folding with 2 gtx 980's problem
Hello I'm in need of some help. I've been folding for several years now and I recently upgraded my gfx card to a GTX 980 and coupled with my i7 I was getting between 200'000 and 360'000 PDD-great. Last week I installed another identical GTX 980, so I now have 2 cards folding, I downloaded and installed the latest folding client, including passkey, but now with the two cards folding, I'm only getting 180'000 PDD, that's almost half of what I was getting with just one card. how can this be?? I was expecting to be getting around 600'000 PDD. Is there something I need to do in the configuration to get my PDD back up again, I let the client set itself up and it's showing 3 slots, one for the cpu and one each for the two graphics cards. I haven't messed with any flags or settings.
My system is a i7 4770 k, Asus maximus mb, 8 GB corsair vengeance ram, 2*MSI GTX 980, windows 8.1, and xfx 850watt power supply.
If somebody could solve this I would be grateful.
Cheers
Ian
Cheers
Ian
Re: folding with 2 gtx 980's problem
Post the log in accordance with the link in my signature.
How many of the CPU cores are available to support the GPUs?
You have used 3 or 4 different passkeys. Are you sure you're using the same one that you've been using (which was qualified)?
*********************** Log Started 2014-12-27T00:09:12Z ***********************
00:09:12:************************* Folding@home Client *************************
00:09:12: Website: http://folding.stanford.edu/
00:09:12: Copyright: (c) 2009-2014 Stanford University
00:09:12: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:09:12: Args:
00:09:12: Config: C:/Users/Ian/AppData/Roaming/FAHClient/config.xml
00:09:12:******************************** Build ********************************
00:09:12: Version: 7.4.4
00:09:12: Date: Mar 4 2014
00:09:12: Time: 20:26:54
00:09:12: SVN Rev: 4130
00:09:12: Branch: fah/trunk/client
00:09:12: Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:09:12: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:09:12: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:09:12: Platform: win32 XP
00:09:12: Bits: 32
00:09:12: Mode: Release
00:09:12:******************************* System ********************************
00:09:12: CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
00:09:12: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:09:12: CPUs: 8
00:09:12: Memory: 7.87GiB
00:09:12: Free Memory: 5.57GiB
00:09:12: Threads: WINDOWS_THREADS
00:09:12: OS Version: 6.2
00:09:12: Has Battery: false
00:09:12: On Battery: false
00:09:12: UTC Offset: 0
00:09:12: PID: 8000
00:09:12: CWD: C:/Users/Ian/AppData/Roaming/FAHClient
00:09:12: OS: Windows 8.1 Pro
00:09:12: OS Arch: AMD64
00:09:12: GPUs: 2
00:09:12: GPU 0: NVIDIA:4 GM204 [GeForce GTX 980]
00:09:12: GPU 1: NVIDIA:4 GM204 [GeForce GTX 980]
00:09:12: CUDA: 5.2
00:09:12: CUDA Driver: 7000
00:09:12:Win32 Service: false
00:09:12:***********************************************************************
00:09:12:<config>
00:09:12: <!-- Network -->
00:09:12: <proxy v=':8080'/>
00:09:12:
00:09:12: <!-- Slot Control -->
00:09:12: <power v='FULL'/>
00:09:12:
00:09:12: <!-- User Information -->
00:09:12: <passkey v='********************************'/>
00:09:12: <team v='35947'/>
00:09:12: <user v='apeman556'/>
00:09:12:
00:09:12: <!-- Folding Slots -->
00:09:12: <slot id='0' type='CPU'/>
00:09:12: <slot id='1' type='GPU'/>
00:09:12: <slot id='2' type='GPU'/>
00:09:12:</config>
00:09:12:Trying to access database...
00:09:12:Successfully acquired database lock
00:09:12:Enabled folding slot 00: READY cpu:6
00:09:12:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 980]
00:09:12:Enabled folding slot 02: READY gpu:1:GM204 [GeForce GTX 980]
00:09:12:WU03:FS02:Starting
00:09:12:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 03 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
00:09:12:WU03:FS02:Started FahCore on PID 8292
00:09:12:WU03:FS02:Core PID:8304
00:09:12:WU03:FS02:FahCore 0x18 started
00:09:12:WU00:FS01:Starting
00:09:12:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:09:12:WU00:FS01:Started FahCore on PID 8312
00:09:12:WU00:FS01:Core PID:8324
00:09:12:WU00:FS01:FahCore 0x18 started
00:09:12:WU01:FS00:Starting
00:09:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -np 6
00:09:12:WU01:FS00:Started FahCore on PID 8332
00:09:13:WU01:FS00:Core PID:8344
00:09:13:WU01:FS00:FahCore 0xa4 started
00:09:13:WU00:FS01:0x18:*********************** Log Started 2014-12-27T00:09:13Z ***********************
00:09:13:WU00:FS01:0x18:Project: 9107 (Run 14, Clone 1, Gen 12)
00:09:13:WU00:FS01:0x18:Unit: 0x0000000f0a3b1e81546bd4414b91c739
00:09:13:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
00:09:13:WU00:FS01:0x18:Machine: 1
00:09:13:WU00:FS01:0x18:Digital signatures verified
00:09:13:WU00:FS01:0x18:Folding@home GPU core18
00:09:13:WU00:FS01:0x18:Version 0.0.3
00:09:13:WU00:FS01:0x18: Found a checkpoint file
00:09:13:WU01:FS00:0xa4:
00:09:13:WU01:FS00:0xa4:*------------------------------*
00:09:13:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
00:09:13:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:09:13:WU01:FS00:0xa4:Preparing to commence simulation
00:09:13:WU01:FS00:0xa4:- Ensuring status. Please wait.
00:09:13:WU03:FS02:0x18:*********************** Log Started 2014-12-27T00:09:13Z ***********************
00:09:13:WU03:FS02:0x18:Project: 9109 (Run 5, Clone 1, Gen 11)
00:09:13:WU03:FS02:0x18:Unit: 0x0000000f0a3b1e80546a972fd51ab669
00:09:13:WU03:FS02:0x18:CPU: 0x00000000000000000000000000000000
00:09:13:WU03:FS02:0x18:Machine: 2
00:09:13:WU03:FS02:0x18:Digital signatures verified
00:09:13:WU03:FS02:0x18:Folding@home GPU core18
00:09:13:WU03:FS02:0x18:Version 0.0.3
00:09:13:WU03:FS02:0x18: Found a checkpoint file
00:09:22:WU01:FS00:0xa4:- Looking at optimizations...
00:09:22:WU01:FS00:0xa4:- Working with standard loops on this execution.
00:09:22:WU01:FS00:0xa4:- Previous termination of core was improper.
00:09:22:WU01:FS00:0xa4:- Files status OK
00:09:22:WU01:FS00:0xa4:- Expanded 1222811 -> 2730916 (decompressed 223.3 percent)
00:09:22:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1222811 data_size=2730916, decompressed_data_size=2730916 diff=0
00:09:22:WU01:FS00:0xa4:- Digital signature verified
00:09:22:WU01:FS00:0xa4:Project: 10187 (Run 961, Clone 1, Gen 46)
00:09:22:WU01:FS00:0xa4:Entering M.D.
