15:*------------------------------*
23:38:03:WU00:FS00:0x15:Folding@Home GPU Core
23:38:03:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:38:03:WU00:FS00:0x15:Build host             AmoebaRemote
23:38:03:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:38:03:WU00:FS00:0x15:Core                   15
23:38:03:WU00:FS00:0x15:Window's signal control handler registered.
23:38:03:WU00:FS00:0x15:Preparing to commence simulation
23:38:03:WU00:FS00:0x15:- Looking at optimizations...
23:38:03:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:38:03:WU00:FS00:0x15:- Created dyn
23:38:03:WU00:FS00:0x15:- Files status OK
23:38:03:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:38:03:WU00:FS00:0x15:- Expanded 124492 -> 501826 (decompressed 403.0 percent)
23:38:03:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124492 data_size=501826, decompressed_data_size=501826 diff=0
23:38:03:WU00:FS00:0x15:- Digital signature verified
23:38:03:WU00:FS00:0x15:Project: 7620 (Run 638, Clone 0, Gen 296)
23:38:03:WU00:FS00:0x15:Assembly optimizations on if available.
23:38:03:WU00:FS00:0x15:Entering M.D.
23:38:04:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  3593168179 3253185958 1232873213 1864185326 41170577
23:38:04:WU00:FS00:0x15:GPU device id=0
23:38:04:WU00:FS00:0x15:Working on Protein
23:38:04:WU00:FS00:0x15:Client config unavailable.
23:38:05:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:38:05:WARNING:WU00:FS00:Too many errors, failing
23:38:05:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:7620 run:638 clone:0 gen:296 core:0x15 unit:0x00000188664f2dd14e42f6d83667da0b
23:38:05:WU00:FS00:Connecting to 171.64.65.105:8080
23:38:05:WU02:FS00:Connecting to 171.67.108.200:80
23:38:05:WU00:FS00:Server responded WORK_QUIT (404)
23:38:05:WARNING:WU00:FS00:Server did not like results, dumping
23:38:05:WU00:FS00:Cleaning up
23:38:09:WU02:FS00:Assigned to work server 171.67.108.52
23:38:09:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
23:38:09:WU02:FS00:Connecting to 171.67.108.52:8080
23:38:10:WU02:FS00:Downloading 1.52MiB
23:38:12:WU01:FS01:0xa3:Completed 510000 out of 1000000 steps  (51%)
23:38:13:WU02:FS00:Download complete
23:38:13:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:573 clone:3 gen:126 core:0x17 unit:0x000000b56652edc45399ec909696524f
23:38:13:WU02:FS00:Starting
23:38:13:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 3792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:38:13:WU02:FS00:Started FahCore on PID 6948
23:38:13:WU02:FS00:Core PID:7044
23:38:13:WU02:FS00:FahCore 0x17 started
23:38:14:WU02:FS00:0x17:*********************** Log Started 2015-01-15T23:38:13Z ***********************
23:38:14:WU02:FS00:0x17:Project: 9201 (Run 573, Clone 3, Gen 126)
23:38:14:WU02:FS00:0x17:Unit: 0x000000b56652edc45399ec909696524f
23:38:14:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:38:14:WU02:FS00:0x17:Machine: 0
23:38:14:WU02:FS00:0x17:Reading tar file state.xml
23:38:14:WU02:FS00:0x17:Reading tar file system.xml
23:38:14:WU02:FS00:0x17:Reading tar file integrator.xml
23:38:14:WU02:FS00:0x17:Reading tar file core.xml
23:38:14:WU02:FS00:0x17:Digital signatures verified
23:38:14:WU02:FS00:0x17:Folding@home GPU core17
23:38:14:WU02:FS00:0x17:Version 0.0.52
23:38:14:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
23:38:14:WU02:FS00:0x17:Saving result file logfile_01.txt
23:38:14:WU02:FS00:0x17:Saving result file log.txt
23:38:14:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:38:14:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:38:14:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:573 clone:3 gen:126 core:0x17 unit:0x000000b56652edc45399ec909696524f
23:38:14:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
23:38:14:WU02:FS00:Connecting to 171.67.108.52:8080
23:38:15:WU02:FS00:Upload complete
23:38:15:WU02:FS00:Server responded WORK_ACK (400)
23:38:15:WU02:FS00:Cleaning up
23:41:14:FS01:Paused
23:41:14:FS00:Paused
23:41:14:FS01:Shutting core down
23:41:19:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
My rig runs on Windows 8.1 Pro with media center fully patched, nvidia driver 347.09 and FAH 7.4.4. My set-up on this machine has client-type = advanced flag as the only flag for the GPU.
I tried downgrading to version 344.11 which came with the card. That just gave the same set of errors plus a new bad_platformsize error message which a quick search indicated that FAH did not have the right resources to function properly.
I can continue resetting and rebooting in the hope that it catches a valid work unit - but any suggestions as to changes that I can make gratefully received.
At this rate I will get more done if I reinstall the GTX 770 the new card replaces.
Ka kite ano
Nick
ChristianVirtual
Re: Problems with new GTX 980
Post by ChristianVirtual »
Any overclocking applied ? If yes, reduce that ...
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Post by jimerickson »
hmm, your config says cuda not detected. that makes me wonder about the driver being used.
Nick200
Post by Nick200 »
Hi
Thanks for the quick responses:
I've not applied any overclocking, mainly because that has given me considerable grief in the past. So I run at factory settings.
As for CUDA, yes, I spotted that too. So I re-installed the latest driver as per the attached log file
*********************** Log Started 2015-01-16T00:12:10Z ***********************
00:12:10:************************* Folding@home Client *************************
00:12:10:      Website: http://folding.stanford.edu/
00:12:10:    Copyright: (c) 2009-2014 Stanford University
00:12:10:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:12:10:         Args:
00:12:10:       Config: C:/ProgramData/FAHClient/config.xml
00:12:10:******************************** Build ********************************
00:12:10:      Version: 7.4.4
00:12:10:         Date: Mar 4 2014
00:12:10:         Time: 20:26:54
00:12:10:      SVN Rev: 4130
00:12:10:       Branch: fah/trunk/client
00:12:10:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:12:10:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:12:10:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:12:10:     Platform: win32 XP
00:12:10:         Bits: 32
00:12:10:         Mode: Release
00:12:10:******************************* System ********************************
00:12:10:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
00:12:10:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:12:10:         CPUs: 8
00:12:10:       Memory: 15.89GiB
00:12:10:  Free Memory: 11.39GiB
00:12:10:      Threads: WINDOWS_THREADS
00:12:10:   OS Version: 6.2
00:12:10:  Has Battery: false
00:12:10:   On Battery: false
00:12:10:   UTC Offset: 13
00:12:10:          PID: 6636
00:12:10:          CWD: C:/ProgramData/FAHClient
00:12:10:           OS: Windows 8.1 Pro with Media Center
00:12:10:      OS Arch: AMD64
00:12:10:         GPUs: 1
00:12:10:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
00:12:10:         CUDA: Not detected
00:12:10:Win32 Service: false
00:12:10:***********************************************************************
00:12:10:<config>
00:12:10:  <!-- Folding Slot Configuration -->
00:12:10:  <client-type v='advanced'/>
00:12:10:
00:12:10:  <!-- Network -->
00:12:10:  <proxy v=':8080'/>
00:12:10:
00:12:10:  <!-- Slot Control -->
00:12:10:  <power v='full'/>
00:12:10:
00:12:10:  <!-- User Information -->
00:12:10:  <passkey v='********************************'/>
00:12:10:  <team v='142900'/>
00:12:10:  <user v='Montague-Cripps'/>
00:12:10:
00:12:10:  <!-- Folding Slots -->
00:12:10:  <slot id='1' type='CPU'/>
00:12:10:  <slot id='0' type='GPU'/>
00:12:10:</config>
00:12:10:Trying to access database...
00:12:10:Successfully acquired database lock
00:12:10:Enabled folding slot 01: READY cpu:7
00:12:10:Enabled folding slot 00: READY gpu:0:GM204 [GeForce GTX 980]
00:12:10:WU01:FS01:Starting
00:12:10:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -np 7
00:12:10:WU01:FS01:Started FahCore on PID 3236
00:12:10:WU01:FS01:Core PID:3248
00:12:10:WU01:FS01:FahCore 0xa3 started
00:12:10:WU00:FS00:Connecting to 171.67.108.200:80
00:12:10:WU01:FS01:0xa3:
00:12:10:WU01:FS01:0xa3:*------------------------------*
00:12:10:WU01:FS01:0xa3:Folding@Home Gromacs SMP Core
00:12:10:WU01:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
00:12:10:WU01:FS01:0xa3:Preparing to commence simulation
00:12:10:WU01:FS01:0xa3:- Looking at optimizations...
00:12:10:WU01:FS01:0xa3:- Files status OK
00:12:10:WU01:FS01:0xa3:- Expanded 3552200 -> 3880552 (decompressed 109.2 percent)
00:12:10:WU01:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3552200 data_size=3880552, decompressed_data_size=3880552 diff=0
00:12:10:WU01:FS01:0xa3:- Digital signature verified
00:12:10:WU01:FS01:0xa3:Project: 7505 (Run 0, Clone 4, Gen 414)
00:12:10:WU01:FS01:0xa3:Assembly optimizations on if available.
00:12:10:WU01:FS01:0xa3:Entering M.D.
00:12:12:WU00:FS00:Assigned to work server 171.64.65.105
00:12:12:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.64.65.105
00:12:12:WU00:FS00:Connecting to 171.64.65.105:8080
00:12:13:WU00:FS00:Downloading 122.33KiB
00:12:13:WU00:FS00:Download complete
00:12:13:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7620 run:272 clone:0 gen:311 core:0x15 unit:0x0000019d664f2dd14e42f5090d5cf322
00:12:13:WU00:FS00:Starting
00:12:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:12:13:WU00:FS00:Started FahCore on PID 6872
00:12:13:WU00:FS00:Core PID:6904
00:12:13:WU00:FS00:FahCore 0x15 started
00:12:14:WU00:FS00:0x15:
00:12:14:WU00:FS00:0x15:*------------------------------*
00:12:14:WU00:FS00:0x15:Folding@Home GPU Core
00:12:14:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:12:14:WU00:FS00:0x15:Build host             AmoebaRemote
00:12:14:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
00:12:14:WU00:FS00:0x15:Core                   15
00:12:14:WU00:FS00:0x15:Window's signal control handler registered.
00:12:14:WU00:FS00:0x15:Preparing to commence simulation
00:12:14:WU00:FS00:0x15:- Looking at optimizations...
00:12:14:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
00:12:14:WU00:FS00:0x15:- Created dyn
00:12:14:WU00:FS00:0x15:- Files status OK
00:12:14:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:12:14:WU00:FS00:0x15:- Expanded 124758 -> 501826 (decompressed 402.2 percent)
00:12:14:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124758 data_size=501826, decompressed_data_size=501826 diff=0
00:12:14:WU00:FS00:0x15:- Digital signature verified
00:12:14:WU00:FS00:0x15:Project: 7620 (Run 272, Clone 0, Gen 311)
00:12:14:WU00:FS00:0x15:Assembly optimizations on if available.
00:12:14:WU00:FS00:0x15:Entering M.D.
00:12:16:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  612187457 1987226964 2230748091 1209787080 1827262250
00:12:16:WU00:FS00:0x15:GPU device id=0
00:12:16:WU00:FS00:0x15:Working on Protein
00:12:16:WU00:FS00:0x15:Client config unavailable.
00:12:16:WU00:FS00:0x15:Finished fah_main status=59
00:12:16:WU00:FS00:0x15:mdrun_gpu returned 59
00:12:16:WU00:FS00:0x15:GPU memtest failure
00:12:16:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:12:16:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:12:16:WU01:FS01:0xa3:Using Gromacs checkpoints
00:12:16:WU00:FS00:Starting
00:12:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:12:16:WU00:FS00:Started FahCore on PID 6032
00:12:16:WU00:FS00:Core PID:4792
00:12:16:WU00:FS00:FahCore 0x15 started
00:12:17:WU01:FS01:0xa3:Mapping NT from 7 to 7
00:12:17:WU00:FS00:0x15:
00:12:17:WU00:FS00:0x15:*------------------------------*
00:12:17:WU00:FS00:0x15:Folding@Home GPU Core
00:12:17:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:12:17:WU00:FS00:0x15:Build host             AmoebaRemote
00:12:17:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
00:12:17:WU00:FS00:0x15:Core                   15
00:12:17:WU00:FS00:0x15:Window's signal control handler registered.
00:12:17:WU00:FS00:0x15:Preparing to commence simulation
00:12:17:WU00:FS00:0x15:- Looking at optimizations...
00:12:17:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
00:12:17:WU00:FS00:0x15:- Created dyn
00:12:17:WU00:FS00:0x15:- Files status OK
00:12:17:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:12:17:WU00:FS00:0x15:- Expanded 124758 -> 501826 (decompressed 402.2 percent)
00:12:17:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124758 data_size=501826, decompressed_data_size=501826 diff=0
00:12:17:WU00:FS00:0x15:- Digital signature verified
00:12:17:WU00:FS00:0x15:Project: 7620 (Run 272, Clone 0, Gen 311)
00:12:17:WU00:FS00:0x15:Assembly optimizations on if available.
00:12:17:WU00:FS00:0x15:Entering M.D.
00:12:17:WU01:FS01:0xa3:Resuming from checkpoint
00:12:17:WU01:FS01:0xa3:Verified 01/wudata_01.log
00:12:17:WU01:FS01:0xa3:Verified 01/wudata_01.trr
00:12:17:WU01:FS01:0xa3:Verified 01/wudata_01.xtc
00:12:17:WU01:FS01:0xa3:Verified 01/wudata_01.edr
00:12:18:WU01:FS01:0xa3:Completed 505350 out of 1000000 steps  (50%)
00:12:19:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  612187457 1987226964 2230748091 1209787080 1827262250
00:12:19:WU00:FS00:0x15:GPU device id=0
00:12:19:WU00:FS00:0x15:Working on Protein
00:12:19:WU00:FS00:0x15:Client config unavailable.
00:12:19:WU00:FS00:0x15:Finished fah_main status=59
00:12:19:WU00:FS00:0x15:mdrun_gpu returned 59
00:12:19:WU00:FS00:0x15:GPU memtest failure
00:12:19:WU00:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:12:19:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:13:17:WU00:FS00:Starting
00:13:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:13:17:WU00:FS00:Started FahCore on PID 1740
00:13:17:WU00:FS00:Core PID:5464
00:13:17:WU00:FS00:FahCore 0x15 started
00:13:17:WU00:FS00:0x15:
00:13:17:WU00:FS00:0x15:*------------------------------*
00:13:17:WU00:FS00:0x15:Folding@Home GPU Core
00:13:17:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:13:17:WU00:FS00:0x15:Build host             AmoebaRemote
00:13:17:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
00:13:17:WU00:FS00:0x15:Core                   15
00:13:17:WU00:FS00:0x15:Window's signal control handler registered.
