171.67.108.200/204 [You MUST report a different server.]
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Post by jimerickson »
getting empty work server assignments
23:34:36:FS03:Unpaused
23:34:38:WU02:FS03:Connecting to 171.67.108.200:80
23:34:39:WARNING:WU02:FS03:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
23:34:39:WU02:FS03:Connecting to 171.67.108.204:80
23:34:39:WARNING:WU02:FS03:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:34:39:ERROR:WU02:FS03:Exception: Could not get an assignment
23:34:50:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
23:35:29:Saving configuration to config.xml
23:35:29:<config>
23:35:29:  <!-- HTTP Server -->
23:35:29:  <allow v='127.0.0.1 192.168.1.31'/>
23:35:29:
23:35:29:  <!-- Network -->
23:35:29:  <proxy v=':8080'/>
23:35:29:
23:35:29:  <!-- Remote Command Server -->
23:35:29:  <password v='******'/>
23:35:29:
23:35:29:  <!-- Slot Control -->
23:35:29:  <power v='full'/>
23:35:29:
23:35:29:  <!-- User Information -->
23:35:29:  <passkey v='********************************'/>
23:35:29:  <team v='172800'/>
23:35:29:  <user v='jimerickson'/>
23:35:29:
23:35:29:  <!-- Work Unit Control -->
23:35:29:  <next-unit-percentage v='100'/>
23:35:29:
23:35:29:  <!-- Folding Slots -->
23:35:29:  <slot id='0' type='CPU'>
23:35:29:    <cpus v='8'/>
23:35:29:  </slot>
23:35:29:  <slot id='1' type='GPU'>
23:35:29:    <cuda-index v='0'/>
23:35:29:    <gpu-index v='0'/>
23:35:29:    <opencl-index v='0'/>
23:35:29:  </slot>
23:35:29:  <slot id='2' type='GPU'>
23:35:29:    <cuda-index v='1'/>
23:35:29:    <gpu-index v='1'/>
23:35:29:    <opencl-index v='1'/>
23:35:29:  </slot>
23:35:29:  <slot id='3' type='GPU'>
23:35:29:    <cuda-index v='2'/>
23:35:29:    <gpu-index v='2'/>
23:35:29:    <opencl-index v='2'/>
23:35:29:  </slot>
23:35:29:  <slot id='4' type='GPU'>
23:35:29:    <cuda-index v='3'/>
23:35:29:    <gpu-index v='3'/>
23:35:29:    <opencl-index v='3'/>
23:35:29:  </slot>
23:35:29:</config>
23:35:36:WU05:FS04:0x17:Completed 4800000 out of 5000000 steps (96%)
23:35:51:WU04:FS02:0x17:Completed 4000000 out of 5000000 steps (80%)
23:36:02:WU03:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
23:36:16:WU02:FS03:Connecting to 171.67.108.200:80
23:36:16:WARNING:WU02:FS03:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
23:36:16:WU02:FS03:Connecting to 171.67.108.204:80
23:36:16:WARNING:WU02:FS03:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:36:16:ERROR:WU02:FS03:Exception: Could not get an assignment
23:36:32:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
23:37:26:WU05:FS04:0x17:Completed 4850000 out of 5000000 steps (97%)
23:37:42:WU04:FS02:0x17:Completed 4050000 out of 5000000 steps (81%)
23:38:13:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
23:38:53:WU02:FS03:Connecting to 171.67.108.200:80
23:38:53:WARNING:WU02:FS03:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
23:38:53:WU02:FS03:Connecting to 171.67.108.204:80
23:38:54:WARNING:WU02:FS03:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:38:54:ERROR:WU02:FS03:Exception: Could not get an assignment
23:39:01:WU03:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
23:39:17:WU05:FS04:0x17:Completed 4900000 out of 5000000 steps (98%)
23:39:33:WU04:FS02:0x17:Completed 4100000 out of 5000000 steps (82%)
23:39:55:WU01:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
23:41:09:WU05:FS04:0x17:Completed 4950000 out of 5000000 steps (99%)
23:41:25:WU04:FS02:0x17:Completed 4150000 out of 5000000 steps (83%)
23:41:37:WU01:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
23:42:01:WU03:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
Re: 171.67.108.200:80
What type of GPU is connected to folding slot 3? Also, this appears to coincide with the announcement of new AS code being tested, has the slot been able to download a new WU yet.
jimerickson
all 8 of my gpus are gtx980. gm204.
jimerickson
still has not downloaded a work unit. got 4 gtx 980's idle.