00:09:28:WU01:FS00:0xa4:Using Gromacs checkpoints
00:09:28:WU01:FS00:0xa4:Mapping NT from 6 to 6
00:09:29:WU01:FS00:0xa4:Resuming from checkpoint
00:09:29:WU01:FS00:0xa4:Verified 01/wudata_01.log
00:09:29:WU01:FS00:0xa4:Verified 01/wudata_01.trr
00:09:29:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
00:09:29:WU01:FS00:0xa4:Verified 01/wudata_01.edr
00:09:29:WU01:FS00:0xa4:Completed 370080 out of 500000 steps (74%)
00:09:32:WU00:FS01:0x18:Completed 400000 out of 2500000 steps (16%)
00:09:32:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:09:34:WU03:FS02:0x18:Completed 2300000 out of 2500000 steps (92%)
00:09:34:WU03:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:12:26:WU01:FS00:0xa4:Completed 375000 out of 500000 steps (75%)
00:13:36:WU00:FS01:0x18:Completed 425000 out of 2500000 steps (17%)
00:14:03:WU03:FS02:0x18:Completed 2325000 out of 2500000 steps (93%)
00:15:26:WU01:FS00:0xa4:Completed 380000 out of 500000 steps (76%)
00:17:32:WU00:FS01:0x18:Completed 450000 out of 2500000 steps (18%)
00:18:20:WU01:FS00:0xa4:Completed 385000 out of 500000 steps (77%)
00:18:20:WU03:FS02:0x18:Completed 2350000 out of 2500000 steps (94%)
00:21:13:WU01:FS00:0xa4:Completed 390000 out of 500000 steps (78%)
00:21:27:WU00:FS01:0x18:Completed 475000 out of 2500000 steps (19%)
00:22:39:WU03:FS02:0x18:Completed 2375000 out of 2500000 steps (95%)
00:24:11:WU01:FS00:0xa4:Completed 395000 out of 500000 steps (79%)
00:25:26:WU00:FS01:0x18:Completed 500000 out of 2500000 steps (20%)
00:26:58:WU03:FS02:0x18:Completed 2400000 out of 2500000 steps (96%)
00:27:00:WU01:FS00:0xa4:Completed 400000 out of 500000 steps (80%)
00:29:31:WU00:FS01:0x18:Completed 525000 out of 2500000 steps (21%)
00:29:54:WU01:FS00:0xa4:Completed 405000 out of 500000 steps (81%)
00:31:30:WU03:FS02:0x18:Completed 2425000 out of 2500000 steps (97%)
00:32:45:WU01:FS00:0xa4:Completed 410000 out of 500000 steps (82%)
00:33:28:WU00:FS01:0x18:Completed 550000 out of 2500000 steps (22%)
00:35:30:WU01:FS00:0xa4:Completed 415000 out of 500000 steps (83%)
00:35:48:WU03:FS02:0x18:Completed 2450000 out of 2500000 steps (98%)
00:37:23:WU00:FS01:0x18:Completed 575000 out of 2500000 steps (23%)
00:38:17:WU01:FS00:0xa4:Completed 420000 out of 500000 steps (84%)
00:40:07:WU03:FS02:0x18:Completed 2475000 out of 2500000 steps (99%)
00:41:04:WU01:FS00:0xa4:Completed 425000 out of 500000 steps (85%)
00:41:20:WU00:FS01:0x18:Completed 600000 out of 2500000 steps (24%)
00:43:50:WU01:FS00:0xa4:Completed 430000 out of 500000 steps (86%)
00:44:28:WU03:FS02:0x18:Completed 2500000 out of 2500000 steps (100%)
00:44:30:WU02:FS02:Connecting to 171.67.108.200:80
00:44:31:WU02:FS02:Assigned to work server 171.64.65.93
00:44:31:WU02:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GM204 [GeForce GTX 980] from 171.64.65.93
00:44:31:WU02:FS02:Connecting to 171.64.65.93:8080
00:44:31:WU02:FS02:Downloading 3.82MiB
00:44:36:WU02:FS02:Download complete
00:44:36:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9106 run:22 clone:6 gen:3 core:0x18 unit:0x000000040a3b1e81546bd32cedcb5d87
00:44:40:WU03:FS02:0x18:Saving result file logfile_01.txt
00:44:40:WU03:FS02:0x18:Saving result file checkpointState.xml
00:44:42:WU03:FS02:0x18:Saving result file checkpt.crc
00:44:42:WU03:FS02:0x18:Saving result file log.txt
00:44:42:WU03:FS02:0x18:Saving result file positions.xtc
00:44:43:WU03:FS02:0x18:Folding@home Core Shutdown: FINISHED_UNIT
00:44:44:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:44:44:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:9109 run:5 clone:1 gen:11 core:0x18 unit:0x0000000f0a3b1e80546a972fd51ab669
00:44:44:WU03:FS02:Uploading 7.04MiB to 171.64.65.92
00:44:44:WU03:FS02:Connecting to 171.64.65.92:8080
00:44:44:WU02:FS02:Starting
00:44:44:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
00:44:44:WU02:FS02:Started FahCore on PID 4212
00:44:44:WU02:FS02:Core PID:6444
00:44:44:WU02:FS02:FahCore 0x18 started
00:44:44:WU02:FS02:0x18:*********************** Log Started 2014-12-27T00:44:44Z ***********************
00:44:44:WU02:FS02:0x18:Project: 9106 (Run 22, Clone 6, Gen 3)
00:44:44:WU02:FS02:0x18:Unit: 0x000000040a3b1e81546bd32cedcb5d87
00:44:44:WU02:FS02:0x18:CPU: 0x00000000000000000000000000000000
00:44:44:WU02:FS02:0x18:Machine: 2
00:44:44:WU02:FS02:0x18:Reading tar file state.xml
00:44:44:WU02:FS02:0x18:Reading tar file system.xml
00:44:45:WU02:FS02:0x18:Reading tar file integrator.xml
00:44:45:WU02:FS02:0x18:Reading tar file core.xml
00:44:45:WU02:FS02:0x18:Digital signatures verified
00:44:45:WU02:FS02:0x18:Folding@home GPU core18
00:44:45:WU02:FS02:0x18:Version 0.0.3
00:44:50:WU03:FS02:Upload 7.10%
00:44:56:WU03:FS02:Upload 14.20%
00:45:02:WU03:FS02:Upload 19.52%
00:45:08:WU03:FS02:Upload 26.62%
00:45:14:WU03:FS02:Upload 33.72%
00:45:15:WU02:FS02:0x18:Completed 0 out of 2500000 steps (0%)
00:45:15:WU02:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:45:20:WU03:FS02:Upload 41.71%
00:45:26:WU03:FS02:Upload 48.81%
00:45:28:WU00:FS01:0x18:Completed 625000 out of 2500000 steps (25%)
00:45:32:WU03:FS02:Upload 55.91%
00:45:38:WU03:FS02:Upload 63.89%
00:45:44:WU03:FS02:Upload 70.99%
00:45:50:WU03:FS02:Upload 78.09%
00:45:56:WU03:FS02:Upload 85.19%
00:46:02:WU03:FS02:Upload 93.18%
00:46:08:WU03:FS02:Upload 100.00%
00:46:15:WU03:FS02:Upload complete
00:46:15:WU03:FS02:Server responded WORK_ACK (400)
00:46:15:WU03:FS02:Final credit estimate, 24178.00 points
00:46:15:WU03:FS02:Cleaning up
00:46:37:WU01:FS00:0xa4:Completed 435000 out of 500000 steps (87%)
00:49:26:WU00:FS01:0x18:Completed 650000 out of 2500000 steps (26%)
00:49:28:WU01:FS00:0xa4:Completed 440000 out of 500000 steps (88%)
00:49:56:WU02:FS02:0x18:Completed 25000 out of 2500000 steps (1%)
00:52:21:WU01:FS00:0xa4:Completed 445000 out of 500000 steps (89%)
00:53:24:WU00:FS01:0x18:Completed 675000 out of 2500000 steps (27%)
00:54:27:WU02:FS02:0x18:Completed 50000 out of 2500000 steps (2%)
00:55:12:WU01:FS00:0xa4:Completed 450000 out of 500000 steps (90%)
00:57:22:WU00:FS01:0x18:Completed 700000 out of 2500000 steps (28%)
00:58:13:WU01:FS00:0xa4:Completed 455000 out of 500000 steps (91%)
00:59:01:WU02:FS02:0x18:Completed 75000 out of 2500000 steps (3%)
01:01:13:WU01:FS00:0xa4:Completed 460000 out of 500000 steps (92%)
01:01:36:WU00:FS01:0x18:Completed 725000 out of 2500000 steps (29%)
01:03:32:WU02:FS02:0x18:Completed 100000 out of 2500000 steps (4%)
01:04:02:WU01:FS00:0xa4:Completed 465000 out of 500000 steps (93%)
01:05:30:WU00:FS01:0x18:Completed 750000 out of 2500000 steps (30%)
01:06:52:WU01:FS00:0xa4:Completed 470000 out of 500000 steps (94%)
01:08:13:WU02:FS02:0x18:Completed 125000 out of 2500000 steps (5%)
01:09:25:WU00:FS01:0x18:Completed 775000 out of 2500000 steps (31%)
01:09:44:WU01:FS00:0xa4:Completed 475000 out of 500000 steps (95%)
01:12:33:WU01:FS00:0xa4:Completed 480000 out of 500000 steps (96%)
01:12:42:WU02:FS02:0x18:Completed 150000 out of 2500000 steps (6%)
01:13:18:WU00:FS01:0x18:Completed 800000 out of 2500000 steps (32%)
01:15:27:WU01:FS00:0xa4:Completed 485000 out of 500000 steps (97%)
01:17:11:WU02:FS02:0x18:Completed 175000 out of 2500000 steps (7%)
01:17:22:WU00:FS01:0x18:Completed 825000 out of 2500000 steps (33%)
01:18:19:WU01:FS00:0xa4:Completed 490000 out of 500000 steps (98%)
01:21:16:WU00:FS01:0x18:Completed 850000 out of 2500000 steps (34%)
01:21:40:WU02:FS02:0x18:Completed 200000 out of 2500000 steps (8%)
01:22:41:WU01:FS00:0xa4:Completed 495000 out of 500000 steps (99%)
01:22:42:WU03:FS00:Connecting to 171.67.108.200:8080
01:22:43:WU03:FS00:Assigned to work server 171.64.65.124
01:22:43:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.64.65.124
01:22:43:WU03:FS00:Connecting to 171.64.65.124:8080
01:22:44:WU03:FS00:Downloading 910.39KiB
01:22:46:WU03:FS00:Download complete