00:13:17:WU00:FS00:0x15:Preparing to commence simulation
00:13:17:WU00:FS00:0x15:- Looking at optimizations...
00:13:17:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
00:13:17:WU00:FS00:0x15:- Created dyn
00:13:17:WU00:FS00:0x15:- Files status OK
00:13:17:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:13:17:WU00:FS00:0x15:- Expanded 124758 -> 501826 (decompressed 402.2 percent)
00:13:17:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124758 data_size=501826, decompressed_data_size=501826 diff=0
00:13:17:WU00:FS00:0x15:- Digital signature verified
00:13:17:WU00:FS00:0x15:Project: 7620 (Run 272, Clone 0, Gen 311)
00:13:17:WU00:FS00:0x15:Assembly optimizations on if available.
00:13:17:WU00:FS00:0x15:Entering M.D.
00:13:19:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  612187457 1987226964 2230748091 1209787080 1827262250
00:13:19:WU00:FS00:0x15:GPU device id=0
00:13:19:WU00:FS00:0x15:Working on Protein
00:13:19:WU00:FS00:0x15:Client config unavailable.
00:13:19:WU00:FS00:0x15:Finished fah_main status=59
00:13:19:WU00:FS00:0x15:mdrun_gpu returned 59
00:13:19:WU00:FS00:0x15:GPU memtest failure
00:13:19:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:14:17:WU00:FS00:Starting
00:14:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:14:17:WU00:FS00:Started FahCore on PID 6576
00:14:17:WU00:FS00:Core PID:2888
00:14:17:WU00:FS00:FahCore 0x15 started
00:14:17:WU00:FS00:0x15:
00:14:17:WU00:FS00:0x15:*------------------------------*
00:14:17:WU00:FS00:0x15:Folding@Home GPU Core
00:14:17:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:14:17:WU00:FS00:0x15:Build host             AmoebaRemote
00:14:17:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
00:14:17:WU00:FS00:0x15:Core                   15
00:14:17:WU00:FS00:0x15:Window's signal control handler registered.
00:14:17:WU00:FS00:0x15:Preparing to commence simulation
00:14:17:WU00:FS00:0x15:- Looking at optimizations...
00:14:17:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
00:14:17:WU00:FS00:0x15:- Created dyn
00:14:17:WU00:FS00:0x15:- Files status OK
00:14:17:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:14:17:WU00:FS00:0x15:- Expanded 124758 -> 501826 (decompressed 402.2 percent)
00:14:17:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124758 data_size=501826, decompressed_data_size=501826 diff=0
00:14:17:WU00:FS00:0x15:- Digital signature verified
00:14:17:WU00:FS00:0x15:Project: 7620 (Run 272, Clone 0, Gen 311)
00:14:17:WU00:FS00:0x15:Assembly optimizations on if available.
00:14:17:WU00:FS00:0x15:Entering M.D.
00:14:19:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  612187457 1987226964 2230748091 1209787080 1827262250
00:14:19:WU00:FS00:0x15:GPU device id=0
00:14:19:WU00:FS00:0x15:Working on Protein
00:14:19:WU00:FS00:0x15:Client config unavailable.
00:14:19:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:15:17:WU00:FS00:Starting
00:15:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:17:WU00:FS00:Started FahCore on PID 3232
00:15:17:WU00:FS00:Core PID:5344
00:15:17:WU00:FS00:FahCore 0x15 started
00:15:17:WU00:FS00:0x15:
00:15:17:WU00:FS00:0x15:*------------------------------*
00:15:17:WU00:FS00:0x15:Folding@Home GPU Core
00:15:17:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:15:17:WU00:FS00:0x15:Build host             AmoebaRemote
00:15:17:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
00:15:17:WU00:FS00:0x15:Core                   15
00:15:17:WU00:FS00:0x15:Window's signal control handler registered.
00:15:17:WU00:FS00:0x15:Preparing to commence simulation
00:15:17:WU00:FS00:0x15:- Looking at optimizations...
00:15:17:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
00:15:17:WU00:FS00:0x15:- Created dyn
00:15:17:WU00:FS00:0x15:- Files status OK
00:15:17:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:15:17:WU00:FS00:0x15:- Expanded 124758 -> 501826 (decompressed 402.2 percent)
00:15:17:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=124758 data_size=501826, decompressed_data_size=501826 diff=0
00:15:17:WU00:FS00:0x15:- Digital signature verified
00:15:17:WU00:FS00:0x15:Project: 7620 (Run 272, Clone 0, Gen 311)
00:15:17:WU00:FS00:0x15:Assembly optimizations on if available.
00:15:17:WU00:FS00:0x15:Entering M.D.
00:15:19:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  612187457 1987226964 2230748091 1209787080 1827262250
00:15:19:WU00:FS00:0x15:GPU device id=0
00:15:19:WU00:FS00:0x15:Working on Protein
00:15:19:WU00:FS00:0x15:Client config unavailable.
00:15:19:WARNING:WU00:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:15:19:WARNING:WU00:FS00:Too many errors, failing
00:15:19:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:7620 run:272 clone:0 gen:311 core:0x15 unit:0x0000019d664f2dd14e42f5090d5cf322
00:15:19:WU00:FS00:Connecting to 171.64.65.105:8080
00:15:20:WU02:FS00:Connecting to 171.67.108.200:80
00:15:20:WU00:FS00:Server responded WORK_QUIT (404)
00:15:20:WARNING:WU00:FS00:Server did not like results, dumping
00:15:20:WU00:FS00:Cleaning up
00:15:21:WU02:FS00:Assigned to work server 171.67.108.52
00:15:21:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:21:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:21:WU02:FS00:Downloading 1.53MiB
00:15:25:WU02:FS00:Download complete
00:15:25:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:490 clone:0 gen:332 core:0x17 unit:0x000001cf6652edc45399e94a067f83e7
00:15:25:WU02:FS00:Starting
00:15:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:25:WU02:FS00:Started FahCore on PID 6624
00:15:25:WU02:FS00:Core PID:416
00:15:25:WU02:FS00:FahCore 0x17 started
00:15:25:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:15:25Z ***********************
00:15:25:WU02:FS00:0x17:Project: 9201 (Run 490, Clone 0, Gen 332)
00:15:25:WU02:FS00:0x17:Unit: 0x000001cf6652edc45399e94a067f83e7
00:15:25:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:15:25:WU02:FS00:0x17:Machine: 0
00:15:25:WU02:FS00:0x17:Reading tar file state.xml
00:15:26:WU02:FS00:0x17:Reading tar file system.xml
00:15:26:WU02:FS00:0x17:Reading tar file integrator.xml
00:15:26:WU02:FS00:0x17:Reading tar file core.xml
00:15:26:WU02:FS00:0x17:Digital signatures verified
00:15:26:WU02:FS00:0x17:Folding@home GPU core17
00:15:26:WU02:FS00:0x17:Version 0.0.52
00:15:26:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:15:26:WU02:FS00:0x17:Saving result file logfile_01.txt
00:15:26:WU02:FS00:0x17:Saving result file log.txt
00:15:26:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:26:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:26:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:490 clone:0 gen:332 core:0x17 unit:0x000001cf6652edc45399e94a067f83e7
00:15:26:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
00:15:26:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:26:WU00:FS00:Connecting to 171.67.108.200:80
00:15:26:WU02:FS00:Upload complete
00:15:26:WU02:FS00:Server responded WORK_ACK (400)
00:15:26:WU02:FS00:Cleaning up
00:15:27:WU00:FS00:Assigned to work server 171.67.108.52
00:15:27:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:27:WU00:FS00:Connecting to 171.67.108.52:8080
00:15:28:WU00:FS00:Downloading 1.53MiB
00:15:31:WU00:FS00:Download complete
00:15:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:376 clone:1 gen:252 core:0x17 unit:0x0000017e6652edc45399e4d59ce803d6
00:15:31:WU00:FS00:Starting
00:15:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:31:WU00:FS00:Started FahCore on PID 3028
00:15:31:WU00:FS00:Core PID:3216
00:15:31:WU00:FS00:FahCore 0x17 started
00:15:31:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:15:31Z ***********************
00:15:31:WU00:FS00:0x17:Project: 9201 (Run 376, Clone 1, Gen 252)
00:15:31:WU00:FS00:0x17:Unit: 0x0000017e6652edc45399e4d59ce803d6
00:15:31:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:15:31:WU00:FS00:0x17:Machine: 0
00:15:31:WU00:FS00:0x17:Reading tar file state.xml
00:15:31:WU00:FS00:0x17:Reading tar file system.xml
00:15:32:WU00:FS00:0x17:Reading tar file integrator.xml
00:15:32:WU00:FS00:0x17:Reading tar file core.xml
00:15:32:WU00:FS00:0x17:Digital signatures verified
00:15:32:WU00:FS00:0x17:Folding@home GPU core17
00:15:32:WU00:FS00:0x17:Version 0.0.52
00:15:32:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:15:32:WU00:FS00:0x17:Saving result file logfile_01.txt
00:15:32:WU00:FS00:0x17:Saving result file log.txt
00:15:32:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:32:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:32:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:376 clone:1 gen:252 core:0x17 unit:0x0000017e6652edc45399e4d59ce803d6
00:15:32:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:15:32:WU00:FS00:Connecting to 171.67.108.52:8080
00:15:32:WU02:FS00:Connecting to 171.67.108.200:80
00:15:32:WU00:FS00:Upload complete
00:15:32:WU00:FS00:Server responded WORK_ACK (400)
00:15:32:WU00:FS00:Cleaning up
00:15:33:WU02:FS00:Assigned to work server 171.67.108.52
00:15:33:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:33:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:34:WU02:FS00:Downloading 1.52MiB
00:15:37:WU02:FS00:Download complete
00:15:37:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:582 clone:4 gen:186 core:0x17 unit:0x000000eb6652edc45399eced6dead335
00:15:37:WU02:FS00:Starting
00:15:37:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:37:WU02:FS00:Started FahCore on PID 6384
00:15:37:WU02:FS00:Core PID:2076
00:15:37:WU02:FS00:FahCore 0x17 started
00:15:37:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:15:37Z ***********************
00:15:37:WU02:FS00:0x17:Project: 9201 (Run 582, Clone 4, Gen 186)
00:15:37:WU02:FS00:0x17:Unit: 0x000000eb6652edc45399eced6dead335
00:15:37:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:15:37:WU02:FS00:0x17:Machine: 0
00:15:37:WU02:FS00:0x17:Reading tar file state.xml
00:15:37:WU02:FS00:0x17:Reading tar file system.xml
00:15:37:WU02:FS00:0x17:Reading tar file integrator.xml
00:15:37:WU02:FS00:0x17:Reading tar file core.xml
00:15:37:WU02:FS00:0x17:Digital signatures verified
00:15:37:WU02:FS00:0x17:Folding@home GPU core17
00:15:37:WU02:FS00:0x17:Version 0.0.52
00:15:38:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:15:38:WU02:FS00:0x17:Saving result file logfile_01.txt
00:15:38:WU02:FS00:0x17:Saving result file log.txt
00:15:38:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:38:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:38:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:582 clone:4 gen:186 core:0x17 unit:0x000000eb6652edc45399eced6dead335
00:15:38:WU02:FS00:Uploading 1.97KiB to 171.67.108.52
00:15:38:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:38:WU00:FS00:Connecting to 171.67.108.200:80
00:15:38:WU02:FS00:Upload complete
00:15:38:WU02:FS00:Server responded WORK_ACK (400)
00:15:38:WU02:FS00:Cleaning up
00:15:39:WU00:FS00:Assigned to work server 171.67.108.52
00:15:39:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:39:WU00:FS00:Connecting to 171.67.108.52:8080
00:15:40:WU00:FS00:Downloading 1.53MiB
00:15:43:WU00:FS00:Download complete
00:15:43:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:903 clone:2 gen:172 core:0x17 unit:0x000000ea6652edc45399f9897e0139e4
00:15:43:WU00:FS00:Starting
00:15:43:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:43:WU00:FS00:Started FahCore on PID 1740
00:15:43:WU00:FS00:Core PID:6988
00:15:43:WU00:FS00:FahCore 0x17 started
00:15:44:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:15:43Z ***********************
00:15:44:WU00:FS00:0x17:Project: 9201 (Run 903, Clone 2, Gen 172)
00:15:44:WU00:FS00:0x17:Unit: 0x000000ea6652edc45399f9897e0139e4
00:15:44:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:15:44:WU00:FS00:0x17:Machine: 0
00:15:44:WU00:FS00:0x17:Reading tar file state.xml
00:15:44:WU00:FS00:0x17:Reading tar file system.xml
00:15:44:WU00:FS00:0x17:Reading tar file integrator.xml
00:15:44:WU00:FS00:0x17:Reading tar file core.xml
00:15:44:WU00:FS00:0x17:Digital signatures verified
00:15:44:WU00:FS00:0x17:Folding@home GPU core17
00:15:44:WU00:FS00:0x17:Version 0.0.52
00:15:44:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:15:44:WU00:FS00:0x17:Saving result file logfile_01.txt
00:15:44:WU00:FS00:0x17:Saving result file log.txt
00:15:44:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:45:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:45:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:903 clone:2 gen:172 core:0x17 unit:0x000000ea6652edc45399f9897e0139e4
00:15:45:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:15:45:WU00:FS00:Connecting to 171.67.108.52:8080
00:15:45:WU02:FS00:Connecting to 171.67.108.200:80
00:15:45:WU00:FS00:Upload complete
00:15:45:WU00:FS00:Server responded WORK_ACK (400)
00:15:45:WU00:FS00:Cleaning up
00:15:46:WU02:FS00:Assigned to work server 171.67.108.52
00:15:46:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:46:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:46:WU02:FS00:Downloading 1.52MiB
00:15:50:WU02:FS00:Download complete
00:15:50:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:460 clone:4 gen:171 core:0x17 unit:0x000000e66652edc45399e825736f7449
00:15:50:WU02:FS00:Starting
00:15:50:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:50:WU02:FS00:Started FahCore on PID 1180
00:15:50:WU02:FS00:Core PID:4296
00:15:50:WU02:FS00:FahCore 0x17 started
00:15:50:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:15:50Z ***********************
00:15:50:WU02:FS00:0x17:Project: 9201 (Run 460, Clone 4, Gen 171)
00:15:50:WU02:FS00:0x17:Unit: 0x000000e66652edc45399e825736f7449
00:15:50:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:15:50:WU02:FS00:0x17:Machine: 0
00:15:50:WU02:FS00:0x17:Reading tar file state.xml
00:15:50:WU02:FS00:0x17:Reading tar file system.xml
