I am new to FAH... I think that my twin GTX 970s are having the usual Maxwell problems with failed WUs. Is there a way to get a list of my completed/failed WUs, without wading through all of the log files? There must be a way to do this, but I just cannot seem to find it.
Thanks,
David
List of WUs?
Re: List of WUs?
Hello dem0707, welcome to the folding forum.
Digging through the logs is the only way using the client to find this data. However, many people install third party applications to help with the tracking of work units. One example is called HFM. There are others.
Posting the fah log here would also help confirm what issues might be causing this.
Re: List of WUs?
Beside HFM as mentioned by 7im other apps can be found in the 3rd party forum, including a mobile app that list up your historical WU from the moment you use or import your older log files.
Last edited by ChristianVirtual on Thu Dec 11, 2014 11:28 pm, edited 2 times in total.
Re: List of WUs?
Thanks for the replies, I will look into that software.
Specs:
i7-4790K @ 4.50GHz 16GB RAM 8 CPU cores/threads
2x EVGA GTX-970 SC (factory OC, I have slowed them down by 500MHz)
Windows 7 Pro
1200 Watt PSU
Here is an edited version on the log file... I hope...
Thanks in advance,
David
Specs:
Windows 7 Pro
1200 Watt PSU
Thanks in advance,
David
*********************** Log Started 2014-12-10T12:25:27Z ***********************
12:25:27:************************* Folding@home Client *************************
12:25:27: Website: http://folding.stanford.edu/
12:25:27: Copyright: (c) 2009-2014 Stanford University
12:25:27: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:25:27: Args:
12:25:27: Config: C:/Users/David/AppData/Roaming/FAHClient/config.xml
12:25:27:******************************** Build ********************************
12:25:27: Version: 7.4.4
12:25:27: Date: Mar 4 2014
12:25:27: Time: 20:26:54
12:25:27: SVN Rev: 4130
12:25:27: Branch: fah/trunk/client
12:25:27: Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:25:27: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:25:27: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:25:27: Platform: win32 XP
12:25:27: Bits: 32
12:25:27: Mode: Release
12:25:27:******************************* System ********************************
12:25:27: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
12:25:27: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:25:27: CPUs: 8
12:25:27: Memory: 15.96GiB
12:25:27: Free Memory: 14.55GiB
12:25:27: Threads: WINDOWS_THREADS
12:25:27: OS Version: 6.1
12:25:27: Has Battery: false
12:25:27: On Battery: false
12:25:27: UTC Offset: -6
12:25:27: PID: 2676
12:25:27: CWD: C:/Users/David/AppData/Roaming/FAHClient
12:25:27: OS: Windows 7 Professional
12:25:27: OS Arch: AMD64
12:25:27: GPUs: 2
12:25:27: GPU 0: NVIDIA:4 GM204 [GeForce GTX 970]
12:25:27: GPU 1: NVIDIA:4 GM204 [GeForce GTX 970]
12:25:27: CUDA: 5.2
12:25:27: CUDA Driver: 6050
12:25:27:Win32 Service: false
12:25:27:***********************************************************************
12:25:27:<config>
12:25:27: <!-- Network -->
12:25:27: <proxy v=':8080'/>
12:25:27:
12:25:27: <!-- Slot Control -->
12:25:27: <pause-on-battery v='false'/>
12:25:27: <power v='full'/>
12:25:27:
12:25:27: <!-- User Information -->
12:25:27: <passkey v='********************************'/>
12:25:27: <team v='111065'/>
12:25:27: <user v='dem0707'/>
12:25:27:
12:25:27: <!-- Folding Slots -->
12:25:27: <slot id='0' type='CPU'/>
12:25:27: <slot id='1' type='GPU'/>
12:25:27: <slot id='2' type='GPU'/>
12:25:27:</config>
12:25:27:Trying to access database...
12:25:27:Successfully acquired database lock
12:25:27:Enabled folding slot 00: READY cpu:6
12:25:27:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970]
12:25:27:Enabled folding slot 02: READY gpu:1:GM204 [GeForce GTX 970]
. I think all is good for 6 hours.
18:58:13:WU02:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
18:58:42:WU01:FS00:0xa4:Completed 400000 out of 5000000 steps (8%)
19:00:15:WU01:FS00:0xa4:Completed 450000 out of 5000000 steps (9%)
19:00:39:WU03:FS02:0x15:Completed 39600000 out of 40000000 steps (99%).
19:00:40:WU00:FS02:Connecting to 171.67.108.200:80
19:00:41:WU00:FS02:Assigned to work server 171.67.108.52
19:00:41:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GM204 [GeForce GTX 970] from 171.67.108.52
19:00:41:WU00:FS02:Connecting to 171.67.108.52:8080
19:00:41:WU00:FS02:Downloading 1.52MiB
19:00:47:WU00:FS02:Download 100.00%
19:00:47:WU00:FS02:Download complete
19:00:47:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:221 clone:0 gen:265 core:0x17 unit:0x0000016f6652edc45399deb2178fe122
19:00:53:WU02:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
19:01:48:WU01:FS00:0xa4:Completed 500000 out of 5000000 steps (10%)
19:03:22:WU01:FS00:0xa4:Completed 550000 out of 5000000 steps (11%)
19:03:33:WU02:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
19:04:22:WU03:FS02:0x15:Completed 40000000 out of 40000000 steps (100%).
19:04:22:WU03:FS02:0x15:Finished fah_main status=0
19:04:22:WU03:FS02:0x15:Successful run
19:04:22:WU03:FS02:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
19:04:32:WU03:FS02:0x15:Reserved 759356 bytes for xtc file; Cosm status=0
19:04:32:WU03:FS02:0x15:Allocated 759356 bytes for xtc file
19:04:32:WU03:FS02:0x15:- Reading up to 759356 from "03/wudata_01.xtc": Read 759356
19:04:32:WU03:FS02:0x15:Read 759356 bytes from xtc file; available packet space=785671108
19:04:32:WU03:FS02:0x15:xtc file hash check passed.
19:04:32:WU03:FS02:0x15:Reserved 47688 47688 785671108 bytes for arc file=<03/wudata_01.trr> Cosm status=0
19:04:32:WU03:FS02:0x15:Allocated 47688 bytes for arc file
19:04:32:WU03:FS02:0x15:- Reading up to 47688 from "03/wudata_01.trr": Read 47688
19:04:32:WU03:FS02:0x15:Read 47688 bytes from arc file; available packet space=785623420
19:04:32:WU03:FS02:0x15:trr file hash check passed.
19:04:32:WU03:FS02:0x15:Allocated 544 bytes for edr file
19:04:32:WU03:FS02:0x15:Read bedfile
19:04:32:WU03:FS02:0x15:edr file hash check passed.
19:04:32:WU03:FS02:0x15:Allocated 36747 bytes for logfile
19:04:32:WU03:FS02:0x15:Read logfile
19:04:32:WU03:FS02:0x15:GuardedRun: success in DynamicWrapper
19:04:32:WU03:FS02:0x15:GuardedRun: done
19:04:32:WU03:FS02:0x15:Run: GuardedRun completed.
19:04:34:WU03:FS02:0x15:+ Opened results file
19:04:34:WU03:FS02:0x15:- Writing 844847 bytes of core data to disk...
19:04:35:WU03:FS02:0x15:Done: 844335 -> 816084 (compressed to 96.6 percent)
19:04:35:WU03:FS02:0x15: ... Done.