01:22:46:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9013 run:738 clone:0 gen:102 core:0xa4 unit:0x00000076664f2de453e5566e4ff4c4b7
01:25:09:WU00:FS01:0x18:Completed 875000 out of 2500000 steps (35%)
01:25:57:WU01:FS00:0xa4:Completed 500000 out of 500000 steps (100%)
01:25:58:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
01:26:08:WU01:FS00:0xa4:
01:26:08:WU01:FS00:0xa4:Finished Work Unit:
01:26:08:WU01:FS00:0xa4:- Reading up to 2060184 from "01/wudata_01.trr": Read 2060184
01:26:08:WU01:FS00:0xa4:trr file hash check passed.
01:26:08:WU01:FS00:0xa4:- Reading up to 4422396 from "01/wudata_01.xtc": Read 4422396
01:26:08:WU01:FS00:0xa4:xtc file hash check passed.
01:26:08:WU01:FS00:0xa4:edr file hash check passed.
01:26:08:WU01:FS00:0xa4:logfile size: 24156
01:26:08:WU01:FS00:0xa4:Leaving Run
01:26:08:WU01:FS00:0xa4:- Writing 6745816 bytes of core data to disk...
01:26:09:WU01:FS00:0xa4:Done: 6745304 -> 6541350 (compressed to 96.9 percent)
01:26:09:WU01:FS00:0xa4: ... Done.
01:26:10:WU01:FS00:0xa4:- Shutting down core
01:26:10:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
01:26:10:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:26:10:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10187 run:961 clone:1 gen:46 core:0xa4 unit:0x000000354c71bbb05418de2752a5a907
01:26:10:WU01:FS00:Uploading 6.24MiB to 128.252.203.2
01:26:10:WU01:FS00:Connecting to 128.252.203.2:8080
01:26:10:WU03:FS00:Starting
01:26:10:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -np 6
01:26:10:WU03:FS00:Started FahCore on PID 8908
01:26:10:WU03:FS00:Core PID:8756
01:26:10:WU03:FS00:FahCore 0xa4 started
01:26:11:WU03:FS00:0xa4:
01:26:11:WU03:FS00:0xa4:*------------------------------*
01:26:11:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
01:26:11:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:26:11:WU03:FS00:0xa4:Preparing to commence simulation
01:26:11:WU03:FS00:0xa4:- Looking at optimizations...
01:26:11:WU03:FS00:0xa4:- Created dyn
01:26:11:WU03:FS00:0xa4:- Files status OK
01:26:11:WU03:FS00:0xa4:- Expanded 931728 -> 1546812 (decompressed 166.0 percent)
01:26:11:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=931728 data_size=1546812, decompressed_data_size=1546812 diff=0
01:26:11:WU03:FS00:0xa4:- Digital signature verified
01:26:11:WU03:FS00:0xa4:Project: 9013 (Run 738, Clone 0, Gen 102)
01:26:11:WU03:FS00:0xa4:Assembly optimizations on if available.
01:26:11:WU03:FS00:0xa4:Entering M.D.
01:26:16:WU01:FS00:Upload 8.01%
01:26:16:WU03:FS00:0xa4:Mapping NT from 6 to 6
01:26:17:WU03:FS00:0xa4:Completed 0 out of 250000 steps (0%)
01:26:17:WU02:FS02:0x18:Completed 225000 out of 2500000 steps (9%)
01:26:22:WU01:FS00:Upload 16.03%
01:26:28:WU01:FS00:Upload 22.04%
01:26:34:WU01:FS00:Upload 31.06%
01:26:40:WU01:FS00:Upload 39.07%
01:26:46:WU01:FS00:Upload 48.09%
01:26:52:WU01:FS00:Upload 56.10%
01:26:58:WU01:FS00:Upload 64.11%
01:27:04:WU01:FS00:Upload 73.13%
01:27:10:WU01:FS00:Upload 81.15%
01:27:16:WU01:FS00:Upload 90.16%
01:27:22:WU01:FS00:Upload 98.18%
01:27:25:WU01:FS00:Upload complete
01:27:25:WU01:FS00:Server responded WORK_ACK (400)
01:27:25:WU01:FS00:Final credit estimate, 2973.00 points
01:27:25:WU01:FS00:Cleaning up
01:27:48:WU03:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
01:29:03:WU00:FS01:0x18:Completed 900000 out of 2500000 steps (36%)
01:29:20:WU03:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
01:30:39:WU02:FS02:0x18:Completed 250000 out of 2500000 steps (10%)
01:30:56:WU03:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
01:32:27:WU03:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
01:33:06:WU00:FS01:0x18:Completed 925000 out of 2500000 steps (37%)
01:33:59:WU03:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
01:35:02:WU02:FS02:0x18:Completed 275000 out of 2500000 steps (11%)
01:35:29:WU03:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
01:36:59:WU03:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
01:36:59:WU00:FS01:0x18:Completed 950000 out of 2500000 steps (38%)
01:38:28:WU03:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
01:39:25:WU02:FS02:0x18:Completed 300000 out of 2500000 steps (12%)
01:39:58:WU03:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
01:40:52:WU00:FS01:0x18:Completed 975000 out of 2500000 steps (39%)
01:41:27:WU03:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
01:42:58:WU03:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
01:43:59:WU02:FS02:0x18:Completed 325000 out of 2500000 steps (13%)
01:44:29:WU03:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
01:44:45:WU00:FS01:0x18:Completed 1000000 out of 2500000 steps (40%)
01:45:58:WU03:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
01:47:27:WU03:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
01:48:22:WU02:FS02:0x18:Completed 350000 out of 2500000 steps (14%)
01:48:49:WU00:FS01:0x18:Completed 1025000 out of 2500000 steps (41%)
01:48:56:WU03:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
01:50:25:WU03:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
01:51:54:WU03:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
01:52:43:WU00:FS01:0x18:Completed 1050000 out of 2500000 steps (42%)
01:52:45:WU02:FS02:0x18:Completed 375000 out of 2500000 steps (15%)
01:53:22:WU03:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
01:54:51:WU03:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
01:56:19:WU03:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
01:56:36:WU00:FS01:0x18:Completed 1075000 out of 2500000 steps (43%)
01:57:07:WU02:FS02:0x18:Completed 400000 out of 2500000 steps (16%)
01:57:47:WU03:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
01:59:16:WU03:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
02:00:30:WU00:FS01:0x18:Completed 1100000 out of 2500000 steps (44%)
02:00:45:WU03:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
02:01:42:WU02:FS02:0x18:Completed 425000 out of 2500000 steps (17%)
02:02:13:WU03:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
02:03:41:WU03:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
02:04:33:WU00:FS01:0x18:Completed 1125000 out of 2500000 steps (45%)
02:05:10:WU03:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
02:06:05:WU02:FS02:0x18:Completed 450000 out of 2500000 steps (18%)
02:06:38:WU03:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
02:08:07:WU03:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
02:08:26:WU00:FS01:0x18:Completed 1150000 out of 2500000 steps (46%)
02:09:36:WU03:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
02:10:27:WU02:FS02:0x18:Completed 475000 out of 2500000 steps (19%)
02:11:04:WU03:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
02:12:19:WU00:FS01:0x18:Completed 1175000 out of 2500000 steps (47%)
02:12:32:WU03:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
02:14:01:WU03:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
02:14:50:WU02:FS02:0x18:Completed 500000 out of 2500000 steps (20%)
02:15:30:WU03:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
02:16:12:WU00:FS01:0x18:Completed 1200000 out of 2500000 steps (48%)
02:16:59:WU03:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
02:18:28:WU03:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
02:19:24:WU02:FS02:0x18:Completed 525000 out of 2500000 steps (21%)
02:19:57:WU03:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
02:20:15:WU00:FS01:0x18:Completed 1225000 out of 2500000 steps (49%)
02:21:25:WU03:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
02:22:55:WU03:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
02:23:47:WU02:FS02:0x18:Completed 550000 out of 2500000 steps (22%)
02:24:07:WU00:FS01:0x18:Completed 1250000 out of 2500000 steps (50%)
02:24:25:WU03:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