00:15:50:WU02:FS00:0x17:Reading tar file integrator.xml
00:15:50:WU02:FS00:0x17:Reading tar file core.xml
00:15:50:WU02:FS00:0x17:Digital signatures verified
00:15:50:WU02:FS00:0x17:Folding@home GPU core17
00:15:50:WU02:FS00:0x17:Version 0.0.52
00:15:50:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:15:51:WU02:FS00:0x17:Saving result file logfile_01.txt
00:15:51:WU02:FS00:0x17:Saving result file log.txt
00:15:51:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:51:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:51:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:460 clone:4 gen:171 core:0x17 unit:0x000000e66652edc45399e825736f7449
00:15:51:WU02:FS00:Uploading 1.97KiB to 171.67.108.52
00:15:51:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:51:WU00:FS00:Connecting to 171.67.108.200:80
00:15:51:WU02:FS00:Upload complete
00:15:51:WU02:FS00:Server responded WORK_ACK (400)
00:15:51:WU02:FS00:Cleaning up
00:15:52:WU00:FS00:Assigned to work server 171.67.108.52
00:15:52:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:52:WU00:FS00:Connecting to 171.67.108.52:8080
00:15:53:WU00:FS00:Downloading 1.52MiB
00:15:56:WU00:FS00:Download complete
00:15:56:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:960 clone:2 gen:170 core:0x17 unit:0x000001006652edc45399fbc9f30be30b
00:15:56:WU00:FS00:Starting
00:15:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:15:56:WU00:FS00:Started FahCore on PID 6608
00:15:56:WU00:FS00:Core PID:6580
00:15:56:WU00:FS00:FahCore 0x17 started
00:15:56:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:15:56Z ***********************
00:15:56:WU00:FS00:0x17:Project: 9201 (Run 960, Clone 2, Gen 170)
00:15:56:WU00:FS00:0x17:Unit: 0x000001006652edc45399fbc9f30be30b
00:15:56:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:15:56:WU00:FS00:0x17:Machine: 0
00:15:56:WU00:FS00:0x17:Reading tar file state.xml
00:15:57:WU00:FS00:0x17:Reading tar file system.xml
00:15:57:WU00:FS00:0x17:Reading tar file integrator.xml
00:15:57:WU00:FS00:0x17:Reading tar file core.xml
00:15:57:WU00:FS00:0x17:Digital signatures verified
00:15:57:WU00:FS00:0x17:Folding@home GPU core17
00:15:57:WU00:FS00:0x17:Version 0.0.52
00:15:57:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:15:57:WU00:FS00:0x17:Saving result file logfile_01.txt
00:15:57:WU00:FS00:0x17:Saving result file log.txt
00:15:57:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:57:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:57:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:960 clone:2 gen:170 core:0x17 unit:0x000001006652edc45399fbc9f30be30b
00:15:57:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:15:57:WU00:FS00:Connecting to 171.67.108.52:8080
00:15:57:WU02:FS00:Connecting to 171.67.108.200:80
00:15:57:WU00:FS00:Upload complete
00:15:57:WU00:FS00:Server responded WORK_ACK (400)
00:15:57:WU00:FS00:Cleaning up
00:15:58:WU02:FS00:Assigned to work server 171.67.108.52
00:15:58:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:15:58:WU02:FS00:Connecting to 171.67.108.52:8080
00:15:59:WU02:FS00:Downloading 1.52MiB
00:16:02:WU02:FS00:Download complete
00:16:02:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:204 clone:3 gen:164 core:0x17 unit:0x000000d76652edc45399de0a41547f3a
00:16:02:WU02:FS00:Starting
00:16:02:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:16:02:WU02:FS00:Started FahCore on PID 2432
00:16:02:WU02:FS00:Core PID:6940
00:16:02:WU02:FS00:FahCore 0x17 started
00:16:03:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:16:02Z ***********************
00:16:03:WU02:FS00:0x17:Project: 9201 (Run 204, Clone 3, Gen 164)
00:16:03:WU02:FS00:0x17:Unit: 0x000000d76652edc45399de0a41547f3a
00:16:03:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:16:03:WU02:FS00:0x17:Machine: 0
00:16:03:WU02:FS00:0x17:Reading tar file state.xml
00:16:03:WU02:FS00:0x17:Reading tar file system.xml
00:16:03:WU02:FS00:0x17:Reading tar file integrator.xml
00:16:03:WU02:FS00:0x17:Reading tar file core.xml
00:16:03:WU02:FS00:0x17:Digital signatures verified
00:16:03:WU02:FS00:0x17:Folding@home GPU core17
00:16:03:WU02:FS00:0x17:Version 0.0.52
00:16:03:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:16:03:WU02:FS00:0x17:Saving result file logfile_01.txt
00:16:03:WU02:FS00:0x17:Saving result file log.txt
00:16:03:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:16:04:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:16:04:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:204 clone:3 gen:164 core:0x17 unit:0x000000d76652edc45399de0a41547f3a
00:16:04:WU02:FS00:Uploading 1.97KiB to 171.67.108.52
00:16:04:WU02:FS00:Connecting to 171.67.108.52:8080
00:16:04:WU00:FS00:Connecting to 171.67.108.200:80
00:16:04:WU02:FS00:Upload complete
00:16:04:WU02:FS00:Server responded WORK_ACK (400)
00:16:04:WU02:FS00:Cleaning up
00:16:05:WU00:FS00:Assigned to work server 171.67.108.52
00:16:05:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:16:05:WU00:FS00:Connecting to 171.67.108.52:8080
00:16:06:WU00:FS00:Downloading 1.53MiB
00:16:09:WU00:FS00:Download complete
00:16:09:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:268 clone:4 gen:154 core:0x17 unit:0x000000d56652edc45399e0922b9e86a3
00:16:09:WU00:FS00:Starting
00:16:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:16:09:WU00:FS00:Started FahCore on PID 2032
00:16:09:WU00:FS00:Core PID:3468
00:16:09:WU00:FS00:FahCore 0x17 started
00:16:09:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:16:09Z ***********************
00:16:09:WU00:FS00:0x17:Project: 9201 (Run 268, Clone 4, Gen 154)
00:16:09:WU00:FS00:0x17:Unit: 0x000000d56652edc45399e0922b9e86a3
00:16:09:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:16:09:WU00:FS00:0x17:Machine: 0
00:16:09:WU00:FS00:0x17:Reading tar file state.xml
00:16:09:WU00:FS00:0x17:Reading tar file system.xml
00:16:10:WU00:FS00:0x17:Reading tar file integrator.xml
00:16:10:WU00:FS00:0x17:Reading tar file core.xml
00:16:10:WU00:FS00:0x17:Digital signatures verified
00:16:10:WU00:FS00:0x17:Folding@home GPU core17
00:16:10:WU00:FS00:0x17:Version 0.0.52
00:16:10:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:16:10:WU00:FS00:0x17:Saving result file logfile_01.txt
00:16:10:WU00:FS00:0x17:Saving result file log.txt
00:16:10:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:16:10:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:16:10:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:268 clone:4 gen:154 core:0x17 unit:0x000000d56652edc45399e0922b9e86a3
00:16:10:WU00:FS00:Uploading 1.97KiB to 171.67.108.52
00:16:10:WU00:FS00:Connecting to 171.67.108.52:8080
00:16:10:WU02:FS00:Connecting to 171.67.108.200:80
00:16:10:WU00:FS00:Upload complete
00:16:10:WU00:FS00:Server responded WORK_ACK (400)
00:16:10:WU00:FS00:Cleaning up
00:16:11:WU02:FS00:Assigned to work server 171.67.108.52
00:16:11:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:16:11:WU02:FS00:Connecting to 171.67.108.52:8080
00:16:12:WU02:FS00:Downloading 1.52MiB
00:16:15:WU02:FS00:Download complete
00:16:15:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:716 clone:4 gen:169 core:0x17 unit:0x000000eb6652edc45399f236c9781ffc
00:16:15:WU02:FS00:Starting
00:16:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 6636 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:16:15:WU02:FS00:Started FahCore on PID 4592
00:16:15:WU02:FS00:Core PID:1324
00:16:15:WU02:FS00:FahCore 0x17 started
00:16:16:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:16:15Z ***********************
00:16:16:WU02:FS00:0x17:Project: 9201 (Run 716, Clone 4, Gen 169)
00:16:16:WU02:FS00:0x17:Unit: 0x000000eb6652edc45399f236c9781ffc
00:16:16:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:16:16:WU02:FS00:0x17:Machine: 0
00:16:16:WU02:FS00:0x17:Reading tar file state.xml
00:16:16:WU02:FS00:0x17:Reading tar file system.xml
00:16:16:WU02:FS00:0x17:Reading tar file integrator.xml
00:16:16:WU02:FS00:0x17:Reading tar file core.xml
00:16:16:WU02:FS00:0x17:Digital signatures verified
00:16:16:WU02:FS00:0x17:Folding@home GPU core17
00:16:16:WU02:FS00:0x17:Version 0.0.52
00:16:16:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:16:16:WU02:FS00:0x17:Saving result file logfile_01.txt
00:16:16:WU02:FS00:0x17:Saving result file log.txt
00:16:16:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:16:16:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:16:16:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:716 clone:4 gen:169 core:0x17 unit:0x000000eb6652edc45399f236c9781ffc
00:16:16:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
00:16:16:WU02:FS00:Connecting to 171.67.108.52:8080
00:16:17:WU02:FS00:Upload complete
00:16:17:WU02:FS00:Server responded WORK_ACK (400)
00:16:17:WU02:FS00:Cleaning up
But, as you can see, CUDA is still absent. And the errors and fails continue. Not sure what I can do to get CUDA installed via the driver route.
Would it be worth downloading the CUDA toolkit to see if that can substitute?
Cheers
Nick
Because you had another card in there, with some other older NV Drivers, you may need to run a driver cleaner or driver sweeper program to clean up the older drivers, and allow the updated drivers to install correctly.
Both the bad platform id error and the no CUDA showing are driver related issues.
Nick200
Post by Nick200 »
Hmm. So I tried to install CUDA 6.5 - big download - and a waste.
All I got was an odd error message that
This graphics driver could not find compatible graphics hardware.  You may continue installation, but you will not be able to run CUDA applications.
So, completely am stumped. Worth trying the 344.80 interim fix driver?
Good thing it's sunny outside - think I'll get more done down at the beach!
Nick
Nick200
Post by Nick200 »
Hi 7im
Yes, good advice. But I had uninstalled the nvidia driver before installing the 980 and run CCleaner on the registry.
Just to make sure, I have just run DDU v13.6.1.0 from safe mode - that cleaner took out any residual junk, I think. And then I re-installed driver 347.09.
But that does not appear to have fixed things as FAH reports CUDA as not detected:
*********************** Log Started 2015-01-16T00:53:30Z ***********************
00:53:30:************************* Folding@home Client *************************
00:53:30:      Website: http://folding.stanford.edu/
00:53:30:    Copyright: (c) 2009-2014 Stanford University
00:53:30:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:53:30:         Args:
00:53:30:       Config: C:/ProgramData/FAHClient/config.xml
00:53:30:******************************** Build ********************************
00:53:30:      Version: 7.4.4
00:53:30:         Date: Mar 4 2014
00:53:30:         Time: 20:26:54
00:53:30:      SVN Rev: 4130
00:53:30:       Branch: fah/trunk/client
00:53:30:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:53:30:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:53:30:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:53:30:     Platform: win32 XP
00:53:30:         Bits: 32
00:53:30:         Mode: Release
00:53:30:******************************* System ********************************
00:53:30:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
00:53:30:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:53:30:         CPUs: 8
00:53:30:       Memory: 15.89GiB
00:53:30:  Free Memory: 13.93GiB
00:53:30:      Threads: WINDOWS_THREADS
00:53:30:   OS Version: 6.2
00:53:30:  Has Battery: false
00:53:30:   On Battery: false
00:53:30:   UTC Offset: 13
00:53:30:          PID: 7148
00:53:30:          CWD: C:/ProgramData/FAHClient
00:53:30:           OS: Windows 8.1 Pro with Media Center
00:53:30:      OS Arch: AMD64
00:53:30:         GPUs: 1
00:53:30:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
00:53:30:         CUDA: Not detected
00:53:30:Win32 Service: false
00:53:30:***********************************************************************
00:53:30:<config>
00:53:30:  <!-- Folding Slot Configuration -->
00:53:30:  <client-type v='advanced'/>
00:53:30:
00:53:30:  <!-- Network -->
00:53:30:  <proxy v=':8080'/>
00:53:30:
00:53:30:  <!-- Slot Control -->
00:53:30:  <power v='full'/>
00:53:30:
00:53:30:  <!-- User Information -->
00:53:30:  <passkey v='********************************'/>
00:53:30:  <team v='142900'/>
00:53:30:  <user v='Montague-Cripps'/>
00:53:30:
00:53:30:  <!-- Folding Slots -->
00:53:30:  <slot id='1' type='CPU'>
00:53:30:    <paused v='true'/>
00:53:30:  </slot>
00:53:30:  <slot id='0' type='GPU'>
00:53:30:  </slot>
00:53:30:</config>
00:53:30:Trying to access database...
00:53:30:Successfully acquired database lock
00:53:30:Enabled folding slot 01: PAUSED cpu:7 (by user)
00:53:30:Enabled folding slot 00: PAUSED gpu:0:GM204 [GeForce GTX 980] (by user)
00:55:16:FS01:Unpaused
00:55:16:FS00:Unpaused
00:55:16:WU01:FS01:Starting
00:55:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -np 7
00:55:16:WU01:FS01:Started FahCore on PID 4584
00:55:16:WU01:FS01:Core PID:292
00:55:16:WU01:FS01:FahCore 0xa3 started
00:55:16:WU01:FS01:0xa3:
00:55:16:WU01:FS01:0xa3:*------------------------------*
00:55:16:WU01:FS01:0xa3:Folding@Home Gromacs SMP Core
00:55:16:WU01:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
00:55:16:WU01:FS01:0xa3:Preparing to commence simulation
00:55:16:WU01:FS01:0xa3:- Looking at optimizations...
00:55:16:WU01:FS01:0xa3:- Files status OK
00:55:16:WU01:FS01:0xa3:- Expanded 3552200 -> 3880552 (decompressed 109.2 percent)
00:55:16:WU01:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3552200 data_size=3880552, decompressed_data_size=3880552 diff=0
00:55:16:WU01:FS01:0xa3:- Digital signature verified
00:55:16:WU01:FS01:0xa3:Project: 7505 (Run 0, Clone 4, Gen 414)
00:55:16:WU01:FS01:0xa3:Assembly optimizations on if available.
00:55:16:WU01:FS01:0xa3:Entering M.D.
