Project: 9012 (Run 326, Clone 0, Gen 33)
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Post by billford »
Client has been looping on this for the last couple of hours:
14:03:10:WU00:FS00:Starting
14:03:10:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1308 -checkpoint 15 -np 3
14:03:10:WU00:FS00:Started FahCore on PID 29451
14:03:10:WU00:FS00:Core PID:29455
14:03:10:WU00:FS00:FahCore 0xa4 started
14:03:11:WU00:FS00:0xa4:
14:03:11:WU00:FS00:0xa4:*------------------------------*
14:03:11:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:03:11:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:03:11:WU00:FS00:0xa4:Preparing to commence simulation
14:03:11:WU00:FS00:0xa4:- Ensuring status. Please wait.
14:03:20:WU00:FS00:0xa4:- Looking at optimizations...
14:03:20:WU00:FS00:0xa4:- Working with standard loops on this execution.
14:03:20:WU00:FS00:0xa4:- Previous termination of core was improper.
14:03:20:WU00:FS00:0xa4:- Files status OK
14:03:20:WU00:FS00:0xa4:- Expanded 912893 -> 1513440 (decompressed 165.7 percent)
14:03:20:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=912893 data_size=1513440, decompressed_data_size=1513440 diff=0
14:03:20:WU00:FS00:0xa4:- Digital signature verified
14:03:20:WU00:FS00:0xa4:Project: 9012 (Run 326, Clone 0, Gen 33)
14:03:20:WU00:FS00:0xa4:Entering M.D.
14:03:26:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
14:03:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
I dumped the WU (deleted/recreated the slot), now running OK.
sryckbos
Pande Group Member
Re: Project: 9012 (Run 326, Clone 0, Gen 33)
Post by sryckbos »
Definitely something funky going on with this WS right now. Trying to figure it out now.
Steven
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
I've got several other WUs from that server (different projects) currently running, they all seem to be OK.
I thought it was just a possible bad WU.
sryckbos
Pande Group Member
Post by sryckbos »
Hmm, I'll look more closely but at first glance you seem right, it looks like a bad WU. The oddness I'm seeing is unrelated. It's good that everything is running for you well though.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
I'll keep an eye on it for the rest of the evening, but the AS seems to be favouring a different server now.