02:25:53:WU03:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
02:27:20:WU03:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
02:28:00:WU00:FS01:0x18:Completed 1275000 out of 2500000 steps (51%)
02:28:09:WU02:FS02:0x18:Completed 575000 out of 2500000 steps (23%)
02:28:47:WU03:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
02:30:14:WU03:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
02:31:42:WU03:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
02:31:53:WU00:FS01:0x18:Completed 1300000 out of 2500000 steps (52%)
02:32:32:WU02:FS02:0x18:Completed 600000 out of 2500000 steps (24%)
02:33:09:WU03:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
02:34:36:WU03:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
02:35:56:WU00:FS01:0x18:Completed 1325000 out of 2500000 steps (53%)
02:36:04:WU03:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
02:37:07:WU02:FS02:0x18:Completed 625000 out of 2500000 steps (25%)
02:37:31:WU03:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
02:38:59:WU03:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
02:39:49:WU00:FS01:0x18:Completed 1350000 out of 2500000 steps (54%)
02:40:26:WU03:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
02:41:29:WU02:FS02:0x18:Completed 650000 out of 2500000 steps (26%)
02:41:53:WU03:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
02:43:21:WU03:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
02:43:42:WU00:FS01:0x18:Completed 1375000 out of 2500000 steps (55%)
02:44:48:WU03:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
02:45:52:WU02:FS02:0x18:Completed 675000 out of 2500000 steps (27%)
02:46:15:WU03:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
02:47:34:WU00:FS01:0x18:Completed 1400000 out of 2500000 steps (56%)
02:47:43:WU03:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
02:49:10:WU03:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
02:50:14:WU02:FS02:0x18:Completed 700000 out of 2500000 steps (28%)
02:50:37:WU03:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
02:51:38:WU00:FS01:0x18:Completed 1425000 out of 2500000 steps (57%)
02:52:04:WU03:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
02:53:31:WU03:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
02:54:49:WU02:FS02:0x18:Completed 725000 out of 2500000 steps (29%)
02:54:58:WU03:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
02:55:30:WU00:FS01:0x18:Completed 1450000 out of 2500000 steps (58%)
02:56:26:WU03:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
02:57:53:WU03:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
02:59:12:WU02:FS02:0x18:Completed 750000 out of 2500000 steps (30%)
02:59:20:WU03:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
02:59:23:WU00:FS01:0x18:Completed 1475000 out of 2500000 steps (59%)
03:00:47:WU03:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
03:02:14:WU03:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
03:03:16:WU00:FS01:0x18:Completed 1500000 out of 2500000 steps (60%)
03:03:34:WU02:FS02:0x18:Completed 775000 out of 2500000 steps (31%)
03:03:41:WU03:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
03:05:08:WU03:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
03:06:35:WU03:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
03:07:19:WU00:FS01:0x18:Completed 1525000 out of 2500000 steps (61%)
03:07:57:WU02:FS02:0x18:Completed 800000 out of 2500000 steps (32%)
03:08:02:WU03:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
03:09:29:WU03:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
03:10:57:WU03:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
03:11:12:WU00:FS01:0x18:Completed 1550000 out of 2500000 steps (62%)
03:12:24:WU03:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
03:12:32:WU02:FS02:0x18:Completed 825000 out of 2500000 steps (33%)
03:13:52:WU03:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
03:15:04:WU00:FS01:0x18:Completed 1575000 out of 2500000 steps (63%)
03:15:19:WU03:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
03:16:47:WU03:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
03:16:54:WU02:FS02:0x18:Completed 850000 out of 2500000 steps (34%)
03:18:14:WU03:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
03:18:57:WU00:FS01:0x18:Completed 1600000 out of 2500000 steps (64%)
03:19:40:WU03:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
03:21:08:WU03:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
03:21:17:WU02:FS02:0x18:Completed 875000 out of 2500000 steps (35%)
03:22:35:WU03:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
03:23:00:WU00:FS01:0x18:Completed 1625000 out of 2500000 steps (65%)
03:24:02:WU03:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
03:25:30:WU03:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
03:25:40:WU02:FS02:0x18:Completed 900000 out of 2500000 steps (36%)
03:26:53:WU00:FS01:0x18:Completed 1650000 out of 2500000 steps (66%)
03:26:57:WU03:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
03:28:26:WU03:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
03:29:53:WU03:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
03:30:14:WU02:FS02:0x18:Completed 925000 out of 2500000 steps (37%)
03:30:46:WU00:FS01:0x18:Completed 1675000 out of 2500000 steps (67%)
03:31:27:WU03:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
03:33:29:WU03:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
03:34:37:WU02:FS02:0x18:Completed 950000 out of 2500000 steps (38%)
03:34:39:WU00:FS01:0x18:Completed 1700000 out of 2500000 steps (68%)
03:35:13:WU03:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
03:36:40:WU03:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
03:38:07:WU03:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
03:38:42:WU00:FS01:0x18:Completed 1725000 out of 2500000 steps (69%)
03:38:59:WU02:FS02:0x18:Completed 975000 out of 2500000 steps (39%)
03:39:34:WU03:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
03:41:02:WU03:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
03:42:29:WU03:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
03:42:35:WU00:FS01:0x18:Completed 1750000 out of 2500000 steps (70%)
03:43:22:WU02:FS02:0x18:Completed 1000000 out of 2500000 steps (40%)
03:43:56:WU03:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
03:45:24:WU03:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
03:46:27:WU00:FS01:0x18:Completed 1775000 out of 2500000 steps (71%)
03:46:51:WU03:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
03:47:56:WU02:FS02:0x18:Completed 1025000 out of 2500000 steps (41%)
03:48:18:WU03:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
03:49:45:WU03:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
03:50:20:WU00:FS01:0x18:Completed 1800000 out of 2500000 steps (72%)
03:51:12:WU03:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
03:52:19:WU02:FS02:0x18:Completed 1050000 out of 2500000 steps (42%)
03:52:39:WU03:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
03:52:40:WU01:FS00:Connecting to 171.67.108.200:8080
03:52:41:WU01:FS00:Assigned to work server 171.64.65.124
03:52:41:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.64.65.124
03:52:41:WU01:FS00:Connecting to 171.64.65.124:8080
03:52:42:WU01:FS00:Downloading 902.87KiB
03:52:44:WU01:FS00:Download complete
03:52:45:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9011 run:632 clone:5 gen:5 core:0xa4 unit:0x00000008664f2de4548af6f8f7dd5686
03:54:06:WU03:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
03:54:07:WU03:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
03:54:17:WU03:FS00:0xa4:
03:54:17:WU03:FS00:0xa4:Finished Work Unit:
03:54:17:WU03:FS00:0xa4:- Reading up to 922512 from "03/wudata_01.trr": Read 922512
03:54:17:WU03:FS00:0xa4:trr file hash check passed.