00:55:17:WU00:FS00:Connecting to 171.67.108.200:80
00:55:17:WU00:FS00:Assigned to work server 171.67.108.52
00:55:17:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:17:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:18:WU00:FS00:Downloading 1.52MiB
00:55:22:WU00:FS00:Download complete
00:55:22:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:9 clone:2 gen:178 core:0x17 unit:0x0000010b6652edc45399d668e778f37c
00:55:22:WU00:FS00:Starting
00:55:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:55:22:WU00:FS00:Started FahCore on PID 6192
00:55:22:WU00:FS00:Core PID:2684
00:55:22:WU00:FS00:FahCore 0x17 started
00:55:22:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:55:22Z ***********************
00:55:22:WU00:FS00:0x17:Project: 9201 (Run 9, Clone 2, Gen 178)
00:55:22:WU00:FS00:0x17:Unit: 0x0000010b6652edc45399d668e778f37c
00:55:22:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:55:22:WU00:FS00:0x17:Machine: 0
00:55:22:WU00:FS00:0x17:Reading tar file state.xml
00:55:22:WU00:FS00:0x17:Reading tar file system.xml
00:55:22:WU01:FS01:0xa3:Using Gromacs checkpoints
00:55:23:WU00:FS00:0x17:Reading tar file integrator.xml
00:55:23:WU00:FS00:0x17:Reading tar file core.xml
00:55:23:WU00:FS00:0x17:Digital signatures verified
00:55:23:WU00:FS00:0x17:Folding@home GPU core17
00:55:23:WU00:FS00:0x17:Version 0.0.52
00:55:23:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:55:23:WU00:FS00:0x17:Saving result file logfile_01.txt
00:55:23:WU00:FS00:0x17:Saving result file log.txt
00:55:23:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:55:23:WU01:FS01:0xa3:Mapping NT from 7 to 7
00:55:23:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:55:23:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:9 clone:2 gen:178 core:0x17 unit:0x0000010b6652edc45399d668e778f37c
00:55:23:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:55:23:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:23:WU01:FS01:0xa3:Resuming from checkpoint
00:55:23:WU01:FS01:0xa3:Verified 01/wudata_01.log
00:55:23:WU02:FS00:Connecting to 171.67.108.200:80
00:55:23:WU01:FS01:0xa3:Verified 01/wudata_01.trr
00:55:23:WU01:FS01:0xa3:Verified 01/wudata_01.xtc
00:55:23:WU01:FS01:0xa3:Verified 01/wudata_01.edr
00:55:23:WU00:FS00:Upload complete
00:55:23:WU00:FS00:Server responded WORK_ACK (400)
00:55:23:WU00:FS00:Cleaning up
00:55:23:WU01:FS01:0xa3:Completed 505350 out of 1000000 steps  (50%)
00:55:24:WU02:FS00:Assigned to work server 171.67.108.52
00:55:24:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:24:WU02:FS00:Connecting to 171.67.108.52:8080
00:55:25:WU02:FS00:Downloading 1.52MiB
00:55:28:WU02:FS00:Download complete
00:55:28:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:716 clone:3 gen:154 core:0x17 unit:0x000000e46652edc45399f234bd47cd81
00:55:28:WU02:FS00:Starting
00:55:28:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:55:28:WU02:FS00:Started FahCore on PID 1160
00:55:28:WU02:FS00:Core PID:2656
00:55:28:WU02:FS00:FahCore 0x17 started
00:55:29:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:55:28Z ***********************
00:55:29:WU02:FS00:0x17:Project: 9201 (Run 716, Clone 3, Gen 154)
00:55:29:WU02:FS00:0x17:Unit: 0x000000e46652edc45399f234bd47cd81
00:55:29:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:55:29:WU02:FS00:0x17:Machine: 0
00:55:29:WU02:FS00:0x17:Reading tar file state.xml
00:55:29:WU02:FS00:0x17:Reading tar file system.xml
00:55:29:WU02:FS00:0x17:Reading tar file integrator.xml
00:55:29:WU02:FS00:0x17:Reading tar file core.xml
00:55:29:WU02:FS00:0x17:Digital signatures verified
00:55:29:WU02:FS00:0x17:Folding@home GPU core17
00:55:29:WU02:FS00:0x17:Version 0.0.52
00:55:29:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:55:29:WU02:FS00:0x17:Saving result file logfile_01.txt
00:55:29:WU02:FS00:0x17:Saving result file log.txt
00:55:29:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:55:29:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:55:29:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:716 clone:3 gen:154 core:0x17 unit:0x000000e46652edc45399f234bd47cd81
00:55:29:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
00:55:29:WU02:FS00:Connecting to 171.67.108.52:8080
00:55:30:WU00:FS00:Connecting to 171.67.108.200:80
00:55:30:WU02:FS00:Upload complete
00:55:30:WU02:FS00:Server responded WORK_ACK (400)
00:55:30:WU02:FS00:Cleaning up
00:55:30:WU00:FS00:Assigned to work server 171.67.108.52
00:55:30:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:30:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:31:WU00:FS00:Downloading 1.53MiB
00:55:32:Removing old file 'configs/config-20150105-143643.xml'
00:55:32:Saving configuration to config.xml
00:55:32:<config>
00:55:32:  <!-- Folding Slot Configuration -->
00:55:32:  <client-type v='advanced'/>
00:55:32:
00:55:32:  <!-- Network -->
00:55:32:  <proxy v=':8080'/>
00:55:32:
00:55:32:  <!-- Slot Control -->
00:55:32:  <power v='full'/>
00:55:32:
00:55:32:  <!-- User Information -->
00:55:32:  <passkey v='********************************'/>
00:55:32:  <team v='142900'/>
00:55:32:  <user v='Montague-Cripps'/>
00:55:32:
00:55:32:  <!-- Folding Slots -->
00:55:32:  <slot id='1' type='CPU'/>
00:55:32:  <slot id='0' type='GPU'/>
00:55:32:</config>
00:55:34:WU00:FS00:Download complete
00:55:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:205 clone:2 gen:153 core:0x17 unit:0x000000de6652edc45399de12ba7fad94
00:55:34:WU00:FS00:Starting
00:55:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:55:34:WU00:FS00:Started FahCore on PID 5928
00:55:35:WU00:FS00:Core PID:1376
00:55:35:WU00:FS00:FahCore 0x17 started
00:55:35:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:55:35Z ***********************
00:55:35:WU00:FS00:0x17:Project: 9201 (Run 205, Clone 2, Gen 153)
00:55:35:WU00:FS00:0x17:Unit: 0x000000de6652edc45399de12ba7fad94
00:55:35:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:55:35:WU00:FS00:0x17:Machine: 0
00:55:35:WU00:FS00:0x17:Reading tar file state.xml
00:55:35:WU00:FS00:0x17:Reading tar file system.xml
00:55:35:WU00:FS00:0x17:Reading tar file integrator.xml
00:55:35:WU00:FS00:0x17:Reading tar file core.xml
00:55:35:WU00:FS00:0x17:Digital signatures verified
00:55:35:WU00:FS00:0x17:Folding@home GPU core17
00:55:35:WU00:FS00:0x17:Version 0.0.52
00:55:35:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:55:35:WU00:FS00:0x17:Saving result file logfile_01.txt
00:55:35:WU00:FS00:0x17:Saving result file log.txt
00:55:35:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:55:36:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:55:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:205 clone:2 gen:153 core:0x17 unit:0x000000de6652edc45399de12ba7fad94
00:55:36:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:55:36:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:37:WU02:FS00:Connecting to 171.67.108.200:80
00:55:37:WU00:FS00:Upload complete
00:55:37:WU00:FS00:Server responded WORK_ACK (400)
00:55:37:WU00:FS00:Cleaning up
00:55:38:WU02:FS00:Assigned to work server 171.67.108.52
00:55:38:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:38:WU02:FS00:Connecting to 171.67.108.52:8080
00:55:39:WU02:FS00:Downloading 1.53MiB
00:55:41:WU02:FS00:Download complete
00:55:42:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:451 clone:2 gen:153 core:0x17 unit:0x000000d36652edc45399e7c7826783e5
00:55:42:WU02:FS00:Starting
00:55:42:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:55:42:WU02:FS00:Started FahCore on PID 3916
00:55:42:WU02:FS00:Core PID:3988
00:55:42:WU02:FS00:FahCore 0x17 started
00:55:42:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:55:42Z ***********************
00:55:42:WU02:FS00:0x17:Project: 9201 (Run 451, Clone 2, Gen 153)
00:55:42:WU02:FS00:0x17:Unit: 0x000000d36652edc45399e7c7826783e5
00:55:42:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:55:42:WU02:FS00:0x17:Machine: 0
00:55:42:WU02:FS00:0x17:Reading tar file state.xml
00:55:42:WU02:FS00:0x17:Reading tar file system.xml
00:55:42:WU02:FS00:0x17:Reading tar file integrator.xml
00:55:42:WU02:FS00:0x17:Reading tar file core.xml
00:55:42:WU02:FS00:0x17:Digital signatures verified
00:55:42:WU02:FS00:0x17:Folding@home GPU core17
00:55:42:WU02:FS00:0x17:Version 0.0.52
00:55:42:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:55:42:WU02:FS00:0x17:Saving result file logfile_01.txt
00:55:42:WU02:FS00:0x17:Saving result file log.txt
00:55:42:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:55:43:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:55:43:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:451 clone:2 gen:153 core:0x17 unit:0x000000d36652edc45399e7c7826783e5
00:55:43:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
00:55:43:WU02:FS00:Connecting to 171.67.108.52:8080
00:55:43:WU00:FS00:Connecting to 171.67.108.200:80
00:55:43:WU02:FS00:Upload complete
00:55:43:WU02:FS00:Server responded WORK_ACK (400)
00:55:43:WU02:FS00:Cleaning up
00:55:44:WU00:FS00:Assigned to work server 171.67.108.52
00:55:44:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:44:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:45:WU00:FS00:Downloading 1.52MiB
00:55:48:WU00:FS00:Download complete
00:55:48:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:782 clone:1 gen:214 core:0x17 unit:0x000001386652edc45399f4c9124d03ff
00:55:48:WU00:FS00:Starting
00:55:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:55:48:WU00:FS00:Started FahCore on PID 2760
00:55:48:WU00:FS00:Core PID:2472
00:55:48:WU00:FS00:FahCore 0x17 started
00:55:49:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:55:48Z ***********************
00:55:49:WU00:FS00:0x17:Project: 9201 (Run 782, Clone 1, Gen 214)
00:55:49:WU00:FS00:0x17:Unit: 0x000001386652edc45399f4c9124d03ff
00:55:49:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:55:49:WU00:FS00:0x17:Machine: 0
00:55:49:WU00:FS00:0x17:Reading tar file state.xml
00:55:49:WU00:FS00:0x17:Reading tar file system.xml
00:55:49:WU00:FS00:0x17:Reading tar file integrator.xml
00:55:49:WU00:FS00:0x17:Reading tar file core.xml
00:55:49:WU00:FS00:0x17:Digital signatures verified
00:55:49:WU00:FS00:0x17:Folding@home GPU core17
00:55:49:WU00:FS00:0x17:Version 0.0.52
00:55:49:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:55:49:WU00:FS00:0x17:Saving result file logfile_01.txt
00:55:49:WU00:FS00:0x17:Saving result file log.txt
00:55:49:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:55:49:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:55:49:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:782 clone:1 gen:214 core:0x17 unit:0x000001386652edc45399f4c9124d03ff
00:55:49:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:55:49:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:50:WU02:FS00:Connecting to 171.67.108.200:80
00:55:50:WU00:FS00:Upload complete
00:55:50:WU00:FS00:Server responded WORK_ACK (400)
00:55:50:WU00:FS00:Cleaning up
00:55:50:WU02:FS00:Assigned to work server 171.67.108.52
00:55:50:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:50:WU02:FS00:Connecting to 171.67.108.52:8080
00:55:51:WU02:FS00:Downloading 1.52MiB
00:55:54:WU02:FS00:Download complete
00:55:54:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:448 clone:3 gen:112 core:0x17 unit:0x000000aa6652edc45399e7aa88c85d79
00:55:54:WU02:FS00:Starting
00:55:54:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:55:55:WU02:FS00:Started FahCore on PID 1252
00:55:55:WU02:FS00:Core PID:2400
00:55:55:WU02:FS00:FahCore 0x17 started
00:55:55:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:55:55Z ***********************
00:55:55:WU02:FS00:0x17:Project: 9201 (Run 448, Clone 3, Gen 112)
00:55:55:WU02:FS00:0x17:Unit: 0x000000aa6652edc45399e7aa88c85d79
00:55:55:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:55:55:WU02:FS00:0x17:Machine: 0
00:55:55:WU02:FS00:0x17:Reading tar file state.xml
00:55:56:WU02:FS00:0x17:Reading tar file system.xml
00:55:56:WU02:FS00:0x17:Reading tar file integrator.xml
00:55:56:WU02:FS00:0x17:Reading tar file core.xml
00:55:56:WU02:FS00:0x17:Digital signatures verified
00:55:56:WU02:FS00:0x17:Folding@home GPU core17
00:55:56:WU02:FS00:0x17:Version 0.0.52
00:55:56:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:55:56:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:55:56:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:448 clone:3 gen:112 core:0x17 unit:0x000000aa6652edc45399e7aa88c85d79
00:55:56:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
00:55:56:WU02:FS00:Connecting to 171.67.108.52:8080
00:55:56:WU00:FS00:Connecting to 171.67.108.200:80
00:55:56:WU02:FS00:Upload complete
00:55:56:WU02:FS00:Server responded WORK_ACK (400)
00:55:56:WU02:FS00:Cleaning up
00:55:57:WU00:FS00:Assigned to work server 171.67.108.52
00:55:57:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:55:57:WU00:FS00:Connecting to 171.67.108.52:8080
00:55:58:WU00:FS00:Downloading 1.52MiB
00:56:01:WU00:FS00:Download complete
00:56:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:554 clone:2 gen:128 core:0x17 unit:0x000000c46652edc45399ebd05035c263
00:56:01:WU00:FS00:Starting
00:56:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:56:01:WU00:FS00:Started FahCore on PID 4084
00:56:01:WU00:FS00:Core PID:7036
00:56:01:WU00:FS00:FahCore 0x17 started
00:56:01:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:56:01Z ***********************
00:56:01:WU00:FS00:0x17:Project: 9201 (Run 554, Clone 2, Gen 128)
00:56:01:WU00:FS00:0x17:Unit: 0x000000c46652edc45399ebd05035c263
00:56:01:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:56:01:WU00:FS00:0x17:Machine: 0
00:56:01:WU00:FS00:0x17:Reading tar file state.xml
00:56:02:WU00:FS00:0x17:Reading tar file system.xml