19:04:35:WU03:FS02:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
19:04:35:WU03:FS02:0x15:Shutting down core
19:04:35:WU03:FS02:0x15:Folding@home Core Shutdown: FINISHED_UNIT
19:04:35:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:04:35:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:7623 run:98 clone:0 gen:173 core:0x15 unit:0x000000f2664f2dd14fe4f907811837b8
19:04:35:WU03:FS02:Uploading 797.46KiB to 171.64.65.105
19:04:35:WU03:FS02:Connecting to 171.64.65.105:8080
19:04:35:WU00:FS02:Starting
19:04:35:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:04:35:WU00:FS02:Started FahCore on PID 2972
19:04:35:WU00:FS02:Core PID:4124
19:04:35:WU00:FS02:FahCore 0x17 started
19:04:35:WU00:FS02:0x17:*********************** Log Started 2014-12-10T19:04:35Z ***********************
19:04:35:WU00:FS02:0x17:Project: 9201 (Run 221, Clone 0, Gen 265)
19:04:35:WU00:FS02:0x17:Unit: 0x0000016f6652edc45399deb2178fe122
19:04:35:WU00:FS02:0x17:CPU: 0x00000000000000000000000000000000
19:04:35:WU00:FS02:0x17:Machine: 2
19:04:35:WU00:FS02:0x17:Reading tar file state.xml
19:04:35:WU00:FS02:0x17:Reading tar file system.xml
19:04:35:WU00:FS02:0x17:Reading tar file integrator.xml
19:04:35:WU00:FS02:0x17:Reading tar file core.xml
19:04:35:WU00:FS02:0x17:Digital signatures verified
19:04:35:WU00:FS02:0x17:Folding@home GPU core17
19:04:35:WU00:FS02:0x17:Version 0.0.52
19:04:35:WU00:FS02:0x17:ERROR:exception: Bad platformId size.
19:04:35:WU00:FS02:0x17:Saving result file logfile_01.txt
19:04:35:WU00:FS02:0x17:Saving result file log.txt
19:04:35:WU00:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
19:04:36:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:04:36:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:221 clone:0 gen:265 core:0x17 unit:0x0000016f6652edc45399deb2178fe122
19:04:36:WU00:FS02:Uploading 1.84KiB to 171.67.108.52
19:04:36:WU00:FS02:Connecting to 171.67.108.52:8080
19:04:36:WU04:FS02:Connecting to 171.67.108.200:80
19:04:37:WU04:FS02:Assigned to work server 140.163.4.234
19:04:37:WU04:FS02:Requesting new work unit for slot 02: READY gpu:1:GM204 [GeForce GTX 970] from 140.163.4.234
19:04:37:WU04:FS02:Connecting to 140.163.4.234:8080
19:04:37:WU00:FS02:Upload complete
19:04:37:WU00:FS02:Server responded WORK_ACK (400)
19:04:37:WU00:FS02:Cleaning up
19:04:38:WU04:FS02:Downloading 2.35MiB
19:04:41:WU03:FS02:Upload 32.10%
19:04:44:WU04:FS02:Download 45.18%
19:04:47:WU03:FS02:Upload 64.20%
19:04:49:WU04:FS02:Download complete
19:04:49:WU04:FS02:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:10475 run:0 clone:9 gen:56 core:0x18 unit:0x0000004c538b3dba53f37f0419b32a9b
19:04:49:WU04:FS02:Starting
19:04:49:WU04:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 04 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:04:49:WU04:FS02:Started FahCore on PID 4764
19:04:49:WU04:FS02:Core PID:4672
19:04:49:WU04:FS02:FahCore 0x18 started
19:04:50:WU04:FS02:0x18:*********************** Log Started 2014-12-10T19:04:49Z ***********************
19:04:50:WU04:FS02:0x18:Project: 10475 (Run 0, Clone 9, Gen 56)
19:04:50:WU04:FS02:0x18:Unit: 0x0000004c538b3dba53f37f0419b32a9b
19:04:50:WU04:FS02:0x18:CPU: 0x00000000000000000000000000000000
19:04:50:WU04:FS02:0x18:Machine: 2
19:04:50:WU04:FS02:0x18:Reading tar file state.xml
19:04:50:WU04:FS02:0x18:Reading tar file system.xml
19:04:50:WU04:FS02:0x18:Reading tar file integrator.xml
19:04:50:WU04:FS02:0x18:Reading tar file core.xml
19:04:50:WU04:FS02:0x18:Digital signatures verified
19:04:50:WU04:FS02:0x18:Folding@home GPU core18
19:04:50:WU04:FS02:0x18:Version 0.0.3
19:04:50:WU04:FS02:0x18:ERROR:exception: Bad platformId size.
19:04:50:WU04:FS02:0x18:Saving result file logfile_01.txt
19:04:50:WU04:FS02:0x18:Saving result file log.txt
19:04:50:WU04:FS02:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
19:04:50:WARNING:WU04:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:04:50:WU04:FS02:Sending unit results: id:04 state:SEND error:FAULTY project:10475 run:0 clone:9 gen:56 core:0x18 unit:0x0000004c538b3dba53f37f0419b32a9b
19:04:50:WU04:FS02:Uploading 1.83KiB to 140.163.4.234
19:04:50:WU04:FS02:Connecting to 140.163.4.234:8080
19:04:50:WU00:FS02:Connecting to 171.67.108.200:80
19:04:51:WU00:FS02:Assigned to work server 171.67.108.52
19:04:51:WU00:FS02:Requesting new work unit for slot 02: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.52
19:04:51:WU00:FS02:Connecting to 171.67.108.52:8080
19:04:52:WU04:FS02:Upload complete
19:04:52:WU04:FS02:Server responded WORK_ACK (400)
19:04:52:WU04:FS02:Cleaning up
19:04:52:WU00:FS02:Downloading 1.53MiB
19:04:53:WU03:FS02:Upload 100.00%
19:04:54:WU03:FS02:Upload complete
19:04:54:WU03:FS02:Server responded WORK_ACK (400)
19:04:54:WU03:FS02:Final credit estimate, 14093.00 points
19:04:54:WU03:FS02:Cleaning up
19:04:57:WU01:FS00:0xa4:Completed 600000 out of 5000000 steps (12%)
19:04:58:WU00:FS02:Download 85.99%
19:04:59:WU00:FS02:Download complete
19:04:59:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:175 clone:3 gen:74 core:0x17 unit:0x000000706652edc45399dce78d511b4b
19:04:59:WU00:FS02:Starting
19:04:59:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:04:59:WU00:FS02:Started FahCore on PID 3320
19:04:59:WU00:FS02:Core PID:2996
19:04:59:WU00:FS02:FahCore 0x17 started
19:05:00:WU00:FS02:0x17:*********************** Log Started 2014-12-10T19:04:59Z ***********************
19:05:00:WU00:FS02:0x17:Project: 9201 (Run 175, Clone 3, Gen 74)
19:05:00:WU00:FS02:0x17:Unit: 0x000000706652edc45399dce78d511b4b
19:05:00:WU00:FS02:0x17:CPU: 0x00000000000000000000000000000000
19:05:00:WU00:FS02:0x17:Machine: 2
19:05:00:WU00:FS02:0x17:Reading tar file state.xml
19:05:00:WU00:FS02:0x17:Reading tar file system.xml
19:05:00:WU00:FS02:0x17:Reading tar file integrator.xml
19:05:00:WU00:FS02:0x17:Reading tar file core.xml
19:05:00:WU00:FS02:0x17:Digital signatures verified
19:05:00:WU00:FS02:0x17:Folding@home GPU core17
19:05:00:WU00:FS02:0x17:Version 0.0.52
19:05:00:WU00:FS02:0x17:ERROR:exception: Bad platformId size.