bollix47
Post by bollix47 »
Same situation here:
00:12:04:WU01:FS01:Connecting to 171.67.108.200:80
00:12:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
00:12:04:WU01:FS01:Connecting to 171.67.108.204:80
00:12:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:12:05:ERROR:WU01:FS01:Exception: Could not get an assignment
00:12:05:WU01:FS01:Connecting to 171.67.108.200:80
00:12:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
00:12:06:WU01:FS01:Connecting to 171.67.108.204:80
00:12:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:12:06:ERROR:WU01:FS01:Exception: Could not get an assignment
00:13:05:WU01:FS01:Connecting to 171.67.108.200:80
00:13:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
00:13:06:WU01:FS01:Connecting to 171.67.108.204:80
00:13:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:13:06:ERROR:WU01:FS01:Exception: Could not get an assignment
00:13:30:WU00:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
00:13:31:WU00:FS01:0x17:Saving result file logfile_01.txt
00:13:31:WU00:FS01:0x17:Saving result file checkpointState.xml
00:13:31:WU00:FS01:0x17:Saving result file checkpt.crc
00:13:31:WU00:FS01:0x17:Saving result file log.txt
00:13:31:WU00:FS01:0x17:Saving result file positions.xtc
00:13:32:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
00:13:33:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:13:33:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9201 run:625 clone:4 gen:63 core:0x17 unit:0x000000666652edc45399ee9f6a237e90
00:13:33:WU00:FS01:Uploading 8.37MiB to 171.67.108.52
00:13:33:WU00:FS01:Connecting to 171.67.108.52:8080
00:13:39:WU00:FS01:Upload 26.88%
00:13:45:WU00:FS01:Upload 58.25%
00:13:51:WU00:FS01:Upload 87.38%
00:13:59:WU00:FS01:Upload complete
00:13:59:WU00:FS01:Server responded WORK_ACK (400)
00:13:59:WU00:FS01:Final credit estimate, 40253.00 points
00:13:59:WU00:FS01:Cleaning up
00:14:43:WU01:FS01:Connecting to 171.67.108.200:80
00:14:43:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
00:14:43:WU01:FS01:Connecting to 171.67.108.204:80
00:14:44:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:14:44:ERROR:WU01:FS01:Exception: Could not get an assignment
00:16:50:FS01:Paused
00:16:54:Saving configuration to config.xml
00:16:54:<config>
00:16:54:  <!-- Folding Core -->
00:16:54:  <checkpoint v='30'/>
00:16:54:  <core-priority v='low'/>
00:16:54:
00:16:54:  <!-- HTTP Server -->
00:16:54:  <allow v='127.0.0.1,192.168.2.100-192.168.2.149'/>
00:16:54:
00:16:54:  <!-- Network -->
00:16:54:  <proxy v=':8080'/>
00:16:54:
00:16:54:  <!-- Remote Command Server -->
00:16:54:  <command-allow-no-pass v='127.0.0.1,192.168.2.100-192.168.2.149'/>
00:16:54:
00:16:54:  <!-- Slot Control -->
00:16:54:  <power v='full'/>
00:16:54:
00:16:54:  <!-- User Information -->
00:16:54:  <passkey v='********************************'/>
00:16:54:  <team v='39340'/>
00:16:54:  <user v='bollix47'/>
00:16:54:
00:16:54:  <!-- Folding Slots -->
00:16:54:  <slot id='1' type='GPU'>
00:16:54:    <paused v='true'/>
00:16:54:  </slot>
00:16:54:</config>
00:17:33:FS01:Unpaused
00:17:33:WU01:FS01:Connecting to 171.67.108.200:80
00:17:34:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
00:17:34:WU01:FS01:Connecting to 171.67.108.204:80
00:17:34:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:17:34:ERROR:WU01:FS01:Exception: Could not get an assignment
00:17:55:Saving configuration to config.xml
00:17:55:<config>
00:17:55:  <!-- Folding Core -->
00:17:55:  <checkpoint v='30'/>
00:17:55:  <core-priority v='low'/>
00:17:55:
00:17:55:  <!-- HTTP Server -->
00:17:55:  <allow v='127.0.0.1,192.168.2.100-192.168.2.149'/>
00:17:55:
00:17:55:  <!-- Network -->
00:17:55:  <proxy v=':8080'/>
00:17:55:
00:17:55:  <!-- Remote Command Server -->
00:17:55:  <command-allow-no-pass v='127.0.0.1,192.168.2.100-192.168.2.149'/>
00:17:55:
00:17:55:  <!-- Slot Control -->
00:17:55:  <power v='full'/>
00:17:55:
00:17:55:  <!-- User Information -->
00:17:55:  <passkey v='********************************'/>
00:17:55:  <team v='39340'/>
00:17:55:  <user v='bollix47'/>
00:17:55:
00:17:55:  <!-- Folding Slots -->
00:17:55:  <slot id='1' type='GPU'/>
00:17:55:</config>
00:19:10:WU01:FS01:Connecting to 171.67.108.200:80
00:19:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
00:19:11:WU01:FS01:Connecting to 171.67.108.204:80
00:19:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:19:11:ERROR:WU01:FS01:Exception: Could not get an assignment
Obviously something to do with this.
jimerickson
just as i suspected.
Or the WS with suitable Core_17 WU's for Maxwell cards is temporarily out. Were you getting anything besides Project 9201 WU's since the restrictions on assignments to Maxwell were put in place? 9201 is the only project I recall as being stable on Maxwell.
jimerickson
only 9201 on my 980's so far.
bollix47
Post by bollix47 »
Switching back to windows did get a core 15 project on my 980.
jimerickson
sorry only fedora here. no core 15 for me.
bollix47
Post by bollix47 »
It appears the problem getting assignments on a Maxwell is just on Linux. I've alerted Joseph to this thread.
jimerickson
thanks much bollix47!
Kjetil
Post by Kjetil »
Now is win to. no work?
According to my information, Project 9201 is served from 171.67.108.52. Some WUs are being distribute and others are being returned. Unfortunately I don't know how to tell if they're Linux or Windows or anything about what other settings might be needed.
jimerickson
even after a pause and restart my 980's are still pointed firmly at 171.67.108.200 and 171.67.108.204. wonder whats up...
Locked