00:56:02:WU00:FS00:0x17:Reading tar file integrator.xml
00:56:02:WU00:FS00:0x17:Reading tar file core.xml
00:56:02:WU00:FS00:0x17:Digital signatures verified
00:56:02:WU00:FS00:0x17:Folding@home GPU core17
00:56:02:WU00:FS00:0x17:Version 0.0.52
00:56:02:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:56:02:WU00:FS00:0x17:Saving result file logfile_01.txt
00:56:02:WU00:FS00:0x17:Saving result file log.txt
00:56:02:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:56:02:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:56:02:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:554 clone:2 gen:128 core:0x17 unit:0x000000c46652edc45399ebd05035c263
00:56:02:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:56:02:WU00:FS00:Connecting to 171.67.108.52:8080
00:56:02:WU02:FS00:Connecting to 171.67.108.200:80
00:56:03:WU00:FS00:Upload complete
00:56:03:WU00:FS00:Server responded WORK_ACK (400)
00:56:03:WU00:FS00:Cleaning up
00:56:03:WU02:FS00:Assigned to work server 171.67.108.52
00:56:03:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:56:03:WU02:FS00:Connecting to 171.67.108.52:8080
00:56:04:WU02:FS00:Downloading 1.53MiB
00:56:07:WU02:FS00:Download complete
00:56:07:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:927 clone:3 gen:117 core:0x17 unit:0x000000ae6652edc45399fa7b76e58dde
00:56:07:WU02:FS00:Starting
00:56:07:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:56:07:WU02:FS00:Started FahCore on PID 2492
00:56:08:WU02:FS00:Core PID:3956
00:56:08:WU02:FS00:FahCore 0x17 started
00:56:08:WU02:FS00:0x17:*********************** Log Started 2015-01-16T00:56:08Z ***********************
00:56:08:WU02:FS00:0x17:Project: 9201 (Run 927, Clone 3, Gen 117)
00:56:08:WU02:FS00:0x17:Unit: 0x000000ae6652edc45399fa7b76e58dde
00:56:08:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:56:08:WU02:FS00:0x17:Machine: 0
00:56:08:WU02:FS00:0x17:Reading tar file state.xml
00:56:08:WU02:FS00:0x17:Reading tar file system.xml
00:56:08:WU02:FS00:0x17:Reading tar file integrator.xml
00:56:08:WU02:FS00:0x17:Reading tar file core.xml
00:56:08:WU02:FS00:0x17:Digital signatures verified
00:56:08:WU02:FS00:0x17:Folding@home GPU core17
00:56:08:WU02:FS00:0x17:Version 0.0.52
00:56:08:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
00:56:09:WU02:FS00:0x17:Saving result file logfile_01.txt
00:56:09:WU02:FS00:0x17:Saving result file log.txt
00:56:09:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:56:09:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:56:09:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:927 clone:3 gen:117 core:0x17 unit:0x000000ae6652edc45399fa7b76e58dde
00:56:09:WU02:FS00:Uploading 1.98KiB to 171.67.108.52
00:56:09:WU02:FS00:Connecting to 171.67.108.52:8080
00:56:09:WU00:FS00:Connecting to 171.67.108.200:80
00:56:09:WU02:FS00:Upload complete
00:56:09:WU02:FS00:Server responded WORK_ACK (400)
00:56:09:WU02:FS00:Cleaning up
00:56:10:WU00:FS00:Assigned to work server 171.67.108.52
00:56:10:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
00:56:10:WU00:FS00:Connecting to 171.67.108.52:8080
00:56:10:WU00:FS00:Downloading 1.52MiB
00:56:14:WU00:FS00:Download complete
00:56:14:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:288 clone:3 gen:165 core:0x17 unit:0x000000e26652edc45399e16268054d95
00:56:14:WU00:FS00:Starting
00:56:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:56:14:WU00:FS00:Started FahCore on PID 156
00:56:14:WU00:FS00:Core PID:1508
00:56:14:WU00:FS00:FahCore 0x17 started
00:56:14:WU00:FS00:0x17:*********************** Log Started 2015-01-16T00:56:14Z ***********************
00:56:14:WU00:FS00:0x17:Project: 9201 (Run 288, Clone 3, Gen 165)
00:56:14:WU00:FS00:0x17:Unit: 0x000000e26652edc45399e16268054d95
00:56:14:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:56:14:WU00:FS00:0x17:Machine: 0
00:56:14:WU00:FS00:0x17:Reading tar file state.xml
00:56:14:WU00:FS00:0x17:Reading tar file system.xml
00:56:14:WU00:FS00:0x17:Reading tar file integrator.xml
00:56:14:WU00:FS00:0x17:Reading tar file core.xml
00:56:14:WU00:FS00:0x17:Digital signatures verified
00:56:14:WU00:FS00:0x17:Folding@home GPU core17
00:56:14:WU00:FS00:0x17:Version 0.0.52
00:56:14:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
00:56:15:WU00:FS00:0x17:Saving result file logfile_01.txt
00:56:15:WU00:FS00:0x17:Saving result file log.txt
00:56:15:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:56:15:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:56:15:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:288 clone:3 gen:165 core:0x17 unit:0x000000e26652edc45399e16268054d95
00:56:15:WU00:FS00:Uploading 1.98KiB to 171.67.108.52
00:56:15:WU00:FS00:Connecting to 171.67.108.52:8080
00:56:15:WU02:FS00:Connecting to 171.67.108.200:80
00:56:15:WU00:FS00:Upload complete
00:56:15:WU00:FS00:Server responded WORK_ACK (400)
00:56:15:WU00:FS00:Cleaning up
00:56:16:WU02:FS00:Assigned to work server 171.64.65.105
00:56:16:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 171.64.65.105
00:56:16:WU02:FS00:Connecting to 171.64.65.105:8080
00:56:17:WU02:FS00:Downloading 124.73KiB
00:56:18:WU02:FS00:Download complete
00:56:18:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:7626 run:162 clone:0 gen:428 core:0x15 unit:0x0000028f664f2dd14fe61aacd86cf0de
00:56:18:WU02:FS00:Starting
00:56:18:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:56:18:WU02:FS00:Started FahCore on PID 596
00:56:18:WU02:FS00:Core PID:6128
00:56:18:WU02:FS00:FahCore 0x15 started
00:56:19:WU02:FS00:0x15:
00:56:19:WU02:FS00:0x15:*------------------------------*
00:56:19:WU02:FS00:0x15:Folding@Home GPU Core
00:56:19:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:56:19:WU02:FS00:0x15:Build host             AmoebaRemote
00:56:19:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
00:56:19:WU02:FS00:0x15:Core                   15
00:56:19:WU02:FS00:0x15:Window's signal control handler registered.
00:56:19:WU02:FS00:0x15:Preparing to commence simulation
00:56:19:WU02:FS00:0x15:- Looking at optimizations...
00:56:19:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
00:56:19:WU02:FS00:0x15:- Created dyn
00:56:19:WU02:FS00:0x15:- Files status OK
00:56:19:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:56:19:WU02:FS00:0x15:- Expanded 127209 -> 507182 (decompressed 398.6 percent)
00:56:19:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=127209 data_size=507182, decompressed_data_size=507182 diff=0
00:56:19:WU02:FS00:0x15:- Digital signature verified
00:56:19:WU02:FS00:0x15:Project: 7626 (Run 162, Clone 0, Gen 428)
00:56:19:WU02:FS00:0x15:Assembly optimizations on if available.
00:56:19:WU02:FS00:0x15:Entering M.D.
00:56:21:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  940086237 3864210142 582985403 3486174122 3651091778
00:56:21:WU02:FS00:0x15:GPU device id=0
00:56:21:WU02:FS00:0x15:Working on Protein
00:56:21:WU02:FS00:0x15:Client config unavailable.
00:56:21:WU02:FS00:0x15:Starting GUI Server
00:56:21:WU02:FS00:0x15:Finished fah_main status=59
00:56:21:WU02:FS00:0x15:mdrun_gpu returned 59
00:56:21:WU02:FS00:0x15:GPU memtest failure
00:56:21:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:56:21:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:56:21:WU02:FS00:Starting
00:56:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:56:21:WU02:FS00:Started FahCore on PID 4664
00:56:21:WU02:FS00:Core PID:1160
00:56:21:WU02:FS00:FahCore 0x15 started
00:56:22:WU02:FS00:0x15:
00:56:22:WU02:FS00:0x15:*------------------------------*
00:56:22:WU02:FS00:0x15:Folding@Home GPU Core
00:56:22:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:56:22:WU02:FS00:0x15:Build host             AmoebaRemote
00:56:22:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
00:56:22:WU02:FS00:0x15:Core                   15
00:56:22:WU02:FS00:0x15:Window's signal control handler registered.
00:56:22:WU02:FS00:0x15:Preparing to commence simulation
00:56:22:WU02:FS00:0x15:- Looking at optimizations...
00:56:22:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
00:56:22:WU02:FS00:0x15:- Created dyn
00:56:22:WU02:FS00:0x15:- Files status OK
00:56:22:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:56:22:WU02:FS00:0x15:- Expanded 127209 -> 507182 (decompressed 398.6 percent)
00:56:22:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=127209 data_size=507182, decompressed_data_size=507182 diff=0
00:56:22:WU02:FS00:0x15:- Digital signature verified
00:56:22:WU02:FS00:0x15:Project: 7626 (Run 162, Clone 0, Gen 428)
00:56:22:WU02:FS00:0x15:Assembly optimizations on if available.
00:56:22:WU02:FS00:0x15:Entering M.D.
00:56:24:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  940086237 3864210142 582985403 3486174122 3651091778
00:56:24:WU02:FS00:0x15:GPU device id=0
00:56:24:WU02:FS00:0x15:Working on Protein
00:56:24:WU02:FS00:0x15:Client config unavailable.
00:56:24:WU02:FS00:0x15:Finished fah_main status=59
00:56:24:WU02:FS00:0x15:mdrun_gpu returned 59
00:56:24:WU02:FS00:0x15:GPU memtest failure
00:56:24:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:56:24:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:57:22:WU02:FS00:Starting
00:57:22:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:57:22:WU02:FS00:Started FahCore on PID 4460
00:57:22:WU02:FS00:Core PID:1776
00:57:22:WU02:FS00:FahCore 0x15 started
00:57:22:WU02:FS00:0x15:
00:57:22:WU02:FS00:0x15:*------------------------------*
00:57:22:WU02:FS00:0x15:Folding@Home GPU Core
00:57:22:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:57:22:WU02:FS00:0x15:Build host             AmoebaRemote
00:57:22:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
00:57:22:WU02:FS00:0x15:Core                   15
00:57:22:WU02:FS00:0x15:Window's signal control handler registered.
00:57:22:WU02:FS00:0x15:Preparing to commence simulation
00:57:22:WU02:FS00:0x15:- Looking at optimizations...
00:57:22:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
00:57:22:WU02:FS00:0x15:- Created dyn
00:57:22:WU02:FS00:0x15:- Files status OK
00:57:22:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:57:22:WU02:FS00:0x15:- Expanded 127209 -> 507182 (decompressed 398.6 percent)
00:57:22:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=127209 data_size=507182, decompressed_data_size=507182 diff=0
00:57:22:WU02:FS00:0x15:- Digital signature verified
00:57:22:WU02:FS00:0x15:Project: 7626 (Run 162, Clone 0, Gen 428)
00:57:22:WU02:FS00:0x15:Assembly optimizations on if available.
00:57:22:WU02:FS00:0x15:Entering M.D.
00:57:24:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  940086237 3864210142 582985403 3486174122 3651091778
00:57:24:WU02:FS00:0x15:GPU device id=0
00:57:24:WU02:FS00:0x15:Working on Protein
00:57:24:WU02:FS00:0x15:Client config unavailable.
00:57:24:WU02:FS00:0x15:Finished fah_main status=59
00:57:24:WU02:FS00:0x15:mdrun_gpu returned 59
00:57:24:WU02:FS00:0x15:GPU memtest failure
00:57:24:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:57:24:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:58:22:WU02:FS00:Starting
00:58:22:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:58:22:WU02:FS00:Started FahCore on PID 2568
00:58:22:WU02:FS00:Core PID:5728
00:58:22:WU02:FS00:FahCore 0x15 started
00:58:22:WU02:FS00:0x15:
00:58:22:WU02:FS00:0x15:*------------------------------*
00:58:22:WU02:FS00:0x15:Folding@Home GPU Core
00:58:22:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:58:22:WU02:FS00:0x15:Build host             AmoebaRemote
00:58:22:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
00:58:22:WU02:FS00:0x15:Core                   15
00:58:22:WU02:FS00:0x15:Window's signal control handler registered.
00:58:22:WU02:FS00:0x15:Preparing to commence simulation
00:58:22:WU02:FS00:0x15:- Looking at optimizations...
00:58:22:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
00:58:22:WU02:FS00:0x15:- Created dyn
00:58:22:WU02:FS00:0x15:- Files status OK
00:58:22:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:58:22:WU02:FS00:0x15:- Expanded 127209 -> 507182 (decompressed 398.6 percent)
00:58:22:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=127209 data_size=507182, decompressed_data_size=507182 diff=0
00:58:22:WU02:FS00:0x15:- Digital signature verified
00:58:22:WU02:FS00:0x15:Project: 7626 (Run 162, Clone 0, Gen 428)
00:58:22:WU02:FS00:0x15:Assembly optimizations on if available.
00:58:22:WU02:FS00:0x15:Entering M.D.
00:58:24:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  940086237 3864210142 582985403 3486174122 3651091778
00:58:24:WU02:FS00:0x15:GPU device id=0
00:58:24:WU02:FS00:0x15:Working on Protein
00:58:24:WU02:FS00:0x15:Client config unavailable.
00:58:24:WU02:FS00:0x15:Finished fah_main status=59
00:58:24:WU02:FS00:0x15:mdrun_gpu returned 59
00:58:24:WU02:FS00:0x15:GPU memtest failure
00:58:24:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:58:24:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:59:22:WU02:FS00:Starting
00:59:22:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 7148 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:59:22:WU02:FS00:Started FahCore on PID 1160
00:59:22:WU02:FS00:Core PID:5820
00:59:22:WU02:FS00:FahCore 0x15 started
00:59:22:WU02:FS00:0x15:
00:59:22:WU02:FS00:0x15:*------------------------------*
00:59:22:WU02:FS00:0x15:Folding@Home GPU Core
00:59:22:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:59:22:WU02:FS00:0x15:Build host             AmoebaRemote
00:59:22:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
00:59:22:WU02:FS00:0x15:Core                   15
00:59:22:WU02:FS00:0x15:Window's signal control handler registered.
00:59:22:WU02:FS00:0x15:Preparing to commence simulation
00:59:22:WU02:FS00:0x15:- Looking at optimizations...