19:05:00:WU00:FS02:0x17:Saving result file logfile_01.txt
19:05:00:WU00:FS02:0x17:Saving result file log.txt
19:05:00:WU00:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
19:05:00:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:05:00:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:175 clone:3 gen:74 core:0x17 unit:0x000000706652edc45399dce78d511b4b
19:05:00:WU00:FS02:Uploading 1.84KiB to 171.67.108.52
19:05:00:WU00:FS02:Connecting to 171.67.108.52:8080
19:05:00:WU03:FS02:Connecting to 171.67.108.200:80
19:05:00:WU00:FS02:Upload complete
19:05:00:WU00:FS02:Server responded WORK_ACK (400)
19:05:00:WU00:FS02:Cleaning up
19:05:01:WU03:FS02:Assigned to work server 171.64.65.105
19:05:01:WU03:FS02:Requesting new work unit for slot 02: READY gpu:1:GM204 [GeForce GTX 970] from 171.64.65.105
19:05:01:WU03:FS02:Connecting to 171.64.65.105:8080
19:05:02:WU03:FS02:Downloading 121.98KiB
19:05:02:WU03:FS02:Download complete
19:05:02:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:7621 run:67 clone:0 gen:387 core:0x15 unit:0x000001f6664f2dd14e4305936c918f6d
19:05:02:WU03:FS02:Starting
19:05:02:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:05:02:WU03:FS02:Started FahCore on PID 4100
19:05:03:WU03:FS02:Core PID:3752
19:05:03:WU03:FS02:FahCore 0x15 started
19:05:03:WU03:FS02:0x15:
19:05:03:WU03:FS02:0x15:*------------------------------*
19:05:03:WU03:FS02:0x15:Folding@Home GPU Core
19:05:03:WU03:FS02:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
19:05:03:WU03:FS02:0x15:Build host AmoebaRemote
19:05:03:WU03:FS02:0x15:Board Type NVIDIA/CUDA
19:05:03:WU03:FS02:0x15:Core 15
19:05:03:WU03:FS02:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
19:05:03:WU03:FS02:0x15:Window's signal control handler registered.
19:05:03:WU03:FS02:0x15:Preparing to commence simulation
19:05:03:WU03:FS02:0x15:- Looking at optimizations...
19:05:03:WU03:FS02:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
19:05:03:WU03:FS02:0x15:- Created dyn
19:05:03:WU03:FS02:0x15:- Files status OK
19:05:03:WU03:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
19:05:03:WU03:FS02:0x15:- Expanded 124394 -> 501826 (decompressed 403.4 percent)
19:05:03:WU03:FS02:0x15:Called DecompressByteArray: compressed_data_size=124394 data_size=501826, decompressed_data_size=501826 diff=0
19:05:03:WU03:FS02:0x15:- Digital signature verified
19:05:03:WU03:FS02:0x15:Project: 7621 (Run 67, Clone 0, Gen 387)
19:05:03:WU03:FS02:0x15:Assembly optimizations on if available.
19:05:03:WU03:FS02:0x15:Entering M.D.
19:05:05:WU03:FS02:0x15:Tpr hash 03/wudata_01.tpr: 4176466183 4022558577 1088954506 2662278704 3255515740
19:05:05:WU03:FS02:0x15:GPU device id=1
19:05:05:WU03:FS02:0x15:Working on Protein
19:05:05:WU03:FS02:0x15:Client config unavailable.
19:05:05:WU03:FS02:0x15:Finished fah_main status=59
19:05:05:WU03:FS02:0x15:mdrun_gpu returned 59
19:05:05:WU03:FS02:0x15:GPU memtest failure
19:05:05:WU03:FS02:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
19:05:05:WARNING:WU03:FS02:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
19:05:05:WU03:FS02:Starting
19:05:05:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:05:05:WU03:FS02:Started FahCore on PID 2144
19:05:05:WU03:FS02:Core PID:4436
19:05:05:WU03:FS02:FahCore 0x15 started
19:05:06:WU03:FS02:0x15:
. Repeats this section 3 more time almost exactly, different PID numbers...
19:08:06:WU03:FS02:0x15:*------------------------------*
19:08:06:WU03:FS02:0x15:Folding@Home GPU Core
19:08:06:WU03:FS02:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
19:08:06:WU03:FS02:0x15:Build host AmoebaRemote
19:08:06:WU03:FS02:0x15:Board Type NVIDIA/CUDA
19:08:06:WU03:FS02:0x15:Core 15
19:08:06:WU03:FS02:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
19:08:06:WU03:FS02:0x15:Window's signal control handler registered.
19:08:06:WU03:FS02:0x15:Preparing to commence simulation
19:08:06:WU03:FS02:0x15:- Looking at optimizations...
19:08:06:WU03:FS02:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
19:08:06:WU03:FS02:0x15:- Created dyn
19:08:06:WU03:FS02:0x15:- Files status OK
19:08:06:WU03:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
19:08:06:WU03:FS02:0x15:- Expanded 124394 -> 501826 (decompressed 403.4 percent)
19:08:06:WU03:FS02:0x15:Called DecompressByteArray: compressed_data_size=124394 data_size=501826, decompressed_data_size=501826 diff=0
19:08:06:WU03:FS02:0x15:- Digital signature verified
19:08:06:WU03:FS02:0x15:Project: 7621 (Run 67, Clone 0, Gen 387)
19:08:06:WU03:FS02:0x15:Assembly optimizations on if available.
19:08:06:WU03:FS02:0x15:Entering M.D.
19:08:08:WU03:FS02:0x15:Tpr hash 03/wudata_01.tpr: 4176466183 4022558577 1088954506 2662278704 3255515740
19:08:08:WU03:FS02:0x15:GPU device id=1
19:08:08:WU03:FS02:0x15:Working on Protein
19:08:08:WU03:FS02:0x15:Client config unavailable.
19:08:08:WU03:FS02:0x15:Finished fah_main status=59
19:08:08:WU03:FS02:0x15:mdrun_gpu returned 59
19:08:08:WU03:FS02:0x15:GPU memtest failure
19:08:08:WU03:FS02:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
19:08:08:WU01:FS00:0xa4:Completed 700000 out of 5000000 steps (14%)
19:08:08:WARNING:WU03:FS02:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
19:08:08:WARNING:WU03:FS02:Too many errors, failing
19:08:08:WU03:FS02:Sending unit results: id:03 state:SEND error:FAILED project:7621 run:67 clone:0 gen:387 core:0x15 unit:0x000001f6664f2dd14e4305936c918f6d
19:08:08:WU03:FS02:Connecting to 171.64.65.105:8080
19:08:09:WU00:FS02:Connecting to 171.67.108.200:80
19:08:09:WU03:FS02:Server responded WORK_QUIT (404)
19:08:09:WARNING:WU03:FS02:Server did not like results, dumping
19:08:09:WU03:FS02:Cleaning up
19:08:09:WU00:FS02:Assigned to work server 171.67.108.52
19:08:09:WU00:FS02:Requesting new work unit for slot 02: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.52
19:08:09:WU00:FS02:Connecting to 171.67.108.52:8080
19:08:10:WU00:FS02:Downloading 1.52MiB
19:08:15:WU00:FS02:Download complete
19:08:16:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:860 clone:3 gen:72 core:0x17 unit:0x000000666652edc45399f7dcfc135e1a
19:08:16:WU00:FS02:Starting
19:08:16:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:08:16:WU00:FS02:Started FahCore on PID 4316
19:08:16:WU00:FS02:Core PID:2600
19:08:16:WU00:FS02:FahCore 0x17 started
19:08:16:WU00:FS02:0x17:*********************** Log Started 2014-12-10T19:08:16Z ***********************
19:08:16:WU00:FS02:0x17:Project: 9201 (Run 860, Clone 3, Gen 72)
19:08:16:WU00:FS02:0x17:Unit: 0x000000666652edc45399f7dcfc135e1a
19:08:16:WU00:FS02:0x17:CPU: 0x00000000000000000000000000000000
19:08:16:WU00:FS02:0x17:Machine: 2
19:08:16:WU00:FS02:0x17:Reading tar file state.xml
19:08:16:WU00:FS02:0x17:Reading tar file system.xml
19:08:16:WU00:FS02:0x17:Reading tar file integrator.xml
19:08:16:WU00:FS02:0x17:Reading tar file core.xml
19:08:16:WU00:FS02:0x17:Digital signatures verified
19:08:16:WU00:FS02:0x17:Folding@home GPU core17
19:08:16:WU00:FS02:0x17:Version 0.0.52
19:08:16:WU00:FS02:0x17:ERROR:exception: Bad platformId size.
