Hi everybody
I have an old Dell Precision 390 workstaition that I am trying to get folding. In device manager the GPU is reported as being an NVidia Quadro FX3450/4000 SDI, but from the details tab and the PCI vendor database, it appears to actually be a Quadro FX1500M. After a bit of digging i have installed the 9.18.16.745 driver but the card is not seen by the client. The driver is correct according to the Nvidia website so I guess the card is not compatible? It is listed in the GPU's.txt file however? Thanks for any help in advance.
Is the Quadro FX1500M supported
pompeyrodney
- Hardware configuration: 1 Dell server running Quad Xeon 2.4 Deino, SMP client. 2 Vista GPU client and 2 6.23 BetaR1. 8 other XP clients running 6.23.
Re: Is the Quadro FX1500M supported
The GPUs.txt file lists both supported and unsupported GPUs. If there are 3 colons in a row just before the description the GPU is not supported.
pompeyrodney
This GPU is too old to do any GPU computing ... it's a G7x chip, and folding on nVidia cards started with G8x chips that are now unsupported.
Minimum requirement (but it might change quite fast if core 15 goes unsupported) is currently a G9x chips.
pompeyrodney