00:59:22:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
00:59:22:WU02:FS00:0x15:- Created dyn
00:59:22:WU02:FS00:0x15:- Files status OK
00:59:22:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:59:22:WU02:FS00:0x15:- Expanded 127209 -> 507182 (decompressed 398.6 percent)
00:59:22:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=127209 data_size=507182, decompressed_data_size=507182 diff=0
00:59:22:WU02:FS00:0x15:- Digital signature verified
00:59:22:WU02:FS00:0x15:Project: 7626 (Run 162, Clone 0, Gen 428)
00:59:22:WU02:FS00:0x15:Assembly optimizations on if available.
00:59:22:WU02:FS00:0x15:Entering M.D.
00:59:24:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  940086237 3864210142 582985403 3486174122 3651091778
00:59:24:WU02:FS00:0x15:GPU device id=0
00:59:24:WU02:FS00:0x15:Working on Protein
00:59:24:WU02:FS00:0x15:Client config unavailable.
00:59:24:WU02:FS00:0x15:Finished fah_main status=59
00:59:24:WU02:FS00:0x15:mdrun_gpu returned 59
00:59:24:WU02:FS00:0x15:GPU memtest failure
00:59:24:WU02:FS00:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
00:59:25:WARNING:WU02:FS00:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
00:59:25:WARNING:WU02:FS00:Too many errors, failing
00:59:25:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:7626 run:162 clone:0 gen:428 core:0x15 unit:0x0000028f664f2dd14fe61aacd86cf0de
00:59:25:WU02:FS00:Connecting to 171.64.65.105:8080
00:59:25:WU02:FS00:Server responded WORK_QUIT (404)
00:59:25:WARNING:WU02:FS00:Server did not like results, dumping
00:59:25:WU02:FS00:Cleaning up
I am loath to try a full Windows re-install. Before I do that, any other suggestions? Is there a better driver uninstaller to try?
Cheers
Nick
Re: Problems with new GTX 980
When you installed the 980 to replace the 770, did you remove the original GPU folding slot and create a new one? Or did you reinstall the folding client? Some odd problems after changing video cards have been fixed by completely uninstalling the F@H client and then reinstalling. For a full reinstall, set the CPU slot to Finish and once it is done uninstall including the data before installing the client again. If you ddi not delete the original GPU slot at all, possibly deleting it and recreating one would be enough to clear out any settings associated with the 770.
Nick200
Post by Nick200 »
OK, latest steps taken:
  • uninstalled nvidia driver and software
    uninstalled all FAH software including data
    ran DDU uninstaller again
    ran CCleaner
    re-installed 347.09 using clean install option
    re-installed FAH
Unfortunately, the outcome from all that is that the problem is not solved, with CUDA still absent and constant bad work units and other error messages.
Noticed an odd thing in GeForce Experience, though, which reports a driver update is available (!). That takes me to 347.09 - running that once more neither clears the folding errors nor removes the update message from GeForce Experience. May be relevant....
I may try the card in another low spec PC - any views? Or other suggestions?
Nick
bollix47
Post by bollix47 »
Try a custom/perform clean install of just the 344.80 graphic drivers. (i.e. specify custom install and uncheck all except graphic driver and check perform clean install)
Nick200
Post by Nick200 »
Hi Bollix47
Thanks for the suggestion. I installed 344.80 using the clean install option after cleaning out whatever driver the windows installation routine foisted on me, using the DDU utility for a belt-and-braces job. But I'm afraid that it has had no effect as per the attached log:
*********************** Log Started 2015-01-16T11:06:03Z ***********************
11:06:03:************************* Folding@home Client *************************
11:06:03:      Website: http://folding.stanford.edu/
11:06:03:    Copyright: (c) 2009-2014 Stanford University
11:06:03:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:06:03:         Args:
11:06:03:       Config: C:/ProgramData/FAHClient/config.xml
11:06:03:******************************** Build ********************************
11:06:03:      Version: 7.4.4
11:06:03:         Date: Mar 4 2014
11:06:03:         Time: 20:26:54
11:06:03:      SVN Rev: 4130
11:06:03:       Branch: fah/trunk/client
11:06:03:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:06:03:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:06:03:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:06:03:     Platform: win32 XP
11:06:03:         Bits: 32
11:06:03:         Mode: Release
11:06:03:******************************* System ********************************
11:06:03:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
11:06:03:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:06:03:         CPUs: 8
11:06:03:       Memory: 15.89GiB
11:06:03:  Free Memory: 14.29GiB
11:06:03:      Threads: WINDOWS_THREADS
11:06:03:   OS Version: 6.2
11:06:03:  Has Battery: false
11:06:03:   On Battery: false
11:06:03:   UTC Offset: 13
11:06:03:          PID: 5652
11:06:03:          CWD: C:/ProgramData/FAHClient
11:06:03:           OS: Windows 8.1 Pro with Media Center
11:06:03:      OS Arch: AMD64
11:06:03:         GPUs: 1
11:06:03:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
11:06:03:         CUDA: Not detected
11:06:03:Win32 Service: false
11:06:03:***********************************************************************
11:06:03:<config>
11:06:03:  <!-- Network -->
11:06:03:  <proxy v=':8080'/>
11:06:03:
11:06:03:  <!-- Slot Control -->
11:06:03:  <power v='FULL'/>
11:06:03:
11:06:03:  <!-- User Information -->
11:06:03:  <passkey v='********************************'/>
11:06:03:  <team v='142900'/>
11:06:03:  <user v='Montague-Cripps'/>
11:06:03:
11:06:03:  <!-- Folding Slots -->
11:06:03:  <slot id='0' type='CPU'/>
11:06:03:  <slot id='1' type='GPU'/>
11:06:03:</config>
11:06:03:Trying to access database...
11:06:03:Successfully acquired database lock
11:06:03:Enabled folding slot 00: READY cpu:7
11:06:03:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 980]
11:06:03:WU00:FS01:Starting
11:06:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:03:WU00:FS01:Started FahCore on PID 5308
11:06:03:WU00:FS01:Core PID:1044
11:06:03:WU00:FS01:FahCore 0x15 started
11:06:03:WU01:FS00:Starting
11:06:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -np 7
11:06:03:WU01:FS00:Started FahCore on PID 4692
11:06:03:WU01:FS00:Core PID:372
11:06:03:WU01:FS00:FahCore 0xa4 started
11:06:04:WU00:FS01:0x15:
11:06:04:WU00:FS01:0x15:*------------------------------*
11:06:04:WU00:FS01:0x15:Folding@Home GPU Core
11:06:04:WU00:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
11:06:04:WU00:FS01:0x15:Build host             AmoebaRemote
11:06:04:WU00:FS01:0x15:Board Type             NVIDIA/CUDA
11:06:04:WU00:FS01:0x15:Core                   15
11:06:04:WU00:FS01:0x15:Window's signal control handler registered.
11:06:04:WU00:FS01:0x15:Preparing to commence simulation
11:06:04:WU00:FS01:0x15:- Looking at optimizations...
11:06:04:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
11:06:04:WU00:FS01:0x15:- Created dyn
11:06:04:WU00:FS01:0x15:- Files status OK
11:06:04:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
11:06:04:WU00:FS01:0x15:- Expanded 124809 -> 501826 (decompressed 402.0 percent)
11:06:04:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=124809 data_size=501826, decompressed_data_size=501826 diff=0
11:06:04:WU00:FS01:0x15:- Digital signature verified
11:06:04:WU00:FS01:0x15:Project: 7620 (Run 754, Clone 0, Gen 345)
11:06:04:WU00:FS01:0x15:Assembly optimizations on if available.
11:06:04:WU00:FS01:0x15:Entering M.D.
11:06:04:WU01:FS00:0xa4:
11:06:04:WU01:FS00:0xa4:*------------------------------*
11:06:04:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
11:06:04:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:06:04:WU01:FS00:0xa4:Preparing to commence simulation
11:06:04:WU01:FS00:0xa4:- Ensuring status. Please wait.
11:06:05:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr:  3003757401 1596406884 3548458916 1809206375 3890214383
11:06:05:WU00:FS01:0x15:GPU device id=0
11:06:05:WU00:FS01:0x15:Working on Protein
11:06:05:WU00:FS01:0x15:Client config unavailable.
11:06:05:WU00:FS01:0x15:Finished fah_main status=59
11:06:05:WU00:FS01:0x15:mdrun_gpu returned 59
11:06:05:WU00:FS01:0x15:GPU memtest failure
11:06:05:WU00:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
11:06:06:WARNING:WU00:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
11:06:06:WU00:FS01:Starting
11:06:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:06:WU00:FS01:Started FahCore on PID 5668
11:06:06:WU00:FS01:Core PID:5688
11:06:06:WU00:FS01:FahCore 0x15 started
11:06:06:WU00:FS01:0x15:
11:06:06:WU00:FS01:0x15:*------------------------------*
11:06:06:WU00:FS01:0x15:Folding@Home GPU Core
11:06:06:WU00:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
11:06:06:WU00:FS01:0x15:Build host             AmoebaRemote
11:06:06:WU00:FS01:0x15:Board Type             NVIDIA/CUDA
11:06:06:WU00:FS01:0x15:Core                   15
11:06:06:WU00:FS01:0x15:Window's signal control handler registered.
11:06:06:WU00:FS01:0x15:Preparing to commence simulation
11:06:06:WU00:FS01:0x15:- Looking at optimizations...
11:06:06:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
11:06:06:WU00:FS01:0x15:- Created dyn
11:06:06:WU00:FS01:0x15:- Files status OK
11:06:06:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
11:06:06:WU00:FS01:0x15:- Expanded 124809 -> 501826 (decompressed 402.0 percent)
11:06:06:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=124809 data_size=501826, decompressed_data_size=501826 diff=0
11:06:06:WU00:FS01:0x15:- Digital signature verified
11:06:06:WU00:FS01:0x15:Project: 7620 (Run 754, Clone 0, Gen 345)
11:06:06:WU00:FS01:0x15:Assembly optimizations on if available.
11:06:06:WU00:FS01:0x15:Entering M.D.
11:06:08:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr:  3003757401 1596406884 3548458916 1809206375 3890214383
11:06:08:WU00:FS01:0x15:GPU device id=0
11:06:08:WU00:FS01:0x15:Working on Protein
11:06:08:WU00:FS01:0x15:Client config unavailable.
11:06:08:WU00:FS01:0x15:Finished fah_main status=59
11:06:08:WU00:FS01:0x15:mdrun_gpu returned 59
11:06:08:WU00:FS01:0x15:GPU memtest failure
11:06:08:WU00:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
11:06:09:WARNING:WU00:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
11:06:09:WARNING:WU00:FS01:Too many errors, failing
11:06:09:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:7620 run:754 clone:0 gen:345 core:0x15 unit:0x000001b8664f2dd14e42f76835afcab2
11:06:09:WU00:FS01:Connecting to 171.64.65.105:8080
11:06:09:WU02:FS01:Connecting to 171.67.108.200:80
11:06:09:WU00:FS01:Server responded WORK_QUIT (404)
11:06:09:WARNING:WU00:FS01:Server did not like results, dumping
11:06:09:WU00:FS01:Cleaning up
11:06:10:WU02:FS01:Assigned to work server 171.67.108.52
11:06:10:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:10:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:11:WU02:FS01:Downloading 1.52MiB
11:06:13:WU01:FS00:0xa4:- Looking at optimizations...
11:06:13:WU01:FS00:0xa4:- Working with standard loops on this execution.
11:06:13:WU01:FS00:0xa4:- Previous termination of core was improper.
11:06:13:WU01:FS00:0xa4:- Files status OK
11:06:13:WU01:FS00:0xa4:- Expanded 923160 -> 1534204 (decompressed 166.1 percent)
11:06:13:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923160 data_size=1534204, decompressed_data_size=1534204 diff=0
11:06:13:WU01:FS00:0xa4:- Digital signature verified
11:06:13:WU01:FS00:0xa4:Project: 9014 (Run 443, Clone 8, Gen 12)
11:06:13:WU01:FS00:0xa4:Entering M.D.
11:06:14:WU02:FS01:Download complete
11:06:14:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:332 clone:3 gen:166 core:0x17 unit:0x000000df6652edc45399e31ec3f48b43
11:06:14:WU02:FS01:Starting
11:06:14:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:14:WU02:FS01:Started FahCore on PID 4476
11:06:14:WU02:FS01:Core PID:4460
11:06:14:WU02:FS01:FahCore 0x17 started
11:06:15:WU02:FS01:0x17:*********************** Log Started 2015-01-16T11:06:14Z ***********************
11:06:15:WU02:FS01:0x17:Project: 9201 (Run 332, Clone 3, Gen 166)
11:06:15:WU02:FS01:0x17:Unit: 0x000000df6652edc45399e31ec3f48b43
11:06:15:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:15:WU02:FS01:0x17:Machine: 1
11:06:15:WU02:FS01:0x17:Reading tar file state.xml
11:06:15:WU02:FS01:0x17:Reading tar file system.xml
11:06:15:WU02:FS01:0x17:Reading tar file integrator.xml
11:06:15:WU02:FS01:0x17:Reading tar file core.xml
11:06:15:WU02:FS01:0x17:Digital signatures verified
11:06:15:WU02:FS01:0x17:Folding@home GPU core17
11:06:15:WU02:FS01:0x17:Version 0.0.52
11:06:15:WU02:FS01:0x17:ERROR:exception: Bad platformId size.