03:54:17:WU03:FS00:0xa4:- Reading up to 845392 from "03/wudata_01.xtc": Read 845392
03:54:17:WU03:FS00:0xa4:xtc file hash check passed.
03:54:17:WU03:FS00:0xa4:edr file hash check passed.
03:54:17:WU03:FS00:0xa4:logfile size: 23174
03:54:17:WU03:FS00:0xa4:Leaving Run
03:54:17:WU03:FS00:0xa4:- Writing 1793566 bytes of core data to disk...
03:54:17:WU03:FS00:0xa4:Done: 1793054 -> 1733311 (compressed to 96.6 percent)
03:54:17:WU03:FS00:0xa4: ... Done.
03:54:17:WU03:FS00:0xa4:- Shutting down core
03:54:17:WU03:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
03:54:18:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:54:18:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:9013 run:738 clone:0 gen:102 core:0xa4 unit:0x00000076664f2de453e5566e4ff4c4b7
03:54:18:WU03:FS00:Uploading 1.65MiB to 171.64.65.124
03:54:18:WU03:FS00:Connecting to 171.64.65.124:8080
03:54:18:WU01:FS00:Starting
03:54:18:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -np 6
03:54:18:WU01:FS00:Started FahCore on PID 8660
03:54:18:WU01:FS00:Core PID:1236
03:54:18:WU01:FS00:FahCore 0xa4 started
03:54:18:WU01:FS00:0xa4:
03:54:18:WU01:FS00:0xa4:*------------------------------*
03:54:18:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
03:54:18:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:54:18:WU01:FS00:0xa4:Preparing to commence simulation
03:54:18:WU01:FS00:0xa4:- Looking at optimizations...
03:54:18:WU01:FS00:0xa4:- Created dyn
03:54:18:WU01:FS00:0xa4:- Files status OK
03:54:18:WU01:FS00:0xa4:- Expanded 924023 -> 1527780 (decompressed 165.3 percent)
03:54:18:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=924023 data_size=1527780, decompressed_data_size=1527780 diff=0
03:54:18:WU01:FS00:0xa4:- Digital signature verified
03:54:18:WU01:FS00:0xa4:Project: 9011 (Run 632, Clone 5, Gen 5)
03:54:18:WU01:FS00:0xa4:Assembly optimizations on if available.
03:54:18:WU01:FS00:0xa4:Entering M.D.
03:54:24:WU03:FS00:Upload 26.46%
03:54:24:WU01:FS00:0xa4:Mapping NT from 6 to 6
03:54:24:WU01:FS00:0xa4:Completed 0 out of 250000 steps (0%)
03:54:24:WU00:FS01:0x18:Completed 1825000 out of 2500000 steps (73%)
03:54:30:WU03:FS00:Upload 60.48%
03:54:36:WU03:FS00:Upload 90.72%
03:54:39:WU03:FS00:Upload complete
03:54:39:WU03:FS00:Server responded WORK_ACK (400)
03:54:39:WU03:FS00:Final credit estimate, 1729.00 points
03:54:39:WU03:FS00:Cleaning up
03:55:54:WU01:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
03:56:41:WU02:FS02:0x18:Completed 1075000 out of 2500000 steps (43%)
03:57:20:WU01:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
03:58:18:WU00:FS01:0x18:Completed 1850000 out of 2500000 steps (74%)
03:58:45:WU01:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
04:00:12:WU01:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
04:01:04:WU02:FS02:0x18:Completed 1100000 out of 2500000 steps (44%)
04:01:37:WU01:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
04:02:12:WU00:FS01:0x18:Completed 1875000 out of 2500000 steps (75%)
04:03:03:WU01:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
04:04:29:WU01:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
04:05:39:WU02:FS02:0x18:Completed 1125000 out of 2500000 steps (45%)
04:05:55:WU01:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
04:06:05:WU00:FS01:0x18:Completed 1900000 out of 2500000 steps (76%)
04:07:21:WU01:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
04:08:47:WU01:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
04:10:01:WU02:FS02:0x18:Completed 1150000 out of 2500000 steps (46%)
04:10:09:WU00:FS01:0x18:Completed 1925000 out of 2500000 steps (77%)
04:10:13:WU01:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
04:11:39:WU01:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
04:13:05:WU01:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
04:14:02:WU00:FS01:0x18:Completed 1950000 out of 2500000 steps (78%)
04:14:24:WU02:FS02:0x18:Completed 1175000 out of 2500000 steps (47%)
04:14:31:WU01:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
04:15:57:WU01:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
04:17:22:WU01:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
04:17:54:WU00:FS01:0x18:Completed 1975000 out of 2500000 steps (79%)
04:18:47:WU02:FS02:0x18:Completed 1200000 out of 2500000 steps (48%)
04:18:47:WU01:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
04:20:16:WU01:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
04:21:41:WU01:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
04:21:47:WU00:FS01:0x18:Completed 2000000 out of 2500000 steps (80%)
04:23:06:WU01:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
04:23:21:WU02:FS02:0x18:Completed 1225000 out of 2500000 steps (49%)
04:24:32:WU01:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
04:25:50:WU00:FS01:0x18:Completed 2025000 out of 2500000 steps (81%)
04:25:57:WU01:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
04:27:23:WU01:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
04:27:44:WU02:FS02:0x18:Completed 1250000 out of 2500000 steps (50%)
04:28:49:WU01:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
04:29:43:WU00:FS01:0x18:Completed 2050000 out of 2500000 steps (82%)
04:30:15:WU01:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
04:31:40:WU01:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
04:32:06:WU02:FS02:0x18:Completed 1275000 out of 2500000 steps (51%)
04:33:06:WU01:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
04:33:36:WU00:FS01:0x18:Completed 2075000 out of 2500000 steps (83%)
04:34:32:WU01:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
04:35:58:WU01:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
04:36:29:WU02:FS02:0x18:Completed 1300000 out of 2500000 steps (52%)
04:37:23:WU01:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
04:37:28:WU00:FS01:0x18:Completed 2100000 out of 2500000 steps (84%)
04:38:49:WU01:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
04:40:15:WU01:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
04:41:03:WU02:FS02:0x18:Completed 1325000 out of 2500000 steps (53%)
04:41:32:WU00:FS01:0x18:Completed 2125000 out of 2500000 steps (85%)
04:41:41:WU01:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
04:43:06:WU01:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
04:44:33:WU01:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
04:45:24:WU00:FS01:0x18:Completed 2150000 out of 2500000 steps (86%)
04:45:26:WU02:FS02:0x18:Completed 1350000 out of 2500000 steps (54%)
04:45:59:WU01:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
04:47:25:WU01:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
04:48:51:WU01:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
04:49:17:WU00:FS01:0x18:Completed 2175000 out of 2500000 steps (87%)
04:49:49:WU02:FS02:0x18:Completed 1375000 out of 2500000 steps (55%)
04:50:17:WU01:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
04:51:43:WU01:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
04:53:08:WU01:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
04:53:10:WU00:FS01:0x18:Completed 2200000 out of 2500000 steps (88%)
04:54:11:WU02:FS02:0x18:Completed 1400000 out of 2500000 steps (56%)
04:54:34:WU01:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
04:56:00:WU01:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
04:57:13:WU00:FS01:0x18:Completed 2225000 out of 2500000 steps (89%)
04:57:26:WU01:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