19:08:16:WU00:FS02:0x17:Saving result file logfile_01.txt
19:08:16:WU00:FS02:0x17:Saving result file log.txt
19:08:16:WU00:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
19:08:16:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:08:16:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:860 clone:3 gen:72 core:0x17 unit:0x000000666652edc45399f7dcfc135e1a
19:08:16:WU00:FS02:Uploading 1.82KiB to 171.67.108.52
19:08:16:WU00:FS02:Connecting to 171.67.108.52:8080
19:08:17:WU03:FS02:Connecting to 171.67.108.200:80
19:08:17:WU00:FS02:Upload complete
19:08:17:WU00:FS02:Server responded WORK_ACK (400)
19:08:17:WU00:FS02:Cleaning up
19:08:17:WU03:FS02:Assigned to work server 171.67.108.52
19:08:17:WU03:FS02:Requesting new work unit for slot 02: READY gpu:1:GM204 [GeForce GTX 970] from 171.67.108.52
19:08:17:WU03:FS02:Connecting to 171.67.108.52:8080
19:08:18:WU03:FS02:Downloading 1.52MiB
19:08:23:WU03:FS02:Download complete
19:08:23:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9201 run:412 clone:3 gen:70 core:0x17 unit:0x0000005e6652edc45399e6416514044a
19:08:23:WU03:FS02:Starting
19:08:23:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
19:08:23:WU03:FS02:Started FahCore on PID 3728
19:08:23:WU03:FS02:Core PID:4656
19:08:23:WU03:FS02:FahCore 0x17 started
. Repeats this section with same errors Bad platformId size and BAD_WORK_UNIT, with different PRCG...
19:08:24:WU03:FS02:0x17:*********************** Log Started 2014-12-10T19:08:23Z ***********************
19:08:24:WU03:FS02:0x17:Project: 9201 (Run 412, Clone 3, Gen 70)
19:08:31:WU00:FS02:0x17:*********************** Log Started 2014-12-10T19:08:31Z ***********************
19:08:31:WU00:FS02:0x17:Project: 9201 (Run 484, Clone 2, Gen 68)
19:08:39:WU03:FS02:0x17:*********************** Log Started 2014-12-10T19:08:38Z ***********************
19:08:39:WU03:FS02:0x17:Project: 9201 (Run 520, Clone 3, Gen 64)
19:08:46:WU00:FS02:0x17:*********************** Log Started 2014-12-10T19:08:46Z ***********************
19:08:46:WU00:FS02:0x17:Project: 9201 (Run 308, Clone 4, Gen 64)
19:08:54:WU03:FS02:0x17:*********************** Log Started 2014-12-10T19:08:54Z ***********************
19:08:54:WU03:FS02:0x17:Project: 9201 (Run 447, Clone 2, Gen 63)
19:08:54:WU03:FS02:0x17:Unit: 0x000000616652edc45399e79eccbe6660
19:08:54:WU03:FS02:0x17:CPU: 0x00000000000000000000000000000000
19:08:54:WU03:FS02:0x17:Machine: 2
19:08:54:WU03:FS02:0x17:Reading tar file state.xml
19:08:54:WU03:FS02:0x17:Reading tar file system.xml
19:08:54:WU03:FS02:0x17:Reading tar file integrator.xml
19:08:54:WU03:FS02:0x17:Reading tar file core.xml
19:08:54:WU03:FS02:0x17:Digital signatures verified
19:08:54:WU03:FS02:0x17:Folding@home GPU core17
19:08:54:WU03:FS02:0x17:Version 0.0.52
19:08:54:WU03:FS02:0x17:ERROR:exception: Bad platformId size.
19:08:54:WU03:FS02:0x17:Saving result file logfile_01.txt
19:08:54:WU03:FS02:0x17:Saving result file log.txt
19:08:54:WU03:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
19:08:54:WARNING:WU03:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:08:54:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:9201 run:447 clone:2 gen:63 core:0x17 unit:0x000000616652edc45399e79eccbe6660
19:08:54:WU03:FS02:Uploading 1.82KiB to 171.67.108.52
19:08:54:WU03:FS02:Connecting to 171.67.108.52:8080
19:08:55:WU03:FS02:Upload complete
19:08:55:WU03:FS02:Server responded WORK_ACK (400)
19:08:55:WU03:FS02:Cleaning up
19:09:44:WU01:FS00:0xa4:Completed 750000 out of 5000000 steps (15%)
19:11:19:WU01:FS00:0xa4:Completed 800000 out of 5000000 steps (16%)
19:11:32:WU02:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
. I guess no more Slot 2...
21:40:31:WU02:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
21:41:20:WU00:FS00:0xa4:Completed 500000 out of 5000000 steps (10%)
21:42:56:WU00:FS00:0xa4:Completed 550000 out of 5000000 steps (11%)
21:43:10:WU02:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
21:43:11:WU01:FS01:Connecting to 171.67.108.200:80
21:43:12:WU01:FS01:Assigned to work server 140.163.4.235
21:43:12:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 140.163.4.235
21:43:12:WU01:FS01:Connecting to 140.163.4.235:8080
21:43:13:WU01:FS01:Downloading 4.24MiB
21:43:19:WU01:FS01:Download 28.01%
21:43:25:WU01:FS01:Download 57.50%
21:43:31:WU01:FS01:Download 100.00%
21:43:31:WU01:FS01:Download complete
21:43:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10472 run:0 clone:29 gen:44 core:0x18 unit:0x00000042538b3dbb53beb3fffad30e72
21:44:32:WU00:FS00:0xa4:Completed 600000 out of 5000000 steps (12%)
21:45:50:WU02:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
21:45:53:WU02:FS01:0x17:Saving result file logfile_01.txt
21:45:53:WU02:FS01:0x17:Saving result file checkpointState.xml
21:45:53:WU02:FS01:0x17:Saving result file checkpt.crc
21:45:53:WU02:FS01:0x17:Saving result file log.txt
21:45:53:WU02:FS01:0x17:Saving result file positions.xtc
21:45:55:WU02:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
21:45:55:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:45:55:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9201 run:627 clone:4 gen:78 core:0x17 unit:0x000000736652edc45399eeb3d2a6402d
21:45:55:WU02:FS01:Uploading 8.38MiB to 171.67.108.52
21:45:55:WU01:FS01:Starting
21:45:55:WU02:FS01:Connecting to 171.67.108.52:8080
21:45:55:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:45:55:WU01:FS01:Started FahCore on PID 4952
21:45:55:WU01:FS01:Core PID:3764
21:45:55:WU01:FS01:FahCore 0x18 started
21:45:56:WU01:FS01:0x18:*********************** Log Started 2014-12-10T21:45:55Z ***********************
21:45:56:WU01:FS01:0x18:Project: 10472 (Run 0, Clone 29, Gen 44)
21:45:56:WU01:FS01:0x18:Unit: 0x00000042538b3dbb53beb3fffad30e72
21:45:56:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:45:56:WU01:FS01:0x18:Machine: 1
21:45:56:WU01:FS01:0x18:Reading tar file state.xml
21:45:56:WU01:FS01:0x18:Reading tar file system.xml
21:45:56:WU01:FS01:0x18:Reading tar file integrator.xml
21:45:56:WU01:FS01:0x18:Reading tar file core.xml
21:45:56:WU01:FS01:0x18:Digital signatures verified
21:45:56:WU01:FS01:0x18:Folding@home GPU core18
21:45:56:WU01:FS01:0x18:Version 0.0.3
21:45:56:WU01:FS01:0x18:ERROR:exception: Bad platformId size.