11:06:15:WU02:FS01:0x17:Saving result file logfile_01.txt
11:06:15:WU02:FS01:0x17:Saving result file log.txt
11:06:15:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:15:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:15:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:332 clone:3 gen:166 core:0x17 unit:0x000000df6652edc45399e31ec3f48b43
11:06:15:WU02:FS01:Uploading 1.98KiB to 171.67.108.52
11:06:15:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:15:WU00:FS01:Connecting to 171.67.108.200:80
11:06:16:WU02:FS01:Upload complete
11:06:16:WU02:FS01:Server responded WORK_ACK (400)
11:06:16:WU02:FS01:Cleaning up
11:06:16:WU00:FS01:Assigned to work server 171.67.108.52
11:06:16:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:16:WU00:FS01:Connecting to 171.67.108.52:8080
11:06:17:WU00:FS01:Downloading 1.52MiB
11:06:19:WU01:FS00:0xa4:Using Gromacs checkpoints
11:06:19:WU01:FS00:0xa4:Mapping NT from 7 to 7
11:06:19:WU01:FS00:0xa4:Resuming from checkpoint
11:06:19:WU01:FS00:0xa4:Verified 01/wudata_01.log
11:06:19:WU01:FS00:0xa4:Verified 01/wudata_01.trr
11:06:19:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
11:06:19:WU01:FS00:0xa4:Verified 01/wudata_01.edr
11:06:19:WU01:FS00:0xa4:Completed 70085 out of 250000 steps  (28%)
11:06:20:WU00:FS01:Download complete
11:06:20:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:509 clone:2 gen:159 core:0x17 unit:0x000000e86652edc45399ea0dc7931e3f
11:06:20:WU00:FS01:Starting
11:06:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:20:WU00:FS01:Started FahCore on PID 4060
11:06:20:WU00:FS01:Core PID:4076
11:06:20:WU00:FS01:FahCore 0x17 started
11:06:21:WU00:FS01:0x17:*********************** Log Started 2015-01-16T11:06:20Z ***********************
11:06:21:WU00:FS01:0x17:Project: 9201 (Run 509, Clone 2, Gen 159)
11:06:21:WU00:FS01:0x17:Unit: 0x000000e86652edc45399ea0dc7931e3f
11:06:21:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:21:WU00:FS01:0x17:Machine: 1
11:06:21:WU00:FS01:0x17:Reading tar file state.xml
11:06:21:WU00:FS01:0x17:Reading tar file system.xml
11:06:21:WU00:FS01:0x17:Reading tar file integrator.xml
11:06:21:WU00:FS01:0x17:Reading tar file core.xml
11:06:21:WU00:FS01:0x17:Digital signatures verified
11:06:21:WU00:FS01:0x17:Folding@home GPU core17
11:06:21:WU00:FS01:0x17:Version 0.0.52
11:06:21:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
11:06:21:WU00:FS01:0x17:Saving result file logfile_01.txt
11:06:21:WU00:FS01:0x17:Saving result file log.txt
11:06:21:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:22:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:22:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:509 clone:2 gen:159 core:0x17 unit:0x000000e86652edc45399ea0dc7931e3f
11:06:22:WU00:FS01:Uploading 1.97KiB to 171.67.108.52
11:06:22:WU00:FS01:Connecting to 171.67.108.52:8080
11:06:22:WU02:FS01:Connecting to 171.67.108.200:80
11:06:22:WU00:FS01:Upload complete
11:06:22:WU00:FS01:Server responded WORK_ACK (400)
11:06:22:WU00:FS01:Cleaning up
11:06:23:WU02:FS01:Assigned to work server 171.67.108.52
11:06:23:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:23:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:24:WU02:FS01:Downloading 1.53MiB
11:06:27:WU02:FS01:Download complete
11:06:27:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:642 clone:2 gen:159 core:0x17 unit:0x000000e06652edc45399ef462c7fc58e
11:06:27:WU02:FS01:Starting
11:06:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:27:WU02:FS01:Started FahCore on PID 6296
11:06:27:WU02:FS01:Core PID:6308
11:06:27:WU02:FS01:FahCore 0x17 started
11:06:28:WU02:FS01:0x17:*********************** Log Started 2015-01-16T11:06:27Z ***********************
11:06:28:WU02:FS01:0x17:Project: 9201 (Run 642, Clone 2, Gen 159)
11:06:28:WU02:FS01:0x17:Unit: 0x000000e06652edc45399ef462c7fc58e
11:06:28:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:28:WU02:FS01:0x17:Machine: 1
11:06:28:WU02:FS01:0x17:Reading tar file state.xml
11:06:28:WU02:FS01:0x17:Reading tar file system.xml
11:06:28:WU02:FS01:0x17:Reading tar file integrator.xml
11:06:28:WU02:FS01:0x17:Reading tar file core.xml
11:06:28:WU02:FS01:0x17:Digital signatures verified
11:06:28:WU02:FS01:0x17:Folding@home GPU core17
11:06:28:WU02:FS01:0x17:Version 0.0.52
11:06:28:WU02:FS01:0x17:ERROR:exception: Bad platformId size.
11:06:28:WU02:FS01:0x17:Saving result file logfile_01.txt
11:06:28:WU02:FS01:0x17:Saving result file log.txt
11:06:28:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:29:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:29:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:642 clone:2 gen:159 core:0x17 unit:0x000000e06652edc45399ef462c7fc58e
11:06:29:WU02:FS01:Uploading 1.97KiB to 171.67.108.52
11:06:29:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:29:WU02:FS01:Upload complete
11:06:29:WU02:FS01:Server responded WORK_ACK (400)
11:06:29:WU02:FS01:Cleaning up
11:06:29:WU00:FS01:Connecting to 171.67.108.200:80
11:06:30:WU00:FS01:Assigned to work server 171.67.108.52
11:06:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:30:WU00:FS01:Connecting to 171.67.108.52:8080
11:06:31:WU00:FS01:Downloading 1.52MiB
11:06:34:WU00:FS01:Download complete
11:06:34:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:277 clone:4 gen:146 core:0x17 unit:0x000000bb6652edc45399e0f65283a96e
11:06:34:WU00:FS01:Starting
11:06:34:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:34:WU00:FS01:Started FahCore on PID 6456
11:06:34:WU00:FS01:Core PID:6468
11:06:34:WU00:FS01:FahCore 0x17 started
11:06:34:WU00:FS01:0x17:*********************** Log Started 2015-01-16T11:06:34Z ***********************
11:06:34:WU00:FS01:0x17:Project: 9201 (Run 277, Clone 4, Gen 146)
11:06:34:WU00:FS01:0x17:Unit: 0x000000bb6652edc45399e0f65283a96e
11:06:34:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:34:WU00:FS01:0x17:Machine: 1
11:06:34:WU00:FS01:0x17:Reading tar file state.xml
11:06:35:WU00:FS01:0x17:Reading tar file system.xml
11:06:35:WU00:FS01:0x17:Reading tar file integrator.xml
11:06:35:WU00:FS01:0x17:Reading tar file core.xml
11:06:35:WU00:FS01:0x17:Digital signatures verified
11:06:35:WU00:FS01:0x17:Folding@home GPU core17
11:06:35:WU00:FS01:0x17:Version 0.0.52
11:06:35:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
11:06:35:WU00:FS01:0x17:Saving result file logfile_01.txt
11:06:35:WU00:FS01:0x17:Saving result file log.txt
11:06:35:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:35:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:35:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:277 clone:4 gen:146 core:0x17 unit:0x000000bb6652edc45399e0f65283a96e
11:06:35:WU00:FS01:Uploading 1.98KiB to 171.67.108.52
11:06:35:WU00:FS01:Connecting to 171.67.108.52:8080
11:06:35:WU02:FS01:Connecting to 171.67.108.200:80
11:06:36:WU00:FS01:Upload complete
11:06:36:WU00:FS01:Server responded WORK_ACK (400)
11:06:36:WU00:FS01:Cleaning up
11:06:36:WU02:FS01:Assigned to work server 171.67.108.52
11:06:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:36:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:37:WU02:FS01:Downloading 1.53MiB
11:06:43:WU02:FS01:Download 69.61%
11:06:45:WU02:FS01:Download complete
11:06:45:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:799 clone:3 gen:139 core:0x17 unit:0x000000c66652edc45399f5780bda6719
11:06:45:WU02:FS01:Starting
11:06:45:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:45:WU02:FS01:Started FahCore on PID 6528
11:06:45:WU02:FS01:Core PID:6540
11:06:45:WU02:FS01:FahCore 0x17 started
11:06:45:WU02:FS01:0x17:*********************** Log Started 2015-01-16T11:06:45Z ***********************
11:06:45:WU02:FS01:0x17:Project: 9201 (Run 799, Clone 3, Gen 139)
11:06:45:WU02:FS01:0x17:Unit: 0x000000c66652edc45399f5780bda6719
11:06:45:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:45:WU02:FS01:0x17:Machine: 1
11:06:45:WU02:FS01:0x17:Reading tar file state.xml
11:06:46:WU02:FS01:0x17:Reading tar file system.xml
11:06:46:WU02:FS01:0x17:Reading tar file integrator.xml
11:06:46:WU02:FS01:0x17:Reading tar file core.xml
11:06:46:WU02:FS01:0x17:Digital signatures verified
11:06:46:WU02:FS01:0x17:Folding@home GPU core17
11:06:46:WU02:FS01:0x17:Version 0.0.52
11:06:46:WU02:FS01:0x17:ERROR:exception: Bad platformId size.
11:06:46:WU02:FS01:0x17:Saving result file logfile_01.txt
11:06:46:WU02:FS01:0x17:Saving result file log.txt
11:06:46:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:46:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:46:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:799 clone:3 gen:139 core:0x17 unit:0x000000c66652edc45399f5780bda6719
11:06:46:WU02:FS01:Uploading 1.98KiB to 171.67.108.52
11:06:46:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:46:WU00:FS01:Connecting to 171.67.108.200:80
11:06:47:WU02:FS01:Upload complete
11:06:47:WU02:FS01:Server responded WORK_ACK (400)
11:06:47:WU02:FS01:Cleaning up
11:06:47:WU00:FS01:Assigned to work server 171.67.108.52
11:06:47:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:47:WU00:FS01:Connecting to 171.67.108.52:8080
11:06:48:WU00:FS01:Downloading 1.52MiB
11:06:52:WU00:FS01:Download complete
11:06:52:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:358 clone:2 gen:132 core:0x17 unit:0x000000c86652edc45399e4222063c879
11:06:52:WU00:FS01:Starting
11:06:52:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:52:WU00:FS01:Started FahCore on PID 6624
11:06:52:WU00:FS01:Core PID:6636
11:06:52:WU00:FS01:FahCore 0x17 started
11:06:53:WU00:FS01:0x17:*********************** Log Started 2015-01-16T11:06:52Z ***********************
11:06:53:WU00:FS01:0x17:Project: 9201 (Run 358, Clone 2, Gen 132)
11:06:53:WU00:FS01:0x17:Unit: 0x000000c86652edc45399e4222063c879
11:06:53:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:06:53:WU00:FS01:0x17:Machine: 1
11:06:53:WU00:FS01:0x17:Reading tar file state.xml
11:06:53:WU00:FS01:0x17:Reading tar file system.xml
11:06:53:WU00:FS01:0x17:Reading tar file integrator.xml
11:06:53:WU00:FS01:0x17:Reading tar file core.xml
11:06:53:WU00:FS01:0x17:Digital signatures verified
11:06:53:WU00:FS01:0x17:Folding@home GPU core17
11:06:53:WU00:FS01:0x17:Version 0.0.52
11:06:53:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
11:06:53:WU00:FS01:0x17:Saving result file logfile_01.txt
11:06:53:WU00:FS01:0x17:Saving result file log.txt
11:06:53:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:06:53:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:06:53:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:358 clone:2 gen:132 core:0x17 unit:0x000000c86652edc45399e4222063c879
11:06:53:WU00:FS01:Uploading 1.98KiB to 171.67.108.52
11:06:53:WU00:FS01:Connecting to 171.67.108.52:8080
11:06:54:WU02:FS01:Connecting to 171.67.108.200:80
11:06:54:WU00:FS01:Upload complete
11:06:54:WU00:FS01:Server responded WORK_ACK (400)
11:06:54:WU00:FS01:Cleaning up
11:06:54:WU02:FS01:Assigned to work server 171.67.108.52
11:06:54:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:06:54:WU02:FS01:Connecting to 171.67.108.52:8080
11:06:55:WU02:FS01:Downloading 1.52MiB
11:06:59:WU02:FS01:Download complete
11:06:59:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:634 clone:2 gen:137 core:0x17 unit:0x000000bc6652edc45399eef6082c663a
11:06:59:WU02:FS01:Starting
11:06:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:06:59:WU02:FS01:Started FahCore on PID 6652
11:06:59:WU02:FS01:Core PID:6664
11:06:59:WU02:FS01:FahCore 0x17 started
11:07:00:WU02:FS01:0x17:*********************** Log Started 2015-01-16T11:06:59Z ***********************
11:07:00:WU02:FS01:0x17:Project: 9201 (Run 634, Clone 2, Gen 137)
11:07:00:WU02:FS01:0x17:Unit: 0x000000bc6652edc45399eef6082c663a
11:07:00:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:07:00:WU02:FS01:0x17:Machine: 1
11:07:00:WU02:FS01:0x17:Reading tar file state.xml
11:07:00:WU02:FS01:0x17:Reading tar file system.xml
11:07:00:WU02:FS01:0x17:Reading tar file integrator.xml
11:07:00:WU02:FS01:0x17:Reading tar file core.xml
11:07:00:WU02:FS01:0x17:Digital signatures verified
11:07:00:WU02:FS01:0x17:Folding@home GPU core17
11:07:00:WU02:FS01:0x17:Version 0.0.52
11:07:00:WU02:FS01:0x17:ERROR:exception: Bad platformId size.
11:07:00:WU02:FS01:0x17:Saving result file logfile_01.txt
11:07:00:WU02:FS01:0x17:Saving result file log.txt
11:07:00:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:07:01:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:07:01:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:634 clone:2 gen:137 core:0x17 unit:0x000000bc6652edc45399eef6082c663a
11:07:01:WU02:FS01:Uploading 1.98KiB to 171.67.108.52
11:07:01:WU02:FS01:Connecting to 171.67.108.52:8080
11:07:01:WU00:FS01:Connecting to 171.67.108.200:80
11:07:01:WU02:FS01:Upload complete
11:07:01:WU02:FS01:Server responded WORK_ACK (400)
11:07:01:WU02:FS01:Cleaning up
11:07:02:WU00:FS01:Assigned to work server 171.67.108.52
11:07:02:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:07:02:WU00:FS01:Connecting to 171.67.108.52:8080
11:07:02:WU00:FS01:Downloading 1.52MiB
11:07:07:WU00:FS01:Download complete
11:07:07:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:241 clone:3 gen:107 core:0x17 unit:0x0000009f6652edc45399df80beab163d
11:07:07:WU00:FS01:Starting
11:07:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:07:07:WU00:FS01:Started FahCore on PID 6760
11:07:07:WU00:FS01:Core PID:6772
11:07:07:WU00:FS01:FahCore 0x17 started
11:07:07:WU00:FS01:0x17:*********************** Log Started 2015-01-16T11:07:07Z ***********************
11:07:07:WU00:FS01:0x17:Project: 9201 (Run 241, Clone 3, Gen 107)
11:07:07:WU00:FS01:0x17:Unit: 0x0000009f6652edc45399df80beab163d
11:07:07:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:07:07:WU00:FS01:0x17:Machine: 1
11:07:07:WU00:FS01:0x17:Reading tar file state.xml
11:07:08:WU00:FS01:0x17:Reading tar file system.xml
11:07:08:WU00:FS01:0x17:Reading tar file integrator.xml
11:07:08:WU00:FS01:0x17:Reading tar file core.xml
11:07:08:WU00:FS01:0x17:Digital signatures verified
11:07:08:WU00:FS01:0x17:Folding@home GPU core17
11:07:08:WU00:FS01:0x17:Version 0.0.52
11:07:08:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
11:07:08:WU00:FS01:0x17:Saving result file logfile_01.txt
11:07:08:WU00:FS01:0x17:Saving result file log.txt
11:07:08:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:07:08:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:07:08:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:241 clone:3 gen:107 core:0x17 unit:0x0000009f6652edc45399df80beab163d
11:07:08:WU00:FS01:Uploading 1.98KiB to 171.67.108.52
11:07:08:WU00:FS01:Connecting to 171.67.108.52:8080
11:07:08:WU02:FS01:Connecting to 171.67.108.200:80
11:07:09:WU00:FS01:Upload complete
11:07:09:WU00:FS01:Server responded WORK_ACK (400)
11:07:09:WU00:FS01:Cleaning up
11:07:09:WU02:FS01:Assigned to work server 171.67.108.52
11:07:09:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 171.67.108.52
11:07:09:WU02:FS01:Connecting to 171.67.108.52:8080
11:07:10:WU02:FS01:Downloading 1.52MiB
11:07:14:WU02:FS01:Download complete
11:07:14:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:627 clone:3 gen:160 core:0x17 unit:0x000000de6652edc45399eeb1ab7a3ecf
11:07:14:WU02:FS01:Starting
11:07:14:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5652 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:07:14:WU02:FS01:Started FahCore on PID 6972
11:07:14:WU02:FS01:Core PID:6984
11:07:14:WU02:FS01:FahCore 0x17 started
11:07:15:WU02:FS01:0x17:*********************** Log Started 2015-01-16T11:07:15Z ***********************
11:07:15:WU02:FS01:0x17:Project: 9201 (Run 627, Clone 3, Gen 160)
11:07:15:WU02:FS01:0x17:Unit: 0x000000de6652edc45399eeb1ab7a3ecf
11:07:15:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:07:15:WU02:FS01:0x17:Machine: 1
11:07:15:WU02:FS01:0x17:Reading tar file state.xml
11:07:15:WU02:FS01:0x17:Reading tar file system.xml
11:07:15:WU02:FS01:0x17:Reading tar file integrator.xml
11:07:15:WU02:FS01:0x17:Reading tar file core.xml
11:07:15:WU02:FS01:0x17:Digital signatures verified
11:07:15:WU02:FS01:0x17:Folding@home GPU core17
11:07:15:WU02:FS01:0x17:Version 0.0.52
11:07:15:WU02:FS01:0x17:ERROR:exception: Bad platformId size.