04:58:46:WU02:FS02:0x18:Completed 1425000 out of 2500000 steps (57%)
04:58:53:WU01:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
05:00:19:WU01:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
05:01:06:WU00:FS01:0x18:Completed 2250000 out of 2500000 steps (90%)
05:01:45:WU01:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
05:03:08:WU02:FS02:0x18:Completed 1450000 out of 2500000 steps (58%)
05:03:11:WU01:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
05:04:37:WU01:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
05:04:59:WU00:FS01:0x18:Completed 2275000 out of 2500000 steps (91%)
05:06:03:WU01:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
05:07:29:WU01:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
05:07:31:WU02:FS02:0x18:Completed 1475000 out of 2500000 steps (59%)
05:08:52:WU00:FS01:0x18:Completed 2300000 out of 2500000 steps (92%)
05:08:56:WU01:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
05:10:22:WU01:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
05:11:47:WU01:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
05:11:54:WU02:FS02:0x18:Completed 1500000 out of 2500000 steps (60%)
05:12:55:WU00:FS01:0x18:Completed 2325000 out of 2500000 steps (93%)
05:13:14:WU01:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
05:14:39:WU01:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
05:16:13:WU01:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
05:16:28:WU02:FS02:0x18:Completed 1525000 out of 2500000 steps (61%)
05:16:48:WU00:FS01:0x18:Completed 2350000 out of 2500000 steps (94%)
05:18:28:WU01:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
05:19:59:WU01:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
05:20:41:WU00:FS01:0x18:Completed 2375000 out of 2500000 steps (95%)
05:20:51:WU02:FS02:0x18:Completed 1550000 out of 2500000 steps (62%)
05:21:25:WU01:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
05:22:51:WU01:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
05:24:17:WU01:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
05:24:34:WU00:FS01:0x18:Completed 2400000 out of 2500000 steps (96%)
05:25:14:WU02:FS02:0x18:Completed 1575000 out of 2500000 steps (63%)
05:25:44:WU01:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
05:27:10:WU01:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
05:28:37:WU01:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
05:28:37:WU00:FS01:0x18:Completed 2425000 out of 2500000 steps (97%)
05:29:36:WU02:FS02:0x18:Completed 1600000 out of 2500000 steps (64%)
05:30:03:WU01:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
05:31:29:WU01:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
05:32:29:WU00:FS01:0x18:Completed 2450000 out of 2500000 steps (98%)
05:32:55:WU01:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
05:34:11:WU02:FS02:0x18:Completed 1625000 out of 2500000 steps (65%)
05:34:21:WU01:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
05:35:47:WU01:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
05:36:22:WU00:FS01:0x18:Completed 2475000 out of 2500000 steps (99%)
05:37:14:WU01:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
05:38:33:WU02:FS02:0x18:Completed 1650000 out of 2500000 steps (66%)
05:38:40:WU01:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
05:40:07:WU01:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
05:40:15:WU00:FS01:0x18:Completed 2500000 out of 2500000 steps (100%)
05:40:16:WU03:FS01:Connecting to 171.67.108.200:80
05:40:17:WU03:FS01:Assigned to work server 171.64.65.92
05:40:17:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 980] from 171.64.65.92
05:40:17:WU03:FS01:Connecting to 171.64.65.92:8080
05:40:18:WU03:FS01:Downloading 3.77MiB
05:40:23:WU03:FS01:Download complete
05:40:23:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9110 run:21 clone:0 gen:3 core:0x18 unit:0x000000030a3b1e80546a98c7bd7218b2
05:40:25:WU00:FS01:0x18:Saving result file logfile_01.txt
05:40:26:WU00:FS01:0x18:Saving result file checkpointState.xml
05:40:27:WU00:FS01:0x18:Saving result file checkpt.crc
05:40:27:WU00:FS01:0x18:Saving result file log.txt
05:40:27:WU00:FS01:0x18:Saving result file positions.xtc
05:40:28:WU00:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
05:40:29:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:40:29:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9107 run:14 clone:1 gen:12 core:0x18 unit:0x0000000f0a3b1e81546bd4414b91c739
05:40:29:WU00:FS01:Uploading 6.52MiB to 171.64.65.93
05:40:29:WU00:FS01:Connecting to 171.64.65.93:8080
05:40:29:WU03:FS01:Starting
05:40:29:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 03 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:40:29:WU03:FS01:Started FahCore on PID 2040
05:40:29:WU03:FS01:Core PID:1524
05:40:29:WU03:FS01:FahCore 0x18 started
05:40:29:WU03:FS01:0x18:*********************** Log Started 2014-12-27T05:40:29Z ***********************
05:40:29:WU03:FS01:0x18:Project: 9110 (Run 21, Clone 0, Gen 3)
05:40:29:WU03:FS01:0x18:Unit: 0x000000030a3b1e80546a98c7bd7218b2
05:40:29:WU03:FS01:0x18:CPU: 0x00000000000000000000000000000000
05:40:29:WU03:FS01:0x18:Machine: 1
05:40:29:WU03:FS01:0x18:Reading tar file state.xml
05:40:29:WU03:FS01:0x18:Reading tar file system.xml
05:40:30:WU03:FS01:0x18:Reading tar file integrator.xml
05:40:30:WU03:FS01:0x18:Reading tar file core.xml
05:40:30:WU03:FS01:0x18:Digital signatures verified
05:40:30:WU03:FS01:0x18:Folding@home GPU core18
05:40:30:WU03:FS01:0x18:Version 0.0.3
05:40:35:WU00:FS01:Upload 6.71%
05:40:41:WU00:FS01:Upload 15.33%
05:40:47:WU00:FS01:Upload 23.00%
05:40:53:WU00:FS01:Upload 31.63%
05:40:59:WU00:FS01:Upload 39.29%
05:40:59:WU03:FS01:0x18:Completed 0 out of 2500000 steps (0%)
05:40:59:WU03:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:41:05:WU00:FS01:Upload 46.96%
05:41:11:WU00:FS01:Upload 55.58%
05:41:17:WU00:FS01:Upload 62.29%
05:41:23:WU00:FS01:Upload 69.00%
05:41:29:WU00:FS01:Upload 76.67%
05:41:33:WU01:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
05:41:35:WU00:FS01:Upload 84.34%
05:41:41:WU00:FS01:Upload 92.96%
05:41:47:WU00:FS01:Upload 100.00%
05:41:54:WU00:FS01:Upload complete
05:41:54:WU00:FS01:Server responded WORK_ACK (400)
05:41:54:WU00:FS01:Final credit estimate, 25318.00 points
05:41:54:WU00:FS01:Cleaning up
05:42:56:WU02:FS02:0x18:Completed 1675000 out of 2500000 steps (67%)
05:42:58:WU01:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
05:44:25:WU01:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
05:45:18:WU03:FS01:0x18:Completed 25000 out of 2500000 steps (1%)
05:45:50:WU01:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
05:47:15:WU01:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
05:47:19:WU02:FS02:0x18:Completed 1700000 out of 2500000 steps (68%)
05:48:41:WU01:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
05:49:28:WU03:FS01:0x18:Completed 50000 out of 2500000 steps (2%)
05:50:07:WU01:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
05:51:33:WU01:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
05:51:54:WU02:FS02:0x18:Completed 1725000 out of 2500000 steps (69%)
05:52:58:WU01:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
05:53:38:WU03:FS01:0x18:Completed 75000 out of 2500000 steps (3%)
05:54:24:WU01:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
05:55:50:WU01:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
05:56:16:WU02:FS02:0x18:Completed 1750000 out of 2500000 steps (70%)