21:45:56:WU01:FS01:0x18:Saving result file logfile_01.txt
21:45:56:WU01:FS01:0x18:Saving result file log.txt
21:45:56:WU01:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:45:57:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:45:57:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:10472 run:0 clone:29 gen:44 core:0x18 unit:0x00000042538b3dbb53beb3fffad30e72
21:45:57:WU01:FS01:Uploading 1.83KiB to 140.163.4.235
21:45:57:WU01:FS01:Connecting to 140.163.4.235:8080
21:45:57:WU03:FS01:Connecting to 171.67.108.200:80
21:45:59:WU03:FS01:Assigned to work server 140.163.4.235
21:45:59:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 140.163.4.235
21:45:59:WU03:FS01:Connecting to 140.163.4.235:8080
21:46:00:WU01:FS01:Upload complete
21:46:00:WU03:FS01:Downloading 4.24MiB
21:46:00:WU01:FS01:Server responded WORK_ACK (400)
21:46:00:WU01:FS01:Cleaning up
21:46:03:WU02:FS01:Upload 1.49%
21:46:06:WU03:FS01:Download 14.75%
21:46:08:WU00:FS00:0xa4:Completed 650000 out of 5000000 steps (13%)
21:46:11:WU02:FS01:Upload 3.73%
21:46:12:WU03:FS01:Download 28.02%
21:46:17:WU02:FS01:Upload 5.22%
21:46:18:WU03:FS01:Download 42.77%
21:46:23:WU02:FS01:Upload 7.46%
21:46:24:WU03:FS01:Download 67.84%
21:46:30:WU03:FS01:Download 88.48%
21:46:30:WU02:FS01:Upload 9.70%
21:46:33:WU03:FS01:Download complete
21:46:33:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:10472 run:0 clone:376 gen:35 core:0x18 unit:0x00000033538b3dbb53bebc5df317eedd
21:46:33:WU03:FS01:Starting
21:46:33:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 03 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:46:33:WU03:FS01:Started FahCore on PID 1736
21:46:33:WU03:FS01:Core PID:1876
21:46:33:WU03:FS01:FahCore 0x18 started
21:46:33:WU03:FS01:0x18:*********************** Log Started 2014-12-10T21:46:33Z ***********************
21:46:33:WU03:FS01:0x18:Project: 10472 (Run 0, Clone 376, Gen 35)
21:46:33:WU03:FS01:0x18:Unit: 0x00000033538b3dbb53bebc5df317eedd
21:46:33:WU03:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:46:33:WU03:FS01:0x18:Machine: 1
21:46:33:WU03:FS01:0x18:Reading tar file state.xml
21:46:34:WU03:FS01:0x18:Reading tar file system.xml
21:46:34:WU03:FS01:0x18:Reading tar file integrator.xml
21:46:34:WU03:FS01:0x18:Reading tar file core.xml
21:46:34:WU03:FS01:0x18:Digital signatures verified
21:46:34:WU03:FS01:0x18:Folding@home GPU core18
21:46:34:WU03:FS01:0x18:Version 0.0.3
21:46:34:WU03:FS01:0x18:ERROR:exception: Bad platformId size.
21:46:34:WU03:FS01:0x18:Saving result file logfile_01.txt
21:46:34:WU03:FS01:0x18:Saving result file log.txt
21:46:34:WU03:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:46:35:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:46:35:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:10472 run:0 clone:376 gen:35 core:0x18 unit:0x00000033538b3dbb53bebc5df317eedd
21:46:35:WU03:FS01:Uploading 1.83KiB to 140.163.4.235
21:46:35:WU03:FS01:Connecting to 140.163.4.235:8080
21:46:35:WU01:FS01:Connecting to 171.67.108.200:80
21:46:36:WU03:FS01:Upload complete
21:46:36:WU03:FS01:Server responded WORK_ACK (400)
21:46:36:WU03:FS01:Cleaning up
21:46:36:WU02:FS01:Upload 11.93%
21:46:36:WU01:FS01:Assigned to work server 171.67.108.52
21:46:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
21:46:36:WU01:FS01:Connecting to 171.67.108.52:8080
21:46:38:WU01:FS01:Downloading 1.52MiB
21:46:42:WU02:FS01:Upload 14.17%
21:46:44:WU01:FS01:Download 24.64%
21:46:50:WU02:FS01:Upload 15.66%
21:46:50:WU01:FS01:Download 65.71%
21:46:56:WU02:FS01:Upload 17.16%
21:46:58:WU01:FS01:Download 98.56%
21:46:59:WU01:FS01:Download complete
21:46:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:617 clone:2 gen:74 core:0x17 unit:0x0000006e6652edc45399ee4afb452d40
21:46:59:WU01:FS01:Starting
21:46:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:46:59:WU01:FS01:Started FahCore on PID 4216
21:46:59:WU01:FS01:Core PID:2372
21:46:59:WU01:FS01:FahCore 0x17 started
21:46:59:WU01:FS01:0x17:*********************** Log Started 2014-12-10T21:46:59Z ***********************
21:46:59:WU01:FS01:0x17:Project: 9201 (Run 617, Clone 2, Gen 74)
21:46:59:WU01:FS01:0x17:Unit: 0x0000006e6652edc45399ee4afb452d40
21:46:59:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:46:59:WU01:FS01:0x17:Machine: 1
21:46:59:WU01:FS01:0x17:Reading tar file state.xml
21:46:59:WU01:FS01:0x17:Reading tar file system.xml
21:46:59:WU01:FS01:0x17:Reading tar file integrator.xml
21:46:59:WU01:FS01:0x17:Reading tar file core.xml
21:46:59:WU01:FS01:0x17:Digital signatures verified
21:46:59:WU01:FS01:0x17:Folding@home GPU core17
21:46:59:WU01:FS01:0x17:Version 0.0.52
21:46:59:WU01:FS01:0x17:ERROR:exception: Bad platformId size.
21:46:59:WU01:FS01:0x17:Saving result file logfile_01.txt
21:46:59:WU01:FS01:0x17:Saving result file log.txt
21:46:59:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
21:46:59:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:46:59:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9201 run:617 clone:2 gen:74 core:0x17 unit:0x0000006e6652edc45399ee4afb452d40
21:46:59:WU01:FS01:Uploading 1.81KiB to 171.67.108.52
21:46:59:WU01:FS01:Connecting to 171.67.108.52:8080
21:47:00:WU03:FS01:Connecting to 171.67.108.200:80
21:47:00:WU01:FS01:Upload complete
21:47:01:WU01:FS01:Server responded WORK_ACK (400)
21:47:01:WU01:FS01:Cleaning up
21:47:01:WU03:FS01:Assigned to work server 171.67.108.52
21:47:01:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
21:47:01:WU03:FS01:Connecting to 171.67.108.52:8080
21:47:03:WU02:FS01:Upload 19.39%
21:47:03:WU03:FS01:Downloading 1.52MiB
21:47:09:WU03:FS01:Download 32.82%
21:47:11:WU02:FS01:Upload 21.63%
21:47:15:WU03:FS01:Download 73.85%
21:47:17:WU02:FS01:Upload 23.12%
21:47:19:WU03:FS01:Download complete
21:47:20:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9201 run:627 clone:2 gen:69 core:0x17 unit:0x000000756652edc45399eeaf948bf079
21:47:20:WU03:FS01:Starting
21:47:20:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:47:20:WU03:FS01:Started FahCore on PID 3196
21:47:20:WU03:FS01:Core PID:4732
21:47:20:WU03:FS01:FahCore 0x17 started
21:47:20:WU03:FS01:0x17:*********************** Log Started 2014-12-10T21:47:20Z ***********************
21:47:20:WU03:FS01:0x17:Project: 9201 (Run 627, Clone 2, Gen 69)
21:47:20:WU03:FS01:0x17:Unit: 0x000000756652edc45399eeaf948bf079
21:47:20:WU03:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:47:20:WU03:FS01:0x17:Machine: 1
21:47:20:WU03:FS01:0x17:Reading tar file state.xml
21:47:20:WU03:FS01:0x17:Reading tar file system.xml
21:47:20:WU03:FS01:0x17:Reading tar file integrator.xml
21:47:20:WU03:FS01:0x17:Reading tar file core.xml
21:47:20:WU03:FS01:0x17:Digital signatures verified
21:47:20:WU03:FS01:0x17:Folding@home GPU core17
21:47:20:WU03:FS01:0x17:Version 0.0.52
21:47:20:WU03:FS01:0x17:ERROR:exception: Bad platformId size.