11:07:15:WU02:FS01:0x17:Saving result file logfile_01.txt
11:07:15:WU02:FS01:0x17:Saving result file log.txt
11:07:15:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
11:07:16:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:07:16:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:627 clone:3 gen:160 core:0x17 unit:0x000000de6652edc45399eeb1ab7a3ecf
11:07:16:WU02:FS01:Uploading 1.98KiB to 171.67.108.52
11:07:16:WU02:FS01:Connecting to 171.67.108.52:8080
11:07:16:WU02:FS01:Upload complete
11:07:16:WU02:FS01:Server responded WORK_ACK (400)
11:07:16:WU02:FS01:Cleaning up
11:08:08:WU01:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
Installing 344.80 (just the driver) has not forced CUDA to install. Or got rid of any of the recurrent error messages.
I have implemented all the good suggestions above in this thread (for which thanks everyone, much appreciated) - but none of them have done the trick.
I also spent the day re-installing windows 8.1 pro (just the activation stage to phone Microsoft about - and I'll leave that till tomorrow). But even that nuclear approach to clearing the system out has not had any effect.
On the bright side, while it has meant enormous downloads and searching out installation disks etc, I now have a clean vanilla installation. Then again, I am pissed off that, after spending nigh on NZ$1,000 and two days of my summer holidays trying to sort it out, I cannot fold with the graphics card.
Any ideas? Worth escalating this to nvidia as I remain completely stumped. Or shall I take it back as not fit for purpose?
Nick
bollix47
Post by bollix47 »
A couple of things to try before RMA:
MemtestG80 (cuda) and MemtestCL (opencl) I don't know how much these utilities have been tested with Maxwells so don't be surprised if they complain. You might also check on the nvidia site for a cuda testing utility ... hopefully they have something you can use if MemtestG80 doesn't work.
If no memory errors a complete uninstall including data and whatever cuda that was installed manually, reinstall the 344.80 drivers and a default reinstall of FAH just for you ... i.e. not for everyone and of course not as a service. Cuda run-time support should be installed when you install the graphic drivers ... there should be no need to install it separately.
This location: 11:06:03: CWD: C:/ProgramData/FAHClient
should change to something like c:/Users/username/AppData/Roaming/FAHClient/
bollix47
Post by bollix47 »
Also, you can right click on your desktop and choose Nvidia Control Panel ... it should tell you if your GPU has cuda under the Manage 3d settings.
Use all of the default settings when Installing the client. And use the install just for me option, not the all users option.
Nick200
Post by Nick200 »
OK, good news as the gtx980 is now folding - but I am at a loss to explain which steps worked.
To activate windows, I had to re-install it according to the ever so helpful Microsoft call centre reps. That was frustrating but, oddly, FAH started working on a Core 15 work unit when I installed Windows 8 Pro (as a step towards getting windows 8.1 Pro up).
I installed just the 344.80 driver - and followed 7im's advice about installing FAH for me only, not other PC users. I attach the log - no error messages, although I note that CUDA is not detected:
*********************** Log Started 2015-01-17T00:31:46Z ***********************
00:31:46:************************* Folding@home Client *************************
00:31:46:      Website: http://folding.stanford.edu/
00:31:46:    Copyright: (c) 2009-2014 Stanford University
00:31:46:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:31:46:         Args:
00:31:46:       Config: C:/Users/Nick/AppData/Roaming/FAHClient/config.xml
00:31:46:******************************** Build ********************************
00:31:46:      Version: 7.4.4
00:31:46:         Date: Mar 4 2014
00:31:46:         Time: 20:26:54
00:31:46:      SVN Rev: 4130
00:31:46:       Branch: fah/trunk/client
00:31:46:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:31:46:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:31:46:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:31:46:     Platform: win32 XP
00:31:46:         Bits: 32
00:31:46:         Mode: Release
00:31:46:******************************* System ********************************
00:31:46:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
00:31:46:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:31:46:         CPUs: 8
00:31:46:       Memory: 15.89GiB
00:31:46:  Free Memory: 14.41GiB
00:31:46:      Threads: WINDOWS_THREADS
00:31:46:   OS Version: 6.2
00:31:46:  Has Battery: false
00:31:46:   On Battery: false
00:31:46:   UTC Offset: 0
00:31:46:          PID: 4532
00:31:46:          CWD: C:/Users/Nick/AppData/Roaming/FAHClient
00:31:46:           OS: Windows 8 Pro with Media Center
00:31:46:      OS Arch: AMD64
00:31:46:         GPUs: 1
00:31:46:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
00:31:46:         CUDA: 5.2
00:31:46:  CUDA Driver: 6050
00:31:46:Win32 Service: false
00:31:46:***********************************************************************
00:31:46:<config>
00:31:46:  <!-- Network -->
00:31:46:  <proxy v=':8080'/>
00:31:46:
00:31:46:  <!-- Slot Control -->
00:31:46:  <power v='full'/>
00:31:46:
00:31:46:  <!-- User Information -->
00:31:46:  <passkey v='********************************'/>
00:31:46:  <team v='142900'/>
00:31:46:  <user v='Montague-Cripps'/>
00:31:46:
00:31:46:  <!-- Folding Slots -->
00:31:46:  <slot id='0' type='CPU'/>
00:31:46:  <slot id='1' type='GPU'/>
00:31:46:</config>
00:31:46:Trying to access database...
00:31:46:Successfully acquired database lock
00:31:46:Enabled folding slot 00: READY cpu:7
00:31:46:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 980]
00:31:46:WU00:FS00:Starting
00:31:46:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Nick/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4532 -checkpoint 15 -np 7
00:31:46:WU00:FS00:Started FahCore on PID 4632
00:31:46:WU00:FS00:Core PID:4644
00:31:46:WU00:FS00:FahCore 0xa4 started
00:31:46:WU01:FS01:Starting
00:31:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Nick/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 4532 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:31:46:WU01:FS01:Started FahCore on PID 4652
00:31:46:WU01:FS01:Core PID:4668
00:31:46:WU01:FS01:FahCore 0x15 started
00:31:47:WU00:FS00:0xa4:
00:31:47:WU00:FS00:0xa4:*------------------------------*
00:31:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
00:31:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:31:47:WU00:FS00:0xa4:Preparing to commence simulation
00:31:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
00:31:47:WU01:FS01:0x15:
00:31:47:WU01:FS01:0x15:*------------------------------*
00:31:47:WU01:FS01:0x15:Folding@Home GPU Core
00:31:47:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:31:47:WU01:FS01:0x15:Build host             AmoebaRemote
00:31:47:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
00:31:47:WU01:FS01:0x15:Core                   15
00:31:47:WU01:FS01:0x15:Window's signal control handler registered.
00:31:47:WU01:FS01:0x15:Preparing to commence simulation
00:31:47:WU01:FS01:0x15:- Ensuring status. Please wait.
00:31:56:WU00:FS00:0xa4:- Looking at optimizations...
00:31:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
00:31:56:WU00:FS00:0xa4:- Previous termination of core was improper.
00:31:56:WU00:FS00:0xa4:- Files status OK
00:31:56:WU00:FS00:0xa4:- Expanded 923020 -> 1526808 (decompressed 165.4 percent)
00:31:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923020 data_size=1526808, decompressed_data_size=1526808 diff=0
00:31:56:WU00:FS00:0xa4:- Digital signature verified
00:31:56:WU00:FS00:0xa4:Project: 9015 (Run 743, Clone 4, Gen 10)
00:31:56:WU00:FS00:0xa4:Entering M.D.
00:31:56:WU01:FS01:0x15:- Looking at optimizations...
00:31:56:WU01:FS01:0x15:- Working with standard loops on this execution.
00:31:56:WU01:FS01:0x15:- Previous termination of core was improper.
00:31:56:WU01:FS01:0x15:- Files status OK
00:31:56:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:31:56:WU01:FS01:0x15:- Expanded 126999 -> 507182 (decompressed 399.3 percent)
00:31:56:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=126999 data_size=507182, decompressed_data_size=507182 diff=0
00:31:56:WU01:FS01:0x15:- Digital signature verified
00:31:56:WU01:FS01:0x15:Project: 7624 (Run 349, Clone 0, Gen 436)
00:31:56:WU01:FS01:0x15:Entering M.D.
00:31:58:WU01:FS01:0x15:Will resume from checkpoint file 01/wudata_01.ckp
00:31:58:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4142911289 2156323806 357129834 165981911 4047768347
00:31:58:WU01:FS01:0x15:GPU device id=0
00:31:58:WU01:FS01:0x15:Working on Protein
00:31:58:WU01:FS01:0x15:Client config unavailable.
00:31:58:WU01:FS01:0x15:Starting GUI Server
00:32:02:WU00:FS00:0xa4:Using Gromacs checkpoints
00:32:02:WU00:FS00:0xa4:Mapping NT from 7 to 7
00:32:02:WU00:FS00:0xa4:Resuming from checkpoint
00:32:02:WU00:FS00:0xa4:Verified 00/wudata_01.log
00:32:02:WU00:FS00:0xa4:Verified 00/wudata_01.trr
00:32:02:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
00:32:02:WU00:FS00:0xa4:Verified 00/wudata_01.edr
00:32:02:WU00:FS00:0xa4:Completed 89075 out of 250000 steps  (35%)
00:32:36:WU00:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
00:33:03:WU01:FS01:0x15:Resuming from checkpoint
00:33:03:WARNING:WU01:FS01:Detected clock skew (1 mins 07 secs), adjusting time estimates
00:33:03:WU01:FS01:0x15:fcCheckPointResume: retreived and current tpr file hash:
00:33:03:WU01:FS01:0x15:   0   4142911289   4142911289
00:33:03:WU01:FS01:0x15:   1   2156323806   2156323806
00:33:03:WU01:FS01:0x15:   2    357129834    357129834
00:33:03:WU01:FS01:0x15:   3    165981911    165981911
00:33:03:WU01:FS01:0x15:   4   4047768347   4047768347
00:33:03:WU01:FS01:0x15:fcCheckPointResume: file hashes same.
00:33:03:WU01:FS01:0x15:fcCheckPointResume: state restored.
00:33:03:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
00:33:03:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
00:33:03:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
00:33:03:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
00:33:03:WU01:FS01:0x15:fcCheckPointResume: state restored 2
00:33:03:WU01:FS01:0x15:Resumed from checkpoint
00:33:03:WU01:FS01:0x15:Setting checkpoint frequency: 400000
00:33:03:WU01:FS01:0x15:Completed  13200001 out of 40000000 steps (33%).
00:34:09:WU00:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
00:35:41:WU01:FS01:0x15:Completed  13600000 out of 40000000 steps (34%).
00:35:44:WU00:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
00:37:20:WU00:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
00:38:19:WU01:FS01:0x15:Completed  14000000 out of 40000000 steps (35%).
00:38:57:WU00:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
00:40:34:WU00:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
00:40:57:WU01:FS01:0x15:Completed  14400000 out of 40000000 steps (36%).
00:42:13:WU00:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
00:43:36:WU01:FS01:0x15:Completed  14800000 out of 40000000 steps (37%).
00:43:50:WU00:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
00:45:31:WU00:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
00:46:14:WU01:FS01:0x15:Completed  15200000 out of 40000000 steps (38%).
00:47:30:WU00:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
00:48:52:WU01:FS01:0x15:Completed  15600000 out of 40000000 steps (39%).
00:49:23:WU00:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
00:51:17:WU00:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
00:51:31:WU01:FS01:0x15:Completed  16000000 out of 40000000 steps (40%).
00:52:53:WU00:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
00:54:09:WU01:FS01:0x15:Completed  16400000 out of 40000000 steps (41%).
00:54:30:WU00:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
00:56:08:WU00:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
00:56:47:WU01:FS01:0x15:Completed  16800000 out of 40000000 steps (42%).
00:57:45:WU00:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
00:59:23:WU00:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
00:59:26:WU01:FS01:0x15:Completed  17200000 out of 40000000 steps (43%).
01:01:00:WU00:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
01:02:04:WU01:FS01:0x15:Completed  17600000 out of 40000000 steps (44%).
01:02:43:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
01:04:23:WU00:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
01:04:42:WU01:FS01:0x15:Completed  18000000 out of 40000000 steps (45%).
01:06:01:WU00:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
01:07:21:WU01:FS01:0x15:Completed  18400000 out of 40000000 steps (46%).
Is it OK to disregard the CUDA messages - and will I have to wait for a functioning Maxwell driver to install all the missing bits (phys x, Experience etc)? I'll not upgrade or change the driver until I see some positive posts about a forthcoming driver on this board.
I will upgrade next to windows 8.1 pro - and check if that affects folding on the GX 980.
Thanks for all the advice - some of the changes seems to have worked but not sure which or how!
Cheers
Nick