05:57:16:WU01:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
05:57:48:WU03:FS01:0x18:Completed 100000 out of 2500000 steps (4%)
05:58:42:WU01:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
06:00:08:WU01:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
06:00:39:WU02:FS02:0x18:Completed 1775000 out of 2500000 steps (71%)
06:01:34:WU01:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
06:02:11:WU03:FS01:0x18:Completed 125000 out of 2500000 steps (5%)
06:02:59:WU01:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
06:04:24:WU01:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
06:05:02:WU02:FS02:0x18:Completed 1800000 out of 2500000 steps (72%)
06:05:50:WU01:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
06:06:21:WU03:FS01:0x18:Completed 150000 out of 2500000 steps (6%)
06:07:15:WU01:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
06:08:40:WU01:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
******************************* Date: 2014-12-27 *******************************
06:09:37:WU02:FS02:0x18:Completed 1825000 out of 2500000 steps (73%)
06:10:06:WU01:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
06:10:32:WU03:FS01:0x18:Completed 175000 out of 2500000 steps (7%)
06:11:30:WU01:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
06:12:56:WU01:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
06:13:59:WU02:FS02:0x18:Completed 1850000 out of 2500000 steps (74%)
06:14:22:WU01:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
06:14:43:WU03:FS01:0x18:Completed 200000 out of 2500000 steps (8%)
06:15:47:WU01:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
06:17:12:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
06:17:13:WU00:FS00:Connecting to 171.67.108.200:8080
06:17:14:WU00:FS00:Assigned to work server 171.64.65.124
06:17:14:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.64.65.124
06:17:14:WU00:FS00:Connecting to 171.64.65.124:8080
06:17:15:WU00:FS00:Downloading 902.84KiB
06:17:18:WU00:FS00:Download complete
06:17:18:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9011 run:268 clone:2 gen:74 core:0xa4 unit:0x00000059664f2de453c87786c953e96a
06:18:22:WU02:FS02:0x18:Completed 1875000 out of 2500000 steps (75%)
06:18:38:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
06:18:38:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
06:18:48:WU01:FS00:0xa4:
06:18:48:WU01:FS00:0xa4:Finished Work Unit:
06:18:48:WU01:FS00:0xa4:- Reading up to 917280 from "01/wudata_01.trr": Read 917280
06:18:48:WU01:FS00:0xa4:trr file hash check passed.
06:18:48:WU01:FS00:0xa4:- Reading up to 840408 from "01/wudata_01.xtc": Read 840408
06:18:48:WU01:FS00:0xa4:xtc file hash check passed.
06:18:48:WU01:FS00:0xa4:edr file hash check passed.
06:18:48:WU01:FS00:0xa4:logfile size: 22999
06:18:48:WU01:FS00:0xa4:Leaving Run
06:18:50:WU01:FS00:0xa4:- Writing 1783175 bytes of core data to disk...
06:18:50:WU01:FS00:0xa4:Done: 1782663 -> 1723759 (compressed to 96.6 percent)
06:18:50:WU01:FS00:0xa4: ... Done.
06:18:50:WU01:FS00:0xa4:- Shutting down core
06:18:50:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
06:18:50:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:18:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9011 run:632 clone:5 gen:5 core:0xa4 unit:0x00000008664f2de4548af6f8f7dd5686
06:18:50:WU01:FS00:Uploading 1.64MiB to 171.64.65.124
06:18:50:WU01:FS00:Connecting to 171.64.65.124:8080
06:18:51:WU00:FS00:Starting
06:18:51:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -np 6
06:18:51:WU00:FS00:Started FahCore on PID 5444
06:18:51:WU00:FS00:Core PID:3400
06:18:51:WU00:FS00:FahCore 0xa4 started
06:18:51:WU00:FS00:0xa4:
06:18:51:WU00:FS00:0xa4:*------------------------------*
06:18:51:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
06:18:51:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:18:51:WU00:FS00:0xa4:Preparing to commence simulation
06:18:51:WU00:FS00:0xa4:- Looking at optimizations...
06:18:51:WU00:FS00:0xa4:- Created dyn
06:18:51:WU00:FS00:0xa4:- Files status OK
06:18:51:WU00:FS00:0xa4:- Expanded 923997 -> 1527780 (decompressed 165.3 percent)
06:18:51:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923997 data_size=1527780, decompressed_data_size=1527780 diff=0
06:18:51:WU00:FS00:0xa4:- Digital signature verified
06:18:51:WU00:FS00:0xa4:Project: 9011 (Run 268, Clone 2, Gen 74)
06:18:51:WU00:FS00:0xa4:Assembly optimizations on if available.
06:18:51:WU00:FS00:0xa4:Entering M.D.
06:18:56:WU01:FS00:Upload 22.80%
06:18:57:WU00:FS00:0xa4:Mapping NT from 6 to 6
06:18:57:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
06:19:02:WU01:FS00:Upload 53.21%
06:19:05:WU03:FS01:0x18:Completed 225000 out of 2500000 steps (9%)
06:19:08:WU01:FS00:Upload 87.42%
06:19:12:WU01:FS00:Upload complete
06:19:12:WU01:FS00:Server responded WORK_ACK (400)
06:19:12:WU01:FS00:Final credit estimate, 1760.00 points
06:19:12:WU01:FS00:Cleaning up
06:20:25:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
06:21:53:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
06:22:44:WU02:FS02:0x18:Completed 1900000 out of 2500000 steps (76%)
06:23:14:WU03:FS01:0x18:Completed 250000 out of 2500000 steps (10%)
06:23:21:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
06:24:50:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
06:26:18:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
06:27:19:WU02:FS02:0x18:Completed 1925000 out of 2500000 steps (77%)
06:27:25:WU03:FS01:0x18:Completed 275000 out of 2500000 steps (11%)
06:27:46:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
06:29:15:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
06:30:43:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
06:31:34:WU03:FS01:0x18:Completed 300000 out of 2500000 steps (12%)
06:31:42:WU02:FS02:0x18:Completed 1950000 out of 2500000 steps (78%)
06:32:12:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
06:33:40:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
06:35:08:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
06:35:57:WU03:FS01:0x18:Completed 325000 out of 2500000 steps (13%)
06:36:04:WU02:FS02:0x18:Completed 1975000 out of 2500000 steps (79%)
06:36:37:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
06:38:05:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
06:39:33:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
06:40:07:WU03:FS01:0x18:Completed 350000 out of 2500000 steps (14%)
06:40:27:WU02:FS02:0x18:Completed 2000000 out of 2500000 steps (80%)
06:41:01:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
06:42:30:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
06:43:58:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
06:44:18:WU03:FS01:0x18:Completed 375000 out of 2500000 steps (15%)
06:45:01:WU02:FS02:0x18:Completed 2025000 out of 2500000 steps (81%)
06:45:26:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
06:46:54:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
06:48:22:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
06:48:29:WU03:FS01:0x18:Completed 400000 out of 2500000 steps (16%)
06:49:24:WU02:FS02:0x18:Completed 2050000 out of 2500000 steps (82%)
06:49:50:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
06:51:19:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
06:52:47:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
06:52:50:WU03:FS01:0x18:Completed 425000 out of 2500000 steps (17%)
06:53:46:WU02:FS02:0x18:Completed 2075000 out of 2500000 steps (83%)