21:47:20:WU03:FS01:0x17:Saving result file logfile_01.txt
21:47:20:WU03:FS01:0x17:Saving result file log.txt
21:47:20:WU03:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
21:47:20:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:47:20:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:9201 run:627 clone:2 gen:69 core:0x17 unit:0x000000756652edc45399eeaf948bf079
21:47:20:WU03:FS01:Uploading 1.82KiB to 171.67.108.52
21:47:20:WU03:FS01:Connecting to 171.67.108.52:8080
21:47:21:WU01:FS01:Connecting to 171.67.108.200:80
21:47:21:WU03:FS01:Upload complete
21:47:21:WU03:FS01:Server responded WORK_ACK (400)
21:47:21:WU03:FS01:Cleaning up
21:47:23:WU01:FS01:Assigned to work server 171.64.65.105
21:47:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.105
21:47:23:WU01:FS01:Connecting to 171.64.65.105:8080
21:47:25:WU01:FS01:Downloading 124.28KiB
21:47:25:WU02:FS01:Upload 25.36%
21:47:27:WU01:FS01:Download complete
21:47:27:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7624 run:281 clone:0 gen:378 core:0x15 unit:0x000001ff664f2dd14fe61225dd0e4b72
21:47:27:WU01:FS01:Starting
21:47:27:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:47:27:WU01:FS01:Started FahCore on PID 3380
21:47:27:WU01:FS01:Core PID:4904
21:47:27:WU01:FS01:FahCore 0x15 started
21:47:28:WU01:FS01:0x15:
21:47:28:WU01:FS01:0x15:*------------------------------*
21:47:28:WU01:FS01:0x15:Folding@Home GPU Core
21:47:28:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
21:47:28:WU01:FS01:0x15:Build host AmoebaRemote
21:47:28:WU01:FS01:0x15:Board Type NVIDIA/CUDA
21:47:28:WU01:FS01:0x15:Core 15
21:47:28:WU01:FS01:0x15:Window's signal control handler registered.
21:47:28:WU01:FS01:0x15:Preparing to commence simulation
21:47:28:WU01:FS01:0x15:- Looking at optimizations...
21:47:28:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:47:28:WU01:FS01:0x15:- Created dyn
21:47:28:WU01:FS01:0x15:- Files status OK
21:47:28:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
21:47:28:WU01:FS01:0x15:- Expanded 126755 -> 507182 (decompressed 400.1 percent)
21:47:28:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=126755 data_size=507182, decompressed_data_size=507182 diff=0
21:47:28:WU01:FS01:0x15:- Digital signature verified
21:47:28:WU01:FS01:0x15:Project: 7624 (Run 281, Clone 0, Gen 378)
21:47:28:WU01:FS01:0x15:Assembly optimizations on if available.
21:47:28:WU01:FS01:0x15:Entering M.D.
21:47:29:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 2373388638 1388645366 2022705849 743477412 1999788321
21:47:29:WU01:FS01:0x15:GPU device id=0
21:47:29:WU01:FS01:0x15:Working on Protein
21:47:29:WU01:FS01:0x15:Client config unavailable.
21:47:29:WU01:FS01:0x15:Finished fah_main status=59
21:47:29:WU01:FS01:0x15:mdrun_gpu returned 59
21:47:29:WU01:FS01:0x15:GPU memtest failure
21:47:29:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
21:47:30:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
21:47:30:WU01:FS01:Starting
21:47:30:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:47:30:WU01:FS01:Started FahCore on PID 5060
21:47:30:WU01:FS01:Core PID:3840
21:47:30:WU01:FS01:FahCore 0x15 started
21:47:31:WU01:FS01:0x15:
21:47:31:WU01:FS01:0x15:*------------------------------*
21:47:31:WU01:FS01:0x15:Folding@Home GPU Core
21:47:31:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
21:47:31:WU01:FS01:0x15:Build host AmoebaRemote
21:47:31:WU01:FS01:0x15:Board Type NVIDIA/CUDA
21:47:31:WU01:FS01:0x15:Core 15
21:47:31:WU01:FS01:0x15:Window's signal control handler registered.
21:47:31:WU01:FS01:0x15:Preparing to commence simulation
21:47:31:WU01:FS01:0x15:- Looking at optimizations...
21:47:31:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:47:31:WU01:FS01:0x15:- Created dyn
21:47:31:WU01:FS01:0x15:- Files status OK
21:47:31:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
21:47:31:WU01:FS01:0x15:- Expanded 126755 -> 507182 (decompressed 400.1 percent)
21:47:31:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=126755 data_size=507182, decompressed_data_size=507182 diff=0
21:47:31:WU01:FS01:0x15:- Digital signature verified
21:47:31:WU01:FS01:0x15:Project: 7624 (Run 281, Clone 0, Gen 378)
21:47:31:WU01:FS01:0x15:Assembly optimizations on if available.
21:47:31:WU01:FS01:0x15:Entering M.D.
21:47:31:WU02:FS01:Upload 26.85%
21:47:32:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 2373388638 1388645366 2022705849 743477412 1999788321
21:47:32:WU01:FS01:0x15:GPU device id=0
21:47:33:WU01:FS01:0x15:Working on Protein
21:47:33:WU01:FS01:0x15:Client config unavailable.
21:47:33:WU01:FS01:0x15:Finished fah_main status=59
21:47:33:WU01:FS01:0x15:mdrun_gpu returned 59
21:47:33:WU01:FS01:0x15:GPU memtest failure
21:47:33:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
21:47:33:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
21:47:37:WU02:FS01:Upload 29.83%
21:47:43:WU02:FS01:Upload 32.07%
21:47:43:WU00:FS00:0xa4:Completed 700000 out of 5000000 steps (14%)
21:47:50:WU02:FS01:Upload 34.31%
21:47:56:WU02:FS01:Upload 35.80%
21:48:02:WU02:FS01:Upload 38.04%
21:48:09:WU02:FS01:Upload 40.28%
21:48:17:WU02:FS01:Upload 42.51%
21:48:25:WU02:FS01:Upload 45.50%
21:48:30:WU01:FS01:Starting
21:48:30:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:48:30:WU01:FS01:Started FahCore on PID 2164
21:48:30:WU01:FS01:Core PID:5012
21:48:30:WU01:FS01:FahCore 0x15 started
21:48:31:WU01:FS01:0x15:
21:48:31:WU01:FS01:0x15:*------------------------------*
21:48:31:WU01:FS01:0x15:Folding@Home GPU Core
21:48:31:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
21:48:31:WU01:FS01:0x15:Build host AmoebaRemote
21:48:31:WU01:FS01:0x15:Board Type NVIDIA/CUDA
21:48:31:WU01:FS01:0x15:Core 15
21:48:31:WU01:FS01:0x15:Window's signal control handler registered.
21:48:31:WU01:FS01:0x15:Preparing to commence simulation
21:48:31:WU01:FS01:0x15:- Looking at optimizations...
