BUUT, I feel the client is not running very well. GPU usage is weird, it get's to ~98 then spikes down to 60-80 then spikes up again, and PPD on the 970 is about 50~60k, which I find odd, since I'm seeing other posts with much higher numbers. And the second card I'm running, a Radeon HD 6670 is just taking an entire week to finish 1 WU, even while running at 24/7. My frankenstein machine consists of an A6-3500 processor OC'd to 3.2 ghz, 16gb 1600mhz ram, A75M-D2H mobo, gtx 970 running at 1.4ghz, and Radeon HD 6670 stock on the 4x PCI-E lane.
So... are these readings normal? Is there anything I can do optimize folding? Also, as a side note, can I use the integrated graphics on the APU? Wasn't able to make that last one run.
(sry for the wall of text