06:54:16:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
06:55:44:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
06:57:00:WU03:FS01:0x18:Completed 450000 out of 2500000 steps (18%)
06:57:12:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
06:58:09:WU02:FS02:0x18:Completed 2100000 out of 2500000 steps (84%)
06:58:41:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
07:00:10:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
07:01:10:WU03:FS01:0x18:Completed 475000 out of 2500000 steps (19%)
07:01:38:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
07:02:44:WU02:FS02:0x18:Completed 2125000 out of 2500000 steps (85%)
07:03:07:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
07:04:35:WU00:FS00:0xa4:
08:09:02:WU01:FS02:Connecting to 171.67.108.200:80
08:09:03:WU01:FS02:Assigned to work server 140.163.4.235
08:09:03:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GM204 [GeForce GTX 980] from 140.163.4.235
08:09:03:WU01:FS02:Connecting to 140.163.4.235:8080
08:09:04:WU01:FS02:Downloading 4.19MiB
08:09:07:WU01:FS02:Download complete
08:09:07:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10471 run:0 clone:143 gen:86 core:0x18 unit:0x0000006e538b3dbb53beaac9bb478c9e
08:09:14:WU02:FS02:0x18:Saving result file logfile_01.txt
08:09:14:WU02:FS02:0x18:Saving result file checkpointState.xml
08:09:16:WU02:FS02:0x18:Saving result file checkpt.crc
08:09:16:WU02:FS02:0x18:Saving result file log.txt
08:09:16:WU02:FS02:0x18:Saving result file positions.xtc
08:09:17:WU02:FS02:0x18:Folding@home Core Shutdown: FINISHED_UNIT
08:09:17:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:09:17:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9106 run:22 clone:6 gen:3 core:0x18 unit:0x000000040a3b1e81546bd32cedcb5d87
08:09:17:WU02:FS02:Uploading 7.29MiB to 171.64.65.93
08:09:17:WU02:FS02:Connecting to 171.64.65.93:8080
08:09:18:WU01:FS02:Starting
08:09:18:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 8000 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
08:09:18:WU01:FS02:Started FahCore on PID 8988
08:09:18:WU01:FS02:Core PID:3872
08:09:18:WU01:FS02:FahCore 0x18 started
08:09:18:WU01:FS02:0x18:*********************** Log Started 2014-12-27T08:09:18Z ***********************
08:09:18:WU01:FS02:0x18:Project: 10471 (Run 0, Clone 143, Gen 86)
08:09:18:WU01:FS02:0x18:Unit: 0x0000006e538b3dbb53beaac9bb478c9e
08:09:18:WU01:FS02:0x18:CPU: 0x00000000000000000000000000000000
08:09:18:WU01:FS02:0x18:Machine: 2
08:09:18:WU01:FS02:0x18:Reading tar file state.xml
08:09:19:WU01:FS02:0x18:Reading tar file system.xml
08:09:19:WU01:FS02:0x18:Reading tar file integrator.xml
08:09:19:WU01:FS02:0x18:Reading tar file core.xml
08:09:19:WU01:FS02:0x18:Digital signatures verified
08:09:19:WU01:FS02:0x18:Folding@home GPU core18
08:09:19:WU01:FS02:0x18:Version 0.0.3
08:09:23:WU02:FS02:Upload 5.14%
08:09:29:WU02:FS02:Upload 12.85%
08:09:35:WU02:FS02:Upload 19.71%
08:09:41:WU02:FS02:Upload 24.85%
08:09:47:WU02:FS02:Upload 31.71%
08:09:49:WU01:FS02:0x18:Completed 0 out of 5000000 steps (0%)
08:09:49:WU01:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:09:52:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
08:09:53:WU02:FS02:Upload 38.56%
08:09:59:WU02:FS02:Upload 45.42%
08:10:05:WU02:FS02:Upload 52.27%
08:10:11:WU02:FS02:Upload 58.27%
08:10:17:WU02:FS02:Upload 65.98%
08:10:23:WU02:FS02:Upload 72.84%
08:10:29:WU02:FS02:Upload 79.69%
08:10:35:WU02:FS02:Upload 86.55%
08:10:41:WU02:FS02:Upload 93.41%
08:10:47:WU02:FS02:Upload 100.00%
08:10:54:WU02:FS02:Upload complete
08:10:54:WU02:FS02:Server responded WORK_ACK (400)
08:10:54:WU02:FS02:Final credit estimate, 24299.00 points
08:10:54:WU02:FS02:Cleaning up
08:11:21:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
08:12:48:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
08:12:54:WU03:FS01:0x18:Completed 900000 out of 2500000 steps (36%)
08:14:16:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
08:15:43:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
My log was too big so I have deleted some of the completed steps only.
The client has assigned 2 cores to support the GPU's, and according to task manager, they are both using 12.6% of the CPU, the other 6 cores are folding normally.
As far as I can recall I've only ever had the one passkey, I keep it saved on my pc and copy and paste it whenever I re-install the client, so I'm convinced the passkey is correct, it's definitely the same one that I was using before I added the 2nd 980. just as a point of interest, this morning I'm only getting 102400 PDD.
Thanks again for your help
Ian
clearview22
That CPU6 is killing you. You can click Finish on the CPU slot and when it is done, delete the CPU slot (in Config Slots). Watch how those 980s run. Bring up Task Manager and see how much each GPU uses of the CPU. You can then tune you system to your liking.
Core 18 currently runs slower than core 17 due to NV driver issues. The PPD will go back up when you get more of the other kind of work unit. No need to change CPU settings.clearview22 wrote:That CPU6 is killing you. You can click Finish on the CPU slot and when it is done, delete the CPU slot (in Config Slots). Watch how those 980s run. Bring up Task Manager and see how much each GPU uses of the CPU. You can then tune you system to your liking.
This is true.clearview22 wrote:That CPU6 is killing you. You can click Finish on the CPU slot and when it is done, delete the CPU slot (in Config Slots). Watch how those 980s run. Bring up Task Manager and see how much each GPU uses of the CPU. You can then tune you system to your liking.
GPU folding do not support HT (hyper trading). It means you have to use 2 cores and 2 treads to support 2 GPUs. If you must fold CPU then use no more than 4 CPU (2 HT and 2 Core).
And like 7im saying.. core 18 do not support Maxwell (or the other way arround.. driver issues Nvidia). So you are left with a significant drop inn PPD when folding Core 18 on Maxwell.
Only WU supporting Maxwell 100% is WU 9201 (Core 17).
You might want to do your own validation of what Sn1ken is suggesting. He might be right, but in my experience, hyperthreaded CPUs do a good job of polling the GPUs. I expect that whether you use 4 CPUs or 6 will change almost nothing. You have only 4 SSE/FPU units, so adding two more logical CPUs will have very little effect on the CPU slot.
Please do report your findings, either way.
Re: folding with 2 gtx 980's problem
Big thankyou to everyone for replies and suggestions. Just for curiosity sake and to eliminate this as a cause, I will delete the cpu slot and see what happens, I'll let you know the results.
Thanks again everyone
Ian
Ian
Unless something in the new 9xx Maxwell GPUs (and/or latest drivers) has changed significantly from all the previous Fermi and Kepler cards, 2 threads from an i7 were sufficient to drive 2 GPUs, and has been commonly reported that way in this forum.
If it has changed, we'd like to see those TPF differences posted as bruce suggested.
Hello.
Yes I can confirm that removing the cpu slot made absolutely no difference to the PPD of the GPU's, however I did loose points as I lost the PPD from the cpu slot.
So this has confirmed what Bruce and 7im thought that an i7 will drive 2 GPU's and fold itself without restricting the GPU's.
Looks like we've got to wait for Nvidia to sort out their drivers then?
Thanks again for everybody's help and suggestions
All the best for the New Year
Ian
Ian