21:48:31:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:48:31:WU01:FS01:0x15:- Created dyn
21:48:31:WU01:FS01:0x15:- Files status OK
21:48:31:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
21:48:31:WU01:FS01:0x15:- Expanded 126755 -> 507182 (decompressed 400.1 percent)
21:48:31:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=126755 data_size=507182, decompressed_data_size=507182 diff=0
21:48:31:WU01:FS01:0x15:- Digital signature verified
21:48:31:WU01:FS01:0x15:Project: 7624 (Run 281, Clone 0, Gen 378)
21:48:31:WU01:FS01:0x15:Assembly optimizations on if available.
21:48:31:WU01:FS01:0x15:Entering M.D.
21:48:32:WU02:FS01:Upload 47.74%
21:48:32:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 2373388638 1388645366 2022705849 743477412 1999788321
21:48:32:WU01:FS01:0x15:GPU device id=0
21:48:33:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
21:48:39:WU02:FS01:Upload 49.97%
21:48:46:WU02:FS01:Upload 52.21%
21:48:52:WU02:FS01:Upload 54.45%
21:48:59:WU02:FS01:Upload 56.69%
21:49:06:WU02:FS01:Upload 58.92%
21:49:12:WU02:FS01:Upload 61.16%
21:49:18:WU02:FS01:Upload 63.40%
21:49:19:WU00:FS00:0xa4:Completed 750000 out of 5000000 steps (15%)
21:49:25:WU02:FS01:Upload 65.64%
21:49:31:WU01:FS01:Starting
21:49:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:49:31:WU01:FS01:Started FahCore on PID 2960
21:49:31:WU01:FS01:Core PID:5088
21:49:31:WU01:FS01:FahCore 0x15 started
21:49:31:WU01:FS01:0x15:
21:49:31:WU01:FS01:0x15:*------------------------------*
21:49:31:WU01:FS01:0x15:Folding@Home GPU Core
21:49:31:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
21:49:31:WU01:FS01:0x15:Build host AmoebaRemote
21:49:31:WU01:FS01:0x15:Board Type NVIDIA/CUDA
21:49:31:WU01:FS01:0x15:Core 15
21:49:31:WU01:FS01:0x15:Window's signal control handler registered.
21:49:31:WU01:FS01:0x15:Preparing to commence simulation
21:49:31:WU01:FS01:0x15:- Looking at optimizations...
21:49:31:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:49:31:WU01:FS01:0x15:- Created dyn
21:49:31:WU01:FS01:0x15:- Files status OK
21:49:31:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
21:49:31:WU01:FS01:0x15:- Expanded 126755 -> 507182 (decompressed 400.1 percent)
21:49:31:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=126755 data_size=507182, decompressed_data_size=507182 diff=0
21:49:31:WU01:FS01:0x15:- Digital signature verified
21:49:31:WU01:FS01:0x15:Project: 7624 (Run 281, Clone 0, Gen 378)
21:49:31:WU01:FS01:0x15:Assembly optimizations on if available.
21:49:31:WU01:FS01:0x15:Entering M.D.
21:49:32:WU02:FS01:Upload 67.13%
21:49:33:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 2373388638 1388645366 2022705849 743477412 1999788321
21:49:33:WU01:FS01:0x15:GPU device id=0
21:49:33:WU01:FS01:0x15:Working on Protein
21:49:33:WU01:FS01:0x15:Client config unavailable.
21:49:33:WU01:FS01:0x15:Finished fah_main status=59
21:49:33:WU01:FS01:0x15:mdrun_gpu returned 59
21:49:33:WU01:FS01:0x15:GPU memtest failure
21:49:33:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
21:49:33:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
21:49:39:WU02:FS01:Upload 69.37%
21:49:45:WU02:FS01:Upload 72.35%
21:49:51:WU02:FS01:Upload 75.33%
21:49:58:WU02:FS01:Upload 77.57%
21:50:05:WU02:FS01:Upload 79.81%
21:50:11:WU02:FS01:Upload 81.30%
21:50:18:WU02:FS01:Upload 83.54%
21:50:25:WU02:FS01:Upload 85.03%
21:50:31:WU01:FS01:Starting
21:50:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:50:31:WU02:FS01:Upload 86.52%
21:50:31:WU01:FS01:Started FahCore on PID 4356
21:50:31:WU01:FS01:Core PID:3008
21:50:31:WU01:FS01:FahCore 0x15 started
21:50:31:WU01:FS01:0x15:
21:50:31:WU01:FS01:0x15:*------------------------------*
21:50:31:WU01:FS01:0x15:Folding@Home GPU Core
21:50:31:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
21:50:31:WU01:FS01:0x15:Build host AmoebaRemote
21:50:31:WU01:FS01:0x15:Board Type NVIDIA/CUDA
21:50:31:WU01:FS01:0x15:Core 15
21:50:31:WU01:FS01:0x15:Window's signal control handler registered.
21:50:31:WU01:FS01:0x15:Preparing to commence simulation
21:50:31:WU01:FS01:0x15:- Looking at optimizations...
21:50:31:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:50:31:WU01:FS01:0x15:- Created dyn
21:50:31:WU01:FS01:0x15:- Files status OK
21:50:31:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
21:50:31:WU01:FS01:0x15:- Expanded 126755 -> 507182 (decompressed 400.1 percent)
21:50:31:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=126755 data_size=507182, decompressed_data_size=507182 diff=0
21:50:31:WU01:FS01:0x15:- Digital signature verified
21:50:31:WU01:FS01:0x15:Project: 7624 (Run 281, Clone 0, Gen 378)
21:50:31:WU01:FS01:0x15:Assembly optimizations on if available.
21:50:31:WU01:FS01:0x15:Entering M.D.
21:50:33:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 2373388638 1388645366 2022705849 743477412 1999788321
21:50:33:WU01:FS01:0x15:GPU device id=0
21:50:33:WU01:FS01:0x15:Working on Protein
21:50:33:WU01:FS01:0x15:Client config unavailable.
21:50:33:WU01:FS01:0x15:Finished fah_main status=59
21:50:33:WU01:FS01:0x15:mdrun_gpu returned 59
21:50:33:WU01:FS01:0x15:GPU memtest failure
21:50:33:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
21:50:33:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
21:50:33:WARNING:WU01:FS01:Too many errors, failing
21:50:33:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:7624 run:281 clone:0 gen:378 core:0x15 unit:0x000001ff664f2dd14fe61225dd0e4b72
21:50:33:WU01:FS01:Connecting to 171.64.65.105:8080
21:50:34:WU03:FS01:Connecting to 171.67.108.200:80
21:50:35:WU03:FS01:Assigned to work server 171.67.108.52
21:50:35:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
21:50:35:WU03:FS01:Connecting to 171.67.108.52:8080
21:50:37:WU03:FS01:Downloading 1.52MiB
21:50:38:WU02:FS01:Upload 88.76%
21:50:43:WU03:FS01:Download 24.59%
21:50:44:WU02:FS01:Upload 90.25%
21:50:46:WU01:FS01:Server responded WORK_QUIT (404)
21:50:46:WARNING:WU01:FS01:Server did not like results, dumping
21:50:46:WU01:FS01:Cleaning up
21:50:49:WU03:FS01:Download 69.67%
21:50:50:WU02:FS01:Upload 91.74%
21:50:54:WU03:FS01:Download complete
21:50:54:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9201 run:433 clone:2 gen:49 core:0x17 unit:0x0000005b6652edc45399e712eecca091
21:50:54:WU03:FS01:Starting
21:50:54:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:50:54:WU03:FS01:Started FahCore on PID 4100
21:50:54:WU03:FS01:Core PID:5036
21:50:54:WU03:FS01:FahCore 0x17 started
21:50:55:WU03:FS01:0x17:*********************** Log Started 2014-12-10T21:50:54Z ***********************
21:50:55:WU03:FS01:0x17:Project: 9201 (Run 433, Clone 2, Gen 49)
21:50:55:WU03:FS01:0x17:Unit: 0x0000005b6652edc45399e712eecca091
21:50:55:WU03:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:50:55:WU03:FS01:0x17:Machine: 1
21:50:55:WU03:FS01:0x17:Reading tar file state.xml
21:50:55:WU03:FS01:0x17:Reading tar file system.xml
21:50:55:WU03:FS01:0x17:Reading tar file integrator.xml
21:50:55:WU03:FS01:0x17:Reading tar file core.xml
21:50:55:WU03:FS01:0x17:Digital signatures verified
21:50:55:WU03:FS01:0x17:Folding@home GPU core17
21:50:55:WU03:FS01:0x17:Version 0.0.52
21:50:55:WU03:FS01:0x17:ERROR:exception: Bad platformId size.
21:50:55:WU03:FS01:0x17:Saving result file logfile_01.txt
21:50:55:WU03:FS01:0x17:Saving result file log.txt
21:50:55:WU03:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
21:50:55:WU00:FS00:0xa4:Completed 800000 out of 5000000 steps (16%)
21:50:55:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:50:55:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:9201 run:433 clone:2 gen:49 core:0x17 unit:0x0000005b6652edc45399e712eecca091
21:50:55:WU03:FS01:Uploading 1.83KiB to 171.67.108.52
21:50:55:WU03:FS01:Connecting to 171.67.108.52:8080
21:50:55:WU01:FS01:Connecting to 171.67.108.200:80
21:50:57:WU01:FS01:Assigned to work server 171.67.108.52
21:50:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 171.67.108.52
21:50:57:WU01:FS01:Connecting to 171.67.108.52:8080
21:50:57:WU02:FS01:Upload 93.98%
21:50:57:WU03:FS01:Upload complete
21:50:57:WU03:FS01:Server responded WORK_ACK (400)
21:50:57:WU03:FS01:Cleaning up
21:50:58:WU01:FS01:Downloading 1.52MiB
21:51:04:WU01:FS01:Download 28.75%
21:51:04:WU02:FS01:Upload 95.47%
21:51:10:WU01:FS01:Download 53.39%
21:51:11:WU02:FS01:Upload 96.96%
21:51:16:WU01:FS01:Download 69.82%
21:51:18:WU02:FS01:Upload 99.20%
21:51:22:WU01:FS01:Download 90.35%
21:51:25:WU02:FS01:Upload complete
21:51:25:WU02:FS01:Server responded WORK_ACK (400)
21:51:25:WU02:FS01:Final credit estimate, 29184.00 points
21:51:25:WU02:FS01:Cleaning up
21:51:25:WU01:FS01:Download complete
21:51:25:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:233 clone:4 gen:64 core:0x17 unit:0x000000586652edc45399df332bc74898
21:51:25:WU01:FS01:Starting
21:51:25:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2676 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:51:25:WU01:FS01:Started FahCore on PID 4852
21:51:25:WU01:FS01:Core PID:4648
21:51:25:WU01:FS01:FahCore 0x17 started
21:51:26:WU01:FS01:0x17:*********************** Log Started 2014-12-10T21:51:25Z ***********************
21:51:26:WU01:FS01:0x17:Project: 9201 (Run 233, Clone 4, Gen 64)
21:51:38:WU02:FS01:0x17:*********************** Log Started 2014-12-10T21:51:38Z ***********************
21:51:38:WU02:FS01:0x17:Project: 9201 (Run 627, Clone 4, Gen 79)
21:51:46:WU01:FS01:0x17:*********************** Log Started 2014-12-10T21:51:45Z ***********************
21:51:46:WU01:FS01:0x17:Project: 9201 (Run 548, Clone 3, Gen 60)
21:51:56:WU02:FS01:0x18:*********************** Log Started 2014-12-10T21:51:55Z ***********************
21:51:56:WU02:FS01:0x18:Project: 10475 (Run 0, Clone 96, Gen 39)
21:51:56:WU02:FS01:0x18:Unit: 0x00000039538b3dba53f38031fba4a137
21:51:56:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
21:51:56:WU02:FS01:0x18:Machine: 1
21:51:56:WU02:FS01:0x18:Reading tar file state.xml
21:51:56:WU02:FS01:0x18:Reading tar file system.xml
21:51:56:WU02:FS01:0x18:Reading tar file integrator.xml
21:51:56:WU02:FS01:0x18:Reading tar file core.xml
21:51:56:WU02:FS01:0x18:Digital signatures verified
21:51:56:WU02:FS01:0x18:Folding@home GPU core18
21:51:56:WU02:FS01:0x18:Version 0.0.3
21:51:56:WU02:FS01:0x18:ERROR:exception: Bad platformId size.
21:51:56:WU02:FS01:0x18:Saving result file logfile_01.txt
21:51:56:WU02:FS01:0x18:Saving result file log.txt
21:51:56:WU02:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
21:51:56:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:51:56:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10475 run:0 clone:96 gen:39 core:0x18 unit:0x00000039538b3dba53f38031fba4a137
21:51:56:WU02:FS01:Uploading 1.83KiB to 140.163.4.234
21:51:56:WU02:FS01:Connecting to 140.163.4.234:8080
21:51:57:WU02:FS01:Upload complete
21:51:58:WU02:FS01:Server responded WORK_ACK (400)
21:51:58:WU02:FS01:Cleaning up
21:52:31:WU00:FS00:0xa4:Completed 850000 out of 5000000 steps (17%)
21:54:06:WU00:FS00:0xa4:Completed 900000 out of 5000000 steps (18%)
. Now Slot 1 is gone, and the CPU continues on it's merry way...
Re: List of WUs?
After looking at my own log file I see several "GPU_MEMTEST_ERROR (124 = 0x7c)" error messages.
I downloaded and ran "memtestG80" on both of my cards and after a few iterations they both show errors. I also ran this on another computer with a GT 640 (GK107), it shows no errors. Does this program work on the new Maxwell cards? Could it be a driver problem? I find it hard to believe that both cards are bad. I ran the "memtestCL" and it showed no errors.
As I mentioned before I have lowered the GPU Clock by 500MHz, and now I also lowered the Memory Clock by 500MHz. I think that this allowed me to actually complete a few Core 18 projects. But another 1 or 2 have now failed.
Any help would be greatly appreciated, Thanks,
David
David
Re: List of WUs?
MemtestG80 was written and tested before Fermi/Kepler/Maxwell were available. You are providing the first report of anybody testing it on Maxwell. Based on you're report, it sounds like it reported an important error which was fixed by lowering the memory clock rate.
By the way, for FAH processing, the memory clock rate is much less important than the core clock rate.
Re: List of WUs?
Thanks Bruce, but just to clarify...
My 2x GTX 970 SC cards show errors with MemTestG80 at "stock" speeds AND underclocked by 500MHz on both the Core Clock and Memory Clock. Since I am using EVGA Precision X16 to control the clock, an offset of -500 on the Memory Clock is as low as I can go... I think. Maybe I will try MSI Afterburner to lower the Memory Clock even more, if that will work on an EVGA card. I know you said the Memory Clock is less important, but I want to try something.
Is there a GPU memory tester that is known to work on Maxwell cards???
Re: List of WUs?
Try the FAHBench application. Downloadable from the FAH Utilities page.
Re: List of WUs?
Upon rereading your problem description, I see I've misinterpreted what you were saying. I apologize.
Most of the FahCores, especially the more recent ones, use OpenCL, so MemtestCL is a valid test, as is FAHBench.
As I said earlier, memtestG80 was released when the only NV GPUs used by FAH that were on the market at the time were G80 hardware so if it doesn't work with Maxwell, that's too bad, but it not likely to be fixed.
